[J6] Processor SDK Linux Automotive boot error
 * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
/dts-v1/;
#include "dra74x.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/clk/ti-dra7-atl.h>
#include <dt-bindings/input/input.h>
	model = "TI DRA742";
	compatible = "ti,dra7-evm", "ti,dra742", "ti,dra74", "ti,dra7";
	memory {
		device_type = "memory";
		reg = <0x0 0x80000000 0x0 0x60000000>; /* 1536 MB */
	reserved_mem: reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		ipu2_cma_pool: ipu2_cma@95800000 {
			compatible = "shared-dma-pool";
			reg = <0x0 0x95800000 0x0 0x3800000>;
			reusable;
			status = "okay";
		dsp1_cma_pool: dsp1_cma@99000000 {
			reg = <0x0 0x99000000 0x0 0x4000000>;
			reusable;
			status = "okay";
		ipu1_cma_pool: ipu1_cma@9d000000 {
			reg = <0x0 0x9d000000 0x0 0x2000000>;
			reusable;
			status = "okay";
		dsp2_cma_pool: dsp2_cma@9f000000 {
			reg = <0x0 0x9f000000 0x0 0x800000>;
			reusable;
			status = "okay";
	aliases {
		display0 = &hdmi0;
		display1 = &fpd_disp;
		sound0 = &snd0;
		sound1 = &hdmi;
		i2c7 = &disp_ser;
	evm_3v3_sd: fixedregulator-sd {
		compatible = "regulator-fixed";
		regulator-name = "evm_3v3_sd";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		enable-active-high;
		gpio = <&pcf_gpio_21 5 GPIO_ACTIVE_HIGH>;
	evm_3v3_sw: fixedregulator-evm_3v3_sw {
		regulator-name = "evm_3v3_sw";
		vin-supply = <&sysen1>;
	aic_dvdd: fixedregulator-aic_dvdd {
		/* TPS77018DBVT */
		regulator-name = "aic_dvdd";
		vin-supply = <&evm_3v3_sw>;
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
	vmmcwl_fixed: fixedregulator-mmcwl {
		regulator-name = "vmmcwl_fixed";
		gpio = <&gpio5 8 0>;	/* gpio5_8 */
		startup-delay-us = <70000>;
		enable-active-high;
	extcon_usb1: extcon_usb1 {
		compatible = "linux,extcon-usb-gpio";
		id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>;
	extcon_usb2: extcon_usb2 {
		id-gpio = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>;
	vtt_fixed: fixedregulator-vtt {
		regulator-name = "vtt_fixed";
		regulator-min-microvolt = <1350000>;
		regulator-max-microvolt = <1350000>;
		regulator-always-on;
		regulator-boot-on;
		enable-active-high;
		vin-supply = <&sysen2>;
		gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
	snd0: sound@0 {
		compatible = "simple-audio-card";
		simple-audio-card,name = "DRA7xx-EVM";
		simple-audio-card,widgets =
			"Headphone", "Headphone Jack",
			"Line", "Line Out",
			"Microphone", "Mic Jack",
			"Line", "Line In";
		simple-audio-card,routing =
			"Headphone Jack",	"HPLOUT",
			"Headphone Jack",	"HPROUT",
			"Line Out",		"LLOUT",
			"Line Out",		"RLOUT",
			"MIC3L",		"Mic Jack",
			"MIC3R",		"Mic Jack",
			"Mic Jack",		"Mic Bias",
			"LINE1L",		"Line In",
			"LINE1R",		"Line In";
		simple-audio-card,format = "dsp_b";
		simple-audio-card,bitclock-master = <&sound0_master>;
		simple-audio-card,frame-master = <&sound0_master>;
		simple-audio-card,bitclock-inversion;
		sound0_master: simple-audio-card,cpu {
			sound-dai = <&mcasp3>;
			system-clock-frequency = <11289600>;
		simple-audio-card,codec {
			sound-dai = <&tlv320aic3106>;
			clocks = <&atl_clkin2_ck>;
	leds {
		compatible = "gpio-leds";
		led@0 {
			label = "dra7:usr1";
			gpios = <&pcf_lcd 4 GPIO_ACTIVE_LOW>;
			default-state = "off";
		led@1 {
			label = "dra7:usr2";
			gpios = <&pcf_lcd 5 GPIO_ACTIVE_LOW>;
		led@2 {
			label = "dra7:usr3";
			gpios = <&pcf_lcd 6 GPIO_ACTIVE_LOW>;
		led@3 {
			label = "dra7:usr4";
			gpios = <&pcf_lcd 7 GPIO_ACTIVE_LOW>;
	gpio_keys {
		compatible = "gpio-keys";
		#address-cells = <1>;
		#size-cells = <0>;
		autorepeat;
		USER1 {
			label = "btnUser1";
			linux,code = <BTN_0>;
			gpios = <&pcf_lcd 2 GPIO_ACTIVE_LOW>;
		USER2 {
			label = "btnUser2";
			linux,code = <BTN_1>;
			gpios = <&pcf_lcd 3 GPIO_ACTIVE_LOW>;
	hdmi0: connector@1 {
		compatible = "hdmi-connector";
		label = "hdmi";
		type = "a";
		port {
			hdmi_connector_in: endpoint {
				remote-endpoint = <&tpd12s015_out>;
	tpd12s015: encoder@1 {
		compatible = "ti,dra7evm-tpd12s015";
		pinctrl-names = "i2c", "ddc";
		pinctrl-0 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_i2c>;
		pinctrl-1 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_ddc>;
		ddc-i2c-bus = <&i2c2>;
		mcasp-gpio = <&mcasp8>;
		gpios = <&pcf_hdmi 4 0>,	/* P4, CT CP HPD */
			<&pcf_hdmi 5 0>,	/* P5, LS OE */
			<&gpio7 12 0>;	/* gpio7_12/sp1_cs2, HPD */
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				tpd12s015_in: endpoint@0 {
					remote-endpoint = <&hdmi_out>;
			port@1 {
				reg = <1>;
				tpd12s015_out: endpoint@0 {
					remote-endpoint = <&hdmi_connector_in>;
&dra7_pmx_core {
	dcan1_pins_default: dcan1_pins_default {
		pinctrl-single,pins = <
			0x3d0   (PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */
			0x418   (PULL_UP | MUX_MODE1) /* wakeup0.dcan1_rx */
	dcan1_pins_sleep: dcan1_pins_sleep {
			0x3d0   (MUX_MODE15 | PULL_UP)	/* dcan1_tx.off */
			0x418   (MUX_MODE15 | PULL_UP)	/* wakeup0.off */
	hdmi_i2c_sel_pin: pinmux_hdmi_i2c_sel_pin {
			/* this pin is used as a GPIO via mcasp */
			0x2fc   (PIN_OUTPUT | MUX_MODE1) /* mcasp8_axr2 */
	hdmi_i2c_pins_i2c: pinmux_hdmi_i2c_pins_default {
			0x408   (PIN_INPUT | MUX_MODE0) /* i2c2_sda.i2c2_sda */
			0x40c   (PIN_INPUT | MUX_MODE0) /* i2c2_scl.i2c2_scl */
	hdmi_i2c_pins_ddc: pinmux_hdmi_i2c_pins_ddc {
			0x408   (PIN_INPUT | MUX_MODE1) /* i2c2_sda.hdmi1_ddc_scl */
			0x40c   (PIN_INPUT | MUX_MODE1) /* i2c2_scl.hdmi1_ddc_sda */
	mmc1_pins_default: pinmux_mmc1_default_pins {
			0x354 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_clk.clk */
			0x358 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_cmd.cmd */
			0x35c (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat0.dat0 */
			0x360 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat1.dat1 */
			0x364 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat2.dat2 */
			0x368 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat3.dat3 */
	mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins {
	mmc1_pins_hs: pinmux_mmc1_hs_pins {
			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_clk.clk */
			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_cmd.cmd */
			0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat0.dat0 */
			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat1.dat1 */
			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat2.dat2 */
			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat3.dat3 */
	mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
	mmc1_pins_sdr50: pinmux_mmc1_sdr50_pins {
			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_clk.clk */
			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_cmd.cmd */
			0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat0.dat0 */
			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat1.dat1 */
			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat2.dat2 */
			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat3.dat3 */
	mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
			0x354 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_clk.clk */
			0x358 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_cmd.cmd */
			0x35c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat0.dat0 */
			0x360 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat1.dat1 */
			0x364 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat2.dat2 */
			0x368 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat3.dat3 */
	mmc1_pins_sdr104: pinmux_mmc1_sdr104_pins {
	mmc2_pins_default: mmc2_pins_default {
			0x9c (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
			0xb0 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
			0xa0 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
			0xa4 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
			0xa8 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
			0xac (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
			0x8c (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
			0x90 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
			0x94 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
			0x98 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
	mmc2_pins_hs: mmc2_pins_hs {
	mmc2_pins_ddr_1_8v: pinmux_mmc2_ddr_1_8v_pins {
			0x9c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a23.mmc2_clk */
			0xb0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
			0xa0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
			0xa4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
			0xa8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
			0xac (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
			0x8c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
			0x90 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
			0x94 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
			0x98 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
	mmc2_pins_hs200_1_8v: mmc2_pins_hs200_1_8v {
	mmc4_pins_default: mmc4_pins_default {
			0x3e8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
			0x3ec (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
			0x3f0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
			0x3f4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
			0x3f8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
			0x3fC (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
	mmc4_pins_hs: mmc4_pins_hs {
	mmc4_pins_sdr12: mmc4_pins_sdr12 {
			0x3eC (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
			0x3fc (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
	mmc4_pins_sdr25: mmc4_pins_sdr25 {
&dra7_iodelay_core {
	uart3_pins_default: pinmux_uart3_pins {
			0x34c (PIN_INPUT | MUX_MODE4) /* mcasp5_axr0.uart3_rxd */
			0x350 (PIN_OUTPUT | MUX_MODE4) /* mcasp5_axr1.uart3_txd */
	mmc1_iodelay_ddr50_rev11_conf: mmc1_iodelay_ddr50_rev11_conf {
			0x618 (A_DELAY(572) | G_DELAY(540))	/* CFG_MMC1_CLK_IN */
			0x624 (A_DELAY(0) | G_DELAY(600))	/* CFG_MMC1_CMD_IN */
			0x630 (A_DELAY(403) | G_DELAY(120))	/* CFG_MMC1_DAT0_IN */
			0x63c (A_DELAY(23) | G_DELAY(60))	/* CFG_MMC1_DAT1_IN */
			0x648 (A_DELAY(25) | G_DELAY(60))	/* CFG_MMC1_DAT2_IN */
			0x654 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_IN */
			0x620 (A_DELAY(1525) | G_DELAY(0))	/* CFG_MMC1_CLK_OUT */
			0x628 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OEN */
			0x62c (A_DELAY(55) | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
			0x634 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT0_OEN */
			0x638 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT0_OUT */
			0x640 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT1_OEN */
			0x644 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT1_OUT */
			0x64c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OEN */
			0x650 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OUT */
			0x658 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OEN */
			0x65c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OUT */
	mmc1_iodelay_ddr50_rev20_conf: mmc1_iodelay_ddr50_rev20_conf {
			0x618 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CLK_IN */
			0x620 (A_DELAY(1271) | G_DELAY(0))	/* CFG_MMC1_CLK_OUT */
			0x624 (A_DELAY(229) | G_DELAY(0))	/* CFG_MMC1_CMD_IN */
			0x62C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OUT */
			0x630 (A_DELAY(850) | G_DELAY(0))	/* CFG_MMC1_DAT0_IN */
			0x638 (A_DELAY(20) | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
			0x63C (A_DELAY(468) | G_DELAY(0))	/* CFG_MMC1_DAT1_IN */
			0x648 (A_DELAY(466) | G_DELAY(0))	/* CFG_MMC1_DAT2_IN */
			0x64C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OEN */
			0x654 (A_DELAY(399) | G_DELAY(0))	/* CFG_MMC1_DAT3_IN */
			0x65C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OUT */
	mmc1_iodelay_sdr104_rev11_conf: mmc1_iodelay_sdr104_rev11_conf {
			0x620 (A_DELAY(1063) | G_DELAY(17))	/* CFG_MMC1_CLK_OUT */
			0x62c (A_DELAY(23) | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
			0x644 (A_DELAY(2) | G_DELAY(0))		/* CFG_MMC1_DAT1_OUT */
	mmc1_iodelay_sdr104_rev20_conf: mmc1_iodelay_sdr104_rev20_conf {
			0x620 (A_DELAY(600) | G_DELAY(400))	/* CFG_MMC1_CLK_OUT */
			0x62c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OUT */
			0x638 (A_DELAY(30) | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
	mmc2_iodelay_hs200_1_8v_rev11_conf: mmc2_iodelay_hs200_1_8v_rev11_conf {
			0x190 (A_DELAY(621) | G_DELAY(600))	/* CFG_GPMC_A19_OEN */
			0x194 (A_DELAY(300) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
			0x1a8 (A_DELAY(739) | G_DELAY(600))	/* CFG_GPMC_A20_OEN */
			0x1ac (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
			0x1b4 (A_DELAY(812) | G_DELAY(600))	/* CFG_GPMC_A21_OEN */
			0x1b8 (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
			0x1c0 (A_DELAY(954) | G_DELAY(600))	/* CFG_GPMC_A22_OEN */
			0x1c4 (A_DELAY(60)  | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
			0x1d0 (A_DELAY(1340)| G_DELAY(420))	/* CFG_GPMC_A23_OUT */
			0x1d8 (A_DELAY(935) | G_DELAY(600))	/* CFG_GPMC_A24_OEN */
			0x1dc (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A24_OUT */
			0x1e4 (A_DELAY(525) | G_DELAY(600))	/* CFG_GPMC_A25_OEN */
			0x1e8 (A_DELAY(120) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
			0x1f0 (A_DELAY(767) | G_DELAY(600))	/* CFG_GPMC_A26_OEN */
			0x1f4 (A_DELAY(225) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
			0x1fc (A_DELAY(565) | G_DELAY(600))	/* CFG_GPMC_A27_OEN */
			0x200 (A_DELAY(60) | G_DELAY(0))	/* CFG_GPMC_A27_OUT */
			0x364 (A_DELAY(969) | G_DELAY(600))	/* CFG_GPMC_CS1_OEN */
			0x368 (A_DELAY(180) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
	mmc2_iodelay_hs200_1_8v_rev20_conf: mmc2_iodelay_hs200_1_8v_rev20_conf {
			0x190 (A_DELAY(274) | G_DELAY(0))       /* CFG_GPMC_A19_OEN */
			0x194 (A_DELAY(162) | G_DELAY(0))       /* CFG_GPMC_A19_OUT */
			0x1a8 (A_DELAY(401) | G_DELAY(0))       /* CFG_GPMC_A20_OEN */
			0x1ac (A_DELAY(73) | G_DELAY(0))        /* CFG_GPMC_A20_OUT */
			0x1b4 (A_DELAY(465) | G_DELAY(0))       /* CFG_GPMC_A21_OEN */
			0x1b8 (A_DELAY(115) | G_DELAY(0))       /* CFG_GPMC_A21_OUT */
			0x1c0 (A_DELAY(633) | G_DELAY(0))       /* CFG_GPMC_A22_OEN */
			0x1c4 (A_DELAY(47) | G_DELAY(0))        /* CFG_GPMC_A22_OUT */
			0x1d0 (A_DELAY(935) | G_DELAY(280))     /* CFG_GPMC_A23_OUT */
			0x1d8 (A_DELAY(621) | G_DELAY(0))       /* CFG_GPMC_A24_OEN */
			0x1e4 (A_DELAY(183) | G_DELAY(0))       /* CFG_GPMC_A25_OEN */
			0x1e8 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A25_OUT */
			0x1f0 (A_DELAY(467) | G_DELAY(0))       /* CFG_GPMC_A26_OEN */
			0x1f4 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A26_OUT */
			0x1fc (A_DELAY(262) | G_DELAY(0))       /* CFG_GPMC_A27_OEN */
			0x200 (A_DELAY(46) | G_DELAY(0))        /* CFG_GPMC_A27_OUT */
			0x364 (A_DELAY(684) | G_DELAY(0))       /* CFG_GPMC_CS1_OEN */
			0x368 (A_DELAY(76) | G_DELAY(0))        /* CFG_GPMC_CS1_OUT */
	mmc2_iodelay_ddr_1_8v_rev11_conf: mmc2_iodelay_ddr_1_8v_rev11_conf {
			0x18c (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A19_IN */
			0x1a4 (A_DELAY(274) | G_DELAY(240))	/* CFG_GPMC_A20_IN */
			0x1b0 (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A21_IN */
			0x1bc (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A22_IN */
			0x1c8 (A_DELAY(514) | G_DELAY(360))	/* CFG_GPMC_A23_IN */
			0x1d4 (A_DELAY(187) | G_DELAY(120))	/* CFG_GPMC_A24_IN */
			0x1e0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A25_IN */
			0x1ec (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A26_IN */
			0x1f8 (A_DELAY(121) | G_DELAY(60))	/* CFG_GPMC_A27_IN */
			0x360 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_IN */
			0x190 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A19_OEN */
			0x194 (A_DELAY(174) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
			0x1a8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A20_OEN */
			0x1ac (A_DELAY(168) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
			0x1b4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A21_OEN */
			0x1b8 (A_DELAY(136) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
			0x1c0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A22_OEN */
			0x1c4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A22_OUT */
			0x1d0 (A_DELAY(879) | G_DELAY(0))	/* CFG_GPMC_A23_OUT */
			0x1d8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A24_OEN */
			0x1e4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A25_OEN */
			0x1e8 (A_DELAY(34) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
			0x1f0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A26_OEN */
			0x1f4 (A_DELAY(120) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
			0x1fc (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A27_OEN */
			0x200 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A27_OUT */
			0x364 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_OEN */
			0x368 (A_DELAY(11) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
	mmc2_iodelay_ddr_1_8v_rev20_conf: mmc2_iodelay_ddr_1_8v_rev20_conf {
			0x18c (A_DELAY(270) | G_DELAY(0))	/* CFG_GPMC_A19_IN */
			0x1a4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A20_IN */
			0x1b0 (A_DELAY(170) | G_DELAY(0))	/* CFG_GPMC_A21_IN */
			0x1bc (A_DELAY(758) | G_DELAY(0))	/* CFG_GPMC_A22_IN */
			0x1c8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A23_IN */
			0x1d4 (A_DELAY(81) | G_DELAY(0))	/* CFG_GPMC_A24_IN */
			0x1e0 (A_DELAY(286) | G_DELAY(0))	/* CFG_GPMC_A25_IN */
			0x1ec (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A26_IN */
			0x1f8 (A_DELAY(123) | G_DELAY(0))	/* CFG_GPMC_A27_IN */
			0x360 (A_DELAY(346) | G_DELAY(0))	/* CFG_GPMC_CS1_IN */
			0x194 (A_DELAY(55) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
			0x1ac (A_DELAY(422) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
			0x1b4 (A_DELAY(642) | G_DELAY(0))	/* CFG_GPMC_A21_OEN */
			0x1b8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A21_OUT */
			0x1c4 (A_DELAY(128) | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
			0x1d0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A23_OUT */
			0x1dc (A_DELAY(395) | G_DELAY(0))	/* CFG_GPMC_A24_OUT */
			0x1f0 (A_DELAY(623) | G_DELAY(0))	/* CFG_GPMC_A26_OEN */
			0x1fc (A_DELAY(54) | G_DELAY(0))	/* CFG_GPMC_A27_OEN */
			0x368 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_OUT */
	mmc4_iodelay_ds_rev11_conf: mmc4_iodelay_ds_rev11_conf {
			0x840 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_CTSN_IN */
			0x848 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_CTSN_OUT */
			0x84c (A_DELAY(96) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
			0x850 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_RTSN_OEN */
			0x854 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_RTSN_OUT */
			0x870 (A_DELAY(582) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
			0x874 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_CTSN_OEN */
			0x878 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_CTSN_OUT */
			0x87c (A_DELAY(391) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
			0x880 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RTSN_OEN */
			0x884 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RTSN_OUT */
			0x888 (A_DELAY(561) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
			0x88c (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RXD_OEN */
			0x890 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RXD_OUT */
			0x894 (A_DELAY(588) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
			0x898 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_TXD_OEN */
			0x89c (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_TXD_OUT */
	mmc4_iodelay_ds_rev20_conf: mmc4_iodelay_ds_rev20_conf {
			0x84c (A_DELAY(307) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
			0x870 (A_DELAY(785) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
			0x87c (A_DELAY(613) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
			0x888 (A_DELAY(683) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
			0x894 (A_DELAY(835) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
	mmc4_iodelay_sdr12_hs_sdr25_rev11_conf: mmc4_iodelay_sdr12_hs_sdr25_rev11_conf {
			0x848 (A_DELAY(2651) | G_DELAY(0))	/* CFG_UART1_CTSN_OUT */
			0x84c (A_DELAY(1572) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
			0x870 (A_DELAY(1913) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
			0x87c (A_DELAY(1721) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
			0x888 (A_DELAY(1891) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
			0x894 (A_DELAY(1919) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
	mmc4_iodelay_sdr12_hs_sdr25_rev20_conf: mmc4_iodelay_sdr12_hs_sdr25_rev20_conf {
			0x848 (A_DELAY(1147) | G_DELAY(0))	/* CFG_UART1_CTSN_OUT */
			0x84c (A_DELAY(1834) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
			0x870 (A_DELAY(2165) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
			0x87c (A_DELAY(1929) | G_DELAY(64))	/* CFG_UART2_RTSN_IN */
			0x888 (A_DELAY(1935) | G_DELAY(128))	/* CFG_UART2_RXD_IN */
			0x894 (A_DELAY(2172) | G_DELAY(44))	/* CFG_UART2_TXD_IN */
&i2c1 {
	status = "okay";
	clock-frequency = <400000>;
	tps659038: tps659038@58 {
		compatible = "ti,tps659038";
		reg = <0x58>;
		tps659038_pmic {
			compatible = "ti,tps659038-pmic";
			regulators {
				smps123_reg: smps123 {
					/* VDD_MPU */
					regulator-name = "smps123";
					regulator-min-microvolt = < 850000>;
					regulator-max-microvolt = <1250000>;
					regulator-boot-on;
				smps45_reg: smps45 {
					/* VDD_DSPEVE */
					regulator-name = "smps45";
					regulator-boot-on;
				smps6_reg: smps6 {
					/* VDD_GPU - over VDD_SMPS6 */
					regulator-name = "smps6";
					regulator-min-microvolt = <850000>;
					regulator-boot-on;
				smps7_reg: smps7 {
					/* CORE_VDD */
					regulator-name = "smps7";
					regulator-max-microvolt = <1150000>;
					regulator-boot-on;
				smps8_reg: smps8 {
					/* VDD_IVAHD */
					regulator-name = "smps8";
					regulator-boot-on;
				smps9_reg: smps9 {
					/* VDDS1V8 */
					regulator-name = "smps9";
					regulator-boot-on;
				ldo1_reg: ldo1 {
					/* LDO1_OUT --> SDIO  */
					regulator-name = "ldo1";
					regulator-boot-on;
				ldo2_reg: ldo2 {
					/* VDD_RTCIO */
					/* LDO2 -> VDDSHV5, LDO2 also goes to CAN_PHY_3V3 */
					regulator-name = "ldo2";
					regulator-boot-on;
				ldo3_reg: ldo3 {
					/* VDDA_1V8_PHY */
					regulator-name = "ldo3";
					regulator-boot-on;
				ldo9_reg: ldo9 {
					/* VDD_RTC */
					regulator-name = "ldo9";
					regulator-min-microvolt = <1050000>;
					regulator-max-microvolt = <1050000>;
					regulator-boot-on;
					regulator-allow-bypass;
				ldoln_reg: ldoln {
					/* VDDA_1V8_PLL */
					regulator-name = "ldoln";
					regulator-boot-on;
				ldousb_reg: ldousb {
					/* VDDA_3V_USB: VDDA_USBHS33 */
					regulator-name = "ldousb";
					regulator-boot-on;
				/* REGEN1 is unused */
				regen2: regen2 {
					/* Needed for PMIC internal resources */
					regulator-name = "regen2";
					regulator-boot-on;
				/* REGEN3 is unused */
				sysen1: sysen1 {
					/* PMIC_REGEN_3V3 */
					regulator-name = "sysen1";
					regulator-boot-on;
				sysen2: sysen2 {
					/* PMIC_REGEN_DDR */
					regulator-name = "sysen2";
					regulator-boot-on;
	pcf_lcd: gpio@20 {
		compatible = "nxp,pcf8575";
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
		interrupt-parent = <&gpio6>;
		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
		interrupt-controller;
		#interrupt-cells = <2>;
	pcf_gpio_21: gpio@21 {
		compatible = "ti,pcf8575";
		reg = <0x21>;
		lines-initial-states = <0x1408>;
		gpio-controller;
		#gpio-cells = <2>;
	tlv320aic3106: tlv320aic3106@19 {
		#sound-dai-cells = <0>;
		compatible = "ti,tlv320aic3106";
		reg = <0x19>;
		adc-settle-ms = <40>;
		ai3x-micbias-vg = <1>;		/* 2.0V */
		status = "okay";
		/* Regulators */
		AVDD-supply = <&evm_3v3_sw>;
		IOVDD-supply = <&evm_3v3_sw>;
		DRVDD-supply = <&evm_3v3_sw>;
		DVDD-supply = <&aic_dvdd>;
i2c_p3_exp: &i2c2 {
	status = "okay";
	pcf_hdmi: gpio@26 {
		reg = <0x26>;
		gpio-controller;
		#gpio-cells = <2>;
		p1 {
			/* vin6_sel_s0: high: VIN6, low: audio */
			gpio-hog;
			gpios = <1 GPIO_ACTIVE_HIGH>;
			output-low;
			line-name = "vin6_sel_s0";
	ov10633@37 {
		compatible = "ovti,ov10633";
		reg = <0x37>;
		mux-gpios = <&pcf_hdmi 3 GPIO_ACTIVE_LOW>; /* CAM_FPD_MUX_S0 */
		port {
			onboardLI: endpoint {
				remote-endpoint = <&vin1a>;
				hsync-active = <1>;
				vsync-active = <1>;
				pclk-sample = <0>;
	disp_ser: serializer@1b {
		compatible = "ti,ds90uh925q";
		reg = <0x1b>;
		#size-cells = <0>;
		ranges = <0x2c 0x2c>,
			<0x1c 0x1c>;
		disp_des: deserializer@2c {
			compatible = "ti,ds90uh928q";
			reg = <0x2c>;
			slave-mode;
		/* TLC chip for LCD panel power and backlight */
		fpd_disp: tlc59108@1c {
			status = "disabled";
			reg = <0x1c>;
			compatible = "ti,tlc59108-fpddisp";
			enable-gpios = <&pcf_gpio_21 0 GPIO_ACTIVE_LOW>;
			/* P0, SEL_GPMC_AD_VID_S0 */
			port@lcd3 {
					fpd_in: endpoint {
					remote-endpoint = <&dpi_out3>;
&i2c3 {
	status = "okay";
&mcspi1 {
	status = "okay";
&mcspi2 {
	status = "okay";
&uart1 {
&uart2 {
	status = "okay";
&uart3 {
	status = "okay";
	/* gpios = <&pcf_gpio_21 14 GPIO_ACTIVE_LOW>; */
	pinctrl-names = "default";
	pinctrl-0 = <&uart3_pins_default>;
&mmc1 {
	status = "okay";
	vmmc-supply = <&evm_3v3_sd>;
	vmmc_aux-supply = <&ldo1_reg>;
	bus-width = <4>;
	 * SDCD signal is not being used here - using the fact that GPIO mode
	 * is always hardwired.
	cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
	max-frequency = <192000000>;
	pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50-rev11", "sdr104-rev11", "ddr50", "sdr104";
	pinctrl-0 = <&mmc1_pins_default>;
	pinctrl-1 = <&mmc1_pins_hs>;
	pinctrl-2 = <&mmc1_pins_sdr12>;
	pinctrl-3 = <&mmc1_pins_sdr25>;
	pinctrl-4 = <&mmc1_pins_sdr50>;
	pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev11_conf>;
	pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev11_conf>;
	pinctrl-7 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev20_conf>;
	pinctrl-8 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
&mmc2 {
	status = "okay";
	vmmc-supply = <&evm_3v3_sw>;
	bus-width = <8>;
	pinctrl-names = "default", "hs", "ddr_1_8v-rev11", "ddr_1_8v", "hs200_1_8v-rev11", "hs200_1_8v";
	pinctrl-0 = <&mmc2_pins_default>;
	pinctrl-1 = <&mmc2_pins_hs>;
	pinctrl-2 = <&mmc2_pins_ddr_1_8v &mmc2_iodelay_ddr_1_8v_rev11_conf>;
	pinctrl-3 = <&mmc2_pins_ddr_1_8v &mmc2_iodelay_ddr_1_8v_rev20_conf>;
	pinctrl-4 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_rev11_conf>;
	pinctrl-5 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_rev20_conf>;
&mmc4 {
	status = "okay";
	vmmc-supply = <&vmmcwl_fixed>;
	bus-width = <4>;
	cap-power-off-card;
	keep-power-in-suspend;
	ti,non-removable;
	pinctrl-names = "default-rev11", "default", "hs-rev11", "hs", "sdr12-rev11", "sdr12", "sdr25-rev11", "sdr25";
	pinctrl-0 = <&mmc4_pins_default &mmc4_iodelay_ds_rev11_conf>;
	pinctrl-1 = <&mmc4_pins_default &mmc4_iodelay_ds_rev20_conf>;
	pinctrl-2 = <&mmc4_pins_hs &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
	pinctrl-3 = <&mmc4_pins_hs &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
	pinctrl-4 = <&mmc4_pins_sdr12 &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
	pinctrl-5 = <&mmc4_pins_sdr12 &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
	pinctrl-6 = <&mmc4_pins_sdr25 &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
	pinctrl-7 = <&mmc4_pins_sdr25 &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
	#size-cells = <0>;
	wlcore: wlcore@0 {
		compatible = "ti,wl1835";
		reg = <2>;
		interrupt-parent = <&gpio5>;
		interrupts = <7 IRQ_TYPE_LEVEL_HIGH>;
&oppdm_mpu {
	vdd-supply = <&smps123_reg>;
&oppdm_dspeve {
	vdd-supply = <&smps45_reg>;
&oppdm_gpu {
	vdd-supply = <&smps6_reg>;
&oppdm_ivahd {
	vdd-supply = <&smps8_reg>;
&oppdm_core {
	vdd-supply = <&smps7_reg>;
&qspi {
	status = "okay";
	spi-max-frequency = <64000000>;
	m25p80@0 {
		compatible = "s25fl256s1";
		reg = <0>;
		spi-tx-bus-width = <1>;
		spi-rx-bus-width = <4>;
		#size-cells = <1>;
		/* MTD partition table.
		 * The ROM checks the first four physical blocks
		 * for a valid file to boot and the flash here is
		 * 64KiB block size.
		partition@0 {
			label = "QSPI.SPL";
			reg = <0x00000000 0x000040000>;
		partition@1 {
			label = "QSPI.u-boot";
			reg = <0x00040000 0x00100000>;
		partition@2 {
			label = "QSPI.u-boot-spl-os";
			reg = <0x00140000 0x00080000>;
		partition@3 {
			label = "QSPI.u-boot-env";
			reg = <0x001c0000 0x00010000>;
		partition@4 {
			label = "QSPI.u-boot-env.backup1";
			reg = <0x001d0000 0x0010000>;
		partition@5 {
			label = "QSPI.kernel";
			reg = <0x001e0000 0x0800000>;
		partition@6 {
			label = "QSPI.file-system";
			reg = <0x009e0000 0x01620000>;
&omap_dwc3_1 {
	extcon = <&extcon_usb1>;
&omap_dwc3_2 {
	extcon = <&extcon_usb2>;
&usb1 {
	dr_mode = "otg";
&usb2 {
	dr_mode = "host";
&elm {
	status = "okay";
&gpmc {
	status = "okay";
	ranges = <0 0 0x08000000 0x01000000>;	/* minimum GPMC partition = 16MB */
	nand@0,0 {
		compatible = "ti,omap2-nand";
		reg = <0 0 4>;		/* device IO registers */
		interrupt-parent = <&gpmc>;
		interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
			     <1 IRQ_TYPE_NONE>; /* termcount */
		rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 pin */
		ti,nand-ecc-opt = "bch8";
		ti,elm-id = <&elm>;
		nand-bus-width = <16>;
		gpmc,device-width = <2>;
		gpmc,sync-clk-ps = <0>;
		gpmc,cs-on-ns = <0>;
		gpmc,cs-rd-off-ns = <80>;
		gpmc,cs-wr-off-ns = <80>;
		gpmc,adv-on-ns = <0>;
		gpmc,adv-rd-off-ns = <60>;
		gpmc,adv-wr-off-ns = <60>;
		gpmc,we-on-ns = <10>;
		gpmc,we-off-ns = <50>;
		gpmc,oe-on-ns = <4>;
		gpmc,oe-off-ns = <40>;
		gpmc,access-ns = <40>;
		gpmc,wr-access-ns = <80>;
		gpmc,rd-cycle-ns = <80>;
		gpmc,wr-cycle-ns = <80>;
		gpmc,bus-turnaround-ns = <0>;
		gpmc,cycle2cycle-delay-ns = <0>;
		gpmc,clk-activation-ns = <0>;
		gpmc,wr-data-mux-bus-ns = <0>;
		/* MTD partition table */
		/* All SPL-* partitions are sized to minimal length
		 * which can be independently programmable. For
		 * NAND flash this is equal to size of erase-block */
		#size-cells = <1>;
		partition@0 {
			label = "NAND.SPL";
			reg = <0x00000000 0x000020000>;
		partition@1 {
			label = "NAND.SPL.backup1";
			reg = <0x00020000 0x00020000>;
		partition@2 {
			label = "NAND.SPL.backup2";
			reg = <0x00040000 0x00020000>;
		partition@3 {
			label = "NAND.SPL.backup3";
			reg = <0x00060000 0x00020000>;
		partition@4 {
			label = "NAND.u-boot-spl-os";
			reg = <0x00080000 0x00040000>;
		partition@5 {
			label = "NAND.u-boot";
			reg = <0x000c0000 0x00100000>;
		partition@6 {
			label = "NAND.u-boot-env";
			reg = <0x001c0000 0x00020000>;
		partition@7 {
			label = "NAND.u-boot-env.backup1";
			reg = <0x001e0000 0x00020000>;
		partition@8 {
			label = "NAND.kernel";
			reg = <0x00200000 0x00800000>;
		partition@9 {
			label = "NAND.file-system";
			reg = <0x00a00000 0x0f600000>;
&usb2_phy1 {
	phy-supply = <&ldousb_reg>;
&usb2_phy2 {
&gpio7 {
	ti,no-reset-on-init;
	ti,no-idle-on-init;
&mac {
	status = "okay";
	dual_emac;
&cpsw_emac0 {
	phy_id = <&davinci_mdio>, <2>;
	phy-mode = "rgmii";
	dual_emac_res_vlan = <1>;
&cpsw_emac1 {
	phy_id = <&davinci_mdio>, <3>;
	phy-mode = "rgmii";
	dual_emac_res_vlan = <2>;
&dcan1 {
	status = "ok";
	pinctrl-names = "default", "sleep", "active";
	pinctrl-0 = <&dcan1_pins_sleep>;
	pinctrl-1 = <&dcan1_pins_sleep>;
	pinctrl-2 = <&dcan1_pins_default>;
&atl {
	assigned-clocks = <&abe_dpll_sys_clk_mux>,
			  <&atl_gfclk_mux>,
			  <&dpll_abe_ck>,
			  <&dpll_abe_m2x2_ck>,
			  <&atl_clkin1_ck>,
			  <&atl_clkin2_ck>;
	assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>;
	assigned-clock-rates = <0>, <0>, <180633600>, <361267200>,
			       <11289600>, <11289600>;
	status = "okay";
	atl2 {
		bws = <DRA7_ATL_WS_MCASP2_FSX>;
		aws = <DRA7_ATL_WS_MCASP3_FSX>;
&mcasp3 {
	assigned-clocks = <&mcasp3_ahclkx_mux>;
	assigned-clock-parents = <&atl_clkin2_ck>;
	status = "okay";
	op-mode = <0>;          /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	/* 4 serializer */
	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
		1 2 0 0
	tx-num-evt = <32>;
	rx-num-evt = <32>;
&mcasp8 {
	/* not used for audio. only the AXR2 pin is used as GPIO */
	status = "okay";
&mailbox5 {
	status = "okay";
	mbox_ipu1_ipc3x: mbox_ipu1_ipc3x {
		status = "okay";
	mbox_dsp1_ipc3x: mbox_dsp1_ipc3x {
		status = "okay";
&mailbox6 {
	status = "okay";
	mbox_ipu2_ipc3x: mbox_ipu2_ipc3x {
		status = "okay";
	mbox_dsp2_ipc3x: mbox_dsp2_ipc3x {
		status = "okay";
&mmu0_dsp1 {
	status = "okay";
&mmu1_dsp1 {
	status = "okay";
&mmu0_dsp2 {
	status = "okay";
&mmu1_dsp2 {
	status = "okay";
&mmu_ipu1 {
	status = "okay";
&mmu_ipu2 {
	status = "okay";
&ipu2 {
	status = "okay";
	memory-region = <&ipu2_cma_pool>;
	mboxes = <&mailbox6 &mbox_ipu2_ipc3x>;
	timers = <&timer3>;
	watchdog-timers = <&timer4>, <&timer9>;
&ipu1 {
	status = "okay";
	memory-region = <&ipu1_cma_pool>;
	mboxes = <&mailbox5 &mbox_ipu1_ipc3x>;
	timers = <&timer11>;
	watchdog-timers = <&timer7>, <&timer8>;
&dsp1 {
	status = "okay";
	memory-region = <&dsp1_cma_pool>;
	mboxes = <&mailbox5 &mbox_dsp1_ipc3x>;
	timers = <&timer5>;
	watchdog-timers = <&timer10>;
&dsp2 {
	status = "okay";
	memory-region = <&dsp2_cma_pool>;
	mboxes = <&mailbox6 &mbox_dsp2_ipc3x>;
	timers = <&timer6>;
&dss {
	status = "okay";
	vdda_video-supply = <&ldoln_reg>;
	ports {
		#size-cells = <0>;
		port@lcd3 {
			reg = <2>;
			dpi_out3: endpoint {
				remote-endpoint = <&fpd_in>;
				data-lines = <24>;
&hdmi {
	status = "ok";
	vdda-supply = <&ldo3_reg>;
	port {
		hdmi_out: endpoint {
			remote-endpoint = <&tpd12s015_in>;
&vip1 {
	status = "okay";
video_in: &vin1a {
	status = "okay";
	endpoint@0 {
		slave-mode;
		remote-endpoint = <&onboardLI>;
#include "dra7xx-jamr3.dtsi"
&tvp_5158{
	mux-gpios = <&pcf_hdmi 3 GPIO_ACTIVE_HIGH>,	/*CAM_FPD_MUX_S0*/
		    <&pcf_jamr3_21 8 GPIO_ACTIVE_LOW>;	/*SEL_TVP_FPD*/
Hi ,
We want to integrate our code into processor SDK linux automotive release(kernel 4.4) and running on our custom board.
But our image always stuck in  "starting kernel ........."
In the GLSDK , we modified the driver/clk/ti/clk-7xx.c to fix this stuck issue  by disable below 3 clock source.
abe_dpll_mux = clk_get_sys(NULL, "abe_dpll_sys_clk_mux");
sys_clkin2 = clk_get_sys(NULL, "sys_clkin2");
dpll_ck = clk_get_sys(NULL, "dpll_abe_ck");
#ifdef CONFIG_WNC_MOD
#else
rc = clk_set_parent(abe_dpll_mux, sys_clkin2);
if (!rc)
rc = clk_set_rate(dpll_ck, DRA7_DPLL_ABE_DEFFREQ);
if (rc)
pr_err("%s: failed to configure ABE DPLL!\n", __func__);
dpll_ck = clk_get_sys(NULL, "dpll_abe_m2x2_ck");
rc = clk_set_rate(dpll_ck, DRA7_DPLL_ABE_DEFFREQ * 2);
if (rc)
pr_err("%s: failed to configure ABE DPLL m2x2!\n", __func__);
#endif
But in the linux automotive sdk release,  I did not find the same code to let me hack.
Besides , I also try to use the dts in the original  automotive sdk (only change uart setting ) and I got the same error.
Could  you give us some advise ?
Andy
  • Hi Andy,
    The code to set parents and clock rates is now moved to device tree file.
    There are new DT bindings available to set parent clocks.
    Look for following node:
    &atl {
                              <&atl_gfclk_mux>,
                              <&dpll_abe_ck>,
                              <&atl_clkin2_ck>;
            assigned-clock-rates = <0>, <0>, <180633600>, <361267200>, <5644
    in file arch/arm/boot/dts/dra7-evm.dts
    Removing assigned-* entries should achieve the same result as removing clk_set* code form clk-7xx.c file in earlier sdk version.
    RK
  • Hi RK,
    Thanks for your reply.
    But this way still can not boot up. I wondering the issue is not the kernel , I think it failed before decompressing kernel.
    Because there is no kernel debug message print out.
    May I know that is something changed in uboot of processor SDK linux automotive sdk ?
    Because I use the uboot of GLSDK + kernel of processor SDK automotive sdk combination.
    Please give some advice.
    Andy
  • Andy
    we have not extensively validated using older uboot(from GLSDK which is based on 2014.07 version of uboot ) with the processor SDK linux automotive sdk(which is based on more recent 2016.05 version of uboot).
    With the newer boot, we now have a device based approach for boot loader as well. Other changes in uboot include usage of HW levelling for DDR and Change in QSPI SPL partition size.
    Were you able to get the GLSDK uboot+kernel working on the same setup before
    Sriram
  • Hi Andy,
    Make sure you are using the correct dtb file, similar hang would be seen if you use incorrect device tree file.
    You may not see the kernel prints until the console is setup by kernel (earlyprintk should be enabled). Even before the console is setup the messages are stored in __log_buf, address of logbuf can be found in System.map file in kernel directory.
    There are two ways to find out where the execution is stuck.
    1. Connect a JTAG, read __log_buf in the memory window.
    2. Do a warm reset (not POR) and stop at u-boot prompt. Read the logbuf address (in u-boot you need to use physical address)
    md 0x8091fe04 (where logbuf address is 0xc091fe04, you may keep pressing enter key to read further),
    if kernel decompression went through then you should see the boot up log here.
    RK
  • Hi RK, Sriram
    In the beginning , I use old uboot + Processor SDK Linux Automotive kernel and then it will stuck at "starting kernel....."
    Now I follow Sriram's suggestion, I switch to latest uboot 2016.05 + kernel 4.4 .
    But I encounter another issue which is MLO can not bring up the u-boot.img.
    Please see the log ......( I add some debug message....)
    U-Boot SPL 2016.05 (Sep 13 2016 - 15:48:23)
    DRA752-GP ES2.0
    MMC Device 1 not found
    *** Warning - No MMC card found, using default environment
    Trying to boot from MMC1
    file_fat_read:1341
    reading u-boot.img
    Size: 645796, got: 64
    fat_read_file:1355
    reading u-boot.img
    Size: 645796, got: 1252
    fat_read_file:1355
    reading u-boot.img
    Size: 645796, got: 415612
    fat_read_file:1355
    reading u-boot.img
    Size: 645796, got: 78540
    Could you provide some idea ?
    Andy
  • Hi ,
    After I turn off the dt support, the bootloader can bring up the kernel successfully.
    Thanks for your help.
    Andy
