hi all
i have written a progam in c and call a function ( which is written in assembly language). i have pass the three array to the funcion mul . When program return back to the main program it change the address of array. my progeam is follwing.
main program in c:
// C code for generation of two arrays. #include<stdio.h> #define row 8 //#define col 8 void main() { int A[row]; int B[row]; int C[row]; int i; int ele,*a; ele=row; a = &A[0]; for(i=0;i<row;i+=2) { A[i]= 64; B[i]= 64; A[i+1]= 32; B[i+1]= 32; } mul(A,B,C,ele); // return 0; } function in assembly :
; Assembly Program to add two matrix.
; mul(A,B,C,max)
; C= A *B, max = length of array.
;=====================CYCLES=============================
; no of cycle required is
; cycles= 12+ array size*0.75 .
;====================ASSUMPTION==========================
; The array size must be multiple of 4.
; Both array having same size...
;========= SYMBOLIC REGISTER ASSIGNMENTS ================
.asg A4, A_Input
.asg B4, B_Input
.asg A6, A_output
.asg B16, B_output
.asg B6, B_length
.asg A12, A_data1
.asg B12, B_data1
.asg A13, A_data2
.asg B13, B_data2
.asg A14, A_data3
.asg B14, B_data3
.asg A15, A_data4
.asg B15, B_data4
.asg A16, A_m1
.asg A17, A_m2
.asg B18, B_m3
.asg B19, B_m4
.text
.global _mul
_mul:
SHR .S2 B_length, 2, B_length ; N/4
MVC .S2 B_length, ILC
ZERO .S1 A_m1
|| ZERO .S2 B_m3
ZERO .S1 A_m2
|| ZERO .S2 B_m4
ADD .L2 A_output,8,B_output
SPLOOP 3
LDDW .D1 *A_Input++,A_data2:A_data1
|| LDDW .D2 *B_Input++,B_data2:B_data1
LDDW .D1 *A_Input++,A_data4:A_data3
|| LDDW .D2 *B_Input++,B_data4:B_data3
NOP 4
MPY32 .M1X A_data1,B_data1,A_m1
|| MPY32 .M2X A_data3,B_data3,B_m3
MPY32 .M1X A_data2,B_data2,A_m2
|| MPY32 .M2X A_data4,B_data4,B_m4
NOP 1
NOP 1
NOP 1
SPKERNEL 4,0
|| STDW .D1 A_m2:A_m1,*A_output++[2]
|| STDW .D2 B_m4:B_m3,*B_output++[2]
.end
