SRIO DIO without using QMSS/CPPI
I'm trying to implement SRIO DIO without using QMSS/CPPI. Is there any example/ references/ Docs which I can refer because current example project uses QMSS for DIO operation and Docs didn't help!
Ruchika
  • Hi Ruchika,
    We do not example/reference for SRIO DIO without using QMSS/CPPI. Please provide more information to help you.
  • Hi Raja,
    I have implemented SRIO DIO in my project.
    (reference taken from C:\ti\pdk_keystone2_3_01_04_07\packages\exampleProjects\SRIO_LpbkDioIsrK2KC66BiosExampleProject).
    It worked fine initially but as soon as I integrated IPC in my project, SRIO started failing. On debugging I found that qmss_start(); has started failing after integration.
    According to SRIO SDS, QMSS is not required for DIO.  So, I removed qmss_start(); and other related stuff in driver configuration but then SRIO driver initialization failed. Now I need some references to proceed further.
    Ruchika
