I am trying to compile de example "bsp_examples_uart" in the vision_sdk of texas instruments and I get always a linking error.
Firstly I compile the vision_sdk through make and the on the folder "bsp_01_04_00_08" I run "make PLATFORM=tda3xx-evm bsp_examples_uart" and I get the following error.
That happens to me only with the uart example cause I ran the i2cUtility and it gave me no problems...could anyone please help me? Does anybody know how to solve this so I can run the uart example?
Would this example be the indicated one it I want to read and write through serial port? I would need to implement the same use as "bsp_examples_i2cUtility" but not through JTAG but through USB-cable...is there an available example for it?
Thank you very much in advance!
Javier
../../ti_components/drivers/bsp_01_04_00_08/binary/ti/sdo/edma3/rm/sample/lib/tda3xx-evm/m4/release/edma3_lld_rm_sample.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/uart/lib/tda3xx-evm/m4/release/bsp_uart.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/common/lib/tda3xx-evm/m4/release/bsp_common.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/osal/lib/tda3xx-evm/m4/release/bsp_osal.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/platforms/lib/tda3xx-evm/m4/release/bsp_platforms.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/boards/lib/tda3xx-evm/m4/release/bsp_boards.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/devices/lib/tda3xx-evm/m4/release/bsp_devices.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/fvid2/lib/tda3xx-evm/m4/release/bsp_fvid2.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/src/i2c/lib/tda3xx-evm/m4/release/bsp_i2c.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/binary/examples/utility/lib/tda3xx-evm/m4/release/bsp_examples_utility.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/cg_tools/linux/ti-cgt-arm_5.2.5/lib/libc.a -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/src/devices/ov10640/lib/ov10640_lib_ipu1_0_release.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/../../../vision_bios_examples/tda2xx/src/common/prof_log/lib/prof_log_ipu1_0_release.aem4 -l/home/javier/Escritorio/tda_integration_1108/tda3/ti_components/drivers/bsp_01_04_00_08/../../../ti_components/drivers/bsp_01_04_00_08/../../../vision_sdk/binaries/lib/tda3xx-evm/ipu1_0/release/vision_sdk_lib.aem4
error: symbol "edma3init" has already been defined
error: symbol "determineProcId" has already been defined
error: symbol "edma3deinit" has already been defined
error: symbol "edma3OsSemTake" has already been defined
error: symbol "edma3OsSemGive" has already been defined
error: symbol "edma3OsProtectEntry" has already been defined
error: symbol "edma3OsProtectExit" has already been defined
>> Compilation failure
>> Compilation failure
fatal error: Failed linktime optimization
