I'm using ipc_3_43_01_03 with bios_6_45_01_29 and xdctools_3_32_00_06_core. I tried ex02_messageq example on my K2G EVM and it worked fine with default makefile configurations. However, when I changed the build profile from debug to release, I saw the following link error during the build process:
# Making bin/release/app_host.xa15fg ... c:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc -o bin/release/app_host.xa15fg -mfloat-abi=hard -nostartfiles -Wl,-static -Wl,--g c-sections -Wl,-Map=bin/release/obj/app_host.xa15fg.map bin/release/obj/MainHost .oa15fg bin/release/obj/App.oa15fg -Wl,-T,bin/release/configuro/linker.cmd \ -lgcc -lc -lm -lnosys -Lc:/ti/xdctools_3_32_00_06_core/packages/ gnu/targets/arm/libs/install-native/arm-none-eabi/lib/fpu C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `ti_sdo_ipc_gates_GateHWSem_O bject__create(void) static': C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro/package/cfg/Host_pa15fg.c:31138: undefined reference to `ti_sdo_ipc_gates _GateHWSem_Instance_init__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `ti_sdo_ipc_GateMP_RemoteSyst emProxy_getReservedMask__E': C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro/package/cfg/Host_pa15fg.c:27904: undefined reference to `ti_sdo_ipc_gates _GateHWSem_getReservedMask__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `ti_sdo_ipc_GateMP_RemoteSyst emProxy_sharedMemReq__E': C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro/package/cfg/Host_pa15fg.c:27910: undefined reference to `ti_sdo_ipc_gates _GateHWSem_sharedMemReq__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `ti_sdo_ipc_Notify_SetupProxy _attach__E': C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro/package/cfg/Host_pa15fg.c:28039: undefined reference to `ti_sdo_ipc_famil y_tci663x_NotifyCircSetup_attach__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `ti_sdo_ipc_Notify_SetupProxy _sharedMemReq__E': C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro/package/cfg/Host_pa15fg.c:28045: undefined reference to `ti_sdo_ipc_famil y_tci663x_NotifyCircSetup_sharedMemReq__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `ti_sdo_ipc_Notify_SetupProxy _numIntLines__E': C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro/package/cfg/Host_pa15fg.c:28051: undefined reference to `ti_sdo_ipc_famil y_tci663x_NotifyCircSetup_numIntLines__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg: In function `.LANCHOR45': Host_pa15fg.c:(.rodata.ti_sdo_ipc_gates_GateHWSem_Module__FXNS__C+0x8): undefine d reference to `ti_sdo_ipc_gates_GateHWSem_query__E' Host_pa15fg.c:(.rodata.ti_sdo_ipc_gates_GateHWSem_Module__FXNS__C+0xc): undefine d reference to `ti_sdo_ipc_gates_GateHWSem_enter__E' Host_pa15fg.c:(.rodata.ti_sdo_ipc_gates_GateHWSem_Module__FXNS__C+0x10): undefin ed reference to `ti_sdo_ipc_gates_GateHWSem_leave__E' Host_pa15fg.c:(.rodata.ti_sdo_ipc_gates_GateHWSem_Module__FXNS__C+0x14): undefin ed reference to `ti_sdo_ipc_gates_GateHWSem_getReservedMask__E' Host_pa15fg.c:(.rodata.ti_sdo_ipc_gates_GateHWSem_Module__FXNS__C+0x18): undefin ed reference to `ti_sdo_ipc_gates_GateHWSem_sharedMemReq__E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg:(.rodata.xdc_runtime_Startup_sfxnTab__A+0x 3c): undefined reference to `ti_sdo_ipc_family_tci663x_Interrupt_Module_startup_ _E' C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\bin\release\con figuro\package\cfg\Host_pa15fg.oa15fg:(.rodata.xdc_runtime_Startup_sfxnTab__A+0x 40): undefined reference to `ti_sdo_ipc_gates_GateHWSem_Module_startup__E' collect2.exe: error: ld returned 1 exit status gmake.exe[2]: *** [bin/release/app_host.xa15fg] Error 1 gmake.exe[2]: Leaving directory `C:/ti/ipc_3_43_01_03/examples/66AK2G_bios_elf/e x02_messageq/host' gmake[1]: *** [all] Error 2 gmake[1]: Leaving directory `C:/ti/ipc_3_43_01_03/examples/66AK2G_bios_elf/ex02_ messageq/host' gmake: *** [host] Error 2
To reproduce the issue, please follow the instructions as below:
1. Go to C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq and modify product.mak to meet your environment. The following is my setup for your reference. Please note these product dependencies should be verified with ProcessorSDK(RTOS) v3.00.00.04.
DEPOT = c:/ti #### BIOS-side dependencies #### BIOS_INSTALL_DIR = $(DEPOT)/bios_6_45_01_29 IPC_INSTALL_DIR = $(DEPOT)/ipc_3_43_01_03 XDC_INSTALL_DIR = $(DEPOT)/xdctools_3_32_00_06_core
2. issue the following command in your command prompt and confirm the build is successfully done.
cd C:/ti/ipc_3_43_01_03/examples/66AK2G_bios_elf/ex02_messageq set MAKE=C:/ti/xdctools_3_32_00_06_core/gmake.exe gmake clean gmake all
3. now open C:\ti\ipc_3_43_01_03\examples\66AK2G_bios_elf\ex02_messageq\host\makefile and modifythe profile from debug to release and rebuild the projects. You will see the build error.
all: # $(MAKE) PROFILE=debug app_host.x $(MAKE) PROFILE=release app_host.x
Naoki
