AM335x switch pin's function
Hi All,
I am working on AM335x, and now I was confused by the pin's function switch, describe as below:
As you know the functions of pin were defined at arch/arm/mach-omap2/. but now I want to define a pin as GPIO when system bootup, and than change the pin as uart function.
For example, driver A will be "insmod" after system bootup, this driver use the uart0_rtsn as GPIO output, and then, driver A will be "remod", Driver B will be "insmod", this driver use the uart0_rtsn as uart4_txd.
In other words, the functions(GPIO and uart_txd) of uart0_rtsn was defined in different driver at different time, is it possible?
Thanks in advance,
Jakebo
