Hi, experts.
My deveplop envirmont is DVSDK1.3 with dm355 codecs 1.15. Linux kernnel is 2.6.10.
I run an encoder application in background, which called CERuntime_Init at startup. Then the encoder application entered into idle
state(no encoding). At this time, starting an decoder application to play a DM355 mpeg4 encoded movie. The decoding process is OK.
Then exit the decoder application. Now starting encoding by send a command to the encoder application. The encoder application tried
to create encoder object by calling Venc1_create but failed. The error message is:
@54,523,984us: [+7 T:0x40018730 S:0xbefff664] ti.sdo.ce.alg.Algorithm - Algorithm_create> Granting DMA channels to algorithm through DMAN3 FAILED (0xfffffffe).
For your reference, I attached the output and the .cfg file of my application(the .cfg is shared by both encoder application & decoder application)
I need your help, thanks
lcj.
# The config file of codec
var osalGlobal = xdc.useModule( 'ti.sdo.ce.osal.Global' );
osalGlobal.runtimeEnv = osalGlobal.LINUX;
var MPEG4ENC = xdc.useModule('ti.sdo.codecs.mpeg4enc.dm355.ce.MPEG4ENC');
var MPEG4DEC = xdc.useModule('ti.sdo.codecs.mpeg4dec.dm355.ce.MPEG4DEC');
var JPEGENC = xdc.useModule('ti.sdo.codecs.jpegenc.dm355.ce.JPEGENC');
var Engine = xdc.useModule('ti.sdo.ce.Engine');
var demoEngine = Engine.create("encodedecode", [
{name: "videnc", mod: MPEG4ENC, local: true, groupId: 1},
{name: "viddec", mod: MPEG4DEC, local: true, groupId: 1},
{name: "jpegenc", mod: JPEGENC, local: true, groupId: 1}
* ======== DMAN3 Configuration ========
var DMAN3 = xdc.useModule('ti.sdo.fc.dman3.DMAN3');
/* give DMAN3 all TCCs except those hard-coded by The JPEG & MPEG Enc & Decs */
* For the 32-63 range, configure tccAllocationMaskH to exclude used channels
* JPEG Dec: {33-47, 52-57}
* JPEG Enc: {34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49}
* MPEG Dec: {32-63}
* MPEG Enc: {12, 13, 34, 35, 40,41,42,43,44,45,46,47,48,49,50,52,53,
* 54,55,56,57,63}
DMAN3.tccAllocationMaskH = 0x0; /* everthing 32-63 hardcoded and unavailable */
/* Give DMAN3 all lower TCCs except what's taken by Linux kernel and a Codec:
* Based on the info from montavista: {2, 3, 8, 9, 26, 27, 30, 31}
* and MPEG Enc taking up: {12, 13}
DMAN3.tccAllocationMaskL = 0x33ffccf3;
/* Following assignments will give DMAN3 control of PaRAMs above 78: */
DMAN3.paRamBaseIndex = 64;
DMAN3.numPaRamEntries = 48;
DMAN3.nullPaRamIndex = 127;
/* Configure Scratch Group's DMAN3 resources */
DMAN3.numTccGroup[1] = 0;
DMAN3.numPaRamGroup[1] = 32;
DMAN3.qdmaChannels = [0, 1, 2, 3, 4, 5, 6, 7];
DMAN3.maxQdmaChannels = 8;
DMAN3.numQdmaChannels = 8;
DMAN3.maxTCs = 2;
/* Load support for the 'Davinci Multimedia Application Interface' module */
var DMAI = xdc.loadPackage('ti.sdo.dmai');
#Output by encoder application
root@davinci:~/dm355# CE_DEBUG=3 ./elss&
@0,514,577us: [+4 T:0x40018730 S:0xbeffeb6c] OG - Global_init> This program was built with the following packages:
@0,515,158us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package gnu.targets.rts470MV (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/bios_5_32_04/xdctools/packages/gnu/targets/rts470MV/) [1,0,0,0,1203621000516]
@0,515,570us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.linuxutils.cmem (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/linuxutils/cmem/) [2,0,1,1204929560755]
@0,515,949us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.catalog.hwa.imcop (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/catalog/hwa/imcop/) [1,0,2,0]
@0,516,338us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.codecs.mpeg4enc.dm355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4enc/dm355/) [1,0,2,0]
@0,516,706us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.codecs.mpeg4dec.dm355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4dec/dm355/) [1,0,2,0]
@0,517,067us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.codecs.jpegenc.dm355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/jpegenc/dm355/) [1,0,2,0]
@0,517,432us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.fc.dman3 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/fc/dman3/) [1,0,3,1220943053023]
@0,517,820us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.xdais.dm (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/xdais/dm/) [1,0,4,1210262746529]
@0,518,166us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.xdais (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/xdais/) [1,2,1,1210262742149]
@0,518,512us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.utils.trace (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/utils/trace/) [1,0,0,1220943366422]
@0,518,867us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.utils.xdm (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1,1220951322616]
@0,519,283us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.fc.acpy3 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/fc/acpy3/) [1,0,2,1220943014135]
@0,519,650us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.catalog.c470 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/bios_5_32_04/xdctools/packages/ti/catalog/c470/) [1,0,1,0,1217383460556]
@0,520,108us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.platforms.evmDM355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/bios_5_32_04/xdctools/packages/ti/platforms/evmDM355/) [1,0,0,1205437912113]
@0,520,544us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.osal (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,1220951127739]
@0,520,905us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.ipc (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,1220951085787]
@0,521,246us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.alg (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,1220950781938]
@0,521,588us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.osal.linux (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/osal/linux/) [2,0,1,1220951140072]
@0,521,977us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.ipc.linux (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/linux/) [2,0,1,1220951106771]
@0,522,340us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
@0,522,673us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.video1 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/video1/) [1,0,2,1220951340734]
@0,854,697us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.codecs.mpeg4enc.dm355.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4enc/dm355/ce/) [1,0,2,0]
@0,855,121us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.video2 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/video2/) [1,0,2,1220951347240]
@0,855,484us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.codecs.mpeg4dec.dm355.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4dec/dm355/ce/) [1,0,2,0]
@0,855,852us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.image1 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/image1/) [1,0,1,1220951080020]
@0,856,244us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.codecs.jpegenc.dm355.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/jpegenc/dm355/ce/) [1,0,2,0]
@0,856,617us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.speech (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/speech/) [1,0,2,1220951161404]
@0,856,969us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.speech1 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/speech1/) [1,0,1,1220951167662]
@0,857,355us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.audio (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/audio/) [1,0,2,1220950788137]
@0,857,706us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.ce.video (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/video/) [1,0,3,1220951334122]
@0,858,052us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package ti.sdo.dmai (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dmai_1_10_00_06/packages/ti/sdo/dmai/) [1,0,0,0]
@0,858,377us: [+4 T:0x40018730 S:0xbeffeb6c] OG - package libce_dm355_config (/home/lcj/work3/projects/dvr/src/libce/libce_dm355_config/) []
@0,858,882us: [+0 T:0x40018730 S:0xbeffeb74] OG - Global_atexit> enter (fxn=0x4004a9a4)
@0,859,262us: [+0 T:0x40018730 S:0xbeffeb74] OG - Global_atexit> enter (fxn=0x40049e3c)
@0,859,639us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> Enter(0x18)
@0,860,139us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> return (0xf96a8)
@0,861,061us: [+0 T:0x40018730 S:0xbeffeb64] OG - Global_atexit> enter (fxn=0x40048720)
@0,861,749us: [+0 T:0x40018730 S:0xbeffeb6c] OG - Global_atexit> enter (fxn=0x400494c0)
@0,862,346us: [+0 T:0x40018730 S:0xbeffeb74] OG - Global_atexit> enter (fxn=0x40047190)
@0,862,933us: [+0 T:0x40018730 S:0xbeffeaf4] ti.sdo.ce.osal.LockMP - LockMP_create> key: 0x4e414d46 count: 1073788332 attrs: 0x400acd44
@0,863,308us: [+0 T:0x40018730 S:0xbeffeadc] OM - Memory_alloc> Enter(0x10)
@0,863,581us: [+0 T:0x40018730 S:0xbeffeadc] OM - Memory_alloc> return (0xf97b8)
@0,863,863us: [+0 T:0x40018730 S:0xbeffeab4] ti.sdo.ce.osal.SemMP - SemMP_create> key: 0x4e414d46 count: 1
@0,864,158us: [+0 T:0x40018730 S:0xbeffea9c] OM - Memory_alloc> Enter(0x4)
@0,864,464us: [+0 T:0x40018730 S:0xbeffea9c] OM - Memory_alloc> return (0xf97d0)
@0,864,721us: [+0 T:0x40018730 S:0xbeffea94] ti.sdo.ce.osal.SemMP - Entered enterCS> key[0x4c41534f]
@0,865,207us: [+0 T:0x40018730 S:0xbeffea94] ti.sdo.ce.osal.SemMP - Leaving enterCS> id[0x170000]
@0,865,826us: [+0 T:0x40018730 S:0xbeffeab4] ti.sdo.ce.osal.SemMP - SemMP_create> semId: 0x178001 refCount: 1
@0,866,170us: [+0 T:0x40018730 S:0xbeffea9c] ti.sdo.ce.osal.SemMP - Entered exitCS> id[0x170000]
@0,866,466us: [+0 T:0x40018730 S:0xbeffeab4] ti.sdo.ce.osal.SemMP - Leaving exitCS
@0,866,714us: [+0 T:0x40018730 S:0xbeffeab4] ti.sdo.ce.osal.SemMP - Leaving SemMP_create> sem[0xf97d0]
@0,867,021us: [+0 T:0x40018730 S:0xbeffeaf4] ti.sdo.ce.osal.LockMP - Leaving LockMP_create> lock[0xf97b8]
@1,200,070us: [+0 T:0x40018730 S:0xbeffeaf4] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xf97b8]
@1,200,528us: [+0 T:0x40018730 S:0xbeffeac4] ti.sdo.ce.osal.SemMP - Entered SemMP_pend> sem[0xf97d0] timeout[0xffffffff]
@1,200,905us: [+0 T:0x40018730 S:0xbeffeac4] ti.sdo.ce.osal.SemMP - Leaving SemMP_pend> sem[0xf97d0] status[0]
@1,201,255us: [+0 T:0x40018730 S:0xbeffeb0c] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xf97b8]
@1,202,156us: [+0 T:0x40018730 S:0xbeffeafc] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xf97b8]
@1,202,607us: [+0 T:0x40018730 S:0xbeffeadc] ti.sdo.ce.osal.SemMP - Entered SemMP_post> sem[0xf97d0]
@1,202,960us: [+0 T:0x40018730 S:0xbeffeadc] ti.sdo.ce.osal.SemMP - Leaving SemMP_post> sem[0xf97d0]
@1,203,247us: [+0 T:0x40018730 S:0xbeffeb0c] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xf97b8]
@1,203,915us: [+0 T:0x40018730 S:0xbeffeaf4] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xf97b8]
@1,204,312us: [+0 T:0x40018730 S:0xbeffeac4] ti.sdo.ce.osal.SemMP - Entered SemMP_pend> sem[0xf97d0] timeout[0xffffffff]
@1,204,663us: [+0 T:0x40018730 S:0xbeffeac4] ti.sdo.ce.osal.SemMP - Leaving SemMP_pend> sem[0xf97d0] status[0]
@1,204,955us: [+0 T:0x40018730 S:0xbeffeb0c] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xf97b8]
@1,205,503us: [+0 T:0x40018730 S:0xbeffeafc] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xf97b8]
@1,205,835us: [+0 T:0x40018730 S:0xbeffeadc] ti.sdo.ce.osal.SemMP - Entered SemMP_post> sem[0xf97d0]
@1,206,156us: [+0 T:0x40018730 S:0xbeffeadc] ti.sdo.ce.osal.SemMP - Leaving SemMP_post> sem[0xf97d0]
@1,206,438us: [+0 T:0x40018730 S:0xbeffeb0c] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xf97b8]
@1,206,859us: [+0 T:0x40018730 S:0xbeffeb5c] ti.sdo.ce.alg - ALG_init> Enter
@1,207,138us: [+0 T:0x40018730 S:0xbeffeb1c] ti.sdo.ce.osal.SemMP - SemMP_create> key: 0x4f474c42 count: 1
@1,207,433us: [+0 T:0x40018730 S:0xbeffeb04] OM - Memory_alloc> Enter(0x4)
@1,207,692us: [+0 T:0x40018730 S:0xbeffeb04] OM - Memory_alloc> return (0xf9808)
@1,207,948us: [+0 T:0x40018730 S:0xbeffeafc] ti.sdo.ce.osal.SemMP - Entered enterCS> key[0x4c41534f]
@1,208,288us: [+0 T:0x40018730 S:0xbeffeafc] ti.sdo.ce.osal.SemMP - Leaving enterCS> id[0x180000]
@1,208,653us: [+0 T:0x40018730 S:0xbeffeb1c] ti.sdo.ce.osal.SemMP - SemMP_create> semId: 0x188002 refCount: 1
@1,208,960us: [+0 T:0x40018730 S:0xbeffeb04] ti.sdo.ce.osal.SemMP - Entered exitCS> id[0x180000]
@1,209,254us: [+0 T:0x40018730 S:0xbeffeb1c] ti.sdo.ce.osal.SemMP - Leaving exitCS
@1,209,542us: [+0 T:0x40018730 S:0xbeffeb1c] ti.sdo.ce.osal.SemMP - Leaving SemMP_create> sem[0xf9808]
@1,209,832us: [+0 T:0x40018730 S:0xbeffeb4c] OG - Global_atexit> enter (fxn=0x4004b36c)
@1,210,240us: [+0 T:0x40018730 S:0xbeffeb7c] ti.sdo.ce.alg - ALG_init> Exit
@1,210,514us: [+0 T:0x40018730 S:0xbeffeb74] OG - Global_atexit> enter (fxn=0x4004ae0c)
@1,210,932us: [+0 T:0x40018730 S:0xbeffeb4c] OM - Memory_alloc> Enter(0x18)
@1,211,234us: [+0 T:0x40018730 S:0xbeffeb4c] OM - Memory_alloc> return (0xf9858)
@1,211,503us: [+0 T:0x40018730 S:0xbeffeb74] OG - Global_atexit> enter (fxn=0x40049624)
@1,211,973us: [+6 T:0x40018730 S:0xbeffeb74] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@1,212,381us: [+0 T:0x40018730 S:0xbeffeb64] OG - Global_atexit> enter (fxn=0x4004348c)
@1,212,670us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> Enter(0x18)
@1,212,933us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> return (0xf9898)
@1,213,195us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> Enter(0x18)
@1,213,449us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> return (0xf98b8)
@1,213,742us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> Enter(0x18)
@1,214,003us: [+0 T:0x40018730 S:0xbeffeb44] OM - Memory_alloc> return (0xf98d8)
@1,214,420us: [+0 T:0x40018730 S:0xbeffeb84] CS - Server_init()
@1,214,683us: [+0 T:0x40018730 S:0xbeffeb84] CS - Server_init> Global_useLinkArbiter = 0
@1,546,662us: [+0 T:0x40018730 S:0xbeffeb84] OG - Global_atexit> enter (fxn=0x40041fdc)
[INFO][01:42:00.547][1474]main2.cpp:363(Initialize): process the startup script
[INFO][01:42:00.552][1474]main2.cpp:459(main): Main loop
#Encoder application is idle background. Start the decoder application. The ollowing is Output by decoder application
@0,088,838us: [+4 T:0x40018298] OG - Global_init> This program was built with the following packages:
@0,089,287us: [+4 T:0x40018298] OG - package gnu.targets.rts470MV (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/bios_5_32_04/xdctools/packages/gnu/targets/rts470MV/) [1,0,0,0,1203621000516]
@0,089,750us: [+4 T:0x40018298] OG - package ti.sdo.linuxutils.cmem (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/linuxutils/cmem/) [2,0,1,1204929560755]
@0,090,275us: [+4 T:0x40018298] OG - package ti.catalog.hwa.imcop (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/catalog/hwa/imcop/) [1,0,2,0]
@0,090,617us: [+4 T:0x40018298] OG - package ti.sdo.codecs.mpeg4enc.dm355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4enc/dm355/) [1,0,2,0]
@0,090,944us: [+4 T:0x40018298] OG - package ti.sdo.codecs.mpeg4dec.dm355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4dec/dm355/) [1,0,2,0]
@0,091,264us: [+4 T:0x40018298] OG - package ti.sdo.codecs.jpegenc.dm355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/jpegenc/dm355/) [1,0,2,0]
@0,091,618us: [+4 T:0x40018298] OG - package ti.sdo.fc.dman3 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/fc/dman3/) [1,0,3,1220943053023]
@0,091,944us: [+4 T:0x40018298] OG - package ti.xdais.dm (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/xdais/dm/) [1,0,4,1210262746529]
@0,092,250us: [+4 T:0x40018298] OG - package ti.xdais (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/xdais/) [1,2,1,1210262742149]
@0,092,546us: [+4 T:0x40018298] OG - package ti.sdo.utils.trace (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/utils/trace/) [1,0,0,1220943366422]
@0,092,896us: [+4 T:0x40018298] OG - package ti.sdo.ce.utils.xdm (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1,1220951322616]
@0,093,218us: [+4 T:0x40018298] OG - package ti.sdo.fc.acpy3 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/cetools/packages/ti/sdo/fc/acpy3/) [1,0,2,1220943014135]
@0,093,532us: [+4 T:0x40018298] OG - package ti.catalog.c470 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/bios_5_32_04/xdctools/packages/ti/catalog/c470/) [1,0,1,0,1217383460556]
@0,093,839us: [+4 T:0x40018298] OG - package ti.platforms.evmDM355 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/bios_5_32_04/xdctools/packages/ti/platforms/evmDM355/) [1,0,0,1205437912113]
@0,094,151us: [+4 T:0x40018298] OG - package ti.sdo.ce.osal (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,1220951127739]
@0,094,495us: [+4 T:0x40018298] OG - package ti.sdo.ce.ipc (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,1220951085787]
@0,094,801us: [+4 T:0x40018298] OG - package ti.sdo.ce.alg (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,1220950781938]
@0,095,103us: [+4 T:0x40018298] OG - package ti.sdo.ce.osal.linux (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/osal/linux/) [2,0,1,1220951140072]
@0,095,415us: [+4 T:0x40018298] OG - package ti.sdo.ce.ipc.linux (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/linux/) [2,0,1,1220951106771]
@0,095,760us: [+4 T:0x40018298] OG - package ti.sdo.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
@0,096,059us: [+4 T:0x40018298] OG - package ti.sdo.ce.video1 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/video1/) [1,0,2,1220951340734]
@0,096,397us: [+4 T:0x40018298] OG - package ti.sdo.codecs.mpeg4enc.dm355.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4enc/dm355/ce/) [1,0,2,0]
@0,428,552us: [+4 T:0x40018298] OG - package ti.sdo.ce.video2 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/video2/) [1,0,2,1220951347240]
@0,428,933us: [+4 T:0x40018298] OG - package ti.sdo.codecs.mpeg4dec.dm355.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/mpeg4dec/dm355/ce/) [1,0,2,0]
@0,429,270us: [+4 T:0x40018298] OG - package ti.sdo.ce.image1 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/image1/) [1,0,1,1220951080020]
@0,429,578us: [+4 T:0x40018298] OG - package ti.sdo.codecs.jpegenc.dm355.ce (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dm355_codecs_1_15_000/packages/ti/sdo/codecs/jpegenc/dm355/ce/) [1,0,2,0]
@0,429,951us: [+4 T:0x40018298] OG - package ti.sdo.ce.speech (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/speech/) [1,0,2,1220951161404]
@0,430,387us: [+4 T:0x40018298] OG - package ti.sdo.ce.speech1 (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/speech1/) [1,0,1,1220951167662]
@0,430,712us: [+4 T:0x40018298] OG - package ti.sdo.ce.audio (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/audio/) [1,0,2,1220950788137]
@0,431,014us: [+4 T:0x40018298] OG - package ti.sdo.ce.video (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/codec_engine_2_10_02/packages/ti/sdo/ce/video/) [1,0,3,1220951334122]
@0,431,359us: [+4 T:0x40018298] OG - package ti.sdo.dmai (/home/lcj/work3/dvsdk1.3/dvsdk_1_30_01/dmai_1_10_00_06/packages/ti/sdo/dmai/) [1,0,0,0]
@0,431,642us: [+4 T:0x40018298] OG - package libce_dm355_config (/home/lcj/work3/projects/dvr/src/libce/libce_dm355_config/) []
@0,433,642us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - LockMP_create> key: 0x4e414d46 count: 1073788332 attrs: 0x4017dd44
@0,434,509us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_create> lock[0x19bde8]
@0,434,880us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0x19bde8]
@0,435,443us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0x19bde8]
@0,436,082us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0x19bde8]
@0,436,484us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0x19bde8]
@0,437,188us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0x19bde8]
@0,437,553us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0x19bde8]
@0,437,938us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0x19bde8]
@0,438,297us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0x19bde8]
@0,438,700us: [+0 T:0x40018298] ti.sdo.ce.alg - ALG_init> Enter
@0,439,070us: [+0 T:0x40018298] ti.sdo.ce.alg - ALG_init> Exit
@0,439,733us: [+6 T:0x40018298] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,440,443us: [+0 T:0x40018298] CS - Server_init()
@0,440,692us: [+0 T:0x40018298] CS - Server_init> Global_useLinkArbiter = 0
[dm3xxmpeg4 @ 0x139498]Opening Engine: encodedecode.0x16e500
@0,443,115us: [+0 T:0x40acab60] CE - Engine_open> Enter('encodedecode', 0x0, 0x40ac9c3c)
@0,443,585us: [+0 T:0x40acab60] CE - Engine_open> return(1687456)
[dm3xxmpeg4 @ 0x139498]Opening Engine: encodedecode,0x19bfa0,0
@0,444,407us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> Enter (engine=0x19bfa0, name='viddec', params=0x16e500)
@0,444,839us: [+0 T:0x40acab60] CV - VISA_create(0x19bfa0, 'viddec', 0x16e500, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
@0,445,244us: [+0 T:0x40acab60] CV - VISA_create2(0x19bfa0, 'viddec', 0x16e500, 0x1c, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
@0,445,868us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x4019f1dc, idma3Fxns=0x4019f1a4, iresFxns=0x0, params=0x16e500, attrs=0x40ac9b48)
@0,446,322us: [+0 T:0x40acab60] ti.sdo.ce.alg - ALG_create> Enter (scratchId=1, fxns=0x4019f1dc, parentAlg=0x0, params=0x16e500)
@0,779,405us: [+2 T:0x40acab60] ti.sdo.ce.alg - ALG_create> algNumAlloc 4 memory recs
@0,779,728us: [+2 T:0x40acab60] ti.sdo.ce.alg - ALG_create> algAlloc returned numRecs=4
@0,779,975us: [+4 T:0x40acab60] ti.sdo.ce.alg - ALG_create> Memory requested memTab[0]: size=0x1354, align=0x80, space=0x11, attrs=0x1
@0,780,406us: [+4 T:0x40acab60] ti.sdo.ce.alg - ALG_create> Memory requested memTab[1]: size=0x333000, align=0x80, space=0x11, attrs=0x1
@0,780,751us: [+4 T:0x40acab60] ti.sdo.ce.alg - ALG_create> Memory requested memTab[2]: size=0x1680, align=0x80, space=0x11, attrs=0x1
@0,781,053us: [+4 T:0x40acab60] ti.sdo.ce.alg - ALG_create> Memory requested memTab[3]: size=0x2000, align=0x80, space=0x11, attrs=0x1
@0,781,426us: [+6 T:0x40acab60] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@0,782,044us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_alloc(4948) = 0x40acb000.
@0,782,446us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_getPhys(0x40acb000) = 0x867b8000.
@0,782,854us: [+6 T:0x40acab60] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@0,784,218us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_alloc(3354624) = 0x40acd000.
@0,784,571us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_getPhys(0x40acd000) = 0x86e00000.
@0,821,617us: [+6 T:0x40acab60] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@0,822,255us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_alloc(5760) = 0x410cd000.
@0,822,595us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_getPhys(0x410cd000) = 0x867ba000.
@0,823,000us: [+6 T:0x40acab60] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@0,823,519us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_alloc(8192) = 0x410e1000.
@0,823,897us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_getPhys(0x410e1000) = 0x867ce000.
@0,826,300us: [+4 T:0x40acab60] ti.sdo.ce.alg - ALG_create> algInit returned IALG_EOK
@0,826,757us: [+0 T:0x40acab60] ti.sdo.ce.alg - ALG_create> Exit (algHandle=0x40acb000)
@0,827,156us: [+0 T:0x40acab60] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0x19bde8]
@0,827,491us: [+0 T:0x40acab60] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0x19bde8]
@0,828,149us: [+0 T:0x40acab60] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0x19bde8]
@0,828,505us: [+0 T:0x40acab60] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0x19bde8]
@0,828,790us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x19c058)
@0,829,045us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> return (0x19c020)
[dm3xxmpeg4 @ 0x139498]Created MPEG4 decoder
@0,829,700us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x19c020, id=2, params=0x40aca4c8 (size=0x1c), status=0x40aca410 (size=0xb8)
@0,830,324us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@0,830,763us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@0,864,289us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@0,864,669us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@0,865,044us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x19c020, retVal=0x0)
@0,865,397us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x19c020, id=1, params=0x40aca4c8 (size=0x1c), status=0x40aca410 (size=0xb8)
@0,865,751us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@0,865,989us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@0,866,707us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@0,866,996us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@0,867,303us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x19c020, retVal=0x0)
@0,867,591us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x19c020, id=5, params=0x40aca4c8 (size=0x1c), status=0x40aca410 (size=0xb8)
@0,867,961us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@0,868,232us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@0,868,899us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@0,869,186us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@0,869,539us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x19c020, retVal=0x0)
@1,203,011us: [+6 T:0x40acab60] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@1,203,835us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_alloc(1658880) = 0x41159000.
@1,204,186us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_getPhys(0x41159000) = 0x86c60000.
@1,204,821us: [+6 T:0x40acab60] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@1,207,055us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_alloc(983040) = 0x412f9000.
@1,207,404us: [+4 T:0x40acab60] OM - Memory_contigAlloc> CMEM_getPhys(0x412f9000) = 0x87400000.
Selected video codec: [ffdm3xxmpeg4] vfm: ffmpeg (FFmpeg DM3xx MPEG-4)
@1,244,241us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,244,631us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,244,877us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
[dm3xxmpeg4 @ 0x139498][decode_frame]check first frame
@1,264,496us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,264,843us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,265,165us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]END..
[dm3xxmpeg4 @ 0x139498][ce_thread_proc] wait for decode
[dm3xxmpeg4 @ 0x139498][decode_frame]check first frame done,720x576
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 3
Movie-Aspect is undefined - no prescaling applied.
VO: [fbdavinci] 720x576 => 720x576 Packed UYVY
[vo_fbdavinci]: config request,720x576=>720x576
[vo_fbdavinci]: display: 288x230(16:5),fbinfo:320x240x640x2,3232
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1,(nil),(nil),576
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1.1,0x41ef9ca0,0x19c620
[dm3xxmpeg4 @ 0x139498]BEGIN..
[dm3xxmpeg4 @ 0x139498]inDataSize = 8022/491520,0x41371000
@1,290,845us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,291,269us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,291,517us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@1,307,131us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,307,461us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,307,835us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1,0x41ef9ca0,0x19c620,576
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1.1,0x41f1f4a0,0x1c8790
[dm3xxmpeg4 @ 0x139498]inDataSize = 4252/491520,0x412f9000
@1,474,120us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,474,504us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,474,746us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
[dm3xxmpeg4 @ 0x139498][decode_frame]waiting for frame
@1,490,157us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,490,484us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,490,859us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1,0x41f1f4a0,0x1c8790,576
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1.1,0x41f44ca0,0x19c620
[dm3xxmpeg4 @ 0x139498]inDataSize = 4227/491520,0x41371000
@1,566,701us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,567,121us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,567,372us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@1,582,023us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,582,381us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,582,697us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1,0x41f44ca0,0x19c620,576
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1.1,0x41f6a4a0,0x1c8790
[dm3xxmpeg4 @ 0x139498]inDataSize = 5177/491520,0x412f9000
@1,605,305us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,605,721us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,605,973us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@1,620,618us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,620,978us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,621,306us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498][ce]decode_frame 1,0x41f6a4a0,0x1c8790,576
[dm3xxmpeg4 @ 0x139498]inDataSize = 5313/491520,0x41371000
@1,645,115us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,645,490us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,645,734us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@1,660,480us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,660,804us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,661,178us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]inDataSize = 5314/491520,0x412f9000
@1,685,096us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@1,685,473us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@1,685,719us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@1,700,550us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@1,700,881us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@1,701,233us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]inDataSize = 5090/491520,0x41371000
@2,059,507us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@2,059,897us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@2,060,258us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@2,074,981us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@2,075,311us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@2,075,639us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498][ce_thread_proc] decode consume:365
[dm3xxmpeg4 @ 0x139498][dm3xxmpeg4 @ 0x139498]BEGIN..
[dm3xxmpeg4 @ 0x139498]inDataSize = 5369/491520,0x412f9000
@2,090,775us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@2,091,200us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@2,091,459us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
[ce]decode_frame 3
@2,106,529us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@2,106,855us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@2,107,175us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]inDataSize = 5439/491520,0x41371000
@2,124,075us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@2,124,497us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@2,124,749us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@2,139,408us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@2,139,771us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@2,140,231us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]inDataSize = 5443/491520,0x412f9000
@2,156,971us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@2,157,355us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@2,157,644us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@2,172,306us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@2,172,630us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@2,173,002us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]inDataSize = 5428/491520,0x41371000
@2,189,635us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@2,190,136us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@2,190,412us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@2,205,204us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@2,205,533us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@2,205,857us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
[dm3xxmpeg4 @ 0x139498]BEGIN.. 0 0
[dm3xxmpeg4 @ 0x139498]inDataSize = 5449/491520,0x412f9000
@2,558,865us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x19c020, inBufs=0x1a8370, outBufs=0x1a844c, inArgs=0x40aca3f0, outArgs=0x40ac9c50)
@2,559,244us: [+5 T:0x40acab60] CV - VISA_enter(visa=0x19c020): algHandle = 0x19c058
@2,559,490us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x19c058)
@2,574,280us: [+5 T:0x40acab60] CV - VISA_exit(visa=0x19c020): algHandle = 0x19c058
@2,574,608us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x19c058)
@2,574,967us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x19c020, retVal=0x0)
@2,588,142us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_delete> Enter (handle=0x19c020)
@2,588,485us: [+0 T:0x40acab60] CV - VISA_delete(0x19c020)
@2,588,755us: [+5 T:0x40acab60] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
@2,589,119us: [+0 T:0x40acab60] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x19c058)
@2,635,006us: [+0 T:0x40acab60] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_delete> return
@2,635,395us: [+0 T:0x40acab60] CE - Engine_close(0x19bfa0)
[dm3xxmpeg4 @ 0x139498]Close ipipe done
Exiting... (Quit)
@2,821,214us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0x19bde8]
@2,821,591us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0x19bde8]
@2,822,128us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0x19bde8]
@2,822,472us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0x19bde8]
@2,822,794us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Entered LockMP_delete> lock[0x19bde8]
@2,823,165us: [+0 T:0x40018298] ti.sdo.ce.osal.LockMP - Leaving LockMP_delete>
#Decoder application exited. Start encoding in encoder application. The following is output by encoder application.
> /tmp/elss_cmd_in5# echo "0 gui:elss 0 storage_config loop=0 reserve_space=20"
#config linein
echo "0 gui:elss 0 dev_config audioin.0 data={dev:/dev/dsp;io:oss;samplerate:8000;channelcount:1;input:line} control={dev:/dev/mixer;leftvol:80;rightvol:80}">/tmp/elss_cmd_in&
[INFO][01:42:48.510][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 storage_config loop=0 reserve_space=20
[INFO][01:42:48.511][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=storage_config level=OK desc=storage_config_0_20
root@davinci:~/dm355# echo "0 gui:elss 0 fileformat name=mkv" > /tmp/elss_cmd_in
elss_cmd_ini:~/dm355# echo "0 gui:elss 0 storage_adddisk /mnt/mmc/video" > /tmp/
root@davinci:~/dm355# echo "0 gui:elss 0[INFO][01:42:48.610][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 fileformat name=mkv
[INFO][01:42:48.611][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=fileformat level=OK desc=fileformat_mkv
[INFO][01:42:48.611][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 storage_adddisk /mnt/mmc/video
[INFO][01:42:48.612][1474]FileManagerImpl.cpp:954(DiskMonitor_AddDisk): /mnt/mmc/video
[INFO][01:42:48.612][1474]FileManagerImpl.cpp:428(Open): Open /mnt/mmc/video/index0.idx
[INFO][01:42:48.617][1474]FileManagerImpl.cpp:428(Open): Open /mnt/mmc/video/index1.idx
[INFO][01:42:48.621][1474]FileManagerImpl.cpp:448(Open): Scandir begin
[INFO][01:42:48.625][1474]FileManagerImpl.cpp:451(Open): Scandir Done
[INFO][01:42:48.626][1474]FileManagerImpl.cpp:454(Open): Sortdir Done
[INFO][01:42:48.627][1474]FileManagerImpl.cpp:459(Open): ItemCount:0,6
[INFO][01:42:48.628][1474]FileManagerImpl.cpp:771(CalRealFreeSpace): More Space(928)/mnt/mmc/video: RealFree:928,RealFreeLast:0,TotalEst:0,EstFree:928
[INFO][01:42:48.629][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=storage_adddisk level=OK desc=add_disk
/3;io:fb}" > /tmp/elss_cmd_indev:/dev/fb
root@davinci:~/dm355# #config linein
;io:oss;samplerate:8000;channelcount:1;input:line} co[INFO][01:42:48.780][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 dev_config videoout.0 data={dev:/dev/fb/3;io:fb}
ntrol={dev:/dev/@49,801,232us: [+2 T:0x40018730 S:0xbeffe954] ti.sdo.dmai - [Display] Setting video output to 'LCD'
[INFO][01:42:48.802][1474]RenderDevVideoImpl.cpp:494(GetDevResolution): bpp:16,red:0:0,g:0:0,b:0:0,t:0:0
@49,803,695us: [+7 T:0x40018730 S:0xbefff96c] ti.sdo.dmai - [Display] 320x240
@49,804,144us: [+2 T:0x40018730 S:0xbefff93c] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
@49,804,954us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x40396000, size=4)
@49,805,330us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x40396000, size=4)
@49,805,632us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
@49,806,028us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x40396000) = 0x86456000.
@49,806,381us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> Enter(virtAddr=0x40396000, size=4, physAddr=0x86456000)
@49,806,701us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> creating new contigBuf object
@49,806,965us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> Enter(0x10)
@49,807,276us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> return (0x10af50)
@49,807,546us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> returning: cb->phys=0x86456000, cb->size=4, cb->virt=0x40396000
@49,807,861us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> return (0x86456000)
@49,808,182us: [+2 T:0x40018730 S:0xbefff96c] ti.sdo.dmai - [Display] Display buffer 0 mapped to 0x40396000 has physical address 0x86456000
@49,808,585us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x403bb800, size=4)
@49,808,900us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x403bb800, size=4)
@49,809,189us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
@49,809,481us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x403bb800) = 0x8647b800.
@49,809,800us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> Enter(virtAddr=0x403bb800, size=4, physAddr=0x8647b800)
@49,810,698us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> creating new contigBuf object
@49,811,047us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> Enter(0x10)
@49,811,385us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> return (0x10af68)
@49,811,659us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> returning: cb->phys=0x8647b800, cb->size=4, cb->virt=0x403bb800
@49,811,980us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> return (0x8647b800)
@49,812,262us: [+2 T:0x40018730 S:0xbefff96c] ti.sdo.dmai - [Display] Display buffer 1 mapped to 0x403bb800, physical address 0x8647b800
@49,812,616us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x403e1000, size=4)
@49,812,964us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x403e1000, size=4)
@49,813,282us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
@49,813,579us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x403e1000) = 0x864a1000.
@49,813,901us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> Enter(virtAddr=0x403e1000, size=4, physAddr=0x864a1000)
@49,814,251us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> creating new contigBuf object
@49,814,523us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> Enter(0x10)
@49,814,790us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> return (0x10af80)
@49,815,043us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> returning: cb->phys=0x864a1000, cb->size=4, cb->virt=0x403e1000
@49,815,359us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> return (0x864a1000)
@49,815,680us: [+2 T:0x40018730 S:0xbefff96c] ti.sdo.dmai - [Display] Display buffer 2 mapped to 0x403e1000, physical address 0x864a1000
@49,816,025us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x40406800, size=4)
@49,816,332us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x40406800, size=4)
@50,148,523us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
@50,148,909us: [+1 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x40406800) = 0x864c6800.
@50,149,250us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> Enter(virtAddr=0x40406800, size=4, physAddr=0x864c6800)
@50,149,579us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> creating new contigBuf object
ol:80;ri@50,149,907us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> Enter(0x10)
@50,160,412us: [+0 T:0x40018730 S:0xbefff8bc] OM - Memory_alloc> return (0x10af98)
@50,160,756us: [+1 T:0x40018730 S:0xbefff8d4] OM - Memory__addContigBuf> returning: cb->phys=0x864c6800, cb->size=4, cb->virt=0x40406800
@50,161,097us: [+0 T:0x40018730 S:0xbefff92c] OM - Memory_getBufferPhysicalAddress> return (0x864c6800)
@50,161,390us: [+2 T:0x40018730 S:0xbefff96c] ti.sdo.dmai - [Display] Display buffer 3 mapped to 0x40406800, physical address 0x864c6800
[INFO][01:42:49.162][1474]RenderDevVideoImpl.cpp:244(Open): Open /dev/fb/3
[INFO][01:42:49.206][1474]RenderDevVideoImpl.cpp:266(Close): Close /dev/fb/3
index:0, type: 2, ref: 0
DATA: dev:/dev/fb/3, io:fb, videoRect:(0,0,320,240), videoStride:640, interlace:0, ftime:0
[INFO][01:42:49.207][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=dev_config level=OK desc=config_dev_ok
[2] 1477
[2]+ Done echo "0 gui:elss 0 dev_config audioin.0 data={dev:/dev/dsp;io:oss;samplerate:8000;channelcount:1;input:line} control={dev:/dev/mixer;leftvol:80;rightvol:80}" >/tmp/elss_cmd_in
[INFO][01:42:49.350][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 dev_config audioin.0 data={dev:/dev/dsp;io:oss;samplerate:8000;channelcount:1;input:line} control={dev:/dev/mixer;leftvol:80;rightvol:80}
@50,380,695us: [+2 T:0x00111a50 S:0x0011134c] ti.sdo.dmai - [Sound] Line in recorder selected
root@davinci:~/dm355# #config mic
;io:oss;samplerate:8000;channelc[INFO][01:42:49.440][1474]AppGraph.cpp:317(CaptureConfigAudio): DumpDevConfig:
index:0, type: 3, ref: 0
DATA: dev:/dev/dsp, io:oss, input:line, samplerate:8000, bitdepth:16, channelcount:1
CNTL: dev:/dev/mixer, leftvol:80, rightvol:80
[INFO][01:42:49.441][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=dev_config level=OK desc=config_dev_ok
l:75;rightvol:75}">/tmp/elss_cmd_in&mixer;leftvo
[2] 1479
[2]+ Done echo "0 gui:elss 0 dev_config audioin.0 data={dev:/dev/dsp;io:oss;samplerate:8000;channelcount:1;input:mic} control={dev:/dev/mixer;leftvol:75;rightvol:75}" >/tmp/elss_cmd_in
[INFO][01:42:49.540][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 dev_config audioin.0 data={dev:/dev/dsp;io:oss;samplerate:8000;channelcount:1;input:mic} control={dev:/dev/mixer;leftvol:75;rightvol:75}
@50,541,935us: [+2 T:0x00111a50 S:0x0011134c] ti.sdo.dmai - [Sound] Microphone recorder selected
[INFO][01:42:49.570][1474]AppGraph.cpp:317(CaptureConfigAudio): DumpDevConfig:
DATA: dev:/dev/dsp, io:oss, input:mic, samplerate:8000, bitdepth:16, channelcount:1
CNTL: dev:/dev/mixer, leftvol:75, rightvol:75
[INFO][01:42:49.571][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=dev_config level=OK desc=config_dev_ok
root@davinci:~/dm355# #config cmos 720x576
ntrol={dev:/dev/video0;camera_index:1}">/tmp/elss_cmd_in&ftime:40000;io:v4l2} co
[2] 1480
v:0;srcRect:(0,0,720,576);dstRect:(0,0,320,240)} aux={dev:[INFO][01:42:49.770][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 dev_config videoin.0 data={dev:/dev/video0;interlace:0;videoRect:(0,0,720,576);videoStride:1440;ftime:40000;io:v4l2} control={dev:/dev/video0;camera_index:1}
eaux:0;savemode:1}">/tmp/elss_cmd_in&
[3] 1482
[2] Done echo "0 gui:elss 0 dev_config videoin.0 data={dev:/dev/video0;interlace:0;videoRect:(0,0,720,576);videoStride:1440;ftime:40000;io:v4l2} control={dev:/dev/video0;camera_index:1}" >/tmp/elss_cmd_in
[3] Done echo "0 gui:elss 0 channel_config live_video.0 video={dev:0;srcRect:(0,0,720,576);dstRect:(0,0,320,240)} aux={dev:-1} output={dev:0;saveaux:0;savemode:1}" >/tmp/elss_cmd_in
[INFO][01:42:49.830][1481]CaptureDevVideoImpl.cpp:297(Open): device:/dev/video0
@50,831,628us: [+7 T:0x00118ca0 S:0x0011840c] ti.sdo.dmai - [Capture] fd = 9
@50,832,004us: [+2 T:0x00118ca0 S:0x00118354] ti.sdo.dmai - [Capture] Available video input:
@50,832,350us: [+2 T:0x00118ca0 S:0x00118354] ti.sdo.dmai - [Capture] name=COMPOSITE
@50,832,693us: [+2 T:0x00118ca0 S:0x00118354] ti.sdo.dmai - [Capture] name=CMOS-OV3640
@50,833,241us: [+2 T:0x00118ca0 S:0x0011840c] ti.sdo.dmai - [Capture] Video input connected size 720x576 pitch 1440
[INFO][01:42:49.835][1481]DeviceHelper.cpp:409(GetCaptureDevVideoConfig): Unknown Video Decoder IC.Assume STANDARD
[INFO][01:42:49.836][1481]DeviceHelper.cpp:220(Common_SelectCamera): Request:720,576,0
[INFO][01:42:49.836][1481]DeviceHelper.cpp:297(Common_SelectCamera): 24 name=SVGA2PAL - 25fps(720x576), fps=25/1,
[INFO][01:42:49.837][1481]DeviceHelper.cpp:315(Common_SelectCamera): STD: 24=>24,0
[INFO][01:42:49.837][1481]DeviceHelper.cpp:87(V4L2_GetSetPixFmt): 720 576 1440 1
[INFO][01:42:49.837][1481]CaptureDevVideoImpl.cpp:177(UpdateDevProp): SelectCamera:1
@50,838,499us: [+2 T:0x00118ca0 S:0x00118424] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
@50,848,921us: [+2 T:0x00118ca0 S:0x00118454] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x40396000 has physical address 0x80800000
@50,859,232us: [+2 T:0x00118ca0 S:0x00118454] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x40996000 has physical address 0x85000000
@50,869,527us: [+2 T:0x00118ca0 S:0x00118454] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x40f96000 has physical address 0x85800000
@50,879,808us: [+2 T:0x00118ca0 S:0x00118454] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x41596000 has physical address 0x84000000
[INFO][01:42:49.880][1481]CaptureDevVideoImpl.cpp:258(Close): device:/dev/video0
le:channel_0;sharedmem={video:(256,4);audio:(0,0)}}">/tmp/elss_cmd_in&@51,416,210us: [+2 T:0x00118ca0 S:0x001185f4] ti.sdo.dmai - [Capture] call BufTab_delete
@51,416,789us: [+2 T:0x00118ca0 S:0x001185f4] ti.sdo.dmai - [Capture] call BufTab_delete done
@51,417,177us: [+7 T:0x00118ca0 S:0x001185ec] ti.sdo.dmai - [Capture] cleanup 0,fd=9
[INFO][01:42:50.420][1474]AppGraph.cpp:362(CaptureConfigVideo): DumpDevConfig:
index:0, type: 1, ref: 0
DATA: dev:/dev/video0, io:v4l2, videoRect:(0,0,720,576), videoStride:1440, interlace:0, ftime:0
CNTL: dev:/dev/video0, cameraindex:1
[INFO][01:42:50.421][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=dev_config level=OK desc=config_dev_ok
[INFO][01:42:50.421][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 channel_config live_video.0 video={dev:0;srcRect:(0,0,720,576);dstRect:(0,0,320,240)} aux={dev:-1} output={dev:0;saveaux:0;savemode:1}
[INFO][01:42:50.426][1474]VideoSourceFilter.cpp:411(SetProp): 0:320 x 240 of 720 x 576,829440
[INFO][01:42:50.428][1474]VideoSourceFilter.cpp:411(SetProp): 0:320 x 240 of 720 x 576,829440
[INFO][01:42:50.428][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=channel_config target=live_video.0 level=OK desc=config_OK
[2] 1483
root@davinci:~/dm355# [INFO][01:42:52.370][1474]AppCtrlImpl.cpp:703(ReadCmd): Cmd:0 gui:elss 0 channel_config encoder.0 audio={dev:0;codec:g726;channel:left;sps:8000;bps:32000;codecprivate={}} video={dev:0;codec:mpeg4;ftime:1;kbps:1768;srcRect:(0,0,720,576);dstRect:(0,0,720,576);rateControl:vbr;codecprivate={preset:high_quality}} aux={dev:-1} output={timelen:3600;savemode:0; saveaux:0;subtitleDate:1;prerecord:2;postrecord:3;recordtime_week:full;title:channel_0;sharedmem={video:(256,4);audio:(0,0)}}
[INFO][01:42:52.374][1474]VideoSourceFilter.cpp:411(SetProp): 0:352 x 288 of 720 x 576,829440
[INFO][01:42:52.376][1474]VideoEncoderFilter.cpp:747(CheckEncoderCfg): CheckEncoderCfg done
[INFO][01:42:52.377][1474]VideoSourceFilter.cpp:411(SetProp): 0:720 x 576 of 720 x 576,829440
[INFO][01:42:52.377][1474]EncoderChannel.cpp:556(IsAudioCfgChanged): bps:32000,16000 sps:8000,8000 codec:g726,G726 chnl:left, dev:0,-1
[INFO][01:42:52.377][1474]EncoderChannel.cpp:558(IsAudioCfgChanged): Audio Cfg changed!
[INFO][01:42:52.378][1474]EncoderChannel.cpp:603(SetConfig): Disconnect audio
[INFO][01:42:52.378][1474]VideoEncoderFilter.cpp:747(CheckEncoderCfg): CheckEncoderCfg done
[INFO][01:42:52.379][1474]CEVideoEncoder.cpp:316(SetEncoderCfg): bps:1768000, 720 x 576
[INFO][01:42:52.379][1474]EncoderChannel.cpp:657(SetConfig): Done
[INFO][01:42:52.379][1474]AppCtrlImpl.cpp:634(SendResponse): 0 elss:gui 0 RESPONSE cmd=channel_config target=encoder.0 level=OK desc=config_OK
[INFO][01:42:52.432][1474]EncoderChannel.cpp:194(ConnectAudio): Connect audio
[INFO][01:42:52.440][1484]FileRender.cpp:219(OnThreadStartPlay): channel 0 video Stream start
[INFO][01:42:52.440][1484]FileRender.cpp:223(OnThreadStartPlay): channel 0 audio Stream start
[INFO][01:42:52.460][1474]CEVideoEncoder.cpp:316(SetEncoderCfg): bps:1768000, 720 x 576
[INFO][01:42:52.461][1474]CEVideoEncoder.cpp:458(Open): RC:2
@53,461,524us: [+0 T:0x40018730 S:0xbefff82c] CE - Engine_open> Enter('encodedecode', 0x0, 0xbefff8f4)
@53,461,873us: [+0 T:0x40018730 S:0xbefff814] OM - Memory_alloc> Enter(0x2c)
@53,462,166us: [+0 T:0x40018730 S:0xbefff814] OM - Memory_alloc> return (0x144700)
@53,462,555us: [+0 T:0x40018730 S:0xbefff82c] CE - Engine_open> return(1328896)
@53,462,900us: [+2 T:0x40018730 S:0xbefff7c4] ti.sdo.dmai - [Venc1] Creating encoder videnc for max 720x576 bitrate 40000000 ratectrl 2
@53,463,340us: [+0 T:0x40018730 S:0xbefff7a4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x144700, name='videnc', params=0x13fee0)
@53,463,830us: [+0 T:0x40018730 S:0xbefff774] CV - VISA_create(0x144700, 'videnc', 0x13fee0, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@53,464,228us: [+0 T:0x40018730 S:0xbefff69c] CV - VISA_create2(0x144700, 'videnc', 0x13fee0, 0x30, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@53,464,852us: [+0 T:0x40018730 S:0xbefff684] OM - Memory_alloc> Enter(0x30)
@53,465,233us: [+0 T:0x40018730 S:0xbefff684] OM - Memory_alloc> return (0x1446a8)
@53,465,559us: [+0 T:0x40018730 S:0xbefff664] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x400cf28c, idma3Fxns=0x400cf254, iresFxns=0x0, params=0x13fee0, attrs=0xbefff710)
@53,465,963us: [+0 T:0x40018730 S:0xbefff64c] OM - Memory_alloc> Enter(0xc)
@53,466,240us: [+0 T:0x40018730 S:0xbefff64c] OM - Memory_alloc> return (0x144848)
@53,466,576us: [+0 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Enter (scratchId=1, fxns=0x400cf28c, parentAlg=0x0, params=0x13fee0)
@53,466,936us: [+2 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> algNumAlloc 7 memory recs
@53,467,228us: [+2 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> algAlloc returned numRecs=7
@53,467,520us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[0]: size=0x2c6c, align=0x100, space=0x11, attrs=0x1
@53,467,858us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[1]: size=0x200, align=0x100, space=0x11, attrs=0x1
@53,468,234us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[2]: size=0x175800, align=0x100, space=0x11, attrs=0x1
@53,468,578us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[3]: size=0x10e0, align=0x100, space=0x11, attrs=0x1
@53,468,916us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[4]: size=0x4, align=0x100, space=0x11, attrs=0x1
@53,469,246us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[5]: size=0x14000, align=0x100, space=0x11, attrs=0x1
@53,469,621us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Memory requested memTab[6]: size=0x32a0, align=0x100, space=0x11, attrs=0x1
@53,470,097us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x2c6c)
@53,470,419us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=11372, align=256, cached=FALSE, heap=FALSE)
@53,470,783us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@53,471,494us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(11372) = 0x407d8000.
@53,471,888us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x407d8000) = 0x867ba000.
@53,805,041us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x407d8000, size=11372, physAddr=0x867ba000)
@53,805,441us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@53,805,733us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@53,806,009us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x140270)
@53,806,328us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x867ba000, cb->size=11372, cb->virt=0x407d8000
@53,806,690us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x407d8000)
@53,806,981us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x407d8000)
@53,807,402us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x200)
@53,807,718us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=512, align=256, cached=FALSE, heap=FALSE)
@53,808,045us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@53,808,570us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(512) = 0x407ec000.
@53,808,924us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x407ec000) = 0x867b7000.
@53,809,282us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x407ec000, size=512, physAddr=0x867b7000)
@53,809,613us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@53,809,893us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@53,810,314us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x1448e8)
@53,810,657us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x867b7000, cb->size=512, cb->virt=0x407ec000
@53,810,991us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x407ec000)
@53,811,265us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x407ec000)
@53,811,569us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x175800)
@53,811,893us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=1529856, align=256, cached=FALSE, heap=FALSE)
@53,812,229us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@53,812,995us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(1529856) = 0x407ed000.
@53,813,412us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x407ed000) = 0x86c60000.
@53,813,725us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x407ed000, size=1529856, physAddr=0x86c60000)
@53,814,057us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@53,814,347us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@53,814,668us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x144900)
@53,814,944us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x86c60000, cb->size=1529856, cb->virt=0x407ed000
@53,815,276us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x407ed000)
@53,815,547us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x407ed000)
@53,832,668us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x10e0)
@53,833,017us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=4320, align=256, cached=FALSE, heap=FALSE)
@53,833,347us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@53,833,881us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(4320) = 0x4098d000.
@53,834,284us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x4098d000) = 0x867b8000.
@53,834,593us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x4098d000, size=4320, physAddr=0x867b8000)
@53,834,928us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@54,166,949us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@54,167,297us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x144918)
@54,167,581us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x867b8000, cb->size=4320, cb->virt=0x4098d000
@54,167,910us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x4098d000)
@54,168,230us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x4098d000)
@54,168,595us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x4)
@54,168,885us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=4, align=256, cached=FALSE, heap=FALSE)
@54,169,201us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@54,169,765us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(4) = 0x4098f000.
@54,170,255us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x4098f000) = 0x867b6000.
@54,170,585us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x4098f000, size=4, physAddr=0x867b6000)
@54,170,959us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@54,171,254us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@54,171,539us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x144930)
@54,171,809us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x867b6000, cb->size=4, cb->virt=0x4098f000
@54,172,137us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x4098f000)
@54,172,445us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x4098f000)
@54,172,761us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x14000)
@54,173,043us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=81920, align=256, cached=FALSE, heap=FALSE)
@54,173,371us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@54,173,950us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(81920) = 0x40990000.
@54,174,372us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x40990000) = 0x867ce000.
@54,174,690us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x40990000, size=81920, physAddr=0x867ce000)
@54,175,035us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@54,175,376us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@54,175,661us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x144948)
@54,175,928us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x867ce000, cb->size=81920, cb->virt=0x40990000
@54,176,261us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x40990000)
@54,176,580us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x40990000)
@54,177,757us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> Enter(0x32a0)
@54,178,076us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Enter(size=12960, align=256, cached=FALSE, heap=FALSE)
@54,178,403us: [+6 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default 0xffffffff.
@54,179,028us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_alloc(12960) = 0x409ab000.
@54,179,460us: [+4 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> CMEM_getPhys(0x409ab000) = 0x867e9000.
@54,179,778us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> Enter(virtAddr=0x409ab000, size=12960, physAddr=0x867e9000)
@54,180,380us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> creating new contigBuf object
@54,180,750us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> Enter(0x10)
@54,513,631us: [+0 T:0x40018730 S:0xbefff504] OM - Memory_alloc> return (0x144960)
@54,513,964us: [+1 T:0x40018730 S:0xbefff51c] OM - Memory__addContigBuf> returning: cb->phys=0x867e9000, cb->size=12960, cb->virt=0x409ab000
@54,514,311us: [+0 T:0x40018730 S:0xbefff574] OM - Memory_contigAlloc> return (0x409ab000)
@54,514,583us: [+0 T:0x40018730 S:0xbefff5c4] OM - Memory_alloc> return (0x409ab000)
@54,518,809us: [+4 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> algInit returned IALG_EOK
@54,519,225us: [+0 T:0x40018730 S:0xbefff614] ti.sdo.ce.alg - ALG_create> Exit (algHandle=0x407d8000)
@54,519,639us: [+0 T:0x40018730 S:0xbefff5e4] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xf97b8]
@54,519,975us: [+0 T:0x40018730 S:0xbefff5b4] ti.sdo.ce.osal.SemMP - Entered SemMP_pend> sem[0xf97d0] timeout[0xffffffff]
@54,520,536us: [+0 T:0x40018730 S:0xbefff5b4] ti.sdo.ce.osal.SemMP - Leaving SemMP_pend> sem[0xf97d0] status[0]
@54,520,864us: [+0 T:0x40018730 S:0xbefff5fc] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xf97b8]
@54,521,431us: [+0 T:0x40018730 S:0xbefff58c] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xf97b8]
@54,521,828us: [+0 T:0x40018730 S:0xbefff5a4] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xf97b8]
@54,522,139us: [+0 T:0x40018730 S:0xbefff594] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xf97b8]
@54,522,436us: [+0 T:0x40018730 S:0xbefff5a4] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xf97b8]
@54,522,719us: [+0 T:0x40018730 S:0xbefff5ec] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xf97b8]
@54,523,009us: [+0 T:0x40018730 S:0xbefff5cc] ti.sdo.ce.osal.SemMP - Entered SemMP_post> sem[0xf97d0]
@54,523,379us: [+0 T:0x40018730 S:0xbefff5cc] ti.sdo.ce.osal.SemMP - Leaving SemMP_post> sem[0xf97d0]
@54,523,677us: [+0 T:0x40018730 S:0xbefff5fc] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xf97b8]
@54,523,984us: [+7 T:0x40018730 S:0xbefff664] ti.sdo.ce.alg.Algorithm - Algorithm_create> Granting DMA channels to algorithm through DMAN3 FAILED (0xfffffffe).
@54,524,373us: [+0 T:0x40018730 S:0xbefff654] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x144848)
@54,525,432us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x407d8000, 0x2c6c)
@54,525,789us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1081966592, size=11372)
@54,526,353us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x407d8000, size=11372)
@54,526,723us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x867ba000, cb->size=0x2c6c, cb->virt=0x407d8000
@54,527,072us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x140270, 0x10)
@54,527,410us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,527,687us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,527,953us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,528,209us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x407ec000, 0x200)
@54,528,473us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1082048512, size=512)
@54,528,910us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x407ec000, size=512)
@54,529,254us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x867b7000, cb->size=0x200, cb->virt=0x407ec000
@54,529,632us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x1448e8, 0x10)
@54,529,919us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,530,510us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,530,798us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,531,057us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x407ed000, 0x175800)
@54,531,331us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1082052608, size=1529856)
@54,535,531us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x407ed000, size=1529856)
@54,868,570us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x86c60000, cb->size=0x175800, cb->virt=0x407ed000
@54,868,968us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x144900, 0x10)
@54,869,261us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,869,528us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,869,830us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,870,230us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x4098d000, 0x10e0)
@54,870,534us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1083756544, size=4320)
@54,870,968us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x4098d000, size=4320)
@54,871,354us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x867b8000, cb->size=0x10e0, cb->virt=0x4098d000
@54,871,705us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x144918, 0x10)
@54,871,990us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,872,247us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,872,550us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,872,852us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x4098f000, 0x4)
@54,873,125us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1083764736, size=4)
@54,873,534us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x4098f000, size=4)
@54,873,868us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x867b6000, cb->size=0x4, cb->virt=0x4098f000
@54,874,256us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x144930, 0x10)
@54,874,543us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,874,805us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,875,064us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,875,320us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x40990000, 0x14000)
@54,875,634us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1083768832, size=81920)
@54,876,106us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x40990000, size=81920)
@54,876,466us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x867ce000, cb->size=0x14000, cb->virt=0x40990000
@54,876,855us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x144948, 0x10)
@54,877,147us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,877,411us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,877,678us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,877,927us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> Enter(0x409ab000, 0x32a0)
@54,878,230us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> Enter(addr=1083879424, size=12960)
@54,879,156us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> Enter(virtAddr=0x409ab000, size=12960)
@54,879,546us: [+1 T:0x40018730 S:0xbefff56c] OM - Memory__removeContigBuf> removing cb->phys=0x867e9000, cb->size=0x32a0, cb->virt=0x409ab000
@54,879,901us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> Enter(0x144960, 0x10)
@54,880,472us: [+0 T:0x40018730 S:0xbefff544] OM - Memory_free> return (0x1)
@54,880,764us: [+0 T:0x40018730 S:0xbefff59c] OM - Memory_contigFree> return (0x1)
@54,881,078us: [+0 T:0x40018730 S:0xbefff5dc] OM - Memory_free> return (0x1)
@54,881,366us: [+0 T:0x40018730 S:0xbefff63c] OM - Memory_free> Enter(0x144848, 0xc)
@54,881,640us: [+0 T:0x40018730 S:0xbefff63c] OM - Memory_free> return (0x1)
@54,881,896us: [+0 T:0x40018730 S:0xbefff664] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
@54,882,181us: [+2 T:0x40018730 S:0xbefff69c] CV - VISA_create> FAILED to create local codec.
@54,882,543us: [+0 T:0x40018730 S:0xbefff674] CV - VISA_delete(0x1446a8)
@55,215,345us: [+5 T:0x40018730 S:0xbefff674] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
@55,215,729us: [+0 T:0x40018730 S:0xbefff64c] OM - Memory_free> Enter(0x1446a8, 0x30)
@55,216,030us: [+0 T:0x40018730 S:0xbefff64c] OM - Memory_free> return (0x1)
@55,216,299us: [+0 T:0x40018730 S:0xbefff7a4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
@55,216,682us: [+7 T:0x40018730 S:0xbefff7c4] ti.sdo.dmai - [Venc1] Failed to open video encode algorithm: videnc (0)
[ERRO][01:42:54.217][1474]CEVideoEncoder.cpp:485(Open): Failed to create video encoder: videnc
@55,217,429us: [+0 T:0x40018730 S:0xbefff84c] CE - Engine_close(0x144700)
@55,217,778us: [+0 T:0x40018730 S:0xbefff844] OM - Memory_free> Enter(0x144700, 0x2c)
@55,218,136us: [+0 T:0x40018730 S:0xbefff844] OM - Memory_free> return (0x1)
[INFO][01:42:54.260][1474]AppGraph.cpp:608(ChannelRun): Channel encoder.0 run done
[INFO][01:42:54.260][1481]CaptureDevVideoImpl.cpp:297(Open): device:/dev/video0
@55,261,538us: [+7 T:0x00118ca0 S:0x00118404] ti.sdo.dmai - [Capture] fd = 14
@55,261,864us: [+2 T:0x00118ca0 S:0x0011834c] ti.sdo.dmai - [Capture] Available video input:
@55,262,189us: [+2 T:0x00118ca0 S:0x0011834c] ti.sdo.dmai - [Capture] name=COMPOSITE
@55,262,543us: [+2 T:0x00118ca0 S:0x0011834c] ti.sdo.dmai - [Capture] name=CMOS-OV3640
@55,262,941us: [+2 T:0x00118ca0 S:0x00118404] ti.sdo.dmai - [Capture] Video input connected size 720x576 pitch 1440
[INFO][01:42:54.264][1481]DeviceHelper.cpp:409(GetCaptureDevVideoConfig): Unknown Video Decoder IC.Assume STANDARD
[INFO][01:42:54.264][1481]DeviceHelper.cpp:220(Common_SelectCamera): Request:720,576,0
[INFO][01:42:54.265][1481]DeviceHelper.cpp:87(V4L2_GetSetPixFmt): 720 576 1440 1
[INFO][01:42:54.265][1481]CaptureDevVideoImpl.cpp:177(UpdateDevProp): SelectCamera:1
@55,266,116us: [+2 T:0x00118ca0 S:0x0011841c] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
@55,276,540us: [+2 T:0x00118ca0 S:0x0011844c] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x40a34000 has physical address 0x80800000
@55,286,988us: [+2 T:0x00118ca0 S:0x0011844c] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x41034000 has physical address 0x85000000
@55,297,487us: [+2 T:0x00118ca0 S:0x0011844c] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x41634000 has physical address 0x85800000
@55,307,964us: [+2 T:0x00118ca0 S:0x0011844c] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x41c34000 has physical address 0x84000000
@55,876,460us: [+7 T:0x00118ca0 S:0x0011860c] ti.sdo.dmai - [Capture] Start ok
[INFO][01:42:54.877][1481]CaptureDevMgrImpl.cpp:337(AddChannelToQueue): (1,0) 41###################
[INFO][01:42:54.880][1474]AppGraph.cpp:616(ChannelRun): call AddChannel encoder.0 done
[INFO][01:42:54.881][1478]CaptureDevAudioImpl.cpp:245(Open): /dev/dsp,channelcount:1
[INFO][01:42:54.881][1478]CaptureDevAudioImpl.cpp:246(Open): SetInputVolume:75,75
@55,881,954us: [+2 T:0x00111a50 S:0x00111324] ti.sdo.dmai - [Sound] Microphone recorder selected
[INFO][01:42:54.884][1478]CaptureDevAudioImpl.cpp:256(Open): m_iBufSize:1536,m_iRecInterval:96000,1,8000,16
[INFO][01:42:54.884][1478]CaptureDevMgrImpl.cpp:337(AddChannelToQueue): (1,0) 21###################
[INFO][01:42:54.883][1481]CaptureDevMgrImpl.cpp:186(ThreadProc): MainLoop begin
[INFO][01:42:54.890][1474]AppGraph.cpp:635(ChannelRun): call AddChannel encoder.0 done
[INFO][01:42:54.890][1474]AppCtrlImpl.cpp:605(SendReport): 0 elss:gui 0 REPORT code=1 channel=encoder.0 desc=Run
[INFO][01:42:54.891][1478]CaptureDevMgrImpl.cpp:186(ThreadProc): MainLoop begin
[INFO][01:42:54.954][1481]CaptureDevVideoImpl.cpp:495(Read): Gap:0 0 0000181e000ea600 0000181e000ea600
[INFO][01:42:54.955][1485]VideoEncoderFilter.cpp:192(MediaTypeChange): rcSource:(0,0,720,576)(0,0,720,576)
[INFO][01:42:54.955][1485]VideoEncoderFilter.cpp:194(MediaTypeChange): rcTarget:(0,0,720,576)(0,0,720,576)
@55,956,384us: [+0 T:0x0014ca20 S:0x0014c24c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x40a34000, size=4)
@55,956,786us: [+1 T:0x0014ca20 S:0x0014c24c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x40a34000, size=4)
@55,957,121us: [+1 T:0x0014ca20 S:0x0014c24c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
@55,957,493us: [+1 T:0x0014ca20 S:0x0014c24c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x40a34000) = 0x80800000.
@55,957,848us: [+1 T:0x0014ca20 S:0x0014c1f4] OM - Memory__addContigBuf> Enter(virtAddr=0x40a34000, size=4, physAddr=0x80800000)
@55,958,192us: [+1 T:0x0014ca20 S:0x0014c1f4] OM - Memory__addContigBuf> creating new contigBuf object
@55,958,487us: [+0 T:0x0014ca20 S:0x0014c1dc] OM - Memory_alloc> Enter(0x10)
@55,958,810us: [+0 T:0x0014ca20 S:0x0014c1dc] OM - Memory_alloc> return (0x1539b8)
@55,959,104us: [+1 T:0x0014ca20 S:0x0014c1f4] OM - Memory__addContigBuf> returning: cb->phys=0x80800000, cb->size=4, cb->virt=0x40a34000
@55,959,449us: [+0 T:0x0014ca20 S:0x0014c24c] OM - Memory_getBufferPhysicalAddress> return (0x80800000)
[ERRO][01:42:54.959][1485]CEVideoEncoder.cpp:562(Process): m_hVe==NULL
[ERRO][01:42:54.960][1485]VideoEncoderFilter.cpp:550(Transform): m_pCodec->Process failed
[ERRO][01:42:54.990][1474]AppGraph.cpp:869(HandleEvent): Channel 0 Event Code:-1
[INFO][01:42:54.990][1474]AppGraph.cpp:690(ChannelStop): Stop encoder.0 ...
@55,995,434us: [+7 T:0x00118ca0 S:0x001185e4] ti.sdo.dmai - [Capture] stop 1
[INFO][01:42:54.995][1481]CaptureDevMgrImpl.cpp:386(DelChannelFromQueue): 41 removed.(0,0) ###################
[INFO][01:42:55.000][1474]AppGraph.cpp:700(ChannelStop): encoder.0 removed from video queue
[INFO][01:42:55.089][1486]AudioEncoderFilter.cpp:314(Transform): Detect media change.
[INFO][01:42:55.110][1478]CaptureDevMgrImpl.cpp:386(DelChannelFromQueue): 21 removed.(0,0) ###################
[INFO][01:42:55.120][1474]AppGraph.cpp:714(ChannelStop): encoder.0 removed from audio queue
[INFO][01:42:55.200][1474]AppCtrlImpl.cpp:605(SendReport): 0 elss:gui 1 REPORT code=2 channel=encoder.0 desc=Stop
[INFO][01:42:55.201][1474]AppGraph.cpp:736(ChannelStop): Stop encoder.0 Done
[INFO][01:42:55.201][1474]AppCtrlImpl.cpp:605(SendReport): 0 elss:gui 2 REPORT code=-1 channel=encoder.0 desc=VideoEncoder_EncoderFail
