VPIF capture from composite in through vpif_mmap_loopback on OMAP-L138 LCDK
Other Parts Discussed in Thread: OMAP-L138, PMP, DA8XX
I've configured and build linux kernell for OMAP L138, as it describes here: http://processors.wiki.ti.com/index.php/MCSDK_OMAPL138_User_Guide_Chapter_Exploring#Overview
Then I'm build examples for VPIF, provided with PSP 03.21.00.04.
But when I'm booting my linux on OMAP-L138 LCSDK with following bootargs: vpif_capture.ch0_bufsize=831488 vpif_display.ch2_bufsize=831488, and trying to captured video stream from my analog cam, connected to composite in, by running command ./vpif_mmap_loopback -m 1 -p 0, it shows an following error:
_________________________________________________________
root@omapl138-lcdk:~/vpif# ./vpif_mmap_loopback -m 1 -p 0
Cannot open = /dev/video0 device
Error in opening capture device for channel 0.
____________________________________________________________________________
As I understand my camera should to be identifired as video device in /dev/video0. But it didn't happen.
Can anybody help me, what am is supposed to do to fix this problem?
  • You are right. The video device is not enumerated or not connected.
    Have you connected the camera to board ?
    In which connector ?
    Can you please attach the Linux bootup log ?
  • I've connected analog cam in composite-in.
    I've set printk in init functions in source code of tvp514x, vpif and vpif capture drivers, and I've get the following bootup log( prints are mentioned as "init_tvp514x, vpif init, vpif capture init") :
    NAND: 512 MiB
    MMC: davinci: 0
    Bad block table found at page 262080, version 0x01
    Bad block table found at page 262016, version 0x01
    In: serial
    Out: serial
    Err: serial
    ARM Clock : 456000000 Hz
    DDR Clock : 150000000 Hz
    Net: Ethernet PHY: GENERIC @ 0x07
    DaVinci-EMAC
    Hit any key to stop autoboot: 0
    U-Boot > loady c0700000 460800
    ## Switch baudrate to 460800 bps and press ENTER ...
    ## Ready for binary (ymodem) download to 0xC0700000 at 460800 bps...
    CCxyzModem - CRC mode, 0(SOH)/2480(STX)/0(CAN) packets, 3 retries
    ## Total Size = 0x0026b928 = 2537768 Bytes
    ## Switch baudrate to 115200 bps and press ESC ...
    U-Boot > bootm
    ## Booting kernel from Legacy Image at c0700000 ...
    Image Name: Linux-3.3.0
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 2537704 Bytes = 2.4 MiB
    Load Address: c0008000
    Entry Point: c0008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    Booting Linux on physical CPU 0
    Linux version 3.3.0 (root@ubuntu) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #5 PREEMPT Mon Sep 5 18:08:18 MSK 2016
    CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    CPU: VIVT data cache, VIVT instruction cache
    Machine: AM18x/OMAP-L138 lcdk board
    Memory policy: ECC disabled, Data cache writeback
    BUG: mapping for 0x80000000 at 0xfffe0000 out of vmalloc space
    DaVinci da850/omap-l138/am18x variant 0x1
    Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
    Kernel command line: mem=32M console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootwait ip=off vpif_capture.ch0_bufsize=831488 vpif_display.ch2_bufsize=831488
    PID hash table entries: 128 (order: -3, 512 bytes)
    Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
    Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Memory: 32MB = 32MB total
    Memory: 27100k/27100k available, 5668k reserved, 0K highmem
    Virtual kernel memory layout:
    vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
    vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
    lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
    modules : 0xbf000000 - 0xc0000000 ( 16 MB)
    .text : 0xc0008000 - 0xc04b4000 (4784 kB)
    .init : 0xc04b4000 - 0xc04de000 ( 168 kB)
    .data : 0xc04de000 - 0xc051a680 ( 242 kB)
    .bss : 0xc051a6a4 - 0xc053648c ( 112 kB)
    SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    NR_IRQS:245
    Console: colour dummy device 80x30
    Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    Setting up static identity map for 0xc038d178 - 0xc038d1d0
    gpiochip_add: registered GPIOs 0 to 31 on device: DaVinci
    gpiochip_add: registered GPIOs 32 to 63 on device: DaVinci
    gpiochip_add: registered GPIOs 64 to 95 on device: DaVinci
    gpiochip_add: registered GPIOs 96 to 127 on device: DaVinci
    gpiochip_add: registered GPIOs 128 to 143 on device: DaVinci
    DaVinci: 144 gpio irqs
    print_constraints: dummy:
    NET: Registered protocol family 16
    EMAC: MII PHY configured
    bio: create slab <bio-0> at 0
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    i2c-gpio i2c-gpio.1: using pins 20 (SDA) and 21 (SCL)
    -------------------vpif init-------------------------
    Advanced Linux Sound Architecture Driver Version 1.0.24.
    Switching to clocksource timer0_1
    musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    musb-hdrc musb-hdrc: dma type: dma-cppi41
    MUSB255 controller's USBSS revision = 4ea11003
    Waiting for USB PHY clock good...
    musb-hdrc musb-hdrc: USB OTG mode controller at fee00000 using DMA, IRQ 58
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 1024 (order: 1, 8192 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    TCP reno registered
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    JFFS2 version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
    msgmni has been set to 52
    io scheduler noop registered (default)
    Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
    serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a AR7
    serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a AR7
    serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a AR7
    console [ttyS2] enabled
    brd: module loaded
    ahci ahci: forcing PORTS_IMPL to 0x1
    ahci ahci: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc
    scsi0 : ahci_platform
    ata1: SATA max UDMA/133 mmio [mem 0x01e18000-0x01e19fff] port 0x100 irq 67
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
    davinci_mdio davinci_mdio.0: detected phy mask ffffff7f
    davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[7]: device davinci_mdio-0:07, driver SMSC LAN8710/LAN8720
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    ohci ohci.0: DA8xx OHCI
    ohci ohci.0: new USB bus registered, assigned bus number 1
    ohci ohci.0: irq 59, io mem 0x01e25000
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    input: gpio-keys-polled as /devices/platform/gpio-keys-polled.0/input/input0
    omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    omap_rtc: RTC power up reset detected
    i2c /dev entries driver
    lirc_dev: IR Remote Control driver registered, major 253
    IR NEC protocol handler initialized
    IR RC5(x) protocol handler initialized
    IR RC6 protocol handler initialized
    IR JVC protocol handler initialized
    IR Sony protocol handler initialized
    IR RC5 (streamzap) protocol handler initialized
    IR SANYO protocol handler initialized
    IR MCE Keyboard/mouse protocol handler initialized
    IR LIRC bridge handler initialized
    Linux video capture interface: v2.00
    --------------------------init_tvp514x----------------------------------
    -----------------------vpif capture init--------------------------------
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (1.1.1)
    watchdog watchdog: heartbeat 60 sec
    cpuidle: using governor ladder
    cpuidle: using governor menu
    davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    usbcore: registered new interface driver snd-usb-audio
    soc-audio soc-audio.0: ASoC: Failed to create card debugfs directory
    _regulator_get: 1-0018 supply IOVDD not found, using dummy regulator
    ata1: SATA link down (SStatus 0 SControl 300)
    _regulator_get: 1-0018 supply DVDD not found, using dummy regulator
    _regulator_get: 1-0018 supply AVDD not found, using dummy regulator
    _regulator_get: 1-0018 supply DRVDD not found, using dummy regulator
    asoc: tlv320aic3x-hifi <-> davinci-mcasp.0 mapping ok
    ALSA device list:
    #0: DA850/OMAP-L138 EVM
    TCP cubic registered
    NET: Registered protocol family 17
    console [netcon0] enabled
    netconsole: network logging started
    davinci_emac davinci_emac.1: using random MAC addr: f2:67:1e:e0:16:4f
    omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    Waiting for root device /dev/mmcblk0p2...
    mmc0: new high speed SDHC card at address 1234
    mmcblk0: mmc0:1234 SA04G 3.63 GiB
    mmcblk0: p1 p2 p3 < p5 >
    EXT3-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
    kjournald starting. Commit interval 5 seconds
    EXT3-fs (mmcblk0p2): using internal journal
    EXT3-fs (mmcblk0p2): recovery complete
    EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    VFS: Mounted root (ext3 filesystem) on device 179:2.
    Freeing init memory: 168K
    INIT: version 2.86 booting
    Please wait: booting...
    Error opening /dev/fb0: No such device or address
    Starting udev
    udevd (615): /proc/615/oom_adj is deprecated, please use /proc/615/oom_score_adj instead.
    udev: starting version 141
    Remounting root file system...
    Caching udev devnodes
    Populating dev cacheFAT-fs (mmcblk0p3): invalid media value (0x1f)
    FAT-fs (mmcblk0p3): Can't find a valid FAT filesystem
    mv: cannot rename '/tmp/devices': No such file or directory
    logger: mount: mount point /proc/bus/usb does not exist
    logger: mount: special device /dev/sda1 does not exist
    ALSA: Restoring mixer settings...
    Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
    ifconfig: SIOCSIFADDR: No such device
    done.
    Setting up IP spoofing protection: rp_filter.
    Mon Nov 11 00:54:00 UTC 2013
    INIT: Entering runlevel: 5
    Starting system message bus: dbus.
    Starting Hardware abstraction layer hald
    Starting Dropbear SSH server: dropbear.
    Starting telnet daemon.
    Starting network benchmark server: netserver.
    Starting syslogd/klogd: done
    Starting thttpd.
    Starting Lighttpd Web Server: lighttpd.
    2013-11-11 00:54:04: (log.c.166) server started
    NOTICE: This file system contains the followin GPLv3 packages:
    binutils-symlinks
    binutils
    gdbserver
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution. This can be done using
    the opkg remove command. i.e.:
    opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
    will be notified of the dependent packages. You should
    use the --force-removal-of-dependent-packages option to
    also remove the dependent packages as well
    But I can't understand, how analog cam can be identifiered as /dev/video0.
    As I understand all test applications use /dev/video0, but video0, what is it? Connected cam devise? If it is a cam device, how it can be identifired as dev0, when it hasn't feedback signal?
    Can you attach your config file ? (can you check if DA850_UI_SD_VIDEO_PORT is enabled in it)
    Also can you post the dmesg output as well.
    Cheers,
    --Prabhakar Lad
  • Thanks, but my kernel is already configured as it describes in this link, what you attached.
    I can't understand, how analog cam can be identified as /dev/video0.
    As I understand all test applications in PSP use /dev/video0, but what is the video0? Connected cam devise? If it is a cam device, how analog cam can be identifired as dev0, when it hasn't feedback signal? Or vpif drivers and test applications can't capturing video stream from analog cam and can do it only through CCDC in?
    Its not you analog cam as /dev/video0 its the bridge.
    To explain you in more detail, You say you have configured as per this link processors.wiki.ti.com/.../Arago_build_recipe_for_OMAPL1
    So now your system would look like this:
    Your Analog ======>>> TVP514x =====>> VPIF====>> /dev/video0
    Camera (composite) Decoder chip
    So the /dev/video0 (which is created by VPIF driver) is the interface for your application which talks to the VPIF driver.
    So now when you open the /dev/video0 and configure the format and start streaming the, the VPIF driver will internally configure the tvp514x decoder and start streaming.
    The TVp514x video decoder converts the analog to digital, this decoder supports SD(NTSC and PAL), so if your analog CAM can output this signals, you should be able to record video.
    No matter if you connect your camera to TVp514x chip the /dev/video0 node will be created.
    Cheers,
    --Prabhakar Lad
  • /dev/video0 should appears, when I connect my cam?Doesn't it appears, at once booting kernel is done?
    And if i haven't /dev/video0 in either way, does it mean, that vpif and tvp drivers doesn't correctly configured in my kernel?
    If your vpif driver is loaded successfully the /dev/video0 should be created no matter you have your cam connected or not.
    [Ilya] And if i haven't /dev/video0 in either way, does it mean, that vpif and tvp drivers doesn't correctly configured in my kernel?
    [Prabhakar] Yes you are rite.
    Can you attach the config file and also the dmesg output so that we can direct you properly..
    Cheers,
    --Prabhakar Lad
  • I'm sorry, what is the "dmesg output"?
  • This is my .config file
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 3.3.0 Kernel Configuration
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_GENERIC_GPIO=y
    # CONFIG_ARCH_USES_GETTIMEOFFSET is not set
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_KTIME_SCALAR=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_ZONE_DMA=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_HAVE_IRQ_WORK=y
    # General setup
    CONFIG_EXPERIMENTAL=y
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_CROSS_COMPILE=""
    CONFIG_LOCALVERSION=""
    # CONFIG_LOCALVERSION_AUTO is not set
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_KERNEL_GZIP=y
    # CONFIG_KERNEL_LZMA is not set
    # CONFIG_KERNEL_LZO is not set
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    # CONFIG_BSD_PROCESS_ACCT is not set
    # CONFIG_FHANDLE is not set
    # CONFIG_TASKSTATS is not set
    # CONFIG_AUDIT is not set
    CONFIG_HAVE_GENERIC_HARDIRQS=y
    # IRQ subsystem
    CONFIG_GENERIC_HARDIRQS=y
    CONFIG_HAVE_SPARSE_IRQ=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_GENERIC_IRQ_CHIP=y
    # CONFIG_SPARSE_IRQ is not set
    # RCU Subsystem
    CONFIG_TINY_PREEMPT_RCU=y
    CONFIG_PREEMPT_RCU=y
    # CONFIG_RCU_TRACE is not set
    # CONFIG_TREE_RCU_TRACE is not set
    # CONFIG_RCU_BOOST is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=14
    # CONFIG_CGROUPS is not set
    # CONFIG_CHECKPOINT_RESTORE is not set
    # CONFIG_NAMESPACES is not set
    # CONFIG_SCHED_AUTOGROUP is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    # CONFIG_RD_BZIP2 is not set
    # CONFIG_RD_LZMA is not set
    # CONFIG_RD_XZ is not set
    # CONFIG_RD_LZO is not set
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    CONFIG_SYSCTL_SYSCALL=y
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    CONFIG_HOTPLUG=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_EMBEDDED=y
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # Kernel Performance Events And Counters
    # CONFIG_PERF_EVENTS is not set
    # CONFIG_PERF_COUNTERS is not set
    CONFIG_VM_EVENT_COUNTERS=y
    CONFIG_SLUB_DEBUG=y
    CONFIG_COMPAT_BRK=y
    # CONFIG_SLAB is not set
    CONFIG_SLUB=y
    # CONFIG_SLOB is not set
    # CONFIG_PROFILING is not set
    CONFIG_HAVE_OPROFILE=y
    # CONFIG_KPROBES is not set
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_DMA_API_DEBUG=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    # CONFIG_MODULE_FORCE_LOAD is not set
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    # CONFIG_MODULE_SRCVERSION_ALL is not set
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_BSGLIB is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    # CONFIG_EFI_PARTITION is not set
    # CONFIG_SYSV68_PARTITION is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    # CONFIG_IOSCHED_DEADLINE is not set
    # CONFIG_IOSCHED_CFQ is not set
    CONFIG_DEFAULT_NOOP=y
    CONFIG_DEFAULT_IOSCHED="noop"
    # CONFIG_INLINE_SPIN_TRYLOCK is not set
    # CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
    # CONFIG_INLINE_SPIN_LOCK is not set
    # CONFIG_INLINE_SPIN_LOCK_BH is not set
    # CONFIG_INLINE_SPIN_LOCK_IRQ is not set
    # CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
    # CONFIG_INLINE_SPIN_UNLOCK is not set
    # CONFIG_INLINE_SPIN_UNLOCK_BH is not set
    # CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set
    # CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
    # CONFIG_INLINE_READ_TRYLOCK is not set
    # CONFIG_INLINE_READ_LOCK is not set
    # CONFIG_INLINE_READ_LOCK_BH is not set
    # CONFIG_INLINE_READ_LOCK_IRQ is not set
    # CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
    # CONFIG_INLINE_READ_UNLOCK is not set
    # CONFIG_INLINE_READ_UNLOCK_BH is not set
    # CONFIG_INLINE_READ_UNLOCK_IRQ is not set
    # CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
    # CONFIG_INLINE_WRITE_TRYLOCK is not set
    # CONFIG_INLINE_WRITE_LOCK is not set
    # CONFIG_INLINE_WRITE_LOCK_BH is not set
    # CONFIG_INLINE_WRITE_LOCK_IRQ is not set
    # CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
    # CONFIG_INLINE_WRITE_UNLOCK is not set
    # CONFIG_INLINE_WRITE_UNLOCK_BH is not set
    # CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set
    # CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
    # CONFIG_MUTEX_SPIN_ON_OWNER is not set
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_BCMRING is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_CNS3XXX is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_PRIMA2 is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_MXS is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_H720X is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP23XX is not set
    # CONFIG_ARCH_IXP2000 is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_LPC32XX is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_PICOXCELL is not set
    # CONFIG_ARCH_PNX4008 is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_MSM is not set
    # CONFIG_ARCH_SHMOBILE is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C2410 is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_S5P64X0 is not set
    # CONFIG_ARCH_S5PC100 is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_SHARK is not set
    # CONFIG_ARCH_U300 is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_NOMADIK is not set
    CONFIG_ARCH_DAVINCI=y
    # CONFIG_ARCH_OMAP is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_VT8500 is not set
    # CONFIG_ARCH_ZYNQ is not set
    CONFIG_CP_INTC=y
    # TI DaVinci Implementations
    # DaVinci Core Type
    # CONFIG_ARCH_DAVINCI_DM644x is not set
    # CONFIG_ARCH_DAVINCI_DM355 is not set
    # CONFIG_ARCH_DAVINCI_DM646x is not set
    # CONFIG_ARCH_DAVINCI_DA830 is not set
    CONFIG_ARCH_DAVINCI_DA850=y
    # CONFIG_DAVINCI_UART1_AFE is not set
    CONFIG_ARCH_DAVINCI_DA8XX=y
    # CONFIG_ARCH_DAVINCI_DM365 is not set
    # CONFIG_ARCH_DAVINCI_TNETV107X is not set
    # DaVinci Board Type
    # CONFIG_WIFI_CONTROL_FUNC is not set
    CONFIG_DA850_USE_MMC0=y
    # CONFIG_DA850_USE_MMC1 is not set
    CONFIG_MACH_DAVINCI_DA850_EVM=y
    # CONFIG_DA850_UI_NONE is not set
    # CONFIG_DA850_UI_RMII is not set
    # CONFIG_DA850_UI_CLCD is not set
    CONFIG_DA850_UI_SD_VIDEO_PORT=y
    # CONFIG_DA850_UI_CAMERA is not set
    CONFIG_DA850_FIX_PLL0_SYSCLK3RATE=0
    # CONFIG_DA850_WL12XX is not set
    CONFIG_GPIO_PCA953X=y
    CONFIG_KEYBOARD_GPIO_POLLED=y
    # CONFIG_MACH_MITYOMAPL138 is not set
    CONFIG_MACH_OMAPL138_LCDKBOARD=y
    CONFIG_MACH_DAVINCI_DA850_SDI=y
    CONFIG_DA850_SDI_LCDC=y
    # CONFIG_DA850_SDI_DVI_VGA is not set
    # CONFIG_DA850_SDI_DVI_480P is not set
    # CONFIG_DA850_SDI_DVI_WVGA is not set
    # CONFIG_DA850_SDI_MII is not set
    CONFIG_DA850_SDI_MAX_SPEED=456000
    CONFIG_DAVINCI_MUX=y
    # CONFIG_DAVINCI_MUX_DEBUG is not set
    # CONFIG_DAVINCI_MUX_WARNINGS is not set
    CONFIG_DAVINCI_RESET_CLOCKS=y
    # System MMU
    # Processor Type
    CONFIG_CPU_ARM926T=y
    CONFIG_CPU_32v5=y
    CONFIG_CPU_ABRT_EV5TJ=y
    CONFIG_CPU_PABRT_LEGACY=y
    CONFIG_CPU_CACHE_VIVT=y
    CONFIG_CPU_COPY_V4WB=y
    CONFIG_CPU_TLB_V4WBI=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    CONFIG_CPU_USE_DOMAINS=y
    # Processor Features
    # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
    CONFIG_ARM_THUMB=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_WRITETHROUGH is not set
    # CONFIG_CPU_CACHE_ROUND_ROBIN is not set
    # CONFIG_CACHE_L2X0 is not set
    CONFIG_ARM_L1_CACHE_SHIFT=5
    CONFIG_ARM_NR_BANKS=8
    # Bus support
    # CONFIG_PCI_SYSCALL is not set
    # CONFIG_ARCH_SUPPORTS_MSI is not set
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    CONFIG_ARCH_NR_GPIO=0
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_PREEMPT_COUNT=y
    CONFIG_HZ=100
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    CONFIG_HAVE_ARCH_PFN_VALID=y
    # CONFIG_HIGHMEM is not set
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_HAVE_MEMBLOCK=y
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=999999
    # CONFIG_COMPACTION is not set
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=1
    CONFIG_BOUNCE=y
    CONFIG_VIRT_TO_BUS=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_NEED_PER_CPU_KM=y
    # CONFIG_CLEANCACHE is not set
    CONFIG_FORCE_MAX_ZONEORDER=11
    CONFIG_LEDS=y
    # CONFIG_LEDS_CPU is not set
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_SECCOMP is not set
    # CONFIG_CC_STACKPROTECTOR is not set
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    # Boot options
    # CONFIG_USE_OF is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_CMDLINE=""
    # CONFIG_XIP_KERNEL is not set
    # CONFIG_KEXEC is not set
    # CONFIG_CRASH_DUMP is not set
    # CONFIG_AUTO_ZRELADDR is not set
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
    CONFIG_CPU_FREQ_STAT=y
    # CONFIG_CPU_FREQ_STAT_DETAILS is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    # ARM CPU frequency scaling drivers
    # CONFIG_ARM_EXYNOS4210_CPUFREQ is not set
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
    # Floating point emulation
    # At least one emulation must be selected
    # CONFIG_VFP is not set
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE=y
    # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
    CONFIG_HAVE_AOUT=y
    # CONFIG_BINFMT_AOUT is not set
    # CONFIG_BINFMT_MISC is not set
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    CONFIG_PM_SLEEP=y
    # CONFIG_PM_RUNTIME is not set
    CONFIG_PM=y
    # CONFIG_PM_DEBUG is not set
    # CONFIG_APM_EMULATION is not set
    CONFIG_PM_CLK=y
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    CONFIG_UNIX=y
    # CONFIG_UNIX_DIAG is not set
    CONFIG_XFRM=y
    # CONFIG_XFRM_USER is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    # CONFIG_NET_KEY is not set
    CONFIG_INET=y
    # CONFIG_IP_MULTICAST is not set
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    # CONFIG_IP_PNP_BOOTP is not set
    # CONFIG_IP_PNP_RARP is not set
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    # CONFIG_ARPD is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_INET_AH is not set
    # CONFIG_INET_ESP is not set
    # CONFIG_INET_IPCOMP is not set
    # CONFIG_INET_XFRM_TUNNEL is not set
    CONFIG_INET_TUNNEL=m
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
    # CONFIG_INET_LRO is not set
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=m
    # CONFIG_IPV6_PRIVACY is not set
    # CONFIG_IPV6_ROUTER_PREF is not set
    # CONFIG_IPV6_OPTIMISTIC_DAD is not set
    # CONFIG_INET6_AH is not set
    # CONFIG_INET6_ESP is not set
    # CONFIG_INET6_IPCOMP is not set
    # CONFIG_IPV6_MIP6 is not set
    # CONFIG_INET6_XFRM_TUNNEL is not set
    # CONFIG_INET6_TUNNEL is not set
    CONFIG_INET6_XFRM_MODE_TRANSPORT=m
    CONFIG_INET6_XFRM_MODE_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_BEET=m
    # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
    CONFIG_IPV6_SIT=m
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    # CONFIG_IPV6_TUNNEL is not set
    # CONFIG_IPV6_MULTIPLE_TABLES is not set
    # CONFIG_IPV6_MROUTE is not set
    # CONFIG_NETWORK_SECMARK is not set
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    # Core Netfilter Configuration
    # CONFIG_NETFILTER_NETLINK_ACCT is not set
    # CONFIG_NETFILTER_NETLINK_QUEUE is not set
    # CONFIG_NETFILTER_NETLINK_LOG is not set
    # CONFIG_NF_CONNTRACK is not set
    # CONFIG_NETFILTER_XTABLES is not set
    # CONFIG_IP_VS is not set
    # IP: Netfilter Configuration
    # CONFIG_NF_DEFRAG_IPV4 is not set
    # CONFIG_IP_NF_QUEUE is not set
    # CONFIG_IP_NF_IPTABLES is not set
    # CONFIG_IP_NF_ARPTABLES is not set
    # IPv6: Netfilter Configuration
    # CONFIG_NF_DEFRAG_IPV6 is not set
    # CONFIG_IP6_NF_QUEUE is not set
    # CONFIG_IP6_NF_IPTABLES is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    # CONFIG_BRIDGE is not set
    # CONFIG_NET_DSA is not set
    # CONFIG_VLAN_8021Q is not set
    # CONFIG_DECNET is not set
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_ECONET is not set
    # CONFIG_WAN_ROUTER is not set
    # CONFIG_PHONET is not set
    # CONFIG_IEEE802154 is not set
    # CONFIG_NET_SCHED is not set
    # CONFIG_DCB is not set
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    CONFIG_BQL=y
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_HAMRADIO is not set
    # CONFIG_CAN is not set
    # CONFIG_IRDA is not set
    # CONFIG_BT is not set
    # CONFIG_AF_RXRPC is not set
    CONFIG_WIRELESS=y
    # CONFIG_CFG80211 is not set
    # CONFIG_LIB80211 is not set
    # CFG80211 needs to be enabled for MAC80211
    # CONFIG_WIMAX is not set
    # CONFIG_RFKILL is not set
    # CONFIG_RFKILL_REGULATOR is not set
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # CONFIG_NFC is not set
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
    # CONFIG_DEVTMPFS is not set
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    # CONFIG_FW_LOADER is not set
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_GENERIC_CPU_DEVICES is not set
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=y
    # CONFIG_DMA_SHARED_BUFFER is not set
    # CONFIG_CONNECTOR is not set
    CONFIG_MTD=y
    # CONFIG_MTD_TESTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    # CONFIG_MTD_CMDLINE_PARTS is not set
    # CONFIG_MTD_AFS_PARTS is not set
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_CHAR=y
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    # CONFIG_MTD_OOPS is not set
    # CONFIG_MTD_SWAP is not set
    # RAM/ROM/Flash chip drivers
    # CONFIG_MTD_CFI is not set
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_DATAFLASH is not set
    CONFIG_MTD_M25P80=y
    CONFIG_M25PXX_USE_FAST_READ=y
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    # CONFIG_MTD_NAND is not set
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_RESERVE=1
    # CONFIG_MTD_UBI_GLUEBI is not set
    # CONFIG_MTD_UBI_DEBUG is not set
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=m
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # DRBD disabled because PROC_FS, INET or CONNECTOR not selected
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_UB is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=1
    CONFIG_BLK_DEV_RAM_SIZE=32768
    # CONFIG_BLK_DEV_XIP is not set
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    # CONFIG_MG_DISK is not set
    # CONFIG_BLK_DEV_RBD is not set
    # Misc devices
    # CONFIG_SENSORS_LIS3LV02D is not set
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_ATMEL_PWM is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_BH1780 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_TI_DAC7512 is not set
    # CONFIG_BMP085 is not set
    # CONFIG_USB_SWITCH_FSA9480 is not set
    # CONFIG_C2PORT is not set
    # EEPROM support
    CONFIG_EEPROM_AT24=y
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    # CONFIG_EEPROM_93CX6 is not set
    # CONFIG_EEPROM_93XX46 is not set
    # CONFIG_IWMC3200TOP is not set
    # Texas Instruments shared transport line discipline
    # CONFIG_TI_ST is not set
    # CONFIG_SENSORS_LIS3_SPI is not set
    # CONFIG_SENSORS_LIS3_I2C is not set
    # Altera FPGA firmware download module
    # CONFIG_ALTERA_STAPL is not set
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_TGT is not set
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    CONFIG_BLK_DEV_SR=y
    # CONFIG_BLK_DEV_SR_VENDOR is not set
    CONFIG_CHR_DEV_SG=y
    # CONFIG_CHR_DEV_SCH is not set
    # CONFIG_SCSI_MULTI_LUN is not set
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    CONFIG_SCSI_WAIT_SCAN=m
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_LIBFC is not set
    # CONFIG_LIBFCOE is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    CONFIG_ATA=y
    # CONFIG_ATA_NONSTANDARD is not set
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    CONFIG_SATA_AHCI_PLATFORM=y
    # CONFIG_ATA_SFF is not set
    # CONFIG_MD is not set
    # CONFIG_TARGET_CORE is not set
    CONFIG_NETDEVICES=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    # CONFIG_DUMMY is not set
    # CONFIG_EQUALIZER is not set
    CONFIG_MII=y
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    CONFIG_NETCONSOLE=y
    CONFIG_NETPOLL=y
    CONFIG_NETPOLL_TRAP=y
    CONFIG_NET_POLL_CONTROLLER=y
    # CONFIG_TUN is not set
    # CONFIG_VETH is not set
    # CAIF transport drivers
    CONFIG_ETHERNET=y
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_NET_CALXEDA_XGMAC is not set
    CONFIG_NET_VENDOR_CHELSIO=y
    # CONFIG_DM9000 is not set
    # CONFIG_DNET is not set
    CONFIG_NET_VENDOR_FARADAY=y
    # CONFIG_FTMAC100 is not set
    # CONFIG_FTGMAC100 is not set
    CONFIG_NET_VENDOR_INTEL=y
    CONFIG_NET_VENDOR_I825XX=y
    CONFIG_NET_VENDOR_MARVELL=y
    CONFIG_NET_VENDOR_MICREL=y
    # CONFIG_KS8851 is not set
    # CONFIG_KS8851_MLL is not set
    CONFIG_NET_VENDOR_MICROCHIP=y
    # CONFIG_ENC28J60 is not set
    CONFIG_NET_VENDOR_NATSEMI=y
    CONFIG_NET_VENDOR_8390=y
    # CONFIG_AX88796 is not set
    # CONFIG_ETHOC is not set
    CONFIG_NET_VENDOR_SEEQ=y
    # CONFIG_SEEQ8005 is not set
    CONFIG_NET_VENDOR_SMSC=y
    # CONFIG_SMC91X is not set
    # CONFIG_SMC911X is not set
    # CONFIG_SMSC911X is not set
    CONFIG_NET_VENDOR_STMICRO=y
    # CONFIG_STMMAC_ETH is not set
    CONFIG_NET_VENDOR_TI=y
    CONFIG_TI_DAVINCI_EMAC=y
    CONFIG_TI_DAVINCI_MDIO=y
    CONFIG_TI_DAVINCI_CPDMA=y
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    # CONFIG_MARVELL_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    CONFIG_LXT_PHY=y
    # CONFIG_CICADA_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    CONFIG_SMSC_PHY=y
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    CONFIG_LSI_ET1011C_PHY=y
    # CONFIG_MICREL_PHY is not set
    # CONFIG_FIXED_PHY is not set
    # CONFIG_MDIO_BITBANG is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    # USB Network Adapters
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    # CONFIG_USB_PEGASUS is not set
    # CONFIG_USB_RTL8150 is not set
    # CONFIG_USB_USBNET is not set
    # CONFIG_USB_IPHETH is not set
    CONFIG_WLAN=y
    # CONFIG_WL1271_WLAN is not set
    # CONFIG_USB_ZD1201 is not set
    # CONFIG_HOSTAP is not set
    CONFIG_WL12XX_PLATFORM_DATA=y
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # CONFIG_WAN is not set
    # CONFIG_ISDN is not set
    # CONFIG_PHONE is not set
    # Input device support
    CONFIG_INPUT=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    CONFIG_INPUT_POLLDEV=y
    # CONFIG_INPUT_SPARSEKMAP is not set
    # Userland interfaces
    # CONFIG_INPUT_MOUSEDEV is not set
    # CONFIG_INPUT_JOYDEV is not set
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=m
    # CONFIG_KEYBOARD_QT1070 is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    # CONFIG_KEYBOARD_MATRIX is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_SAMSUNG is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    CONFIG_KEYBOARD_XTKBD=m
    # CONFIG_INPUT_MOUSE is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    # CONFIG_TOUCHSCREEN_ADS7846 is not set
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    # CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    # CONFIG_TOUCHSCREEN_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    # CONFIG_TOUCHSCREEN_TSC2005 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    # CONFIG_TOUCHSCREEN_TSC2004 is not set
    # CONFIG_TOUCHSCREEN_W90X900 is not set
    # CONFIG_TOUCHSCREEN_ST1232 is not set
    CONFIG_TOUCHSCREEN_TPS6507X=y
    # CONFIG_INPUT_MISC is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    # CONFIG_VT_CONSOLE is not set
    CONFIG_HW_CONSOLE=y
    # CONFIG_VT_HW_CONSOLE_BINDING is not set
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    CONFIG_LEGACY_PTYS=y
    CONFIG_LEGACY_PTY_COUNT=8
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_N_GSM is not set
    # CONFIG_TRACE_SINK is not set
    CONFIG_DEVKMEM=y
    # Serial drivers
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_NR_UARTS=3
    CONFIG_SERIAL_8250_RUNTIME_UARTS=3
    # CONFIG_SERIAL_8250_EXTENDED is not set
    # Non-8250 serial port support
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX3107 is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_TIMBERDALE is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_IFX6X60 is not set
    # CONFIG_SERIAL_XILINX_PS_UART is not set
    # CONFIG_TTY_PRINTK is not set
    # CONFIG_HVC_DCC is not set
    # CONFIG_IPMI_HANDLER is not set
    CONFIG_HW_RANDOM=m
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    # CONFIG_R3964 is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    # CONFIG_RAMOOPS is not set
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    # CONFIG_I2C_MUX is not set
    CONFIG_I2C_HELPER_AUTO=y
    CONFIG_I2C_ALGOBIT=y
    # I2C Hardware Bus support
    # I2C system bus drivers (mostly embedded / system-on-chip)
    CONFIG_I2C_DAVINCI=y
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    CONFIG_I2C_GPIO=y
    # CONFIG_I2C_OCORES is not set
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_PXA_PCI is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_STUB is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    CONFIG_SPI_BITBANG=y
    CONFIG_SPI_DAVINCI=y
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_OC_TINY is not set
    # CONFIG_SPI_PXA2XX_PCI is not set
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_DESIGNWARE is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_TLE62X0 is not set
    # PPS support
    # CONFIG_PPS is not set
    # PPS generators support
    # PTP clock support
    # Enable Device Drivers -> PPS to see the PTP clock options.
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIOLIB=y
    # CONFIG_DEBUG_GPIO is not set
    # CONFIG_GPIO_SYSFS is not set
    # Memory mapped GPIO drivers:
    # CONFIG_GPIO_GENERIC_PLATFORM is not set
    # I2C GPIO expanders:
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCA953X_IRQ is not set
    CONFIG_GPIO_PCF857X=y
    # CONFIG_GPIO_SX150X is not set
    # CONFIG_GPIO_ADP5588 is not set
    # PCI GPIO expanders:
    # SPI GPIO expanders:
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_74X164 is not set
    # AC97 GPIO expanders:
    # MODULbus GPIO expanders:
    # CONFIG_GENERIC_PWM is not set
    # CONFIG_W1 is not set
    # CONFIG_POWER_SUPPLY is not set
    # CONFIG_HWMON is not set
    # CONFIG_THERMAL is not set
    CONFIG_WATCHDOG=y
    # CONFIG_WATCHDOG_CORE is not set
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_DAVINCI_WATCHDOG=y
    # CONFIG_MAX63XX_WATCHDOG is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    # Broadcom specific AMBA
    # CONFIG_BCMA is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    CONFIG_TPS6507X=y
    # CONFIG_MFD_TPS6586X is not set
    # CONFIG_MFD_TPS65910 is not set
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_TWL4030_CORE is not set
    # CONFIG_MFD_STMPE is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_MFD_S5M_CORE is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_MC13XXX is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    CONFIG_REGULATOR_DUMMY=y
    # CONFIG_REGULATOR_FIXED_VOLTAGE is not set
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_GPIO is not set
    # CONFIG_REGULATOR_BQ24022 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_TPS65023 is not set
    CONFIG_REGULATOR_TPS6507X=y
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_AD5398 is not set
    # CONFIG_REGULATOR_TPS6524X is not set
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    # CONFIG_MEDIA_CONTROLLER is not set
    CONFIG_VIDEO_DEV=y
    CONFIG_VIDEO_V4L2_COMMON=y
    # CONFIG_DVB_CORE is not set
    CONFIG_VIDEO_MEDIA=y
    # Multimedia drivers
    CONFIG_RC_CORE=y
    CONFIG_LIRC=y
    CONFIG_RC_MAP=y
    CONFIG_IR_NEC_DECODER=y
    CONFIG_IR_RC5_DECODER=y
    CONFIG_IR_RC6_DECODER=y
    CONFIG_IR_JVC_DECODER=y
    CONFIG_IR_SONY_DECODER=y
    CONFIG_IR_RC5_SZ_DECODER=y
    CONFIG_IR_SANYO_DECODER=y
    CONFIG_IR_MCE_KBD_DECODER=y
    CONFIG_IR_LIRC_CODEC=y
    # CONFIG_RC_ATI_REMOTE is not set
    # CONFIG_IR_IMON is not set
    # CONFIG_IR_MCEUSB is not set
    # CONFIG_IR_REDRAT3 is not set
    # CONFIG_IR_STREAMZAP is not set
    # CONFIG_RC_LOOPBACK is not set
    # CONFIG_MEDIA_ATTACH is not set
    CONFIG_MEDIA_TUNER=y
    # CONFIG_MEDIA_TUNER_CUSTOMISE is not set
    CONFIG_MEDIA_TUNER_SIMPLE=y
    CONFIG_MEDIA_TUNER_TDA8290=y
    CONFIG_MEDIA_TUNER_TDA827X=y
    CONFIG_MEDIA_TUNER_TDA18271=y
    CONFIG_MEDIA_TUNER_TDA9887=y
    CONFIG_MEDIA_TUNER_TEA5761=y
    CONFIG_MEDIA_TUNER_TEA5767=y
    CONFIG_MEDIA_TUNER_MT20XX=y
    CONFIG_MEDIA_TUNER_XC2028=y
    CONFIG_MEDIA_TUNER_XC5000=y
    CONFIG_MEDIA_TUNER_XC4000=y
    CONFIG_MEDIA_TUNER_MC44S803=y
    CONFIG_VIDEO_V4L2=y
    CONFIG_VIDEOBUF_GEN=y
    CONFIG_VIDEOBUF_DMA_CONTIG=y
    CONFIG_VIDEOBUF2_CORE=y
    CONFIG_VIDEOBUF2_MEMOPS=y
    CONFIG_VIDEOBUF2_VMALLOC=y
    CONFIG_VIDEO_CAPTURE_DRIVERS=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    # CONFIG_VIDEO_HELPER_CHIPS_AUTO is not set
    CONFIG_VIDEO_IR_I2C=y
    # Encoders, decoders, sensors and other helper chips
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_WM8775 is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # Video decoders
    # CONFIG_VIDEO_ADV7180 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_SAA7191 is not set
    CONFIG_VIDEO_TVP514X=y
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # MPEG video encoders
    # CONFIG_VIDEO_CX2341X is not set
    # Video encoders
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    CONFIG_VIDEO_ADV7343=y
    # CONFIG_VIDEO_AK881X is not set
    # Camera sensor devices
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_TCM825X is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # Flash devices
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # Miscelaneous helper chips
    CONFIG_VIDEO_THS7303=y
    # CONFIG_VIDEO_M52790 is not set
    CONFIG_V4L_USB_DRIVERS=y
    CONFIG_USB_VIDEO_CLASS=y
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    # CONFIG_USB_GSPCA is not set
    # CONFIG_VIDEO_PVRUSB2 is not set
    # CONFIG_VIDEO_HDPVR is not set
    # CONFIG_VIDEO_EM28XX is not set
    # CONFIG_VIDEO_CX231XX is not set
    # CONFIG_VIDEO_TM6000 is not set
    # CONFIG_VIDEO_USBVISION is not set
    # CONFIG_USB_ET61X251 is not set
    # CONFIG_USB_SN9C102 is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_USB_ZR364XX is not set
    # CONFIG_USB_STKWEBCAM is not set
    # CONFIG_USB_S2255 is not set
    CONFIG_V4L_PLATFORM_DRIVERS=y
    CONFIG_VIDEO_DAVINCI_VPIF_DISPLAY=y
    CONFIG_VIDEO_DAVINCI_VPIF_CAPTURE=y
    CONFIG_VIDEO_DAVINCI_VPIF=y
    # CONFIG_VIDEO_VPSS_SYSTEM is not set
    # CONFIG_VIDEO_VPFE_CAPTURE is not set
    # CONFIG_SOC_CAMERA is not set
    # CONFIG_V4L_MEM2MEM_DRIVERS is not set
    # CONFIG_RADIO_ADAPTERS is not set
    # Graphics support
    # CONFIG_DRM is not set
    # CONFIG_VGASTATE is not set
    # CONFIG_VIDEO_OUTPUT_CONTROL is not set
    # CONFIG_FB is not set
    # CONFIG_BACKLIGHT_LCD_SUPPORT is not set
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_SOUND=y
    # CONFIG_SOUND_OSS_CORE is not set
    CONFIG_SND=y
    CONFIG_SND_TIMER=y
    CONFIG_SND_PCM=y
    CONFIG_SND_HWDEP=y
    CONFIG_SND_RAWMIDI=y
    CONFIG_SND_JACK=y
    # CONFIG_SND_SEQUENCER is not set
    # CONFIG_SND_MIXER_OSS is not set
    # CONFIG_SND_PCM_OSS is not set
    # CONFIG_SND_HRTIMER is not set
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    # CONFIG_SND_DEBUG is not set
    # CONFIG_SND_RAWMIDI_SEQ is not set
    # CONFIG_SND_OPL3_LIB_SEQ is not set
    # CONFIG_SND_OPL4_LIB_SEQ is not set
    # CONFIG_SND_SBAWE_SEQ is not set
    # CONFIG_SND_EMU10K1_SEQ is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    CONFIG_SND_ARM=y
    CONFIG_SND_SPI=y
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=y
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_6FIRE is not set
    CONFIG_SND_SOC=y
    CONFIG_SND_DAVINCI_SOC=y
    CONFIG_SND_DAVINCI_SOC_MCASP=y
    CONFIG_SND_DA850_SOC_EVM=y
    # CONFIG_SND_OMAPL138_LCDKBOARD is not set
    # CONFIG_SND_DA850_SOC_SDI is not set
    CONFIG_SND_SOC_I2C_AND_SPI=y
    # CONFIG_SND_SOC_ALL_CODECS is not set
    CONFIG_SND_SOC_TLV320AIC3X=y
    # CONFIG_SOUND_PRIME is not set
    CONFIG_HID_SUPPORT=y
    CONFIG_HID=y
    # CONFIG_HIDRAW is not set
    # USB Input Devices
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_MULTITOUCH is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB_ARCH_HAS_OHCI=y
    # CONFIG_USB_ARCH_HAS_EHCI is not set
    # CONFIG_USB_ARCH_HAS_XHCI is not set
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
    # Miscellaneous USB options
    # CONFIG_USB_DEVICEFS is not set
    CONFIG_USB_DEVICE_CLASS=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    # CONFIG_USB_DWC3 is not set
    # CONFIG_USB_MON is not set
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1760_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    CONFIG_USB_OHCI_HCD=y
    # CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
    # CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    CONFIG_USB_MUSB_HDRC=y
    # Platform Glue Layer
    CONFIG_USB_MUSB_DA8XX_GLUE=y
    # CONFIG_USB_MUSB_DAVINCI is not set
    CONFIG_USB_MUSB_DA8XX=y
    # CONFIG_USB_MUSB_TUSB6010 is not set
    # CONFIG_USB_MUSB_OMAP2PLUS is not set
    # CONFIG_USB_MUSB_AM35X is not set
    # CONFIG_USB_MUSB_TI81XX is not set
    # CONFIG_USB_MUSB_BLACKFIN is not set
    # CONFIG_USB_MUSB_UX500 is not set
    CONFIG_USB_TI_CPPI41_DMA_HW=y
    # CONFIG_MUSB_SCHEDULE_INTR_EP is not set
    # CONFIG_MUSB_PIO_ONLY is not set
    # CONFIG_USB_INVENTRA_DMA is not set
    # CONFIG_USB_TI_CPPI_DMA is not set
    CONFIG_USB_TI_CPPI41_DMA=y
    CONFIG_USB_TI_CPPI41_IN_TRANSPARENT=y
    # CONFIG_USB_TUSB_OMAP_DMA is not set
    # CONFIG_USB_UX500_DMA is not set
    # CONFIG_USB_RENESAS_USBHS is not set
    # USB Device Class drivers
    # CONFIG_USB_ACM is not set
    # CONFIG_USB_PRINTER is not set
    # CONFIG_USB_WDM is not set
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    # CONFIG_USB_UAS is not set
    # CONFIG_USB_LIBUSUAL is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_LED is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    # CONFIG_USB_TEST is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    # CONFIG_USB_GADGET_DEBUG_FS is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_MV_UDC is not set
    CONFIG_USB_GADGET_MUSB_HDRC=y
    # CONFIG_USB_M66592 is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_DUMMY_HCD is not set
    CONFIG_USB_GADGET_DUALSPEED=y
    # CONFIG_USB_ZERO is not set
    # CONFIG_USB_AUDIO is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    # CONFIG_USB_G_NCM is not set
    # CONFIG_USB_GADGETFS is not set
    # CONFIG_USB_FUNCTIONFS is not set
    CONFIG_USB_FILE_STORAGE=m
    # CONFIG_USB_FILE_STORAGE_TEST is not set
    CONFIG_USB_MASS_STORAGE=m
    # CONFIG_USB_G_SERIAL is not set
    # CONFIG_USB_MIDI_GADGET is not set
    # CONFIG_USB_G_PRINTER is not set
    # CONFIG_USB_CDC_COMPOSITE is not set
    # CONFIG_USB_G_ACM_MS is not set
    # CONFIG_USB_G_MULTI is not set
    # CONFIG_USB_G_HID is not set
    # CONFIG_USB_G_DBGP is not set
    # CONFIG_USB_G_WEBCAM is not set
    # OTG and related infrastructure
    CONFIG_USB_OTG_UTILS=y
    # CONFIG_USB_GPIO_VBUS is not set
    # CONFIG_USB_ULPI is not set
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    CONFIG_MMC_UNSAFE_RESUME=y
    # CONFIG_MMC_CLKGATE is not set
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=8
    CONFIG_MMC_BLOCK_BOUNCE=y
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_MMC_SDHCI_PXAV3 is not set
    # CONFIG_MMC_SDHCI_PXAV2 is not set
    CONFIG_MMC_DAVINCI=y
    # CONFIG_MMC_SPI is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MEMSTICK is not set
    # CONFIG_NEW_LEDS is not set
    # CONFIG_ACCESSIBILITY is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_DS1307 is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # on-CPU RTC drivers
    CONFIG_RTC_DRV_OMAP=y
    # CONFIG_DMADEVICES is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_UIO is not set
    # Virtio drivers
    # CONFIG_VIRTIO_BALLOON is not set
    # CONFIG_VIRTIO_MMIO is not set
    # Microsoft Hyper-V guest support
    # CONFIG_STAGING is not set
    CONFIG_CLKDEV_LOOKUP=y
    # Hardware Spinlock drivers
    CONFIG_IOMMU_SUPPORT=y
    # CONFIG_VIRT_DRIVERS is not set
    # CONFIG_PM_DEVFREQ is not set
    # File systems
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    # CONFIG_EXT2_FS_XIP is not set
    CONFIG_EXT3_FS=y
    # CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
    CONFIG_EXT3_FS_XATTR=y
    # CONFIG_EXT3_FS_POSIX_ACL is not set
    # CONFIG_EXT3_FS_SECURITY is not set
    # CONFIG_EXT4_FS is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    # CONFIG_FS_POSIX_ACL is not set
    CONFIG_EXPORTFS=m
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY is not set
    # CONFIG_QUOTA is not set
    # CONFIG_QUOTACTL is not set
    CONFIG_AUTOFS4_FS=m
    # CONFIG_FUSE_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    CONFIG_ISO9660_FS=y
    # CONFIG_JOLIET is not set
    # CONFIG_ZISOFS is not set
    # CONFIG_UDF_FS is not set
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_NTFS_FS is not set
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    # CONFIG_TMPFS_POSIX_ACL is not set
    # CONFIG_TMPFS_XATTR is not set
    # CONFIG_HUGETLB_PAGE is not set
    # CONFIG_CONFIGFS_FS is not set
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    # CONFIG_JFFS2_SUMMARY is not set
    # CONFIG_JFFS2_FS_XATTR is not set
    # CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
    CONFIG_JFFS2_ZLIB=y
    # CONFIG_JFFS2_LZO is not set
    CONFIG_JFFS2_RTIME=y
    # CONFIG_JFFS2_RUBIN is not set
    CONFIG_UBIFS_FS=y
    # CONFIG_UBIFS_FS_XATTR is not set
    # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    # CONFIG_UBIFS_FS_DEBUG is not set
    # CONFIG_LOGFS is not set
    CONFIG_CRAMFS=y
    # CONFIG_SQUASHFS is not set
    # CONFIG_VXFS_FS is not set
    CONFIG_MINIX_FS=m
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    # CONFIG_PSTORE is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V3=y
    # CONFIG_NFS_V3_ACL is not set
    # CONFIG_NFS_V4 is not set
    CONFIG_ROOT_NFS=y
    CONFIG_NFSD=m
    CONFIG_NFSD_V3=y
    # CONFIG_NFSD_V3_ACL is not set
    # CONFIG_NFSD_V4 is not set
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_NCP_FS is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    CONFIG_NLS_ASCII=m
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    CONFIG_NLS_UTF8=m
    # Kernel hacking
    # CONFIG_PRINTK_TIME is not set
    CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4
    # CONFIG_ENABLE_WARN_DEPRECATED is not set
    # CONFIG_ENABLE_MUST_CHECK is not set
    CONFIG_FRAME_WARN=1024
    # CONFIG_MAGIC_SYSRQ is not set
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_DEBUG_KERNEL=y
    # CONFIG_DEBUG_SHIRQ is not set
    # CONFIG_LOCKUP_DETECTOR is not set
    # CONFIG_HARDLOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    CONFIG_SCHED_DEBUG=y
    # CONFIG_SCHEDSTATS is not set
    # CONFIG_TIMER_STATS is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_SLUB_DEBUG_ON is not set
    # CONFIG_SLUB_STATS is not set
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_PREEMPT is not set
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_SPARSE_RCU_POINTER is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_KOBJECT is not set
    CONFIG_DEBUG_BUGVERBOSE=y
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    CONFIG_FRAME_POINTER=y
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # CONFIG_LKDTM is not set
    # CONFIG_FAULT_INJECTION is not set
    # CONFIG_LATENCYTOP is not set
    # CONFIG_SYSCTL_SYSCALL_CHECK is not set
    # CONFIG_DEBUG_PAGEALLOC is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_STRICT_DEVMEM is not set
    # CONFIG_ARM_UNWIND is not set
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_LL is not set
    # Security options
    # CONFIG_KEYS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    # CONFIG_SECURITY is not set
    # CONFIG_SECURITYFS is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    # CONFIG_CRYPTO_MANAGER is not set
    # CONFIG_CRYPTO_MANAGER2 is not set
    # CONFIG_CRYPTO_USER is not set
    # CONFIG_CRYPTO_GF128MUL is not set
    # CONFIG_CRYPTO_NULL is not set
    # CONFIG_CRYPTO_CRYPTD is not set
    # CONFIG_CRYPTO_AUTHENC is not set
    # CONFIG_CRYPTO_TEST is not set
    # Authenticated Encryption with Associated Data
    # CONFIG_CRYPTO_CCM is not set
    # CONFIG_CRYPTO_GCM is not set
    # CONFIG_CRYPTO_SEQIV is not set
    # Block modes
    # CONFIG_CRYPTO_CBC is not set
    # CONFIG_CRYPTO_CTR is not set
    # CONFIG_CRYPTO_CTS is not set
    # CONFIG_CRYPTO_ECB is not set
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_PCBC is not set
    # CONFIG_CRYPTO_XTS is not set
    # Hash modes
    # CONFIG_CRYPTO_HMAC is not set
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    # CONFIG_CRYPTO_CRC32C is not set
    # CONFIG_CRYPTO_GHASH is not set
    # CONFIG_CRYPTO_MD4 is not set
    # CONFIG_CRYPTO_MD5 is not set
    # CONFIG_CRYPTO_MICHAEL_MIC is not set
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    # CONFIG_CRYPTO_SHA1 is not set
    # CONFIG_CRYPTO_SHA256 is not set
    # CONFIG_CRYPTO_SHA512 is not set
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    # CONFIG_CRYPTO_AES is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    # CONFIG_CRYPTO_ARC4 is not set
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    # CONFIG_CRYPTO_DES is not set
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    # CONFIG_CRYPTO_ZLIB is not set
    CONFIG_CRYPTO_LZO=y
    # Random Number Generation
    # CONFIG_CRYPTO_ANSI_CPRNG is not set
    # CONFIG_CRYPTO_USER_API_HASH is not set
    # CONFIG_CRYPTO_USER_API_SKCIPHER is not set
    # CONFIG_CRYPTO_HW is not set
    # CONFIG_BINARY_PRINTF is not set
    # Library routines
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_CRC_CCITT=m
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=m
    # CONFIG_CRC_ITU_T is not set
    CONFIG_CRC32=y
    # CONFIG_CRC7 is not set
    # CONFIG_LIBCRC32C is not set
    # CONFIG_CRC8 is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    # CONFIG_XZ_DEC is not set
    # CONFIG_XZ_DEC_BCJ is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
    CONFIG_DQL=y
    CONFIG_NLATTR=y
    CONFIG_GENERIC_ATOMIC64=y
    # CONFIG_AVERAGE is not set
    # CONFIG_CORDIC is not set
    Your config file looks good.
    dmesg output means, when you boot into your linux system , type the command dmesg
    and attach the output of that command here.
    Cheers,
    --Prabhakar Lad
  • Thanks, I'm understand. This is my dmesg output.
    root@omapl138-lcdk:~# dmesg
    Booting Linux on physical CPU 0
    Linux version 3.3.0 (root@ubuntu) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #5 PREEMPT Mon Sep 5 18:08:18 MSK 2016
    CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    CPU: VIVT data cache, VIVT instruction cache
    Machine: AM18x/OMAP-L138 lcdk board
    Memory policy: ECC disabled, Data cache writeback
    BUG: mapping for 0x80000000 at 0xfffe0000 out of vmalloc space
    DaVinci da850/omap-l138/am18x variant 0x1
    On node 0 totalpages: 8192
    free_area_init_node: node 0, pgdat c0519c5c, node_mem_map c0537000
      DMA zone: 64 pages used for memmap
      DMA zone: 0 pages reserved
      DMA zone: 8128 pages, LIFO batch:0
    pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    pcpu-alloc: [0] 0
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
    Kernel command line: mem=32M console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootwait ip=off vpif_capture.ch0_bufsize=831488 vpif_display.ch2_bufsize=831488
    PID hash table entries: 128 (order: -3, 512 bytes)
    Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
    Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Memory: 32MB = 32MB total
    Memory: 27100k/27100k available, 5668k reserved, 0K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        vmalloc : 0xc2800000 - 0xff000000   ( 968 MB)
        lowmem  : 0xc0000000 - 0xc2000000   (  32 MB)
        modules : 0xbf000000 - 0xc0000000   (  16 MB)
          .text : 0xc0008000 - 0xc04b4000   (4784 kB)
          .init : 0xc04b4000 - 0xc04de000   ( 168 kB)
          .data : 0xc04de000 - 0xc051a680   ( 242 kB)
           .bss : 0xc051a6a4 - 0xc053648c   ( 112 kB)
    SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    NR_IRQS:245
    Console: colour dummy device 80x30
    Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    Setting up static identity map for 0xc038d178 - 0xc038d1d0
    gpiochip_add: registered GPIOs 0 to 31 on device: DaVinci
    gpiochip_add: registered GPIOs 32 to 63 on device: DaVinci
    gpiochip_add: registered GPIOs 64 to 95 on device: DaVinci
    gpiochip_add: registered GPIOs 96 to 127 on device: DaVinci
    gpiochip_add: registered GPIOs 128 to 143 on device: DaVinci
    DaVinci: 144 gpio irqs
    print_constraints: dummy:
    NET: Registered protocol family 16
    EMAC: MII PHY configured
    bio: create slab <bio-0> at 0
    SCSI subsystem initialized
    libata version 3.00 loaded.
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    i2c-gpio i2c-gpio.1: using pins 20 (SDA) and 21 (SCL)
    --------------------vpif init-------------------------
    Advanced Linux Sound Architecture Driver Version 1.0.24.
    Switching to clocksource timer0_1
    musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    musb-hdrc musb-hdrc: dma type: dma-cppi41
    MUSB255 controller's USBSS revision = 4ea11003
    Waiting for USB PHY clock good...
    musb-hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
    musb-hdrc: MHDRC RTL version 1.800
    musb-hdrc: setup fifo_mode 2
    musb-hdrc: 7/9 max ep, 2624/4096 memory
    musb-hdrc musb-hdrc: USB OTG mode controller at fee00000 using DMA, IRQ 58
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 1024 (order: 1, 8192 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    TCP reno registered
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    msgmni has been set to 52
    io scheduler noop registered (default)
    Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
    serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a AR7
    serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a AR7
    serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a AR7
    console [ttyS2] enabled
    brd: module loaded
    ahci ahci: forcing PORTS_IMPL to 0x1
    ahci ahci: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc
    scsi0 : ahci_platform
    ata1: SATA max UDMA/133 mmio [mem 0x01e18000-0x01e19fff] port 0x100 irq 67
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
    davinci_mdio davinci_mdio.0: detected phy mask ffffff7f
    davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[7]: device davinci_mdio-0:07, driver SMSC LAN8710/LAN8720
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    ohci ohci.0: DA8xx OHCI
    ohci ohci.0: new USB bus registered, assigned bus number 1
    ohci ohci.0: irq 59, io mem 0x01e25000
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    input: gpio-keys-polled as /devices/platform/gpio-keys-polled.0/input/input0
    omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    omap_rtc: RTC power up reset detected
    i2c /dev entries driver
    lirc_dev: IR Remote Control driver registered, major 253
    IR NEC protocol handler initialized
    IR RC5(x) protocol handler initialized
    IR RC6 protocol handler initialized
    IR JVC protocol handler initialized
    IR Sony protocol handler initialized
    IR RC5 (streamzap) protocol handler initialized
    IR SANYO protocol handler initialized
    IR MCE Keyboard/mouse protocol handler initialized
    IR LIRC bridge handler initialized
    Linux video capture interface: v2.00
    --------------------------init_tvp514x----------------------------------
    -------------------------vpif capture init------------------------------
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (1.1.1)
    watchdog watchdog: heartbeat 60 sec
    cpuidle: using governor ladder
    cpuidle: using governor menu
    davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    usbcore: registered new interface driver snd-usb-audio
    soc-audio soc-audio.0: ASoC: Failed to create card debugfs directory
    _regulator_get: 1-0018 supply IOVDD not found, using dummy regulator
    ata1: SATA link down (SStatus 0 SControl 300)
    _regulator_get: 1-0018 supply DVDD not found, using dummy regulator
    _regulator_get: 1-0018 supply AVDD not found, using dummy regulator
    _regulator_get: 1-0018 supply DRVDD not found, using dummy regulator
    asoc: tlv320aic3x-hifi <-> davinci-mcasp.0 mapping ok
    ALSA device list:
      #0: DA850/OMAP-L138 EVM
    TCP cubic registered
    NET: Registered protocol family 17
    console [netcon0] enabled
    netconsole: network logging started
    davinci_emac davinci_emac.1: using random MAC addr: 0a:56:51:b5:94:c2
    omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    Waiting for root device /dev/mmcblk0p2...
    mmc0: new high speed SDHC card at address 1234
    mmcblk0: mmc0:1234 SA04G 3.63 GiB
     mmcblk0: p1 p2 p3 < p5 >
    EXT3-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs (mmcblk0p2): using internal journal
    EXT3-fs (mmcblk0p2): recovery complete
    EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    VFS: Mounted root (ext3 filesystem) on device 179:2.
    Freeing init memory: 168K
    udevd (615): /proc/615/oom_adj is deprecated, please use /proc/615/oom_score_adj instead.
    udev: starting version 141
    FAT-fs (mmcblk0p3): invalid media value (0x1f)
    FAT-fs (mmcblk0p3): Can't find a valid FAT filesystem
    messages ---vpif init---, ----init_tvp514--- and ---vpif capture init--- is my prints, which I've set for checking init functions of vpif, vpif capture and tvp514 drivers.
