Programing usb camera using (dm37x) embest devkit8500d
Hello there,
I have USB camera and will hook it up to my devkit but, now my first task is to  display the images captured by the camera on lcd(display device) how do I begin with this?
I have all necessary components installed that is:dvsdk software,ccs-v6.
I have tried simple things like flashing the NAND from SD card writing hello world program and dumping using gcc tool-chain and even led testing  examples given. I know C-programing and now I want to complete the above mentioned task first and then I will go for image processing.
I have linux host machine.
How do I start with this?
  • Hi Disha,
    I suggest you to check the kernel configuration weather the following options are enabled to support USB ISO devices:
    host# make your_board_defconfig
    host# make menuconfig
    Device Driver -> USB -> <*> Support for USB Host side
    <*> USB device file system
    <*> Inventra USB controller
    Driver Mode -> Host
    <*> Reserve ISO endpoint
    host# make uImage
    Then you can connect the USB camera and use the following gstreamer pipe for camera capture:
    host# gst-launch-0.10 v4l2src device=/dev/video0 ! video/x-raw-yuv,width=640,height=480 ! ffmpegcolorspace ! autovideosink
    BR
    Tsvetolin Shulev
  • Thanks for reply,
    But,I have got some doubts:
    The manual provided by embest here see page number 424477.DevKit8500 User Manual.pdf
    They have given details on video capture and also kernel-driver refrence path there two .c files I didn't get what should I do with those like is it that I need to cross compile both of them and dump in hardware which will help is detecting the device connected to the kit and start capturing the video?
    The two c-files are:
     * omap34xxcam.c
     * Copyright (C) 2006--2009 Nokia Corporation
     * Copyright (C) 2007--2009 Texas Instruments
     * Contact: Sakari Ailus <sakari.ailus@nokia.com>
     *          Tuukka Toivonen <tuukka.o.toivonen@nokia.com>
     * Originally based on the OMAP 2 camera driver.
     * Written by Sakari Ailus <sakari.ailus@nokia.com>
     *            Sergio Aguirre <saaguirre@ti.com>
     *            Mohit Jalori
     *            Sameer Venkatraman
     *            Leonides Martinez
     * This program is free software; you can redistribute it and/or
     * modify it under the terms of the GNU General Public License
     * version 2 as published by the Free Software Foundation.
     * This program is distributed in the hope that it will be useful, but
     * WITHOUT ANY WARRANTY; without even the implied warranty of
     * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
     * General Public License for more details.
     * You should have received a copy of the GNU General Public License
     * along with this program; if not, write to the Free Software
     * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
     * 02110-1301 USA
    #include <linux/videodev2.h>
    #include <linux/version.h>
    #include <linux/sched.h>
    #include <linux/vmalloc.h>
    #include <linux/mm.h>
    #include <linux/dma-mapping.h>
    #include <media/v4l2-common.h>
    #include <media/v4l2-ioctl.h>
    #include <media/v4l2-int-device.h>
    #include <media/tvp514x-int.h>
    #include "omap34xxcam.h"
    #include "isp/isp.h"
    #define OMAP34XXCAM_VERSION KERNEL_VERSION(0, 0, 0)
    /* global variables */
    static struct omap34xxcam_device *omap34xxcam;
     * Sensor handling.
     * omap34xxcam_slave_power_set - set slave power state
     * @vdev: per-video device data structure
     * @power: new power state
    static int omap34xxcam_slave_power_set(struct omap34xxcam_videodev *vdev,
    				       enum v4l2_power power,
    				       int mask)
    	int rval = 0, i = 0;
    	BUG_ON(!mutex_is_locked(&vdev->mutex));
    #ifdef OMAP34XXCAM_POWEROFF_DELAY
    	vdev->power_state_wish = -1;
    #endif
    	for (i = 0; i <= OMAP34XXCAM_SLAVE_FLASH; i++) {
    		if (vdev->slave[i] == v4l2_int_device_dummy())
    			continue;
    		if (!(mask & (1 << i))
    		    || power == vdev->power_state[i])
    			continue;
    		rval = vidioc_int_s_power(vdev->slave[i], power);
    		if (rval && power != V4L2_POWER_OFF) {
    			power = V4L2_POWER_OFF;
    			goto out;
    		vdev->power_state[i] = power;
    	return 0;
    out:
    	for (i--; i >= 0; i--) {
    			continue;
    		if (!(mask & (1 << i)))
    			continue;
    	return rval;
    static void omap34xxcam_slave_power_work(struct work_struct *work)
    	struct omap34xxcam_videodev *vdev =
    		container_of(work, struct omap34xxcam_videodev, poweroff_work);
    	mutex_lock(&vdev->mutex);
    	if (vdev->power_state_wish != -1)
    		omap34xxcam_slave_power_set(vdev, vdev->power_state_wish,
    					    vdev->power_state_mask);
    	mutex_unlock(&vdev->mutex);
    static void omap34xxcam_slave_power_timer(unsigned long ptr)
    	struct omap34xxcam_videodev *vdev = (void *)ptr;
    	schedule_work(&vdev->poweroff_work);
     * omap34xxcam_slave_power_suggest - delayed power state change
    static void omap34xxcam_slave_power_suggest(struct omap34xxcam_videodev *vdev,
    					    int mask)
    	del_timer(&vdev->poweroff_timer);
    	vdev->power_state_wish = power;
    	vdev->power_state_mask = mask;
    	mod_timer(&vdev->poweroff_timer, jiffies + OMAP34XXCAM_POWEROFF_DELAY);
    #else /* OMAP34XXCAM_POWEROFF_DELAY */
    #define omap34xxcam_slave_power_suggest(a, b, c) do {} while (0)
    #endif /* OMAP34XXCAM_POWEROFF_DELAY */
     * omap34xxcam_update_vbq - Updates VBQ with completed input buffer
     * @vb: ptr. to standard V4L2 video buffer structure
     * Updates video buffer queue with completed buffer passed as
     * input parameter.  Also updates ISP H3A timestamp and field count
     * statistics.
    void omap34xxcam_vbq_complete(struct videobuf_buffer *vb, void *priv)
    	struct omap34xxcam_fh *fh = priv;
    	do_gettimeofday(&vb->ts);
    	vb->field_count = atomic_add_return(2, &fh->field_count);
    	wake_up(&vb->done);
     * omap34xxcam_vbq_setup - Calcs size and num of buffs allowed in queue
     * @vbq: ptr. to standard V4L2 video buffer queue structure
     * @cnt: ptr to location to hold the count of buffers to be in the queue
     * @size: ptr to location to hold the size of a frame
     * Calculates the number of buffers of current image size that can be
     * supported by the available capture memory.
    static int omap34xxcam_vbq_setup(struct videobuf_queue *vbq, unsigned int *cnt,
    				 unsigned int *size)
    	struct omap34xxcam_fh *fh = vbq->priv_data;
    	struct omap34xxcam_videodev *vdev = fh->vdev;
    	if (*cnt <= 0)
    		*cnt = VIDEO_MAX_FRAME;	/* supply a default number of buffers */
    	if (*cnt > VIDEO_MAX_FRAME)
    	*size = vdev->pix.sizeimage;
    	while (*size * *cnt > fh->vdev->vdev_sensor_config.capture_mem)
    		(*cnt)--;
    	return isp_vbq_setup(vdev->cam->isp, vbq, cnt, size);
     * omap34xxcam_vbq_release - Free resources for input VBQ and VB
     * @vb: ptr to standard V4L2 video buffer structure
     * Unmap and free all memory associated with input VBQ and VB, also
     * unmap the address in ISP MMU.  Reset the VB state.
    static void omap34xxcam_vbq_release(struct videobuf_queue *vbq,
    				    struct videobuf_buffer *vb)
    	struct device *isp = vdev->cam->isp;
    	if (!vbq->streaming || vb->memory != V4L2_MEMORY_MMAP) {
    		isp_vbq_release(isp, vbq, vb);
    		videobuf_dma_unmap(vbq, videobuf_to_dma(vb));
    		videobuf_dma_free(videobuf_to_dma(vb));
    		vb->state = VIDEOBUF_NEEDS_INIT;
     * This function is work around for the videobuf_iolock API,
     * for User memory allocated with ioremap (VM_IO flag) the API
     * get_user_pages fails.
     * To fulfill this requirement, we have completely ignored VM layer of
     * Linux, and configuring the ISP MMU with physical address.
    static int omap_videobuf_dma_init_user(struct videobuf_buffer *vb,
    		unsigned long physp, unsigned long asize)
    	struct videobuf_dmabuf *dma;
    	struct scatterlist *sglist;
    	unsigned long data, first, last;
    	int i = 0;
    	dma = videobuf_to_dma(vb);
    	data = vb->baddr;
    	first = (data & PAGE_MASK) >> PAGE_SHIFT;
    	last  = ((data+asize-1) & PAGE_MASK) >> PAGE_SHIFT;
    	dma->offset   = data & ~PAGE_MASK;
    	dma->nr_pages = last-first+1;
    	dma->direction = DMA_FROM_DEVICE;
    	BUG_ON(0 == dma->nr_pages);
    	 * Allocate array of sglen + 1, to add entry of extra page
    	 * for input buffer. Driver always uses 0th buffer as input buffer.
    	sglist = vmalloc(dma->nr_pages * sizeof(*sglist));
    	if (NULL == sglist)
    		return -ENOMEM;
    	sg_init_table(sglist, dma->nr_pages);
    	sglist[0].offset = 0;
    	sglist[0].length = PAGE_SIZE - dma->offset;
    	sglist[0].dma_address = (dma_addr_t)physp;
    	physp += sglist[0].length;
    	 * Iterate in a loop for the number of pages
    	for (i = 1; i < dma->nr_pages; i++) {
    		sglist[i].offset = 0;
    		sglist[i].length = PAGE_SIZE;
    		sglist[i].dma_address = (dma_addr_t)physp;
    		physp += PAGE_SIZE;
    	dma->sglist = sglist;
    	dma->sglen = dma->nr_pages;
    	return 0;
     * omap34xxcam_vbq_prepare - V4L2 video ops buf_prepare handler
     * @field: standard V4L2 field enum
     * Verifies there is sufficient locked memory for the requested
     * buffer, or if there is not, allocates, locks and initializes
     * it.
    static int omap34xxcam_vbq_prepare(struct videobuf_queue *vbq,
    				   enum v4l2_field field)
    	int err = 0;
    	 * Accessing pix here is okay since it's constant while
    	 * streaming is on (and we only get called then).
    	if (vb->baddr) {
    		/* This is a userspace buffer. */
    		if (vdev->pix.sizeimage > vb->bsize ||
    				vb->baddr != (vb->baddr & ~0x1F))
    			/* The buffer isn't big enough. */
    			return -EINVAL;
    	} else {
    		if (vb->state != VIDEOBUF_NEEDS_INIT
    		    && vdev->pix.sizeimage > vb->bsize)
    			 * We have a kernel bounce buffer that has
    			 * already been allocated.
    			omap34xxcam_vbq_release(vbq, vb);
    	vb->size = vdev->pix.bytesperline * vdev->pix.height;
    	vb->width = vdev->pix.width;
    	vb->height = vdev->pix.height;
    	vb->field = field;
    	if (vb->state == VIDEOBUF_NEEDS_INIT) {
    		struct vm_area_struct *vma;
    		vma = find_vma(current->mm, vb->baddr);
    		if ((vma) && (vma->vm_flags & VM_IO) && (vma->vm_pgoff)) {
    			/* This will catch ioremaped buffers to the kernel.
    			 *  It gives two possible scenarios -
    			 *  - Driver allocates buffer using either
    			 *    dma_alloc_coherent or get_free_pages,
    			 *    and maps to user space using
    			 *    io_remap_pfn_range/remap_pfn_range
    			 *  - Drivers maps memory outside from Linux using
    			 *    io_remap
    			unsigned long physp = 0;
    			if ((vb->baddr + vb->bsize) > vma->vm_end) {
    				dev_err(&vdev->vfd->dev,
    						"User Buffer Allocation:" \
    						"err=%lu[%u]\n",\
    						(vma->vm_end - vb->baddr),
    						vb->bsize);
    				return -ENOMEM;
    			physp = (vma->vm_pgoff << PAGE_SHIFT) +
    				(vb->baddr - vma->vm_start);
    			err = omap_videobuf_dma_init_user(vb, physp, vb->bsize);
    		} else {
    			err = videobuf_iolock(vbq, vb, NULL);
    		if (!err) {
    			/* isp_addr will be stored locally inside isp code */
    			err = isp_vbq_prepare(isp, vbq, vb, field);
    	if (!err)
    		vb->state = VIDEOBUF_PREPARED;
    	else
    	return err;
     * omap34xxcam_vbq_queue - V4L2 video ops buf_queue handler
     * Maps the video buffer to sgdma and through the isp, sets
     * the isp buffer done callback and sets the video buffer state
     * to active.
    static void omap34xxcam_vbq_queue(struct videobuf_queue *vbq,
    	isp_buf_queue(isp, vb, omap34xxcam_vbq_complete, (void *)fh);
    static struct videobuf_queue_ops omap34xxcam_vbq_ops = {
    	.buf_setup = omap34xxcam_vbq_setup,
    	.buf_prepare = omap34xxcam_vbq_prepare,
    	.buf_queue = omap34xxcam_vbq_queue,
    	.buf_release = omap34xxcam_vbq_release,
     * IOCTL interface.
     * vidioc_querycap - V4L2 query capabilities IOCTL handler
     * @file: ptr. to system file structure
     * @fh: ptr to hold address of omap34xxcam_fh struct (per-filehandle data)
     * @cap: ptr to standard V4L2 capability structure
     * Fill in the V4L2 capabliity structure for the camera device
    static int vidioc_querycap(struct file *file, void *fh,
    			   struct v4l2_capability *cap)
    	struct omap34xxcam_fh *ofh = fh;
    	struct omap34xxcam_videodev *vdev = ofh->vdev;
    	strlcpy(cap->driver, CAM_SHORT_NAME, sizeof(cap->driver));
    	strlcpy(cap->card, vdev->vfd->name, sizeof(cap->card));
    	cap->version = OMAP34XXCAM_VERSION;
    	if (vdev->vdev_sensor != v4l2_int_device_dummy())
    		cap->capabilities = V4L2_CAP_VIDEO_CAPTURE | V4L2_CAP_STREAMING;
    	return 0;
     * vidioc_enum_fmt_vid_cap - V4L2 enumerate format capabilities IOCTL handler
     * @f: ptr to standard V4L2 format description structure
     * Fills in enumerate format capabilities information for sensor (if SOC
     * sensor attached) or ISP (if raw sensor attached).
    static int vidioc_enum_fmt_vid_cap(struct file *file, void *fh,
    				   struct v4l2_fmtdesc *f)
    	int rval;
    	if (vdev->vdev_sensor == v4l2_int_device_dummy())
    		return -EINVAL;
    	if (vdev->vdev_sensor_mode)
    		rval = isp_enum_fmt_cap(f);
    	else if (vdev->vdev_sensor_config.sensor_isp)
    		rval = vidioc_int_enum_fmt_cap(vdev->vdev_sensor, f);
    	else
    	return rval;
     * vidioc_g_fmt_vid_cap - V4L2 get format capabilities IOCTL handler
     * @f: ptr to standard V4L2 format structure
     * Fills in format capabilities for sensor (if SOC sensor attached) or ISP
     * (if raw sensor attached).
    static int vidioc_g_fmt_vid_cap(struct file *file, void *fh,
    				struct v4l2_format *f)
    		return -EINVAL;
    	f->fmt.pix = vdev->pix;
    	return 0;
    static int try_pix_parm(struct omap34xxcam_videodev *vdev,
    			struct v4l2_pix_format *best_pix_in,
    			struct v4l2_pix_format *wanted_pix_out,
    			struct v4l2_fract *best_ival)
    	int fps;
    	int fmtd_index;
    	int rval;
    	struct v4l2_pix_format best_pix_out;
    	if (best_ival->numerator == 0
    	    || best_ival->denominator == 0)
    		*best_ival = vdev->vdev_sensor_config.ival_default;
    	fps = best_ival->denominator / best_ival->numerator;
    	memset(best_pix_in, 0, sizeof(*best_pix_in));
    	best_ival->denominator = 0;
    	best_pix_out.height = INT_MAX >> 1;
    	best_pix_out.width = best_pix_out.height;
    	for (fmtd_index = 0; ; fmtd_index++) {
    		int size_index;
    		struct v4l2_fmtdesc fmtd;
    		fmtd.index = fmtd_index;
    		fmtd.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    		rval = vidioc_int_enum_fmt_cap(vdev->vdev_sensor, &fmtd);
    		if (rval)
    			break;
    		dev_dbg(&vdev->vfd->dev, "trying fmt %8.8x (%d)\n",
    			fmtd.pixelformat, fmtd_index);
    		 * Get supported resolutions.
    		for (size_index = 0; ; size_index++) {
    			struct v4l2_frmsizeenum frms;
    			struct v4l2_pix_format pix_tmp_in, pix_tmp_out;
    			int ival_index;
    			frms.index = size_index;
    			frms.pixel_format = fmtd.pixelformat;
    			rval = vidioc_int_enum_framesizes(vdev->vdev_sensor,
    							  &frms);
    			if (rval)
    				break;
    			pix_tmp_in.pixelformat = frms.pixel_format;
    			pix_tmp_in.width = frms.discrete.width;
    			pix_tmp_in.height = frms.discrete.height;
    			pix_tmp_out = *wanted_pix_out;
    			/* Don't do upscaling. */
    			if (pix_tmp_out.width > pix_tmp_in.width)
    				pix_tmp_out.width = pix_tmp_in.width;
    			if (pix_tmp_out.height > pix_tmp_in.height)
    				pix_tmp_out.height = pix_tmp_in.height;
    			rval = isp_try_fmt_cap(isp, &pix_tmp_in, &pix_tmp_out);
    			if (rval)
    				return rval;
    			dev_dbg(&vdev->vfd->dev, "this w %d\th %d\tfmt %8.8x\t"
    				"-> w %d\th %d\t fmt %8.8x"
    				"\twanted w %d\th %d\t fmt %8.8x\n",
    				pix_tmp_in.width, pix_tmp_in.height,
    				pix_tmp_in.pixelformat,
    				pix_tmp_out.width, pix_tmp_out.height,
    				pix_tmp_out.pixelformat,
    				wanted_pix_out->width, wanted_pix_out->height,
    				wanted_pix_out->pixelformat);
    #define IS_SMALLER_OR_EQUAL(pix1, pix2)				\
    			((pix1)->width + (pix1)->height		\
    			 < (pix2)->width + (pix2)->height)
    #define SIZE_DIFF(pix1, pix2)						\
    			(abs((pix1)->width - (pix2)->width)		\
    			 + abs((pix1)->height - (pix2)->height))
    			 * Don't use modes that are farther from wanted size
    			 * that what we already got.
    			if (SIZE_DIFF(&pix_tmp_out, wanted_pix_out)
    			    > SIZE_DIFF(&best_pix_out, wanted_pix_out)) {
    				dev_dbg(&vdev->vfd->dev, "size diff bigger: "
    					"w %d\th %d\tw %d\th %d\n",
    					best_pix_out.width,
    					best_pix_out.height);
    				continue;
    			 * There's an input mode that can provide output
    			 * closer to wanted.
    			    < SIZE_DIFF(&best_pix_out, wanted_pix_out)) {
    				/* Force renegotation of fps etc. */
    				dev_dbg(&vdev->vfd->dev, "renegotiate: "
    					best_pix_out.width,
    			for (ival_index = 0; ; ival_index++) {
    				struct v4l2_frmivalenum frmi;
    				frmi.index = ival_index;
    				frmi.pixel_format = frms.pixel_format;
    				frmi.width = frms.discrete.width;
    				frmi.height = frms.discrete.height;
    				/* FIXME: try to fix standard... */
    				frmi.reserved[0] = 0xdeafbeef;
    				rval = vidioc_int_enum_frameintervals(
    					vdev->vdev_sensor, &frmi);
    				if (rval)
    					break;
    				dev_dbg(&vdev->vfd->dev, "fps %d\n",
    					frmi.discrete.denominator
    					/ frmi.discrete.numerator);
    				if (best_ival->denominator == 0)
    					goto do_it_now;
    				if (best_pix_in->width == 0)
    					goto do_it_now;
    				 * We aim to use maximum resolution
    				 * from the sensor, provided that the
    				 * fps is at least as close as on the
    				 * current mode.
    #define FPS_ABS_DIFF(fps, ival) abs(fps - (ival).denominator / (ival).numerator)
    				/* Select mode with closest fps. */
    				if (FPS_ABS_DIFF(fps, frmi.discrete)
    				    < FPS_ABS_DIFF(fps, *best_ival)) {
    					dev_dbg(&vdev->vfd->dev, "closer fps: "
    						"fps %ld\t fps %ld\n",
    						FPS_ABS_DIFF(fps,
    							      frmi.discrete),
    						FPS_ABS_DIFF(fps, *best_ival));
    					goto do_it_now;
    				 * Select bigger resolution if it's available
    				 * at same fps.
    				if (frmi.width + frmi.height
    				    > best_pix_in->width + best_pix_in->height
    				    && FPS_ABS_DIFF(fps, frmi.discrete)
    				    <= FPS_ABS_DIFF(fps, *best_ival)) {
    					dev_dbg(&vdev->vfd->dev, "bigger res, "
    						"same fps: "
    						frmi.width, frmi.height,
    						best_pix_in->width,
    						best_pix_in->height);
    					goto do_it_now;
    				dev_dbg(&vdev->vfd->dev, "falling through\n");
    				continue;
    do_it_now:
    				*best_ival = frmi.discrete;
    				best_pix_out = pix_tmp_out;
    				best_pix_in->width = frmi.width;
    				best_pix_in->height = frmi.height;
    				best_pix_in->pixelformat = frmi.pixel_format;
    					"best_pix_in: w %d\th %d\tfmt %8.8x"
    					"\tival %d/%d\n",
    					best_pix_in->width,
    					best_pix_in->height,
    					best_pix_in->pixelformat,
    					best_ival->numerator,
    					best_ival->denominator);
    		return -EINVAL;
    	*wanted_pix_out = best_pix_out;
    	dev_dbg(&vdev->vfd->dev, "w %d, h %d, fmt %8.8x -> w %d, h %d\n",
    		best_pix_in->width, best_pix_in->height,
    		best_pix_out.width, best_pix_out.height);
    	return 0;
    static int s_pix_parm(struct omap34xxcam_videodev *vdev,
    		      struct v4l2_pix_format *best_pix,
    		      struct v4l2_pix_format *pix,
    	struct v4l2_streamparm a;
    	struct v4l2_format fmt;
    	struct v4l2_format old_fmt;
    	int rval;
    	rval = try_pix_parm(vdev, best_pix, pix, best_ival);
    	if (rval)
    		return rval;
    	rval = isp_s_fmt_cap(isp, best_pix, pix);
    	if (rval)
    		return rval;
    	fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    	fmt.fmt.pix = *best_pix;
    	vidioc_int_g_fmt_cap(vdev->vdev_sensor, &old_fmt);
    	rval = vidioc_int_s_fmt_cap(vdev->vdev_sensor, &fmt);
    	if (rval)
    		return rval;
    	a.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    	a.parm.capture.timeperframe = *best_ival;
    	rval = vidioc_int_s_parm(vdev->vdev_sensor, &a);
    	return rval;
     * vidioc_s_fmt_vid_cap - V4L2 set format capabilities IOCTL handler
     * Attempts to set input format with the sensor driver (first) and then the
     * ISP.  Returns the return code from vidioc_g_fmt_vid_cap().
    static int vidioc_s_fmt_vid_cap(struct file *file, void *fh,
    	struct v4l2_pix_format pix_tmp;
    	struct v4l2_fract timeperframe;
    	int rval;
    		return -EINVAL;
    	if (vdev->streaming) {
    		rval = -EBUSY;
    		goto out;
    	if (vdev->vdev_sensor_mode) {
    		struct v4l2_format input_fmt = *f;
    		struct v4l2_pix_format *pix = &f->fmt.pix;
    		rval = isp_try_fmt_cap(isp, pix, pix);
    		if (rval)
    			goto out;
    		/* Always negotiate with the sensor first */
    		rval = vidioc_int_s_fmt_cap(vdev->vdev_sensor, &input_fmt);
    		if (rval)
    			goto out;
    		pix->width = input_fmt.fmt.pix.width;
    		pix->height = input_fmt.fmt.pix.height;
    		pix->pixelformat = input_fmt.fmt.pix.pixelformat;
    		pix->field = input_fmt.fmt.pix.field;
    		pix->bytesperline = input_fmt.fmt.pix.bytesperline;
    		pix->colorspace = input_fmt.fmt.pix.colorspace;
    		pix->sizeimage = input_fmt.fmt.pix.sizeimage;
    		/* Negotiate with OMAP3 ISP */
    		rval = isp_s_fmt_cap(isp, pix, pix);
    		if (!rval)
    			vdev->pix = f->fmt.pix;
    	} else {
    		vdev->want_pix = f->fmt.pix;
    		timeperframe = vdev->want_timeperframe;
    		rval = s_pix_parm(vdev, &pix_tmp, &f->fmt.pix, &timeperframe);
    		if (!rval)
    out:
    	return rval;
     * vidioc_try_fmt_vid_cap - V4L2 try format capabilities IOCTL handler
     * Checks if the given format is supported by the sensor driver and
     * by the ISP.
    static int vidioc_try_fmt_vid_cap(struct file *file, void *fh,
    	int rval;
    		return -EINVAL;
    	rval = try_pix_parm(vdev, &pix_tmp, &f->fmt.pix, &timeperframe);
    	return rval;
     * vidioc_reqbufs - V4L2 request buffers IOCTL handler
     * @b: ptr to standard V4L2 request buffers structure
     * Attempts to get a buffer from the buffer queue associated with the
     * fh through the video buffer library API.
    static int vidioc_reqbufs(struct file *file, void *fh,
    			  struct v4l2_requestbuffers *b)
    	int rval;
    		return -EINVAL;
    		return -EBUSY;
    	rval = videobuf_reqbufs(&ofh->vbq, b);
    	 * Either videobuf_reqbufs failed or the buffers are not
    	 * memory-mapped (which would need special attention).
    	if (rval < 0 || b->memory != V4L2_MEMORY_MMAP)
    		goto out;
    out:
    	return rval;
     * vidioc_querybuf - V4L2 query buffer IOCTL handler
     * @b: ptr to standard V4L2 buffer structure
     * Attempts to fill in the v4l2_buffer structure for the buffer queue
     * associated with the fh through the video buffer library API.
    static int vidioc_querybuf(struct file *file, void *fh, struct v4l2_buffer *b)
    	return videobuf_querybuf(&ofh->vbq, b);
     * vidioc_qbuf - V4L2 queue buffer IOCTL handler
     * Attempts to queue the v4l2_buffer on the buffer queue
    static int vidioc_qbuf(struct file *file, void *fh, struct v4l2_buffer *b)
    	return videobuf_qbuf(&ofh->vbq, b);
     * vidioc_dqbuf - V4L2 dequeue buffer IOCTL handler
     * Attempts to dequeue the v4l2_buffer from the buffer queue
     * associated with the fh through the video buffer library API.  If the
     * buffer is a user space buffer, then this function will also requeue it,
     * as user does not expect to do this.
    static int vidioc_dqbuf(struct file *file, void *fh, struct v4l2_buffer *b)
    	int rval;
    videobuf_dqbuf_again:
    	rval = videobuf_dqbuf(&ofh->vbq, b, file->f_flags & O_NONBLOCK);
    	 * This is a hack. We don't want to show -EIO to the user
    	 * space. Requeue the buffer and try again if we're not doing
    	 * this in non-blocking mode.
    	if (rval == -EIO) {
    		if (!(file->f_flags & O_NONBLOCK))
    			goto videobuf_dqbuf_again;
    		 * We don't have a videobuf_buffer now --- maybe next
    		 * time...
    		rval = -EAGAIN;
    	return rval;
     * vidioc_streamon - V4L2 streamon IOCTL handler
     * @i: V4L2 buffer type
     * Attempts to start streaming by enabling the sensor interface and turning
     * on video buffer streaming through the video buffer library API.  Upon
     * success the function returns 0, otherwise an error code is returned.
    static int vidioc_streamon(struct file *file, void *fh, enum v4l2_buf_type i)
    	int rval;
    		return -EINVAL;
    		rval = -EBUSY;
    		goto out;
    	rval = omap34xxcam_slave_power_set(vdev, V4L2_POWER_ON,
    					   OMAP34XXCAM_SLAVE_POWER_SENSOR_LENS);
    	if (rval) {
    			"omap34xxcam_slave_power_set failed\n");
    		goto out;
    	isp_start(isp);
    	rval = videobuf_streamon(&ofh->vbq);
    	if (rval) {
    		isp_stop(isp);
    			vdev, V4L2_POWER_OFF,
    	} else
    		vdev->streaming = file;
    out:
    	return rval;
     * vidioc_streamoff - V4L2 streamoff IOCTL handler
     * Attempts to stop streaming by flushing all scheduled work, waiting on
     * any queued buffers to complete and then stopping the ISP and turning
     * off video buffer streaming through the video buffer library API.  Upon
    static int vidioc_streamoff(struct file *file, void *fh, enum v4l2_buf_type i)
    	struct videobuf_queue *q = &ofh->vbq;
    	int rval;
    	if (vdev->streaming == file)
    		isp_stop(isp);
    	rval = videobuf_streamoff(q);
    	if (!rval) {
    		vdev->streaming = NULL;
    		omap34xxcam_slave_power_set(vdev, V4L2_POWER_STANDBY,
    					    OMAP34XXCAM_SLAVE_POWER_SENSOR);
    		omap34xxcam_slave_power_suggest(vdev, V4L2_POWER_STANDBY,
    						OMAP34XXCAM_SLAVE_POWER_LENS);
    	return rval;
     * vidioc_enum_input - V4L2 enumerate input IOCTL handler
     * @inp: V4L2 input type information structure
     * Fills in v4l2_input structure.  Returns 0.
    static int vidioc_enum_input(struct file *file, void *fh,
    			     struct v4l2_input *inp)
    	struct omap34xxcam_videodev *vdev = ((struct omap34xxcam_fh *)fh)->vdev;
    #if defined(CONFIG_MACH_OMAP3_SOC8600)
                    strlcpy(inp->name, "COMPOSITE", sizeof(inp->name));
                    inp->type = V4L2_INPUT_TYPE_CAMERA;
    #else
    		if (inp->index == 0) {
    		} else if (inp->index == 1) {
    			strlcpy(inp->name, "S-VIDEO", sizeof(inp->name));
    		} else
    			return -EINVAL;
    #endif
    	} else {
    		if (inp->index > 0)
    			return -EINVAL;
    		strlcpy(inp->name, "camera", sizeof(inp->name));
    	return 0;
     * vidioc_g_input - V4L2 get input IOCTL handler
     * @i: address to hold index of input supported
     * Sets index to 0.
    static int vidioc_g_input(struct file *file, void *fh, unsigned int *i)
    	int rval = 0;
                    switch(vdev->slave_config[OMAP34XXCAM_SLAVE_SENSOR].cur_input) {
                    case INPUT_CVBS_VI3A:
                            *i = 0;
                            break;
                    case INPUT_CVBS_VI2A:
                            *i = 1;
                            break;
                    case INPUT_CVBS_VI1A:
                            *i = 2;
                            break;
                    case INPUT_CVBS_VI4A:
                            *i = 3;
                            break;
                    default:
                            *i = 0;
    #else
    		if (vdev->slave_config[OMAP34XXCAM_SLAVE_SENSOR].cur_input
    				== INPUT_CVBS_VI4A)
    			*i = 0;
    		else if (vdev->slave_config[OMAP34XXCAM_SLAVE_SENSOR].cur_input
    				== INPUT_SVIDEO_VI2C_VI1C)
    			*i = 1;
    #endif
    	} else {
    		*i = 0;
    	return rval;
     * vidioc_s_input - V4L2 set input IOCTL handler
     * @i: index of input selected
     * 0 is only index supported.
    static int vidioc_s_input(struct file *file, void *fh, unsigned int i)
    	int rval = 0;
    	struct v4l2_routing route;
                    switch(i) {
                    case 0:
                            route.input = INPUT_CVBS_VI3A;
                            break;
                    case 1:
                            route.input = INPUT_CVBS_VI2A;
                            break;
                    case 2:
                            route.input = INPUT_CVBS_VI1A;
                            break;
                    case 3:
                            route.input = INPUT_CVBS_VI4A;
                            break;
                    default:
    #else
    		if (i == 0)
    		else
    			route.input = INPUT_SVIDEO_VI2C_VI1C;
    #endif
    		route.output = 0;
    		rval = vidioc_int_s_video_routing(vdev->vdev_sensor, &route);
    		if (!rval)
    				= route.input;
    	} else {
    		if (i > 0)
    			rval = -EINVAL;
    	return rval;
     * vidioc_queryctrl - V4L2 query control IOCTL handler
     * @a: standard V4L2 query control ioctl structure
     * If the requested control is supported, returns the control information
     * in the v4l2_queryctrl structure.  Otherwise, returns -EINVAL if the
     * control is not supported.  If the sensor being used is a "smart sensor",
     * this request is passed to the sensor driver, otherwise the ISP is
     * queried and if it does not support the requested control, the request
     * is forwarded to the "raw" sensor driver to see if it supports it.
    static int vidioc_queryctrl(struct file *file, void *fh,
    			    struct v4l2_queryctrl *a)
    	struct v4l2_queryctrl a_tmp;
    	int best_slave = -1;
    	u32 best_ctrl = (u32)-1;
    	int i;
    		return vidioc_int_queryctrl(vdev->vdev_sensor, a);
    	/* No next flags: try slaves directly. */
    	if (!(a->id & V4L2_CTRL_FLAG_NEXT_CTRL)) {
    			if (!vidioc_int_queryctrl(vdev->slave[i], a))
    				return 0;
    		return isp_queryctrl(a);
    	/* Find slave with smallest next control id. */
    		a_tmp = *a;
    		if (vidioc_int_queryctrl(vdev->slave[i], &a_tmp))
    			continue;
    		if (a_tmp.id < best_ctrl) {
    			best_slave = i;
    			best_ctrl = a_tmp.id;
    	a_tmp = *a;
    	if (!isp_queryctrl(&a_tmp)) {
    			*a = a_tmp;
    			return 0;
    	if (best_slave == -1)
    		return -EINVAL;
    	a->id = best_ctrl;
    	return vidioc_int_queryctrl(vdev->slave[best_slave], a);
     * vidioc_querymenu - V4L2 query menu IOCTL handler
     * @a: standard V4L2 query menu ioctl structure
     * If the requested control is supported, returns the menu information
     * in the v4l2_querymenu structure.  Otherwise, returns -EINVAL if the
     * control is not supported or is not a menu.  If the sensor being used
     * is a "smart sensor", this request is passed to the sensor driver,
     * otherwise the ISP is queried and if it does not support the requested
     * menu control, the request is forwarded to the "raw" sensor driver to
     * see if it supports it.
    static int vidioc_querymenu(struct file *file, void *fh,
    			    struct v4l2_querymenu *a)
    	int i;
    		return vidioc_int_querymenu(vdev->vdev_sensor, a);
    	/* Try slaves directly. */
    		if (!vidioc_int_querymenu(vdev->slave[i], a))
    			return 0;
    	return isp_querymenu(a);
    static int vidioc_g_ext_ctrls(struct file *file, void *fh,
    			      struct v4l2_ext_controls *a)
    	int i, ctrl_idx, rval = 0;
    	for (ctrl_idx = 0; ctrl_idx < a->count; ctrl_idx++) {
    		struct v4l2_control ctrl;
    		ctrl.id = a->controls[ctrl_idx].id;
    		if (vdev->vdev_sensor_config.sensor_isp) {
    			rval = vidioc_int_g_ctrl(vdev->vdev_sensor, &ctrl);
    		} else {
    				rval = vidioc_int_g_ctrl(vdev->slave[i], &ctrl);
    				if (!rval)
    					break;
    		if (rval)
    			rval = isp_g_ctrl(isp, &ctrl);
    		if (rval) {
    			a->error_idx = ctrl_idx;
    			break;
    		a->controls[ctrl_idx].value = ctrl.value;
    	return rval;
    static int vidioc_s_ext_ctrls(struct file *file, void *fh,
    		ctrl.value = a->controls[ctrl_idx].value;
    			rval = vidioc_int_s_ctrl(vdev->vdev_sensor, &ctrl);
    		} else {
    				rval = vidioc_int_s_ctrl(vdev->slave[i], &ctrl);
    				if (!rval)
    					break;
    		if (rval)
    			rval = isp_s_ctrl(isp, &ctrl);
    		if (rval) {
    			break;
    	return rval;
     * vidioc_g_parm - V4L2 get parameters IOCTL handler
     * @a: standard V4L2 stream parameters structure
     * If request is for video capture buffer type, handles request by
     * forwarding to sensor driver.
    static int vidioc_g_parm(struct file *file, void *fh, struct v4l2_streamparm *a)
    	int rval;
    	if (a->type != V4L2_BUF_TYPE_VIDEO_CAPTURE)
    		return -EINVAL;
    	rval = vidioc_int_g_parm(vdev->vdev_sensor, a);
    	return rval;
     * vidioc_s_parm - V4L2 set parameters IOCTL handler
     * first getting current stream parameters from sensor, then forwarding
     * request to set new parameters to sensor driver.  It then attempts to
     * enable the sensor interface with the new parameters.  If this fails, it
     * reverts back to the previous parameters.
    static int vidioc_s_parm(struct file *file, void *fh, struct v4l2_streamparm *a)
    	struct v4l2_pix_format pix_tmp_sensor, pix_tmp;
    	int rval;
    		return -EINVAL;
    		return -EINVAL;
    		rval = -EBUSY;
    		goto out;
    	vdev->want_timeperframe = a->parm.capture.timeperframe;
    	pix_tmp = vdev->want_pix;
    	rval = s_pix_parm(vdev, &pix_tmp_sensor, &pix_tmp,
    			  &a->parm.capture.timeperframe);
    out:
    	return rval;
     * vidioc_cropcap - V4L2 crop capture IOCTL handler
     * @a: standard V4L2 crop capture structure
     * If using a "smart" sensor, just forwards request to the sensor driver,
     * otherwise fills in the v4l2_cropcap values locally.
    static int vidioc_cropcap(struct file *file, void *fh, struct v4l2_cropcap *a)
    	struct v4l2_cropcap *cropcap = a;
    	int rval;
    		return -EINVAL;
    	rval = vidioc_int_cropcap(vdev->vdev_sensor, a);
    	if (rval && !vdev->vdev_sensor_config.sensor_isp) {
    		struct v4l2_format f;
    		/* cropcap failed, try to do this via g_fmt_cap */
    		rval = vidioc_int_g_fmt_cap(vdev->vdev_sensor, &f);
    		if (!rval) {
    			cropcap->bounds.top = 0;
    			cropcap->bounds.left = 0;
    			cropcap->bounds.width = f.fmt.pix.width;
    			cropcap->bounds.height = f.fmt.pix.height;
    			cropcap->defrect = cropcap->bounds;
    			cropcap->pixelaspect.numerator = 1;
    			cropcap->pixelaspect.denominator = 1;
    	return rval;
     * vidioc_g_crop - V4L2 get capture crop IOCTL handler
     * @a: standard V4L2 crop structure
     * otherwise calls the isp functions to fill in current crop values.
    static int vidioc_g_crop(struct file *file, void *fh, struct v4l2_crop *a)
    	int rval = 0;
    		return -EINVAL;
    		rval = vidioc_int_g_crop(vdev->vdev_sensor, a);
    	else
    		rval = isp_g_crop(isp, a);
    	return rval;
     * vidioc_s_crop - V4L2 set capture crop IOCTL handler
     * otherwise calls the isp functions to set the current crop values.
    static int vidioc_s_crop(struct file *file, void *fh, struct v4l2_crop *a)
    	int rval = 0;
    		return -EINVAL;
    		rval = vidioc_int_s_crop(vdev->vdev_sensor, a);
    	else
    		rval = isp_s_crop(isp, a);
    	return rval;
    static int vidioc_enum_framesizes(struct file *file, void *fh,
    				  struct v4l2_frmsizeenum *frms)
    	u32 pixel_format;
    	int rval;
    		rval = vidioc_int_enum_framesizes(vdev->vdev_sensor, frms);
    	} else {
    		pixel_format = frms->pixel_format;
    		frms->pixel_format = -1;	/* ISP does format conversion */
    		frms->pixel_format = pixel_format;
    	return rval;
    static int vidioc_enum_frameintervals(struct file *file, void *fh,
    				      struct v4l2_frmivalenum *frmi)
    	u32 pixel_format;
    	int rval;
    		rval = vidioc_int_enum_frameintervals(vdev->vdev_sensor, frmi);
    	} else {
    		pixel_format = frmi->pixel_format;
    		frmi->pixel_format = -1;	/* ISP does format conversion */
    		frmi->pixel_format = pixel_format;
    	return rval;
     * vidioc_querystd - V4L2 query current standard IOCTL handler
     * @std: standard V4L2 v4l2_std_id enum
     * otherwise returns error
    static int vidioc_querystd(struct file *file, void *fh, v4l2_std_id *std)
    	int rval = 0;
    		rval = vidioc_int_querystd(vdev->vdev_sensor, std);
    		if (rval == 0)
    			vdev->vfd->current_norm = *std;
    	} else
    		rval = -EINVAL;
    	return rval;
     * vidioc_s_std - V4L2 set standard IOCTL handler
    static int vidioc_s_std(struct file *file, void *fh, v4l2_std_id *std)
    	int rval = 0;
    		rval = vidioc_int_s_std(vdev->vdev_sensor, std);
    		if (rval == 0)
    	} else
    		rval = -EINVAL;
    	return rval;
     * vidioc_default - private IOCTL handler
     * @cmd: ioctl cmd value
     * @arg: ioctl arg value
     * If the sensor being used is a "smart sensor", this request is returned to
     * caller with -EINVAL err code.  Otherwise if the control id is the private
     * VIDIOC_PRIVATE_ISP_AEWB_REQ to update the analog gain or exposure,
     * then this request is forwared directly to the sensor to incorporate the
     * feedback. The request is then passed on to the ISP private IOCTL handler,
     * isp_handle_private()
    static long vidioc_default(struct file *file, void *fh, int cmd, void *arg)
    	struct omap34xxcam_fh *ofh = file->private_data;
    	int rval;
    	if (cmd == VIDIOC_PRIVATE_OMAP34XXCAM_SENSOR_INFO) {
    		u32 pixclk;
    		struct v4l2_pix_format active_size, full_size;
    		struct omap34xxcam_sensor_info *ret_sensor_info;
    		ret_sensor_info = (struct omap34xxcam_sensor_info *)arg;
    		rval = vidioc_int_priv_g_pixclk(vdev->vdev_sensor, &pixclk);
    		if (rval)
    			goto out;
    		rval = vidioc_int_priv_g_activesize(vdev->vdev_sensor,
    					    &active_size);
    		if (rval)
    			goto out;
    		rval = vidioc_int_priv_g_fullsize(vdev->vdev_sensor,
    						  &full_size);
    		if (rval)
    			goto out;
    		ret_sensor_info->current_xclk = pixclk;
    		memcpy(&ret_sensor_info->active_size, &active_size,
    			sizeof(struct v4l2_pix_format));
    		memcpy(&ret_sensor_info->full_size, &full_size,
    		rval = 0;
    		goto out;
    		rval = -EINVAL;
    	} else {
    		switch (cmd) {
    		case VIDIOC_PRIVATE_ISP_AEWB_REQ:
    			/* Need to update sensor first */
    			struct isph3a_aewb_data *data;
    			struct v4l2_control vc;
    			data = (struct isph3a_aewb_data *) arg;
    			if (data->update & SET_EXPOSURE) {
    				dev_dbg(&vdev->vfd->dev, "using "
    					"VIDIOC_PRIVATE_ISP_AEWB_REQ to set "
    					"exposure is deprecated!\n");
    				vc.id = V4L2_CID_EXPOSURE;
    				vc.value = data->shutter;
    							 &vc);
    				if (rval)
    					goto out;
    			if (data->update & SET_ANALOG_GAIN) {
    					"gain is deprecated!\n");
    				vc.id = V4L2_CID_GAIN;
    				vc.value = data->gain;
    							 &vc);
    				if (rval)
    					goto out;
    		break;
    		case VIDIOC_PRIVATE_ISP_AF_REQ: {
    			/* Need to update lens first */
    			struct isp_af_data *data;
    			if (!vdev->vdev_lens) {
    				rval = -EINVAL;
    				goto out;
    			data = (struct isp_af_data *) arg;
    			if (data->update & LENS_DESIRED_POSITION) {
    					"VIDIOC_PRIVATE_ISP_AF_REQ to set "
    					"lens position is deprecated!\n");
    				vc.id = V4L2_CID_FOCUS_ABSOLUTE;
    				vc.value = data->desired_lens_direction;
    				rval = vidioc_int_s_ctrl(vdev->vdev_lens, &vc);
    				if (rval)
    					goto out;
    			break;
    		rval = isp_handle_private(isp, cmd, arg);
    out:
    	return rval;
     * File operations.
     * omap34xxcam_poll - file operations poll handler
     * @wait: system poll table structure
    static unsigned int omap34xxcam_poll(struct file *file,
    				     struct poll_table_struct *wait)
    	struct omap34xxcam_fh *fh = file->private_data;
    	struct videobuf_buffer *vb;
    	if (vdev->streaming != file) {
    		return POLLERR;
    	mutex_lock(&fh->vbq.vb_lock);
    	if (list_empty(&fh->vbq.stream)) {
    		mutex_unlock(&fh->vbq.vb_lock);
    		return POLLERR;
    	vb = list_entry(fh->vbq.stream.next, struct videobuf_buffer, stream);
    	poll_wait(file, &vb->done, wait);
    	if (vb->state == VIDEOBUF_DONE || vb->state == VIDEOBUF_ERROR)
    		return POLLIN | POLLRDNORM;
    	return 0;
     * omap34xxcam_mmap - file operations mmap handler
     * @vma: system virt. mem. area structure
     * Maps a virtual memory area via the video buffer API
    static int omap34xxcam_mmap(struct file *file, struct vm_area_struct *vma)
    	return videobuf_mmap_mapper(&fh->vbq, vma);
     * omap34xxcam_open - file operations open handler
     * @inode: ptr. to system inode structure
     * Allocates and initializes the per-filehandle data (omap34xxcam_fh),
     * enables the sensor, opens/initializes the ISP interface and the
     * video buffer queue.  Note that this function will allow multiple
     * file handles to be open simultaneously, however only the first
     * handle opened will initialize the ISP.  It is the application
     * responsibility to only use one handle for streaming and the others
     * for control only.
     * This function returns 0 upon success and -ENODEV upon error.
    static int omap34xxcam_open(struct file *file)
    	int rval = 0;
    	struct omap34xxcam_videodev *vdev = NULL;
    	struct omap34xxcam_device *cam = omap34xxcam;
    	struct device *isp;
    	struct omap34xxcam_fh *fh;
    	struct v4l2_format sensor_format;
    	int first_user = 0;
    	int i;
    	for (i = 0; i < OMAP34XXCAM_VIDEODEVS; i++) {
    		if (cam->vdevs[i].vfd
    		    && cam->vdevs[i].vfd->minor ==
    		    iminor(file->f_dentry->d_inode)) {
    			vdev = &cam->vdevs[i];
    			break;
    	if (!vdev || !vdev->vfd)
    		return -ENODEV;
    	fh = kzalloc(sizeof(*fh), GFP_KERNEL);
    	if (fh == NULL)
    		return -ENOMEM;
    	fh->vdev = vdev;
    		if (vdev->slave[i] != v4l2_int_device_dummy()
    		    && !try_module_get(vdev->slave[i]->module)) {
    			dev_err(&vdev->vfd->dev, "can't try_module_get %s\n",
    				vdev->slave[i]->name);
    			rval = -ENODEV;
    			goto out_try_module_get;
    	if (atomic_inc_return(&vdev->users) == 1) {
    		first_user = 1;
    		isp = isp_get();
    		if (!isp) {
    			rval = -EBUSY;
    			dev_err(&vdev->vfd->dev, "can't get isp\n");
    			goto out_isp_get;
    		cam->isp = isp;
    		if (omap34xxcam_slave_power_set(vdev, V4L2_POWER_ON,
    						OMAP34XXCAM_SLAVE_POWER_ALL)) {
    			dev_err(&vdev->vfd->dev, "can't power up slaves\n");
    			rval = -EBUSY;
    			goto out_slave_power_set_standby;
    	if (vdev->vdev_sensor == v4l2_int_device_dummy() || !first_user)
    		goto out_no_pix;
                    int rval;
                    route.output = 0;
                                    &route);
                    if (!rval)
                                    .cur_input = route.input;
    #else
    		if ((vdev->slave_config[OMAP34XXCAM_SLAVE_SENSOR].cur_input
    					!= INPUT_CVBS_VI4A) &&
    				 cur_input != INPUT_SVIDEO_VI2C_VI1C)) {
    			int rval;
    			route.output = 0;
    					&route);
    			if (rval) {
    			if (!rval)
    #endif
    		sensor_format.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    	/* Get the format the sensor is using. */
    	rval = vidioc_int_g_fmt_cap(vdev->vdev_sensor, &sensor_format);
    	if (rval) {
    			"can't get current pix from sensor!\n");
    		goto out_vidioc_int_g_fmt_cap;
    	if (!vdev->pix.width)
    		vdev->pix = sensor_format.fmt.pix;
    	if (!vdev->vdev_sensor_config.sensor_isp) {
    		struct v4l2_pix_format pix;
    		struct v4l2_fract timeperframe =
    		rval = s_pix_parm(vdev, &pix, &vdev->pix, &timeperframe);
    		if (rval) {
    				"isp doesn't like the sensor!\n");
    			goto out_isp_s_fmt_cap;
    out_no_pix:
    	file->private_data = fh;
    	spin_lock_init(&fh->vbq_lock);
    	videobuf_queue_sg_init(&fh->vbq, &omap34xxcam_vbq_ops, NULL,
    				&fh->vbq_lock, V4L2_BUF_TYPE_VIDEO_CAPTURE,
    				V4L2_FIELD_NONE,
    				sizeof(struct videobuf_buffer), fh);
    	return 0;
    out_isp_s_fmt_cap:
    out_vidioc_int_g_fmt_cap:
    	omap34xxcam_slave_power_set(vdev, V4L2_POWER_OFF,
    				    OMAP34XXCAM_SLAVE_POWER_ALL);
    out_slave_power_set_standby:
    	isp_put();
    out_isp_get:
    	atomic_dec(&vdev->users);
    out_try_module_get:
    		if (vdev->slave[i] != v4l2_int_device_dummy())
    			module_put(vdev->slave[i]->module);
    	kfree(fh);
    	return rval;
     * omap34xxcam_release - file operations release handler
     * Complement of omap34xxcam_open.  This function will flush any scheduled
     * work, disable the sensor, close the ISP interface, stop the
     * video buffer queue from streaming and free the per-filehandle data
     * (omap34xxcam_fh).  Note that because multiple open file handles
     * are allowed, this function will only close the ISP and disable the
     * sensor when the last open file handle (by count) is closed.
     * This function returns 0.
    static int omap34xxcam_release(struct file *file)
    	int i;
    	if (vdev->streaming == file) {
    		isp_stop(isp);
    		videobuf_streamoff(&fh->vbq);
    	if (atomic_dec_return(&vdev->users) == 0) {
    		isp_put();
    	file->private_data = NULL;
    	kfree(fh);
    	return 0;
    static struct v4l2_file_operations omap34xxcam_fops = {
    	.owner = THIS_MODULE,
    	.unlocked_ioctl = video_ioctl2,
    	.poll = omap34xxcam_poll,
    	.mmap = omap34xxcam_mmap,
    	.open = omap34xxcam_open,
    	.release = omap34xxcam_release,
    static void omap34xxcam_vfd_name_update(struct omap34xxcam_videodev *vdev)
    	struct video_device *vfd = vdev->vfd;
    	int i;
    	strlcpy(vfd->name, CAM_SHORT_NAME, sizeof(vfd->name));
    		strlcat(vfd->name, "/", sizeof(vfd->name));
    			continue;
    		strlcat(vfd->name, vdev->slave[i]->name, sizeof(vfd->name));
    	dev_dbg(&vdev->vfd->dev, "video%d is now %s\n", vfd->num, vfd->name);
     * omap34xxcam_device_unregister - V4L2 detach handler
     * @s: ptr. to standard V4L2 device information structure
     * Detach sensor and unregister and release the video device.
    static void omap34xxcam_device_unregister(struct v4l2_int_device *s)
    	struct omap34xxcam_videodev *vdev = s->u.slave->master->priv;
    	struct omap34xxcam_hw_config hwc;
    	BUG_ON(vidioc_int_g_priv(s, &hwc) < 0);
    	if (vdev->slave[hwc.dev_type] != v4l2_int_device_dummy()) {
    		vdev->slave[hwc.dev_type] = v4l2_int_device_dummy();
    		vdev->slaves--;
    		omap34xxcam_vfd_name_update(vdev);
    	if (vdev->slaves == 0 && vdev->vfd) {
    		if (vdev->vfd->minor == -1) {
    			 * The device was never registered, so release the
    			 * video_device struct directly.
    			video_device_release(vdev->vfd);
    		} else {
    			 * The unregister function will release the
    			 * video_device struct as well as
    			 * unregistering it.
    			video_unregister_device(vdev->vfd);
    		vdev->vfd = NULL;
    static const struct v4l2_ioctl_ops omap34xxcam_ioctl_ops = {
    	.vidioc_querycap		= vidioc_querycap,
    	.vidioc_enum_fmt_vid_cap	= vidioc_enum_fmt_vid_cap,
    	.vidioc_g_fmt_vid_cap		= vidioc_g_fmt_vid_cap,
    	.vidioc_s_fmt_vid_cap		= vidioc_s_fmt_vid_cap,
    	.vidioc_try_fmt_vid_cap		= vidioc_try_fmt_vid_cap,
    	.vidioc_reqbufs			= vidioc_reqbufs,
    	.vidioc_querybuf		= vidioc_querybuf,
    	.vidioc_qbuf			= vidioc_qbuf,
    	.vidioc_dqbuf			= vidioc_dqbuf,
    	.vidioc_streamon		= vidioc_streamon,
    	.vidioc_streamoff		= vidioc_streamoff,
    	.vidioc_enum_input		= vidioc_enum_input,
    	.vidioc_g_input			= vidioc_g_input,
    	.vidioc_s_input			= vidioc_s_input,
    	.vidioc_queryctrl		= vidioc_queryctrl,
    	.vidioc_querymenu		= vidioc_querymenu,
    	.vidioc_g_ext_ctrls		= vidioc_g_ext_ctrls,
    	.vidioc_s_ext_ctrls		= vidioc_s_ext_ctrls,
    	.vidioc_g_parm			= vidioc_g_parm,
    	.vidioc_s_parm			= vidioc_s_parm,
    	.vidioc_cropcap			= vidioc_cropcap,
    	.vidioc_g_crop			= vidioc_g_crop,
    	.vidioc_s_crop			= vidioc_s_crop,
    	.vidioc_enum_framesizes		= vidioc_enum_framesizes,
    	.vidioc_enum_frameintervals	= vidioc_enum_frameintervals,
    	.vidioc_s_std			= vidioc_s_std,
    	.vidioc_querystd		= vidioc_querystd,
    	.vidioc_default			= vidioc_default,
     * omap34xxcam_device_register - V4L2 attach handler
     * Allocates and initializes the V4L2 video_device structure, initializes
     * the sensor, and finally
     registers the device with V4L2 based on the
     * video_device structure.
     * Returns 0 on success, otherwise an appropriate error code on
     * failure.
    static int omap34xxcam_device_register(struct v4l2_int_device *s)
    	struct v4l2_ifparm ifparm;
    	struct device *isp;
    	int rval;
    	/* We need to check rval just once. The place is here. */
    	if (vidioc_int_g_priv(s, &hwc))
    		return -ENODEV;
    	if (vdev->index != hwc.dev_index)
    		return -ENODEV;
    	if (hwc.dev_type < 0 || hwc.dev_type > OMAP34XXCAM_SLAVE_FLASH)
    		return -EINVAL;
    		return -EBUSY;
    	if (atomic_read(&vdev->users)) {
    		printk(KERN_ERR "%s: we're open (%d), can't register\n",
    		       __func__, atomic_read(&vdev->users));
    		return -EBUSY;
    	vdev->slaves++;
    	vdev->slave[hwc.dev_type] = s;
    	vdev->slave_config[hwc.dev_type] = hwc;
    	if (hwc.dev_type == OMAP34XXCAM_SLAVE_SENSOR) {
    		isp = isp_get();
    		if (!isp) {
    			rval = -EBUSY;
    			printk(KERN_ERR "%s: can't get ISP, "
    			       "sensor init failed\n", __func__);
    			goto err;
    		vdev->cam->isp = isp;
    					   1 << hwc.dev_type);
    	if (rval)
    		goto err_omap34xxcam_slave_power_set;
    		struct v4l2_format format;
    		rval = vidioc_int_g_fmt_cap(vdev->vdev_sensor, &format);
    		if (rval)
    			rval = -EBUSY;
    		vdev->want_pix = format.fmt.pix;
    	omap34xxcam_slave_power_set(vdev, V4L2_POWER_OFF, 1 << hwc.dev_type);
    		isp_put();
    	if (rval)
    		goto err;
    	/* Are we the first slave? */
    	if (vdev->slaves == 1) {
    		/* initialize the video_device struct */
    		vdev->vfd = video_device_alloc();
    		if (!vdev->vfd) {
    			printk(KERN_ERR "%s: could not allocate "
    			       "video device struct\n", __func__);
    			rval = -ENOMEM;
    			goto err;
    		vdev->vfd->release	= video_device_release;
    		vdev->vfd->minor	= -1;
    		vdev->vfd->fops		= &omap34xxcam_fops;
    		vdev->vfd->ioctl_ops	= &omap34xxcam_ioctl_ops;
    		video_set_drvdata(vdev->vfd, vdev);
    		if (video_register_device(vdev->vfd, VFL_TYPE_GRABBER,
    					  hwc.dev_minor) < 0) {
    			printk(KERN_ERR "%s: could not register V4L device\n",
    				__func__);
    			rval = -EBUSY;
    			goto err;
    	/*Determine whether the slave connected is BT656 decoder or a sensor*/
    	if (!vidioc_int_g_ifparm(s, &ifparm)) {
    		if (ifparm.if_type == V4L2_IF_TYPE_BT656) {
    			vdev->vfd->current_norm = V4L2_STD_NTSC;
    			vdev->vfd->tvnorms	= V4L2_STD_NTSC | V4L2_STD_PAL;
    			if ((ifparm.u.bt656.mode ==
    					V4L2_IF_TYPE_BT656_MODE_BT_8BIT) ||
    					 V4L2_IF_TYPE_BT656_MODE_BT_10BIT))
    				vdev->slave_mode[hwc.dev_type] = 1;
    	return 0;
    err_omap34xxcam_slave_power_set:
    		isp_put();
    err:
    	if (s == vdev->slave[hwc.dev_type]) {
    		vdev->slaves--;
    	omap34xxcam_device_unregister(s);
    	return rval;
    static struct v4l2_int_master omap34xxcam_master = {
    	.attach = omap34xxcam_device_register,
    	.detach = omap34xxcam_device_unregister,
     * Module initialisation and deinitialisation
    static void omap34xxcam_exit(void)
    	int i;
    	if (!cam)
    		return;
    		if (cam->vdevs[i].cam == NULL)
    			continue;
    		v4l2_int_device_unregister(&cam->vdevs[i].master);
    		cam->vdevs[i].cam = NULL;
    	omap34xxcam = NULL;
    	kfree(cam);
    static int __init omap34xxcam_init(void)
    	struct omap34xxcam_device *cam;
    	int i;
    	cam = kzalloc(sizeof(*cam), GFP_KERNEL);
    	if (!cam) {
    		printk(KERN_ERR "%s: could not allocate memory\n", __func__);
    		return -ENOMEM;
    	omap34xxcam = cam;
    		struct omap34xxcam_videodev *vdev = &cam->vdevs[i];
    		struct v4l2_int_device *m = &vdev->master;
    		m->module       = THIS_MODULE;
    		strlcpy(m->name, CAM_NAME, sizeof(m->name));
    		m->type         = v4l2_int_type_master;
    		m->u.master     = &omap34xxcam_master;
    		m->priv		= vdev;
    		mutex_init(&vdev->mutex);
    		vdev->index             = i;
    		vdev->cam               = cam;
    		vdev->vdev_sensor =
    			vdev->vdev_lens =
    			vdev->vdev_flash = v4l2_int_device_dummy();
    		setup_timer(&vdev->poweroff_timer,
    			    omap34xxcam_slave_power_timer, (unsigned long)vdev);
    		INIT_WORK(&vdev->poweroff_work, omap34xxcam_slave_power_work);
    		if (v4l2_int_device_register(m))
    			goto err;
    	return 0;
    err:
    	omap34xxcam_exit();
    	return -ENODEV;
    MODULE_AUTHOR("Sakari Ailus <sakari.ailus@nokia.com>");
    MODULE_DESCRIPTION("OMAP34xx Video for Linux camera driver");
    MODULE_LICENSE("GPL");
    late_initcall(omap34xxcam_init);
    module_exit(omap34xxcam_exit);
     * drivers/media/video/tvp514x.c
     * TI TVP5146/47 decoder driver
     * Copyright (C) 2008 Texas Instruments Inc
     * Author: Vaibhav Hiremath <hvaibhav@ti.com>
     * Contributors:
     *     Sivaraj R <sivaraj@ti.com>
     *     Brijesh R Jadav <brijesh.j@ti.com>
     *     Hardik Shah <hardik.shah@ti.com>
     *     Manjunath Hadli <mrh@ti.com>
     *     Karicheri Muralidharan <m-karicheri2@ti.com>
     * This package is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
     * but WITHOUT ANY WARRANTY; without even the implied warranty of
     * GNU General Public License for more details.
     * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
    #include <linux/i2c.h>
    #include <linux/delay.h>
    #include <media/v4l2-device.h>
    #include <media/v4l2-chip-ident.h>
    #include <media/tvp514x.h>
    #include "tvp514x_regs.h"
    /* Module Name */
    #define TVP514X_MODULE_NAME		"tvp514x"
    /* Private macros for TVP */
    #define I2C_RETRY_COUNT                 (5)
    #define LOCK_RETRY_COUNT                (5)
    #define LOCK_RETRY_DELAY                (200)
    /* Debug functions */
    static int debug;
    module_param(debug, bool, 0644);
    MODULE_PARM_DESC(debug, "Debug level (0-1)");
    MODULE_AUTHOR("Texas Instruments");
    MODULE_DESCRIPTION("TVP514X linux decoder driver");
    /* enum tvp514x_std - enum for supported standards */
    enum tvp514x_std {
    	STD_NTSC_MJ = 0,
    	STD_PAL_BDGHIN,
    	STD_INVALID
     * struct tvp514x_std_info - Structure to store standard informations
     * @width: Line width in pixels
     * @height:Number of active lines
     * @video_std: Value to write in REG_VIDEO_STD register
     * @standard: v4l2 standard structure information
    struct tvp514x_std_info {
    	unsigned long width;
    	unsigned long height;
    	u8 video_std;
    	struct v4l2_standard standard;
    static struct tvp514x_reg tvp514x_reg_list_default[0x40];
    static int tvp514x_s_stream(struct v4l2_subdev *sd, int enable);
     * struct tvp514x_decoder - TVP5146/47 decoder object
     * @sd: Subdevice Slave handle
     * @tvp514x_regs: copy of hw's regs with preset values.
     * @pdata: Board specific
     * @ver: Chip version
     * @streaming: TVP5146/47 decoder streaming - enabled or disabled.
     * @pix: Current pixel format
     * @num_fmts: Number of formats
     * @fmt_list: Format list
     * @current_std: Current standard
     * @num_stds: Number of standards
     * @std_list: Standards list
     * @input: Input routing at chip level
     * @output: Output routing at chip level
    struct tvp514x_decoder {
    	struct v4l2_subdev sd;
    	struct tvp514x_reg tvp514x_regs[ARRAY_SIZE(tvp514x_reg_list_default)];
    	const struct tvp514x_platform_data *pdata;
    	int ver;
    	int streaming;
    	int num_fmts;
    	const struct v4l2_fmtdesc *fmt_list;
    	enum tvp514x_std current_std;
    	int num_stds;
    	struct tvp514x_std_info *std_list;
    	/* Input and Output Routing parameters */
    	u32 input;
    	u32 output;
    /* TVP514x default register values */
    static struct tvp514x_reg tvp514x_reg_list_default[] = {
    	/* Composite selected */
    	{TOK_WRITE, REG_INPUT_SEL, 0x05},
    	{TOK_WRITE, REG_AFE_GAIN_CTRL, 0x0F},
    	/* Auto mode */
    	{TOK_WRITE, REG_VIDEO_STD, 0x00},
    	{TOK_WRITE, REG_OPERATION_MODE, 0x00},
    	{TOK_SKIP, REG_AUTOSWITCH_MASK, 0x3F},
    	{TOK_WRITE, REG_COLOR_KILLER, 0x10},
    	{TOK_WRITE, REG_LUMA_CONTROL1, 0x00},
    	{TOK_WRITE, REG_LUMA_CONTROL2, 0x00},
    	{TOK_WRITE, REG_LUMA_CONTROL3, 0x02},
    	{TOK_WRITE, REG_BRIGHTNESS, 0x80},
    	{TOK_WRITE, REG_CONTRAST, 0x80},
    	{TOK_WRITE, REG_SATURATION, 0x80},
    	{TOK_WRITE, REG_HUE, 0x00},
    	{TOK_WRITE, REG_CHROMA_CONTROL1, 0x00},
    	{TOK_WRITE, REG_CHROMA_CONTROL2, 0x0E},
    	/* Reserved */
    	{TOK_SKIP, 0x0F, 0x00},
    	{TOK_WRITE, REG_COMP_PR_SATURATION, 0x80},
    	{TOK_WRITE, REG_COMP_Y_CONTRAST, 0x80},
    	{TOK_WRITE, REG_COMP_PB_SATURATION, 0x80},
    	/* Reserved */
    	{TOK_SKIP, 0x13, 0x00},
    	{TOK_WRITE, REG_COMP_Y_BRIGHTNESS, 0x80},
    	/* Reserved */
    	{TOK_SKIP, 0x15, 0x00},
    	/* NTSC timing */
    	{TOK_SKIP, REG_AVID_START_PIXEL_LSB, 0x55},
    	{TOK_SKIP, REG_AVID_START_PIXEL_MSB, 0x00},
    	{TOK_SKIP, REG_AVID_STOP_PIXEL_LSB, 0x25},
    	{TOK_SKIP, REG_AVID_STOP_PIXEL_MSB, 0x03},
    	/* NTSC timing */
    	{TOK_SKIP, REG_HSYNC_START_PIXEL_LSB, 0x00},
    	{TOK_SKIP, REG_HSYNC_START_PIXEL_MSB, 0x00},
    	{TOK_SKIP, REG_HSYNC_STOP_PIXEL_LSB, 0x40},
    	{TOK_SKIP, REG_HSYNC_STOP_PIXEL_MSB, 0x00},
    	/* NTSC timing */
    	{TOK_SKIP, REG_VSYNC_START_LINE_LSB, 0x04},
    	{TOK_SKIP, REG_VSYNC_START_LINE_MSB, 0x00},
    	{TOK_SKIP, REG_VSYNC_STOP_LINE_LSB, 0x07},
    	{TOK_SKIP, REG_VSYNC_STOP_LINE_MSB, 0x00},
    	/* NTSC timing */
    	{TOK_SKIP, REG_VBLK_START_LINE_LSB, 0x01},
    	{TOK_SKIP, REG_VBLK_START_LINE_MSB, 0x00},
    	{TOK_SKIP, REG_VBLK_STOP_LINE_LSB, 0x15},
    	{TOK_SKIP, REG_VBLK_STOP_LINE_MSB, 0x00},
    	/* Reserved */
    	{TOK_SKIP, 0x26, 0x00},
    	/* Reserved */
    	{TOK_SKIP, 0x27, 0x00},
    	{TOK_SKIP, REG_FAST_SWTICH_CONTROL, 0xCC},
    	/* Reserved */
    	{TOK_SKIP, 0x29, 0x00},
    	{TOK_SKIP, REG_FAST_SWTICH_SCART_DELAY, 0x00},
    	/* Reserved */
    	{TOK_SKIP, 0x2B, 0x00},
    	{TOK_SKIP, REG_SCART_DELAY, 0x00},
    	{TOK_SKIP, REG_CTI_DELAY, 0x00},
    	{TOK_SKIP, REG_CTI_CONTROL, 0x00},
    	/* Reserved */
    	{TOK_SKIP, 0x2F, 0x00},
    	/* Reserved */
    	{TOK_SKIP, 0x30, 0x00},
    	/* Reserved */
    	{TOK_SKIP, 0x31, 0x00},
    	/* HS, VS active high */
    	{TOK_WRITE, REG_SYNC_CONTROL, 0x00},
    	/* 10-bit BT.656 */
    	{TOK_WRITE, REG_OUTPUT_FORMATTER1, 0x00},
    	/* Enable clk & data */
    	{TOK_WRITE, REG_OUTPUT_FORMATTER2, 0x11},
    	/* Enable AVID & FLD */
    	{TOK_WRITE, REG_OUTPUT_FORMATTER3, 0xEE},
    	/* Enable VS & HS */
    	{TOK_WRITE, REG_OUTPUT_FORMATTER4, 0xAF},
    	{TOK_WRITE, REG_OUTPUT_FORMATTER5, 0xFF},
    	{TOK_WRITE, REG_OUTPUT_FORMATTER6, 0xFF},
    	/* Clear status */
    	{TOK_WRITE, REG_CLEAR_LOST_LOCK, 0x01},
    	{TOK_TERM, 0, 0},
     * List of image formats supported by TVP5146/47 decoder
     * Currently we are using 8 bit mode only, but can be
     * extended to 10/20 bit mode.
    static const struct v4l2_fmtdesc tvp514x_fmt_list[] = {
    	 .index = 0,
    	 .type = V4L2_BUF_TYPE_VIDEO_CAPTURE,
    	 .flags = 0,
    	 .description = "8-bit UYVY 4:2:2 Format",
    	 .pixelformat = V4L2_PIX_FMT_UYVY,
    	 .index = 1,
    	 .flags = 0,
    	 .description = "8-bit YUYV 4:2:2 Format",
    	 .pixelformat = V4L2_PIX_FMT_YUYV,
     * Supported standards -
     * Currently supports two standards only, need to add support for rest of the
     * modes, like SECAM, etc...
    static struct tvp514x_std_info tvp514x_std_list[] = {
    	/* Standard: STD_NTSC_MJ */
    	[STD_NTSC_MJ] = {
    	 .width = NTSC_NUM_ACTIVE_PIXELS,
    	 .height = NTSC_NUM_ACTIVE_LINES,
    	 .video_std = VIDEO_STD_NTSC_MJ_BIT,
    	 .standard = {
    		      .index = 0,
    		      .id = V4L2_STD_NTSC,
    		      .name = "NTSC",
    		      .frameperiod = {1001, 30000},
    		      .framelines = 525
    	/* Standard: STD_PAL_BDGHIN */
    	[STD_PAL_BDGHIN] = {
    	 .width = PAL_NUM_ACTIVE_PIXELS,
    	 .height = PAL_NUM_ACTIVE_LINES,
    	 .video_std = VIDEO_STD_PAL_BDGHIN_BIT,
    	 .standard = {
    		      .index = 1,
    		      .id = V4L2_STD_PAL,
    		      .name = "PAL",
    		      .frameperiod = {1, 25},
    		      .framelines = 625
    	/* Standard: need to add for additional standard */
    static inline struct tvp514x_decoder *to_decoder(struct v4l2_subdev *sd)
    	return container_of(sd, struct tvp514x_decoder, sd);
     * tvp514x_read_reg() - Read a value from a register in an TVP5146/47.
     * @sd: ptr to v4l2_subdev struct
     * @reg: TVP5146/47 register address
     * Returns value read if successful, or non-zero (-1) otherwise.
    static int tvp514x_read_reg(struct v4l2_subdev *sd, u8 reg)
    	int err, retry = 0;
    	struct i2c_client *client = v4l2_get_subdevdata(sd);
    read_again:
    	err = i2c_smbus_read_byte_data(client, reg);
    	if (err < 0) {
    		if (retry <= I2C_RETRY_COUNT) {
    			v4l2_warn(sd, "Read: retry ... %d\n", retry);
    			retry++;
    			msleep_interruptible(10);
    			goto read_again;
    	return err;
     * dump_reg() - dump the register content of TVP5146/47.
    static void dump_reg(struct v4l2_subdev *sd, u8 reg)
    	u32 val;
    	val = tvp514x_read_reg(sd, reg);
    	v4l2_info(sd, "Reg(0x%.2X): 0x%.2X\n", reg, val);
     * tvp514x_write_reg() - Write a value to a register in TVP5146/47
     * @val: value to be written to the register
     * Write a value to a register in an TVP5146/47 decoder device.
     * Returns zero if successful, or non-zero otherwise.
    static int tvp514x_write_reg(struct v4l2_subdev *sd, u8 reg, u8 val)
    	int err, retry = 0;
    write_again:
    	err = i2c_smbus_write_byte_data(client, reg, val);
    	if (err) {
    			v4l2_warn(sd, "Write: retry ... %d\n", retry);
    			retry++;
    			goto write_again;
    	return err;
     * tvp514x_write_regs() : Initializes a list of TVP5146/47 registers
     * @reglist: list of TVP5146/47 registers and values
     * Initializes a list of TVP5146/47 registers:-
     *		if token is TOK_TERM, then entire write operation terminates
     *		if token is TOK_DELAY, then a delay of 'val' msec is introduced
     *		if token is TOK_SKIP, then the register write is skipped
     *		if token is TOK_WRITE, then the register write is performed
    static int tvp514x_write_regs(struct v4l2_subdev *sd,
    			      const struct tvp514x_reg reglist[])
    	int err;
    	const struct tvp514x_reg *next = reglist;
    	for (; next->token != TOK_TERM; next++) {
    		if (next->token == TOK_DELAY) {
    			msleep(next->val);
    			continue;
    		if (next->token == TOK_SKIP)
    			continue;
    		err = tvp514x_write_reg(sd, next->reg, (u8) next->val);
    		if (err) {
    			v4l2_err(sd, "Write failed. Err[%d]\n", err);
    			return err;
    	return 0;
     * tvp514x_get_current_std() : Get the current standard detected by TVP5146/47
     * Get current standard detected by TVP5146/47, STD_INVALID if there is no
     * standard detected.
    static enum tvp514x_std tvp514x_get_current_std(struct v4l2_subdev *sd)
    	u8 std, std_status;
    	std = tvp514x_read_reg(sd, REG_VIDEO_STD);
    	if ((std & VIDEO_STD_MASK) == VIDEO_STD_AUTO_SWITCH_BIT)
    		/* use the standard status register */
    		std_status = tvp514x_read_reg(sd, REG_VIDEO_STD_STATUS);
    	else
    		/* use the standard register itself */
    		std_status = std;
    	switch (std_status & VIDEO_STD_MASK) {
    	case VIDEO_STD_NTSC_MJ_BIT:
    		return STD_NTSC_MJ;
    	case VIDEO_STD_PAL_BDGHIN_BIT:
    		return STD_PAL_BDGHIN;
    	default:
    		return STD_INVALID;
    	return STD_INVALID;
    /* TVP5146/47 register dump function */
    static void tvp514x_reg_dump(struct v4l2_subdev *sd)
    	dump_reg(sd, REG_INPUT_SEL);
    	dump_reg(sd, REG_AFE_GAIN_CTRL);
    	dump_reg(sd, REG_VIDEO_STD);
    	dump_reg(sd, REG_OPERATION_MODE);
    	dump_reg(sd, REG_COLOR_KILLER);
    	dump_reg(sd, REG_LUMA_CONTROL1);
    	dump_reg(sd, REG_LUMA_CONTROL2);
    	dump_reg(sd, REG_LUMA_CONTROL3);
    	dump_reg(sd, REG_BRIGHTNESS);
    	dump_reg(sd, REG_CONTRAST);
    	dump_reg(sd, REG_SATURATION);
    	dump_reg(sd, REG_HUE);
    	dump_reg(sd, REG_CHROMA_CONTROL1);
    	dump_reg(sd, REG_CHROMA_CONTROL2);
    	dump_reg(sd, REG_COMP_PR_SATURATION);
    	dump_reg(sd, REG_COMP_Y_CONTRAST);
    	dump_reg(sd, REG_COMP_PB_SATURATION);
    	dump_reg(sd, REG_COMP_Y_BRIGHTNESS);
    	dump_reg(sd, REG_AVID_START_PIXEL_LSB);
    	dump_reg(sd, REG_AVID_START_PIXEL_MSB);
    	dump_reg(sd, REG_AVID_STOP_PIXEL_LSB);
    	dump_reg(sd, REG_AVID_STOP_PIXEL_MSB);
    	dump_reg(sd, REG_HSYNC_START_PIXEL_LSB);
    	dump_reg(sd, REG_HSYNC_START_PIXEL_MSB);
    	dump_reg(sd, REG_HSYNC_STOP_PIXEL_LSB);
    	dump_reg(sd, REG_HSYNC_STOP_PIXEL_MSB);
    	dump_reg(sd, REG_VSYNC_START_LINE_LSB);
    	dump_reg(sd, REG_VSYNC_START_LINE_MSB);
    	dump_reg(sd, REG_VSYNC_STOP_LINE_LSB);
    	dump_reg(sd, REG_VSYNC_STOP_LINE_MSB);
    	dump_reg(sd, REG_VBLK_START_LINE_LSB);
    	dump_reg(sd, REG_VBLK_START_LINE_MSB);
    	dump_reg(sd, REG_VBLK_STOP_LINE_LSB);
    	dump_reg(sd, REG_VBLK_STOP_LINE_MSB);
    	dump_reg(sd, REG_SYNC_CONTROL);
    	dump_reg(sd, REG_OUTPUT_FORMATTER1);
    	dump_reg(sd, REG_OUTPUT_FORMATTER2);
    	dump_reg(sd, REG_OUTPUT_FORMATTER3);
    	dump_reg(sd, REG_OUTPUT_FORMATTER4);
    	dump_reg(sd, REG_OUTPUT_FORMATTER5);
    	dump_reg(sd, REG_OUTPUT_FORMATTER6);
    	dump_reg(sd, REG_CLEAR_LOST_LOCK);
     * tvp514x_configure() - Configure the TVP5146/47 registers
     * @decoder: ptr to tvp514x_decoder structure
    static int tvp514x_configure(struct v4l2_subdev *sd,
    		struct tvp514x_decoder *decoder)
    	int err;
    	/* common register initialization */
    	err =
    	    tvp514x_write_regs(sd, decoder->tvp514x_regs);
    	if (err)
    		return err;
    	if (debug)
    		tvp514x_reg_dump(sd);
    	return 0;
     * tvp514x_detect() - Detect if an tvp514x is present, and if so which revision.
     * @sd: pointer to standard V4L2 sub-device structure
     * @decoder: pointer to tvp514x_decoder structure
     * A device is considered to be detected if the chip ID (LSB and MSB)
     * registers match the expected values.
     * Any value of the rom version register is accepted.
     * Returns ENODEV error number if no device is detected, or zero
     * if a device is detected.
    static int tvp514x_detect(struct v4l2_subdev *sd,
    	u8 chip_id_msb, chip_id_lsb, rom_ver;
    	chip_id_msb = tvp514x_read_reg(sd, REG_CHIP_ID_MSB);
    	chip_id_lsb = tvp514x_read_reg(sd, REG_CHIP_ID_LSB);
    	rom_ver = tvp514x_read_reg(sd, REG_ROM_VERSION);
    	v4l2_dbg(1, debug, sd,
    		 "chip id detected msb:0x%x lsb:0x%x rom version:0x%x\n",
    		 chip_id_msb, chip_id_lsb, rom_ver);
    	if ((chip_id_msb != TVP514X_CHIP_ID_MSB)
    		|| ((chip_id_lsb != TVP5146_CHIP_ID_LSB)
    		&& (chip_id_lsb != TVP5147_CHIP_ID_LSB))) {
    		/* We didn't read the values we expected, so this must not be
    		 * an TVP5146/47.
    		v4l2_err(sd, "chip id mismatch msb:0x%x lsb:0x%x\n",
    				chip_id_msb, chip_id_lsb);
    		return -ENODEV;
    	decoder->ver = rom_ver;
    	v4l2_info(sd, "%s (Version - 0x%.2x) found at 0x%x (%s)\n",
    			client->name, decoder->ver,
    			client->addr << 1, client->adapter->name);
    	return 0;
     * tvp514x_querystd() - V4L2 decoder interface handler for querystd
     * @std_id: standard V4L2 std_id ioctl enum
     * Returns the current standard detected by TVP5146/47. If no active input is
     * detected, returns -EINVAL
    static int tvp514x_querystd(struct v4l2_subdev *sd, v4l2_std_id *std_id)
    	struct tvp514x_decoder *decoder = to_decoder(sd);
    	enum tvp514x_input input_sel;
    	u8 sync_lock_status, lock_mask;
    	int err;
    	if (std_id == NULL)
    		return -EINVAL;
    	err = tvp514x_write_reg(sd, REG_VIDEO_STD,
    			VIDEO_STD_AUTO_SWITCH_BIT);
    	if (err < 0)
    		return err;
    	msleep(LOCK_RETRY_DELAY);
    	/* get the current standard */
    	current_std = tvp514x_get_current_std(sd);
    	if (current_std == STD_INVALID)
    		return -EINVAL;
    	input_sel = decoder->input;
    	switch (input_sel) {
    	case INPUT_CVBS_VI1B:
    	case INPUT_CVBS_VI1C:
    	case INPUT_CVBS_VI2B:
    	case INPUT_CVBS_VI2C:
    	case INPUT_CVBS_VI3B:
    	case INPUT_CVBS_VI3C:
    		lock_mask = STATUS_CLR_SUBCAR_LOCK_BIT |
    			STATUS_HORZ_SYNC_LOCK_BIT |
    			STATUS_VIRT_SYNC_LOCK_BIT;
    		break;
    	case INPUT_SVIDEO_VI2A_VI1A:
    	case INPUT_SVIDEO_VI2B_VI1B:
    	case INPUT_SVIDEO_VI2C_VI1C:
    	case INPUT_SVIDEO_VI2A_VI3A:
    	case INPUT_SVIDEO_VI2B_VI3B:
    	case INPUT_SVIDEO_VI2C_VI3C:
    	case INPUT_SVIDEO_VI4A_VI1A:
    	case INPUT_SVIDEO_VI4A_VI1B:
    	case INPUT_SVIDEO_VI4A_VI1C:
    	case INPUT_SVIDEO_VI4A_VI3A:
    	case INPUT_SVIDEO_VI4A_VI3B:
    	case INPUT_SVIDEO_VI4A_VI3C:
    		lock_mask = STATUS_HORZ_SYNC_LOCK_BIT |
    		break;
    		/*Need to add other interfaces*/
    	default:
    		return -EINVAL;
    	/* check whether signal is locked */
    	sync_lock_status = tvp514x_read_reg(sd, REG_STATUS1);
    	if (lock_mask != (sync_lock_status & lock_mask))
    		return -EINVAL;	/* No input detected */
    	decoder->current_std = current_std;
    	*std_id = decoder->std_list[current_std].standard.id;
    	v4l2_dbg(1, debug, sd, "Current STD: %s",
    			decoder->std_list[current_std].standard.name);
    	return 0;
     * tvp514x_s_std() - V4L2 decoder interface handler for s_std
     * @std_id: standard V4L2 v4l2_std_id ioctl enum
     * If std_id is supported, sets the requested standard. Otherwise, returns
     * -EINVAL
    static int tvp514x_s_std(struct v4l2_subdev *sd, v4l2_std_id std_id)
    	int err, i;
    	for (i = 0; i < decoder->num_stds; i++)
    		if (std_id & decoder->std_list[i].standard.id)
    			break;
    	if ((i == decoder->num_stds) || (i == STD_INVALID))
    		return -EINVAL;
    				decoder->std_list[i].video_std);
    	if (err)
    		return err;
    	decoder->current_std = i;
    	decoder->tvp514x_regs[REG_VIDEO_STD].val =
    		decoder->std_list[i].video_std;
    	v4l2_dbg(1, debug, sd, "Standard set to: %s",
    			decoder->std_list[i].standard.name);
    	return 0;
     * tvp514x_s_routing() - V4L2 decoder interface handler for s_routing
     * @input: input selector for routing the signal
     * @output: output selector for routing the signal
     * @config: config value. Not used
     * If index is valid, selects the requested input. Otherwise, returns -EINVAL if
     * the input is not supported or there is no active signal present in the
     * selected input.
    static int tvp514x_s_routing(struct v4l2_subdev *sd,
    				u32 input, u32 output, u32 config)
    	int err;
    	enum tvp514x_output output_sel;
    	enum tvp514x_std current_std = STD_INVALID;
    	int try_count = LOCK_RETRY_COUNT;
    	if ((input >= INPUT_INVALID) ||
    			(output >= OUTPUT_INVALID))
    		/* Index out of bound */
    		return -EINVAL;
    	 * For the sequence streamon -> streamoff and again s_input, most of
    	 * the time it fails to lock the signal, since streamoff puts TVP514x
    	 * into power off state which leads to failure in sub-sequent s_input.
    	tvp514x_s_stream(sd, 1);
    	input_sel = input;
    	output_sel = output;
    	err = tvp514x_write_reg(sd, REG_INPUT_SEL, input_sel);
    	if (err)
    		return err;
    	output_sel |= tvp514x_read_reg(sd,
    			REG_OUTPUT_FORMATTER1) & 0x7;
    	err = tvp514x_write_reg(sd, REG_OUTPUT_FORMATTER1,
    			output_sel);
    	if (err)
    		return err;
    	decoder->tvp514x_regs[REG_INPUT_SEL].val = input_sel;
    	decoder->tvp514x_regs[REG_OUTPUT_FORMATTER1].val = output_sel;
    	/* Clear status */
    	err =
    	    tvp514x_write_reg(sd, REG_CLEAR_LOST_LOCK, 0x01);
    	if (err)
    		return err;
    		break;
    		break;
    	/* Need to add other interfaces*/
    	default:
    		return -EINVAL;
    	while (try_count-- > 0) {
    		/* Allow decoder to sync up with new input */
    		/* get the current standard for future reference */
    			continue;
    				REG_STATUS1);
    		if (lock_mask == (sync_lock_status & lock_mask))
    			/* Input detected */
    			break;
    	if ((current_std == STD_INVALID) || (try_count < 0))
    		return -EINVAL;
    	decoder->input = input;
    	decoder->output = output;
    	v4l2_dbg(1, debug, sd, "Input set to: %d, std : %d",
    			input_sel, current_std);
    	return 0;
     * tvp514x_queryctrl() - V4L2 decoder interface handler for queryctrl
     * @qctrl: standard V4L2 v4l2_queryctrl structure
     * If the requested control is supported, returns the control information.
     * Otherwise, returns -EINVAL if the control is not supported.
    static int
    tvp514x_queryctrl(struct v4l2_subdev *sd, struct v4l2_queryctrl *qctrl)
    	int err = -EINVAL;
    	if (qctrl == NULL)
    		return err;
    	switch (qctrl->id) {
    	case V4L2_CID_BRIGHTNESS:
    		/* Brightness supported is (0-255), */
    		err = v4l2_ctrl_query_fill(qctrl, 0, 255, 1, 128);
    		break;
    	case V4L2_CID_CONTRAST:
    	case V4L2_CID_SATURATION:
    		 * Saturation and Contrast supported is -
    		 *	Contrast: 0 - 255 (Default - 128)
    		 *	Saturation: 0 - 255 (Default - 128)
    		break;
    	case V4L2_CID_HUE:
    		/* Hue Supported is -
    		 *	Hue - -180 - +180 (Default - 0, Step - +180)
    		err = v4l2_ctrl_query_fill(qctrl, -180, 180, 180, 0);
    		break;
    	case V4L2_CID_AUTOGAIN:
    		 * Auto Gain supported is -
    		 * 	0 - 1 (Default - 1)
    		err = v4l2_ctrl_query_fill(qctrl, 0, 1, 1, 1);
    		break;
    	default:
    		v4l2_err(sd, "invalid control id %d\n", qctrl->id);
    		return err;
    	v4l2_dbg(1, debug, sd, "Query Control:%s: Min - %d, Max - %d, Def - %d",
    			qctrl->name, qctrl->minimum, qctrl->maximum,
    			qctrl->default_value);
    	return err;
     * tvp514x_g_ctrl() - V4L2 decoder interface handler for g_ctrl
     * @ctrl: pointer to v4l2_control structure
     * If the requested control is supported, returns the control's current
     * value from the decoder. Otherwise, returns -EINVAL if the control is not
     * supported.
    static int
    tvp514x_g_ctrl(struct v4l2_subdev *sd, struct v4l2_control *ctrl)
    	if (ctrl == NULL)
    		return -EINVAL;
    	switch (ctrl->id) {
    		ctrl->value = decoder->tvp514x_regs[REG_BRIGHTNESS].val;
    		break;
    		ctrl->value = decoder->tvp514x_regs[REG_CONTRAST].val;
    		break;
    		ctrl->value = decoder->tvp514x_regs[REG_SATURATION].val;
    		break;
    	case V4L2_CID_HUE:
    		ctrl->value = decoder->tvp514x_regs[REG_HUE].val;
    		if (ctrl->value == 0x7F)
    			ctrl->value = 180;
    		else if (ctrl->value == 0x80)
    			ctrl->value = -180;
    		else
    			ctrl->value = 0;
    		break;
    		ctrl->value = decoder->tvp514x_regs[REG_AFE_GAIN_CTRL].val;
    		if ((ctrl->value & 0x3) == 3)
    			ctrl->value = 1;
    		else
    			ctrl->value = 0;
    		break;
    	default:
    		v4l2_err(sd, "invalid control id %d\n", ctrl->id);
    		return -EINVAL;
    	v4l2_dbg(1, debug, sd, "Get Control: ID - %d - %d",
    			ctrl->id, ctrl->value);
    	return 0;
     * tvp514x_s_ctrl() - V4L2 decoder interface handler for s_ctrl
     * If the requested control is supported, sets the control's current
     * value in HW. Otherwise, returns -EINVAL if the control is not supported.
    static int
    tvp514x_s_ctrl(struct v4l2_subdev *sd, struct v4l2_control *ctrl)
    	int err = -EINVAL, value;
    	if (ctrl == NULL)
    		return err;
    	value = ctrl->value;
    	switch (ctrl->id) {
    		if (ctrl->value < 0 || ctrl->value > 255) {
    			v4l2_err(sd, "invalid brightness setting %d\n",
    					ctrl->value);
    			return -ERANGE;
    		err = tvp514x_write_reg(sd, REG_BRIGHTNESS,
    				value);
    		if (err)
    			return err;
    		decoder->tvp514x_regs[REG_BRIGHTNESS].val = value;
    		break;
    			v4l2_err(sd, "invalid contrast setting %d\n",
    					ctrl->value);
    			return -ERANGE;
    		err = tvp514x_write_reg(sd, REG_CONTRAST, value);
    		if (err)
    			return err;
    		decoder->tvp514x_regs[REG_CONTRAST].val = value;
    		break;
    			v4l2_err(sd, "invalid saturation setting %d\n",
    					ctrl->value);
    			return -ERANGE;
    		err = tvp514x_write_reg(sd, REG_SATURATION, value);
    		if (err)
    			return err;
    		decoder->tvp514x_regs[REG_SATURATION].val = value;
    		break;
    	case V4L2_CID_HUE:
    		if (value == 180)
    			value = 0x7F;
    		else if (value == -180)
    			value = 0x80;
    		else if (value == 0)
    			value = 0;
    		else {
    			v4l2_err(sd, "invalid hue setting %d\n", ctrl->value);
    			return -ERANGE;
    		err = tvp514x_write_reg(sd, REG_HUE, value);
    		if (err)
    			return err;
    		decoder->tvp514x_regs[REG_HUE].val = value;
    		break;
    		if (value == 1)
    			value = 0x0F;
    			value = 0x0C;
    		else {
    			v4l2_err(sd, "invalid auto gain setting %d\n",
    					ctrl->value);
    			return -ERANGE;
    		err = tvp514x_write_reg(sd, REG_AFE_GAIN_CTRL, value);
    		if (err)
    			return err;
    		decoder->tvp514x_regs[REG_AFE_GAIN_CTRL].val = value;
    		break;
    	default:
    		return err;
    	v4l2_dbg(1, debug, sd, "Set Control: ID - %d - %d",
    	return err;
     * tvp514x_enum_fmt_cap() - V4L2 decoder interface handler for enum_fmt
     * @fmt: standard V4L2 VIDIOC_ENUM_FMT ioctl structure
     * Implement the VIDIOC_ENUM_FMT ioctl to enumerate supported formats
    static int
    tvp514x_enum_fmt_cap(struct v4l2_subdev *sd, struct v4l2_fmtdesc *fmt)
    	int index;
    	if (fmt == NULL)
    		return -EINVAL;
    	index = fmt->index;
    	if ((index >= decoder->num_fmts) || (index < 0))
    		return -EINVAL;
    	if (fmt->type != V4L2_BUF_TYPE_VIDEO_CAPTURE)
    		/* only capture is supported */
    		return -EINVAL;
    	memcpy(fmt, &decoder->fmt_list[index],
    		sizeof(struct v4l2_fmtdesc));
    	v4l2_dbg(1, debug, sd, "Current FMT: index - %d (%s)",
    			decoder->fmt_list[index].index,
    			decoder->fmt_list[index].description);
    	return 0;
     * tvp514x_try_fmt_cap() - V4L2 decoder interface handler for try_fmt
     * @f: pointer to standard V4L2 VIDIOC_TRY_FMT ioctl structure
     * Implement the VIDIOC_TRY_FMT ioctl for the CAPTURE buffer type. This
     * ioctl is used to negotiate the image capture size and pixel format
     * without actually making it take effect.
    static int
    tvp514x_try_fmt_cap(struct v4l2_subdev *sd, struct v4l2_format *f)
    	int ifmt;
    	struct v4l2_pix_format *pix;
    	if (f == NULL)
    		return -EINVAL;
    	if (f->type != V4L2_BUF_TYPE_VIDEO_CAPTURE)
    		f->type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    	pix = &f->fmt.pix;
    	/* Calculate height and width based on current standard */
    		return -EINVAL;
    	pix->width = decoder->std_list[current_std].width;
    	pix->height = decoder->std_list[current_std].height;
    	for (ifmt = 0; ifmt < decoder->num_fmts; ifmt++) {
    		if (pix->pixelformat ==
    			decoder->fmt_list[ifmt].pixelformat)
    			break;
    	if (ifmt == decoder->num_fmts)
    		/* None of the format matched, select default */
    		ifmt = 0;
    	pix->pixelformat = decoder->fmt_list[ifmt].pixelformat;
    	pix->field = V4L2_FIELD_INTERLACED;
    	pix->bytesperline = pix->width * 2;
    	pix->sizeimage = pix->bytesperline * pix->height;
    	pix->colorspace = V4L2_COLORSPACE_SMPTE170M;
    	pix->priv = 0;
    	v4l2_dbg(1, debug, sd, "Try FMT: pixelformat - %s, bytesperline - %d"
    			"Width - %d, Height - %d",
    			decoder->fmt_list[ifmt].description, pix->bytesperline,
    			pix->width, pix->height);
    	return 0;
     * tvp514x_s_fmt_cap() - V4L2 decoder interface handler for s_fmt
     * @f: pointer to standard V4L2 VIDIOC_S_FMT ioctl structure
     * If the requested format is supported, configures the HW to use that
     * format, returns error code if format not supported or HW can't be
     * correctly configured.
    static int
    tvp514x_s_fmt_cap(struct v4l2_subdev *sd, struct v4l2_format *f)
    	int rval;
    	if (f == NULL)
    		return -EINVAL;
    		return -EINVAL;
    	pix = &f->fmt.pix;
    	rval = tvp514x_try_fmt_cap(sd, f);
    	if (rval)
    		return rval;
    		decoder->pix = *pix;
    	return rval;
     * tvp514x_g_fmt_cap() - V4L2 decoder interface handler for tvp514x_g_fmt_cap
     * @f: pointer to standard V4L2 v4l2_format structure
     * Returns the decoder's current pixel format in the v4l2_format
     * parameter.
    static int
    tvp514x_g_fmt_cap(struct v4l2_subdev *sd, struct v4l2_format *f)
    	if (f == NULL)
    		return -EINVAL;
    		return -EINVAL;
    	f->fmt.pix = decoder->pix;
    	v4l2_dbg(1, debug, sd, "Current FMT: bytesperline - %d"
    			decoder->pix.bytesperline,
    			decoder->pix.width, decoder->pix.height);
    	return 0;
     * tvp514x_g_parm() - V4L2 decoder interface handler for g_parm
     * @a: pointer to standard V4L2 VIDIOC_G_PARM ioctl structure
     * Returns the decoder's video CAPTURE parameters.
    static int
    tvp514x_g_parm(struct v4l2_subdev *sd, struct v4l2_streamparm *a)
    	struct v4l2_captureparm *cparm;
    	if (a == NULL)
    		return -EINVAL;
    		return -EINVAL;
    	memset(a, 0, sizeof(*a));
    	a->type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    		return -EINVAL;
    	cparm = &a->parm.capture;
    	cparm->capability = V4L2_CAP_TIMEPERFRAME;
    	cparm->timeperframe =
    		decoder->std_list[current_std].standard.frameperiod;
    	return 0;
     * tvp514x_s_parm() - V4L2 decoder interface handler for s_parm
     * @a: pointer to standard V4L2 VIDIOC_S_PARM ioctl structure
     * Configures the decoder to use the input parameters, if possible. If
     * not possible, returns the appropriate error code.
    static int
    tvp514x_s_parm(struct v4l2_subdev *sd, struct v4l2_streamparm *a)
    	struct v4l2_fract *timeperframe;
    	if (a == NULL)
    		return -EINVAL;
    		return -EINVAL;
    	timeperframe = &a->parm.capture.timeperframe;
    		return -EINVAL;
    	*timeperframe =
    	return 0;
     * tvp514x_s_stream() - V4L2 decoder i/f handler for s_stream
     * @enable: streaming enable or disable
     * Sets streaming to enable or disable, if possible.
    	int err = 0;
    	if (decoder->streaming == enable)
    		return 0;
    	switch (enable) {
    	case 0:
    		/* Power Down Sequence */
    		err = tvp514x_write_reg(sd, REG_OPERATION_MODE, 0x01);
    		if (err) {
    			v4l2_err(sd, "Unable to turn off decoder\n");
    			return err;
    		decoder->streaming = enable;
    		break;
    	case 1:
    		struct tvp514x_reg *int_seq = (struct tvp514x_reg *)
    				client->driver->id_table->driver_data;
    		/* Power Up Sequence */
    		err = tvp514x_write_regs(sd, int_seq);
    		if (err) {
    			v4l2_err(sd, "Unable to turn on decoder\n");
    			return err;
    		/* Detect if not already detected */
    		err = tvp514x_detect(sd, decoder);
    		if (err) {
    			v4l2_err(sd, "Unable to detect decoder\n");
    			return err;
    		err = tvp514x_configure(sd, decoder);
    		if (err) {
    			v4l2_err(sd, "Unable to configure decoder\n");
    			return err;
    		break;
    	default:
    		err = -ENODEV;
    		break;
    	return err;
    static const struct v4l2_subdev_core_ops tvp514x_core_ops = {
    	.queryctrl = tvp514x_queryctrl,
    	.g_ctrl = tvp514x_g_ctrl,
    	.s_ctrl = tvp514x_s_ctrl,
    	.s_std = tvp514x_s_std,
    static const struct v4l2_subdev_video_ops tvp514x_video_ops = {
    	.s_routing = tvp514x_s_routing,
    	.querystd = tvp514x_querystd,
    	.enum_fmt = tvp514x_enum_fmt_cap,
    	.g_fmt = tvp514x_g_fmt_cap,
    	.try_fmt = tvp514x_try_fmt_cap,
    	.s_fmt = tvp514x_s_fmt_cap,
    	.g_parm = tvp514x_g_parm,
    	.s_parm = tvp514x_s_parm,
    	.s_stream = tvp514x_s_stream,
    static const struct v4l2_subdev_ops tvp514x_ops = {
    	.core = &tvp514x_core_ops,
    	.video = &tvp514x_video_ops,
    static struct tvp514x_decoder tvp514x_dev = {
    	.streaming = 0,
    	.fmt_list = tvp514x_fmt_list,
    	.num_fmts = ARRAY_SIZE(tvp514x_fmt_list),
    	.pix = {
    		/* Default to NTSC 8-bit YUV 422 */
    		.field = V4L2_FIELD_INTERLACED,
    		.bytesperline = NTSC_NUM_ACTIVE_PIXELS * 2,
    		.sizeimage =
    		NTSC_NUM_ACTIVE_PIXELS * 2 * NTSC_NUM_ACTIVE_LINES,
    		.colorspace = V4L2_COLORSPACE_SMPTE170M,
    	.current_std = STD_NTSC_MJ,
    	.std_list = tvp514x_std_list,
    	.num_stds = ARRAY_SIZE(tvp514x_std_list),
     * tvp514x_probe() - decoder driver i2c probe handler
     * @client: i2c driver client device structure
     * @id: i2c driver id table
     * Register decoder as an i2c client device and V4L2
     * device.
    static int
    tvp514x_probe(struct i2c_client *client, const struct i2c_device_id *id)
    	struct tvp514x_decoder *decoder;
    	struct v4l2_subdev *sd;
    	/* Check if the adapter supports the needed features */
    	if (!i2c_check_functionality(client->adapter, I2C_FUNC_SMBUS_BYTE_DATA))
    		return -EIO;
    	if (!client->dev.platform_data) {
    		v4l2_err(client, "No platform data!!\n");
    		return -ENODEV;
    	decoder = kzalloc(sizeof(*decoder), GFP_KERNEL);
    	if (!decoder)
    		return -ENOMEM;
    	/* Initialize the tvp514x_decoder with default configuration */
    	*decoder = tvp514x_dev;
    	/* Copy default register configuration */
    	memcpy(decoder->tvp514x_regs, tvp514x_reg_list_default,
    			sizeof(tvp514x_reg_list_default));
    	/* Copy board specific information here */
    	decoder->pdata = client->dev.platform_data;
    	 * Fetch platform specific data, and configure the
    	 * tvp514x_reg_list[] accordingly. Since this is one
    	 * time configuration, no need to preserve.
    	decoder->tvp514x_regs[REG_OUTPUT_FORMATTER2].val |=
    		(decoder->pdata->clk_polarity << 1);
    	decoder->tvp514x_regs[REG_SYNC_CONTROL].val |=
    		((decoder->pdata->hs_polarity << 2) |
    		 (decoder->pdata->vs_polarity << 3));
    	/* Set default standard to auto */
    		VIDEO_STD_AUTO_SWITCH_BIT;
    	/* Register with V4L2 layer as slave device */
    	sd = &decoder->sd;
    	v4l2_i2c_subdev_init(sd, client, &tvp514x_ops);
    	v4l2_info(sd, "%s decoder driver registered !!\n", sd->name);
    	return 0;
     * tvp514x_remove() - decoder driver i2c remove handler
     * Unregister decoder as an i2c client device and V4L2
     * device. Complement of tvp514x_probe().
    static int tvp514x_remove(struct i2c_client *client)
    	struct v4l2_subdev *sd = i2c_get_clientdata(client);
    	v4l2_device_unregister_subdev(sd);
    	kfree(decoder);
    	return 0;
    /* TVP5146 Init/Power on Sequence */
    static const struct tvp514x_reg tvp5146_init_reg_seq[] = {
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS1, 0x02},
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS2, 0x00},
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS3, 0x80},
    	{TOK_WRITE, REG_VBUS_DATA_ACCESS_NO_VBUS_ADDR_INCR, 0x01},
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS1, 0x60},
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS3, 0xB0},
    	{TOK_WRITE, REG_VBUS_DATA_ACCESS_NO_VBUS_ADDR_INCR, 0x00},
    	{TOK_WRITE, REG_OPERATION_MODE, 0x01},
    	{TOK_TERM, 0, 0},
    /* TVP5147 Init/Power on Sequence */
    static const struct tvp514x_reg tvp5147_init_reg_seq[] =	{
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS1, 0x16},
    	{TOK_WRITE, REG_VBUS_ADDRESS_ACCESS3, 0xA0},
    	{TOK_WRITE, REG_VBUS_DATA_ACCESS_NO_VBUS_ADDR_INCR, 0x16},
    	{TOK_TERM, 0, 0},
    /* TVP5146M2/TVP5147M1 Init/Power on Sequence */
    static const struct tvp514x_reg tvp514xm_init_reg_seq[] = {
    	{TOK_TERM, 0, 0},
     * I2C Device Table -
     * name - Name of the actual device/chip.
     * driver_data - Driver data
    static const struct i2c_device_id tvp514x_id[] = {
    	{"tvp5146", (unsigned long)tvp5146_init_reg_seq},
    	{"tvp5146m2", (unsigned long)tvp514xm_init_reg_seq},
    	{"tvp5147", (unsigned long)tvp5147_init_reg_seq},
    	{"tvp5147m1", (unsigned long)tvp514xm_init_reg_seq},
    MODULE_DEVICE_TABLE(i2c, tvp514x_id);
    static struct i2c_driver tvp514x_driver = {
    	.driver = {
    		.name = TVP514X_MODULE_NAME,
    	.probe = tvp514x_probe,
    	.remove = tvp514x_remove,
    	.id_table = tvp514x_id,
    static int __init tvp514x_init(void)
    	return i2c_add_driver(&tvp514x_driver);
    static void __exit tvp514x_exit(void)
    	i2c_del_driver(&tvp514x_driver);
    module_init(tvp514x_init);
    module_exit(tvp514x_exit);
    So these files when cross compiled help in video capture?
