Dropbear issue with Linux SDK 03.00.00.04
Other Parts Discussed in Thread: AM3352, TPS65217
I am using ti-processor-sdk-linux-am335x-evm-03.00.00.04-Linux-x86-Install.bin
The systemd-sysv-generator is generating dropbear.service unit in /run/systemd/generator.late for sysV init script in /etc/init.d/dropbear. But this dropbear.service is not running during bootup.
when i see the status of dropbear.service(systemctl status dropbear.service) it giving bellow message.
● dropbear.service - LSB: Dropbear Secure Shell server
Loaded: loaded (/etc/init.d/dropbear; bad; vendor preset: enabled)
Active: inactive (dead)
Docs: man:systemd-sysv-generator(8)
The message during booting.
U-Boot SPL 2016.05-00230-g120a8a3-dirty (Sep 01 2016 - 18:57:01)
Trying to boot from MMC2
Card did not respond to voltage select!
*** Warning - MMC init failed, using default environment
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00230-g120a8a3-dirty (Sep 01 2016 - 18:57:01 +0530)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
SD/MMC found on device 1
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
3661576 bytes read in 254 ms (13.7 MiB/s)
** Bad device mmc 0 **
37020 bytes read in 38 ms (951.2 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x37df08 ]
Loading Device Tree to 8fff3000, end 8ffff09b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-g3639bea54a (venkatesh@venkatesh-VirtualBox) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 PREE6
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 24 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=e43a2f28-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 484024K/524288K available (7095K kernel code, 292K rwdata, 2444K rodata, 288K init, 263K bss, 15688K reserved, 24576K cm)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0959034 (9541 kB)
[ 0.000000] .init : 0xc095a000 - 0xc09a2000 ( 288 kB)
[ 0.000000] .data : 0xc09a2000 - 0xc09eb248 ( 293 kB)
[ 0.000000] .bss : 0xc09ed000 - 0xc0a2eed8 ( 264 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000032] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000041] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000376] clocksource_probe: no matching clocksources found
[ 0.000536] Console: colour dummy device 80x30
[ 0.000560] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000565] This ensures that you still see kernel messages. Please
[ 0.000569] update your kernel commandline.
[ 0.000585] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089244] pid_max: default: 32768 minimum: 301
[ 0.089357] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089366] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089965] Initializing cgroup subsys io
[ 0.089993] Initializing cgroup subsys memory
[ 0.090023] Initializing cgroup subsys devices
[ 0.090036] Initializing cgroup subsys freezer
[ 0.090049] Initializing cgroup subsys perf_event
[ 0.090059] Initializing cgroup subsys pids
[ 0.090083] CPU: Testing write buffer coherency: ok
[ 0.090434] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.092184] devtmpfs: initialized
[ 0.101029] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.113481] omap_hwmod: debugss: _wait_target_disable failed
[ 0.168172] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.170160] pinctrl core: initialized pinctrl subsystem
[ 0.171326] NET: Registered protocol family 16
[ 0.173133] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.199238] cpuidle: using governor ladder
[ 0.229226] cpuidle: using governor menu
[ 0.233106] OMAP GPIO hardware version 0.1
[ 0.241652] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.276397] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.279419] vgaarb: loaded
[ 0.279912] SCSI subsystem initialized
[ 0.280188] usbcore: registered new interface driver usbfs
[ 0.280250] usbcore: registered new interface driver hub
[ 0.280342] usbcore: registered new device driver usb
[ 0.280836] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring pe
[ 0.280885] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring pe
[ 0.280986] media: Linux media interface: v0.10
[ 0.281046] Linux video capture interface: v2.00
[ 0.281090] pps_core: LinuxPPS API ver. 1 registered
[ 0.281097] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.281122] PTP clock support registered
[ 0.281307] EDAC MC: Ver: 3.0.0
[ 0.282311] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.282573] Advanced Linux Sound Architecture Driver Initialized.
[ 0.283610] clocksource: Switched to clocksource timer1
[ 0.292834] NET: Registered protocol family 2
[ 0.293517] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293564] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293658] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.293729] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293757] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293900] NET: Registered protocol family 1
[ 0.294245] RPC: Registered named UNIX socket transport module.
[ 0.294258] RPC: Registered udp transport module.
[ 0.294264] RPC: Registered tcp transport module.
[ 0.294270] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.295129] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.296796] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.303932] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.304618] NFS: Registering the id_resolver key type
[ 0.304683] Key type id_resolver registered
[ 0.304690] Key type id_legacy registered
[ 0.304758] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.306473] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.306498] io scheduler noop registered
[ 0.306511] io scheduler deadline registered
[ 0.306653] io scheduler cfq registered (default)
[ 0.308001] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.361005] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.364786] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.995715] console [ttyS0] enabled
[ 1.000292] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 159, base_baud = 3000000) is a 8250
[ 1.010067] [drm] Initialized drm 1.1.0 20060810
[ 1.021663] loop: module loaded
[ 1.027099] libphy: Fixed MDIO Bus: probed
[ 1.093671] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.099808] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.106839] libphy: 4a101000.mdio: probed
[ 1.110881] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.120790] cpsw 4a100000.ethernet: Detected MACID = 68:9e:19:9a:51:11
[ 1.128318] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.135963] usbcore: registered new interface driver pegasus
[ 1.141714] usbcore: registered new interface driver asix
[ 1.147232] usbcore: registered new interface driver ax88179_178a
[ 1.153404] usbcore: registered new interface driver cdc_ether
[ 1.159372] usbcore: registered new interface driver smsc75xx
[ 1.165223] usbcore: registered new interface driver smsc95xx
[ 1.171037] usbcore: registered new interface driver net1080
[ 1.176778] usbcore: registered new interface driver cdc_subset
[ 1.182763] usbcore: registered new interface driver zaurus
[ 1.188469] usbcore: registered new interface driver cdc_ncm
[ 1.194827] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.201393] ehci-pci: EHCI PCI platform driver
[ 1.205944] ehci-platform: EHCI generic platform driver
[ 1.211351] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.216713] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.222952] ohci-pci: OHCI PCI platform driver
[ 1.227494] ohci-platform: OHCI generic platform driver
[ 1.233140] usbcore: registered new interface driver usb-storage
[ 1.239576] mousedev: PS/2 mouse device common for all mice
[ 1.246005] i2c /dev entries driver
[ 1.250773] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.257785] sdhci: Secure Digital Host Controller Interface driver
[ 1.264033] sdhci: Copyright(c) Pierre Ossman
[ 1.268883] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.393820] Synopsys Designware Multimedia Card Interface Driver
[ 1.399940] mmc1: MAN_BKOPS_EN bit is not set
[ 1.404772] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.411308] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.417751] usbcore: registered new interface driver usbhid
[ 1.423389] usbhid: USB HID core driver
[ 1.429327] mmc1: new high speed MMC card at address 0001
[ 1.435146] NET: Registered protocol family 10
[ 1.440759] mmcblk0: mmc1:0001 MMC04G 3.66 GiB
[ 1.446062] sit: IPv6 over IPv4 tunneling driver
[ 1.451389] NET: Registered protocol family 17
[ 1.456295] mmcblk0boot0: mmc1:0001 MMC04G partition 1 1.00 MiB
[ 1.462752] Key type dns_resolver registered
[ 1.467137] mmcblk0boot1: mmc1:0001 MMC04G partition 2 1.00 MiB
[ 1.474007] omap_voltage_late_init: Voltage driver support not added
[ 1.480518] mmcblk0: p1 p2
[ 1.484611] ThumbEE CPU extension supported.
[ 1.488929] Registering SWP/SWPB emulation handler
[ 1.500918] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 1.520844] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.528376] mmc2: new high speed SDIO card at address 0001
[ 1.539149] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.544780] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.551717] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.558750] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.565900] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.572958] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.580095] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.587102] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.597982] hctosys: unable to open rtc device (rtc0)
[ 1.606848] ALSA device list:
[ 1.609890] No soundcards found.
[ 3.378052] EXT4-fs (mmcblk0p2): recovery complete
[ 3.384112] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.392304] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.414426] devtmpfs: mounted
[ 3.418595] Freeing unused kernel memory: 288K (c095a000 - c09a2000)
[ 3.425061] This architecture does not have kernel memory protection.
[ 3.719487] systemd[1]: System time before build time, advancing clock.
[ 3.853040] random: systemd urandom read with 22 bits of entropy available
[ 3.879007] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRY)
[ 3.898180] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[ 3.925750] systemd[1]: Set hostname to <BlueHub-788C>.
[ 4.384303] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 4.682914] systemd[1]: basic.target: Found ordering cycle on basic.target/start
[ 4.690604] systemd[1]: basic.target: Found dependency on sockets.target/start
[ 4.697940] systemd[1]: basic.target: Found dependency on dropbear.socket/stop
[ 4.705283] systemd[1]: basic.target: Found dependency on sysinit.target/start
[ 4.712552] systemd[1]: basic.target: Found dependency on alignment.service/start
[ 4.720102] systemd[1]: basic.target: Found dependency on basic.target/start
[ 4.727208] systemd[1]: basic.target: Breaking ordering cycle by deleting job sockets.target/start
[ 4.736245] systemd[1]: sockets.target: Job sockets.target/start deleted to break ordering cycle starting with basic.target/start
[ SKIP ] Ordering cycle found, skipping Sockets
[ 4.774251] systemd[1]: alignment.service: Found ordering cycle on alignment.service/start
[ 4.782594] systemd[1]: alignment.service: Found dependency on sysinit.target/start
[ 4.790388] systemd[1]: alignment.service: Found dependency on alignment.service/start
[ 4.798401] systemd[1]: alignment.service: Breaking ordering cycle by deleting job alignment.service/start
[ 4.808153] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 4.849656] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.874087] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.896557] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.924000] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.955224] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.993993] systemd[1]: Starting Load Kernel Modules...
[ 5.028587] systemd[1]: Starting Setup Virtual Console...
[ 5.054199] cryptodev: driver 1.8 loaded.
[ 5.079327] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.145094] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.179710] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.191327] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 5.224754] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 5.254293] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 5.285413] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 5.314307] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.344234] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 5.393521] systemd[1]: Starting Journal Service...
[ 5.429269] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 5.495714] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.518854] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.579037] systemd[1]: Mounting Debug File System...
[ 5.634614] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 5.664142] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 5.689823] systemd[1]: Mounting Temporary Directory...
[ 5.724488] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.754193] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.799135] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 5.824290] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 5.854130] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 5.884755] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
Starting Create Static Device Nodes in /dev...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 7.287471] systemd-journald[87]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Found device /dev/ttyS0.
[ 9.532278] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 9.608872] 47401300.usb-phy supply vcc not found, using dummy regulator
[ OK ] Started Create Volatile Files and Directories.
[ 9.685656] 47401b00.usb-phy supply vcc not found, using dummy regulator
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ 9.790951] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 9.886272] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 9.952126] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 10.011809] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 10.090621] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 10.111947] remoteproc0: wkup_m3 is available
[ 10.191841] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ OK ] Started Network Time Synchronization.[ 10.201522] remoteproc0: Note: remoteproc is still under development and considered experimen.
[ 10.244910] remoteproc1: 4a334000.pru0 is available
[ 10.249921] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 10.318560] PM: Cannot get wkup_m3_ipc handle
[ 10.373322] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.433752] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.503426] PM: bootloader does not support rtc-only!
[ 10.508998] remoteproc0: powering up wkup_m3
[ 10.585925] remoteproc1: registered virtio0 (type 7)
[ 10.591089] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 10.603237] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 216252
[ 10.699104] remoteproc0: remote processor wkup_m3 is now up
[ 10.699131] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 10.714325] remoteproc2: 4a338000.pru1 is available
[ 10.813237] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 10.909324] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 11.045125] remoteproc2: registered virtio1 (type 7)
[ 11.050291] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ OK ] Found device /dev/ttyS3.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 11.958977] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Found device /dev/mmcblk0p1.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Basic System.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
Starting Telephony service...
Starting uim-sysfs.service...
[ OK ] Started System Logging Service.
[ OK ] Started Kernel Logging Service.
Starting Permit User Sessions...
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Starting Avahi mDNS/DNS-SD Stack...
Starting Login Service...
[ OK ] Listening on dropbear.socket.
Starting Start USB gadget...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ 14.120357] Bluetooth: Core ver 2.21
[ 14.167712] NET: Registered protocol family 31
[ 14.172202] Bluetooth: HCI device and connection manager initialized
Starting Network Service...
[ OK ] Started Permit User Sessions.
[ 14.283777] Bluetooth: HCI socket layer initialized
[ 14.288719] Bluetooth: L2CAP socket layer initialized
[ OK ] Started Start USB gadget.
[ 14.609698] net eth0: initializing cpsw version 1.12 (0)
[ 14.670025] net eth0: initialized cpsw ale version 1.4
[ OK ] Started Network Service.
[ 14.730581] net eth0: phy found : id is : 0x7c0f1
[ 14.782107] libphy: PHY 4a101000.mdio:01 not found
[ 14.843849] net eth0: phy "4a101000.mdio:01" not found on slave 1, err -19
[ 14.930812] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.964109] NET: Registered protocol family 15
[ 15.256728] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 15.262534] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[ 15.444739] hub 1-0:1.0: USB hub found
[ 15.515646] hub 1-0:1.0: 1 port detected
[ 15.669020] remoteproc1: powering up 4a334000.pru0
[ 15.734334] remoteproc1: Booting fw image am335x-pru0-fw, size 80252
[ 15.740920] ti-pruss 4a300000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
[ 15.887480] Initializing XFRM netlink socket
[ 15.944853] remoteproc1: remote processor 4a334000.pru0 is now up
[ 16.000024] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[ 16.009714] random: nonblocking pool is initialized
[ 16.016491] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 16.081804] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 16.121935] cfg80211: World regulatory domain updated:
[ 16.172613] remoteproc2: powering up 4a338000.pru1
[ 16.183826] cfg80211: DFS Master region: unset
[ 16.188229] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 16.198048] musb-hdrc musb-hdrc.2.auto: VBUS_ERROR in a_wait_vrise (80, <SessEnd), retry #3, port1 0008010c
[ 16.219836] remoteproc2: Booting fw image am335x-pru1-fw, size 80252
[ 16.280098] ti-pruss 4a300000.pruss: configured system_events = 0x0800000000000000 intr_channels = 0x00000002 host_intr = 0x00000002
[ 16.355942] remoteproc2: remote processor 4a338000.pru1 is now up
[ 16.380702] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 16.409838] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
[ 16.419445] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 16.459693] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 16.468579] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 16.543760] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 16.551827] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 16.567020] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
[ 16.618869] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
[ 16.696167] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 16.768545] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 16.823181] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 16.874489] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 16.965741] wlcore: loaded
[ 17.669053] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 17.837214] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 17.913789] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ OK ] Started uim-sysfs.service.
[ OK ] Started Login Service.
Mounting Configuration File System...
Starting rc.pvr.service...
Starting Load/Save RF Kill Switch Status...
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Mounted Configuration File System.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Network Name Resolution.
[ OK ] Started rc.pvr.service.
Starting LSB: Cron service...
Starting weston.service...
[ OK ] Started LSB: Cron service.
[ OK ] Started weston.service.
Starting busybox-udhcpd.service...
[ OK ] Started busybox-udhcpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting thermal-zone-init.service...
Starting parse-ip.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Started parse-ip.service.
Starting LSB: Vensi Bluetooth Gateway...
Starting gplv3-notice.service...
[ OK ] Started gplv3-notice.service.
[ OK ] Started LSB: Vensi Bluetooth Gateway.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org BlueHub-788C ttyS0
Arago 2016.05 BlueHub-788C ttyS0
  • Welcome to the TI E2E forum. I hope you will find many good answers here and in the TI.com documents and in the TI Wiki Pages (for processor issues). Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics (e2e.ti.com).
    Moved this thread over Sitara Forum for appropriate response. Thank you.
    Note: We strongly recommend you to create new e2e thread for your queries instead of following up on an old/closed e2e thread, new threads gets more attention than old threads and can provide link of old threads or information on the new post for clarity and faster response.
  • Hi.
    I am using AM3358BZCZ100 processor based hardware board and I flashed this board with new ti-processor-sdk-linux-am335x-evm-03.00.00.04-Linux-x86-Install.bin image.
    In this all the services are bringing up during bootup except dropbear. After analyze I under stand one thin this evm-03.00.00.04 is lanched with systemd support.
    Usually The systemd-sysv-generator is generating dropbear.service unit in /run/systemd/generator.late for sysV init script in /etc/init.d/dropbear. But this dropbear.service is not running during bootup.
    Message during bootup is below:-
    reading u-boot.img
    reading u-boot.img
    Watchdog enabled
    I2C: ready
    DRAM: 512 MiB
    Scanning mmc 1:1...
    reading boot.scr
    reading uEnv.txt
    3661576 bytes read in 235 ms (14.9 MiB/s)
    Starting kernel ...
    [ 0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [ 0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [ 0.000038] OMAP clocksource: timer1 at 24000000 Hz
    [ 0.000373] clocksource_probe: no matching clocksources found
    [ 0.000529] Console: colour dummy device 80x30
    [ 0.000554] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [ 0.000560] This ensures that you still see kernel messages. Please
    [ 0.000565] update your kernel commandline.
    [ 0.000580] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
    [ 0.089243] pid_max: default: 32768 minimum: 301
    [ 0.089361] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.089370] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.089968] Initializing cgroup subsys io
    [ 0.089997] Initializing cgroup subsys memory
    [ 0.090027] Initializing cgroup subsys devices
    [ 0.090040] Initializing cgroup subsys freezer
    [ 0.090052] Initializing cgroup subsys perf_event
    [ 0.090063] Initializing cgroup subsys pids
    [ 0.090087] CPU: Testing write buffer coherency: ok
    [ 0.090440] Setting up static identity map for 0x80008200 - 0x80008258
    [ 0.092191] devtmpfs: initialized
    [ 0.101040] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [ 0.113492] omap_hwmod: debugss: _wait_target_disable failed
    [ 0.168205] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.170206] pinctrl core: initialized pinctrl subsystem
    [ 0.171377] NET: Registered protocol family 16
    [ 0.173179] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.199237] cpuidle: using governor ladder
    [ 0.229223] cpuidle: using governor menu
    [ 0.233110] OMAP GPIO hardware version 0.1
    [ 0.241662] hw-breakpoint: debug architecture 0x4 unsupported.
    [ 0.276391] edma 49000000.edma: TI EDMA DMA engine driver
    [ 0.279432] vgaarb: loaded
    [ 0.279926] SCSI subsystem initialized
    [ 0.280189] usbcore: registered new interface driver usbfs
    [ 0.280343] usbcore: registered new device driver usb
    [ 0.280831] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring pe
    [ 0.280882] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring pe
    [ 0.280980] media: Linux media interface: v0.10
    [ 0.281038] Linux video capture interface: v2.00
    [ 0.281082] pps_core: LinuxPPS API ver. 1 registered
    [ 0.281089] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.281114] PTP clock support registered
    [ 0.281299] EDAC MC: Ver: 3.0.0
    [ 0.282295] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [ 0.282560] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.283592] clocksource: Switched to clocksource timer1
    [ 0.292807] NET: Registered protocol family 2
    [ 0.293487] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [ 0.293535] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
    [ 0.293572] TCP: Hash tables configured (established 4096 bind 4096)
    [ 0.293701] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.293729] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.293876] NET: Registered protocol family 1
    [ 0.294218] RPC: Registered named UNIX socket transport module.
    [ 0.294232] RPC: Registered udp transport module.
    [ 0.294237] RPC: Registered tcp transport module.
    [ 0.294243] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.295102] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
    [ 0.296774] futex hash table entries: 256 (order: -1, 3072 bytes)
    [ 0.303907] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.304603] NFS: Registering the id_resolver key type
    [ 0.304667] Key type id_resolver registered
    [ 0.304675] Key type id_legacy registered
    [ 0.304737] ntfs: driver 2.1.32 [Flags: R/O].
    [ 0.306440] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [ 0.306465] io scheduler noop registered
    [ 0.306476] io scheduler deadline registered
    [ 0.306623] io scheduler cfq registered (default)
    [ 0.307962] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
    [ 0.361068] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [ 0.364838] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
    [ 0.995754] console [ttyS0] enabled
    [ 1.000335] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 159, base_baud = 3000000) is a 8250
    [ 1.010102] [drm] Initialized drm 1.1.0 20060810
    [ 1.021685] loop: module loaded
    [ 1.027116] libphy: Fixed MDIO Bus: probed
    [ 1.093656] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
    [ 1.099793] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
    [ 1.106857] libphy: 4a101000.mdio: probed
    [ 1.110898] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
    [ 1.120807] cpsw 4a100000.ethernet: Detected MACID = 68:9e:19:9a:51:11
    [ 1.128332] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
    [ 1.135974] usbcore: registered new interface driver pegasus
    [ 1.141721] usbcore: registered new interface driver asix
    [ 1.147236] usbcore: registered new interface driver ax88179_178a
    [ 1.153406] usbcore: registered new interface driver cdc_ether
    [ 1.159373] usbcore: registered new interface driver smsc75xx
    [ 1.165222] usbcore: registered new interface driver smsc95xx
    [ 1.171035] usbcore: registered new interface driver net1080
    [ 1.176775] usbcore: registered new interface driver cdc_subset
    [ 1.182760] usbcore: registered new interface driver zaurus
    [ 1.188464] usbcore: registered new interface driver cdc_ncm
    [ 1.194817] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 1.201385] ehci-pci: EHCI PCI platform driver
    [ 1.205936] ehci-platform: EHCI generic platform driver
    [ 1.211345] ehci-omap: OMAP-EHCI Host Controller driver
    [ 1.216710] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [ 1.233148] usbcore: registered new interface driver usb-storage
    [ 1.239591] mousedev: PS/2 mouse device common for all mice
    [ 1.246015] i2c /dev entries driver
    [ 1.250781] cpuidle: enable-method property 'ti,am3352' found operations
    [ 1.257789] sdhci: Secure Digital Host Controller Interface driver
    [ 1.264038] sdhci: Copyright(c) Pierre Ossman
    [ 1.268889] omap_hsmmc 48060000.mmc: Got CD GPIO
    [ 1.393815] Synopsys Designware Multimedia Card Interface Driver
    [ 1.399941] mmc1: MAN_BKOPS_EN bit is not set
    [ 1.404778] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 1.411314] ledtrig-cpu: registered to indicate activity on CPUs
    [ 1.417760] usbcore: registered new interface driver usbhid
    [ 1.423397] usbhid: USB HID core driver
    [ 1.429251] mmc1: new high speed MMC card at address 0001
    [ 1.435162] NET: Registered protocol family 10
    [ 1.440747] mmcblk0: mmc1:0001 MMC04G 3.66 GiB
    [ 1.446040] sit: IPv6 over IPv4 tunneling driver
    [ 1.451362] NET: Registered protocol family 17
    [ 1.456257] mmcblk0boot0: mmc1:0001 MMC04G partition 1 1.00 MiB
    [ 1.462700] Key type dns_resolver registered
    [ 1.467086] mmcblk0boot1: mmc1:0001 MMC04G partition 2 1.00 MiB
    [ 1.473958] omap_voltage_late_init: Voltage driver support not added
    [ 1.480469] mmcblk0: p1 p2
    [ 1.484587] ThumbEE CPU extension supported.
    [ 1.488906] Registering SWP/SWPB emulation handler
    [ 1.500842] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
    [ 1.520741] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
    [ 1.528281] mmc2: new high speed SDIO card at address 0001
    [ 1.539040] tps65217 0-0024: TPS65217 ID 0xe version 1.2
    [ 1.544663] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [ 1.551600] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
    [ 1.558632] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [ 1.565780] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [ 1.572840] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [ 1.579977] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [ 1.586983] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
    [ 1.597852] hctosys: unable to open rtc device (rtc0)
    [ 1.606741] ALSA device list:
    [ 1.609770] No soundcards found.
    [ 3.170450] EXT4-fs (mmcblk0p2): recovery complete
    [ 3.176545] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 3.184755] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [ 3.195544] devtmpfs: mounted
    [ 3.198841] Freeing unused kernel memory: 288K (c095a000 - c09a2000)
    [ 3.205362] This architecture does not have kernel memory protection.
    [ 3.477214] systemd[1]: System time before build time, advancing clock.
    [ 3.616202] random: systemd urandom read with 25 bits of entropy available
    [ 3.671193] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRY)
    [ 3.690362] systemd[1]: Detected architecture arm.
    [ 3.736287] systemd[1]: Set hostname to <BlueHub-788C>.
    [ 4.179906] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
    [ 4.478571] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [ 4.486556] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [ 4.494403] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [ 4.501854] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [ 4.511334] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ 4.549913] systemd[1]: Reached target Swap.
    [ 4.574405] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 4.604512] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 4.634316] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ 4.680576] systemd[1]: Reached target Paths.quests to Console Directory Watch.
    [ 4.704343] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [ 4.733987] systemd[1]: Reached target Remote File Systems.
    [ 4.766224] systemd[1]: Created slice User and Session Slice.
    [ 4.794342] systemd[1]: Listening on udev Control Socket.
    [ 4.824585] systemd[1]: Listening on Network Service Netlink Socket.
    [ 4.855231] systemd[1]: Created slice System Slice.
    [ 4.885899] systemd[1]: Created slice system-getty.slice.
    [ 4.915706] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ 4.944076] systemd[1]: Reached target Slices.
    [ 4.964477] systemd[1]: Listening on Journal Socket.
    [ 4.999231] systemd[1]: Mounting POSIX Message Queue File System...
    [ 5.062479] systemd[1]: Starting Load Kernel Modules...
    [ 5.103305] cryptodev: driver 1.8 loaded.
    [ 5.119470] systemd[1]: Mounting Debug File System...
    [ 5.179200] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [ 5.239724] systemd[1]: Mounting Temporary Directory...
    [ 5.274504] systemd[1]: Listening on Syslog Socket.
    [ 5.308762] systemd[1]: Starting Journal Service...
    [ 5.351383] systemd[1]: Starting Remount Root and Kernel File Systems...
    [ 5.414399] systemd[1]: Listening on udev Kernel Socket.
    [ 5.458960] systemd[1]: Starting Setup Virtual Console...
    [ 5.466552] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [ 5.571583] systemd[1]: Mounted Debug File System.
    [ 5.604268] systemd[1]: Mounted POSIX Message Queue File System.
    [ 5.634114] systemd[1]: Mounted Temporary Directory.
    [ 5.664716] systemd[1]: Started Journal Service.
    [ 7.014552] systemd-journald[90]: Received request to flush runtime journal from PID 1
    [ 9.477189] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [ 9.633858] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
    [ 9.680478] 47401300.usb-phy supply vcc not found, using dummy regulator
    [ 9.735671] 47401b00.usb-phy supply vcc not found, using dummy regulator
    [ 10.109838] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
    [ 11.087998] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
    [ 11.254187] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
    [ 11.292143] remoteproc0: 4a334000.pru0 is available
    [ 11.374064] remoteproc0: Note: remoteproc is still under development and considered experimental.
    [ 11.383090] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 11.395633] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
    [ 11.515930] remoteproc1: wkup_m3 is available
    [ 11.520420] remoteproc1: Note: remoteproc is still under development and considered experimental.
    [ 11.622235] remoteproc0: registered virtio0 (type 7)
    [ 11.675285] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
    [ 11.694053] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
    [ 11.706256] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 11.744666] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
    [ 11.751772] remoteproc2: 4a338000.pru1 is available
    [ 11.778700] PM: Cannot get wkup_m3_ipc handle
    [ 11.828258] remoteproc2: Note: remoteproc is still under development and considered experimental.
    [ 11.855639] PM: bootloader does not support rtc-only!
    [ 11.860862] remoteproc1: powering up wkup_m3
    [ 11.911958] remoteproc1: Booting fw image am335x-pm-firmware.elf, size 216252
    [ 11.943753] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 11.974815] remoteproc1: remote processor wkup_m3 is now up
    [ 11.974838] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
    [ 12.065223] remoteproc2: registered virtio1 (type 7)
    [ 12.070392] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
    [ OK ] Reached target Sockets.
    [ 12.350323] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [ 13.349891] net eth0: initializing cpsw version 1.12 (0)
    [ 13.457145] net eth0: initialized cpsw ale version 1.4
    [ 13.568540] net eth0: phy found : id is : 0x7c0f1
    [ 13.573353] libphy: PHY 4a101000.mdio:01 not found
    [ 13.671103] Bluetooth: Core ver 2.21
    [ 13.753907] net eth0: phy "4a101000.mdio:01" not found on slave 1, err -19
    [ 13.779491] NET: Registered protocol family 31
    [ 13.853274] Bluetooth: HCI device and connection manager initialized
    [ 13.912115] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 13.938387] Bluetooth: HCI socket layer initialized
    [ 13.943325] Bluetooth: L2CAP socket layer initialized
    [ 14.337488] NET: Registered protocol family 15
    [ 15.021556] Initializing XFRM netlink socket
    [ 15.923695] random: nonblocking pool is initialized
    [ 17.515625] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
    [ 17.604538] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
    [ 17.694767] hub 1-0:1.0: USB hub found
    [ 17.741364] hub 1-0:1.0: 1 port detected
    [ 17.914361] remoteproc0: powering up 4a334000.pru0
    [ 17.919882] remoteproc0: Booting fw image am335x-pru0-fw, size 80252
    [ 18.011630] ti-pruss 4a300000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
    [ 18.153781] remoteproc0: remote processor 4a334000.pru0 is now up
    [ 18.198255] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
    [ 18.208029] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 18.247783] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [ 18.284530] remoteproc2: powering up 4a338000.pru1
    [ 18.290011] remoteproc2: Booting fw image am335x-pru1-fw, size 80252
    [ 18.367442] ti-pruss 4a300000.pruss: configured system_events = 0x0800000000000000 intr_channels = 0x00000002 host_intr = 0x00000002
    [ 18.401521] cfg80211: World regulatory domain updated:
    [ 18.424060] musb-hdrc musb-hdrc.2.auto: VBUS_ERROR in a_wait_vrise (80, <SessEnd), retry #3, port1 0008010c
    [ 18.451568] cfg80211: DFS Master region: unset
    [ 18.471181] remoteproc2: remote processor 4a338000.pru1 is now up
    [ 18.488951] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    [ 18.531358] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
    [ 18.538578] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 18.565193] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.573259] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.638798] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
    [ 18.684344] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [ 18.693278] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
    [ 18.702611] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.759681] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
    [ 18.819147] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
    [ 18.878879] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
    [ 18.923767] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.931834] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    [ 19.076492] wlcore: loaded
    [ 19.684101] wlcore: PHY firmware version: Rev 8.2.0.0.232
    [ 19.827159] wlcore: firmware booted (Rev 8.9.0.0.48)
    [ 19.871052] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [ 21.225529] using random self ethernet address
    [ 21.230022] using random host ethernet address
    [ 21.263991] using host ethernet address: 68:9E:19:9A:51:13
    [ 21.269413] using random self ethernet address
    [ 21.287121] using random host ethernet address
    [ 21.291627] using host ethernet address: 68:9E:19:9A:51:13
    [ 21.311526] usb0: HOST MAC 68:9e:19:9a:51:13
    [ 21.335200] usb0: MAC 6e:8c:47:8f:f6:3d
    [ 21.385034] Mass Storage Function, version: 2009/09/11
    [ 21.390224] LUN: removable file: (no medium)
    [ 21.414533] LUN: removable read only file: /dev/mmcblk0p1
    [ 21.419985] Number of LUNs=1
    [ 21.453248] g_multi gadget: Multifunction Composite Gadget
    [ 21.473822] g_multi gadget: g_multi ready
    [ 21.504236] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
    [ OK ] Found device /dev/ttyGS0.
    [ OK ] Started Serial Getty on ttyGS0.
    _____ _____ _ _
    |___| |___|
    Have you tried starting the service yourself, by adding a custom dropbear.service file in /lib/systemd/system/?
    Try creating a file containing something like:
     [Unit]
     Description=SSH Per-Connection Server
     Wants=dropbearkey.service
     After=syslog.target dropbearkey.service
     [Service]
     Environment="DROPBEAR_RSAKEY_DIR=/etc/dropbear"
     EnvironmentFile=-/etc/default/dropbear
     ExecStart=/etc/init.d/dropbear start
     ExecReload=/bin/kill -HUP $MAINPID
     StandardInput=socket
     KillMode=process
     [Install]
     WantedBy=multi-user.target
    Then run:
      systemctl disable dropbear.service
      systemctl daemon-reload
      systemctl enable daemon
    You could also refer to the following thread:
    Yordan
  • Hi Ti employee I tried in above senario. After that I start it.
    systemctl start dropbear.service. I am getting below message.
    Job for dropbear.service failed because a configured resource limit was exceeded.
    See "systemctl status dropbear.service" and "journalct -xe" for details.
    while i see the status(systemctl status dropbear.service).
    [[0;1;31m●[[0m dropbear.service - SSH Per-Connection Server
    Loaded: loaded (/lib/systemd/system/dropbear.service; enabled; vendor preset: enabled)
    Active: [[0;1;31mfailed[[0m (Result: resources)
    Jul 08 22:44:44 BlueHub-788C systemd[1]: [[0;1;31mdropbear.service: Got more than one socket.[[0m
    Jul 08 22:44:44 BlueHub-788C systemd[1]: [[0;1;39mdropbear.service: Failed to run 'start' task: Invalid argument[[0m
    Jul 08 22:44:44 BlueHub-788C systemd[1]: [[0;1;31mFailed to start SSH Per-Connection Server.[[0m
    Jul 08 22:44:44 BlueHub-788C systemd[1]: [[0;1;39mdropbear.service: Unit entered failed state.[[0m
    Jul 08 22:44:44 BlueHub-788C systemd[1]: [[0;1;39mdropbear.service: Failed with result 'resources'.[[0m
  • This is an old thread, but the SDK version hasn't changed since. I experienced this problem yesterday. I'm using TI Processor SDK 3.03.00.04 on Ubuntu Linux 16.04 LTS with a recent vintage Beagle Bone Black as target hardware.
    Upon running a fresh image created from the SDK, the dropbear daemon is not running and systemctl reports the service as dead. I also noticed there were no keys present in /etc/dropbear. Rebooting the bone resulted in no apparent change.
    To solve, I issued a manual 'systemctl start dropbear' via serial connection. Immediately ssh connections via usb0 started working, and of course an RSA key was now present in /etc/dropbear. dropbear now starts correctly on subsequent reboots.
    I didn't investigate why a manual start is any different than a start at boot. I'm guessing it has something to do with key generation in the start script.
