In TDA3x TRM, I found below info in DSS section. Shall the bold work change to blanking interval or horizontal and vertical blanking interval?
During the transmission of the video signal, the portion of the stream in-between active video data segments is known as the horizontal blanking interval.
In 9.2.4.13.4.1 DISPC BT Mode Blanking, it says blanking interval also includes the EAV and SAV codes. But due to above info, customer is not sure if there are SAV/EAV codes during vertical blanking period with BT656 output.
Would you pls help to confirm?
