C6742 pin connection clarification
The pin map for the ZWT of the C6742 package shows some pins (H1,H2,K1,K2,L3,M1) as VSS connections, but the table of pins does not show these pins.  Should they be connected?
  • Hi John
    These pins need to be tied to VSS as indicated in the pin map section 3.6.1.
    Thanks for pointing out that these pins don't seemed to be getting covered in the Terminal Function section. I will notify the datasheet owner to add this to a subsequent revision of the C6742 datasheet.
    Mukul
