Beagle Bone Green Wireless not waking up
Hi ,
We are working on trying to get Beagle Bone Green Wireless to wake up after putting it in Deep Sleep mode. For the past 5 days, we have had no luck in getting it to wake up.
I have attached the Log file here. Please let us know what is going wrong.
Girish
Last login: Thu Sep 29 16:10:34 UTC 2016 from 192.168.7.1 on pts/0
Linux beaglebone 4.4.9-ti-r25 #1 SMP Thu May 5 23:08:13 UTC 2016 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@beaglebone:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.9-ti-r25 (root@b3-jetson-tk1-2gb) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP Thu May 5 23:08:13 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x BeagleBone Green Wireless
[ 0.000000] cma: Reserved 24 MiB at 0x9e000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] free_area_init_node: node 0, pgdat c0c37b80, node_mem_map df96d000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] PERCPU: Embedded 13 pages/cpu @df923000 s24320 r8192 d20736 u53248
[ 0.000000] pcpu-alloc: s24320 r8192 d20736 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129408
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=UUID=c0e7ddb4-bd83-43f6-99a2-aad370ac417f ro rootfstype=ext4 rootwait coherent_pool=1M quiet cape_universal=enable
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 474076K/522240K available (7344K kernel code, 914K rwdata, 3704K rodata, 604K init, 907K bss, 23588K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
.text : 0xc0008000 - 0xc0ad2480 (11050 kB)
.init : 0xc0ad3000 - 0xc0b6a000 ( 604 kB)
.data : 0xc0b6a000 - 0xc0c4e818 ( 915 kB)
.bss : 0xc0c51000 - 0xc0d33de8 ( 908 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000028] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000040] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000225] Console: colour dummy device 80x30
[ 0.000249] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000256] This ensures that you still see kernel messages. Please
[ 0.000262] update your kernel commandline.
[ 0.000280] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.046936] pid_max: default: 32768 minimum: 301
[ 0.047066] Security Framework initialized
[ 0.047080] Yama: becoming mindful.
[ 0.047113] AppArmor: AppArmor disabled by boot time parameter
[ 0.047269] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047280] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.048057] Initializing cgroup subsys io
[ 0.048085] Initializing cgroup subsys memory
[ 0.048124] Initializing cgroup subsys devices
[ 0.048140] Initializing cgroup subsys freezer
[ 0.048156] Initializing cgroup subsys net_cls
[ 0.048170] Initializing cgroup subsys perf_event
[ 0.048183] Initializing cgroup subsys net_prio
[ 0.048198] Initializing cgroup subsys pids
[ 0.048256] CPU: Testing write buffer coherency: ok
[ 0.048305] ftrace: allocating 34073 entries in 67 pages
[ 0.133434] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.133555] Setting up static identity map for 0x80008240 - 0x8000828c
[ 0.136932] Brought up 1 CPUs
[ 0.136953] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.136961] CPU: All CPU(s) started in SVC mode.
[ 0.138375] devtmpfs: initialized
[ 0.157251] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.175312] omap_hwmod: debugss: _wait_target_disable failed
[ 0.228965] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.231129] xor: measuring software checksum speed
[ 0.270938] arm4regs : 1221.000 MB/sec
[ 0.310937] 8regs : 1094.000 MB/sec
[ 0.350935] 32regs : 1093.000 MB/sec
[ 0.390935] neon : 1754.000 MB/sec
[ 0.390943] xor: using function: neon (1754.000 MB/sec)
[ 0.391039] pinctrl core: initialized pinctrl subsystem
[ 0.392980] NET: Registered protocol family 16
[ 0.396493] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.397699] cpuidle: using governor ladder
[ 0.397719] cpuidle: using governor menu
[ 0.402708] OMAP GPIO hardware version 0.1
[ 0.414269] No ATAGs?
[ 0.414298] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.414837] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.414850] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.491030] raid6: int32x1 gen() 269 MB/s
[ 0.558963] raid6: int32x1 xor() 236 MB/s
[ 0.627048] raid6: int32x2 gen() 356 MB/s
[ 0.694969] raid6: int32x2 xor() 269 MB/s
[ 0.763022] raid6: int32x4 gen() 405 MB/s
[ 0.831037] raid6: int32x4 xor() 259 MB/s
[ 0.899081] raid6: int32x8 gen() 359 MB/s
[ 0.966940] raid6: int32x8 xor() 231 MB/s
[ 1.034951] raid6: neonx1 gen() 1460 MB/s
[ 1.102948] raid6: neonx1 xor() 846 MB/s
[ 1.170936] raid6: neonx2 gen() 1882 MB/s
[ 1.238941] raid6: neonx2 xor() 1169 MB/s
[ 1.306956] raid6: neonx4 gen() 1975 MB/s
[ 1.374938] raid6: neonx4 xor() 1203 MB/s
[ 1.442961] raid6: neonx8 gen() 1211 MB/s
[ 1.510971] raid6: neonx8 xor() 671 MB/s
[ 1.510979] raid6: using algorithm neonx4 gen() 1975 MB/s
[ 1.510985] raid6: .... xor() 1203 MB/s, rmw enabled
[ 1.510991] raid6: using intx1 recovery algorithm
[ 1.520046] edma 49000000.edma: TI EDMA DMA engine driver
[ 1.525096] SCSI subsystem initialized
[ 1.525491] libata version 3.00 loaded.
[ 1.525820] usbcore: registered new interface driver usbfs
[ 1.525888] usbcore: registered new interface driver hub
[ 1.525991] usbcore: registered new device driver usb
[ 1.526565] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 1.526609] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 1.526722] media: Linux media interface: v0.10
[ 1.526783] Linux video capture interface: v2.00
[ 1.526875] pps_core: LinuxPPS API ver. 1 registered
[ 1.526882] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.526909] PTP clock support registered
[ 1.527826] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 1.529115] NetLabel: Initializing
[ 1.529129] NetLabel: domain hash size = 128
[ 1.529135] NetLabel: protocols = UNLABELED CIPSOv4
[ 1.529192] NetLabel: unlabeled traffic allowed by default
[ 1.529570] clocksource: Switched to clocksource timer1
[ 1.635428] NET: Registered protocol family 2
[ 1.636176] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.636225] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.636284] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.636348] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.636369] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.636668] NET: Registered protocol family 1
[ 1.637213] RPC: Registered named UNIX socket transport module.
[ 1.637224] RPC: Registered udp transport module.
[ 1.637230] RPC: Registered tcp transport module.
[ 1.637236] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.637900] Unpacking initramfs...
[ 1.973325] Freeing initrd memory: 4652K (cfb75000 - d0000000)
[ 1.974048] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.976531] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 1.976643] audit: initializing netlink subsys (disabled)
[ 1.976715] audit: type=2000 audit(1.912:1): initialized
[ 1.986919] zbud: loaded
[ 1.987561] VFS: Disk quotas dquot_6.6.0
[ 1.987814] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.990525] NFS: Registering the id_resolver key type
[ 1.990587] Key type id_resolver registered
[ 1.990594] Key type id_legacy registered
[ 1.990619] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.990944] fuse init (API version 7.23)
[ 1.991560] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 1.999245] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.999481] io scheduler noop registered
[ 1.999495] io scheduler deadline registered
[ 1.999556] io scheduler cfq registered (default)
[ 2.000875] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 2.002533] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.003755] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 2.006917] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 2.014310] console [ttyS0] enabled
[ 2.015184] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 159, base_baud = 3000000) is a 8250
[ 2.016550] [drm] Initialized drm 1.1.0 20060810
[ 2.021008] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.021045] ehci-platform: EHCI generic platform driver
[ 2.021212] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.021795] usbcore: registered new interface driver usb-storage
[ 2.023406] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 2.025539] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 2.025659] musb-hdrc: MHDRC RTL version 2.0
[ 2.025667] musb-hdrc: setup fifo_mode 4
[ 2.025684] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 2.026841] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 2.028807] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 2.028821] musb-hdrc: MHDRC RTL version 2.0
[ 2.028827] musb-hdrc: setup fifo_mode 4
[ 2.028841] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 2.028973] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 2.029004] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 2.029264] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.029277] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.029286] usb usb1: Product: MUSB HDRC host driver
[ 2.029295] usb usb1: Manufacturer: Linux 4.4.9-ti-r25 musb-hcd
[ 2.029303] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 2.030181] hub 1-0:1.0: USB hub found
[ 2.030231] hub 1-0:1.0: 1 port detected
[ 2.039612] mousedev: PS/2 mouse device common for all mice
[ 2.042043] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 2.042831] i2c /dev entries driver
[ 2.044365] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.045111] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 2.143007] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.143687] usbcore: registered new interface driver usbhid
[ 2.143699] usbhid: USB HID core driver
[ 2.143971] ashmem: initialized
[ 2.144697] remoteproc0: wkup_m3 is available
[ 2.144709] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 2.144717] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.147853] NET: Registered protocol family 10
[ 2.149088] mip6: Mobile IPv6
[ 2.149111] NET: Registered protocol family 17
[ 2.149255] Key type dns_resolver registered
[ 2.149270] mpls_gso: MPLS GSO support
[ 2.149636] omap_voltage_late_init: Voltage driver support not added
[ 2.156144] mmc1: MAN_BKOPS_EN bit is not set
[ 2.157077] PM: Cannot get wkup_m3_ipc handle
[ 2.161655] ThumbEE CPU extension supported.
[ 2.161683] Registering SWP/SWPB emulation handler
[ 2.162858] registered taskstats version 1
[ 2.163033] zswap: loaded using pool lzo/zbud
[ 2.163943] mmc1: new high speed MMC card at address 0001
[ 2.167253] Btrfs loaded
[ 2.167615] mmcblk0: mmc1:0001 Q2J54A 3.64 GiB
[ 2.169862] mmcblk0boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[ 2.174164] mmcblk0boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[ 2.175782] mmcblk0: p1
[ 2.186122] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 2.200225] Key type encrypted registered
[ 2.203170] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 2.227364] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 2.228011] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.228061] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 2.229954] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.230431] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.230904] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.231340] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.231380] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 2.232539] remoteproc0: powering up wkup_m3
[ 2.232630] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 219735
[ 2.232896] remoteproc0: remote processor wkup_m3 is now up
[ 2.232917] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 2.238618] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,GW1A,BBGW16053959'
[ 2.238646] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 2.277622] bone_capemgr bone_capemgr: slot #0: No cape found
[ 2.301921] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.321591] bone_capemgr bone_capemgr: slot #1: No cape found
[ 2.365593] bone_capemgr bone_capemgr: slot #2: No cape found
[ 2.371404] mmc2: new high speed SDIO card at address 0001
[ 2.409575] bone_capemgr bone_capemgr: slot #3: No cape found
[ 2.415467] bone_capemgr bone_capemgr: initialized OK.
[ 2.417325] PM: bootloader does not support rtc-only!
[ 2.417888] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.417908] of_cfs_init
[ 2.418020] of_cfs_init: OK
[ 2.421747] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 2.423750] PM: Hibernation image not present or could not be loaded.
[ 2.425030] Freeing unused kernel memory: 604K (c0ad3000 - c0b6a000)
[ 2.550984] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 2.551005] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.551015] usb 1-1: Product: USB2.0 Hub
[ 2.552073] hub 1-1:1.0: USB hub found
[ 2.552394] hub 1-1:1.0: 4 ports detected
[ 2.623009] systemd-udevd[104]: starting version 215
[ 2.625279] random: systemd-udevd urandom read with 40 bits of entropy available
[ 8.389516] EXT4-fs (mmcblk0p1): INFO: recovery required on readonly filesystem
[ 8.389537] EXT4-fs (mmcblk0p1): write access will be enabled during recovery
[ 8.461857] EXT4-fs (mmcblk0p1): recovery complete
[ 8.462626] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.085264] systemd-udevd[196]: starting version 215
[ 10.517446] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro
[ 11.092086] systemd-journald[193]: Received request to flush runtime journal from PID 1
[ 11.105107] random: nonblocking pool is initialized
[ 14.427501] using random self ethernet address
[ 14.427526] using random host ethernet address
[ 14.427545] using host ethernet address: B0:D5:CC:77:8A:C8
[ 14.427555] using self ethernet address: B0:D5:CC:77:8A:C0
[ 14.476736] Mass Storage Function, version: 2009/09/11
[ 14.476761] LUN: removable file: (no medium)
[ 14.476972] LUN: removable file: /var/cache/doc-seeed-bbgw-getting-started/beaglebone-getting-started-2016-05-11.img
[ 14.476985] Number of LUNs=1
[ 14.486572] usb0: HOST MAC b0:d5:cc:77:8a:c8
[ 14.487695] usb0: MAC b0:d5:cc:77:8a:c0
[ 14.490344] g_multi gadget: Multifunction Composite Gadget
[ 14.490364] g_multi gadget: g_multi ready
[ 14.840043] g_multi gadget: high-speed config #1: Multifunction with RNDIS
[ 15.430810] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 16.869077] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 17.068281] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 17.106115] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 17.168388] remoteproc1: 4a334000.pru0 is available
[ 17.168413] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 17.168422] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 17.176421] remoteproc1: Direct firmware load for am335x-pru0-fw failed with error -2
[ 17.176455] remoteproc1: failed to load am335x-pru0-fw
[ 17.262358] pru-rproc 4a334000.pru0: booting the PRU core manually
[ 17.262387] remoteproc1: powering up 4a334000.pru0
[ 17.262463] remoteproc1: Direct firmware load for am335x-pru0-fw failed with error -2
[ 17.262478] remoteproc1: request_firmware failed: -2
[ 17.267691] pru-rproc 4a334000.pru0: rproc_boot failed
[ 17.715598] davinci_evm sound: wilink8_bt-hifi <-> 48038000.mcasp mapping ok
[ 17.748808] remoteproc1: releasing 4a334000.pru0
[ 17.748973] pru-rproc: probe of 4a334000.pru0 failed with error -2
[ 17.749285] remoteproc1: 4a338000.pru1 is available
[ 17.749297] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 17.749306] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 17.749698] remoteproc1: Direct firmware load for am335x-pru1-fw failed with error -2
[ 17.749719] remoteproc1: failed to load am335x-pru1-fw
[ 17.782442] pru-rproc 4a338000.pru1: booting the PRU core manually
[ 17.782473] remoteproc1: powering up 4a338000.pru1
[ 17.782541] remoteproc1: Direct firmware load for am335x-pru1-fw failed with error -2
[ 17.782555] remoteproc1: request_firmware failed: -2
[ 17.787769] pru-rproc 4a338000.pru1: rproc_boot failed
[ 18.149853] remoteproc1: releasing 4a338000.pru1
[ 18.150014] pru-rproc: probe of 4a338000.pru1 failed with error -2
[ 21.322619] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 21.500601] wlcore: loaded
[ 22.394753] wlcore: PHY firmware version: Rev 8.2.0.0.233
[ 22.763426] wlcore: firmware booted (Rev 8.9.0.1.55)
[ 23.091253] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.874803] Bluetooth: Core ver 2.21
[ 24.879671] NET: Registered protocol family 31
[ 24.879696] Bluetooth: HCI device and connection manager initialized
[ 24.879728] Bluetooth: HCI socket layer initialized
[ 24.879745] Bluetooth: L2CAP socket layer initialized
[ 24.879804] Bluetooth: SCO socket layer initialized
[ 24.918024] Bluetooth: HCI UART driver ver 2.3
[ 24.918053] Bluetooth: HCI UART protocol H4 registered
[ 24.918061] Bluetooth: HCI UART protocol BCSP registered
[ 24.918068] Bluetooth: HCI UART protocol LL registered
[ 24.918075] Bluetooth: HCI UART protocol ATH3K registered
[ 24.918082] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 24.923877] Bluetooth: HCI UART protocol BCM registered
[ 24.923896] Bluetooth: HCI UART protocol QCA registered
[ 25.293859] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.293885] Bluetooth: BNEP filters: protocol multicast
[ 25.293919] Bluetooth: BNEP socket layer initialized
root@beaglebone:~# cat /sys/kernel/debug/wakeup_sources
name active_count event_count wakeup_count expire_count active_since total_time max_time last_change prevent_suspend_time
wl18xx.2.auto 0 0 0 0 0 0 0 21309 0
47810000.mmc 0 0 0 0 0 0 0 2048 0
481d8000.mmc 0 0 0 0 0 0 0 2016 0
48060000.mmc 0 0 0 0 0 0 0 1983 0
44e3e000.rtc 0 0 0 0 0 0 0 1980 0
musb-hdrc.1.auto 0 0 0 0 0 0 0 1967 0
musb-hdrc.0.auto 0 0 0 0 0 0 0 1964 0
481a6000.serial 0 0 0 0 0 0 0 1953 0
44e09000.serial 0 0 0 0 0 0 0 1945 0
alarmtimer 0 0 0 0 0 0 0 1914 0
autosleep 0 0 0 0 0 0 0 168 0
deleted 0 0 0 0 0 0 0 0 0
root@beaglebone:~#
root
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] free_area_init_node: node 0, pgdat c0c37b80, node_mem_map df96d00 0
[ 0.000000] PERCPU: Embedded 13 pages/cpu @df923000 s24320 r8192 d20736 u5324 8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 129408
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=UUID=c0e7ddb4-bd 83-43f6-99a2-aad370ac417f ro rootfstype=ext4 rootwait coherent_pool=1M quiet cap e_universal=enable
[ 0.000000] Memory: 474076K/522240K available (7344K kernel code, 914K rwdata , 3704K rodata, 604K init, 907K bss, 23588K reserved, 24576K cma-reserved, 0K hi ghmem)
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts
[ 0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478 484971ns
[ 0.000028] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max _idle_ns: 79635851949 ns
[ 0.228965] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.414837] omap4_sram_init:Unable to allocate sram needed to handle errata I 688
[ 0.414850] omap4_sram_init:Unable to get sram pool needed to handle errata I 688
[ 1.526565] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wk up@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 1.526609] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wk up@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 1.526882] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 1.974048] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counter s available
[ 1.991560] SGI XFS with ACLs, security attributes, realtime, no debug enable d
[ 1.999245] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 49)
[ 2.029277] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.144709] remoteproc0: Note: remoteproc is still under development and con sidered experimental.
[ 2.144717] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backwar d compatibility isn't yet guaranteed.
[ 2.186122] omap_hsmmc 47810000.mmc: card claims to support voltages below de fined range
[ 2.203170] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c -0/0-0024/input/input0
[ 2.232630] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 21973 5
[ 2.238618] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,GW1A,BBGW16053959 '
[ 2.238646] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-bla ck - #slots=4
[ 2.417888] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:0 1 UTC (946684801)
[ 2.625279] random: systemd-udevd urandom read with 40 bits of entropy availa ble
[ 8.389516] EXT4-fs (mmcblk0p1): INFO: recovery required on readonly filesyst em
[ 8.462626] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. O pts: (null)
[ 14.476972] LUN: removable file: /var/cache/doc-seeed-bbgw-getting-started/be aglebone-getting-started-2016-05-11.img
[ 17.068281] ti-pruss 4a300000.pruss: creating PRU cores and other child platf orm devices
[ 17.168413] remoteproc1: Note: remoteproc is still under development and con sidered experimental.
[ 17.168422] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backwar d compatibility isn't yet guaranteed.
[ 17.749297] remoteproc1: Note: remoteproc is still under development and con sidered experimental.
[ 17.749306] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backwar d compatibility isn't yet guaranteed.
root@beaglebone:~# cat /sys/devices/platform/ocp/wakeup
cat: /sys/devices/platform/ocp/wakeup: No such file or directory
root@beaglebone:~# find / -name wake
^C
root@beaglebone:~# find / -name wake*
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_abort_count
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_active
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_total_time_ms
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_active_count
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_max_time_ms
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_count
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_last_time_ms
/sys/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18x x.2.auto/power/wakeup_expire_count
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_abort_count
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_active
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_total_time_ms
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_active_count
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_max_time_ms
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_count
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_last_time_ms
/sys/devices/platform/ocp/47810000.mmc/power/wakeup_expire_count
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_abort_count
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_active
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_total_time_ms
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_active_count
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_max_time_ms
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_count
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_last_time_ms
/sys/devices/platform/ocp/481d8000.mmc/power/wakeup_expire_count
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_prevent_sleep_t ime_ms
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_abort_count
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_active
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_total_time_ms
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_active_count
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_max_time_ms
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_count
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_last_time_ms
/sys/devices/platform/ocp/44e09000.serial/tty/ttyS0/power/wakeup_expire_count
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_abort_count
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_active
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_total_time_ms
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_active_count
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_max_time_ms
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_count
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_last_time_ms
/sys/devices/platform/ocp/44e09000.serial/power/wakeup_expire_count
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_prevent_sleep_t ime_ms
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_abort_count
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_active
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_total_time_ms
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_active_count
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_max_time_ms
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_count
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_last_time_ms
/sys/devices/platform/ocp/481a6000.serial/tty/ttyS3/power/wakeup_expire_count
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_abort_count
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_active
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_total_time_ms
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_active_count
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_max_time_ms
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_count
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_last_time_ms
/sys/devices/platform/ocp/481a6000.serial/power/wakeup_expire_count
/sys/devices/platform/ocp/44e3e000.rtc/rtc/rtc0/wakealarm
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_abort_count
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_active
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_total_time_ms
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_active_count
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_max_time_ms
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_count
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_last_time_ms
/sys/devices/platform/ocp/44e3e000.rtc/power/wakeup_expire_count
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_prevent_sle ep_time_ms
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_abort_count
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_active
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_total_time_ ms
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_active_coun t
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_max_time_ms
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_count
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_last_time_m s
/sys/devices/platform/ocp/47400000.usb/47401300.usb-phy/power/wakeup_expire_coun t
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_prevent_sle ep_time_ms
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_abort_count
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_active
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_total_time_ ms
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_active_coun t
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_max_time_ms
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_count
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_last_time_m s
/sys/devices/platform/ocp/47400000.usb/47401b00.usb-phy/power/wakeup_expire_coun t
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_abort_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_active
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_total_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_active_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_max_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_last_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/po wer/wakeup_expire_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_abort_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_active
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_total_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_active_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_max_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_last_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/power/ wakeup_expire_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_prevent_sleep_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_abort_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_active
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_total_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_active_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_max_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_count
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_last_time_ms
/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/power/wakeu p_expire_count
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_prevent_sleep_time_ms
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_abort_count
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_active
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_total_time_ms
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_active_count
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_max_time_ms
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_count
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_last_time_ms
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/power/wakeu p_expire_count
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_abort_count
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_active
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_total_time_ms
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_active_count
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_max_time_ms
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_count
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_last_time_ms
/sys/devices/platform/ocp/48060000.mmc/power/wakeup_expire_count
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_abort_count
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_active
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_total_time_ms
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_active_count
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_max_time_ms
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_count
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_last_time_ms
/sys/devices/platform/serial8250/tty/ttyS1/power/wakeup_expire_count
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_abort_count
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_active
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_total_time_ms
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_active_count
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_max_time_ms
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_count
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_last_time_ms
/sys/devices/platform/serial8250/tty/ttyS2/power/wakeup_expire_count
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_abort_count
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_active
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_total_time_ms
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_active_count
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_max_time_ms
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_count
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_last_time_ms
/sys/devices/platform/serial8250/tty/ttyS4/power/wakeup_expire_count
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_prevent_sleep_time_ms
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_abort_count
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_active
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_total_time_ms
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_active_count
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_max_time_ms
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_count
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_last_time_ms
/sys/devices/platform/serial8250/tty/ttyS5/power/wakeup_expire_count
/sys/power/wake_unlock
/sys/power/wakeup_count
/sys/power/wake_lock
/sys/kernel/debug/tracing/events/mac80211/wake_queue
/sys/kernel/debug/tracing/events/power/wakeup_source_activate
/sys/kernel/debug/tracing/events/power/wakeup_source_deactivate
/sys/kernel/debug/tracing/events/ftrace/wakeup
root@beaglebone:~# cat /proc/interrupts
CPU0
16: 59081 INTC 68 Level gp_timer
19: 1 INTC 78 Level wkup_m3_txev
20: 12026 INTC 12 Level 49000000.edma_ccint
22: 109 INTC 14 Level 49000000.edma_ccerrint
26: 700 INTC 96 Level 44e07000.gpio
33: 0 44e07000.gpio 6 Edge 48060000.mmc cd
54: 700 44e07000.gpio 27 Level wl18xx
59: 0 INTC 98 Level 4804c000.gpio
92: 0 INTC 32 Level 481ac000.gpio
125: 0 INTC 62 Level 481ae000.gpio
158: 26 INTC 72 Level 44e09000.serial
159: 1705 INTC 44 Level
160: 5742 INTC 70 Level 44e0b000.i2c
161: 39 INTC 30 Level 4819c000.i2c
162: 13 INTC 64 Level mmc0
163: 26209 INTC 28 Level mmc1
164: 7276 INTC 29 Level mmc2
166: 0 INTC 77 Level wkup_m3
172: 0 INTC 75 Level rtc0
173: 0 INTC 76 Level rtc0
174: 0 INTC 109 Level 53100000.sham
176: 0 INTC 80 Level 48038000.mcasp_tx
177: 0 INTC 81 Level 48038000.mcasp_rx
178: 1 INTC 111 Level 48310000.rng
180: 699088 INTC 18 Level musb-hdrc.0.auto
181: 69 INTC 19 Level musb-hdrc.1.auto
182: 0 INTC 17 Level 47400000.dma-controller
183: 1 INTC 7 Level tps65217
IPI0: 0 CPU wakeup interrupts
IPI1: 0 Timer broadcast interrupts
IPI2: 0 Rescheduling interrupts
IPI3: 0 Function call interrupts
IPI4: 0 Single function call interrupts
IPI5: 0 CPU stop interrupts
IPI6: 0 IRQ work interrupts
IPI7: 0 completion interrupts
Err: 0
root@beaglebone:~#
