Dear All,
Tried to boot kernel with New uImage & jffs2 file system by Flash Boot / tftp boot but , no luck. Please find the message thrown by EVM & Print env.
Can some one please suggest where the mistake is .. #########################T #################T #####################
done
Bytes transferred = 2318004 (235eb4 hex)
## Booting kernel from Legacy Image at 80000000 ...
Image Name: Linux-2.6.31-rc7-omap1
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2317940 Bytes = 2.2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux................................................................................................................................................. done, booting the kernel.
Linux version 2.6.31-rc7-omap1 (root@localhost.localdomain) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #18 Sat Apr 3 15:00:29 IST 2010
CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3517 EVM
Memory policy: ECC disabled, Data cache writeback
OMAP3517 ES1.0 (full speed SGX, IVA2)
SRAM: Mapped pa 0x40200000 to va 0xe3000000 size: 0x100000
Reserving 4194304 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: mem=256M console=ttyS2,115200n8 noinitrd root=/dev/mtdblock4 rw rootfstype=jffs2
PID hash table entries: 1024 (order: 10, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 250880KB available (4036K code, 373K data, 140K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:368
Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
IVA2 clocking rate: 0 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
OMAP clockevent source: GPTIMER1 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
NET: Registered protocol family 16
MUX: setup N5_3517_GPIO57_OUT (0xd80020ba): 0x0100 -> 0x0004
MUX: setup Y9_3430_USB1HS_PHY_STP (0xd80025d8): 0x0018 -> 0x0003
MUX: setup Y8_3430_USB1HS_PHY_CLK (0xd80025da): 0x0000 -> 0x0003
MUX: setup AA14_3430_USB1HS_PHY_DIR (0xd80025ec): 0x0100 -> 0x010b
MUX: setup AA11_3430_USB1HS_PHY_NXT (0xd80025ee): 0x0100 -> 0x010b
MUX: setup W13_3430_USB1HS_PHY_D0 (0xd80025dc): 0x0100 -> 0x010b
MUX: setup W12_3430_USB1HS_PHY_D1 (0xd80025de): 0x0100 -> 0x010b
MUX: setup W11_3430_USB1HS_PHY_D2 (0xd80025e0): 0x0108 -> 0x010b
MUX: setup Y11_3430_USB1HS_PHY_D3 (0xd80025ea): 0x0100 -> 0x010b
MUX: setup W9_3430_USB1HS_PHY_D4 (0xd80025e4): 0x0100 -> 0x010b
MUX: setup Y12_3430_USB1HS_PHY_D5 (0xd80025e6): 0x0100 -> 0x010b
MUX: setup W8_3430_USB1HS_PHY_D6 (0xd80025e8): 0x0100 -> 0x010b
MUX: setup Y13_3430_USB1HS_PHY_D7 (0xd80025e2): 0x0100 -> 0x010b
MUX: setup AA16_34XX_GPI181 (0xd80021dc): 0x010c -> 0x011c
MUX: setup AE17_34XX_GPIO182 (0xd80021de): 0x010c -> 0x011c
MUX: setup AE15_34XX_GPIO176 (0xd80021d0): 0x010c -> 0x011c
Display initialized successfully
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
i2c_omap i2c_omap.1: bus 1 rev3.12 at 400 kHz
regulator: VDCDC1: 1200 mV
regulator: VDCDC2: 3300 mV
regulator: VDCDC3: 1800 mV
regulator: LDO1: 1800 mV
regulator: LDO2: 3300 mV
i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, cppi4.1-dma, otg (peripheral+host), debug=0
Waiting for PHY clock good...(CONF0=0xf003622)
OMAP3517 OTG revision 4ea41001, PHY f0036a2, control 00
musb_hdrc: USB OTG mode controller at d0810000 using DMA, IRQ 71
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
OMAP3517 Linux PSP version 03.00.00.02 (OMAP3517EVM)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 490
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
i2c /dev entries driver
davinci_emac_probe: using random MAC addr: ba:22:59:8a:2c:ac
emac-mii: probed
vcan: Virtual CAN interface driver
CAN device driver interface
TI High End CAN Controller Driver 0.4
ti_hecc ti_hecc.1: device registered (reg_base=d0808000, irq=24)
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit)
Creating 5 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000080000 : "xloader-nand"
0x000000080000-0x000000240000 : "uboot-nand"
0x000000240000-0x000000280000 : "params-nand"
0x000000280000-0x000000780000 : "linux-nand"
0x000000780000-0x000020000000 : "jffs2-nand"
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.31-rc7-omap1 ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 92:41:96:ca:01:a7
usb0: HOST MAC 16:e9:f3:66:4b:e8
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.31-rc7-omap1 musb-hcd
usb usb2: SerialNumber: musb_hdrc
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver appletouch
usbcore: registered new interface driver bcm5974
Linux video capture interface: v2.00
vpfe_init
vpfe-capture: vpss clock vpfe_ck enabled
vpfe-capture: vpss clock vpfe_pck enabled
vpfe-capture vpfe-capture: v4l2 device registered
vpfe-capture vpfe-capture: video device registered
tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
vpfe-capture vpfe-capture: v4l2 sub device tvp514x registered
dm644x_ccdc_init
vpfe_register_ccdc_device: DM6446 CCDC
DM6446 CCDC is registered with vpfe.
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
mmci-omap-hs mmci-omap-hs.1: Failed to get debounce clock
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.20.
usbcore: registered new interface driver snd-usb-audio
No device for DAI tlv320aic23
No device for DAI omap-mcbsp-dai-0
No device for DAI omap-mcbsp-dai-1
No device for DAI omap-mcbsp-dai-2
No device for DAI omap-mcbsp-dai-3
No device for DAI omap-mcbsp-dai-4
OMAP3 EVM SoC init
AIC23 Audio Codec 0.1
tlv320aic23_write cannot write 000 to register R15
asoc: tlv320aic23 <-> omap-mcbsp-dai-0 mapping ok
tlv320aic23_write cannot write 047 to register R6
tlv320aic23_write cannot write 004 to register R5
tlv320aic23_write cannot write 117 to register R0
tlv320aic23_write cannot write 117 to register R1
tlv320aic23_write cannot write 010 to register R4
tlv320aic23_write cannot write 070 to register R2
tlv320aic23_write cannot write 070 to register R3
tlv320aic23_write cannot write 001 to register R9
ALSA device list:
#0: omap3517evm (tlv320aic23)
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
Console: switching to colour frame buffer device 60x34
regulator_init_complete: incomplete constraints, leaving LDO2 on
regulator_init_complete: incomplete constraints, leaving LDO1 on
regulator_init_complete: incomplete constraints, leaving VDCDC3 on
regulator_init_complete: incomplete constraints, leaving VDCDC2 on
regulator_init_complete: incomplete constraints, leaving VDCDC1 on
omapdss DPI: display already enabled
omap_vout omap_vout: 'lcd' Display already enabled
omap_voutBuffer Size = 3686400
omap_vout: registered and initialized video device 1 [v4l2]
omap_vout: registered and initialized video device 2 [v4l2]
Empty flash at 0x1b8b809c ends at 0x1b8b8800
VFS: Mounted root (jffs2 filesystem) on device 31:4.
Freeing init memory: 140K
/sbin/init: error while loading shared libraries: /lib/libc.so.6: ELF file version does not match current one
Kernel panic - not syncing: Attempted to kill init!
[<c00313fc>] (unwind_backtrace+0x0/0xdc) from [<c030fc54>] (panic+0x40/0x108)
[<c030fc54>] (panic+0x40/0x108) from [<c004ed30>] (do_exit+0x68/0x58c)
[<c004ed30>] (do_exit+0x68/0x58c) from [<c004f2d0>] (do_group_exit+0x7c/0xac)
[<c004f2d0>] (do_group_exit+0x7c/0xac) from [<c004f310>] (sys_exit_group+0x10/0x18)
[<c004f310>] (sys_exit_group+0x10/0x18) from [<c002bdc0>] (ret_fast_syscall+0x0/0x2c)
Print Env
baudrate=115200
loadaddr=0x82000000
mmcargs=setenv bootargs console=${console} root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
nandargs=setenv bootargs console=${console} root=/dev/mtdblock4 rw rootfstype=jffs2 omapfb.vram=0:1M
loadbootscript=fatload mmc 0 ${loadaddr} boot.scr
bootscript=echo Running bootscript from mmc ...; autoscr ${loadaddr}
loaduimage=fatload mmc 0 ${loadaddr} uImage
mmcboot=echo Booting from mmc ...; run mmcargs; bootm ${loadaddr}
nandboot=echo Booting from nand ...; run nandargs; nand read ${loadaddr} 280000 260000; bootm ${loadaddr}
dieid#=607600000000000001543b210200c009
bootdelay=5
dnsip=172.16.4.2
dnsip2=202.131.104.2
nand_kernel=nand read.i 0x80000000 280000 300000
bootargs=mem=256M console=ttyS2,115200n8 noinitrd root=/dev/mtdblock4 rw rootfstype=jffs2
ethaddr=00:08:EE:03:77:FC
bootfile=uImage
filesize=F60000
fileaddr=81600000
gatewayip=172.16.4.1
netmask=255.255.252.0
ipaddr=172.16.6.4
serverip=172.16.5.251
bootcmd rn=bootarun tftp_kernel
nfshost=172.16.5.251
rootpath=/tftpboot
get_kernel=run nand_kernel
get_initrd=run nand_initrd
bootcmd=run bootargs_fs
stdin=serial
stdout=serial
stderr=serial
Thanks in Advance
