I modified the message sample code for my own application. GPP loads DSP. DSP sends a message to GPP, then it waits for a message from GPP. Once DSP receives the message, it executes TSKMESSAGE_delete. It ran correctly before I added my own code. If TSKMESSAGE_execute() (in DSP) calls my own function, the code (in GPP) appears to be stuck at the MESSAGE_delete() in GPP . The following is the stdout output. The code hangs at the line "tmpStatus = MSGQ_transportClose(0)". From the message sent by DSP, my DSP code (a complex DP floating point algorithm) is correct. Well, at least its output is the expected result.
Thanks a lot!
Entered MESSAGE_Create ()
Leaving MESSAGE_Create ()
Entered MESSAGE_Execute ()
Entering MESSAGE_VerifyData
Display the received data from DSP.
Leaving MESSAGE_Execute ()
Entered MESSAGE_Delete ()
Assertion failed (addr != NULL). File : /home/vadmin/OMAP-L138_arm_1_00_00_11/dsplink_linux_1_65_00_02/dsplink/gpp/src/../../gpp/src/ldrv/POOLS/ldrv_pool.c Line : 1037
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = c1ea4000
[00000004] *pgd=c101c031, *pte=00000000, *ppte=00000000
Internal error: Oops: 817 [#1] PREEMPT
last sysfs file: /sys/kernel/uevent_seqnum
Modules linked in: dsplinkk
CPU: 0 Not tainted (2.6.33-rc4 #1)
PC is at LDRV_MPLIST_getHead+0x1a4/0x1f0 [dsplinkk]
LR is at DA8XXGEM_addrConvert+0xbc/0x144 [dsplinkk]
pc : [<bf0107cc>] lr : [<bf000698>] psr: 20000013
sp : c1febdd8 ip : c1febdb8 fp : c1febe04
r10: 00000000 r9 : c2900000 r8 : bf0359f8
r7 : c294d600 r6 : 00000000 r5 : 00000000 r4 : c1febe14
r3 : c296b000 r2 : 00000001 r1 : 00000001 r0 : c3f12600
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005317f Table: c1ea4000 DAC: 00000015
Process msggpp (pid: 861, stack limit = 0xc1fea270)
Stack: (0xc1febdd8 to 0xc1fec000)
bdc0: c294d700 0020d600
bde0: c1febe04 c294d700 c294d600 00008000 c294d580 00000000 c1febe44 c1febe08
be00: bf00aafc bf010638 bf035698 c1ec9b80 be8a3c64 c2c00080 c1febe34 00000000
be20: 00000001 00000000 c1ec9b80 be8a3c64 c1fea000 40025000 c1febe5c c1febe48
be40: bf00875c bf00a914 0000800d 00000001 c1febe7c c1febe60 bf01fe68 bf0086f0
be60: c018e031 c018e031 be8a3c64 c1ec9b80 c1febeec c1febe80 bf020764 bf01fdd0
be80: c1febe9c c1febe90 c01b0358 c01b02f4 00000000 60000013 c1febf08 c1f5dc00
bea0: c1fea000 0000000c c1fda400 00008000 00000000 be8a3c7c 00008cc0 00009934
bec0: 00021ed0 c01721f4 0000000c c1ec9b80 c018e031 be8a3c64 c1ec9b80 be8a3c64
bee0: c1febf0c c1febef0 c00b37b8 bf020248 00000003 c1ec9b80 00000003 c1ec9b80
bf00: c1febf7c c1febf10 c00b3e7c c00b3744 40990000 00000002 00000000 c1827180
bf20: c1ed5380 0000000c c1fea000 00021edc c1febf6c c1febf40 c00a5d94 c00d52cc
bf40: 00000000 00000000 c002e0a4 00000000 00000000 00000003 be8a3c64 c018e031
bf60: c1ec9b80 c002e0a4 c1fea000 40025000 c1febfa4 c1febf80 c00b3f18 c00b38f8
bf80: c1fea000 00000001 0000035d 00000000 00008c14 00000036 00000000 c1febfa8
bfa0: c002df20 c00b3ee8 0000035d 00000000 00000003 c018e031 be8a3c64 00000003
bfc0: 0000035d 00000000 00008c14 00000036 00000000 00000000 40025000 be8a3c54
bfe0: 00000000 be8a3b40 0000c720 40101aec 80000010 00000003 c04aa031 c04aa431
Backtrace:
[<bf010628>] (LDRV_MPLIST_getHead+0x0/0x1f0 [dsplinkk]) from [<bf00aafc>] (ZCPYMQT_close+0x1f8/0x354 [dsplinkk])
r8:00000000 r7:c294d580 r6:00008000 r5:c294d600 r4:c294d700
[<bf00a904>] (ZCPYMQT_close+0x0/0x354 [dsplinkk]) from [<bf00875c>] (LDRV_MSGQ_transportClose+0x7c/0xe4 [dsplinkk])
[<bf0086e0>] (LDRV_MSGQ_transportClose+0x0/0xe4 [dsplinkk]) from [<bf01fe68>] (PMGR_MSGQ_transportClose+0xa8/0xf0 [dsplinkk])
r5:00000001 r4:0000800d
[<bf01fdc0>] (PMGR_MSGQ_transportClose+0x0/0xf0 [dsplinkk]) from [<bf020764>] (DRV_Ioctl+0x52c/0x7f4 [dsplinkk])
r7:c1ec9b80 r6:be8a3c64 r5:c018e031 r4:c018e031
[<bf020238>] (DRV_Ioctl+0x0/0x7f4 [dsplinkk]) from [<c00b37b8>] (vfs_ioctl+0x84/0xb4)
r8:be8a3c64 r7:c1ec9b80 r6:be8a3c64 r5:c018e031 r4:c1ec9b80
[<c00b3734>] (vfs_ioctl+0x0/0xb4) from [<c00b3e7c>] (do_vfs_ioctl+0x594/0x5f0)
r7:c1ec9b80 r6:00000003 r5:c1ec9b80 r4:00000003
[<c00b38e8>] (do_vfs_ioctl+0x0/0x5f0) from [<c00b3f18>] (sys_ioctl+0x40/0x64)
[<c00b3ed8>] (sys_ioctl+0x0/0x64) from [<c002df20>] (ret_fast_syscall+0x0/0x28)
r7:00000036 r6:00008c14 r5:00000000 r4:0000035d
Code: e1a00005 ebffbe6c e1a04804 e1840820 (e5860004)
---[ end trace 59188382e69cfb96 ]---
