Build Errors in Gpio???Rectify pls!!!!
Hello
Am working with this program its not running as a separate program in vs 2005. Am getting the errors can anybody help me to solve the errors or to make this program to run.
This program is nothing but gpiotest.cpp i added the header files too but i cant able to run .what are the things i want to make the program running.
Help me to rectify the errors.
Error    6    error C2146: syntax error : missing ';' before identifier 'ShellProc'    e:\ti\globals.h    47
Error    7    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\globals.h    47
Error    8    error C2061: syntax error : identifier 'SPPARAM'    e:\ti\globals.h    47
Error    9    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\globals.h    47
Error    10    error C2146: syntax error : missing ';' before identifier 'g_lpFTE'    e:\ti\ft.h    70
Error    11    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    70
Error    12    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    70
Error    13    error C2146: syntax error : missing ';' before identifier 'TestProc_IOCTL_API'    e:\ti\ft.h    72
Error    14    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    72
Error    15    error C2061: syntax error : identifier 'TPPARAM'    e:\ti\ft.h    72
Error    16    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    72
Error    17    error C2146: syntax error : missing ';' before identifier 'TestProc_Inline_API'    e:\ti\ft.h    73
Error    18    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    73
Error    19    error C2086: 'int TESTPROCAPI' : redefinition    e:\ti\ft.h    73
Error    20    error C2061: syntax error : identifier 'TPPARAM'    e:\ti\ft.h    73
Error    21    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    73
Error    22    error C2146: syntax error : missing ';' before identifier 'TestProc_ReadWrite'    e:\ti\ft.h    74
Error    23    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    74
Error    24    error C2086: 'int TESTPROCAPI' : redefinition    e:\ti\ft.h    74
Error    25    error C2061: syntax error : identifier 'TPPARAM'    e:\ti\ft.h    74
Error    26    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    74
Error    27    error C2146: syntax error : missing ';' before identifier 'TestProc_MultiThread'    e:\ti\ft.h    75
Error    28    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    75
Error    29    error C2086: 'int TESTPROCAPI' : redefinition    e:\ti\ft.h    75
Error    30    error C2061: syntax error : identifier 'TPPARAM'    e:\ti\ft.h    75
Error    31    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\ft.h    75
Error    32    error C2143: syntax error : missing ';' before '*'    e:\ti\globals.h    58
Error    33    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\globals.h    58
Error    34    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\globals.h    58
Error    35    error C2143: syntax error : missing ';' before '*'    e:\ti\globals.h    61
Error    36    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\globals.h    61
Error    37    error C4430: missing type specifier - int assumed. Note: C++ does not support default-int    e:\ti\globals.h    61
Error    38    fatal error C1083: Cannot open include file: 'kernelgpio.h': No such file or directory    e:\ti\gpiotest.cpp    16
Vinoth.
