Other Parts Discussed in Thread: OMAP3530
Hi ,all
I am using omap3530 with wince 6.0 R2,i am using ce 2.24.01 which is download from ti.com .
in platform builder ,i has built the image with DVSDK intergration sub project. and i can run the command below successfully
video_decode_io2_omap3530 -c h264dec -i ice-4cif-20.264 -o ice-4cif-20.264.yuv -n 2
since i use the command below
osalsetenv_wince.exe debug 2, s
o i can see the serial message below
@54,247,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@54,249,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x61740]
@54,263,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@54,277,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x61760]
@54,293,408us: [+0 T:0x063f018a] OT - Thread_create> Enter (fxn=0x2a558, attrs=0x0)
@54,313,408us: [+0 T:0x063f018a] OT - Thread_create> Exit (task=0x617a0)
@54,327,408us: [+0 T:0x063f018a] ti.sdo.ce.alg - ALG_init> Enter
@54,333,408us: [+0 T:0x063f018a] ti.sdo.ce.alg - ALG_init> Exit
@54,347,408us: [+6 T:0x063f018a] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@54,369,408us: [+0 T:0x063f018a] CS - Server_init()
@54,377,408us: [+0 T:0x063f018a] CS - Server_init> Global_useLinkArbiter = 0
@54,423,408us: [+1 T:0x066b009a] OP - daemon> thread created.
@54,423,408us: [+0 T:0x066b009a] OP - getCmd_d> Enter (proc=0xbfe3c)
@54,437,408us: [+0 T:0x066b009a] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x61740] timeout[0xffffffff]
@55,113,408us: [+0 T:0x063f018a] CE - Engine_open> Enter('decode', 0x0, 0x5f864)
@55,115,408us: [+0 T:0x063f018a] CE - rserverOpen('windows\cs.x64P'), count = 0
@55,129,408us: [+0 T:0x063f018a] OP - Processor_create> Enter(imageName='windows\cs.x64P', linkCfg='(null)', attrs=0x5f7f8)
@55,155,408us: [+0 T:0x063f018a] OP - doCmd> Enter (cmdId=1, proc=0x61c60)
@55,165,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x61740]
@55,181,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x61740]
@55,195,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x61760] timeout[0xffffffff]
@55,293,408us: [+0 T:0x066b009a] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x61740] status[0]
@55,297,408us: [+0 T:0x066b009a] OP - getCmd_d> Exit (result=1)
@55,309,408us: [+0 T:0x066b009a] OP - Processor_create_d> Enter(proc=0x61c60)
@55,323,408us: [+0 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_on> Enter(handle=0x61c7c)
@55,339,408us: [+2 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_on> Opening Local Power Manager for the DSP on /dev/lpm0...
@55,361,408us: [+2 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_on> Turning on DSP power...
@55,377,408us: [+2 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_on> return (0)
@55,389,408us: [+2 T:0x066b009a] OP - Processor_create_d> Initializing DSP PROC...
@55,405,408us: [+2 T:0x066b009a] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'windows\cs.x64P']
@55,427,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x87d00000, sizeInBytes=0x300000, shared=1, syncd=0
@55,459,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x87301000, sizeInBytes=0xff000, shared=1, syncd=0
@55,579,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x87300000, sizeInBytes=0x1000, shared=1, syncd=0
@55,601,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='L4PER', startAddress=0x49000000, sizeInBytes=0x100000, shared=0, syncd=0
@55,633,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #4 to Link configuration: name='IRAM', startAddress=0x5c7f8000, sizeInBytes=0x8000, shared=1, syncd=0
@55,665,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #5 to Link configuration: name='L1DSRAM', startAddress=0x5cf04000, sizeInBytes=0x10000, shared=1, syncd=0
@55,697,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #6 to Link configuration: name='DDRALGHEAP', startAddress=0x87400000, sizeInBytes=0x900000, shared=0, syncd=0
@55,731,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #7 to Link configuration: name='L4CORE', startAddress=0x48000000, sizeInBytes=0x1000000, shared=0, syncd=0
@55,763,408us: [+2 T:0x066b009a] OP - Processor_create_d> Found 'CMEM' entry, adjusting base and size according to CMEM_getBlock()
@55,859,408us: [+0 T:0x066b009a] OP - Processor_create_d> Setting CMEM base to 0x86300000, size to 0x1000000
@55,871,408us: [+2 T:0x066b009a] OP - Processor_create_d> Adding DSP segment #8 to Link configuration: name='CMEM', startAddress=0x86300000, sizeInBytes=0x1000000, shared=0, syncd=0
@55,903,408us: [+2 T:0x066b009a] OP - Processor_create_d> DODSPCTRL was=0; now=0
@55,921,408us: [+3 T:0x066b009a] OP - LINKCFG_Object generated for PROC_setup(p) ...
@55,933,408us: [+3 T:0x066b009a] OP - linkCfg->gppObject->
@55,945,408us: [+3 T:0x066b009a] OP - name = "ARM9"
@55,953,408us: [+3 T:0x066b009a] OP - maxMsgqs = 0x82
@55,965,408us: [+3 T:0x066b009a] OP - maxChnlQueue = 0x10
@55,975,408us: [+3 T:0x066b009a] OP - poolTableId = 0xffffffff
@55,987,408us: [+3 T:0x066b009a] OP - numPools = 0x0
@55,997,408us: [+3 T:0x066b009a] OP -
@56,003,408us: [+3 T:0x066b009a] OP - linkCfg->dspConfigs[0]->dspObject->
@56,017,408us: [+3 T:0x066b009a] OP - name = "OMAP3530"
@56,027,408us: [+3 T:0x066b009a] OP - dspArch = 0x2
@56,037,408us: [+3 T:0x066b009a] OP - loaderName = "COFF"
@56,047,408us: [+3 T:0x066b009a] OP - autoStart = FALSE
@56,059,408us: [+3 T:0x066b009a] OP - execName = "DEFAULT.OUT"
@56,137,408us: [+3 T:0x066b009a] OP - doDspCtrl = DSP_BootMode_Boot_NoPwr
@56,151,408us: [+3 T:0x066b009a] OP - resumeAddr = 0x87300020
@56,163,408us: [+3 T:0x066b009a] OP - resetVector = 0x87300000
@56,175,408us: [+3 T:0x066b009a] OP - resetCodeSize = 0x1000
@56,185,408us: [+3 T:0x066b009a] OP - maduSize = 0x1
@56,195,408us: [+3 T:0x066b009a] OP - cpuFreq = 0x6ddd0
@56,205,408us: [+3 T:0x066b009a] OP - endian = 0x3
@56,215,408us: [+3 T:0x066b009a] OP - wordSwap = 0x0
@56,225,408us: [+3 T:0x066b009a] OP - memTableId = 0x0
@56,235,408us: [+3 T:0x066b009a] OP - memEntries = 0x9
@56,245,408us: [+3 T:0x066b009a] OP - linkDrvId = 0x0
@56,257,408us: [+3 T:0x066b009a] OP - arg1 = 0xffffffff
@56,267,408us: [+3 T:0x066b009a] OP - arg2 = 0xffffffff
@56,277,408us: [+3 T:0x066b009a] OP - arg3 = 0x0
@56,287,408us: [+3 T:0x066b009a] OP - arg4 = 0x0
@56,295,408us: [+3 T:0x066b009a] OP - arg5 = 0xffffffff
@56,305,408us: [+3 T:0x066b009a] OP -
@56,313,408us: [+3 T:0x066b009a] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
@56,327,408us: [+3 T:0x066b009a] OP - name = "SHMDRV"
@56,415,408us: [+3 T:0x066b009a] OP - hshkPollCount = 0x989680
@56,415,408us: [+3 T:0x066b009a] OP - memEntry = 0x1
@56,425,408us: [+3 T:0x066b009a] OP - ipsTableId = 0x0
@56,435,408us: [+3 T:0x066b009a] OP - numIpsEntries = 0x1
@56,447,408us: [+3 T:0x066b009a] OP - poolTableId = 0x0
@56,457,408us: [+3 T:0x066b009a] OP - numPools = 0x1
@56,467,408us: [+3 T:0x066b009a] OP - dataTableId = 0x0
@56,477,408us: [+3 T:0x066b009a] OP - numDataDrivers = 0x1
@56,489,408us: [+3 T:0x066b009a] OP - mqtId = 0x0
@56,497,408us: [+3 T:0x066b009a] OP - ringIoTableId = 0x0
@56,509,408us: [+3 T:0x066b009a] OP - mplistTableId = 0x0
@56,519,408us: [+3 T:0x066b009a] OP - mpcsTableId = 0x0
@56,529,408us: [+3 T:0x066b009a] OP -
@56,537,408us: [+3 T:0x066b009a] OP - linkCfg->dspConfigs[0]->memTables[0][i].
@56,551,408us: [+3 T:0x066b009a] OP - entry #0:
@56,559,408us: [+3 T:0x066b009a] OP - entry = 0x0
@56,569,408us: [+3 T:0x066b009a] OP - name = "DDR2"
@56,579,408us: [+3 T:0x066b009a] OP - physAddr = 0x87d00000
@56,589,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x87d00000
@56,601,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@56,613,408us: [+3 T:0x066b009a] OP - size = 0x300000
@56,693,408us: [+3 T:0x066b009a] OP - shared = TRUE
@56,699,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@56,709,408us: [+3 T:0x066b009a] OP - entry #1:
@56,719,408us: [+3 T:0x066b009a] OP - entry = 0x1
@56,727,408us: [+3 T:0x066b009a] OP - name = "DSPLINKMEM"
@56,739,408us: [+3 T:0x066b009a] OP - physAddr = 0x87301000
@56,749,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x87301000
@56,761,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@56,773,408us: [+3 T:0x066b009a] OP - size = 0xff000
@56,783,408us: [+3 T:0x066b009a] OP - shared = TRUE
@56,793,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@56,803,408us: [+3 T:0x066b009a] OP - entry #2:
@56,811,408us: [+3 T:0x066b009a] OP - entry = 0x2
@56,821,408us: [+3 T:0x066b009a] OP - name = "RESET_VECTOR"
@56,831,408us: [+3 T:0x066b009a] OP - physAddr = 0x87300000
@56,843,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x87300000
@56,855,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@56,867,408us: [+3 T:0x066b009a] OP - size = 0x1000
@56,877,408us: [+3 T:0x066b009a] OP - shared = TRUE
@56,885,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@56,971,408us: [+3 T:0x066b009a] OP - entry #3:
@56,971,408us: [+3 T:0x066b009a] OP - entry = 0x3
@56,979,408us: [+3 T:0x066b009a] OP - name = "L4PER"
@56,989,408us: [+3 T:0x066b009a] OP - physAddr = 0x49000000
@57,001,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x49000000
@57,013,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@57,025,408us: [+3 T:0x066b009a] OP - size = 0x100000
@57,035,408us: [+3 T:0x066b009a] OP - shared = FALSE
@57,045,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@57,055,408us: [+3 T:0x066b009a] OP - entry #4:
@57,063,408us: [+3 T:0x066b009a] OP - entry = 0x4
@57,073,408us: [+3 T:0x066b009a] OP - name = "IRAM"
@57,083,408us: [+3 T:0x066b009a] OP - physAddr = 0x5c7f8000
@57,093,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x107f8000
@57,105,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@57,117,408us: [+3 T:0x066b009a] OP - size = 0x8000
@57,127,408us: [+3 T:0x066b009a] OP - shared = TRUE
@57,137,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@57,145,408us: [+3 T:0x066b009a] OP - entry #5:
@57,155,408us: [+3 T:0x066b009a] OP - entry = 0x5
@57,165,408us: [+3 T:0x066b009a] OP - name = "L1DSRAM"
@57,249,408us: [+3 T:0x066b009a] OP - physAddr = 0x5cf04000
@57,251,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x10f04000
@57,263,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@57,275,408us: [+3 T:0x066b009a] OP - size = 0x10000
@57,285,408us: [+3 T:0x066b009a] OP - shared = TRUE
@57,295,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@57,305,408us: [+3 T:0x066b009a] OP - entry #6:
@57,313,408us: [+3 T:0x066b009a] OP - entry = 0x6
@57,323,408us: [+3 T:0x066b009a] OP - name = "DDRALGHEAP"
@57,333,408us: [+3 T:0x066b009a] OP - physAddr = 0x87400000
@57,345,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x87400000
@57,357,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@57,369,408us: [+3 T:0x066b009a] OP - size = 0x900000
@57,379,408us: [+3 T:0x066b009a] OP - shared = FALSE
@57,389,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@57,399,408us: [+3 T:0x066b009a] OP - entry #7:
@57,407,408us: [+3 T:0x066b009a] OP - entry = 0x7
@57,417,408us: [+3 T:0x066b009a] OP - name = "L4CORE"
@57,427,408us: [+3 T:0x066b009a] OP - physAddr = 0x48000000
@57,437,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x48000000
@57,451,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@57,461,408us: [+3 T:0x066b009a] OP - size = 0x1000000
@57,471,408us: [+3 T:0x066b009a] OP - shared = FALSE
@57,481,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@57,491,408us: [+3 T:0x066b009a] OP - entry #8:
@57,499,408us: [+3 T:0x066b009a] OP - entry = 0x8
@57,509,408us: [+3 T:0x066b009a] OP - name = "CMEM"
@57,519,408us: [+3 T:0x066b009a] OP - physAddr = 0x86300000
@57,529,408us: [+3 T:0x066b009a] OP - dspVirtAddr = 0x86300000
@57,541,408us: [+3 T:0x066b009a] OP - gppVirtAddr = 0xffffffff
@57,553,408us: [+3 T:0x066b009a] OP - size = 0x1000000
@57,563,408us: [+3 T:0x066b009a] OP - shared = FALSE
@57,573,408us: [+3 T:0x066b009a] OP - syncd = FALSE
@57,583,408us: [+3 T:0x066b009a] OP -
@57,591,408us: [+3 T:0x066b009a] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].
@57,605,408us: [+3 T:0x066b009a] OP - entry #0:
@57,613,43,408us: [+3 T:0x066b009a] OP - numIpsEvents = 0x20
@57,633,408us: [+3 T:0x066b009a] OP - memEntry = 0x1
@57,643pIntId = 0x1a
@57,729,408us: [+3 T:0x066b009a] OP - dspIntId = 0x37
@57,731,408us: [+3 T:0x066b009a] OP - dspIntonfigs[0]->dataTables[0][i].
@57,805,408us: [+3 T:0x066b00 queuePerChnl = 0x1
@57,885,408us: [+3 T:0x066b009a] OP - ipsId = 0x0
@57,895,408u] OP -
@58,007,408us: [+3 T:0x066b009a] OP - linkCfg->dspConfigs[0]->mqtObjects->
@5851,408us: [+3 T:0x066b009a] OP - ipsEventNo = 0x0
@58,068,153,408us: [+3 T:0x066b009a] OP -
@58,161,408us: [+3 T:08us: [+3 T:0x066b009a] OP - ipsId = 0xffffffff
@58,285,T:0x066b009a] OP - name = "MPCS"
@58,325,408us: [+3 T:0x@58,413,408us: [+2 T:0x066b009a] OP - Processor_create_d> Op@62,573,408us: [+2 T:0x066b009a] OP - Processor_create_d> Starting DSP PROC...
@62,701,408us: [+2 T:0x066b009a] OP - Processor_create_d> Opening remote transport...
@62,709,408us: [+0 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_connect> Enter (handle=0x61ca0)
@62,721,408us: [+2 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_connect> Calling LPM_connect to connect to the DSP power handler...
@62,745,408us: [+0 T:0x066b009a] ti.sdo.ce.ipc.Power - Power_connect> return (0)
@62,759,408us: [+2 T:0x066b009a] OP - Processor_create_d> return (1)
@62,771,408us: [+0 T:0x066b009a] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x61760]
@62,787,408us: [+0 T:0x066b009a] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x61760]
@62,801,408us: [+0 T:0x066b009a] OP - getCmd_d> Enter (proc=0xbfe3c)
@62,815,408us: [+0 T:0x066b009a] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x61740] timeout[0xffffffff]
@62,911,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x61760] status[0]
@62,917,408us: [+0 T:0x063f018a] OP - doCmd> Exit (result=1)
@62,927,408us: [+0 T:0x063f018a] OP - Processor_create> return (0x61c60)
@62,941,408us: [+0 T:0x063f018a] CE - rserverOpen('windows\cs.x64P'): 0x3f32c done.
@63,035,408us: [+0 T:0x063f018a] CE - checkServer(0x61c20)
@63,113,408us: [+0 T:0x063f018a] CE - rmsInit> RMS initialized(0x61c20); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3
@63,135,408us: [+0 T:0x063f018a] CE - Engine_setTrace> Enter(engine=0x61c20, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
@63,163,408us: [+1 T:0x063f018a] CE - Engine_setTrace> Requesting DSP set trace ...
@63,257,408us: [+0 T:0x063f018a] CE - Engine_setTrace> return(0)
[DSP] @0x000001cd:[T:0x00000000] codec_unitserver - main> Welcome to CS1OMAP3530 DSP server's main().
[DSP] @0,336,238tk: [+0 T:0x87ee45f4] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
[DSP] @0,336,332tk: [+4 T:0x87ee45f4] OG - Global_setSpecialTrace> This program was built with the following packages:
[DSP] @0,336,398tk: [+4 T:0x87ee45f4] OG - package ti.targets.rts6000 (C:/ti_tools/xdctools/xdctools_3_10_05_61/packages/ti/targets/rts6000/) [1,0,0,0,1242339328638]
[DSP] @0,336,478tk: [+4 T:0x87ee45f4] OG - package ti.sdo.codecs.aachedec (C:/dvsdk_wince_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/aachedec/) [1,0,0,1258043351233]
[DSP] @0,336,562tk: [+4 T:0x87ee45f4] OG - package ti.sdo.codecs.g711dec (C:/dvsdk_wince_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/g711dec/) [1,0,0,1258043352952]
[DSP] @0,336,646tk: [+4 T:0x87ee45f4] OG - package ti.sdo.codecs.g711enc (C:/dvsdk_wince_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/g711enc/) [1,0,0,1258043354264]
[DSP] @0,336,730tk: [+4 T:0x87ee45f4] OG - package ti.sdo.codecs.h264dec (C:/dvsdk_wince_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/h264dec/) [1,0,0,1258043356046]
[DSP] @0,336,813tk: [+4 T:0x87ee45f4] OG - package ti.sdo.codecs.h264enc (C:/dvsdk_wince_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/h264enc/) [1,0,0,1258043357296]
[DSP] @0,336,897tk: [+4 T:0x87ee45f4] OG - package ti.sdo.codecs.jpegdec (C:/dvsdk_wince_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/jpegdec/) [1,0,_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/mpeg2dec/) @0,337,326tk: [+4 T:0x87ee45f4] OG - package ti.sdo.fc.obal (C:/dvsdk_wince_1_00_00_0kages/ti/xdais/) [1,2,1,1247590290221]
[DSP] @0,337,567tk: [+4 T:0x87ee45f4] OG - pado.fc.dskt2 (C:/dvsdk_wince_1_4,1247787218672]
[DSP] @0,337,927tk: [+4 T:0x87ee45f4] OG k: [+4 T:0x87ee45f4] OG - package ti.xdais.dm (C:/dvsdk_wince_1_00_00_05/xdais_6_24_01[DSP] @0,338,167tk: [+4 T:0x87ee45f4] OG - package ti.sd - package ti.sdo.ce.ipc.dsplink.dsp (C:/dvsdk_wince_1_0,338,500tk: [+4 T:0x87ee45f4] T:0x87ee45f4] OG - packagti.platforms.evm3530 (C:/CCStuengine_2_24_01/packages/ti/sdoe/ipc/) [2,0,1,1248496427151]
1_00_00_05/codec_engine_2_24_01/packages/ti/sdo/ce/) [1,0,6,/bioslog/) [1,0,1,1248495742355]
[DSP] @0,339,421tk: [+4 T package ti.sdo.ce.speech1 (ince_1_00_00_05/codec_engine_2cs/g711enc/ce/) [1,0,0,1258043354967]
[DSP] @0,339,841tk: ackage ti.sdo.ce.video2 (C:/dvsdk_wince_1_00_00_05/codec_engackages/ti/sdo/ce/video1/) [1,0,2,1248497011003]
[DSP] @0,[DSP] @0,340,176tk: [+4 T:0x87ee45f4] OG - package ti.sdnce_1_00_00_05/cs1omap3530_1_00_01/packages/ti/sdo/codecs/jp1,0,0,1258043362249]
[DSP] @0,340,516tk: [+4 T:0x87ee45f4]package ti.sdo.server.cs (C:/d00_05/cs1omap3530_1_00_01/packc', params=0x5f89c)
@65,689,Node Enter(engine=0x61c20, impId='h264dec')
@65,767,408us:@66,023,408us: [+4 T:0x063f018a] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x62260, algName='h264dec', rmsNode=0x87ee90d8, [DSP] @2,170,904tk: [+0 T:0x87ee45f4] OM - Memory_alloc> Ent OM - Memory_alloc> Enter(size=0xa)
[DSP] @2,171,052tk: [+7ee45f4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> Enter (e48c0)
[DSP] @2,171,613tk: [+4] OM - Memory_alloc> return (0x87ee9190)
[DSP] @2,171,715rs=0x87ee8408)
[DSP] @2,171,974tk: [+0 T:0x87ee45f4] OM - ", pri: -1, stack size: 2252 stack seg: 0
@66,571,408us:@66,677,408us: [+5 T:0x063f018a] CV - VISA_create> remote co- VISA_allocMsg> Allocating meage for messageId=0x0002bb40
3f018a] CV - VISA_call(visa=0x[DSP] @2,873,180tk: [+5 T:0x87 0x87ee9100(h264dec#0) call(alsdo.ce.alg.Algorithm - Algorit> Exit
[DSP] @2,873,818tk: [+0 T:0x87ee98cc] ti.sdo.ce.vidine_fwriteTrace> returning count [1144]
@67,219,408us: [+062200, 0x101880): Freeing message with messageId=0x0002bb40
T:0x063f018a] CV - VISA_allocMsg> Allocating message for me[DSP] @3,273,069tk: [+5 T:0x87ee98cc] CN - NODE> 0x87ee9100(b8)
[DSP] @3,273,254tk: [+5 T:0x87ee98cc] CV - VISA_enter(g.Algorithm - Algorithm_deactivate> Enter(alg=0x87ee91f0)
@67,711,408us: [+0l Completed: messageId=0x0002b1, command=0x1, return(status=ab for 2 buffers
@67,801,408us: [+6 T:0x063f018a] OM - Mem0 at 0x180000 (0x870e0000 phys)
@67,877,408us: [+6 T:0x063contigAlloc> CMEM_alloc(829440) = 0x280000.
@67,989,408us:do.dmai - [Loader] Creating Lo0x390000) = 0x867d5000.
@68,@68,403,408us: [+0 T:0x063f018a] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x62200, inBufs=0x5ef7c, outBufs=0x5ef08, inArgs=0x5eeb8, outArgs=0x5f044)
@68,421,408us: [+5 T:0x063f018a] CV - VISA_allocMsg> Allocating message [DSP] @4,048,406tk: [+5 T:0x87ee98cc] CN - NODE> 0x87ee9100(andle=0x87ee91c0, msg=0x87305880); messageId=0x0002bb42
[D inArgs=0x873059f8, outArgs=0xtivate> Enter(alg=0x87ee91f0)
a] CV - VISA_call Completed: mUse 0 consumed 22627
@68,963,408us: [+2 T:0x063f018a] ti.s8a] CV - VISA_allocMsg> Allocating message for messageId=0x0[DSP] @4,509,868tk: [+5 T:0x87ee98cc] CN - NODE> 0x87ee9100(h264dec#0) call(algHandle=0x87ee91c0, msg=0x87305880); messageId=0x0002bb43
[DSP] @4,509188tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm2_control> Exit (handle=0x87ee91c0, retVal=0x0)
[DSP] @4,5fwriteTrace> returning count [002bb43
@69,581,408us: [+0 Tuffer] Set user pointer 0x2800:0x063f018a] OM - Memory_contigAlloc> CMEM_getPhys(0x700000) = 0x86ee0000.
@69,741,408usti.sdo.dmai - [Buffer] Alloc Bhys(0x800000) = 0x86de0000.
@69,887,408us: [+2 T:0x063f018@71,595,408us: [+2 T:0x063f018a] ti.sdo.dmai - [Buffer] Set user pointer 0x395863 (physical 0x867da863)
@71,603,408us: [+0 T:0x063f018a] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x62200, inBufs=0x5ef7c, outBufs=0x5ef08, inArgs=0x5eeb8, outArgs=0x5f044)
@71,631,408us: [+5 T:0x063f018a] CV - VISA_allocMsg> Allocating message for messageId=0x0002bb44
@71,649,408us: [+0 T:0x063f018a] CV - VISA_call(visa=0x62200, msg=0x101880): messageId=0x0002bb44, command=0x0
[DSP] @6,305,938tk: [+5 T:0x87ee98cc] CN - NODE> 0x87ee9100(h264dec#0) call(algHandle=0x87ee91c0, msg=0x87305880); messageId=0x0002bb44
[DSP] @6,306,029tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> Enter(addr=0x867da863, sizeInBytes=147205)
[DSP] @6,306,251tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> return
[DSP] @6,306,291tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> Enter(addr=0x870e0000, sizeInBytes=811008)
[DSP] @6,307,223tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> return
[DSP] @6,307,266tk: [+0 T:0x87ee98cc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x87ee91c0, inBufs=0x87eeefd4, outBufs=0x87eef098, inArgs=0x873059f8, outArgs=0x87305a04)
[DSP] @6,307,377tk: [+5 T:0x87ee98cc] CV - VISA_enter(visa=0x87ee91c0): algHandle = 0x87ee91f0
[DSP] @6,307,436tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x87ee91f0)
[DSP] @6,307,498tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @6,335,001tk: [+5 T:0x87ee98cc] CV - VISA_exit(visa=0x87ee91c0): algHandle = 0x87ee91f0
[DSP] @6,335,092tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x87ee91f0)
[DSP] @6,335,158tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_deac@71,971,408us: [+0 T:0x063f018 CE - Engine_fwriteTrace> retudmai - [Vdec2] VIDDEC2_processnId 0 inUse 0 consumed 6993
@74,737,408us: [+2 T:0x063f018a] ti.sdo.dmai - [Buffer] Set user pointer 0x3973b4 (physical 0x867dc3b4)
@74,743,408us: [+0 T:0x063f018a] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x62200, id=4, dynParams=0x6215c (size=0x1c), status=0x5f7a4 (size=0xb8)
@74,773,408us: [+5 T:0x063f018a] CV - VISA_allocMsg> Allocating message for messageId=0x0002bb45
@74,789,408us: [+0 T:0x063f018a] CV - VISA_call(visa=0x62200, msg=0x101880): messageId=0x0002bb45, command=0x1
[DSP] @8,514,047tk: [+5 T:0x87ee98cc] CN - NODE> 0x87ee9100(h264dec#0) call(algHandle=0x87ee91c0, msg=0x87305880); messageId=0x0002bb45
[DSP] @8,514,135tk: [+0 T:0x87ee98cc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x87ee91c0, id=4, dynParams=0x873058b4 (size=0x1c), status=0x873058d0 (size=0xb8)
[DSP] @8,514,243tk: [+5 T:0x87ee98cc] CV - VISA_enter(visa=0x87ee91c0): algHandle = 0x87ee91f0
[DSP] @8,514,310tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x87ee91f0)
[DSP] @8,514,373tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @8,514,434tk: [+5 T:0x87ee98cc] CV - VISA_exit(visa=0x87ee91c0): algHandle = 0x87ee91f0
[DSP] @8,514,492tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x87ee91f0)
[DSP] @8,514,554tk: [+0 T:0x87ee98cc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @8,514,605tk: [+0 T:0x87ee98cc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x87ee91c0, retVal=0x0)
[DSP] @8,514,672tk: [+5 T:0x87ee98cc] CN - NODE> returned from call(algHandle=0x87ee91c0, msg=0x87305880); messageId=0x0002bb45
@75,013,408us: [+0 T:0x063f018a] CE - Engine_fwriteTrace> returning count [1144]
@75,027,408us: [+0 T:0x063f018a] CV - VISA_call Completed: messageId=0x0002bb45, command=0x1, return(status=0)
@75,047,408us: [+5 T:0x063f018a] CV - VISA_freeMsg(0x62200, 0x101880): Freeing message with messageId=0x0002bb45
@75,067,408us: [+0 T:0x063f018a] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x62200, retVal=0x0)
@75,087,408us: [+6 T:0x063f018a] OM - Memory_contigAlloc> Warning: non-default alignment not supported for pool-based allocations, using default #x.
@75,113,408us: [+4 T:0x063f018a] OM - Memory_contigAlloc> CMEM_alloc(1) = 0x900000.
@75,127,408us: [+4 T:0x063f018a] OM - Memory_contigAlloc> CMEM_getPhys(0x900000) = 0x872ff000.
@75,145,408us: [+2 T:0x063f018a] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1 at 0x900000 (0x872ff000 phys)
@75,163,408us: [+0 T:0x063f018a] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x62200, inBufs=0x5ef7c, outBufs=0x5ef08, inArgs=0x5eeb8, outArgs=0x5f044)
@75,193,408us: [+5 T:0x063f018a] CV - VISA_allocMsg> Allocating message for messageId=0x0002bb46
@75,211,408us: [+0 T:0x063f018a] CV - VISA_call(visa=0x62200, msg=0x101880): messageId=0x0002bb46, command=0x0
[DSP] @8,809,954tk: [+5 T:0x87ee98cc] CN - NODE> 0x87ee9100(h264dec#0) call(algHandle=0x87ee91c0, msg=0x87305880); messageId=0x0002bb46
[DSP] @8,810,044tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> Enter(addr=0x872ff000, sizeInBytes=1)
[DSP] @8,810,104tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> return
[DSP] @8,810,144tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> Enter(addr=0x870e0000, sizeInBytes=811008)
[DSP] @8,811,078tk: [+0 T:0x87ee98cc] OM - Memory_cacheInv> return
[DSP] @8,811,120tk: [+0 T:0x87ee98cc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2lgorithm - Algorithm_activate>al=0x0)
[DSP] @8,811,672tk: [+5 T:0x87ee98cc] CN - NODE> returned from call(algHandle=0x87ee91c0, msg=0x87305880); mesDEC2 - VIDDEC2_process> Exit (handle=0x62200, retVal=0x0)
00)
@75,645,408us: [+0 T:0x063f018a] CV - VISA_delete(0x62200)
@75,655,408us: [+5 T:0x063f018a] CV - VISA_delete> def018a] ti.sdo.dmai - [Buffer] Free Buffer of size 811008 at 0x700000 (0x86ee0000 phys)
@75,749,408us: [+2 T:0x063f018aT:0x87ee98cc] CN - NODE_EXECFX[+5 T:0x87ee45f4] CV - VISA_delete> deleting codec 0x87ee91f0
[DSP] @9,130,433tk: [+0 T:x87ee91c0, size=48)
[DSP] @9,130,837tk: [+0 T:0x87ee45f4] 9,131,125tk: [+0 T:0x87ee45f4]nnectTrace('0x61c20', 0x0)
@76,161,408us: [+0 T:0x063f018a] CS - Server_connectTrace> re40]
@76,243,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x61760] timeout[0xffffffff]
@76,265onnect> Calling LPM_disconnectrom DSP...
@76,459,408us: [+2 T:0x066b009a] OP - Processor_delete_d> Destroying DSP... (object, that is)
@76,465,408_delete_d> return
@76,541,408us: [+0 T:0x066b009a] ti.sdo.ce.osal.Sem - Entered Sem_post,408us: [+0 T:0x063f018a] OP - Processor_delete> return.
@76,657,408us: [+0 T:0x063f018a@76,975,408us: [+0 T:0x063f018a] OP - doCmd> Enter (cmdId=3, proc=0x0)
@76,975,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x61740]
@76,991,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Seem[0x61760] timeout[0xffffffffce.osal.Sem - Leaving Sem_pend@77,231,408us: [+0 T:0x063f018a] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x61760] statu=0x617a0)
@77,261,408us: [+4 T:0x063f018a] OT - Thread_delete> TerminateThread() (0x0)
Sem_delete> sem[0x61760]
@77,349,408us: [+0 T:0x063f018a]
it seems like everything goes well
but after i use gmake to produce the all.X64P,all_pm.x64p, app_remote_wince.exe files
which is in
C:\Ti\dvsdk_wince\dvsdk_wince_1_00_00_05\codec_engine_2_24_01\examples\ti\sdo\ce\examples
for example image1_copy
i copy those files to the root of my_device
and run
the serial message below indicate sth is error
@4286,646,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@4286,648,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x506c0]
@4286,664,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@4286,678,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x506e0]
@4286,694,704us: [+0 T:0x0615017a] OT - Thread_create> Enter (fxn=0x29558, attrs=0x0)
@4286,714,704us: [+0 T:0x0615017a] OT - Thread_create> Exit (task=0x50720)
@4286,726,704us: [+0 T:0x0615017a] ti.sdo.ce.alg - ALG_init> Enter
@4286,734,704us: [+0 T:0x0615017a] ti.sdo.ce.alg - ALG_init> Exit
@4286,750,704us: [+6 T:0x0615017a] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed
@4286,772,704us: [+0 T:0x0615017a] CS - Server_init()
@4286,780,704us: [+0 T:0x0615017a] CS - Server_init> Global_useLinkArbiter = 0
@4286,794,704us: [+2 T:0x0615017a] ti.sdo.ce.examples.apps.image1_copy - main>
@4286,814,704us: [+1 T:0x061e009e] OP - daemon> thread created.
@4286,826,704us: [+1 T:0x0615017a] ti.sdo.ce.examples.apps.image1_copy - App-> Application
started.
@4286,844,704us: [+0 T:0x061e009e] OP - getCmd_d> Enter (proc=0xafe3c)
@4286,856,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_alloc(1024) = 0xb0000.
@4286,872,704us: [+0 T:0x061e009e] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x506c0]
timeout[0xffffffff]
@4286,890,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_getPhys(0xb0000) =
0x872fc000.
@4286,908,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_alloc(1024) = 0xc0000.
@4286,924,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_getPhys(0xc0000) =
0x872fd000.
@4286,940,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_alloc(1024) = 0xd0000.
@4286,956,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_getPhys(0xd0000) =
0x872fe000.
@4286,974,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_alloc(128) = 0xe0000.
@4286,988,704us: [+4 T:0x0615017a] OM - Memory_contigAlloc> CMEM_getPhys(0xe0000) =
0x872ff000.
@4287,010,704us: [+0 T:0x0615017a] CE - Engine_open> Enter('image1_copy', 0x0, 0x4fb38)
@4287,022,704us: [+0 T:0x0615017a] CE - rserverOpen('all.x64P'), count = 0
@4287,036,704us: [+0 T:0x0615017a] OP - Processor_create> Enter(imageName='all.x64P',
linkCfg='(null)', attrs=0x4facc)
@4287,058,704us: [+0 T:0x0615017a] OP - doCmd> Enter (cmdId=1, proc=0x50cc0)
@4287,070,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x506c0]
@4287,086,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x506c0]
@4287,110,704us: [+0 T:0x061e009e] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x506c0]
status[0]
@4287,118,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x506e0]
timeout[0xffffffff]
@4287,138,704us: [+0 T:0x061e009e] OP - getCmd_d> Exit (result=1)
@4287,150,704us: [+0 T:0x061e009e] OP - Processor_create_d> Enter(proc=0x50cc0)
@4287,164,704us: [+0 T:0x061e009e] ti.sdo.ce.ipc.Power - Power_on> Enter(handle=0x50cdc)
@4287,180,704us: [+2 T:0x061e009e] ti.sdo.ce.ipc.Power - Power_on> Opening Local Power
@4287,202,704us: [+2 T:0x061e009e] ti.sdo.ce.ipc.Power - Power_on> Turning on DSP power...
@4287,218,704us: [+2 T:0x061e009e] ti.sdo.ce.ipc.Power - Power_on> return (0)
@4287,232,704us: [+2 T:0x061e009e] OP - Processor_create_d> Initializing DSP PROC...
@4287,246,704us: [+2 T:0x061e009e] OP - Processor_create_d> Using DspLink config data for
entry #0 [server 'all.x64P']
@4287,268,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #0 to Link
configuration: name='DDR2', startAddress=0x87800000, sizeInBytes=0x600000, shared=1, syncd=0
@4287,300,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #1 to Link
configuration: name='DSPLINKMEM', startAddress=0x87e00000, sizeInBytes=0x100000, shared=1,
syncd=0
@4287,334,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #2 to Link
configuration: name='RESET_VECTOR', startAddress=0x87f00000, sizeInBytes=0x1000, shared=1,
syncd=0
@4287,366,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #3 to Link
configuration: name='IVAMMU', startAddress=0x5d000000, sizeInBytes=0x1000, shared=0, syncd=0
@4287,398,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #4 to Link
syncd=0
@4287,432,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #5 to Link
@4287,464,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #6 to Link
configuration: name='L1DSRAM', startAddress=0x5cf04000, sizeInBytes=0xc000, shared=1,
syncd=0
@4287,496,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #7 to Link
configuration: name='DDRALGHEAP', startAddress=0x86000000, sizeInBytes=0x1800000, shared=0,
syncd=0
@4287,530,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #8 to Link
syncd=0
@4287,562,704us: [+2 T:0x061e009e] OP - Processor_create_d> Found 'CMEM' entry, adjusting
@4287,586,704us: [+0 T:0x061e009e] OP - Processor_create_d> Setting CMEM base to 0x86300000,
size to 0x1000000
@4287,606,704us: [+2 T:0x061e009e] OP - Processor_create_d> Adding DSP segment #9 to Link
syncd=0
@4287,638,704us: [+2 T:0x061e009e] OP - Processor_create_d> DODSPCTRL was=0; now=0
@4287,654,704us: [+3 T:0x061e009e] OP - LINKCFG_Object generated for PROC_setup(p) ...
@4287,668,704us: [+3 T:0x061e009e] OP - linkCfg->gppObject->
@4287,678,704us: [+3 T:0x061e009e] OP - name = "ARM9"
@4287,688,704us: [+3 T:0x061e009e] OP - maxMsgqs = 0x82
@4287,700,704us: [+3 T:0x061e009e] OP - maxChnlQueue = 0x10
@4287,710,704us: [+3 T:0x061e009e] OP - poolTableId = 0xffffffff
@4287,722,704us: [+3 T:0x061e009e] OP - numPools = 0x0
@4287,732,704us: [+3 T:0x061e009e] OP -
@4287,740,704us: [+3 T:0x061e009e] OP - linkCfg->dspConfigs[0]->dspObject->
@4287,754,704us: [+3 T:0x061e009e] OP - name = "OMAP3530"
@4287,764,704us: [+3 T:0x061e009e] OP - dspArch = 0x2
@4287,774,704us: [+3 T:0x061e009e] OP - loaderName = "COFF"
@4287,786,704us: [+3 T:0x061e009e] OP - autoStart = FALSE
@4287,796,704us: [+3 T:0x061e009e] OP - execName = "DEFAULT.OUT"
@4287,810,704us: [+3 T:0x061e009e] OP - doDspCtrl = DSP_BootMode_Boot_NoPwr
@4287,822,704us: [+3 T:0x061e009e] OP - resumeAddr = 0x87f00020
@4287,834,704us: [+3 T:0x061e009e] OP - resetVector = 0x87f00000
@4287,846,704us: [+3 T:0x061e009e] OP - resetCodeSize = 0x1000
@4287,858,704us: [+3 T:0x061e009e] OP - maduSize = 0x1
@4287,868,704us: [+3 T:0x061e009e] OP - cpuFreq = 0x6ddd0
@4287,880,704us: [+3 T:0x061e009e] OP - endian = 0x3
@4287,890,704us: [+3 T:0x061e009e] OP - wordSwap = 0x0
@4287,900,704us: [+3 T:0x061e009e] OP - memTableId = 0x0
@4287,910,704us: [+3 T:0x061e009e] OP - memEntries = 0xa
@4287,922,704us: [+3 T:0x061e009e] OP - linkDrvId = 0x0
@4287,932,704us: [+3 T:0x061e009e] OP - arg1 = 0xffffffff
@4287,942,704us: [+3 T:0x061e009e] OP - arg2 = 0xffffffff
@4287,954,704us: [+3 T:0x061e009e] OP - arg3 = 0x0
@4287,962,704us: [+3 T:0x061e009e] OP - arg4 = 0x0
@4287,972,704us: [+3 T:0x061e009e] OP - arg5 = 0xffffffff
@4287,984,704us: [+3 T:0x061e009e] OP -
@4287,990,704us: [+3 T:0x061e009e] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
@4288,006,704us: [+3 T:0x061e009e] OP - name = "SHMDRV"
@4288,016,704us: [+3 T:0x061e009e] OP - hshkPollCount = 0x989680
@4288,028,704us: [+3 T:0x061e009e] OP - memEntry = 0x1
@4288,038,704us: [+3 T:0x061e009e] OP - ipsTableId = 0x0
@4288,048,704us: [+3 T:0x061e009e] OP - numIpsEntries = 0x1
@4288,060,704us: [+3 T:0x061e009e] OP - poolTableId = 0x0
@4288,070,704us: [+3 T:0x061e009e] OP - numPools = 0x1
@4288,080,704us: [+3 T:0x061e009e] OP - dataTableId = 0x0
@4288,092,704us: [+3 T:0x061e009e] OP - numDataDrivers = 0x1
@4288,104,704us: [+3 T:0x061e009e] OP - mqtId = 0x0
@4288,112,704us: [+3 T:0x061e009e] OP - ringIoTableId = 0x0
@4288,124,704us: [+3 T:0x061e009e] OP - mplistTableId = 0x0
@4288,136,704us: [+3 T:0x061e009e] OP - mpcsTableId = 0x0
@4288,146,704us: [+3 T:0x061e009e] OP -
@4288,154,704us: [+3 T:0x061e009e] OP - linkCfg->dspConfigs[0]->memTables[0][i].
@4288,168,704us: [+3 T:0x061e009e] OP - entry #0:
@4288,176,704us: [+3 T:0x061e009e] OP - entry = 0x0
@4288,186,704us: [+3 T:0x061e009e] OP - name = "DDR2"
@4288,196,704us: [+3 T:0x061e009e] OP - physAddr = 0x87800000
@4288,208,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x87800000
@4288,220,704us: [+3 T:0x061e009e] OP - gppVirtAddr = 0xffffffff
@4288,232,704us: [+3 T:0x061e009e] OP - size = 0x600000
@4288,242,704us: [+3 T:0x061e009e] OP - shared = TRUE
@4288,252,704us: [+3 T:0x061e009e] OP - syncd = FALSE
@4288,264,704us: [+3 T:0x061e009e] OP - entry #1:
@4288,272,704us: [+3 T:0x061e009e] OP - entry = 0x1
@4288,282,704us: [+3 T:0x061e009e] OP - name = "DSPLINKMEM"
@4288,294,704us: [+3 T:0x061e009e] OP - physAddr = 0x87e00000
@4288,304,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x87e00000
@4288,316,704us: [+3 T:0x061e009e] OP - gppVirtAddr = 0xffffffff
@4288,328,704us: [+3 T:0x061e009e] OP - size = 0x100000
@4288,340,704us: [+3 T:0x061e009e] OP - shared = TRUE
@4288,350,704us: [+3 T:0x061e009e] OP - syncd = FALSE
@4288,360,704us: [+3 T:0x061e009e] OP - entry #2:
@4288,368,704us: [+3 T:0x061e009e] OP - entry = 0x2
@4288,378,704us: [+3 T:0x061e009e] OP - name = "RESET_VECTOR"
@4288,390,704us: [+3 T:0x061e009e] OP - physAddr = 0x87f00000
@4288,402,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x87f00000
@4288,414,704us: [+3 T:0x061e009e] OP - gppVirtAddr = 0xffffffff
@4288,426,704us: [+3 T:0x061e009e] OP - size = 0x1000
@4288,436,704us: [+3 T:0x061e009e] OP - shared = TRUE
@4288,446,704us: [+3 T:0x061e009e] OP - syncd = FALSE
@4288,456,704us: [+3 T:0x061e009e] OP - entry #3:
@4288,464,704us: [+3 T:0x061e009e] OP - entry = 0x3
@4288,474,704us: [+3 T:0x061e009e] OP - name = "IVAMMU"
@4288,484,704us: [+3 T:0x061e009e] OP - physAddr = 0x5d000000
@4288,496,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x5d000000
@4288,508,704us: [+3 T:0x061e009e] OP - gppVirtAddr = 0xffffffff
@4288,520,704us: [+3 T:0x061e009e] OP - size = 0x1000
@4288,530,704us: [+3 T:0x061e009e] OP - shared = FALSE
@4288,540,704us: [+3 T:0x061e009e] OP - syncd = FALSE
@4288,552,704us: [+3 T:0x061e009e] OP - entry #4:
@4288,560,704us: [+3 T:0x061e009e] OP - entry = 0x4
@4288,570,704us: [+3 T:0x061e009e] OP - name = "L4PER"
@4288,580,704us: [+3 T:0x061e009e] OP - physAddr = 0x49000000
@4288,592,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x49000000
@4288,604,704us: [+3 T:0x061e009e] OP - gppVirtAddr = 0xffffffff
@4288,616,704us: [+3 T:0x061e009e] OP - size = 0x100000
@4288,626,704us: [+3 T:0x061e009e] OP - shared = FALSE
@4288,636,704us: [+3 T:0x061e009e] OP - syncd = FALSE
@4288,646,704us: [+3 T:0x061e009e] OP - entry #5:
@4288,656,704us: [+3 T:0x= 0x5c7f8000
@4288,688,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x107f8000
@4288,
@4288,782,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x10f04000
@4288,794,704us: [+3 T:0x061e009e] OP - gppVirtAP"
@4288,866,704us: [+3 T:0x061e009e] OP - physAddr = 0x86000000
@4288,878,704us: [+3 T:0x061e009e] OP - dspVirtAddr = 0x86000000
@4288,890 [+3 T:0x061e009e] OP - name"
@4288,962,704us: [+3 T:0x0704us: [+3 T:0x061e009e] OP - entry = 0x9
@4289,048,704us: [+3 T:0x061e009e] OP - name = "CMEM"
@4289,058,704us:289,126,704us: [+3 T:0x061e009e] OP -
@4289,132,704us: [+e] OP - dspIntId = 0x37
@4289,208,704us: [+3 T:0x061e009e] OP - dspIntVectorId = 0x5
@4289,220,704us: [+3 T:0x06061e009e] OP - entry #0:
@4289,294,704us: [+3 T:0x061e009ePerChnl = 0x1
@4289,368,704us: [+3 T:0x061e009e] OP - ipsId = 0x0
@4289,378,704us: [+3 T:0x061e009e] OP - ipsEventNo = 0x1
@4289,388,704us: 62,704us: [+3 T:0x061e009e] OP:0x061e009e] OP - memEntry = 0x1
@4289,544,704us: [+3 T:0x061e009e] OP - maxEntries = 0x40
@4289,556,704us: [+3 T:0x061e009e] OP - ipsId = 09e] OP - maxEntries = 0x40
@4289,630,704us: [+3 T:0x061entries = 0x100
@4289,706,704us: [+3 T:0x061e009e] OP - ipsId = 0xffffffff
@4289,718,704us: [+3 T:0x061e009e] OP - SP server 'all.x64P' FAILED, status=[0x80008050]
(look for e: [+2 T:0x061e009e] OP - Processor_delete_d> Stopping DSP...
@4289,876,704us: [+6 T:0x061e009e] OP - Processor_delete_289,958,704us: [+2 T:0x061e009...
(object, that is)
@4289,e] ti.sdo.ce.osal.Sem - Leavin> sem[0x506e0]
@4290,098,704: [+0 T:0x061e009e] OP - getCmd_d> Enter (proc=0xafe3c)
@4 start 'all.x64P'; Processor_ced
@4290,216,704us: [+0 T:0x@4290,390,704us: [+1 T:0x0615017a]
ti.sdo.ce.examples.apps.image1_copy - app done.
@4290,394,704us: [+0 T:0x0615017a] OP - doCmd> Enter (cmdId=3, pr sem[0x506c0] status[0]
@4290,474,704us: [+0 T:0x061e009e]T - Thread_delete> Enter (task=0x50720)
@4290,560,704us: [+4 T:0x0615017a] OT - Thread_delete> TerminateThread() (0x0)17a]
ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x506e0]
@4290,648,704us: [+0 T:0x0615017a] ti.sdo.ce.osal.Sem - Lea
i don't konw where is wrong .
