evmdm6437 6437 audio
Dear sir,
Am doing audio processing on DM6437 with CCSv6.2,but i cant able to set the sampling frequency ,EVMDM6437_AIC33_setFreq(hCodec, 1) as we did in DSK6713[DSK6713_AIC23_setFreq(hCodec, 1)]............Here is my code and project,please let me know is my project is right and if not,let me know the changes.
thank you.
  • #include "evmdm6437.h"
    #include "evmdm6437_aic33.h"
    float filter_Coeff[] ={0.000000,-0.013457,-0.023448,-0.025402,-0.017127,-0.000000,0.020933,0.038103,0.043547,0.031399,
    0.000000,-0.047098,-0.101609,-0.152414,-0.188394,0.805541,-0.188394,-0.152414,-0.101609,-0.047098,
    0.000000,0.031399,0.043547,0.038103,0.020933,-0.000000,-0.017127,-0.025402,-0.023448,-0.013457,
    0.000000
    static short in_buffer[100];
    static AIC33_Config config = {
    0, // 0 Page Select <- [Page=0]
    READONLY, // 1 Software Reset <- [ResetOnly]
    0, // 2 Codec Sample Rate Select <- [ADC=FS][DAC=FS]
    // For: [FS=48 kHz][MCLK=22.5792 MHz]
    0x92, // 3 PLL A <- [PLL=ON][P=2][Q=2]
    0x20, // 4 PLL B <- [J=8]
    0x6E, // 5 PLL C <- [D=7075]
    0x23, // 6 PLL D <- [D=7075]
    0x0A, // 7 Codec Datapath Setup <- [FS=48 kHz][LeftDACPlays=left][RightDACPlays=right]
    0xC0, // 8 Audio Serial Data A <- [BCLK=Master][WCLK=Master][3DEffects=OFF][DigitalMIC=OFF]
    0, // 9 Audio Serial Data B <- [Mode=I2S][Length=16-bit][TransferMode=Continous]
    0, // 10 Audio Serial Data C <- [DataOffset=0]
    READONLY, // 11 Audio Codec Overflow Flag <- [ReadOnly]
    0, // 12 Audio Codec Digital Filter <- [OFF]
    0, // 13 Headset Detection A <- [OFF]
    0, // 14 Headset Detection B <- []
    0, // 15 Left ADC PGA Gain <- [Mute=OFF]
    0, // 16 Right ADC PGA Gain <- [Mute=OFF]
    0xFF, // 17 MIC3L/R to Left ADC <- [OFF]
    0xFF, // 18 MIC3L/R to Right ADC <- [OFF]
    0x04, // 19 LINE1L to Left ADC <- [SingleEnd][Gain=0dB][Power=ON][SoftStep=OncePerFS]
    0x78, // 20 LINE2L to Left ADC <- [OFF]
    0x78, // 21 LINE1R to Left ADC <- [OFF]
    0x04, // 22 LINE1R to Right ADC <- [SingleEnd][Gain=0dB][Power=ON][SoftStep=OncePerFS]
    0x78, // 23 LINE2R to Right ADC <- [OFF]
    0x78, // 24 LINE1L to Right ADC <- [OFF]
    0, // 25 MICBIAS <- [Power=OFF]
    0, // 26 Left AGC A <- [LeftAGC=OFF]
    0, // 27 Left AGC B <- [OFF]
    0, // 28 Left AGC C <- [OFF]
    0, // 29 Right AGC A <- [RightAGC=OFF]
    0, // 30 Right AGC B <- [OFF]
    0, // 31 Right AGC C <- [OFF]
    READONLY, // 32 Left AGC Gain <- [ReadOnly]
    READONLY, // 33 Right AGC Gain <- [ReadOnly]
    0, // 34 Left AGC Noise Debounce <- []
    0, // 35 Right AGC Noise Debounce <- []
    READONLY, // 36 ADC Flag <- [ReadOnly]
    0xE0, // 37 DAC Power & Output Dvr <- [LeftDAC=ON][RightDAC=ON][HPLCOM=SingleEnd]
    0x10, // 38 High Power Output Dvr <- [HPRCOM=SingleEnd][ShortCircuit=OFF]
    RESERVED, // 39 <- [Reserved]
    0, // 40 High Power Output Stage <- []
    0, // 41 DAC Output Switching <- []
    0, // 42 Output Driver Pop Reduction <- []
    0, // 43 Left DAC Digital Volume <- [Mute=OFF][Gain=0dB]
    0, // 44 Right DAC Digital Volume <- [Mute=OFF][Gain=0dB]
    0, // 45 Line2L to HPLOUT Volume <- []
    0, // 46 PGA_L to HPLOUT Volume <- []
    0x80, // 47 DAC_L1 to HPLOUT Volume <- [Routed]
    0, // 48 LINE2R to HPLOUT Volume <- []
    0, // 49 PGA_R to HPLOUT Volume <- []
    0, // 50 DAC_R1 to HPLOUT Volume <- []
    0x09, // 51 HPLOUT Output <- [Mute=OFF][Power=ON]
    0, // 52 LINE2L to HPLCOM Volume <- []
    0, // 53 PGA_L to HPLCOM Volume <- []
    0, // 54 DAC_L1 to HPLCOM Volume <- []
    0, // 55 LINE2R to HPLCOM Volume <- []
    0, // 56 PGA_R to HPLCOM Volume <- []
    0, // 57 DAC_R1 to HPLCOM Volume <- []
    0, // 58 HPLCOM Output <- []
    0, // 59 LINE2L to HPROUT Volume <- []
    0, // 60 PGA_L to HPROUT Volume <- []
    0, // 61 DAC_L1 to HPROUT Volume <- []
    0, // 62 LINE2R to HPROUT Volume <- []
    0, // 63 PGA_R to HPROUT Volume <- []
    0x80, // 64 DAC_R1 to HPROUT Volume <- [Routed]
    0x09, // 65 HPROUT Output <- [Mute=OFF][Power=ON]
    0, // 66 LINE2L to HPRCOM Volume <- []
    0, // 67 PGA_L to HPRCOM Volume <- []
    0, // 68 DAC_L1 to HPRCOM Volume <- []
    0, // 69 LINE2R to HPRCOM Volume <- []
    0, // 70 PGA_R to HPRCOM Volume <- []
    0, // 71 DAC_R1 to HPRCOM Volume <- []
    0, // 72 HPRCOM Output <- []
    0, // 73 LINE2L to MONO_LOP/M Volume <- []
    0, // 74 PGA_L to MONO_LOP/M Volume <- []
    0, // 75 DAC_L1 to MONO_LOP/M Volume <- []
    0, // 76 LINE2R to MONO_LOP/M Volume <- []
    0, // 77 PGA_R to MONO_LOP/M Volume <- []
    0, // 78 DAC_R1 to MONO_LOP/M Volume <- []
    0, // 79 MONO_LOP/M Output <- []
    0, // 80 LINE2L to LEFT_LOP/M Volume <- []
    0, // 81 PGA_L to LEFT_LOP/M Volume <- []
    0x80, // 82 DAC_L1 to LEFT_LOP/M Volume <- [Routed]
    0, // 83 LINE2R to LEFT_LOP/M Volume <- []
    0, // 84 PGA_R to LEFT_LOP/M Volume <- []
    0, // 85 DAC_R1 to LEFT_LOP/M Volume <- []
    0x09, // 86 LEFT_LOP/M Output <- [Mute=OFF][Power=ON]
    0, // 87 LINE2L to RIGHT_LOP/M Volume <- []
    0, // 88 PGA_L to RIGHT_LOP/M Volume <- []
    0, // 89 DAC_L1 to RIGHT_LOP/M Volume <- []
    0, // 90 LINE2R to RIGHT_LOP/M Volume <- []
    0, // 91 PGA_R to RIGHT_LOP/M Volume <- []
    0x80, // 92 DAC_R1 to RIGHT_LOP/M Volume <- [Routed]
    0x09, // 93 RIGHT_LOP/M Output <- [Mute=OFF][Power=ON]
    READONLY, // 94 Module Power Status <- [ReadOnly]
    READONLY, // 95 Short Circuit Detection <- [ReadOnly]
    RESERVED, // 96 <- [Reserved]
    RESERVED, // 97 <- [Reserved]
    0, // 98 GPIO1 <- []
    0, // 99 GPIO2 <- []
    0, // 100 Additional GPIO Control A <- []
    0 // 101 Additional GPIO Control B <- []
    * main() - Main code routine, initializes BSL and generates tone
    void main()
    AIC33_CodecHandle hCodec;
    Int32 l_input, r_input,l_output, r_output;
    /* Initialize the board support library, must be called first */
    EVMDM6437_init( );
    /* Start the codec */
    hCodec = EVMDM6437_AIC33_openCodec (0, &config);
    //EVMDM6437_AIC33_setFreq(hCodec, 1);
    while(1)
    { /* Read a sample to the left channel */
    while (!EVMDM6437_AIC33_read32(hCodec, &l_input));
    /* Read a sample to the right channel */
    while (!EVMDM6437_AIC33_read32(hCodec, &r_input));
    l_output=(Int16)FIR_FILTER(&filter_Coeff ,l_input);
    r_output=l_output;
    /* Send a sample to the left channel */
    while (!EVMDM6437_AIC33_write32(hCodec, l_output));
    /* Send a sample to the right channel */
    while (!EVMDM6437_AIC33_write32(hCodec, r_output));
    /* Close the codec */
    EVMDM6437_AIC33_closeCodec(hCodec);
    signed int FIR_FILTER(float * h, signed int x)
    int i=0;
    signed long output=0;
    in_buffer[0] = x; /* new input at buffer[0] */
    for(i=30;i>0;i--)
    in_buffer[i] = in_buffer[i-1]; /* shuffle the buffer */
    for(i=0;i<32;i++)
    output = output + h[i] * in_buffer[i];
    return(output);
  • Dear sir,
    waiting for your reply.
    thank you.
  • Hi All,
    waiting for you reply.
    thank you.
    waiting for your response.
    thank you.
  • Hi All,
    thank you.
