HI,
I am on using AM57xx Linux SDK 3.1.6. About the filesystem. the Systemd has replaced the Sys V.
I have known how to add a startup items under systemd mechanism. But I found some confusing issue
in Ti orignal filesystem.
I know "to startup a service , you must add a foo.service file. and systemctrl enable foo".
But about the matrix-gui2.0 , tiipclad-daemon and so on such services. I just found these service file
in :
/run/systemd/generator.late/tiipclad-daemon.service /run/systemd/generator.late/graphical.target.wants/tiipclad-daemon.service /run/systemd/generator.late/multi-user.target.wants/tiipclad-daemon.service /sys/fs/cgroup/devices/system.slice/tiipclad-daemon.service /sys/fs/cgroup/pids/system.slice/tiipclad-daemon.service /sys/fs/cgroup/systemd/system.slice/tiipclad-daemon.service
and no .service in other area(eg. /etc/systemd or /lib/systemd/system/). why?
when I cat the first file, an infomation "# Automatically generated by systemd-sysv-generator"
in this file content.
That is , these is generated by systemd-sysv-generator.
What control the systemd to generate these file, and how can I set these configuration?
I have ever seen a world " Once systemd look this service no unit. it will to lookup the init.d/ script to match
the service name . if matched, it will generate the service 's .service file in /run/systemd/generated.late/."
is right ?
Thank you very much!
Best Regards
Qing
