AM57x PDK rebuild does not work
I've tried to build the pdk, but following the directions just plain does not work.
I wipe out my pdk directory to make sure I've got a clean install, then install the sdk which gives me a clean untouched pdk. Then I try pdksetupenv.bat.
C:\ti\pdk_am57xx_1_0_4\packages>pdksetupenv.bat
Optional parameter not configured : CG_XML_BIN_INSTALL_PATH
REQUIRED for xdc release build
Example: set CG_XML_BIN_INSTALL_PATH=C:/ti/cg_xml/bin
Optional parameter not configured : DOXYGEN_INSTALL_PATH
Example: set DOXYGEN_INSTALL_PATH=C:/ti/Doxygen/doxygen/1.5.1-p1/bin
Environment Configuration:
    LIMIT_SOCS                : am571x am572x
    LIMIT_BOARDS              : evmAM572x idkAM571x idkAM572x
    PDK_INSTALL_PATH          : /ti/PD23B8~1/packages/
    C6X_GEN_INSTALL_PATH      : C:/ti/ccsv6/tools/compiler/ti-cgt-c6000_8.1.0
    TOOLCHAIN_PATH_A15        : C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9
-2015q3
    TOOLCHAIN_PATH_A8         : C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9
-2015q3
    TOOLCHAIN_PATH_A9         : C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9
-2015q3
    TOOLCHAIN_PATH_M4         : C:/ti/ccsv6/tools/compiler/ti-cgt-arm_15.12.1.LT
S
    FPULIB_PATH               : C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9
-2015q3/lib/gcc/arm-none-eabi/4.9.3/fpu
    CROSS_TOOL_PRFX           : arm-none-eabi-
    XDC_INSTALL_PATH          : C:/ti/xdctools_3_32_00_06_core
    BIOS_INSTALL_PATH         : C:/ti/bios_6_45_01_29
    IPC_INSTALL_PATH          : C:/ti/ipc_3_43_02_04
    EDMA3LLD_BIOS6_INSTALLDIR : C:/ti/edma3_lld_2_12_01_25
    NDK_INSTALL_PATH          : C:/ti/ndk_2_24_03_35
    IMGLIB_INSTALL_PATH       : C:/ti/imglib_c66x_3_1_1_0
    UIA_INSTALL_PATH          : C:/ti/uia_2_00_03_43
Changing to short name to support directory names containing spaces
current directory: /ti/PD23B8~1/packages/
PDK BUILD ENVIRONMENT CONFIGURED
Then I do gmake clean or gmake csl_clean and after lots of printing, I do gmake all or gmake csl. Neither work. Here's the results for gmake csl.
C:\ti\PD23B8~1\packages>gmake csl
gmake -C ./ti/csl all
gmake[1]: Entering directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake libcores SOC=am572x
gmake[2]: Entering directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake lib_allendians CORE=a15_0 BUILD_PROFILE_a15_0=release
gmake[3]: Entering directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake comp_libs ENDIAN=little
gmake[4]: Entering directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake -C /ti/PD23B8~1/packages//ti/csl/arch -fmakefile_init.mk
gmake[5]: Entering directory `C:/ti/PD23B8~1/packages/ti/csl/arch'
# Compiling am572x:a15_0:release:csl_init: a15/src/exceptionhandler.asm
C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc -c
 -x assembler-with-cpp -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-prag
mas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloa
t-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG     -DSOC_
AM572x          -IC:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_9-2015q3/arm-no
ne-eabi/include -I. -Ia15/src -Ia15 -I/ti/PD23B8~1/packages/ -I/ti/PD23B8~1/pack
ages//ti/csl -I/ti/PD23B8~1/packages//ti/csl -I/apps/apps_nonbam/inc -I/ -I/comm
on -o /ti/PD23B8~1/packages//ti/binary/ti/csl/arch/obj/am572x/a15/release/except
ionhandler.oa15fg a15/src/exceptionhandler.asm
process_begin: CreateProcess(NULL, C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-
4_9-2015q3/bin/arm-none-eabi-gcc -c -x assembler-with-cpp -DMAKEFILE_BUILD -Wimp
licit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -m
cpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7
 -Werror -O2 -s -DNDEBUG -DSOC_AM572x -IC:/ti/ccsv6/tools/compiler/gcc-arm-none-
eabi-4_9-2015q3/arm-none-eabi/include -I. -Ia15/src -Ia15 -I/ti/PD23B8~1/package
s/ -I/ti/PD23B8~1/packages//ti/csl -I/ti/PD23B8~1/packages//ti/csl -I/apps/apps_
nonbam/inc -I/ -I/common -o /ti/PD23B8~1/packages//ti/binary/ti/csl/arch/obj/am5
72x/a15/release/exceptionhandler.oa15fg a15/src/exceptionhandler.asm, ...) faile
d.
make (e=2): The system cannot find the file specified.
gmake[5]: *** [/ti/PD23B8~1/packages//ti/binary/ti/csl/arch/obj/am572x/a15/relea
se/exceptionhandler.oa15fg] Error 2
gmake[5]: Leaving directory `C:/ti/PD23B8~1/packages/ti/csl/arch'
gmake[4]: *** [csl_init] Error 2
gmake[4]: Leaving directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake[3]: *** [little_lib] Error 2
gmake[3]: Leaving directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake[2]: *** [a15_0_lib] Error 2
gmake[2]: Leaving directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake[1]: *** [am572x_lib] Error 2
gmake[1]: Leaving directory `C:/ti/PD23B8~1/packages/ti/csl'
gmake: *** [csl] Error 2
