环境:
dvsdk_2_00_00_22
dm6467_h264fhdvenc_01_10_02_03_production dm6467_hdvicp_1_01_017_production
server.cfg
/* set up OSAL */
var osalGlobal = xdc.useModule('ti.sdo.ce.osal.Global');
osalGlobal.runtimeEnv = osalGlobal.DSPLINK_BIOS;
osalGlobal.traceBufferSize = 0x40000;
/* configure default memory seg id to BIOS-defined "DDR" */
osalGlobal.defaultMemSegId = "DDR2";
/* Enable DSP-side BIOS logging */
var LogServer = xdc.useModule('ti.sdo.ce.bioslog.LogServer');
* ======== Server Configuration ========
var Server = xdc.useModule('ti.sdo.ce.Server');
Server.threadAttrs.stackSize = 16384;
* The optional stack pad to add to non-configured stacks. This is well
* beyond most codec needs, but follows the approach of "start big and
* safe, then optimize when things are working."
Server.stackSizePad = 9000;
/* get various codec modules; i.e., implementation of codecs */
var H264FHDVENC = xdc.useModule('ti.sdo.codecs.h264fhdvenc.ce.H264FHDVENC');
var H264ENC = xdc.useModule('ti.sdo.codecs.h264enc.ce.H264ENC');
var AACHEENC = xdc.useModule('ti.sdo.codecs.aacheenc.ce.AACHEENC');
var G711ENC = xdc.useModule('ti.sdo.codecs.g711enc.ce.G711ENC');
xdc.useModule('ti.sdo.codecs.hdvicp2.HDVICP');
if (prog.build.cfgArgs.profile == "eval"){
print("Configuring server to use watermarked codecs...");
H264FHDVENC.alg.watermark = true;
H264ENC.alg.watermark = true;
AACHEENC.alg.watermark = true;
G711ENC.alg.watermark = true;
else
H264FHDVENC.alg.watermark = false;
H264ENC.alg.watermark = false;
AACHEENC.alg.watermark = false;
G711ENC.alg.watermark = false;
H264FHDVENC.alg.codeSection = "DDR2";
H264FHDVENC.alg.intMemSection = "IRAM";
H264ENC.alg.codeSection = "DDR2";
//H264ENC.alg.intMemSection = "IRAM";
/* Switching off Outs Bufs Cache */
H264FHDVENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
H264ENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
Server.algs = [
{name: "h264fhdvenc", mod: H264FHDVENC,groupId:0,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 1}
{name: "h264enc", mod: H264ENC,groupId:0,threadAttrs: {
{name: "aacheenc", mod: AACHEENC,groupId:1,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 2}
{name: "g711enc", mod: G711ENC,groupId:1,threadAttrs: {
* ======== DSKT2 and RMAN Configuration ========
* XDAIS Algorithm Memory and DMA allocation
var DSKT2 = xdc.useModule('ti.sdo.fc.dskt2.DSKT2');
DSKT2.DARAM0 = "IRAM";
DSKT2.DARAM1 = "IRAM";
DSKT2.DARAM2 = "IRAM";
DSKT2.SARAM0 = "IRAM";
DSKT2.SARAM1 = "IRAM";
DSKT2.SARAM2 = "IRAM";
DSKT2.ESDATA = "DDRALGHEAP";
DSKT2.IPROG = "IRAM";
DSKT2.EPROG = "DDR2";
DSKT2.DSKT2_HEAP = "DDR2"; /* to allocate internal DSKT2 object */
DSKT2.trace = true;
DSKT2.debug = true;
DSKT2.DARAM_SCRATCH_SIZES = [ 65536, 0, 0,0,0,0,0, /* ... */ 0 ];
DSKT2.SARAM_SCRATCH_SIZES = [ 65536, 0, 0,0,0,0,0, /* ... */ 0 ];
var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
RMAN.useDSKT2 = true;
RMAN.tableSize = 10;
RMAN.semCreateFxn = "Sem_create";
RMAN.semDeleteFxn = "Sem_delete";
RMAN.semPendFxn = "Sem_pend";
RMAN.semPostFxn = "Sem_post";
RMAN.debug = true;
RMAN.trace = true;
var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
// EDMA3.globalInit = true;
EDMA3.maxPaRams[0] = 384;
EDMA3.maxPaRams[1] = 0;
EDMA3.maxPaRams[2] = 0;
EDMA3.maxPaRams[3] = 0;
EDMA3.maxTccs[0] = 49;
EDMA3.maxTccs[1] = 0;
EDMA3.maxTccs[2] = 0;
EDMA3.maxTccs[3] = 0;
EDMA3.maxEdmaChannels[0] = 49;
EDMA3.maxEdmaChannels[1] = 0;
EDMA3.maxEdmaChannels[2] = 0;
EDMA3.maxEdmaChannels[3] = 0;
EDMA3.maxQdmaChannels[0] = 0;
EDMA3.trace = true;
EDMA3.debug = true;
var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
EDMA3CHAN.debug = true;
EDMA3CHAN.trace = true;
var HDVICP = xdc.useModule('ti.sdo.fc.ires.hdvicp.HDVICP');
HDVICP.debug = true;
HDVICP.trace = true;
var HDINTC = xdc.useModule('ti.sdo.fc.hdintc.HDINTC');
HDINTC.interruptVectorId_0 = 10;
HDINTC.interruptVectorId_1 = 11;
HDINTC.hdvicpInterruptEventNo_0 = 29;
HDINTC.hdvicpInterruptEventNo_1 = 39;
I have created the codec server but when I encode 1080p the demo failed.
Error: Failed to encode video buffer
