Detecting and mounting NAND Flash
Other Parts Discussed in Thread: AM1705, TLV320AIC3106, TPS65023, DA8XX
First of all, my board has the following hardware:
CPU: AM1705
SPI Flash : K0XMFI011 (Spansion) - 4MBytes - Connected to SPI0
Nand Flash: S34ML01G200TFI000 (Spansion) - 128MBytes - Connected to EMIFA
SDR SDRAM : AS4C16M16SA (Alliance Memory) - 32MBytes - Connected to EMIFB - Only one RAM chip
Ethernet : LAN8720a
Audio : TLV320AIC3106
Power : TPS65023
U-boot is inside a SPI flash chip connected at SPI0.
Now my question:
For an application I need my board to mount filesystem that is located in another computer. Using a NFS server I did this succesfully.
I also need at the same time to have access to an onboard NAND flash chip for storing data. I have looked inside the /dev folder but there are no device nodes like mtdX and mtdblockX, with X=0, 1, ... n. Does this mean that my NAND flash is not being detected? How can I mount this flash memory so it can be seen like a "secondary hard drive" for storing data?.
Thanks for your help in advance.
Patricio
  • Yes, if you didn't see the entry for /dev/mtdblockX.
    Can you please attach the boot log ?
    Please make sure that you have enabled the davinci NAND driver support (using make menuconfig) and board file.
  • Hello Titus,
    Attached you can find my boot log.
    I'm confident that the driver support is enabled.
    About the board file are you referring to src/kernel/linux-davinci/arch/arm/mach-davinci/board-da830-evm.c?
    If yes you can find my attached board file too.
    Thank you
    Patricio
    ## Booting kernel from Legacy Image at c0700000 ...
       Image Name:   Linux-3.3.0
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2270840 Bytes = 2.2 MiB
       Load Address: c0008000
       Entry Point:  c0008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Booting Linux on physical CPU 0
    Linux version 3.3.0 (armdev@armdev-VirtualBox) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #5 PREEMPT Mon Oct 17 11:44:20 CLST 2016
    CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    CPU: VIVT data cache, VIVT instruction cache
    Machine: DaVinci DA830/OMAP-L137/AM17x EVM
    Memory policy: ECC disabled, Data cache writethrough
    DaVinci da830/omap-l137 rev2.0 variant 0x9
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
    Kernel command line: console=tty,115200n8 noinitrd ip=192.168.0.7:192.168.0.5:192.168.0.1:255.255.255.0:carbonius:eth0:off davinci_emac.et
    haddr=00:0e:99:02:52:03 mem=32M root=/dev/nfs rw nfsroot=192.168.0.5:/home/armdev/TI-OMAP/AM1705/srv_nfs/4_arago-base-image-arago/
    PID hash table entries: 128 (order: -3, 512 bytes)
    Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
    Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Memory: 32MB = 32MB total
    Memory: 27692k/27692k available, 5076k reserved, 0K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        vmalloc : 0xc2800000 - 0xff000000   ( 968 MB)
        lowmem  : 0xc0000000 - 0xc2000000   (  32 MB)
        modules : 0xbf000000 - 0xc0000000   (  16 MB)
          .text : 0xc0008000 - 0xc042a000   (4232 kB)
          .init : 0xc042a000 - 0xc044e000   ( 144 kB)
          .data : 0xc044e000 - 0xc0487340   ( 229 kB)
           .bss : 0xc0487364 - 0xc04a2534   ( 109 kB)
    SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    NR_IRQS:245
    Console: colour dummy device 80x30
    Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    Setting up static identity map for 0xc0326dd0 - 0xc0326e28
    gpiochip_add: registered GPIOs 0 to 31 on device: DaVinci
    gpiochip_add: registered GPIOs 32 to 63 on device: DaVinci
    gpiochip_add: registered GPIOs 64 to 95 on device: DaVinci
    gpiochip_add: registered GPIOs 96 to 127 on device: DaVinci
    DaVinci: 128 gpio irqs
    NET: Registered protocol family 16
    bio: create slab <bio-0> at 0
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    pcf857x: probe of 1-003f failed with error -121
    Advanced Linux Sound Architecture Driver Version 1.0.24.
    Switching to clocksource timer0_0
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 1024 (order: 1, 8192 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    TCP reno registered
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
    msgmni has been set to 54
    io scheduler noop registered (default)
    Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
    serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a AR7
    serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a AR7
    console [ttyS1] enabled
    serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a AR7
    brd: module loaded
    at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    spi_davinci spi_davinci.0: DMA: supported
    spi_davinci spi_davinci.0: DMA: RX channel: 14, TX channel: 15, event queue: 0
    m25p80 spi0.0: unrecognized JEDEC id 014016
    spi_davinci spi_davinci.0: Controller at 0xfec41000
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
    davinci_mdio davinci_mdio.0: detected phy mask fffffffe
    davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[0]: device davinci_mdio-0:00, driver SMSC LAN8710/LAN8720
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    ohci ohci.0: DA8xx OHCI
    ohci ohci.0: new USB bus registered, assigned bus number 1
    Waiting for USB PHY clock good...
    ohci ohci.0: irq 59, io mem 0x01e25000
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    tsc2004: probe of 1-0049 failed with error -121
    i2c /dev entries driver
    lirc_dev: IR Remote Control driver registered, major 254
    IR NEC protocol handler initialized
    IR RC5(x) protocol handler initialized
    IR RC6 protocol handler initialized
    IR JVC protocol handler initialized
    IR Sony protocol handler initialized
    IR RC5 (streamzap) protocol handler initialized
    IR SANYO protocol handler initialized
    IR MCE Keyboard/mouse protocol handler initialized
    IR LIRC bridge handler initialized
    Linux video capture interface: v2.00
    uvcvideo: Unable to create debugfs directory
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (1.1.1)
    watchdog watchdog: heartbeat 60 sec
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    usbcore: registered new interface driver snd-usb-audio
    asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
    ALSA device list:
      #0: DA830/OMAP-L137 EVM
    TCP cubic registered
    NET: Registered protocol family 17
    Registering the dns_resolver key type
    console [netcon0] enabled
    netconsole: network logging started
    davinci_emac davinci_emac.1: using random MAC addr: 02:68:52:34:85:2d
    net eth0: no phy, defaulting to 100/full
    IP-Config: Complete:
         device=eth0, addr=192.168.0.7, mask=255.255.255.0, gw=192.168.0.1,
         host=carbonius, domain=, nis-domain=(none),
         bootserver=192.168.0.5, rootserver=192.168.0.5, rootpath=
    VFS: Mounted root (nfs filesystem) on device 0:12.
    Freeing init memory: 144K
    usb 1-1: new low-speed USB device number 2 using ohci
    usb 1-1: device descriptor read/64, error -62
    /bin/sh: can't access tty; job control turned off
    usb 1-1: new low-speed USB device number 3 using ohci
    / # usb 1-1: device descriptor read/64, error -62
    usb 1-1: new low-speed USB device number 4 using ohci
    usb 1-1: device not accepting address 4, error -62
    usb 1-1: new low-speed USB device number 5 using ohci
    usb 1-1: device not accepting address 5, error -62
    hub 1-0:1.0: unable to enumerate USB device on port 1
    / # ls
    bin      dev      home     linuxrc  mnt      sbin     tmp      var
    boot     etc      lib      media    proc     sys      usr
     * TI DA830/OMAP L137 EVM board
     * Author: Mark A. Greer <mgreer@mvista.com>
     * Derived from: arch/arm/mach-davinci/board-dm644x-evm.c
     * 2007, 2009 (c) MontaVista Software, Inc. This file is licensed under
     * the terms of the GNU General Public License version 2. This program
     * is licensed "as is" without any warranty of any kind, whether express
     * or implied.
    #include <linux/kernel.h>
    #include <linux/init.h>
    #include <linux/console.h>
    #include <linux/interrupt.h>
    #include <linux/gpio.h>
    #include <linux/platform_device.h>
    #include <linux/i2c.h>
    #include <linux/i2c/pcf857x.h>
    #include <linux/i2c/at24.h>
    #include <linux/i2c/tsc2004.h>
    #include <linux/mtd/mtd.h>
    #include <linux/mtd/partitions.h>
    #include <linux/spi/spi.h>
    #include <linux/spi/flash.h>
    #include <linux/delay.h>
    #include <linux/wl12xx.h>
    #include <asm/mach-types.h>
    #include <asm/mach/arch.h>
    #include <mach/cp_intc.h>
    #include <mach/mux.h>
    #include <mach/nand.h>
    #include <mach/da8xx.h>
    #include <mach/usb.h>
    #include <linux/mfd/davinci_aemif.h>
    #include <mach/spi.h>
    #define DA830_EVM_PHY_ID		""
    #if defined(CONFIG_SND_DA830_SOC_EVM) || \
            defined(CONFIG_SND_DA830_SOC_EVM_MODULE)
    #define HAS_MCASP 1
    #else
    #define HAS_MCASP 0
    #endif
    #if defined(CONFIG_ECAP_PWM) || \
    	defined(CONFIG_ECAP_PWM_MODULE)
    #define HAS_ECAP_PWM 1
    #else
    #define HAS_ECAP_PWM 0
    #endif
    #if defined(CONFIG_ECAP_CAP) || defined(CONFIG_ECAP_CAP_MODULE)
    #define HAS_ECAP_CAP 1
    #else
    #define HAS_ECAP_CAP 0
    #endif
    #ifdef CONFIG_DA830_WL18XX
    #define DA830_WIFI_NAND			GPIO_TO_PIN(1, 15)
    #define DA830_BT_EN			GPIO_TO_PIN(2, 2)
    #define DA830_SPI_UART    		GPIO_TO_PIN(3, 10)
    #define DA830_WLAN_EN			GPIO_TO_PIN(5, 7)
    #define DA830_WLAN_IRQ			GPIO_TO_PIN(2, 12)
    #else
     * USB1 VBUS is controlled by GPIO1[15], over-current is reported on GPIO2[4].
    #define ON_BD_USB_DRV	GPIO_TO_PIN(1, 15)
    #define ON_BD_USB_OVC	GPIO_TO_PIN(2, 4)
    static const short da830_evm_usb11_pins[] = {
    	DA830_GPIO1_15, DA830_GPIO2_4,
    	-1
    static irqreturn_t da830_evm_usb_ocic_irq(int, void *);
    static struct da8xx_ohci_root_hub da830_evm_usb11_pdata = {
    	.type			= GPIO_BASED,
    	.method	= {
    		.gpio_method = {
    			.power_control_pin	= ON_BD_USB_DRV,
    			.over_current_indicator = ON_BD_USB_OVC,
    	.board_ocic_handler	= da830_evm_usb_ocic_irq,
    static irqreturn_t da830_evm_usb_ocic_irq(int irq, void *handler)
    	if (handler != NULL)
    		((da8xx_ocic_handler_t)handler)(&da830_evm_usb11_pdata, 1);
    	return IRQ_HANDLED;
    #endif
    static __init void da830_evm_usb_init(void)
    	u32 cfgchip2;
    	int ret;
    	 * Set up USB clock/mode in the CFGCHIP2 register.
    	 * FYI:  CFGCHIP2 is 0x0000ef00 initially.
    	cfgchip2 = __raw_readl(DA8XX_SYSCFG0_VIRT(DA8XX_CFGCHIP2_REG));
    	/* USB2.0 PHY reference clock is 24 MHz */
    	cfgchip2 &= ~CFGCHIP2_REFFREQ;
    	cfgchip2 |=  CFGCHIP2_REFFREQ_24MHZ;
    	 * Select internal reference clock for USB 2.0 PHY
    	 * and use it as a clock source for USB 1.1 PHY
    	 * (this is the default setting anyway).
    	cfgchip2 &= ~CFGCHIP2_USB1PHYCLKMUX;
    	cfgchip2 |=  CFGCHIP2_USB2PHYCLKMUX;
    	 * We have to override VBUS/ID signals when MUSB is configured into the
    	 * host-only mode -- ID pin will float if no cable is connected, so the
    	 * controller won't be able to drive VBUS thinking that it's a B-device.
    	 * Otherwise, we want to use the OTG mode and enable VBUS comparators.
    	cfgchip2 &= ~CFGCHIP2_OTGMODE;
    #ifdef	CONFIG_USB_MUSB_HOST
    	cfgchip2 |=  CFGCHIP2_FORCE_HOST;
    #else
    	cfgchip2 |=  CFGCHIP2_SESENDEN | CFGCHIP2_VBDTCTEN;
    #endif
    	__raw_writel(cfgchip2, DA8XX_SYSCFG0_VIRT(DA8XX_CFGCHIP2_REG));
    	/* USB_REFCLKIN is not used. */
    	ret = davinci_cfg_reg(DA830_USB0_DRVVBUS);
    	if (ret)
    		pr_warning("%s: USB 2.0 PinMux setup failed: %d\n",
    			   __func__, ret);
    	else {
    		 * TPS2065 switch @ 5V supplies 1 A (sustains 1.5 A),
    		 * with the power on to power good time of 3 ms.
    		ret = da8xx_register_usb20(1000, 3);
    		if (ret)
    			pr_warning("%s: USB 2.0 registration failed: %d\n",
    				   __func__, ret);
    static struct davinci_uart_config da830_evm_uart_config __initdata = {
    	.enabled_uarts = 0x7,
    static const short da830_evm_mcasp1_pins[] = {
    	DA830_AHCLKX1, DA830_ACLKX1, DA830_AFSX1, DA830_AHCLKR1, DA830_AFSR1,
    	DA830_AMUTE1, DA830_AXR1_0, DA830_AXR1_1, DA830_AXR1_2, DA830_AXR1_5,
    	DA830_ACLKR1, DA830_AXR1_6, DA830_AXR1_7, DA830_AXR1_8, DA830_AXR1_10,
    	DA830_AXR1_11,
    	-1
    static u8 da830_iis_serializer_direction[] = {
    	RX_MODE,	INACTIVE_MODE,	INACTIVE_MODE,	INACTIVE_MODE,
    	INACTIVE_MODE,	TX_MODE,	INACTIVE_MODE,	INACTIVE_MODE,
    	INACTIVE_MODE,	INACTIVE_MODE,	INACTIVE_MODE,	INACTIVE_MODE,
    static struct snd_platform_data da830_evm_snd_data = {
    	.tx_dma_offset  = 0x2000,
    	.rx_dma_offset  = 0x2000,
    	.op_mode        = DAVINCI_MCASP_IIS_MODE,
    	.num_serializer = ARRAY_SIZE(da830_iis_serializer_direction),
    	.tdm_slots      = 2,
    	.serial_dir     = da830_iis_serializer_direction,
    	.asp_chan_q     = EVENTQ_0,
    	.version	= MCASP_VERSION_2,
    	.txnumevt	= 1,
    	.rxnumevt	= 1,
     * GPIO2[1] is used as MMC_SD_WP and GPIO2[2] as MMC_SD_INS.
    static const short da830_evm_mmc_sd_pins[] = {
    	DA830_MMCSD_DAT_0, DA830_MMCSD_DAT_1, DA830_MMCSD_DAT_2,
    	DA830_MMCSD_DAT_3, DA830_MMCSD_DAT_4, DA830_MMCSD_DAT_5,
    	DA830_MMCSD_DAT_6, DA830_MMCSD_DAT_7, DA830_MMCSD_CLK,
    	DA830_MMCSD_CMD,   DA830_GPIO2_1,     DA830_GPIO2_2,
    	-1
    #define DA830_MMCSD_WP_PIN		GPIO_TO_PIN(2, 1)
    #define DA830_MMCSD_CD_PIN		GPIO_TO_PIN(2, 2)
    static int da830_evm_mmc_get_ro(int index)
    	return gpio_get_value(DA830_MMCSD_WP_PIN);
    static int da830_evm_mmc_get_cd(int index)
    	return !gpio_get_value(DA830_MMCSD_CD_PIN);
    static struct davinci_mmc_config da830_evm_mmc_config = {
    	.get_ro			= da830_evm_mmc_get_ro,
    	.get_cd			= da830_evm_mmc_get_cd,
    	.wires			= 8,
    	.max_freq		= 50000000,
    	.caps			= MMC_CAP_MMC_HIGHSPEED | MMC_CAP_SD_HIGHSPEED,
    	.version		= MMC_CTLR_VERSION_2,
    static inline void da830_evm_init_mmc(void)
    	int ret;
    	ret = davinci_cfg_reg_list(da830_evm_mmc_sd_pins);
    	if (ret) {
    		pr_warning("da830_evm_init: mmc/sd mux setup failed: %d\n",
    				ret);
    		return;
    	ret = gpio_request(DA830_MMCSD_WP_PIN, "MMC WP");
    	if (ret) {
    		pr_warning("da830_evm_init: can not open GPIO %d\n",
    		return;
    	gpio_direction_input(DA830_MMCSD_WP_PIN);
    	ret = gpio_request(DA830_MMCSD_CD_PIN, "MMC CD\n");
    	if (ret) {
    		return;
    	gpio_direction_input(DA830_MMCSD_CD_PIN);
    	ret = da8xx_register_mmcsd0(&da830_evm_mmc_config);
    	if (ret) {
    		pr_warning("da830_evm_init: mmc/sd registration failed: %d\n",
    				ret);
    		gpio_free(DA830_MMCSD_WP_PIN);
     * UI board NAND/NOR flashes only use 8-bit data bus.
    static const short da830_evm_emif25_pins[] = {
    	DA830_EMA_D_0, DA830_EMA_D_1, DA830_EMA_D_2, DA830_EMA_D_3,
    	DA830_EMA_D_4, DA830_EMA_D_5, DA830_EMA_D_6, DA830_EMA_D_7,
    	DA830_EMA_A_0, DA830_EMA_A_1, DA830_EMA_A_2, DA830_EMA_A_3,
    	DA830_EMA_A_4, DA830_EMA_A_5, DA830_EMA_A_6, DA830_EMA_A_7,
    	DA830_EMA_A_8, DA830_EMA_A_9, DA830_EMA_A_10, DA830_EMA_A_11,
    	DA830_EMA_A_12, DA830_EMA_BA_0, DA830_EMA_BA_1, DA830_NEMA_WE,
    	DA830_NEMA_CS_2, DA830_NEMA_CS_3, DA830_NEMA_OE, DA830_EMA_WAIT_0,
    	-1
    #if defined(CONFIG_MMC_DAVINCI) || defined(CONFIG_MMC_DAVINCI_MODULE)
    #define HAS_MMC	1
    #else
    #define HAS_MMC	0
    #endif
    #if defined(CONFIG_SPI_DAVINCI) || defined(CONFIG_SPI_DAVINCI_MODULE)
    #define HAS_SPI 1
    #else
    #define HAS_SPI 0
    #endif
    #if defined (CONFIG_DA830_UI_NAND) || defined (CONFIG_DA830_WL18XX)
    static struct mtd_partition da830_evm_nand_partitions[] = {
    	/* bootloader (U-Boot, etc) in first sector */
    	[0] = {
    		.name		= "bootloader",
    		.offset		= 0,
    		.size		= SZ_128K,
    		.mask_flags	= MTD_WRITEABLE,	/* force read-only */
    	/* bootloader params in the next sector */
    	[1] = {
    		.name		= "params",
    		.offset		= MTDPART_OFS_APPEND,
    		.size		= SZ_128K,
    	/* kernel */
    	[2] = {
    		.name		= "kernel",
    		.size		= SZ_2M,
    		.mask_flags	= 0,
    	/* file system */
    	[3] = {
    		.name		= "filesystem",
    		.size		= MTDPART_SIZ_FULL,
    		.mask_flags	= 0,
    /* flash bbt decriptors */
    static uint8_t da830_evm_nand_bbt_pattern[] = { 'B', 'b', 't', '0' };
    static uint8_t da830_evm_nand_mirror_pattern[] = { '1', 't', 'b', 'B' };
    static struct nand_bbt_descr da830_evm_nand_bbt_main_descr = {
    	.options	= NAND_BBT_LASTBLOCK | NAND_BBT_CREATE |
    			  NAND_BBT_WRITE | NAND_BBT_2BIT |
    			  NAND_BBT_VERSION | NAND_BBT_PERCHIP,
    	.offs		= 2,
    	.len		= 4,
    	.veroffs	= 16,
    	.maxblocks	= 4,
    	.pattern	= da830_evm_nand_bbt_pattern
    static struct nand_bbt_descr da830_evm_nand_bbt_mirror_descr = {
    	.offs		= 2,
    	.len		= 4,
    	.veroffs	= 16,
    	.maxblocks	= 4,
    	.pattern	= da830_evm_nand_mirror_pattern
    static struct davinci_aemif_timing da830_evm_nandflash_timing = {
    	.wsetup         = 24,
    	.wstrobe        = 21,
    	.whold          = 14,
    	.rsetup         = 19,
    	.rstrobe        = 50,
    	.rhold          = 0,
    	.ta             = 20,
    static struct davinci_nand_pdata da830_evm_nand_pdata = {
    	.parts		= da830_evm_nand_partitions,
    	.nr_parts	= ARRAY_SIZE(da830_evm_nand_partitions),
    	.ecc_mode	= NAND_ECC_HW,
    	.ecc_bits	= 4,
    	.bbt_options	= NAND_BBT_USE_FLASH,
    	.bbt_td		= &da830_evm_nand_bbt_main_descr,
    	.bbt_md		= &da830_evm_nand_bbt_mirror_descr,
    	.timing         = &da830_evm_nandflash_timing,
    static struct resource da830_evm_nand_resources[] = {
    	[0] = {		/* First memory resource is NAND I/O window */
    		.start	= DA8XX_AEMIF_CS3_BASE,
    		.end	= DA8XX_AEMIF_CS3_BASE + PAGE_SIZE - 1,
    		.flags	= IORESOURCE_MEM,
    	[1] = {		/* Second memory resource is AEMIF control registers */
    		.start	= DA8XX_AEMIF_CTL_BASE,
    		.end	= DA8XX_AEMIF_CTL_BASE + SZ_32K - 1,
    static struct platform_device da830_evm_devices[] __initdata = {
    		.name		= "davinci_nand",
    		.id		= 1,
    		.dev		= {
    			.platform_data	= &da830_evm_nand_pdata,
    		.num_resources	= ARRAY_SIZE(da830_evm_nand_resources),
    		.resource	= da830_evm_nand_resources,
    static struct davinci_aemif_devices da830_emif_devices = {
    	.devices	= da830_evm_devices,
    	.num_devices	= ARRAY_SIZE(da830_evm_devices),
    static struct platform_device davinci_emif_device = {
    	.name	= "davinci_aemif",
    	.id	= -1,
    	.dev	= {
    		.platform_data	= &da830_emif_devices,
    static inline void da830_evm_init_nand(int mux_mode)
    	int ret;
    	if (HAS_MMC) {
    		pr_warning("WARNING: both MMC/SD and NAND are "
    				"enabled, but they share AEMIF pins.\n"
    				"\tDisable MMC/SD for NAND support.\n");
    		return;
    	ret = davinci_cfg_reg_list(da830_evm_emif25_pins);
    	if (ret)
    		pr_warning("da830_evm_init: emif25 mux setup failed: %d\n",
    				ret);
    	ret = platform_device_register(&davinci_emif_device);
    	if (ret)
    		pr_warning("da830_evm_init: NAND device not registered.\n");
    	if (mux_mode > 0)
    		gpio_direction_output(mux_mode, 1);
    #else
    static inline void da830_evm_init_nand(int mux_mode) {}
    #endif
    #if defined(CONFIG_DA830_UI_LCD) || defined(CONFIG_GLCD_DVI_VGA)
    static int da830_lcd_hw_init(void)
    	void __iomem *cfg_mstpri2_base;
    #ifdef CONFIG_GLCD_DVI_VGA
    	u32 emifb_revid = 0;
    	u32 emifb_bprio = 0;
    	u32 *emifb_mem = 0;
    #endif
    	u32 val = 0;
    	 * Reconfigure the LCDC priority to the highest to ensure that
    	 * the throughput/latency requirements for the LCDC are met.
    	cfg_mstpri2_base = DA8XX_SYSCFG0_VIRT(DA8XX_MSTPRI2_REG);
    	val = __raw_readl(cfg_mstpri2_base);
    	val &= 0x0fffffff;
    	__raw_writel(val, cfg_mstpri2_base);
    	 *The PBBPR set to a moderately low value to provide an acceptable
    	 *balance of SDRAM efficiency and latency for high priority master.
    	emifb_mem = ioremap_nocache((DA8XX_EMIF30_CONTROL_BASE), 256);
    	if(emifb_mem == NULL)
    		pr_warning("da830_evm_init: EMIFB mem allocate failed\n");
    		return 0;
    	/* Rev ID reg */
    	emifb_revid = *(u32 *)emifb_mem;
    	/* set BPRIO */
    	*(emifb_mem + DA8XX_EMIF30_BPRIO_OFFSET/4) = 0x20;
    	emifb_bprio = *(emifb_mem + DA8XX_EMIF30_BPRIO_OFFSET/4);
    	iounmap(emifb_mem);
    #endif
    	return 0;
    static const short da830_evm_lcdc_pins[] = {
    	DA830_NLCD_AC_ENB_CS,
    	-1
    static inline void da830_evm_init_lcdc(int mux_mode)
    	int ret;
    	ret = davinci_cfg_reg_list(da830_lcdcntl_pins);
    	if (ret)
    		pr_warning("da830_evm_init: lcdcntl mux setup failed: %d\n",
    				ret);
    	ret = da830_lcd_hw_init();
    	if (ret)
    		pr_warning("da830_evm_init: lcd hw init failed: %d\n", ret);
    #if !defined(CONFIG_FB_DA8XX) && !defined(CONFIG_FB_DA8XX_MODULE)
    	ret = davinci_cfg_reg_list(da830_evm_lcdc_pins);
    	if (ret)
    		pr_warning("da830_evm_init:evm lcd mux setup failed: %d\n",
    				ret);
    #endif
    #ifndef CONFIG_GLCD_DVI_VGA
    	ret = da8xx_register_lcdc(&sharp_lcd035q3dg01_pdata);
    	if (ret)
    		pr_warning("da830_evm_init: lcd setup failed: %d\n", ret);
    	gpio_direction_output(mux_mode, 0);
    #else
    	ret = da8xx_register_lcdc(&ti_dvi_vga_pdata);
    	if (ret)
    #endif
    #else
    static inline void da830_evm_init_lcdc(int mux_mode) { }
    #endif
    static struct at24_platform_data da830_evm_i2c_eeprom_info = {
    	.byte_len	= SZ_256K / 8,
    	.page_size	= 64,
    	.flags		= AT24_FLAG_ADDR16,
    	.setup		= davinci_get_mac_addr,
    	.context	= (void *)0x7f00,
    static int __init da830_evm_ui_expander_setup(struct i2c_client *client,
    		int gpio, unsigned ngpio, void *context)
    	gpio_request(gpio + 6, "UI MUX_MODE");
    	/* Drive mux mode low to match the default without UI card */
    	gpio_direction_output(gpio + 6, 0);
    	da830_evm_init_lcdc(gpio + 6);
    #endif
    	da830_evm_init_nand(gpio + 6);
    	return 0;
    static int da830_evm_ui_expander_teardown(struct i2c_client *client, int gpio,
    	gpio_free(gpio + 6);
    	return 0;
    static struct pcf857x_platform_data __initdata da830_evm_ui_expander_info = {
    	.gpio_base	= DAVINCI_N_GPIO,
    	.setup		= da830_evm_ui_expander_setup,
    	.teardown	= da830_evm_ui_expander_teardown,
     * TSC 2004 Support
    #define TSC2004_GPIO_IRQ_PIN	GPIO_TO_PIN(2, 8)
    #define DA830_EVM_TSC2004_ADDRESS       0x49
    static int tsc2004_init_irq(void)
    	int ret = 0;
    	ret = gpio_request(TSC2004_GPIO_IRQ_PIN, "tsc2004-irq");
    	if (ret < 0) {
    		pr_warning("%s: failed to TSC2004 IRQ GPIO: %d\n",
    								__func__, ret);
    		return ret;
    	ret = davinci_cfg_reg(DA830_GPIO2_8);
    	if (ret) {
    		pr_warning("%s: PinMux setup for GPIO %d failed: %d\n",
    			   __func__, TSC2004_GPIO_IRQ_PIN, ret);
    		return ret;
    	gpio_direction_input(TSC2004_GPIO_IRQ_PIN);
    	return ret;
    static void tsc2004_exit_irq(void)
    	gpio_free(TSC2004_GPIO_IRQ_PIN);
    static int tsc2004_get_irq_level(void)
    	return gpio_get_value(TSC2004_GPIO_IRQ_PIN) ? 0 : 1;
    struct tsc2004_platform_data da830evm_tsc2004data = {
    	.model = 2004,
    	.x_plate_ohms = 180,
    	.get_pendown_state = tsc2004_get_irq_level,
    	.init_platform_hw = tsc2004_init_irq,
    	.exit_platform_hw = tsc2004_exit_irq,
    static struct i2c_board_info __initdata da830_evm_i2c_devices[] = {
    		I2C_BOARD_INFO("24c256", 0x50),
    		.platform_data	= &da830_evm_i2c_eeprom_info,
    		I2C_BOARD_INFO("tlv320aic3x", 0x18),   //OK CARBONIUS
    		I2C_BOARD_INFO("pcf8574", 0x3f),
    		.platform_data	= &da830_evm_ui_expander_info,
    static struct i2c_board_info __initdata da830_evm_tsc2004_dev = {
    	I2C_BOARD_INFO("tsc2004", DA830_EVM_TSC2004_ADDRESS),
    	.platform_data  = &da830evm_tsc2004data,
    static struct davinci_i2c_platform_data da830_evm_i2c_pdata = {
    	.bus_freq	= 100,	/* kHz */
    	.bus_delay	= 0,	/* usec */
     * The following EDMA channels/slots are not being used by drivers (for
     * example: Timer, GPIO, UART events etc) on da830/omap-l137 EVM, hence
     * they are being reserved for codecs on the DSP side.
    static const s16 da830_dma_rsv_chans[][2] = {
    	/* (offset, number) */
    	{ 8,  2},
    	{12,  2},
    	{24,  4},
    	{30,  2},
    	{-1, -1}
    static const s16 da830_dma_rsv_slots[][2] = {
    	{ 8,  2},
    	{12,  2},
    	{24,  4},
    	{30, 26},
    	{-1, -1}
    static struct edma_rsv_info da830_edma_rsv[] = {
    		.rsv_chans	= da830_dma_rsv_chans,
    		.rsv_slots	= da830_dma_rsv_slots,
    static struct mtd_partition da830evm_spiflash_part[] = {
    	[0] = {
    		.name = "DSP-UBL",
    		.offset = 0,
    		.size = SZ_8K,
    	[1] = {
    		.name = "ARM-UBL",
    		.size = SZ_16K + SZ_8K,
    	[2] = {
    		.name = "U-Boot",
    		.size = SZ_256K - SZ_32K,
    	[3] = {
    		.name = "U-Boot-Environment",
    		.size = SZ_16K,
    		.mask_flags = 0,
    	[4] = {
    		.name = "Kernel",
    		.mask_flags = 0,
    static struct flash_platform_data da830evm_spiflash_data = {
    	.name		= "m25p80",
    	.parts		= da830evm_spiflash_part,
    	.nr_parts	= ARRAY_SIZE(da830evm_spiflash_part),
    	.type		= "w25x32",
    static struct davinci_spi_config da830evm_spiflash_cfg = {
    	.io_type	= SPI_IO_TYPE_DMA,
    	.c2tdelay	= 8,
    	.t2cdelay	= 8,
    static struct spi_board_info da830evm_spi_info[] = {
    		.modalias		= "m25p80",
    		.platform_data		= &da830evm_spiflash_data,
    		.controller_data	= &da830evm_spiflash_cfg,
    		.mode			= SPI_MODE_0,
    		.max_speed_hz		= 30000000,
    		.bus_num		= 0,
    		.chip_select		= 0,
    static void wl18xx_set_power(int index, bool power_on)
    	static bool power_state;
    	pr_debug("Powering %s wl18xx", power_on ? "on" : "off");
    	if (power_on == power_state)
    		return;
    	power_state = power_on;
    	if (power_on) {
    		/* Power up sequence required for wl127x devices */
    		gpio_set_value_cansleep(DA830_WLAN_EN, 1);
    		usleep_range(15000, 15000);
    		gpio_set_value_cansleep(DA830_WLAN_EN, 0);
    		usleep_range(1000, 1000);
    		msleep(70);
    	} else {
    static struct davinci_mmc_config da830_wl18xx_mmc_config = {
    	.set_power	= wl18xx_set_power,
    	.wires		= 4,
    	.max_freq	= 25000000,
    	.caps		= MMC_CAP_4_BIT_DATA | MMC_CAP_NONREMOVABLE |
    			  MMC_CAP_POWER_OFF_CARD,
    static const short da830_wl18xx_pins[] __initconst = {
    	DA830_MMCSD_DAT_3, DA830_MMCSD_CLK, DA830_MMCSD_CMD,
    	DA830_GPIO5_7, DA830_GPIO2_12,
    	-1
    static struct wl12xx_platform_data da830_wl18xx_wlan_data __initdata = {
    	.irq			= -1,
    	.board_ref_clock	= WL12XX_REFCLOCK_26,
    	.platform_quirks	= WL12XX_PLATFORM_QUIRK_EDGE_IRQ,
    static __init int da830_wl18xx_init(void)
    	int ret;
    	ret = davinci_cfg_reg_list(da830_wl18xx_pins);
    	if (ret) {
    		pr_err("wl12xx/mmc mux setup failed: %d\n", ret);
    		goto exit;
    	ret = da8xx_register_mmcsd0(&da830_wl18xx_mmc_config);
    	if (ret) {
    		pr_err("wl12xx/mmc registration failed: %d\n", ret);
    		goto exit;
    	ret = gpio_request_one(DA830_WLAN_EN, GPIOF_OUT_INIT_LOW, "wlan_en");
    	if (ret) {
    		pr_err("Could not request wl12xx enable gpio: %d\n", ret);
    		goto exit;
    	ret = gpio_request_one(DA830_WLAN_IRQ, GPIOF_IN, "wlan_irq");
    	if (ret) {
    		pr_err("Could not request wl12xx irq gpio: %d\n", ret);
    		goto free_wlan_en;
    	da830_wl18xx_wlan_data.irq = gpio_to_irq(DA830_WLAN_IRQ);
    	ret = wl12xx_set_platform_data(&da830_wl18xx_wlan_data);
    	if (ret) {
    		pr_err("Could not set wl12xx data: %d\n", ret);
    		goto free_wlan_irq;
    	return 0;
    free_wlan_irq:
    	gpio_free(DA830_WLAN_IRQ);
    free_wlan_en:
    	gpio_free(DA830_WLAN_EN);
    exit:
    	return ret;
    static __init void da830_init_i2c(void)
    	int ret;
    	ret = davinci_cfg_reg_list(da830_i2c1_pins);
    	if (ret) {
    		pr_warning("da830_evm_init: i2c1 mux setup failed: %d\n",
    				ret);
    		return;
    	ret = da8xx_register_i2c(1, &da830_evm_i2c_pdata);
    	if (ret) {
    		pr_warning("da830_evm_init: i2c1 registration failed: %d\n",
    				ret);
    		return;
    	i2c_register_board_info(2, da830_evm_i2c_devices,
    			ARRAY_SIZE(da830_evm_i2c_devices));
    	da830_evm_tsc2004_dev.irq = gpio_to_irq(TSC2004_GPIO_IRQ_PIN),
    	i2c_register_board_info(2, &da830_evm_tsc2004_dev, 1);
    static __init void da830_init_func(void)
    	int ret;
    	da830_init_i2c();
    	ret = davinci_cfg_reg(DA830_GPIO1_15);
    	if (ret)
    		pr_warning("gpio1_15 mux setup failed: %d\n", ret);
    	ret = gpio_request(DA830_WIFI_NAND, "WIFI_NAND");
    	if (ret)
    		pr_warning("gpio1_15 gpio request failed: %d\n", ret);
    	if (HAS_MMC) {
    		if(!ret) {
    			gpio_direction_output(DA830_WIFI_NAND, 1);
    			da830_wl18xx_init();
    		} else
    			pr_warning("da830_evm_init: SDIO setup failed\n");
    	} else {
    		if (!ret) {
    			gpio_direction_output(DA830_WIFI_NAND, 0);
    #if !defined(CONFIG_DA830_UI_NAND)
    			da830_evm_init_nand(0);
    #endif
    		} else
    			pr_warning("da830_evm_init: nand setup failed\n");
    	ret = davinci_cfg_reg(DA830_GPIO3_10);
    	if (ret)
    		pr_warning("gpio3_10 mux setup failed: %d\n", ret);
    	ret = gpio_request(DA830_SPI_UART, "SPI_UART");
    	if (ret)
    		pr_warning("gpio3_10 gpio request failed: %d\n", ret);
    	if (!HAS_SPI) {
    		if(!ret) {
    			ret = davinci_cfg_reg(DA830_GPIO2_2);
    			if (ret)
    				pr_warning("gpio2_2 pinmux failed\n");
    			ret = gpio_request(DA830_BT_EN, "BT_EN");
    			if (ret)
    				pr_warning("gpio2_2 gpio request failed\n");
    			gpio_direction_output(DA830_BT_EN, 1);
    			davinci_cfg_reg_list(da830_uart0_pins);
    			gpio_direction_output(DA830_SPI_UART, 1);
    	} else {
    		if (!ret) {
    			gpio_direction_output(DA830_SPI_UART, 0);
    			ret = da8xx_register_spi(0, da830evm_spi_info,
    				 ARRAY_SIZE(da830evm_spi_info));
    		if (!ret)
    			pr_warning("da830_evm_init:"
    			"spi 0 registration failed: %d\n", ret);
    #else
    	int ret;
    	ret = davinci_cfg_reg_list(da830_i2c0_pins);
    	if (ret) {
    		pr_warning("da830_evm_init: i2c0 mux setup failed: %d\n",
    				ret);
    		return;
    	ret = da8xx_register_i2c(0, &da830_evm_i2c_pdata);
    	if (ret) {
    				ret);
    		return;
    	i2c_register_board_info(1, da830_evm_i2c_devices,
    	i2c_register_board_info(1, &da830_evm_tsc2004_dev, 1);
    	int ret;
    	da830_init_i2c();
    	da8xx_board_usb_init(da830_evm_usb11_pins, &da830_evm_usb11_pdata);
    	da830_evm_init_mmc();
    	if (ret)
    		pr_warning("da830_evm_init: spi 0 registration failed: %d\n",
    			   ret);
    #endif
    static __init void da830_evm_init(void)
    	struct davinci_soc_info *soc_info = &davinci_soc_info;
    	int ret;
    	ret = da830_register_edma(da830_edma_rsv);
    	if (ret)
    		pr_warning("da830_evm_init: edma registration failed: %d\n",
    				ret);
    	da830_evm_usb_init();
    	soc_info->emac_pdata->rmii_en = 1;
    	soc_info->emac_pdata->phy_id = DA830_EVM_PHY_ID;
    	ret = davinci_cfg_reg_list(da830_cpgmac_pins);
    	if (ret)
    		pr_warning("da830_evm_init: cpgmac mux setup failed: %d\n",
    				ret);
    	ret = da8xx_register_emac();
    	if (ret)
    		pr_warning("da830_evm_init: emac registration failed: %d\n",
    				ret);
    	ret = da8xx_register_watchdog();
    	if (ret)
    		pr_warning("da830_evm_init: watchdog registration failed: %d\n",
    				ret);
    	davinci_serial_init(&da830_evm_uart_config);
    	if (HAS_MCASP) {
    		ret = davinci_cfg_reg_list(da830_evm_mcasp1_pins);
    		if (ret)
    			pr_warning("da830_evm_init: mcasp1 mux setup failed: %d\n",
    					ret);
    		da8xx_register_mcasp(1, &da830_evm_snd_data);
    	ret = da8xx_register_rtc();
    	if (ret)
    		pr_warning("da830_evm_init: rtc setup failed: %d\n", ret);
    	da830_init_func();
    	da830_evm_init_lcdc(0);
    #endif
    	if (HAS_ECAP_PWM) {
    		ret = davinci_cfg_reg_list(da830_ecap1_pins);
    		if (ret)
    			pr_warning("da850_evm_init:ecap mux failed:"
    					" %d\n", ret);
    		ret = da830_register_ecap(2);
    		if (ret)
    			pr_warning("da850_evm_init:"
    				" eCAP registration failed: %d\n", ret);
    	if (HAS_ECAP_CAP) {
    		if (HAS_MCASP)
    				"ecap module 1 cannot be used "
    				"since it shares pins with McASP\n");
    		else {
    			ret = davinci_cfg_reg_list(da830_ecap2_pins);
    			if (ret)
    				pr_warning("da850_evm_init:ecap mux failed:%d\n"
    						, ret);
    			else {
    				ret = da830_register_ecap_cap(1);
    				if (ret)
    					pr_warning("da850_evm_init"
    					"eCAP registration failed: %d\n", ret);
    #ifdef CONFIG_SERIAL_8250_CONSOLE
    static int __init da830_evm_console_init(void)
    	if (!machine_is_davinci_da830_evm())
    		return 0;
    	return add_preferred_console("ttyS", 1, "115200"); //UART 1 CARBONIUS
    console_initcall(da830_evm_console_init);
    #endif
    static void __init da830_evm_map_io(void)
    	da830_init();
    MACHINE_START(DAVINCI_DA830_EVM, "DaVinci DA830/OMAP-L137/AM17x EVM")
    	.atag_offset	= 0x100,
    	.map_io		= da830_evm_map_io,
    	.init_irq	= cp_intc_init,
    	.timer		= &davinci_timer,
    	.init_machine	= da830_evm_init,
    	.dma_zone_size	= SZ_128M,
    	.restart	= da8xx_restart,
    MACHINE_END
  • Can you please put one 'printk' in "da830_evm_init_nand" function ?
    If you didn't see that print then you should enable "CONFIG_DA830_UI_NAND" option via make menuconfig.
    Actually, EVM board has the NAND flash in UI card and SPI flash is on board, thats why board file has the #define configuration (conditional compilation)
  • Hello Titus,
    I did what you told me. I put a test message via printk to see if the function is executed and after testing I realized that it is not being executed.
    I rechecked my kernel config and the CONFIG_DA830_UI_NAND is indeed enabled.
    After taking a deeper look in the board-da830-evm.c I realized that CONFIG_DA830_UI_NAND is not the problem. I'm using PSP-SDK-03.22.00.04.
    The da830_evm_init_nand(0) function is called from the da830_init_func() only when CONFIG_DA830_WL18XX is defined. Please see attached board-da830-evm.c.txt (lines 710 and 828).
    Can you please give me another board file to try? Or could you tell me the changes I need to do to the attached board file so my kernel can detect my NAND flash chip?
     * or implied.
    #define HAS_MCASP 1
    #else
    #define HAS_MCASP 0
    #endif
    #else
    #endif
    #else
    #endif
    #else
     * USB1 VBUS is controlled by GPIO3[12], over-current is reported on GPIO2[13].
    #define ON_BD_USB_DRV	GPIO_TO_PIN(3, 12)
    #define ON_BD_USB_OVC	GPIO_TO_PIN(2, 13)
    	DA830_GPIO3_12, DA830_GPIO2_13,
    	-1
    	.type			= GPIO_BASED,
    	.method	= {
    		.gpio_method = {
    	return IRQ_HANDLED;
    #endif
    	u32 cfgchip2;
    	int ret;
    #else
    #endif
    	if (ret)
    			   __func__, ret);
    	else {
    		if (ret)
    				   __func__, ret);
    	DA830_AXR1_11,
    	-1
    	.tdm_slots      = 2,
    	.txnumevt	= 1,
    	.rxnumevt	= 1,
    	-1
    	.wires			= 8,
    	int ret;
    	if (ret) {
    				ret);
    		return;
    	if (ret) {
    		return;
    	if (ret) {
    		return;
    	if (ret) {
    				ret);
    	-1
    #define HAS_MMC	1
    #else
    #define HAS_MMC	0
    #endif
    #define HAS_SPI 1
    #else
    #define HAS_SPI 0
    #endif
    	[0] = {
    		.offset		= 0,
    		.size		= SZ_128K,
    	[1] = {
    		.name		= "params",
    		.size		= SZ_128K,
    	/* kernel */
    	[2] = {
    		.name		= "kernel",
    		.size		= SZ_2M,
    		.mask_flags	= 0,
    	/* file system */
    	[3] = {
    		.mask_flags	= 0,
    	.offs		= 2,
    	.len		= 4,
    	.veroffs	= 16,
    	.maxblocks	= 4,
    	.offs		= 2,
    	.len		= 4,
    	.veroffs	= 16,
    	.maxblocks	= 4,
    	.wsetup         = 24,
    	.wstrobe        = 21,
    	.whold          = 14,
    	.rsetup         = 19,
    	.rstrobe        = 50,
    	.rhold          = 0,
    	.ta             = 20,
    	.ecc_bits	= 4,
    		.id		= 1,
    		.dev		= {
    	.id	= -1,
    	.dev	= {
    	int ret;
    	printk("da830_evm_init_nand: Entramos\n");
    	if (HAS_MMC) {
    		return;
    	if (ret)
    				ret);
    	if (ret)
    	if (mux_mode > 0)
    #else
    #endif
    	u32 *emifb_mem = 0;
    #endif
    	u32 val = 0;
    	val &= 0x0fffffff;
    		return 0;
    	/* Rev ID reg */
    	/* set BPRIO */
    	iounmap(emifb_mem);
    #endif
    	return 0;
    	-1
    	int ret;
    	if (ret)
    				ret);
    	if (ret)
    	if (ret)
    				ret);
    #endif
    	if (ret)
    #else
    	if (ret)
    #endif
    #else
    #endif
    	.page_size	= 64,
    #endif
    	return 0;
    	return 0;
     * TSC 2004 Support
    	int ret = 0;
    	if (ret < 0) {
    								__func__, ret);
    		return ret;
    	if (ret) {
    		return ret;
    	return ret;
    	.model = 2004,
    	{ 8,  2},
    	{12,  2},
    	{24,  4},
    	{30,  2},
    	{-1, -1}
    	{ 8,  2},
    	{12,  2},
    	{24,  4},
    	{30, 26},
    	{-1, -1}
    	[0] = {
    		.name = "DSP-UBL",
    		.offset = 0,
    		.size = SZ_8K,
    	[1] = {
    		.name = "ARM-UBL",
    	[2] = {
    		.name = "U-Boot",
    	[3] = {
    		.size = SZ_16K,
    		.mask_flags = 0,
    	[4] = {
    		.name = "Kernel",
    		.mask_flags = 0,
    	.name		= "m25p80",
    	.type		= "w25x32",
    	.c2tdelay	= 8,
    	.t2cdelay	= 8,
    		.mode			= SPI_MODE_0,
    		.bus_num		= 0,
    		.chip_select		= 0,
    		return;
    	if (power_on) {
    		msleep(70);
    	} else {
    	.wires		= 4,
    	-1
    	.irq			= -1,
    	int ret;
    	if (ret) {
    		goto exit;
    	if (ret) {
    		goto exit;
    	if (ret) {
    		goto exit;
    	if (ret) {
    		goto free_wlan_en;
    	if (ret) {
    		goto free_wlan_irq;
    	return 0;
    free_wlan_irq:
    free_wlan_en:
    exit:
    	return ret;
    	int ret;
    	if (ret) {
    				ret);
    		return;
    	if (ret) {
    				ret);
    		return;
    	int ret;
    	printk("da830_init_func:  We entered the 1st definition of the function \n\n");
    	da830_init_i2c();
    	if (ret)
    	if (ret)
    	if (HAS_MMC) {
    		if(!ret) {
    		} else
    	} else {
    		if (!ret) {
    #endif
    		} else
    	if (ret)
    	if (ret)
    	if (!HAS_SPI) {
    		if(!ret) {
    			if (ret)
    			if (ret)
    	} else {
    		if (!ret) {
    		if (!ret)
    #else
    	int ret;
    	if (ret) {
    				ret);
    		return;
    	if (ret) {
    				ret);
    		return;
    	int ret;
    	printk("da830_init_func: We entered the 2nd definition of the function \n");
    	da830_init_i2c();
    	if (ret)
    			   ret);
    #endif
    	int ret;
    	printk("da830_evm_init: Entramos\n");
    	if (ret)
    				ret);
    	if (ret)
    				ret);
    	if (ret)
    				ret);
    	if (ret)
    				ret);
    	if (HAS_MCASP) {
    		if (ret)
    					ret);
    	if (ret)
    	da830_init_func();
    #endif
    	if (HAS_ECAP_PWM) {
    		if (ret)
    					" %d\n", ret);
    		if (ret)
    	if (HAS_ECAP_CAP) {
    		if (HAS_MCASP)
    		else {
    			if (ret)
    						, ret);
    			else {
    				if (ret)
    		return 0;
    #endif
    	da830_init();
    MACHINE_END
    Thank you very much,
    Patricio
  • Hi Patricio,
    Are you able to access NAND flash being in u-boot?
    Just to narrow down the problem, by any chance, Did you ever try to build it as modules instead of inbuilt NAND driver and try inserting it after booting Linux.
  • Can you please try the following changes in your board file and tell me you are getting the outputs ?
    Make this changes in "da830_init_func" line no 914.
    int ret;
    da830_init_i2c();
    //Titus : Disable the MMC
    // da830_evm_init_mmc();
    //Titus : Enable the NAND
    if (ret)
    ret);
  • Hello Titus,
    I did everything you told me. Now the following happens:
    In line 58 now it shows the "We entered the 2nd definition of the function", so now we are sure it is being executed.
    Also there are 4 partitions being created (lines 99 to 103).
    However once the system boots and I enter the dev/ directory and see its contents I can't see an entry for mtd or mtdblock. Do I need to create them manually?
    Here is the new boot log, with your modifications:
       Data Size:    2229032 Bytes = 2.1 MiB
    OK
    Starting kernel ...
    Linux version 3.3.0 (armdev@armdev-VirtualBox) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 PREEM
    PT Mon Nov 7 08:52:04 CLST 2016
    carbonius:eth0:off davinci_emac.ethaddr=00:0e:99:02:52:03 mem=32M root=/dev/nfs rw nfsroot=192.168.0.5:/
    Memory: 27780k/27780k available, 4988k reserved, 0K highmem
          .text : 0xc0008000 - 0xc0411000   (4132 kB)
          .init : 0xc0411000 - 0xc0438000   ( 156 kB)
          .data : 0xc0438000 - 0xc0470ea0   ( 228 kB)
           .bss : 0xc0470ec4 - 0xc048cc0c   ( 112 kB)
    NR_IRQS:245
    Setting up static identity map for 0xc0310d98 - 0xc0310df0
    MUX: initialized AHCLKR1
    MUX: Setting register AHCLKR1
               PINMUX12 (0x00000030) = 0x11111110 -> 0x11111111
    TCP reno registered
    brd: module loaded
    ONFI flash detected
    ONFI param page 0 valid
    NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD S34ML01G2)
    Bad block table not found for chip 0
    Scanning device for bad blocks
    Bad block table written to 0x000007fe0000, version 0x01
    Bad block table written to 0x000007fc0000, version 0x01
    Creating 4 MTD partitions on "davinci_nand.1":
    0x000000000000-0x000000020000 : "bootloader"
    0x000000020000-0x000000040000 : "params"
    0x000000040000-0x000000240000 : "kernel"
    0x000000240000-0x000008000000 : "filesystem"
    davinci_nand davinci_nand.1: controller rev. 2.5
    MUX: initialized GPIO2_8
    MUX: Setting register GPIO2_8
               PINMUX18 (0x00000048) = 0x00111010 -> 0x08111010
    ALSA device list:
    davinci_emac davinci_emac.1: using random MAC addr: f6:6b:de:2d:47:21
    Freeing init memory: 156K
    / # ls
    / # cd dev
    /dev # ls
    log   null  pts   tty0
    Thank you.
    Patricio
  • Seems you are using small rootfs (like ramdisk), so you might not have udev to create nodes for mtd.
    You can create mtd device nodes manually (mknod) and try to access it.
  • Hello Titus,
    I will appreciate if you can answer the following questions:
    1) Can you please tell me what dev nodes do I need to create?
    2) Also please tell me the steps necessary to mount and have access to the device.
    3 Is there a way for the linux kernel to detect automatically what "disks" are connected? If yes, how can I do it?
    Please be as detailed as possible, I'm a newbie with linux and I'm having a really hard time trying to make my system work.
    Thank you very much Titus
    Patricio
  • What is your rootfs size ?
    Can you please use the big rootfs which has most of the tools to validate/access the NAND flash like "nandtest"
    Typically "udev" would create device nodes
    A1. We should create mtd and mtdblock nodes.
    You have four partitions in your NAND flash so, you have create following device nodes.
    /dev/mtd0 (char device) and /dev/mtdblock0 (block device)
    /dev/mtd1 and /dev/mtdblock1
    /dev/mtd2 and /dev/mtdblock2
    /dev/mtd3 and /dev/mtdblock3
    Ex:
    driver node ( c or b) Major Minor nodes
    crw-rw---- 1 root root 90, 0 Jan 1 00:00 /dev/mtd0
    crw-rw---- 1 root root 90, 1 Jan 1 00:00 /dev/mtd0ro
    crw-rw---- 1 root root 90, 2 Jan 1 00:00 /dev/mtd1
    crw-rw---- 1 root root 90, 3 Jan 1 00:00 /dev/mtd1ro
    crw-rw---- 1 root root 90, 4 Jan 1 00:00 /dev/mtd2
    crw-rw---- 1 root root 90, 5 Jan 1 00:00 /dev/mtd2ro
    crw-rw---- 1 root root 90, 6 Jan 1 00:00 /dev/mtd3
    crw-rw---- 1 root root 90, 7 Jan 1 00:00 /dev/mtd3ro
    brw-rw---- 1 root root 31, 0 Jan 1 00:00 /dev/mtdblock0
    brw-rw---- 1 root root 31, 1 Jan 1 00:00 /dev/mtdblock1
    brw-rw---- 1 root root 31, 2 Jan 1 00:00 /dev/mtdblock2
    brw-rw---- 1 root root 31, 3 Jan 1 00:00 /dev/mtdblock3
    To create device node for 1st partition:
    mknod /dev/mtd0 c 90 0
    /dev/mtd0ro c 90 1
    mknod /dev/mtdblock0 b 31 0
    where,
    c -> character driver node
    b -> block driver node
    90, 31 -> Major no
    0,1 -> Minor no.
    A2) Once you have created nodes, then you can use "mount" command to mount the filesystem.
    You should install "mtd-utils" package, by default it will be available in filesystem.
    Refer to this wikis.
    processors.wiki.ti.com/.../MTD_Utilities
    processors.wiki.ti.com/.../Mtdutils
    A3) As I said, you should need "udev" or "mdev"
  • Hello Titus,
    Can you please recommend me a filesystem and where to download it?
    Thank you
    Patricio
  • Hello Titus,
    Can you please reply to my last message?
    Patricio
  • Thank you Titus, now it worked.
