Other Parts Discussed in Thread: AM3351
Good afternoon,
I'm trying to boot Linux-4.4.12 from the ti-processor-sdk onto a custom am3351-based board. I'm able to make SPL and u-boot changes to properly load u-boot from an SD card, and this seems to be working properly. However, when loading Linux from the SD card, the process hangs at the function kernel_init with the attached console output. I've tried booting directly from the SD card, running the boot command from the u-boot prompt, and also manually loading the Linux kernel and booting using the following commands.
=> run args_mmc
=> ext4ls mmc 0:2
=> ext4load mmc 0:2 0x82000000 /boot/zImage
=> ext4load mmc 0:2 0x83800000 /boot/am335x-zc.dtb (my custom dtb file)
=> bootz 0x82000000 - 0x83800000
I only have 64 MB of DDR memory available on my system, and I've reconfigured the load addresses as follows. Is there anywhere else that I may need to reconfigure the DDR memory size? Is it a problem that I'm only using 64 MB?
#define DEFAULT_LINUX_BOOT_ENV \
"loadaddr=0x82000000\0" \
"kernel_addr_r=0x82000000\0" \
"fdtaddr=0x83800000\0" \
"fdt_addr_r=0x83800000\0" \
"rdaddr=0x83880000\0" \
"ramdisk_addr_r=0x83880000\0" \
"scriptaddr=0x80000000\0" \
"pxefile_addr_r=0x80100000\0" \
"bootm_size=0x04000000\0"
Please let me know your suggestions after reviewing my log files.
=> ext4ls mmc0:2 ** No device specified ** Command failed, result=1 => ext4ls mmc 0:2 <2, 0, 1024> EXT2 rev 1, inode_size 256 ext4fs read 0 group descriptor (blkno 1 blkoff 0) <8, 0, 32> <3712, 256, 128> read_allocated_block 973 <7784, 0, 8> read_allocated_block 973 <7784, 8, 1> iterate >.< ext4fs read 0 group descriptor (blkno 1 blkoff 0) <8, 0, 32> <3712, 256, 128> <DIR> 4096 . read_allocated_block 973 <7784, 12, 8> read_allocated_block 973 <7784, 20, 2> iterate >..< ext4fs read 0 group descriptor (blkno 1 blkoff 0) <8, 0, 32> <3712, 256, 128> <DIR> 4096 .. read_allocated_block 973 <7784, 24, 8> read_allocated_block 973 <7784, 32, 3> iterate >bin< ext4fs read 4 group descriptor (blkno 1 blkoff 128) <8, 128, 32> <1048592, 0, 128> <DIR> 4096 bin read_allocated_block 973 <7784, 36, 8> read_allocated_block 973 <7784, 44, 4> iterate >boot< ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582928, 0, 128> <DIR> 4096 boot read_allocated_block 973 <7784, 48, 8> read_allocated_block 973 <7784, 56, 3> iterate >dev< ext4fs read 44 group descriptor (blkno 1 blkoff 1408) <10, 384, 32> <11534352, 0, 128> <DIR> 4096 dev read_allocated_block 973 <7784, 60, 8> read_allocated_block 973 <7784, 68, 3> iterate >etc< ext4fs read 32 group descriptor (blkno 1 blkoff 1024) <10, 0, 32> <8388624, 0, 128> <DIR> 4096 etc read_allocated_block 973 <7784, 72, 8> read_allocated_block 973 <7784, 80, 4> iterate >home< ext4fs read 50 group descriptor (blkno 1 blkoff 1600) <11, 64, 32> <13107216, 0, 128> <DIR> 4096 home read_allocated_block 973 <7784, 84, 8> read_allocated_block 973 <7784, 92, 7> iterate >include< ext4fs read 26 group descriptor (blkno 1 blkoff 832) <9, 320, 32> <6815760, 0, 128> <DIR> 4096 include read_allocated_block 973 <7784, 100, 8> read_allocated_block 973 <7784, 108, 3> iterate >lib< ext4fs read 5 group descriptor (blkno 1 blkoff 160) <8, 160, 32> <1314432, 0, 128> <DIR> 4096 lib read_allocated_block 973 <7784, 112, 8> read_allocated_block 973 <7784, 120, 5> iterate >media< ext4fs read 49 group descriptor (blkno 1 blkoff 1568) <11, 32, 32> <12848768, 0, 128> <DIR> 4096 media read_allocated_block 973 <7784, 128, 8> read_allocated_block 973 <7784, 136, 3> iterate >mnt< ext4fs read 16 group descriptor (blkno 1 blkoff 512) <9, 0, 32> <4194320, 0, 128> <DIR> 4096 mnt read_allocated_block 973 <7784, 140, 8> read_allocated_block 973 <7784, 148, 3> iterate >opt< ext4fs read 46 group descriptor (blkno 1 blkoff 1472) <10, 448, 32> <12058640, 0, 128> <DIR> 4096 opt read_allocated_block 973 <7784, 152, 8> read_allocated_block 973 <7784, 160, 4> iterate >proc< ext4fs read 51 group descriptor (blkno 1 blkoff 1632) <11, 96, 32> <13369360, 0, 128> <DIR> 4096 proc read_allocated_block 973 <7784, 164, 8> read_allocated_block 973 <7784, 172, 3> iterate >run< ext4fs read 18 group descriptor (blkno 1 blkoff 576) <9, 64, 32> <4718608, 0, 128> <DIR> 4096 run read_allocated_block 973 <7784, 176, 8> read_allocated_block 973 <7784, 184, 4> iterate >sbin< ext4fs read 20 group descriptor (blkno 1 blkoff 640) <9, 128, 32> <5242896, 0, 128> <DIR> 4096 sbin read_allocated_block 973 <7784, 188, 8> read_allocated_block 973 <7784, 196, 3> iterate >srv< ext4fs read 47 group descriptor (blkno 1 blkoff 1504) <10, 480, 32> <12320784, 0, 128> <DIR> 4096 srv read_allocated_block 973 <7784, 200, 8> read_allocated_block 973 <7784, 208, 3> iterate >sys< ext4fs read 10 group descriptor (blkno 1 blkoff 320) <8, 320, 32> <2621456, 0, 128> <DIR> 4096 sys read_allocated_block 973 <7784, 212, 8> read_allocated_block 973 <7784, 220, 3> iterate >tmp< ext4fs read 17 group descriptor (blkno 1 blkoff 544) <9, 32, 32> <4456464, 0, 128> <DIR> 4096 tmp read_allocated_block 973 <7784, 224, 8> read_allocated_block 973 <7784, 232, 3> iterate >usr< ext4fs read 19 group descriptor (blkno 1 blkoff 608) <9, 96, 32> <4980752, 0, 128> <DIR> 4096 usr read_allocated_block 973 <7784, 236, 8> read_allocated_block 973 <7784, 244, 3> iterate >var< ext4fs read 52 group descriptor (blkno 1 blkoff 1664) <11, 128, 32> <13631504, 0, 128> <DIR> 4096 var read_allocated_block 973 <7784, 248, 8> read_allocated_block 973 <7784, 256, 3> iterate >www< ext4fs read 42 group descriptor (blkno 1 blkoff 1344) <10, 320, 32> <11010064, 0, 128> <DIR> 4096 www => ext4load mmc 0:2 0x82000000 /boot/zImage <2, 0, 1024> EXT2 rev 1, inode_size 256 ext4fs read 0 group descriptor (blkno 1 blkoff 0) <8, 0, 32> <3712, 256, 128> Iterate dir boot read_allocated_block 973 <7784, 0, 8> read_allocated_block 973 <7784, 8, 1> iterate >.< read_allocated_block 973 <7784, 12, 8> read_allocated_block 973 <7784, 20, 2> iterate >..< read_allocated_block 973 <7784, 24, 8> read_allocated_block 973 <7784, 32, 3> iterate >bin< read_allocated_block 973 <7784, 36, 8> read_allocated_block 973 <7784, 44, 4> iterate >boot< Iterate dir zImage ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582928, 0, 128> read_allocated_block 1573375 <12587000, 0, 8> read_allocated_block 1573375 <12587000, 8, 1> iterate >.< read_allocated_block 1573375 <12587000, 12, 8> read_allocated_block 1573375 <12587000, 20, 2> iterate >..< read_allocated_block 1573375 <12587000, 24, 8> read_allocated_block 1573375 <12587000, 32, 14> iterate >am335x-evm.dtb< read_allocated_block 1573375 <12587000, 48, 8> read_allocated_block 1573375 <12587000, 56, 25> iterate >zImage-4.4.12-g3639bea54a< read_allocated_block 1573375 <12587000, 84, 8> read_allocated_block 1573375 <12587000, 92, 16> iterate >am335x-icev2.dtb< read_allocated_block 1573375 <12587000, 108, 8> read_allocated_block 1573375 <12587000, 116, 34> iterate >devicetree-zImage-am335x-evmsk.dtb< read_allocated_block 1573375 <12587000, 152, 8> read_allocated_block 1573375 <12587000, 160, 20> iterate >am335x-bonegreen.dtb< read_allocated_block 1573375 <12587000, 180, 8> read_allocated_block 1573375 <12587000, 188, 16> iterate >am335x-evmsk.dtb< read_allocated_block 1573375 <12587000, 204, 8> read_allocated_block 1573375 <12587000, 212, 34> iterate >devicetree-zImage-am335x-icev2.dtb< read_allocated_block 1573375 <12587000, 248, 8> read_allocated_block 1573375 <12587000, 256, 32> iterate >devicetree-zImage-am335x-evm.dtb< read_allocated_block 1573375 <12587000, 288, 8> read_allocated_block 1573375 <12587000, 296, 15> iterate >am335x-bone.dtb< read_allocated_block 1573375 <12587000, 312, 8> read_allocated_block 1573375 <12587000, 320, 33> iterate >devicetree-zImage-am335x-bone.dtb< read_allocated_block 1573375 <12587000, 356, 8> read_allocated_block 1573375 <12587000, 364, 6> iterate >zImage< ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582933, 256, 128> Got symlink >zImage-4.4.12-g3639bea54a< Iterate dir zImage-4.4.12-g3639bea54a ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582928, 0, 128> read_allocated_block 1573375 <12587000, 0, 8> read_allocated_block 1573375 <12587000, 8, 1> iterate >.< read_allocated_block 1573375 <12587000, 12, 8> read_allocated_block 1573375 <12587000, 20, 2> iterate >..< read_allocated_block 1573375 <12587000, 24, 8> read_allocated_block 1573375 <12587000, 32, 14> iterate >am335x-evm.dtb< read_allocated_block 1573375 <12587000, 48, 8> read_allocated_block 1573375 <12587000, 56, 25> iterate >zImage-4.4.12-g3639bea54a< ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582929, 0, 128> read_allocated_block 1578496 read_allocated_block 1578497 read_allocated_block 1578498 read_allocated_block 1578499 read_allocated_block 1578500 read_allocated_block 1578501 read_allocated_block 1578502 read_allocated_block 1578503 read_allocated_block 1578504 read_allocated_block 1578505 read_allocated_block 1578506 read_allocated_block 1578507 <12591464, 0, 4096> read_allocated_block 1578508 read_allocated_block 1578509 read_allocated_block 1578510 read_allocated_block 1578511 read_allocated_block 3536 <12627968, 0, 65536> read_allocated_block 3537 read_allocated_block 3538 read_allocated_block 3539 read_allocated_block 3540 read_allocated_block 3541 read_allocated_block 3542 read_allocated_block 3543 read_allocated_block 3544 read_allocated_block 3545 read_allocated_block 3546 read_allocated_block 3547 read_allocated_block 3548 read_allocated_block 3549 read_allocated_block 3550 read_allocated_block 3551 read_allocated_block 3616 <28288, 0, 65536> read_allocated_block 3617 read_allocated_block 3618 read_allocated_block 3619 read_allocated_block 3620 read_allocated_block 3621 read_allocated_block 3622 read_allocated_block 3623 read_allocated_block 3624 read_allocated_block 3625 read_allocated_block 3626 read_allocated_block 3627 read_allocated_block 3628 read_allocated_block 3629 read_allocated_block 3630 read_allocated_block 3631 read_allocated_block 3632 read_allocated_block 3633 read_allocated_block 3634 read_allocated_block 3635 read_allocated_block 3636 read_allocated_block 3637 read_allocated_block 3638 read_allocated_block 3639 read_allocated_block 3640 read_allocated_block 3641 read_allocated_block 3642 read_allocated_block 3643 read_allocated_block 3644 read_allocated_block 3645 read_allocated_block 3646 read_allocated_block 3647 read_allocated_block 3872 <28928, 0, 131072> read_allocated_block 3873 read_allocated_block 3874 read_allocated_block 3875 read_allocated_block 3876 read_allocated_block 3877 read_allocated_block 3878 read_allocated_block 3879 read_allocated_block 3880 read_allocated_block 3881 read_allocated_block 3882 read_allocated_block 3883 read_allocated_block 3884 read_allocated_block 3885 read_allocated_block 3886 read_allocated_block 3887 read_allocated_block 3888 read_allocated_block 3889 read_allocated_block 3890 read_allocated_block 3891 read_allocated_block 3892 read_allocated_block 3893 read_allocated_block 3894 read_allocated_block 3895 read_allocated_block 3896 read_allocated_block 3897 read_allocated_block 3898 read_allocated_block 3899 read_allocated_block 3900 read_allocated_block 3901 read_allocated_block 3902 read_allocated_block 3903 read_allocated_block 3904 read_allocated_block 3905 read_allocated_block 3906 read_allocated_block 3907 read_allocated_block 3908 read_allocated_block 3909 read_allocated_block 3910 read_allocated_block 3911 read_allocated_block 3912 read_allocated_block 3913 read_allocated_block 3914 read_allocated_block 3915 read_allocated_block 3916 read_allocated_block 3917 read_allocated_block 3918 read_allocated_block 3919 read_allocated_block 3920 read_allocated_block 3921 read_allocated_block 3922 read_allocated_block 3923 read_allocated_block 3924 read_allocated_block 3925 read_allocated_block 3926 read_allocated_block 3927 read_allocated_block 3928 read_allocated_block 3929 read_allocated_block 3930 read_allocated_block 3931 read_allocated_block 3932 read_allocated_block 3933 read_allocated_block 3934 read_allocated_block 3935 read_allocated_block 3968 <30976, 0, 262144> read_allocated_block 3969 read_allocated_block 3970 read_allocated_block 3971 read_allocated_block 3972 read_allocated_block 3973 read_allocated_block 3974 read_allocated_block 3975 read_allocated_block 3976 read_allocated_block 3977 read_allocated_block 3978 read_allocated_block 3979 read_allocated_block 3980 read_allocated_block 3981 read_allocated_block 3982 read_allocated_block 3983 read_allocated_block 3984 read_allocated_block 3985 read_allocated_block 3986 read_allocated_block 3987 read_allocated_block 3988 read_allocated_block 3989 read_allocated_block 3990 read_allocated_block 3991 read_allocated_block 3992 read_allocated_block 3993 read_allocated_block 3994 read_allocated_block 3995 read_allocated_block 3996 read_allocated_block 3997 read_allocated_block 3998 read_allocated_block 3999 read_allocated_block 4000 read_allocated_block 4001 read_allocated_block 4002 read_allocated_block 4003 read_allocated_block 4004 read_allocated_block 4005 read_allocated_block 4006 read_allocated_block 4007 read_allocated_block 4008 read_allocated_block 4009 read_allocated_block 4010 read_allocated_block 4011 read_allocated_block 4012 read_allocated_block 4013 read_allocated_block 4014 read_allocated_block 4015 read_allocated_block 4016 read_allocated_block 4017 read_allocated_block 4018 read_allocated_block 4019 read_allocated_block 4020 read_allocated_block 4021 read_allocated_block 4022 read_allocated_block 4023 read_allocated_block 4024 read_allocated_block 4025 read_allocated_block 4026 read_allocated_block 4027 read_allocated_block 4028 read_allocated_block 4029 read_allocated_block 4030 read_allocated_block 4031 read_allocated_block 4032 read_allocated_block 4033 read_allocated_block 4034 read_allocated_block 4035 read_allocated_block 4036 read_allocated_block 4037 read_allocated_block 4038 read_allocated_block 4039 read_allocated_block 4040 read_allocated_block 4041 read_allocated_block 4042 read_allocated_block 4043 read_allocated_block 4044 read_allocated_block 4045 read_allocated_block 4046 read_allocated_block 4047 read_allocated_block 4048 read_allocated_block 4049 read_allocated_block 4050 read_allocated_block 4051 read_allocated_block 4052 read_allocated_block 4053 read_allocated_block 4054 read_allocated_block 4055 read_allocated_block 4056 read_allocated_block 4057 read_allocated_block 4058 read_allocated_block 4059 read_allocated_block 4060 read_allocated_block 4061 read_allocated_block 4062 read_allocated_block 4063 read_allocated_block 4064 read_allocated_block 4065 read_allocated_block 4066 read_allocated_block 4067 read_allocated_block 4068 read_allocated_block 4069 read_allocated_block 4070 read_allocated_block 4071 read_allocated_block 4072 read_allocated_block 4073 read_allocated_block 4074 read_allocated_block 4075 read_allocated_block 4076 read_allocated_block 4077 read_allocated_block 4078 read_allocated_block 4079 read_allocated_block 4080 read_allocated_block 4081 read_allocated_block 4082 read_allocated_block 4083 read_allocated_block 4084 read_allocated_block 4085 read_allocated_block 4086 read_allocated_block 4087 read_allocated_block 4088 read_allocated_block 4089 read_allocated_block 4090 read_allocated_block 4091 read_allocated_block 4092 read_allocated_block 4093 read_allocated_block 4094 read_allocated_block 4095 read_allocated_block 5504 <31744, 0, 524288> read_allocated_block 5505 read_allocated_block 5506 read_allocated_block 5507 read_allocated_block 5508 read_allocated_block 5509 read_allocated_block 5510 read_allocated_block 5511 read_allocated_block 5512 read_allocated_block 5513 read_allocated_block 5514 read_allocated_block 5515 read_allocated_block 5516 read_allocated_block 5517 read_allocated_block 5518 read_allocated_block 5519 read_allocated_block 5520 read_allocated_block 5521 read_allocated_block 5522 read_allocated_block 5523 read_allocated_block 5524 read_allocated_block 5525 read_allocated_block 5526 read_allocated_block 5527 read_allocated_block 5528 read_allocated_block 5529 read_allocated_block 5530 read_allocated_block 5531 read_allocated_block 5532 read_allocated_block 5533 read_allocated_block 5534 read_allocated_block 5535 read_allocated_block 5536 read_allocated_block 5537 read_allocated_block 5538 read_allocated_block 5539 read_allocated_block 5540 read_allocated_block 5541 read_allocated_block 5542 read_allocated_block 5543 read_allocated_block 5544 read_allocated_block 5545 read_allocated_block 5546 read_allocated_block 5547 read_allocated_block 5548 read_allocated_block 5549 read_allocated_block 5550 read_allocated_block 5551 read_allocated_block 5552 read_allocated_block 5553 read_allocated_block 5554 read_allocated_block 5555 read_allocated_block 5556 read_allocated_block 5557 read_allocated_block 5558 read_allocated_block 5559 read_allocated_block 5560 read_allocated_block 5561 read_allocated_block 5562 read_allocated_block 5563 read_allocated_block 5564 read_allocated_block 5565 read_allocated_block 5566 read_allocated_block 5567 read_allocated_block 5568 read_allocated_block 5569 read_allocated_block 5570 read_allocated_block 5571 read_allocated_block 5572 read_allocated_block 5573 read_allocated_block 5574 read_allocated_block 5575 read_allocated_block 5576 read_allocated_block 5577 read_allocated_block 5578 read_allocated_block 5579 read_allocated_block 5580 read_allocated_block 5581 read_allocated_block 5582 read_allocated_block 5583 read_allocated_block 5584 read_allocated_block 5585 read_allocated_block 5586 read_allocated_block 5587 read_allocated_block 5588 read_allocated_block 5589 read_allocated_block 5590 read_allocated_block 5591 read_allocated_block 5592 read_allocated_block 5593 read_allocated_block 5594 read_allocated_block 5595 read_allocated_block 5596 read_allocated_block 5597 read_allocated_block 5598 read_allocated_block 5599 read_allocated_block 5600 read_allocated_block 5601 read_allocated_block 5602 read_allocated_block 5603 read_allocated_block 5604 read_allocated_block 5605 read_allocated_block 5606 read_allocated_block 5607 read_allocated_block 5608 read_allocated_block 5609 read_allocated_block 5610 read_allocated_block 5611 read_allocated_block 5612 read_allocated_block 5613 read_allocated_block 5614 read_allocated_block 5615 read_allocated_block 5616 read_allocated_block 5617 read_allocated_block 5618 read_allocated_block 5619 read_allocated_block 5620 read_allocated_block 5621 read_allocated_block 5622 read_allocated_block 5623 read_allocated_block 5624 read_allocated_block 5625 read_allocated_block 5626 read_allocated_block 5627 read_allocated_block 5628 read_allocated_block 5629 read_allocated_block 5630 read_allocated_block 5631 read_allocated_block 5632 read_allocated_block 5633 read_allocated_block 5634 read_allocated_block 5635 read_allocated_block 5636 read_allocated_block 5637 read_allocated_block 5638 read_allocated_block 5639 read_allocated_block 5640 read_allocated_block 5641 read_allocated_block 5642 read_allocated_block 5643 read_allocated_block 5644 read_allocated_block 5645 read_allocated_block 5646 read_allocated_block 5647 read_allocated_block 5648 read_allocated_block 5649 read_allocated_block 5650 read_allocated_block 5651 read_allocated_block 5652 read_allocated_block 5653 read_allocated_block 5654 read_allocated_block 5655 read_allocated_block 5656 read_allocated_block 5657 read_allocated_block 5658 read_allocated_block 5659 read_allocated_block 5660 read_allocated_block 5661 read_allocated_block 5662 read_allocated_block 5663 read_allocated_block 5664 read_allocated_block 5665 read_allocated_block 5666 read_allocated_block 5667 read_allocated_block 5668 read_allocated_block 5669 read_allocated_block 5670 read_allocated_block 5671 read_allocated_block 5672 read_allocated_block 5673 read_allocated_block 5674 read_allocated_block 5675 read_allocated_block 5676 read_allocated_block 5677 read_allocated_block 5678 read_allocated_block 5679 read_allocated_block 5680 read_allocated_block 5681 read_allocated_block 5682 read_allocated_block 5683 read_allocated_block 5684 read_allocated_block 5685 read_allocated_block 5686 read_allocated_block 5687 read_allocated_block 5688 read_allocated_block 5689 read_allocated_block 5690 read_allocated_block 5691 read_allocated_block 5692 read_allocated_block 5693 read_allocated_block 5694 read_allocated_block 5695 read_allocated_block 5696 read_allocated_block 5697 read_allocated_block 5698 read_allocated_block 5699 read_allocated_block 5700 read_allocated_block 5701 read_allocated_block 5702 read_allocated_block 5703 read_allocated_block 5704 read_allocated_block 5705 read_allocated_block 5706 read_allocated_block 5707 read_allocated_block 5708 read_allocated_block 5709 read_allocated_block 5710 read_allocated_block 5711 read_allocated_block 5712 read_allocated_block 5713 read_allocated_block 5714 read_allocated_block 5715 read_allocated_block 5716 read_allocated_block 5717 read_allocated_block 5718 read_allocated_block 5719 read_allocated_block 5720 read_allocated_block 5721 read_allocated_block 5722 read_allocated_block 5723 read_allocated_block 5724 read_allocated_block 5725 read_allocated_block 5726 read_allocated_block 5727 read_allocated_block 5728 read_allocated_block 5729 read_allocated_block 5730 read_allocated_block 5731 read_allocated_block 5732 read_allocated_block 5733 read_allocated_block 5734 read_allocated_block 5735 read_allocated_block 5736 read_allocated_block 5737 read_allocated_block 5738 read_allocated_block 5739 read_allocated_block 5740 read_allocated_block 5741 read_allocated_block 5742 read_allocated_block 5743 read_allocated_block 5744 read_allocated_block 5745 read_allocated_block 5746 read_allocated_block 5747 read_allocated_block 5748 read_allocated_block 5749 read_allocated_block 5750 read_allocated_block 5751 read_allocated_block 5752 read_allocated_block 5753 read_allocated_block 5754 read_allocated_block 5755 read_allocated_block 5756 read_allocated_block 5757 read_allocated_block 5758 read_allocated_block 5759 read_allocated_block 6144 <44032, 0, 1048576> read_allocated_block 6145 read_allocated_block 6146 read_allocated_block 6147 read_allocated_block 6148 read_allocated_block 6149 read_allocated_block 6150 read_allocated_block 6151 read_allocated_block 6152 read_allocated_block 6153 read_allocated_block 6154 read_allocated_block 6155 read_allocated_block 6156 read_allocated_block 6157 read_allocated_block 6158 read_allocated_block 6159 read_allocated_block 6160 read_allocated_block 6161 read_allocated_block 6162 read_allocated_block 6163 read_allocated_block 6164 read_allocated_block 6165 read_allocated_block 6166 read_allocated_block 6167 read_allocated_block 6168 read_allocated_block 6169 read_allocated_block 6170 read_allocated_block 6171 read_allocated_block 6172 read_allocated_block 6173 read_allocated_block 6174 read_allocated_block 6175 read_allocated_block 6176 read_allocated_block 6177 read_allocated_block 6178 read_allocated_block 6179 read_allocated_block 6180 read_allocated_block 6181 read_allocated_block 6182 read_allocated_block 6183 read_allocated_block 6184 read_allocated_block 6185 read_allocated_block 6186 read_allocated_block 6187 read_allocated_block 6188 read_allocated_block 6189 read_allocated_block 6190 read_allocated_block 6191 read_allocated_block 6192 read_allocated_block 6193 read_allocated_block 6194 read_allocated_block 6195 read_allocated_block 6196 read_allocated_block 6197 read_allocated_block 6198 read_allocated_block 6199 read_allocated_block 6200 read_allocated_block 6201 read_allocated_block 6202 read_allocated_block 6203 read_allocated_block 6204 read_allocated_block 6205 read_allocated_block 6206 read_allocated_block 6207 read_allocated_block 6208 read_allocated_block 6209 read_allocated_block 6210 read_allocated_block 6211 read_allocated_block 6212 read_allocated_block 6213 read_allocated_block 6214 read_allocated_block 6215 read_allocated_block 6216 read_allocated_block 6217 read_allocated_block 6218 read_allocated_block 6219 read_allocated_block 6220 read_allocated_block 6221 read_allocated_block 6222 read_allocated_block 6223 read_allocated_block 6224 read_allocated_block 6225 read_allocated_block 6226 read_allocated_block 6227 read_allocated_block 6228 read_allocated_block 6229 read_allocated_block 6230 read_allocated_block 6231 read_allocated_block 6232 read_allocated_block 6233 read_allocated_block 6234 read_allocated_block 6235 read_allocated_block 6236 read_allocated_block 6237 read_allocated_block 6238 read_allocated_block 6239 read_allocated_block 6240 read_allocated_block 6241 read_allocated_block 6242 read_allocated_block 6243 read_allocated_block 6244 read_allocated_block 6245 read_allocated_block 6246 read_allocated_block 6247 read_allocated_block 6248 read_allocated_block 6249 read_allocated_block 6250 read_allocated_block 6251 read_allocated_block 6252 read_allocated_block 6253 read_allocated_block 6254 read_allocated_block 6255 read_allocated_block 6256 read_allocated_block 6257 read_allocated_block 6258 read_allocated_block 6259 read_allocated_block 6260 read_allocated_block 6261 read_allocated_block 6262 read_allocated_block 6263 read_allocated_block 6264 read_allocated_block 6265 read_allocated_block 6266 read_allocated_block 6267 read_allocated_block 6268 read_allocated_block 6269 read_allocated_block 6270 read_allocated_block 6271 read_allocated_block 6272 read_allocated_block 6273 read_allocated_block 6274 read_allocated_block 6275 read_allocated_block 6276 read_allocated_block 6277 read_allocated_block 6278 read_allocated_block 6279 read_allocated_block 6280 read_allocated_block 6281 read_allocated_block 6282 read_allocated_block 6283 read_allocated_block 6284 read_allocated_block 6285 read_allocated_block 6286 read_allocated_block 6287 read_allocated_block 6288 read_allocated_block 6289 read_allocated_block 6290 read_allocated_block 6291 read_allocated_block 6292 read_allocated_block 6293 read_allocated_block 6294 read_allocated_block 6295 read_allocated_block 6296 read_allocated_block 6297 read_allocated_block 6298 read_allocated_block 6299 read_allocated_block 6300 read_allocated_block 6301 read_allocated_block 6302 read_allocated_block 6303 read_allocated_block 6304 read_allocated_block 6305 read_allocated_block 6306 read_allocated_block 6307 read_allocated_block 6308 read_allocated_block 6309 read_allocated_block 6310 read_allocated_block 6311 read_allocated_block 6312 read_allocated_block 6313 read_allocated_block 6314 read_allocated_block 6315 read_allocated_block 6316 read_allocated_block 6317 read_allocated_block 6318 read_allocated_block 6319 read_allocated_block 6320 read_allocated_block 6321 read_allocated_block 6322 read_allocated_block 6323 read_allocated_block 6324 read_allocated_block 6325 read_allocated_block 6326 read_allocated_block 6327 read_allocated_block 6328 read_allocated_block 6329 read_allocated_block 6330 read_allocated_block 6331 read_allocated_block 6332 read_allocated_block 6333 read_allocated_block 6334 read_allocated_block 6335 read_allocated_block 6336 read_allocated_block 6337 read_allocated_block 6338 read_allocated_block 6339 read_allocated_block 6340 read_allocated_block 6341 read_allocated_block 6342 read_allocated_block 6343 read_allocated_block 6344 read_allocated_block 6345 read_allocated_block 6346 read_allocated_block 6347 read_allocated_block 6348 read_allocated_block 6349 read_allocated_block 6350 read_allocated_block 6351 read_allocated_block 6352 read_allocated_block 6353 read_allocated_block 6354 read_allocated_block 6355 read_allocated_block 6356 read_allocated_block 6357 read_allocated_block 6358 read_allocated_block 6359 read_allocated_block 6360 read_allocated_block 6361 read_allocated_block 6362 read_allocated_block 6363 read_allocated_block 6364 read_allocated_block 6365 read_allocated_block 6366 read_allocated_block 6367 read_allocated_block 6368 read_allocated_block 6369 read_allocated_block 6370 read_allocated_block 6371 read_allocated_block 6372 read_allocated_block 6373 read_allocated_block 6374 read_allocated_block 6375 read_allocated_block 6376 read_allocated_block 6377 read_allocated_block 6378 read_allocated_block 6379 read_allocated_block 6380 read_allocated_block 6381 read_allocated_block 6382 read_allocated_block 6383 read_allocated_block 6384 read_allocated_block 6385 read_allocated_block 6386 read_allocated_block 6387 read_allocated_block 6388 read_allocated_block 6389 read_allocated_block 6390 read_allocated_block 6391 read_allocated_block 6392 read_allocated_block 6393 read_allocated_block 6394 read_allocated_block 6395 read_allocated_block 6396 read_allocated_block 6397 read_allocated_block 6398 read_allocated_block 6399 read_allocated_block 6400 read_allocated_block 6401 read_allocated_block 6402 read_allocated_block 6403 read_allocated_block 6404 read_allocated_block 6405 read_allocated_block 6406 read_allocated_block 6407 read_allocated_block 6408 read_allocated_block 6409 read_allocated_block 6410 read_allocated_block 6411 read_allocated_block 6412 read_allocated_block 6413 read_allocated_block 6414 read_allocated_block 6415 read_allocated_block 6416 read_allocated_block 6417 read_allocated_block 6418 read_allocated_block 6419 read_allocated_block 6420 read_allocated_block 6421 read_allocated_block 6422 read_allocated_block 6423 read_allocated_block 6424 read_allocated_block 6425 read_allocated_block 6426 read_allocated_block 6427 read_allocated_block 6428 read_allocated_block 6429 read_allocated_block 6430 read_allocated_block 6431 read_allocated_block 6432 read_allocated_block 6433 read_allocated_block 6434 read_allocated_block 6435 read_allocated_block 6436 read_allocated_block 6437 read_allocated_block 6438 read_allocated_block 6439 read_allocated_block 6440 read_allocated_block 6441 read_allocated_block 6442 read_allocated_block 6443 read_allocated_block 6444 read_allocated_block 6445 read_allocated_block 6446 read_allocated_block 6447 read_allocated_block 6448 read_allocated_block 6449 read_allocated_block 6450 read_allocated_block 6451 read_allocated_block 6452 read_allocated_block 6453 read_allocated_block 6454 read_allocated_block 6455 read_allocated_block 6456 read_allocated_block 6457 read_allocated_block 6458 read_allocated_block 6459 read_allocated_block 6460 read_allocated_block 6461 read_allocated_block 6462 read_allocated_block 6463 read_allocated_block 6464 read_allocated_block 6465 read_allocated_block 6466 read_allocated_block 6467 read_allocated_block 6468 read_allocated_block 6469 read_allocated_block 6470 read_allocated_block 6471 read_allocated_block 6472 read_allocated_block 6473 read_allocated_block 6474 read_allocated_block 6475 read_allocated_block 6476 read_allocated_block 6477 read_allocated_block 6478 read_allocated_block 6479 read_allocated_block 6480 read_allocated_block 6481 read_allocated_block 6482 read_allocated_block 6483 read_allocated_block 6484 read_allocated_block 6485 read_allocated_block 6486 read_allocated_block 6487 read_allocated_block 6488 read_allocated_block 6489 read_allocated_block 6490 read_allocated_block 6491 read_allocated_block 6492 read_allocated_block 6493 read_allocated_block 6494 read_allocated_block 6495 read_allocated_block 6496 read_allocated_block 6497 read_allocated_block 6498 read_allocated_block 6499 read_allocated_block 6500 read_allocated_block 6501 read_allocated_block 6502 read_allocated_block 6503 read_allocated_block 6504 read_allocated_block 6505 read_allocated_block 6506 read_allocated_block 6507 read_allocated_block 6508 read_allocated_block 6509 read_allocated_block 6510 read_allocated_block 6511 read_allocated_block 6512 read_allocated_block 6513 read_allocated_block 6514 read_allocated_block 6515 read_allocated_block 6516 read_allocated_block 6517 read_allocated_block 6518 read_allocated_block 6519 read_allocated_block 6520 read_allocated_block 6521 read_allocated_block 6522 read_allocated_block 6523 read_allocated_block 6524 read_allocated_block 6525 read_allocated_block 6526 <49152, 0, 1565056> 3662208 bytes read in 2944 ms (1.2 MiB/s) Initial value for argc=3 Final value for argc=3 Initial value for argc=3 Final value for argc=3 => ext4load mmc 0:2 0x83800000 /boot/am335x-zc.dtb <2, 0, 1024> EXT2 rev 1, inode_size 256 ext4fs read 0 group descriptor (blkno 1 blkoff 0) <8, 0, 32> <3712, 256, 128> Iterate dir boot read_allocated_block 973 <7784, 0, 8> read_allocated_block 973 <7784, 8, 1> iterate >.< read_allocated_block 973 <7784, 12, 8> read_allocated_block 973 <7784, 20, 2> iterate >..< read_allocated_block 973 <7784, 24, 8> read_allocated_block 973 <7784, 32, 3> iterate >bin< read_allocated_block 973 <7784, 36, 8> read_allocated_block 973 <7784, 44, 4> iterate >boot< Iterate dir am335x-zc.dtb ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582928, 0, 128> read_allocated_block 1573375 <12587000, 0, 8> read_allocated_block 1573375 <12587000, 8, 1> iterate >.< read_allocated_block 1573375 <12587000, 12, 8> read_allocated_block 1573375 <12587000, 20, 2> iterate >..< read_allocated_block 1573375 <12587000, 24, 8> read_allocated_block 1573375 <12587000, 32, 14> iterate >am335x-evm.dtb< read_allocated_block 1573375 <12587000, 48, 8> read_allocated_block 1573375 <12587000, 56, 25> iterate >zImage-4.4.12-g3639bea54a< read_allocated_block 1573375 <12587000, 84, 8> read_allocated_block 1573375 <12587000, 92, 16> iterate >am335x-icev2.dtb< read_allocated_block 1573375 <12587000, 108, 8> read_allocated_block 1573375 <12587000, 116, 34> iterate >devicetree-zImage-am335x-evmsk.dtb< read_allocated_block 1573375 <12587000, 152, 8> read_allocated_block 1573375 <12587000, 160, 20> iterate >am335x-bonegreen.dtb< read_allocated_block 1573375 <12587000, 180, 8> read_allocated_block 1573375 <12587000, 188, 16> iterate >am335x-evmsk.dtb< read_allocated_block 1573375 <12587000, 204, 8> read_allocated_block 1573375 <12587000, 212, 34> iterate >devicetree-zImage-am335x-icev2.dtb< read_allocated_block 1573375 <12587000, 248, 8> read_allocated_block 1573375 <12587000, 256, 32> iterate >devicetree-zImage-am335x-evm.dtb< read_allocated_block 1573375 <12587000, 288, 8> read_allocated_block 1573375 <12587000, 296, 15> iterate >am335x-bone.dtb< read_allocated_block 1573375 <12587000, 312, 8> read_allocated_block 1573375 <12587000, 320, 33> iterate >devicetree-zImage-am335x-bone.dtb< read_allocated_block 1573375 <12587000, 356, 8> read_allocated_block 1573375 <12587000, 364, 6> iterate >zImage< read_allocated_block 1573375 <12587000, 372, 8> read_allocated_block 1573375 <12587000, 380, 20> iterate >am335x-boneblack.dtb< read_allocated_block 1573375 <12587000, 400, 8> read_allocated_block 1573375 <12587000, 408, 38> iterate >devicetree-zImage-am335x-boneblack.dtb< read_allocated_block 1573375 <12587000, 448, 8> read_allocated_block 1573375 <12587000, 456, 26> iterate >vmlinux-4.4.12-g3639bea54a< read_allocated_block 1573375 <12587000, 484, 8> read_allocated_block 1573375 <12587000, 492, 38> iterate >devicetree-zImage-am335x-bonegreen.dtb< read_allocated_block 1573375 <12587001, 20, 8> read_allocated_block 1573375 <12587001, 28, 13> iterate >am335x-zc.dtb< ext4fs read 48 group descriptor (blkno 1 blkoff 1536) <11, 0, 32> <12582936, 0, 128> read_allocated_block 1577984 read_allocated_block 1577985 read_allocated_block 1577986 read_allocated_block 1577987 read_allocated_block 1577988 read_allocated_block 1577989 read_allocated_block 1577990 <12623872, 0, 27813> 27813 bytes read in 332 ms (81.1 KiB/s) Initial value for argc=3 Final value for argc=3 Initial value for argc=3 Final value for argc=3 => bootz 0x82000000 - 0x83800000 ## Current stack ends at 0x82f22018 * kernel: cmdline image address = 0x82000000 Kernel image @ 0x82000000 [ 0x000000 - 0x37e180 ] ## Skipping init Ramdisk ## No init Ramdisk ramdisk start = 0x00000000, ramdisk end = 0x00000000 * fdt: cmdline image address = 0x83800000 ## Checking for 'FDT'/'FDT Image' at 83800000 Wrong FIT format: no description * fdt: raw FDT blob ## Flattened Device Tree blob at 83800000 Booting using the fdt blob at 0x83800000 of_flat_tree at 0x83800000 size 0x00006ca5 Initial value for argc=3 Final value for argc=3 ## FIT configuration was not specified using: FDT ## initrd_high = 0x84000000, copy_to_ram = 1 ramdisk load start = 0x00000000, ramdisk load end = 0x00000000 ## device tree at 83800000 ... 83806ca4 (len=40101 [0x9CA5]) Loading Device Tree to 82f17000, end 82f20ca4 ... OK Initial value for argc=3 Final value for argc=3 Updating property '/ocp/ethernet@4a100000/slave@4a100200/mac-address' = a0 f6 fd 27 f2 11 Updating property '/ocp/ethernet@4a100000/slave@4a100200/local-mac-address' = a0 f6 fd 27 f2 11 Updating property '/ocp/ethernet@4a100000/slave@4a100300/mac-address' = a0 f6 fd 27 f2 13 Updating property '/ocp/ethernet@4a100000/slave@4a100300/local-mac-address' = a0 f6 fd 27 f2 13 ## Transferring control to Linux (at address 82000000)... Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.12-g3639bea54a (clightcap@hp-envy) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #12 PREEMPT Mon Nov 7 10:06:43 EST 2016 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: TI AM335x ZC [ 0.000000] bootconsole [earlycon0] enabled [ 0.000000] cma: Reserved 24 MiB at 0x81000000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16240 [ 0.000000] Kernel command line: console=ttyO0,115200n8 earlyprintk=ttyO0,115200n8,keep mem=64m root=PARTUUID=19b1aec4-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes) [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Memory: 29692K/65536K available (7095K kernel code, 292K rwdata, 2444K rodata, 288K init, 263K bss, 11268K reserved, 24576K cma-reserved, 0K h ighmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0959034 (9541 kB) [ 0.000000] .init : 0xc095a000 - 0xc09a2000 ( 288 kB) [ 0.000000] .data : 0xc09a2000 - 0xc09eb288 ( 293 kB) [ 0.000000] .bss : 0xc09ed000 - 0xc0a2eed8 ( 264 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000031] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.008252] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.017879] OMAP clocksource: timer1 at 24000000 Hz [ 0.023794] clocksource_probe: no matching clocksources found [ 0.030337] Console: colour dummy device 80x30 [ 0.035113] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.041956] This ensures that you still see kernel messages. Please [ 0.048551] update your kernel commandline. [ 0.053018] Calibrating delay loop... 298.59 BogoMIPS (lpj=1492992) [ 0.125269] pid_max: default: 32768 minimum: 301 [ 0.130390] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.137363] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.146308] Initializing cgroup subsys io [ 0.150595] Initializing cgroup subsys memory [ 0.155334] Initializing cgroup subsys devices [ 0.160044] Initializing cgroup subsys freezer [ 0.164781] Initializing cgroup subsys perf_event [ 0.169755] Initializing cgroup subsys pids [ 0.174255] CPU: Testing write buffer coherency: ok [ 0.180186] Setting up static identity map for 0x800082c0 - 0x80008318 [ 0.192317] devtmpfs: initialized [ 0.217094] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.247108] omap_hwmod: tptc0 using broken dt data from edma [ 0.253429] omap_hwmod: tptc1 using broken dt data from edma [ 0.259659] omap_hwmod: tptc2 using broken dt data from edma [ 0.273091] omap_hwmod: debugss: _wait_target_disable failed [ 0.279797] Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e3e078 [ 0.287813] pgd = c0004000 [ 0.290702] [f9e3e078] *pgd=44e11452(bad) [ 0.294966] Internal error: : 1028 [#1] PREEMPT ARM [ 0.300106] Modules linked in: [ 0.303375] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.12-g3639bea54a #12 [ 0.310576] Hardware name: Generic AM33XX (Flattened Device Tree) [ 0.316971] task: c3830000 ti: c382e000 task.ti: c382e000 [ 0.322687] PC is at _update_sysc_cache+0x3c/0x94 [ 0.327651] LR is at _enable+0x2ac/0x318 [ 0.331807] pc : [<c00236c0>] lr : [<c0023ca0>] psr: 40000013 [ 0.331807] sp : c382fe50 ip : c382fe60 fp : c382fe5c [ 0.343861] r10: 00000000 r9 : c095a600 r8 : 000000d7 [ 0.349354] r7 : c09ed5d0 r6 : 00000000 r5 : 00000000 r4 : c09ac338 [ 0.356193] r3 : c09ac338 r2 : f9e3e078 r1 : c09aceb0 r0 : f9e3e000 [ 0.363039] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none [ 0.370511] Control: 10c5387d Table: 80004019 DAC: 00000051 [ 0.376551] Process swapper (pid: 1, stack limit = 0xc382e210) [ 0.382675] Stack: (0xc382fe50 to 0xc3830000) [ 0.387283] fe40: c382fe84 c382fe60 c0023ca0 c0023690 [ 0.395850] fe60: c382fe84 c382fe70 c09ac338 00000002 c09ac384 c386f540 c382feb4 c382fe88 [ 0.404412] fe80: c0965874 c0023a00 c09660b0 c09acc80 c09a9320 c09a70e8 c386f540 c09ac338 [ 0.412979] fea0: c09a9320 c09a70e8 c382fecc c382feb8 c096612c c09657b4 c09a70e8 c09660b0 [ 0.421541] fec0: c382ff4c c382fed0 c0009760 c09660bc c382fef4 c382fee0 c004d468 c02a06d0 [ 0.430105] fee0: c3fff400 c0715268 c382ff4c c382fef8 c004d778 c095a60c 00000000 c088ff6c [ 0.438669] ff00: c088ffb8 c088f960 00000001 00000001 00000000 c0956998 c090a92c 00000000 [ 0.447236] ff20: 00000000 c09ed000 c09ed000 c09a0f98 c099381c 000000d7 c095a600 00000002 [ 0.455798] ff40: c382ff94 c382ff50 c095ae80 c00096d4 00000001 00000001 00000000 c095a600 [ 0.464361] ff60: 00000000 c0956998 00000000 c09ed000 c06eebac 00000000 00000000 00000000 [ 0.472924] ff80: 00000000 00000000 c382ffac c382ff98 c06eebc4 c095ad54 00000000 c06eebac [ 0.481489] ffa0: 00000000 c382ffb0 c000fb38 c06eebb8 00000000 00000000 00000000 00000000 [ 0.490056] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.498619] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 0.507155] Backtrace: [ 0.509807] [<c0023684>] (_update_sysc_cache) from [<c0023ca0>] (_enable+0x2ac/0x318) [ 0.518028] [<c00239f4>] (_enable) from [<c0965874>] (_setup.part.14+0xcc/0x3fc) [ 0.525765] r7:c386f540 r6:c09ac384 r5:00000002 r4:c09ac338 [ 0.531756] [<c09657a8>] (_setup.part.14) from [<c096612c>] (__omap_hwmod_setup_all+0x7c/0x98) [ 0.540745] r6:c09a70e8 r5:c09a9320 r4:c09ac338 [ 0.545646] [<c09660b0>] (__omap_hwmod_setup_all) from [<c0009760>] (do_one_initcall+0x98/0x1e4) [ 0.554817] r5:c09660b0 r4:c09a70e8 [ 0.558626] [<c00096c8>] (do_one_initcall) from [<c095ae80>] (kernel_init_freeable+0x138/0x1cc) [ 0.567709] r10:00000002 r9:c095a600 r8:000000d7 r7:c099381c r6:c09a0f98 r5:c09ed000 [ 0.575927] r4:c09ed000 [ 0.578665] [<c095ad48>] (kernel_init_freeable) from [<c06eebc4>] (kernel_init+0x18/0xf4) [ 0.587213] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c06eebac [ 0.595427] r4:c09ed000 [ 0.598165] [<c06eebac>] (kernel_init) from [<c000fb38>] (ret_from_fork+0x14/0x3c) [ 0.606078] r5:c06eebac r4:00000000 [ 0.609889] Code: e593005c e6ff2072 e0802002 1a000009 (e5922000) [ 0.616365] ---[ end trace 59ae336d970bcf14 ]--- [ 0.621371] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 0.621371] [ 0.631017] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 0.631017] [ 82.912444] random: nonblocking pool is initialized
Chris
