Other Parts Discussed in Thread: TUSB9261
We got a problem with musb dma transfer.
Here is hardware topology: USB0 is a usb2stata bridge(TUSB9261), USB1 is a usb hub(USB2514B), on this hub there are two smartcard readers.
The ACR39U one (bulk EP maxpacketsize is 64 bytes) always works. The EMV one(it is AU9560, bulk EP maxpacketsize is 16 bytes) has problems if
bulk transfer more than 64 bytes, this leads to usb hang, cannot recover without a reboot or reloading the usb driver, and both readers become unusable.
Do a bulk transfer with 64 bytes or less to the reader is fine.
Kernel we use is identical to linux-3.2.0-psp04.06.00.08, already applied musb patch 6.1 - 6.7 from http://processors.wiki.ti.com/index.php/Sitara_Linux_MUSB_Issues.
How can I fix this, I don't know much about usb protocol. If more details will be needed, let me know.
# lsusb -v
Bus 002 Device 004: ID 072f:b100
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 16
idVendor 0x072f
idProduct 0xb100
bcdDevice 2.16
iManufacturer 1 ACS
iProduct 2 ACR39U ICC Reader
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 93
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 3 CCID
bmAttributes 0x80
(Bus Powered)
MaxPower 120mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 11
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
ChipCard Interface Descriptor:
bLength 54
bDescriptorType 33
bcdCCID 1.10 (Warning: Only accurate for version 1.0)
nMaxSlotIndex 0
bVoltageSupport 7 5.0V 3.0V 1.8V
dwProtocols 3 T=0 T=1
dwDefaultClock 4800
dwMaxiumumClock 16000
bNumClockSupported 0
dwDataRate 12903 bps
dwMaxDataRate 826000 bps
bNumDataRatesSupp. 0
dwMaxIFSD 247
dwSyncProtocols 00000000
dwMechanical 00000000
dwFeatures 000100B2
Auto configuration based on ATR
Auto clock change
Auto baud rate change
Auto PPS made by CCID
TPDU level exchange
dwMaxCCIDMsgLen 271
bClassGetResponse echo
bClassEnvelope echo
wlcdLayout none
bPINSupport 0
bMaxCCIDBusySlots 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 16
Device Status: 0x0000
(Bus Powered)
Bus 002 Device 003: ID 058f:9540
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.01
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x058f
idProduct 0x9540
bcdDevice 1.20
iManufacturer 1 Generic
iProduct 2 EMV Smartcard Reader
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 93
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 50mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 11
iInterface 0
bLength 54
bDescriptorType 33
nMaxSlotIndex 0
dwDefaultClock 3700
dwMaxiumumClock 12000
bNumClockSupported 3
dwDataRate 9946 bps
dwMaxDataRate 688172 bps
bNumDataRatesSupp. 138
dwMaxIFSD 254
dwSyncProtocols 00000007 2-wire 3-wire I2C
dwFeatures 000404BE
Auto activation on insert
Auto voltage selection
Auto clock change
Auto IFSD exchange
Short and extended APDU level exchange
dwMaxCCIDMsgLen 272
bClassEnvelope echo
wlcdLayout none
bPINSupport 0
bMaxCCIDBusySlots 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 12
bNumDeviceCaps 1
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
Link Power Management (LPM) Supported
(Bus Powered)
Bus 002 Device 002: ID 0424:2514
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 2
bMaxPacketSize0 64
idVendor 0x0424
idProduct 0x2514
bcdDevice b.b3
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
bInterfaceProtocol 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceClass 9
bInterfaceProtocol 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 2
wHubCharacteristic 0x0009
Per-port power switching
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 1 milli Ampere
DeviceRemovable 0x00
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0103 power enable connect
Port 2: 0000.0103 power enable connect
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Bus 001 Device 002: ID 0451:9261
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0451
idProduct 0x9261
bcdDevice 1.00
iManufacturer 1 Texas Instruments
iProduct 2 TUSB9261 USB3.0 to SATA Bridge
iSerial 3 D0A33CD7DE75FDED10514473262694EB6
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8
bInterfaceSubClass 6
bInterfaceProtocol 80
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 5
bDescriptorType 15
wTotalLength 42
bNumDeviceCaps 3
bLength 7
bDescriptorType 16
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 2047 micro seconds
Container ID Device Capability:
bLength 20
bDescriptorType 16
bDevCapabilityType 4
bReserved 0
ContainerID {0d12c35c-1f92-e35c-ed57-dfde0d3ac37d}
(Bus Powered)
Bus 002 Device 001: ID 1d6b:0002
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 3.02
iManufacturer 3 Linux 3.2.0 musb-hcd
iProduct 2 MUSB HDRC host driver
iSerial 1 musb-hdrc.1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0011
No overcurrent protection
bPwrOn2PwrGood 5 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x02
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Self Powered
Bus 001 Device 001: ID 1d6b:0002
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 3.02
iSerial 1 musb-hdrc.0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Self Powered
# cat /proc/driver/musb_hdrc1
Status: MHDRC, Mode=Host (Power=f0, DevCtl=5d)
OTG state: a_host; active
Options: ?dma?, otg (peripheral+host), [eps=16]
Peripheral address: 00
Root port status: 00000503
CPPI: txcr=0 txsrc=0 txena=0; rxcr=0 rxsrc=280de80 rxena=0
RX10: 1buf rxcsr 3020 interval 0c max 0001 type 71; dev 2 hub 0 port 0
rx dma9: 0 left, 00000000 00000000, 00000000 00000000; 00000000 00000000 00000000 .. 00000000
qh df299a40 dev2 ep1-int max1
in urb df2efc40 0/1
RX11: 1buf rxcsr 3220 interval 10 max 0008 type b3; dev 4 hub 130 port 2
rx dma10: 0 left, 00100000 00000000, ffffffff 00000000; 20000000 16808000 3f9f4450 .. 00000003
qh df559900 dev4 ep3-int max8
in urb df568f40 0/8
RX12: 1buf rxcsr 3220 interval 20 max 0004 type b1; dev 3 hub 130 port 1
rx dma11: 0 left, 00000000 00000000, 00000000 00000000; 00000000 00000000 00000000 .. 00000000
qh df5598c0 dev3 ep1-int max4
in urb df568e40 0/8
# on problem occurs
# reader with maxpacket=16
RX2: 1buf rxcsr 2020 interval 00 max 0010 type a3; dev 3 hub 130 port 1
rx dma1: 270926084 left,00000000 00000000, 00000000 00000000; 00000000 00000000 00000000 .. 00000000
qh df4a84c0 dev3 ep3-bulk max16
in urb df4c4140 0/10
# reader with maxpacket=64
RX2: 1buf rxcsr 2020 interval 00 max 0040 type a2; dev 4 hub 130 port 2
qh df4a84c0 dev4 ep2-bulk max64
in urb df4c4140 0/16384
in urb df4c40c0 0/16384
in urb df4c42c0 0/16384
in urb df4c4540 0/16384
in urb df4c4240 0/20
#regdump after problem occurs
MUSB (M)HDRC Register Dump
FAddr : 00
Power : f0
Frame : 0608
Index : 0f
Testmode : 00
TxMaxPp : 0000
TxCSRp : 0000
RxMaxPp : 0000
RxCSR : 0000
RxCount : 0000
ConfigData : 33
DevCtl : 5d
MISC : 44
TxFIFOsz : 07
RxFIFOsz : 07
TxFIFOadd : 0780
RxFIFOadd : 0780
VControl : 00000000
HWVers : 0800
EPInfo : ff
RAMInfo : 0d
LinkInfo : 5c
VPLen : 3c
HS_EOF1 : 80
FS_EOF1 : 77
LS_EOF1 : 72
SOFT_RST : 00
DMA_CNTLch0 : 0000
DMA_ADDRch0 : 00000000
DMA_COUNTch0: 00000000
DMA_CNTLch1 : 0000
DMA_ADDRch1 : 00000000
DMA_COUNTch1: 00000000
DMA_CNTLch2 : 0000
DMA_ADDRch2 : 00000000
DMA_COUNTch2: 00000000
DMA_CNTLch3 : 0000
DMA_ADDRch3 : 00000000
DMA_COUNTch3: 00000000
DMA_CNTLch4 : 0000
DMA_ADDRch4 : 00000000
DMA_COUNTch4: 00000000
DMA_CNTLch5 : 0000
DMA_ADDRch5 : 00000000
DMA_COUNTch5: 00000000
DMA_CNTLch6 : 0000
DMA_ADDRch6 : 00000000
DMA_COUNTch6: 00000000
DMA_CNTLch7 : 0000
DMA_ADDRch7 : 00000000
DMA_COUNTch7: 00000000
