AM335x Uniflash isc-dhcp-server will not start
I am trying to setup my Linux Mint 17.2 machine so that I can boot BBB from PC over USB.
I am following the step in “processors.wiki.ti.com/.../Ubuntu_12.04_Set_Up_to_Network_Boot_an_AM335x_Based_Platform”. I have edited the /etc/dhcp/dhcpd.conf file: default-lease-time 600; max-lease-time 7200; subnet 192.168.2.0 netmask 255.255.255.0 { range dynamic-bootp 192.168.2.2 192.168.2.100; if substring (option vendor-class-identifier, 0, 10) = "AM335x ROM" { filename "u-boot-spl-restore.bin"; } elsif substring (option vendor-class-identifier, 0, 10) = "DM814x ROM" { filename "u-boot-spl-restore.bin"; } elsif substring (option vendor-class-identifier, 0, 17) = "AM335x U-Boot SPL" { filename "u-boot-restore.img"; } else { filename "zImage"; } range 192.168.2.101 192.168.2.199; } I have edited the /etc/xinetd.d/tftp file: service tftp { protocol = udp port = 69 socket_type = dgram wait = yes user = root server = /usr/sbin/in.tftpd server_args = -s /tftpboot disable = no } I have edited the /etc/default/isc-dhcp-server file: INTERFACES="eth0 eth1 usb0" I have edited the /etc/network/interfaces file: auto lo iface lo inet loopback allow-hotplug usb0 iface usb0 inet static address 192.168.2.1 network 192.168.2.0 netmask 255.255.255.0 broadcast 192.168.2.255 up /etc/network/if-up.d/usb-interfaces I have created a /etc/network/if-up.d/usb-interfaces file: #!/bin/sh if [ "$IFACE" = usb0 ]; then sudo service isc-dhcp-server restart fi I have edited the /etc/NetworkManager/NetworkManager.conf file: [main] plugins=ifupdown [ifupdown] managed=false When I try to start isc-dhcp-server this is the result: ronz@ronz-TMP453-M:/home/sitara > sudo service network-manager restart network-manager stop/waiting network-manager start/running, process 7439 ronz@ronz-TMP453-M:/home/sitara > sudo /etc/init.d/isc-dhcp-server restart * Stopping ISC DHCP server dhcpd [fail] * Starting ISC DHCP server dhcpd * check syslog for diagnostics. [fail] The syslog indicates that there is “No subnet declaration for usb0”, but a subnet (192.168.2.0) is defined in /etc/dhcp/dhcpd.conf ronz@ronz-TMP453-M:/home/sitara > tail -n 40 /var/log/syslog Nov 8 17:41:46 ronz-TMP453-M avahi-daemon[867]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.165. Nov 8 17:41:46 ronz-TMP453-M avahi-daemon[867]: New relevant interface wlan0.IPv4 for mDNS. Nov 8 17:41:46 ronz-TMP453-M avahi-daemon[867]: Registering new address record for 192.168.0.165 on wlan0.IPv4. Nov 8 17:41:47 ronz-TMP453-M NetworkManager[7439]: <info> (wlan0): device state change: ip-config -> secondaries (reason 'none') [70 90 0] Nov 8 17:41:47 ronz-TMP453-M NetworkManager[7439]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete. Nov 8 17:41:47 ronz-TMP453-M NetworkManager[7439]: <info> (wlan0): device state change: secondaries -> activated (reason 'none') [90 100 0] Nov 8 17:41:48 ronz-TMP453-M avahi-daemon[867]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::caf7:33ff:fea2:dee7. Nov 8 17:41:48 ronz-TMP453-M avahi-daemon[867]: New relevant interface wlan0.IPv6 for mDNS. Nov 8 17:41:48 ronz-TMP453-M avahi-daemon[867]: Registering new address record for fe80::caf7:33ff:fea2:dee7 on wlan0.*. Nov 8 17:41:48 ronz-TMP453-M NetworkManager[7439]: <info> NetworkManager state is now CONNECTED_GLOBAL Nov 8 17:41:48 ronz-TMP453-M NetworkManager[7439]: <info> Policy set 'MAGicALL' (wlan0) as default for IPv4 routing and DNS. Nov 8 17:41:48 ronz-TMP453-M NetworkManager[7439]: <info> Writing DNS information to /sbin/resolvconf Nov 8 17:41:49 ronz-TMP453-M ntpd[7389]: Listen normally on 6 wlan0 192.168.0.165 UDP 123 Nov 8 17:41:49 ronz-TMP453-M ntpd[7389]: Listen normally on 7 wlan0 fe80::caf7:33ff:fea2:dee7 UDP 123 Nov 8 17:41:49 ronz-TMP453-M ntpd[7389]: peers refreshed Nov 8 17:41:49 ronz-TMP453-M ntpd[7389]: new interface(s) found: waking up resolver Nov 8 17:41:49 ronz-TMP453-M dhcpd: Wrote 0 leases to leases file. Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: No subnet declaration for usb0 (no IPv4 addresses). Nov 8 17:41:49 ronz-TMP453-M dhcpd: ** Ignoring requests on usb0. If this is not what Nov 8 17:41:49 ronz-TMP453-M dhcpd: you want, please write a subnet declaration Nov 8 17:41:49 ronz-TMP453-M dhcpd: in your dhcpd.conf file for the network segment Nov 8 17:41:49 ronz-TMP453-M dhcpd: to which interface usb0 is attached. ** Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: No subnet declaration for eth1 (no IPv4 addresses). Nov 8 17:41:49 ronz-TMP453-M dhcpd: ** Ignoring requests on eth1. If this is not what Nov 8 17:41:49 ronz-TMP453-M dhcpd: you want, please write a subnet declaration Nov 8 17:41:49 ronz-TMP453-M dhcpd: in your dhcpd.conf file for the network segment Nov 8 17:41:49 ronz-TMP453-M dhcpd: to which interface eth1 is attached. ** Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: No subnet declaration for eth0 (no IPv4 addresses). Nov 8 17:41:49 ronz-TMP453-M dhcpd: ** Ignoring requests on eth0. If this is not what Nov 8 17:41:49 ronz-TMP453-M dhcpd: you want, please write a subnet declaration Nov 8 17:41:49 ronz-TMP453-M dhcpd: in your dhcpd.conf file for the network segment Nov 8 17:41:49 ronz-TMP453-M dhcpd: to which interface eth0 is attached. ** Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: Nov 8 17:41:49 ronz-TMP453-M dhcpd: Not configured to listen on any interfaces! ronz@ronz-TMP453-M:/home/sitara >
What have I missed?
    The software team have been notified. They will respond here.
  • I don't see anything that you've missed. It compares pretty closely to my Ubuntu 12.04 set up and what I've don on 14.04 as well.
    What happens if you just plug in the Black? This set up should run the restart of the DHCP server on that event. Do you get something similar?
  • Powering the BBB through the USB cable while pressing the Boot button gives this result from the /var/log/syslog file:
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.294668] usb 1-1.2: new full-speed USB device number 6 using ehci-pci
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.387222] usb 1-1.2: not running at top speed; connect to a high speed hub
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.388611] usb 1-1.2: New USB device found, idVendor=0451, idProduct=6141
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.388620] usb 1-1.2: New USB device strings: Mfr=33, Product=37, SerialNumber=0
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.388623] usb 1-1.2: Product: AM335x USB
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.388627] usb 1-1.2: Manufacturer: Texas Instruments
    Nov 28 14:15:31 ronz-TMP453-M kernel: [ 805.445086] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-0000:00:1a.0-1.2, RNDIS device, 9a:1f:85:1c:3d:0e
    Nov 28 14:15:31 ronz-TMP453-M mtp-probe: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2"
    Nov 28 14:15:31 ronz-TMP453-M mtp-probe: bus: 1, device: 6 was not an MTP device
    Nov 28 14:15:31 ronz-TMP453-M NetworkManager[3830]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/net/usb0, iface: usb0)
    Nov 28 14:15:31 ronz-TMP453-M NetworkManager[3830]: SCPluginIfupdown: locking wired connection setting
    Nov 28 14:15:31 ronz-TMP453-M NetworkManager[3830]: Ifupdown: get unmanaged devices count: 1
    Nov 28 14:15:31 ronz-TMP453-M NetworkManager[3830]: <warn> failed to allocate link cache: (-12) Object not found
    Nov 28 14:15:32 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): carrier is OFF
    Nov 28 14:15:32 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): new Ethernet device (driver: 'rndis_host' ifindex: 6)
    Nov 28 14:15:32 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): exported as /org/freedesktop/NetworkManager/Devices/2
    Nov 28 14:15:32 ronz-TMP453-M avahi-daemon[1116]: Joining mDNS multicast group on interface usb0.IPv4 with address 192.168.2.1.
    Nov 28 14:15:32 ronz-TMP453-M avahi-daemon[1116]: New relevant interface usb0.IPv4 for mDNS.
    Nov 28 14:15:32 ronz-TMP453-M avahi-daemon[1116]: Registering new address record for 192.168.2.1 on usb0.IPv4.
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: Wrote 1 leases to leases file.
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: No subnet declaration for eth1 (no IPv4 addresses).
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: ** Ignoring requests on eth1. If this is not what
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: you want, please write a subnet declaration
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: in your dhcpd.conf file for the network segment
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: to which interface eth1 is attached. **
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: No subnet declaration for eth0 (no IPv4 addresses).
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: ** Ignoring requests on eth0. If this is not what
    Nov 28 14:15:32 ronz-TMP453-M dhcpd: to which interface eth0 is attached. **
    Nov 28 14:15:33 ronz-TMP453-M avahi-daemon[1116]: Joining mDNS multicast group on interface usb0.IPv6 with address fe80::981f:85ff:fe1c:3d0e.
    Nov 28 14:15:33 ronz-TMP453-M avahi-daemon[1116]: New relevant interface usb0.IPv6 for mDNS.
    Nov 28 14:15:33 ronz-TMP453-M avahi-daemon[1116]: Registering new address record for fe80::981f:85ff:fe1c:3d0e on usb0.*.
    Nov 28 14:15:33 ronz-TMP453-M ModemManager[3823]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2': not supported by any plugin
    Nov 28 14:15:35 ronz-TMP453-M ntpd[3981]: Listen normally on 6 usb0 192.168.2.1 UDP 123
    Nov 28 14:15:35 ronz-TMP453-M ntpd[3981]: Listen normally on 7 usb0 fe80::981f:85ff:fe1c:3d0e UDP 123
    Nov 28 14:15:35 ronz-TMP453-M ntpd[3981]: peers refreshed
    Nov 28 14:15:35 ronz-TMP453-M ntpd[3981]: new interface(s) found: waking up resolver
    Nov 28 14:15:35 ronz-TMP453-M dhcpd: BOOTREQUEST from 54:4a:16:f5:62:07 via usb0
    Nov 28 14:15:35 ronz-TMP453-M dhcpd: BOOTREPLY on 192.168.2.2 to 54:4a:16:f5:62:07 via usb0
    Nov 28 14:15:35 ronz-TMP453-M in.tftpd[4057]: cannot set groups for user nobody
    Nov 28 14:15:36 ronz-TMP453-M in.tftpd[4058]: cannot set groups for user nobody
    Nov 28 14:15:37 ronz-TMP453-M in.tftpd[4059]: cannot set groups for user nobody
    Nov 28 14:15:38 ronz-TMP453-M in.tftpd[4060]: cannot set groups for user nobody
    Nov 28 14:15:39 ronz-TMP453-M in.tftpd[4061]: cannot set groups for user nobody
    Nov 28 14:15:40 ronz-TMP453-M in.tftpd[4062]: cannot set groups for user nobody
    Nov 28 14:15:42 ronz-TMP453-M ntpd[3981]: ntpd exiting on signal 15
    Nov 28 14:15:42 ronz-TMP453-M kernel: [ 815.635366] init: isc-dhcp-server main process (4019) killed by TERM signal
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: Wrote 1 leases to leases file.
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: No subnet declaration for eth1 (no IPv4 addresses).
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: ** Ignoring requests on eth1. If this is not what
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: you want, please write a subnet declaration
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: in your dhcpd.conf file for the network segment
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: to which interface eth1 is attached. **
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: No subnet declaration for eth0 (no IPv4 addresses).
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: ** Ignoring requests on eth0. If this is not what
    Nov 28 14:15:42 ronz-TMP453-M dhcpd: to which interface eth0 is attached. **
    Nov 28 14:16:01 ronz-TMP453-M wpa_supplicant[1349]: wlan0: CTRL-EVENT-SCAN-STARTED
    Nov 28 14:16:04 ronz-TMP453-M kernel: [ 838.334531] rndis_host 1-1.2:1.0 usb0: kevent 1 may have been dropped
    Nov 28 14:16:04 ronz-TMP453-M dhcpd: receive_packet failed on usb0: Network is down
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Interface usb0.IPv6 no longer relevant for mDNS.
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Leaving mDNS multicast group on interface usb0.IPv6 with address fe80::981f:85ff:fe1c:3d0e.
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Interface usb0.IPv4 no longer relevant for mDNS.
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Leaving mDNS multicast group on interface usb0.IPv4 with address 192.168.2.1.
    Nov 28 14:16:04 ronz-TMP453-M kernel: [ 838.442642] usb 1-1.2: USB disconnect, device number 6
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: IP_DROP_MEMBERSHIP failed: No such device
    Nov 28 14:16:04 ronz-TMP453-M kernel: [ 838.444768] rndis_host 1-1.2:1.0 usb0: unregister 'rndis_host' usb-0000:00:1a.0-1.2, RNDIS device
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Withdrawing address record for fe80::981f:85ff:fe1c:3d0e on usb0.
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Withdrawing address record for 192.168.2.1 on usb0.
    Nov 28 14:16:04 ronz-TMP453-M avahi-daemon[1116]: Withdrawing workstation service for usb0.
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: SCPlugin-Ifupdown: devices removed (path: /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/net/usb0, iface: usb0)
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: Ifupdown: get unmanaged devices count: 0
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <warn> (6) failed to find interface name for index
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: (nm-system.c:766):nm_system_iface_get_flags: runtime check failed: (iface != NULL)
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <error> [1480371364.972262] [nm-system.c:768] nm_system_iface_get_flags(): (unknown): failed to get interface link object
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): bringing up device.
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): deactivating device (reason 'managed') [2]
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <warn> sysctl: failed to open '/proc/sys/net/ipv6/conf/usb0/accept_ra': (2) No such file or directory
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <warn> sysctl: failed to open '/proc/sys/net/ipv6/conf/usb0/use_tempaddr': (2) No such file or directory
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: nm_system_iface_flush_routes: assertion 'iface != NULL' failed
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): device state change: unavailable -> unmanaged (reason 'removed') [20 10 36]
    Nov 28 14:16:04 ronz-TMP453-M NetworkManager[3830]: <error> [1480371364.991874] [nm-system.c:768] nm_system_iface_get_flags(): (unknown): failed to get interface link object
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.628099] usb 1-1.2: new full-speed USB device number 7 using ehci-pci
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.720541] usb 1-1.2: not running at top speed; connect to a high speed hub
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.721920] usb 1-1.2: New USB device found, idVendor=0451, idProduct=6141
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.721926] usb 1-1.2: New USB device strings: Mfr=33, Product=37, SerialNumber=0
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.721929] usb 1-1.2: Product: AM335x USB
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.721932] usb 1-1.2: Manufacturer: Texas Instruments
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.776309] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-0000:00:1a.0-1.2, RNDIS device, 9a:1f:85:1c:3d:0e
    Nov 28 14:16:08 ronz-TMP453-M mtp-probe: checking bus 1, device 7: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2"
    Nov 28 14:16:08 ronz-TMP453-M mtp-probe: bus: 1, device: 7 was not an MTP device
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <warn> failed to allocate link cache: (-12) Object not found
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): carrier is OFF
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): new Ethernet device (driver: 'rndis_host' ifindex: 7)
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): exported as /org/freedesktop/NetworkManager/Devices/3
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): bringing up device.
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): carrier now ON (device state 20)
    Nov 28 14:16:08 ronz-TMP453-M avahi-daemon[1116]: Joining mDNS multicast group on interface usb0.IPv4 with address 192.168.2.1.
    Nov 28 14:16:08 ronz-TMP453-M avahi-daemon[1116]: New relevant interface usb0.IPv4 for mDNS.
    Nov 28 14:16:08 ronz-TMP453-M avahi-daemon[1116]: Registering new address record for 192.168.2.1 on usb0.IPv4.
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): preparing device.
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): deactivating device (reason 'managed') [2]
    Nov 28 14:16:08 ronz-TMP453-M avahi-daemon[1116]: Withdrawing address record for 192.168.2.1 on usb0.
    Nov 28 14:16:08 ronz-TMP453-M avahi-daemon[1116]: Leaving mDNS multicast group on interface usb0.IPv4 with address 192.168.2.1.
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> Added default wired connection 'Wired connection 2' for /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/net/usb0
    Nov 28 14:16:08 ronz-TMP453-M avahi-daemon[1116]: Interface usb0.IPv4 no longer relevant for mDNS.
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/net/usb0, iface: usb0)
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: SCPluginIfupdown: locking wired connection setting
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: Ifupdown: get unmanaged devices count: 1
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): device state change: unavailable -> unmanaged (reason 'unmanaged') [20 10 3]
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): cleaning up...
    Nov 28 14:16:08 ronz-TMP453-M NetworkManager[3830]: <info> (usb0): taking down device.
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.875369] init: isc-dhcp-server main process (4126) killed by TERM signal
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: Wrote 1 leases to leases file.
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: No subnet declaration for usb0 (no IPv4 addresses).
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: ** Ignoring requests on usb0. If this is not what
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: you want, please write a subnet declaration
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: in your dhcpd.conf file for the network segment
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: to which interface usb0 is attached. **
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: No subnet declaration for eth1 (no IPv4 addresses).
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: ** Ignoring requests on eth1. If this is not what
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: to which interface eth1 is attached. **
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: No subnet declaration for eth0 (no IPv4 addresses).
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: ** Ignoring requests on eth0. If this is not what
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: to which interface eth0 is attached. **
    Nov 28 14:16:08 ronz-TMP453-M dhcpd: Not configured to listen on any interfaces!
    Nov 28 14:16:08 ronz-TMP453-M kernel: [ 841.974969] init: isc-dhcp-server main process (4206) terminated with status 1
    I looks like it makes the connection and then drops the connection.
