u-boot build fail - DTC upgrade
Dear Champs,
I tried to build PSDKv3.01 of AM335x and failed to build u-boot.
I found the message to upgrade dtc 1.4 in the log, but I don't know how I can upgrade dtc.
Could you please let me know how dtc can be upgraded?
OBJCOPY u-boot-nodtb.bin
../scripts/dtc-version.sh: line 17: dtc: command not found
./scripts/dtc-version.sh: line 18: dtc: command not found
******** Your dtc is too old, please upgrade to dtc 1.4 or newer
make[2]: *** [checkdtc] Error 1
make[1]: *** [__build_one_by_one] Error 2
Thanks and Best Regards,
SI.
  • Hi SI,
    Seems you have some issue with device tree compiler. I suggest you to check the version of your dtc using the command:
    dpkg -s device-tree-compiler | grep Version
    On my host PC the version is:
    Version: 1.3.0-2ubuntu1
    but I successfully build u-boot.
    You can try to install dtc:
    sudo apt-get install device-tree-compiler
    Also check the toolchain. The recommended version is: gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02)
    BR
    Tsvetolin Shulev
  • SI,
    For installing Device Tree Compiler version 1.4.1 you can get it from source:
    git clone git://git.kernel.org/pub/scm/utils/dtc/dtc.git -b v1.4.1
    cd dtc/
    make
    export PATH=$HOME/dtc/:$PATH
    BR
    Tsvetolin Shulev
