Hi Sir
SDK 2.00.02 with Kernel 4.1
1. We set USB DMA enabled and have below situation
USB0 is connected with Cellular Module
USB1 is connected with USB Hub and Hub is connected with TypeA and USB to UART Chip。
2. We did below test flow and got error message as below
a. open UART device node from USB port
b. write data
c. read data
d.close UART device node
And we got error message from console as below
[ 121.813394] musb_host_rx 1654: RX5 dma busy, csr 2220
[ 129.819145] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 168.831798] musb_host_rx 1654: RX2 dma busy, csr 2220
[ 169.618754] musb_host_rx 1654: RX5 dma busy, csr 2220
Does TI have any suggestion ? or USB DMA mode of AM3352 has any limitation or bug ?
BTW, attachment is the test code and complete log message
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <fcntl.h>
#include <errno.h>
#include <termios.h>
#include <time.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <sys/ioctl.h>
#include <sys/select.h>
#include <linux/if.h>
#define TEST_OK 0
#define TEST_FAIL 1
#define TEST_LEN 256
#define RS232_WAIT_TIME 5 // unit seconds
#define MAXPORTNUM 64
#define TESTPORT 4
#define dbg_printf(x...) printf(x)
// must test item
static char sbuf[TEST_LEN], wbuf[TEST_LEN], rbuf[MAXPORTNUM][TEST_LEN];
int main ()
int count;
for (count = 1; count <=10000000; count++) {
dbg_printf("This is the %d time test\n", count);
test();
return 0;
int test(void)
int fd[MAXPORTNUM];
int i, j, k, ret=TEST_OK;
int rcnt[MAXPORTNUM];
char name[16];
struct termios termio;
unsigned long stime;
// initialize the file handle
for ( i=0; i<MAXPORTNUM; i++ ) {
fd[i] = -1;
rcnt[i] = 0;
// open serial port
for ( i=0; i<TESTPORT; i++ ) {
sprintf(name, "/dev/ttyMI%d", i);
fd[i] = open(name, O_RDWR|O_NOCTTY);
if ( fd[i] <= 0 ) {
dbg_printf("Open serial port /dev/ttyMI%d fail !\n", i);
ret = TEST_FAIL;
continue;
memset(rbuf[0], -1, TEST_LEN * MAXPORTNUM);
for ( i=0; i<TEST_LEN; i++ )
wbuf[i] = i;
// initialize the serial
termio.c_iflag = 0;
termio.c_oflag = 0;
termio.c_lflag = 0;
termio.c_cflag = B115200 | CRTSCTS | CS8 | CREAD | CLOCAL;
termio.c_cc[VMIN] = 0;
termio.c_cc[VTIME] = 0;
tcflush(fd[i], TCIOFLUSH);
tcsetattr(fd[i], TCSANOW, &termio);
usleep(100*1000);
write(fd[i], wbuf, TEST_LEN);
stime = time(NULL);
usleep(90 * 1000);
while ( (unsigned long)(time(NULL)-stime) < RS232_WAIT_TIME ) {
if ( rcnt[i] < TEST_LEN )
break;
if ( i == TESTPORT )
break;
if ( (j=rcnt[i]) >= TEST_LEN )
continue;
if ( (k=read(fd[i], &rbuf[i][j], TEST_LEN-j)) <= 0 )
continue;
rcnt[i] += k;
if ( rcnt[i] < TEST_LEN ) {
dbg_printf("Serial port %d read length error !\n", i);
ret = TEST_FAIL;
continue;
for ( j=0; j<TEST_LEN; j++ ) {
if ( wbuf[j] != rbuf[i][j] ) {
dbg_printf("Serial port %d read data error !\n", i);
dbg_printf("wbuf[%d]=%x,rbuf[%d][%d]=%x\n", j, wbuf[j], i, j, rbuf[i][j]);
ret = TEST_FAIL;
exit (1);
if ( fd[i] > 0 ) {
close(fd[i]);
if( ret == TEST_OK )
dbg_printf("serial test OK!\n");
else
exit;
return ret;
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.0-ltsi-rt-mxcore01+ (root@weshuang) (gcc version 4.9.2 ( 4.9.2-10) ) #1 SMP Wed Oct 5 14:10:48 CST 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: MOXA MXcore01
[ 0.000000] cma: Reserved 16 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c0725840, node_mem_map dfa71000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130816 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon )
[ 0.000000] PERCPU: Embedded 12 pages/cpu @dfa3c000 s17984 r8192 d22976 u49152
[ 0.000000] pcpu-alloc: s17984 r8192 d22976 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129664
[ 0.000000] Kernel command line: mac=11:22:33:44:55:66 sd=2 ver=3 console=ttyS0,115200n8 root=/dev/mmcblk1p2 rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 493984K/523264K available (5155K kernel code, 217K rwdata, 1592K rodata, 324K init, 271K bss, 12896K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc069efa4 (6748 kB)
.init : 0xc069f000 - 0xc06f0000 ( 324 kB)
.data : 0xc06f0000 - 0xc0726780 ( 218 kB)
.bss : 0xc0729000 - 0xc076cc80 ( 272 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 25000000 Hz
[ 0.000016] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[ 0.000041] clocksource timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000054] OMAP clocksource: timer1 at 25000000 Hz
[ 0.000390] Console: colour dummy device 80x30
[ 0.000431] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089090] pid_max: default: 32768 minimum: 301
[ 0.089235] Security Framework initialized
[ 0.089270] SELinux: Initializing.
[ 0.089305] SELinux: Starting in permissive mode
[ 0.089376] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089389] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090331] Initializing cgroup subsys blkio
[ 0.090360] Initializing cgroup subsys memory
[ 0.090415] Initializing cgroup subsys devices
[ 0.090435] Initializing cgroup subsys freezer
[ 0.090459] Initializing cgroup subsys net_cls
[ 0.090476] Initializing cgroup subsys perf_event
[ 0.090492] Initializing cgroup subsys net_prio
[ 0.090525] CPU: Testing write buffer coherency: ok
[ 0.091002] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.091110] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.092818] Brought up 1 CPUs
[ 0.092841] SMP: Total of 1 processors activated (795.44 BogoMIPS).
[ 0.092850] CPU: All CPU(s) started in SVC mode.
[ 0.093729] devtmpfs: initialized
[ 0.105888] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.120391] omap_hwmod: tptc0 using broken dt data from edma
[ 0.120556] omap_hwmod: tptc1 using broken dt data from edma
[ 0.120698] omap_hwmod: tptc2 using broken dt data from edma
[ 0.125811] omap_hwmod: debugss: _wait_target_disable failed
[ 0.167927] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.170127] pinctrl core: initialized pinctrl subsystem
[ 0.171547] NET: Registered protocol family 16
[ 0.174389] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.175244] cpuidle: using governor ladder
[ 0.175261] cpuidle: using governor menu
[ 0.178534] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.178997] OMAP GPIO hardware version 0.1
[ 0.179768] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.180748] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.181705] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.188769] No ATAGs?
[ 0.188806] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.206090] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.206610] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator@0[0]'
[ 0.207003] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator@1[0]'
[ 0.209280] SCSI subsystem initialized
[ 0.209700] libata version 3.00 loaded.
[ 0.210117] usbcore: registered new interface driver usbfs
[ 0.210204] usbcore: registered new interface driver hub
[ 0.210287] usbcore: registered new device driver usb
[ 0.210781] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.210837] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.212174] NetLabel: Initializing
[ 0.212193] NetLabel: domain hash size = 128
[ 0.212199] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.212272] NetLabel: unlabeled traffic allowed by default
[ 0.212627] Switched to clocksource timer1
[ 0.226653] NET: Registered protocol family 2
[ 0.227650] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.227715] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.227790] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.227895] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.227921] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.228194] NET: Registered protocol family 1
[ 0.229201] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[ 0.229266] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.231333] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.231440] audit: initializing netlink subsys (disabled)
[ 0.231545] audit: type=2000 audit(0.210:1): initialized
[ 0.233699] VFS: Disk quotas dquot_6.6.0
[ 0.233809] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.234356] SELinux: Registering netfilter hooks
[ 0.236994] io scheduler noop registered
[ 0.237018] io scheduler deadline registered (default)
[ 0.237115] io scheduler cfq registered
[ 0.238220] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.239239] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.241295] console [ttyS0] disabled
[ 0.241366] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 154, base_baud = 3000000) is a 8250
[ 0.861257] console [ttyS0] enabled
[ 0.866356] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 0.886857] brd: module loaded
[ 0.896730] loop: module loaded
[ 0.902766] m25p80 spi1.0: mx25l6405d (8192 Kbytes)
[ 0.908520] 3 ofpart partitions found on MTD device spi1.0
[ 0.914127] Creating 3 MTD partitions on "spi1.0":
[ 0.918959] 0x000000000000-0x000000080000 : "MLO"
[ 0.925229] 0x000000080000-0x000000180000 : "U-Boot"
[ 0.931342] 0x000000180000-0x0000001a0000 : "U-Boot Env"
[ 0.938973] PPP generic driver version 2.4.2
[ 0.943839] PPP BSD Compression module registered
[ 0.948579] PPP Deflate Compression module registered
[ 0.953743] PPP MPPE Compression module registered
[ 0.958571] NET: Registered protocol family 24
[ 0.963639] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.970207] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.975629] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.991181] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer reset
[ 0.991209] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup
[ 0.991228] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]'
[ 0.991240] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]'
[ 0.991251] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup
[ 0.991265] am335x-phy-driver 47401300.usb-phy: lookup for GPIO reset failed
[ 0.991278] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer vbus-detect
[ 0.991289] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup
[ 0.991302] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]'
[ 0.991314] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]'
[ 0.991325] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup
[ 0.991337] am335x-phy-driver 47401300.usb-phy: lookup for GPIO vbus-detect failed
[ 0.991405] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 1.005403] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.005424] musb-hdrc: MHDRC RTL version 2.0
[ 1.005435] musb-hdrc: setup fifo_mode 4
[ 1.005458] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.005633] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 1.011440] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 1.019773] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.026641] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.033917] usb usb1: Product: MUSB HDRC host driver
[ 1.038906] usb usb1: Manufacturer: Linux 4.1.0-ltsi-rt-mxcore01+ musb-hcd
[ 1.045851] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 1.051979] hub 1-0:1.0: USB hub found
[ 1.055943] hub 1-0:1.0: 1 port detected
[ 1.061159] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer reset
[ 1.061181] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup
[ 1.061201] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]'
[ 1.061214] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]'
[ 1.061225] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup
[ 1.061239] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO reset failed
[ 1.061251] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer vbus-detect
[ 1.061262] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup
[ 1.061274] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]'
[ 1.061285] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]'
[ 1.061296] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup
[ 1.061308] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO vbus-detect failed
[ 1.061367] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 1.075233] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.075253] musb-hdrc: MHDRC RTL version 2.0
[ 1.075263] musb-hdrc: setup fifo_mode 4
[ 1.075282] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.075440] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.081248] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 1.089546] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.096426] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.103706] usb usb2: Product: MUSB HDRC host driver
[ 1.108694] usb usb2: Manufacturer: Linux 4.1.0-ltsi-rt-mxcore01+ musb-hcd
[ 1.115629] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 1.121622] hub 2-0:1.0: USB hub found
[ 1.125563] hub 2-0:1.0: 1 port detected
[ 1.130502] i2c /dev entries driver
[ 1.134983] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
[ 1.135000] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[ 1.135019] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@48060000[0]'
[ 1.135031] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@48060000[0]'
[ 1.135043] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[ 1.135056] omap_hsmmc 48060000.mmc: lookup for GPIO cd failed
[ 1.135070] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
[ 1.135080] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[ 1.135092] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]'
[ 1.135103] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]'
[ 1.135113] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[ 1.135124] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed
[ 1.172920] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd
[ 1.172944] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
[ 1.172977] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' - status (0)
[ 1.173052] omap_hsmmc 481d8000.mmc: Got CD GPIO
[ 1.177706] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp
[ 1.177718] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
[ 1.177731] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]'
[ 1.177743] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]'
[ 1.177754] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
[ 1.177766] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed
[ 1.213409] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.219837] oprofile: using arm/armv7
[ 1.224024] Initializing XFRM netlink socket
[ 1.228505] NET: Registered protocol family 10
[ 1.234923] NET: Registered protocol family 17
[ 1.239440] NET: Registered protocol family 15
[ 1.244054] Key type dns_resolver registered
[ 1.248987] ThumbEE CPU extension supported.
[ 1.253370] Registering SWP/SWPB emulation handler
[ 1.266173] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.276381] mmc0: new high speed SDHC card at address 97a2
[ 1.282752] mmcblk0: mmc0:97a2 SE08G 7.28 GiB
[ 1.289283] mmcblk0: p1
[ 1.322661] rtc-ds1374 0-0068: rtc core: registered ds1374 as rtc0
[ 1.328926] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.348876] mmc1: MAN_BKOPS_EN bit is not set
[ 1.353936] gpiochip_find_base: found new base at 496
[ 1.354114] gpiochip_add: registered GPIOs 496 to 511 on device: pca9535
[ 1.354887] gpiochip_find_base: found new base at 480
[ 1.355076] gpiochip_add: registered GPIOs 480 to 495 on device: pca9535
[ 1.355847] gpiochip_find_base: found new base at 464
[ 1.355995] gpiochip_add: registered GPIOs 464 to 479 on device: pca9535
[ 1.356814] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[ 1.377627] mmc1: new high speed MMC card at address 0001
[ 1.383838] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
[ 1.388616] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
[ 1.394923] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
[ 1.402473] mmcblk1: p1 p2 p3
[ 1.422625] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.428765] davinci_mdio 4a101000.mdio: detected phy mask 7ffffffd
[ 1.436320] libphy: 4a101000.mdio: probed
[ 1.440368] davinci_mdio 4a101000.mdio: phy[31]: device 4a101000.mdio:1f, driver Marvell 88E1118
[ 1.449887] cpsw 4a100000.ethernet: Missing slave[0] phy_id property
[ 1.456507] cpsw 4a100000.ethernet: Detected MACID = 00:90:e8:00:00:45
[ 1.465470] rtc-ds1374 0-0068: setting system clock to 2016-11-15 03:23:52 UTC (1479180232)
[ 1.480991] vbat: disabling
[ 1.487031] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[ 1.494501] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[ 1.533207] usb 2-1: new high-speed USB device number 2 using musb-hdrc
[ 1.570288] EXT4-fs (mmcblk1p2): recovery complete
[ 1.576117] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.584406] VFS: Mounted root (ext4 filesystem) readonly on device 179:10.
[ 1.596788] devtmpfs: mounted
[ 1.600272] Freeing unused kernel memory: 324K (c069f000 - c06f0000)
[ 1.674210] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610
[ 1.680968] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.688220] usb 2-1: Product: USB2.0 Hub
[ 1.693700] hub 2-1:1.0: USB hub found
[ 1.697895] hub 2-1:1.0: 2 ports detected
[ 1.827193] random: systemd urandom read with 18 bits of entropy available
[ 1.839265] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 1.853397] systemd[1]: Detected architecture 'arm'.
[ 1.929791] systemd[1]: Inserted module 'autofs4'
[ 1.936719] systemd[1]: Set hostname to <Moxa>.
[ 1.982835] usb 2-1.1: new high-speed USB device number 3 using musb-hdrc
[ 2.146978] usb 2-1.1: New USB device found, idVendor=0403, idProduct=6011
[ 2.154010] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.161355] usb 2-1.1: Product: USB <-> Serial Converter
[ 2.166718] usb 2-1.1: Manufacturer: FTDI
[ 2.272772] usb 2-1.2: new high-speed USB device number 4 using musb-hdrc
[ 2.363719] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 2.380903] usb 2-1.2: New USB device found, idVendor=054c, idProduct=05ba
[ 2.387923] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.395290] usb 2-1.2: Product: Storage Media
[ 2.399669] usb 2-1.2: Manufacturer: Sony
[ 2.403717] usb 2-1.2: SerialNumber: CB4001202110003834
[ 2.411321] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.419842] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.427749] systemd[1]: Expecting device dev-ttyS0.device...
[ 2.452872] systemd[1]: Starting Remote File Systems (Pre).
[ 2.472788] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.479074] systemd[1]: Starting Encrypted Volumes.
[ 2.502760] systemd[1]: Reached target Encrypted Volumes.
[ 2.508458] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 2.542772] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.552441] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 2.560993] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.569167] systemd[1]: Starting Paths.
[ 2.592739] systemd[1]: Reached target Paths.
[ 2.597216] systemd[1]: Starting Swap.
[ 2.612741] systemd[1]: Reached target Swap.
[ 2.617139] systemd[1]: Starting Root Slice.
[ 2.632758] systemd[1]: Created slice Root Slice.
[ 2.637594] systemd[1]: Starting User and Session Slice.
[ 2.662764] systemd[1]: Created slice User and Session Slice.
[ 2.668655] systemd[1]: Starting Delayed Shutdown Socket.
[ 2.692773] systemd[1]: Listening on Delayed Shutdown Socket.
[ 2.698657] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 2.722762] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.729871] systemd[1]: Starting Journal Socket (/dev/log).
[ 2.752767] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.758878] systemd[1]: Starting udev Kernel Socket.
[ 2.782758] systemd[1]: Listening on udev Kernel Socket.
[ 2.788245] systemd[1]: Starting udev Control Socket.
[ 2.812764] systemd[1]: Listening on udev Control Socket.
[ 2.818340] systemd[1]: Starting Journal Socket.
[ 2.842767] systemd[1]: Listening on Journal Socket.
[ 2.847979] systemd[1]: Starting System Slice.
[ 2.872788] systemd[1]: Created slice System Slice.
[ 2.877936] systemd[1]: Starting File System Check on Root Device...
[ 2.906416] systemd[1]: Starting system-getty.slice.
[ 2.933171] systemd[1]: Created slice system-getty.slice.
[ 2.938772] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 2.947785] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.963241] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.979565] systemd[1]: Mounting Debug File System...
[ 3.017347] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.049741] systemd[1]: Starting Load Kernel Modules...
[ 3.077243] systemd[1]: Mounted Huge Pages File System.
[ 3.100428] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.125861] systemd[1]: Starting udev Coldplug all Devices...
[ 3.151038] fuse init (API version 7.23)
[ 3.166268] systemd[1]: Starting Journal Service...
[ 3.253115] systemd[1]: Started Journal Service.
[ 3.891193] EXT4-fs (mmcblk1p2): re-mounted. Opts: errors=remount-ro
[ 4.131643] systemd-udevd[102]: starting version 215
[ 4.515262] systemd-journald[84]: Received request to flush runtime journal from PID 1
[ 4.767237] lm75 0-0048: hwmon0: sensor 'lm75'
[ 4.816619] lm75 2-0048: hwmon1: sensor 'lm75'
[ 4.873440] lm75 2-0049: hwmon2: sensor 'lm75'
[ 4.908687] ds1374_wdt: Watchdog timer initial timeout 60 sec
[ 4.914633] ds1374_wdt: Common mode
[ 5.444498] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[ 5.470781] usbcore: registered new interface driver usbserial
[ 5.476947] usbcore: registered new interface driver usbserial_generic
[ 5.483658] usbserial: USB Serial support registered for generic
[ 5.507410] usbcore: registered new interface driver ftdi_sio
[ 5.513473] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.521120] ftdi_sio 2-1.1:1.0: FTDI USB Serial Device converter detected
[ 5.528270] usb 2-1.1: Detected FT4232H
[ 5.624698] scsi host0: usb-storage 2-1.2:1.0
[ 5.629830] usbcore: registered new interface driver usb-storage
[ 5.678186] CAN device driver interface
[ 5.730895] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=160)
[ 5.775479] usb 2-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
[ 5.783128] ftdi_sio 2-1.1:1.1: FTDI USB Serial Device converter detected
[ 5.790154] usb 2-1.1: Detected FT4232H
[ 5.999089] usb 2-1.1: FTDI USB Serial Device converter now attached to ttyUSB1
[ 6.006779] ftdi_sio 2-1.1:1.2: FTDI USB Serial Device converter detected
[ 6.013891] usb 2-1.1: Detected FT4232H
[ 6.163021] usb 2-1.1: FTDI USB Serial Device converter now attached to ttyUSB2
[ 6.170609] ftdi_sio 2-1.1:1.3: FTDI USB Serial Device converter detected
[ 6.177745] usb 2-1.1: Detected FT4232H
[ 6.361676] usb 2-1.1: FTDI USB Serial Device converter now attached to ttyUSB3
[ 6.573188] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 6.579004] omap-sham 53100000.sham: initialization failed.
[ 6.584766] omap-sham: probe of 53100000.sham failed with error -22
[ 6.592955] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 6.623959] scsi 0:0:0:0: Direct-Access Sony Storage Media 0100 PQ: 0 ANSI: 4
[ 6.680467] sd 0:0:0:0: [sda] 31297536 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 6.729588] sd 0:0:0:0: [sda] Write Protect is off
[ 6.734584] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 6.780057] sd 0:0:0:0: [sda] No Caching mode page found
[ 6.785599] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 6.903732] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.005941] sda: sda1
[ 7.044250] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 7.300824] random: nonblocking pool is initialized
[ 7.814049] EXT4-fs (sda): no journal found
[ 8.157925] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.515553] net eth0: initializing cpsw version 1.12 (0)
[ 8.522764] libphy: PHY not found
[ 8.526190] net eth0: phy not found on slave 0
[ 8.603582] net eth0: phy found : id is : 0x1410e11
[ 8.614342] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.868053] EXT4-fs (mmcblk1p2): resizing filesystem from 93696 to 1818368 blocks
[ 10.009888] EXT4-fs (mmcblk1p2): resized filesystem to 1818368
[ 12.603975] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.612050] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 303.422169] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 342.235840] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 344.192769] musb_host_rx 1654: RX3 dma busy, csr 2220
[ 494.336656] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 595.943147] musb_host_rx 1654: RX5 dma busy, csr 2020
[ 1068.457980] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1081.727536] musb_host_rx 1654: RX4 dma busy, csr 2220
[ 1091.487219] musb_host_rx 1654: RX2 dma busy, csr 2220
[ 1110.217581] musb_host_rx 1654: RX2 dma busy, csr 2220
[ 1139.086573] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 1168.152576] musb_host_rx 1654: RX2 dma busy, csr 2220
[ 1175.767310] musb_host_rx 1654: RX5 dma busy, csr 2220
[ 1241.684058] musb_host_rx 1654: RX5 dma busy, csr 2020
[ 1371.767614] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1375.674482] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1456.028766] musb_host_rx 1654: RX2 dma busy, csr 2220
[ 1458.376669] musb_host_rx 1654: RX3 dma busy, csr 2220
[ 1469.888258] musb_host_rx 1654: RX4 dma busy, csr 2220
[ 1489.592589] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1505.012086] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1510.870891] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 1540.322850] musb_host_rx 1654: RX5 dma busy, csr 2220
[ 1555.342374] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 1599.621848] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1621.076118] musb_host_rx 1654: RX3 dma busy, csr 2020
[ 1652.867042] musb_host_rx 1654: RX2 dma busy, csr 2020
[ 1667.697529] musb_host_rx 1654: RX2 dma busy, csr 2220
BR
Yimin
