Two channel input resize issue in VPE on TDA2x
Requirement:
  • Two channel input to VPE :1280x800, YUV422Interlaced
  • Two channel output from VPE : 640x400, YUV422Interlaced
Use case:
NullSource (A15) -> VPE -> Select_alg
Select_alg -> Alg_FrameCopy_1 (DSP1) -> Merge_alg
Select_alg -> Alg_FrameCopy_2 (A15) -> Merge_alg
Merge_alg -> Sync_alg -> Alg_Decision -> Dup_Output -> Display_Video
Dup_Output -> Null (A15)
GrpxSrc -> Display_Grpx
Observations:
  1. Channel 1 and Channel 2 input images are proper (1280x800, YUV422I). Verified by dumping the images.
  2. First channel VPE output is perfect (640x400, YUV422I)
  3. Second channel VPE output is wrong. Observed 640x200 Image
  4. Same issues were observed even after choosing two separate instances of VPE as below
NullSource (A15) -> Select_alg
Select_alg -> VPE_1 ->  Alg_FrameCopy_1 (DSP1) -> Merge_alg
Select_alg -> VPE_2 -> Alg_FrameCopy_2 (A15) -> Merge_alg
Note:
Pls find attached VPE output for channel 1 and channel 2 with this thread.
Support needed:https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/VPEOut.7z
Could you please suggest possible solution to get proper output on channel 2 (640x400, YUV422I)
  • As suggested earlier we tested above use case for YUV420 SP also. We got same issue as stated in previous post. Our requirement is for YUV422Interlaced.
  • Hi, Socrates,
    I have pinged expert to comment here.
    Mariya
  • Hi Socrates,
    Can you please provide us the VPE link create paramters that is being done in your usecase?
    Sujith
  • Hi Sujith,
    Below is the VPE create time parameters for
    1) single VPE instance and two channel input
    pPrm->enableOut[0] = TRUE;
    pPrm->chParams[0].outParams[0].width = SystemUtils_floor(outWidth,4);
    pPrm->chParams[0].outParams[0].height = SystemUtils_floor(outHeight, 2);
    pPrm->chParams[0].outParams[0].numBufsPerCh = 5;
    pPrm->chParams[0].scCropCfg.cropStartX = 0;
    pPrm->chParams[0].scCropCfg.cropStartY = 0;
    pPrm->chParams[0].scCropCfg.cropWidth = srcWidth;
    pPrm->chParams[0].scCropCfg.cropHeight = srcHeight;
    pPrm->chParams[0].outParams[0].dataFormat = dataFormat;
    pPrm->chParams[1].outParams[0].width = SystemUtils_floor(outWidth,4);
    pPrm->chParams[1].outParams[0].height = SystemUtils_floor(outHeight, 2);
    pPrm->chParams[1].outParams[0].numBufsPerCh = 5;
    pPrm->chParams[1].scCropCfg.cropStartX = 0;
    pPrm->chParams[1].scCropCfg.cropStartY = 0;
    pPrm->chParams[1].scCropCfg.cropWidth = srcWidth;
    pPrm->chParams[1].scCropCfg.cropHeight = srcHeight;
    pPrm->chParams[1].outParams[0].dataFormat = dataFormat;
    2) Two separate instances of VPE
    pPrm1->enableOut[0] = TRUE;
    pPrm1->chParams[0].outParams[0].width = SystemUtils_floor(outWidth,4);
    pPrm1->chParams[0].outParams[0].height = SystemUtils_floor(outHeight, 2);
    pPrm1->chParams[0].outParams[0].numBufsPerCh = 5;
    pPrm1->chParams[0].scCropCfg.cropStartX = 0;
    pPrm1->chParams[0].scCropCfg.cropStartY = 0;
    pPrm1->chParams[0].scCropCfg.cropWidth = srcWidth;
    pPrm1->chParams[0].scCropCfg.cropHeight = srcHeight;
    pPrm1->chParams[0].outParams[0].dataFormat = dataFormat;
    pPrm1->chParams[0].scCfg.bypass = FALSE;
    pPrm1->chParams[0].scCfg.nonLinear = FALSE;
    pPrm1->chParams[0].scCfg.stripSize = 0;
    pPrm2->enableOut[0] = TRUE;
    pPrm2->chParams[0].outParams[0].width = SystemUtils_floor(outWidth,4);
    pPrm2->chParams[0].outParams[0].height = SystemUtils_floor(outHeight, 2);
    pPrm2->chParams[0].outParams[0].numBufsPerCh = 5;
    pPrm2->chParams[0].scCropCfg.cropStartX = 0;
    pPrm2->chParams[0].scCropCfg.cropStartY = 0;
    pPrm2->chParams[0].scCropCfg.cropWidth = srcWidth;
    pPrm2->chParams[0].scCropCfg.cropHeight = srcHeight;
    pPrm2->chParams[0].outParams[0].dataFormat = dataFormat;
    (outWidth=640,outHeight=400,srcWidth=1280,srcHeight=800,dataFormat=SYSTEM_DF_YUV422I_YUYV)
    Socrates
  • Hi Sujith,
    Please find attached usecase file for your reference.
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
     * ALL RIGHTS RESERVED
     *  INCLUDE FILES
    #include "chains_network_integrated_priv.h"
    #include <examples/tda2xx/include/chains_common.h>
    #define KPIT_MODIFICATIONS
    #define CAPTURE_SENSOR_WIDTH      (1280)
    #define CAPTURE_SENSOR_HEIGHT     (800)
    #define ALGORITHM_WIDTH  (640)
    #define ALGORITHM_HEIGHT  (400)
     *  \brief  Use-case object
     *        This structure contains all the LinksId's and create Params.
     *        The same is passed to all create, start, stop functions.
    typedef struct {
    	chains_network_integratedObj ucObj;
        UInt32  captureOutWidth;
        UInt32  captureOutHeight;
        UInt32  displayWidth;
        UInt32  displayHeight;
        UInt32 numCh;
        UInt32  displayActiveChId;
        Chains_Ctrl *chainsCfg;
    } chains_network_integratedAppObj;
     * \brief   Set create parameters for NullSrc
    Void chains_network_integrated_SetNullSrcPrms(chains_network_integratedAppObj *pObj,
                            NullSrcLink_CreateParams *pPrm)
        UInt32 chId;
        System_LinkChInfo *pChInfo;
        pPrm->outQueInfo.numCh = 2;
        pObj->numCh = pPrm->outQueInfo.numCh;
    #ifdef KPIT_MODIFICATIONS
        pPrm->timerPeriodMilliSecs = 100;
    #else
        pPrm->timerPeriodMilliSecs = 1000;
    #endif
        for (chId = 0; chId < pPrm->outQueInfo.numCh; chId++)
            pPrm->channelParams[chId].numBuffers = 5;
            pChInfo = &pPrm->outQueInfo.chInfo[chId];
            pChInfo->flags = System_Link_Ch_Info_Set_Flag_Data_Format(pChInfo->flags,
                                                        SYSTEM_DF_YUV422I_YUYV);
    #else
                                                        SYSTEM_DF_YUV420SP_UV);
    #endif
                                                        SYSTEM_SF_PROGRESSIVE);
            pChInfo->flags = System_Link_Ch_Info_Set_Flag_Buf_Type(pChInfo->flags,
                                                   SYSTEM_BUFFER_TYPE_VIDEO_FRAME);
            pChInfo->width  = pObj->captureOutWidth;
            pChInfo->height = pObj->captureOutHeight;
            pChInfo->startX = 0;
            pChInfo->startY = 0;
            pChInfo->pitch[0] = SystemUtils_align((pChInfo->width*2), 32);
            pChInfo->pitch[1] = SystemUtils_align((pChInfo->width*2), 32);
    #else
            pChInfo->pitch[0] = SystemUtils_align(pChInfo->width, 32);
            pChInfo->pitch[1] = SystemUtils_align(pChInfo->width, 32);
    #endif
        pPrm->networkServerPort = NETWORK_RX_SERVER_PORT;
        pPrm->dataRxMode = NULLSRC_LINK_DATA_RX_MODE_NETWORK;
    Void chains_network_integrated_SetNullPrms(NullLink_CreateParams *pPrm)
        pPrm->dumpDataType = NULL_LINK_COPY_TYPE_NETWORK;
        pPrm->networkServerPort = NETWORK_TX_SERVER_PORT;
     * \brief   Set VPE Create Parameters
     * \param   pPrm    [OUT]    VpeLink_CreateParams
    Void chains_network_integrated_SetVpePrm(
                        VpeLink_CreateParams *pPrm1,
                        VpeLink_CreateParams *pPrm2,
                        UInt32 outWidth,
                        UInt32 outHeight,
                        UInt32 srcWidth,
                        UInt32 srcHeight,
                        System_VideoDataFormat dataFormat
        pPrm2->chParams[0].scCfg.bypass       = FALSE;
        pPrm2->chParams[0].scCfg.nonLinear    = FALSE;
        pPrm2->chParams[0].scCfg.stripSize    = 0;
    Void chains_network_integrated_SetDisplayPrms(
                                    DisplayLink_CreateParams *pPrm,
                                    UInt32 displayID,
                                    UInt32 displayWinStartX,
                                    UInt32 displayWinStartY,
                                    UInt32 displayWinWidth,
                                    UInt32 displayWinHeight
        pPrm->displayId = displayID;
        pPrm->rtParams.posX = displayWinStartX;
        pPrm->rtParams.posY = displayWinStartY;
        pPrm->rtParams.tarWidth  = displayWinWidth;
        pPrm->rtParams.tarHeight = displayWinHeight;
    Void chains_network_integrated_Set_AlgPrms(
    		AlgorithmLink_FrameCopyCreateParams *FrameCopy1,
    		AlgorithmLink_FrameCopyCreateParams *FrameCopy2,
                                            Chains_Ctrl *chainsCfg)
    	FrameCopy1->maxWidth    = ALGORITHM_WIDTH;
    	FrameCopy1->maxHeight   = ALGORITHM_HEIGHT;
    	FrameCopy1->numOutputFrames = 5;
    	FrameCopy2->maxWidth    = ALGORITHM_WIDTH;
    	FrameCopy2->maxHeight   = ALGORITHM_HEIGHT;
    	FrameCopy2->numOutputFrames = 5;
    Void chains_network_integrated_SetSyncPrm(SyncLink_CreateParams *Sync)
        Sync->syncDelta = 1100;
        Sync->syncThreshold = 11000;
    Void chains_network_integrated_SetSelectlinkPrms(SelectLink_CreateParams *pPrm)
        pPrm->numOutQue = 2;
        pPrm->outQueChInfo[0].outQueId   = 0;
        pPrm->outQueChInfo[0].numOutCh   = 1;
        pPrm->outQueChInfo[0].inChNum[0] = 0;
        pPrm->outQueChInfo[1].outQueId   = 1;
        pPrm->outQueChInfo[1].numOutCh   = 1;
        pPrm->outQueChInfo[1].inChNum[0] = 1;
    Void chains_network_integrated_Set_DrawPrms( AlgorithmLink_IntegratedDrawCreateParams *OutputDrawParams,
    	OutputDrawParams->imgFrameHeight = ALGORITHM_HEIGHT;
    	OutputDrawParams->imgFrameWidth = ALGORITHM_WIDTH;
    	OutputDrawParams->imgFrameStartX = 0;
    	OutputDrawParams->imgFrameStartY = 0;
    	OutputDrawParams->numOutBuffers = 5;
     * \brief   Set link Parameters
     *          It is called in Create function of the auto generated use-case file.
     * \param pUcObj    [IN] Auto-generated use case object
     * \param appObj    [IN] Application specific object
    Void chains_network_integrated_SetAppPrms(chains_network_integratedObj *pUcObj, Void *appObj)
            = (chains_network_integratedAppObj*)appObj;
        pObj->captureOutWidth  = CAPTURE_SENSOR_WIDTH;
        pObj->captureOutHeight = CAPTURE_SENSOR_HEIGHT;
        ChainsCommon_GetDisplayWidthHeight(
            pObj->chainsCfg->displayType,
            &pObj->displayWidth,
            &pObj->displayHeight
            pObj,
            &pUcObj->NullSourcePrm
        chains_network_integrated_SetNullPrms(&pUcObj->NullPrm);
                               &pUcObj->VPE_1Prm,
                               &pUcObj->VPE_2Prm,
                               ALGORITHM_WIDTH,
                               ALGORITHM_HEIGHT,
                               pObj->captureOutWidth,
                               pObj->captureOutHeight,
        chains_network_integrated_SetSelectlinkPrms(&pUcObj->Select_algPrm);
        ChainsCommon_SetGrpxSrcPrms(&pUcObj->GrpxSrcPrm,
                                                   pObj->displayWidth,
                                                   pObj->displayHeight
        ChainsCommon_SetDisplayPrms(NULL,//&pUcObj->Display_algPrm,
                                    &pUcObj->Display_GrpxPrm,
                                    pObj->displayWidth,
                                    pObj->displayHeight
    //    pUcObj->Display_VideoPrm.displayId                 = DISPLAY_LINK_INST_DSS_VID1;
        chains_network_integrated_Set_AlgPrms(          &pUcObj->Alg_FrameCopy_1Prm,
                									&pUcObj->Alg_FrameCopy_2Prm,
                                                    pObj->chainsCfg);
        chains_network_integrated_Set_DrawPrms( &pUcObj->Alg_IntegratedDrawPrm,pObj->chainsCfg);
        chains_network_integrated_SetSyncPrm(       &pUcObj->Sync_algPrm);
        pUcObj->Display_VideoPrm.rtParams.tarWidth = ALGORITHM_WIDTH;
        pUcObj->Display_VideoPrm.rtParams.tarHeight = ALGORITHM_HEIGHT;
        //Swapnil: Assertion when Image Width/height more than Display Height/Width
        UTILS_assert(pUcObj->Display_VideoPrm.rtParams.tarWidth <= pObj->displayWidth);
        UTILS_assert(pUcObj->Display_VideoPrm.rtParams.tarHeight <= pObj->displayHeight);
        //Swapnil: To Place the Frame at centre of display.Calculate Start PosX and Y based on Display and Frame Width /Height.
        pUcObj->Display_VideoPrm.rtParams.posX = (pObj->displayWidth >> 1) - (ALGORITHM_WIDTH >>1);
        pUcObj->Display_VideoPrm.rtParams.posY = (pObj->displayHeight >> 1) - (ALGORITHM_HEIGHT >>1);
        pUcObj->GrpxSrcPrm.logoDisplayEnable = FALSE;
    #endif
        ChainsCommon_StartDisplayCtrl(
            pObj->displayWidth,
            pObj->displayHeight
     * \brief   Start the Multiple Algorithm Demonstration Links
     *          Function sends a control command to Null Source, Algorithm and display link to
     *          to Start all the required links . Links are started in reverce
     *          order as information of next link is required to connect.
     *          System_linkStart is called with LinkId to start the links.
     * \param   pObj  [IN] chains_network_integratedAppObj
     * \return  SYSTEM_LINK_STATUS_SOK on success
    Void chains_network_integrated_StartApp(chains_network_integratedAppObj *pObj)
        Chains_memPrintHeapStatus();
        ChainsCommon_StartDisplayDevice(pObj->chainsCfg->displayType);
        chains_network_integrated_Start(&pObj->ucObj);
        Chains_prfLoadCalcEnable(TRUE, FALSE, FALSE);
     * \brief   Delete the Multiple Algorithm Demonstration Links
     *          to delete all the prior created links
     *          System_linkDelete is called with LinkId to delete the links.
    Void chains_network_integrated_StopAndDeleteApp(chains_network_integratedAppObj *pObj)
        chains_network_integrated_Stop(&pObj->ucObj);
        chains_network_integrated_Delete(&pObj->ucObj);
        ChainsCommon_StopDisplayCtrl();
        ChainsCommon_StopDisplayDevice(pObj->chainsCfg->displayType);
        /* Print the HWI, SWI and all tasks load */
        /* Reset the accumulated timer ticks */
        Chains_prfLoadCalcEnable(FALSE, TRUE, TRUE);
     * \brief   Multiple Algorithm Demonstration Usecase
     *          This functions executes the create, start functions
     *          Further in a while loop displays run time menu and waits
     *          for user inputs to print the statistics or to end the demo.
     *          Once the user inputs end of demo stop and delete
     *          functions are executed.
     * \param   chainsCfg       [IN]   Chains_Ctrl
    Void chains_network_integrated(Chains_Ctrl *chainsCfg)
        char ch;
        UInt32 done = FALSE;
        chains_network_integratedAppObj chainsObj;
        chainsObj.chainsCfg = chainsCfg;
        chains_network_integrated_Create(&chainsObj.ucObj, &chainsObj);
        chains_network_integrated_StartApp(&chainsObj);
        chainsObj.displayActiveChId = 0;
        while(!done)
            ch = Chains_menuRunTime();
            switch(ch)
                case '0':
                    done = TRUE;
                    break;
                case 'p':
                case 'P':
                    chains_network_integrated_printStatistics(&chainsObj.ucObj);
                    ChainsCommon_PrintStatistics();
                    break;
                default:
                    Vps_printf("\nUnsupported option '%c'. Please try again\n", ch);
                    break;
        chains_network_integrated_StopAndDeleteApp(&chainsObj);
    Socrates
  • Hi Sujith,
    We also tried printing create time parameters in VPE link.
    Here is the log:
    [IPU1-0]     29.734673 s: VPE: OUT0: CH 0: Frame 0: 0x8f08b000, 0x8f08b000, 640 x 400
    [IPU1-0]     29.734856 s: VPE: OUT0: CH 0: Frame 1: 0x8f108000, 0x8f108000, 640 x 400
    [IPU1-0]     29.734978 s: VPE: OUT0: CH 0: Frame 2: 0x8f185000, 0x8f185000, 640 x 400
    [IPU1-0]     29.735100 s: VPE: OUT0: CH 0: Frame 3: 0x8f202000, 0x8f202000, 640 x 400
    [IPU1-0]     29.735252 s: VPE: OUT0: CH 0: Frame 4: 0x8f27f000, 0x8f27f000, 640 x 400
    [IPU1-0]     29.773409 s: VPE: OUT0: CH 1: Frame 0: 0x8f2fc000, 0x8f2fc000, 640 x 400
    [IPU1-0]     29.773592 s: VPE: OUT0: CH 1: Frame 1: 0x8f379000, 0x8f379000, 640 x 400
    [IPU1-0]     29.773775 s: VPE: OUT0: CH 1: Frame 2: 0x8f3f6000, 0x8f3f6000, 640 x 400
    [IPU1-0]     29.773897 s: VPE: OUT0: CH 1: Frame 3: 0x8f473000, 0x8f473000, 640 x 400
    [IPU1-0]     29.774019 s: VPE: OUT0: CH 1: Frame 4: 0x8f4f0000, 0x8f4f0000, 640 x 400
    Socrates
  • Hi Socrates,
    The arguments seem fine. Can you please check the VPE is actually scaling it in-correctly. Please follow the steps below
    1. Build in debug mode, in vision_sdk prompt
    rm -rf ./binaries/
    make -s -j PROFILE=debug depend
    2. Use CCS to load executable for all required core
    3. In IPU_0
    4. Put a break point in function VpeLink_drvReleaseFrames () in VPE Link
    5. run the usecase
    6. Once this function hits, step through and come to instruction pBuf = pFrame->appData;
    7. Copy the 32 bit address of luma from "pFrame->addr[0][0]"
    8. Goto scripting console of CCS (CCS Menu -> View -> Scripting Console)
    9. In the command below replace AAAAAAAA with the 32 bit address that you have copied
    "saveRaw(0, 0xAAAAAAAA, "C:\\VPE_YUV422_1280_720_B_0.yuv", 128000, 32, false)"
    10. Paste this command in the console, ensure that you have pasted correct address.
    11. Use any YUV viewer to check the output or post in the forum.
    Sujith
  • Hi Sujith,
    Please find attached VPE Out files as requested.
    Lower half of the channel 2 output is still corrupted.
    Socrateshttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/4530.VPEOut.7z
  • Hi Socrates,
    Can you please check the input to VPE, it seems like VPE output is 640x400 for both the channels.
    i.e. Put a break point in In function VpeLink_drvReleaseFrames () and run upto "for (frameId = 0x0U; frameId < pReqObj->inFrameListN.numFrames; frameId++)"
    Once pFrame is updated with the input frame, please dump frame pointed by pFrame->addr[0][0]
    Sujith
  • Hi Sujith,
    This is Siddique, working with Socrates.
    As suggested we had put a break point in function VpeLink_drvReleaseFrames() and tried to run till "(frameId = 0x0U; frameId < pReqObj->inFrameListN.numFrames; frameId++)" but the control wasn't coming to that particular line, this line was under a condition "if(pObj->useOverridePrevFldBuf)" and the value of useOverridePrevFldBuf was zero, we made the value forcefully to one and then dumped both input channel values, both the input frames are found to be OK.
    Siddique
  • Hi Siddique,
    OK, can you please check if the width/heights are not actually changing in the SC registers. Please follow steps below
    1. Use CCS to load and run the usecase
    2. From IPU1_C0, open a memory browser (From View tab, choose view memory browser)
    3. Please look at address 0x489D 0710 & 0x489D 0714
      1. Put memory window in continuous refresh mode (or refresh manually), while the usecase is running
    4. Also, please look at address 0x489D 0708 & 0x489D 070C in continuous refresh mode (or manually refresh)
    5. Share the values of these registers
    Sujith
