Linux/WL1831MOD: Unable to add wlan0 into bridge mode
Part Number: WL1831MOD
Tool/software: Linux
we are using wilink wl1831MOD soc on imx6slzbha in dual WIFI STA/AP Mode.
we have created a managed wlan1 interface and are able to add it to a bridge br0 but it is not possible for wlan0
Later we intend to bridge wlan0 on wlan1 but we are getting an error:
root@imx6slzbha:~# brctl addbr br0
root@imx6slzbha:~# brctl addif br0 wlan0
can't add wlan0 to bridge br0: Operation not supported
root@imx6slzbha:~# brctl addif br0 wlan1
device wlan1 entered promiscuous mode
Please assist here.
Ashish S
  • Hi Ashish,
    can you try the command:
    iw dev wlan0 set 4addr on
    before you run "brctl addif br0 wlan0"
    Yordan
  • HI Yordan,
    Thanks for your reply.
    i have tried the same step like this:
    1. This is our WIFI_STA_ON.sh script:
    ifconfig wlan0 up
    sleep 1
    wpa_supplicant -d -Dnl80211 -c/etc/wpa_supplicant.conf -iwlan0 -B
    sleep 1
    wpa_cli -iwlan0 disconnect
    for i in `wpa_cli -iwlan0 list_networks | grep ^[0-9] | cut -f1`; do wpa_cli -iwlan0 remove_network $i; done
    wpa_cli -iwlan0 add_network
    wpa_cli -iwlan0 set_network 0 auth_alg OPEN
    wpa_cli -iwlan0 set_network 0 key_mgmt WPA-PSK
    wpa_cli -iwlan0 set_network 0 psk '"micromax"'
    wpa_cli -iwlan0 set_network 0 pairwise CCMP TKIP
    wpa_cli -iwlan0 set_network 0 group CCMP TKIP
    wpa_cli -iwlan0 set_network 0 mode 0
    wpa_cli -iwlan0 set_network 0 ssid '"AT&T"'
    wpa_cli -iwlan0 select_network 0
    wpa_cli -iwlan0 enable_network 0
    wpa_cli -iwlan0 reassociate
    wpa_cli -iwlan0 status
    udhcpc -i wlan0
    echo 1 > /sys/class/gpio/gpio17/value
    echo 0 > /sys/class/gpio/gpio18/value
    2. This is our Script_bridge.sh:
    lsmod
    sleep 1
    iw wlan0 set 4addr on
    sleep 2
    iw $(ls /sys/class/ieee80211/) interface add wlan1 type managed
    sleep 2
    iw wlan1 set 4addr on
    sleep 3
    ifconfig wlan0 up
    sleep 2
    ifconfig wlan1 up
    sleep 2
    brctl addbr br0
    ifconfig br0 192.168.44.1 netmask 255.255.255.0 up
    sleep 2
    sleep 2
    sleep 30
    sh /home/root/system_init/WIFI_STA_ON.sh
    Logs:
    root@imx6slzbha:~# sh Script_bridge.sh
    Tainted: G
    wl18xx 72328 0 - Live 0x7f0e5000 (O)
    wlcore_sdio 4145 0 - Live 0x7f0e0000 (O)
    wlcore 156846 1 wl18xx, Live 0x7f0ab000 (O)
    mac80211 349608 2 wl18xx,wlcore, Live 0x7f03b000 (O)
    cfg80211 162831 3 wl18xx,wlcore,mac80211, Live 0x7f004000 (O)
    compat 1860 4 wl18xx,wlcore_sdio,mac80211,cfg80211, Live 0x7f000000 (O)
    wlcore: PHY firmware version: Rev 8.2.0.0.195
    wlcore: firmware booted (Rev 8.8.0.0.13)
    IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
    device wlan0 entered promiscuous mode
    wpa_supplicant v2.1
    random: Trying to read entropy from /dev/random
    Successfully initialized wpa_supplicant
    Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
    Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
    Reading configuration file '/etc/wpa_supplicant.conf'
    ctrl_interface='/var/run/wpa_supplicant'
    ctrl_interface_group='0'
    update_config=1
    Priority group 0
    id=0 ssid=''
    nl80211: Could not add multicast membership for vendor events: -2 (No such file or directory)
    rfkill: initial event: idx=0 type=2 op=0 soft=0 hard=0
    rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
    nl80211: Supported cipher 00-0f-ac:1
    nl80211: Supported cipher 00-0f-ac:5
    nl80211: Supported cipher 00-0f-ac:2
    nl80211: Supported cipher 00-0f-ac:4
    nl80211: Supported cipher 00-14-72:1
    nl80211: Supports Probe Response offload in AP mode
    nl80211: Using driver-based off-channel TX
    nl80211: Use separate P2P group interface (driver advertised support)
    nl80211: Enable multi-channel concurrent (driver advertised support)
    nl80211: interface wlan0 in phy phy0
    nl80211: Set mode ifindex 4 iftype 2 (STATION)
    nl80211: Subscribe to mgmt frames with non-AP handle 0x2573a0
    nl80211: Register frame type=0xd0 nl_handle=0x2573a0 match=06
    nl80211: Register frame type=0xd0 nl_handle=0x2573a0 match=0a07
    nl80211: Register frame type=0xd0 nl_handle=0x2573a0 match=0a11
    netlink: Operstate: ifindex=4 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
    nl80211: driver param='(null)'
    Add interface wlan0 to a new radio phy0
    nl80211: Regulatory information - country=00
    nl80211: 2402-2472 @ 40 MHz 20 mBm
    nl80211: 2457-2482 @ 40 MHz 20 mBm
    nl80211: 2474-2494 @ 20 MHz 20 mBm
    nl80211: 5170-5250 @ 160 MHz 20 mBm
    nl80211: 5250-5330 @ 160 MHz 20 mBm
    nl80211: 5490-5730 @ 160 MHz 20 mBm
    nl80211: Added 802.11b mode based on 802.11g information
    wlan0: Own MAC address: 78:a5:04:26:72:44
    wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
    wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
    wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
    wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
    wlan0: RSN: flushing PMKID list in the driver
    nl80211: Flush PMKIDs
    wlan0: WPS: UUID based on MAC address: 116c5382-4500-506d-8fc8-202bbd61bdb4
    EAPOL: SUPP_PAE entering state DISCONNECTED
    EAPOL: Supplicant port status: Unauthorized
    nl80211: Skip set_supp_port(unauthorized) while not associated
    EAPOL: KEY_RX entering state NO_KEY_RECEIVE
    EAPOL: SUPP_BE entering state INITIALIZE
    EAP: EAP entering state DISABLED
    Using existing control interface directory.
    ctrl_interface_group=0
    wlan0: Added interface wlan0
    wlan0: State: DISCONNECTED -> DISCONNECTED
    nl80211: Set wlan0 operstate 0->0 (DORMANT)
    netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
    Daemonize..
    wlan0: authenticate with 40:e3:d6:a2:94:08
    wlan0: send auth to 40:e3:d6:a2:94:08 (try 1/3)
    wlan0: authenticated
    wlan0: associate with 40:e3:d6:a2:94:08 (try 1/3)
    wlan0: RX AssocResp from 40:e3:d6:a2:94:08 (capab=0x421 status=0 aid=1)
    IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    wlan0: associated
    wlcore: Association completed.
    br0: port 2(wlan0) entered forwarding state
    wlcore: ERROR SW watchdog interrupt received! starting recovery.
    ------------[ cut here ]------------
    WARNING: at /home/sandeep/Desktop/SDK/stct_iog1/source/yocto/build/tmp/work/imx6slzbha-poky-linux-gnueabi/ti-compat-wl18xx/r8.a8.10-r0/compat_wireless/drivers/net/wirel)
    Modules linked in: wl18xx(O) wlcore_sdio(O) wlcore(O) mac80211(O) cfg80211(O) compat(O)
    CPU: 0 PID: 323 Comm: irq/283-wl18xx Tainted: G O 3.10.17_BETA-2015-02-12-00_21-1.0.0_ga #13
    [<800138c0>] (unwind_backtrace+0x0/0xf4) from [<800114f8>] (show_stack+0x10/0x14)
    [<800114f8>] (show_stack+0x10/0x14) from [<80025e20>] (warn_slowpath_common+0x54/0x6c)
    [<80025e20>] (warn_slowpath_common+0x54/0x6c) from [<80025ed4>] (warn_slowpath_null+0x1c/0x24)
    [<80025ed4>] (warn_slowpath_null+0x1c/0x24) from [<7f0b02cc>] (wl12xx_queue_recovery_work.part.37+0x58/0x5c [wlcore])
    [<7f0b02cc>] (wl12xx_queue_recovery_work.part.37+0x58/0x5c [wlcore]) from [<7f0b0548>] (wlcore_irq+0x158/0x16c [wlcore])
    [<7f0b0548>] (wlcore_irq+0x158/0x16c [wlcore]) from [<80073dec>] (irq_thread+0x10c/0x160)
    [<80073dec>] (irq_thread+0x10c/0x160) from [<80043220>] (kthread+0xb4/0xb8)
    [<80043220>] (kthread+0xb4/0xb8) from [<8000e118>] (ret_from_fork+0x14/0x3c)
    ---[ end trace c223e9937b562fe2 ]---
    wlcore: Hardware recovery in progress. FW ver: Rev 8.8.0.0.13
    wlcore: pc: 0x1181f0, hint_sts: 0x00000000 count: 1
    wlcore: down
    wlcore: down
    ieee80211 phy0: Hardware restart was requested
    wlan0: deauthenticating from 40:e3:d6:a2:94:08 by local choice (reason=3)
    cfg80211: Calling CRDA to update world regulatory domain
    br0: port 2(wlan0) entered disabled state
    OK
    OK
    0
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    wpa_state=SCANNING
    address=78:a5:04:26:72:44
    uuid=116c5382-4500-506d-8fc8-202bbd61bdb4
    udhcpc (v1.22.1) started
    wlan0: authenticate with a2:f8:95:28:56:3d
    wlan0: send auth to a2:f8:95:28:56:3d (try 1/3)
    wlan0: associate with a2:f8:95:28:56:3d (try 1/3)
    wlan0: RX AssocResp from a2:f8:95:28:56:3d (capab=0x431 status=0 aid=1)
    wlan0: associated
    Sending discover...
    Sending discover...
    wlan0: deauthenticating from a2:f8:95:28:56:3d by local choice (reason=3)
    wlan0: associated
    Sending discover...
    wlan0: associated
    Sending discover...
    ****These logs in a loop****
    Logs in /var/log/messages:
    root@imx6slzbha:~# tail -f /var/log/messages
    Dec 14 18:13:07 imx6slzbha user.info kernel: wlcore: pc: 0x1181f0, hint_sts: 0x00000000 count: 1
    Dec 14 18:13:07 imx6slzbha user.info kernel: wlcore: down
    Dec 14 18:13:07 imx6slzbha user.info kernel: ieee80211 phy0: Hardware restart was requested
    Dec 14 18:13:07 imx6slzbha user.info kernel: wlan0: deauthenticating from 40:e3:d6:a2:94:08 by local choice (reason=3)
    Dec 14 18:13:07 imx6slzbha user.info kernel: cfg80211: Calling CRDA to update world regulatory domain
    Dec 14 18:13:08 imx6slzbha user.info kernel: wlcore: PHY firmware version: Rev 8.2.0.0.195
    Dec 14 18:13:08 imx6slzbha user.info kernel: wlcore: firmware booted (Rev 8.8.0.0.13)
    Dec 14 18:13:08 imx6slzbha user.info kernel: br0: port 2(wlan0) entered disabled state
    Dec 14 18:13:09 imx6slzbha daemon.info telnetd[477]: child process 478 exited: 0
    Dec 14 18:14:02 imx6slzbha user.info kernel: wlan0: authenticate with a2:f8:95:28:56:3d
    Dec 14 18:14:02 imx6slzbha user.info kernel: wlan0: send auth to a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:14:02 imx6slzbha user.info kernel: wlan0: authenticated
    Dec 14 18:14:02 imx6slzbha user.info kernel: wlan0: associate with a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:14:02 imx6slzbha user.info kernel: wlan0: RX AssocResp from a2:f8:95:28:56:3d (capab=0x431 status=0 aid=1)
    Dec 14 18:14:02 imx6slzbha user.info kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    Dec 14 18:14:02 imx6slzbha user.info kernel: wlan0: associated
    Dec 14 18:14:12 imx6slzbha user.info kernel: wlan0: deauthenticating from a2:f8:95:28:56:3d by local choice (reason=3)
    Dec 14 18:14:12 imx6slzbha user.info kernel: cfg80211: Calling CRDA to update world regulatory domain
    Dec 14 18:14:13 imx6slzbha user.info kernel: wlan0: authenticate with a2:f8:95:28:56:3d
    Dec 14 18:14:13 imx6slzbha user.info kernel: wlan0: send auth to a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:14:13 imx6slzbha user.info kernel: wlan0: authenticated
    Dec 14 18:14:13 imx6slzbha user.info kernel: wlan0: associate with a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:14:13 imx6slzbha user.info kernel: wlan0: RX AssocResp from a2:f8:95:28:56:3d (capab=0x431 status=0 aid=1)
    Dec 14 18:14:13 imx6slzbha user.info kernel: wlan0: associated
    Dec 14 18:14:23 imx6slzbha user.info kernel: wlan0: deauthenticating from a2:f8:95:28:56:3d by local choice (reason=3)
    Dec 14 18:14:23 imx6slzbha user.info kernel: cfg80211: Calling CRDA to update world regulatory domain
    Dec 14 18:14:34 imx6slzbha user.info kernel: wlan0: authenticate with a2:f8:95:28:56:3d
    Dec 14 18:14:34 imx6slzbha user.info kernel: wlan0: send auth to a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:14:34 imx6slzbha user.info kernel: wlan0: authenticated
    Dec 14 18:14:34 imx6slzbha user.info kernel: wlan0: associate with a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:14:34 imx6slzbha user.info kernel: wlan0: RX AssocResp from a2:f8:95:28:56:3d (capab=0x431 status=0 aid=1)
    Dec 14 18:14:34 imx6slzbha user.info kernel: wlan0: associated
    Dec 14 18:14:44 imx6slzbha user.info kernel: wlan0: deauthenticating from a2:f8:95:28:56:3d by local choice (reason=3)
    Dec 14 18:14:44 imx6slzbha user.info kernel: cfg80211: Calling CRDA to update world regulatory domain
    Dec 14 18:15:05 imx6slzbha user.info kernel: wlan0: authenticate with a2:f8:95:28:56:3d
    Dec 14 18:15:05 imx6slzbha user.info kernel: wlan0: send auth to a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:15:05 imx6slzbha user.info kernel: wlan0: authenticated
    Dec 14 18:15:05 imx6slzbha user.info kernel: wlan0: associate with a2:f8:95:28:56:3d (try 1/3)
    Dec 14 18:15:05 imx6slzbha user.info kernel: wlan0: RX AssocResp from a2:f8:95:28:56:3d (capab=0x431 status=0 aid=1)
    Dec 14 18:15:05 imx6slzbha user.info kernel: wlan0: associated
    Logs using command: tcpdunmp -i wlan0 -vv
    root@imx6slzbha:~# tcpdump -i wlan0 -vv
    tcpdump: WARNING: wlan0: no IPv4 address assigned
    tcpdump: listening on wlan0, link-type EN10MB (Ethernet), capture size 65535 bytes
    18:15:07.740223 EAPOL key (3) v2, len 95
    18:15:08.740905 EAPOL key (3) v2, len 95
    18:15:09.036243 IP (tos 0x0, ttl 64, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 78:a5:04:26:72:44 (oui Unknown), length 300, xid 0x86bf064c, secs 120, Flags [none] (0x0000)
    Client-Ethernet-Address 78:a5:04:26:72:44 (oui Unknown)
    Vendor-rfc1048 Extensions
    Magic Cookie 0x63825363
    DHCP-Message Option 53, length 1: Discover
    Client-ID Option 61, length 7: ether 78:a5:04:26:72:44
    MSZ Option 57, length 2: 576
    Parameter-Request Option 55, length 7:
    Subnet-Mask, Default-Gateway, Domain-Name-Server, Hostname
    Domain-Name, BR, NTP
    Vendor-Class Option 60, length 12: "udhcp 1.22.1"
    18:15:12.116044 IP (tos 0x0, ttl 64, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 78:a5:04:26:72:44 (oui Unknown), length 300, xid 0x86bf064c, secs 123, Flags [none] (0x0000)
    18:15:37.114110 EAPOL key (3) v2, len 95
    18:15:38.117270 EAPOL key (3) v2, len 95
    18:15:38.326042 IP (tos 0x0, ttl 64, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 78:a5:04:26:72:44 (oui Unknown), length 300, xid 0x9a85150a, secs 149, Flags [none] (0x0000)
    18:15:39.116131 EAPOL key (3) v2, len 95
    18:15:40.117465 EAPOL key (3) v2, len 95
    18:15:41.406052 IP (tos 0x0, ttl 64, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 78:a5:04:26:72:44 (oui Unknown), length 300, xid 0x9a85150a, secs 152, Flags [none] (0x0000)
    ./AP.sh (we are able to start AP mode successfully on wlan1).
    PLease assist here,
    why we are unable to get an IP on wlan0(STA mode).
    Ashish S
  • Hi Yordan,
    A little modification in steps performed:
    As observed, it may be the 4addr command which may be causing problems:
    root@imx6slzbha:~# iw wlan0 set 4addr on
    Please let me know if some more steps are required.
    1. only eth0 and lo interfaces are up at boot.
    2. we add bridge br0 first using:
    brctl addbr br0, then
    and get logs: device wlan0 entered promiscuous mode
    then we run our STA script:
    wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
    sleep 10
    udhcpc -i wlan0
    contents of wpa_supplicant.conf are:
    ctrl_interface=/var/run/wpa_supplicant
    update_config=1
    network={
    ssid="AJT"
    psk="micromax"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    Logs:
    root@imx6slzbha:~# ifconfig br0 up
    IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
    root@imx6slzbha:~# sh STA.sh
    br0: port 1(wlan0) entered forwarding state
    br0: port 1(wlan0) entered disabled state
    Sending discover...
    wlan0: associated
    Sending discover...
    Sending discover...
    wlan0: associated
    we get these logs in a loop.
    Please let us know if it is merely a configuration issue or wlcore driver issue.
    Ashish S
  • Hi Ashish,
    in the last post I don't see "brctl addif br0 wlan1" (adding wlan1 to the bridge) before running STA script, can you check that.
    Also I think that wlan0/1 should be set to "down" before adding to the bridge, something like this:
    # ifconfig wlan0 down
    # ifconfig wlan1 down
    # brctl addbr br0
    # ifconfig wlan0 up
    # ifconfig wlan1 up
    # ifconfig br0 ... up
    Yordan
