AM3352: Booting errors
Part Number: AM3352
Other Parts Discussed in Thread: AM3358, DA8XX
Hi. I have a Problem about Am3352 that I designed.
There is problem the board is stopped at only specific logs(blue logs) and
The number of Occurrences is apporoximately once or twice a 10 times.
The following Log is that I mentioned when problem is occured.
I don't know why this problem happens.!! Please give a comment to solve the problem.
[Fri Jan 06 20:59:48.162 2017] U-Boot SPL 2013.01.01 (Oct 25 2016 - 21:05:39)
[Fri Jan 06 20:59:48.164 2017] [CRZ] mux.c (366) enable_i2c0_pin_mux:
[Fri Jan 06 20:59:48.188 2017] [CRZ] board.c (847) s_init:
[Fri Jan 06 20:59:48.189 2017] [CRZ] board.c (94) read_eeprom:
[Fri Jan 06 20:59:48.190 2017] [CRZ] mux.c (485) enable_board_pin_mux: AM3358, Start EVM
[Fri Jan 06 20:59:48.193 2017] [CRZ] mux.c (378) enable_spi0_pin_mux:
[Fri Jan 06 20:59:48.194 2017] [CRZ] mux.c (372) enable_nand_pin_mux:
[Fri Jan 06 20:59:48.196 2017] [CRZ] board.c (912) s_init:
[Fri Jan 06 20:59:48.205 2017] [CRZ] board.c (943) s_init:
[Fri Jan 06 20:59:48.222 2017] [CRZ] spl.c (162) board_init_r:
[Fri Jan 06 20:59:48.325 2017] [CRZ] timer.c (52) timer_init:
[Fri Jan 06 20:59:48.327 2017] [CRZ] boot-common.c (59) spl_board_init:
[Fri Jan 06 20:59:48.329 2017] [CRZ] mem.c (90) gpmc_init:
[Fri Jan 06 20:59:48.330 2017] [CRZ] mem.c (66) enable_gpmc_cs_config:
[Fri Jan 06 20:59:48.331 2017] [CRZ] board.c (477) am33xx_spl_board_init:
[Fri Jan 06 20:59:48.345 2017] [CRZ] board.c (142) arch_misc_init:
[Fri Jan 06 20:59:48.356 2017] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Fri Jan 06 20:59:48.360 2017] musb-hdrc: MHDRC RTL version 2.0
[Fri Jan 06 20:59:48.361 2017] musb-hdrc: setup fifo_mode 4
[Fri Jan 06 20:59:48.363 2017] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Fri Jan 06 20:59:48.396 2017] USB Peripheral mode controller at 47401000 using PIO, IRQ 0
[Fri Jan 06 20:59:48.398 2017] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Fri Jan 06 20:59:48.402 2017] musb-hdrc: MHDRC RTL version 2.0
[Fri Jan 06 20:59:48.403 2017] musb-hdrc: setup fifo_mode 4
[Fri Jan 06 20:59:48.404 2017] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Fri Jan 06 20:59:48.406 2017] USB Host mode controller at 47401800 using PIO, IRQ 0
[Fri Jan 06 20:59:48.408 2017] [CRZ] boot-common.c (45) spl_boot_device: boot_params.omap_bootdevice: 0x8
[Fri Jan 06 20:59:48.411 2017] [CRZ] spl.c (182) board_init_r: boot device - 8
[Fri Jan 06 20:59:48.413 2017] [CRZ] spl.c (201) board_init_r: BOOT_DEVICE_MMC
[Fri Jan 06 20:59:48.431 2017] [CRZ] boot-common.c (74) board_mmc_init:
[Fri Jan 06 20:59:48.433 2017] [CRZ] boot-common.c (45) spl_boot_device: boot_params.omap_bootdevice: 0x8
[Fri Jan 06 20:59:48.436 2017] OMAP SD/MMC: 0
[Fri Jan 06 20:59:48.480 2017] [CRZ] boot-common.c (52) spl_boot_mode: omap_bootmode: 0x2
[Fri Jan 06 20:59:48.487 2017] reading u-boot.img
[Fri Jan 06 20:59:48.488 2017] reading u-boot.img
[Fri Jan 06 20:59:48.543 2017] [CRZ] spl.c (252) board_init_r: Jumping to U-Boot
[Fri Jan 06 20:59:48.546 2017] [CRZ] spl.c (133) jump_to_image_no_args: image entry point: 0x80800000
[Fri Jan 06 20:59:48.557 2017]
[Fri Jan 06 20:59:48.557 2017] U-Boot 2013.01.01 (Oct 25 2016 - 21:05:39)
[Fri Jan 06 20:59:48.558 2017]
[Fri Jan 06 20:59:48.559 2017] I2C: ready
[Fri Jan 06 20:59:48.605 2017] DRAM: 1 GiB
[Fri Jan 06 20:59:48.822 2017] WARNING: Caches not enabled
[Fri Jan 06 20:59:48.824 2017] [CRZ] board.c (993) board_init:
[Fri Jan 06 20:59:48.825 2017] [CRZ] mux.c (378) enable_spi0_pin_mux:
[Fri Jan 06 20:59:48.827 2017] [CRZ] mux.c (372) enable_nand_pin_mux:
[Fri Jan 06 20:59:48.828 2017] [CRZ] board.c (964) check_reset_status: PRM_RSTST: 0x00000001
[Fri Jan 06 20:59:48.831 2017] [CRZ] board.c (984) check_reset_status: Power-on reset has occurred.
[Fri Jan 06 20:59:48.889 2017] [CRZ] board.c (1006) board_init:
[Fri Jan 06 20:59:48.891 2017] [CRZ] board.c (94) read_eeprom:
[Fri Jan 06 20:59:48.892 2017] [CRZ] mem.c (90) gpmc_init:
[Fri Jan 06 20:59:48.894 2017] [CRZ] mem.c (66) enable_gpmc_cs_config:
[Fri Jan 06 20:59:48.968 2017] NAND: [CRZ] nand.c (107) nand_init:
[Fri Jan 06 20:59:48.969 2017] [CRZ] nand.c (87) nand_init_chip:
[Fri Jan 06 20:59:48.971 2017] [CRZ] omap_gpmc.c (797) board_nand_init:
[Fri Jan 06 20:59:48.972 2017] [CRZ] omap_gpmc.c (847) board_nand_init: AM33XX NAND_ECC_HW
[Fri Jan 06 20:59:48.975 2017] [CRZ] nand_base.c (3240) nand_scan:
[Fri Jan 06 20:59:48.976 2017] [CRZ] nand_base.c (2920) nand_scan_ident:
[Fri Jan 06 20:59:48.978 2017] [CRZ] nand_base.c (2610) nand_get_flash_type:
[Fri Jan 06 20:59:49.004 2017] [CRZ] nand_base.c (2686) nand_get_flash_type: chip->cellinfo: 0x90, extid: 0x95
[Fri Jan 06 20:59:49.007 2017] [CRZ] nand_base.c (2746) nand_get_flash_type: mtd->writesize: 0x800
[Fri Jan 06 20:59:49.009 2017] [CRZ] nand_base.c (2764) nand_get_flash_type: busw: 0x0
[Fri Jan 06 20:59:49.012 2017] [CRZ] nand_base.c (2841) nand_get_flash_type: NAND_LARGE_BADBLOCK_POS
[Fri Jan 06 20:59:49.015 2017] [CRZ] nand.c (53) nand_register:
[Fri Jan 06 20:59:49.016 2017] 256 MiB
[Fri Jan 06 20:59:49.016 2017] MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
[Fri Jan 06 20:59:49.921 2017] *** Warning - bad CRC, using default environment
[Fri Jan 06 20:59:49.923 2017]
[Fri Jan 06 20:59:50.373 2017] [CRZ] board.c (142) arch_misc_init:
[Fri Jan 06 20:59:50.394 2017] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Fri Jan 06 20:59:50.397 2017] musb-hdrc: MHDRC RTL version 2.0
[Fri Jan 06 20:59:50.399 2017] musb-hdrc: setup fifo_mode 4
[Fri Jan 06 20:59:50.400 2017] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Fri Jan 06 20:59:50.405 2017] USB Peripheral mode controller at 47401000 using PIO, IRQ 0
[Fri Jan 06 20:59:50.446 2017] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Fri Jan 06 20:59:50.450 2017] musb-hdrc: MHDRC RTL version 2.0
[Fri Jan 06 20:59:50.451 2017] musb-hdrc: setup fifo_mode 4
[Fri Jan 06 20:59:50.452 2017] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Fri Jan 06 20:59:50.454 2017] USB Host mode controller at 47401800 using PIO, IRQ 0
[Fri Jan 06 20:59:50.456 2017] [CRZ] board.c (1020) board_late_init:
[Fri Jan 06 20:59:50.458 2017] [CRZ] mux.c (378) enable_spi0_pin_mux:
[Fri Jan 06 20:59:50.459 2017] [CRZ] mux.c (372) enable_nand_pin_mux:
[Fri Jan 06 20:59:50.461 2017] Net: [CRZ] board.c (1095) board_eth_init:
[Fri Jan 06 20:59:50.463 2017] <ethaddr> not set. Validating first E-fuse MAC
[Fri Jan 06 20:59:50.474 2017] cpsw, usb_ether
[Fri Jan 06 20:59:50.474 2017] Hit enter key to stop autoboot: 1 0
[Fri Jan 06 20:59:51.542 2017] mmc0 is current device
[Fri Jan 06 20:59:51.610 2017] SD/MMC found on device 0
[Fri Jan 06 20:59:51.613 2017] reading uEnv.txt
[Fri Jan 06 20:59:51.616 2017] ** Unable to read file uEnv.txt **
[Fri Jan 06 20:59:51.620 2017] reading uImage
[Fri Jan 06 20:59:52.038 2017] 4219368 bytes read in 414 ms (9.7 MiB/s)
[Fri Jan 06 20:59:52.041 2017] Booting from mmc ...
[Fri Jan 06 20:59:52.069 2017] ## Booting kernel from Legacy Image at 80007fc0 ...
[Fri Jan 06 20:59:52.070 2017] Image Name: Linux-3.2.0
[Fri Jan 06 20:59:52.071 2017] Image Type: ARM Linux Kernel Image (uncompressed)
[Fri Jan 06 20:59:52.072 2017] Data Size: 4219304 Bytes = 4 MiB
[Fri Jan 06 20:59:52.073 2017] Load Address: 80008000
[Fri Jan 06 20:59:52.073 2017] Entry Point: 80008000
[Fri Jan 06 20:59:52.074 2017] Verifying Checksum ... OK
[Fri Jan 06 20:59:53.084 2017] XIP Kernel Image ... OK
[Fri Jan 06 20:59:53.119 2017] OK
[Fri Jan 06 20:59:53.119 2017] Starting kernel ...
[Fri Jan 06 20:59:53.120 2017]
[Fri Jan 06 20:59:53.140 2017] Uncompressing Linux... done, booting the kernel.
[Fri Jan 06 20:59:54.196 2017] [ 0.000000] Linux version 3.2.0 (root@sitara-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #9 Fri Oct 28 16:19:11 KST 2016
[Fri Jan 06 20:59:54.199 2017] [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[Fri Jan 06 20:59:54.201 2017] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[Fri Jan 06 20:59:54.203 2017] [ 0.000000] Machine: am335xevm
[Fri Jan 06 20:59:54.204 2017] [ 0.000000] Truncating RAM at 80000000-bfffffff to -af7fffff (vmalloc region overlap).
[Fri Jan 06 20:59:54.205 2017] [ 0.000000] Memory policy: ECC disabled, Data cache writeback
[Fri Jan 06 20:59:54.243 2017] [ 0.000000] AM335X ES2.1 (neon )
[Fri Jan 06 20:59:54.244 2017] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 193040
[Fri Jan 06 20:59:54.246 2017] [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait ip=none
[Fri Jan 06 20:59:54.248 2017] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[Fri Jan 06 20:59:54.250 2017] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[Fri Jan 06 20:59:54.252 2017] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[Fri Jan 06 20:59:54.253 2017] [ 0.000000] Memory: 760MB = 760MB total
[Fri Jan 06 20:59:54.289 2017] [ 0.000000] Memory: 761272k/761272k available, 16968k reserved, 0K highmem
[Fri Jan 06 20:59:54.291 2017] [ 0.000000] Virtual kernel memory layout:
[Fri Jan 06 20:59:54.292 2017] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[Fri Jan 06 20:59:54.293 2017] [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[Fri Jan 06 20:59:54.295 2017] [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[Fri Jan 06 20:59:54.297 2017] [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[Fri Jan 06 20:59:54.298 2017] [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[Fri Jan 06 20:59:54.299 2017] [ 0.000000] .text : 0xc0008000 - 0xc07ac000 (7824 kB)
[Fri Jan 06 20:59:54.336 2017] [ 0.000000] .init : 0xc07ac000 - 0xc07fd000 ( 324 kB)
[Fri Jan 06 20:59:54.338 2017] [ 0.000000] .data : 0xc07fe000 - 0xc0874970 ( 475 kB)
[Fri Jan 06 20:59:54.339 2017] [ 0.000000] .bss : 0xc0874994 - 0xc09d099c (1393 kB)
[Fri Jan 06 20:59:54.341 2017] [ 0.000000] NR_IRQS:396
[Fri Jan 06 20:59:54.341 2017] [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[Fri Jan 06 20:59:54.343 2017] [ 0.000000] Total of 128 interrupts on 1 active controller
[Fri Jan 06 20:59:54.344 2017] [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[Fri Jan 06 20:59:54.346 2017] [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[Fri Jan 06 20:59:54.347 2017] [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[Fri Jan 06 20:59:54.384 2017] [ 0.000000] Console: colour dummy device 80x30
[Fri Jan 06 20:59:54.385 2017] [ 0.000061] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[Fri Jan 06 20:59:54.387 2017] [ 0.089202] pid_max: default: 32768 minimum: 301
[Fri Jan 06 20:59:54.388 2017] [ 0.089324] Security Framework initialized
[Fri Jan 06 20:59:54.389 2017] [ 0.089385] Mount-cache hash table entries: 512
[Fri Jan 06 20:59:54.390 2017] [ 0.089721] CPU: Testing write buffer coherency: ok
[Fri Jan 06 20:59:54.391 2017] [ 0.089752] ftrace: allocating 22346 entries in 66 pages
[Fri Jan 06 20:59:54.392 2017] [ 0.126800] devtmpfs: initialized
[Fri Jan 06 20:59:54.429 2017] [ 0.145874] omap_hwmod: gfx: failed to hardreset
[Fri Jan 06 20:59:54.430 2017] [ 0.161743] omap_hwmod: pruss: failed to hardreset
[Fri Jan 06 20:59:54.432 2017] [ 0.163024] print_constraints: dummy:
[Fri Jan 06 20:59:54.432 2017] [ 0.163269] NET: Registered protocol family 16
[Fri Jan 06 20:59:54.433 2017] [ 0.165069] OMAP GPIO hardware version 0.1
[Fri Jan 06 20:59:54.434 2017] [ 0.167266] omap_mux_init: Add partition: #1: core, flags: 0
[Fri Jan 06 20:59:54.436 2017] [ 0.168670] Board name: A335X_SK
[Fri Jan 06 20:59:54.437 2017] [ 0.168670] Board version:
[Fri Jan 06 20:59:54.437 2017] [ 0.168701] omap_i2c.1: alias fck already exists
[Fri Jan 06 20:59:54.439 2017] [ 0.168853] Board name: A335X_SK
[Fri Jan 06 20:59:54.439 2017] [ 0.168884] Board version:
[Fri Jan 06 20:59:54.476 2017] [ 0.168884] The board is a AM335x Starter Kit.
[Fri Jan 06 20:59:54.477 2017] [ 0.168914] omap_hsmmc.0: alias fck already exists
[Fri Jan 06 20:59:54.478 2017] [ 0.169677] da8xx_lcdc.0: alias fck already exists
[Fri Jan 06 20:59:54.480 2017] [ 0.171020] davinci-mcasp.1: alias fck already exists
[Fri Jan 06 20:59:54.481 2017] [ 0.171264] omap_i2c.2: alias fck already exists
[Fri Jan 06 20:59:54.482 2017] [ 0.171813] _regulator_get: l3_main.0 supply vdd_core not found, using dummy regulator
[Fri Jan 06 20:59:54.485 2017] [ 0.171905] am335x_opp_update: physical regulator not present for core(-22)
[Fri Jan 06 20:59:54.487 2017] [ 0.172363] omap2_mcspi.1: alias fck already exists
[Fri Jan 06 20:59:54.489 2017] [ 0.172546] omap2_mcspi.2: alias fck already exists
[Fri Jan 06 20:59:54.523 2017] [ 0.172790] edma.0: alias fck already exists
[Fri Jan 06 20:59:54.524 2017] [ 0.172790] edma.0: alias fck already exists
[Fri Jan 06 20:59:54.525 2017] [ 0.172821] edma.0: alias fck already exists
[Fri Jan 06 20:59:54.526 2017] [ 0.200836] bio: create slab <bio-0> at 0
[Fri Jan 06 20:59:54.528 2017] [ 0.202606] SCSI subsystem initialized
[Fri Jan 06 20:59:54.529 2017] [ 0.203948] usbcore: registered new interface driver usbfs
[Fri Jan 06 20:59:54.530 2017] [ 0.204193] usbcore: registered new interface driver hub
[Fri Jan 06 20:59:54.531 2017] [ 0.204345] usbcore: registered new device driver usb
[Fri Jan 06 20:59:54.533 2017] [ 0.205047] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[Fri Jan 06 20:59:54.569 2017] [ 0.205535] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[Fri Jan 06 20:59:54.571 2017] [ 0.206115] pps_core: LinuxPPS API ver. 1 registered
[Fri Jan 06 20:59:54.572 2017] [ 0.206115] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Fri Jan 06 20:59:54.574 2017] [ 0.206207] PTP clock support registered
[Fri Jan 06 20:59:54.575 2017] [ 0.207000] Advanced Linux Sound Architecture Driver Version 1.0.24.
[Fri Jan 06 20:59:54.577 2017] [ 0.208038] Switching to clocksource gp timer
[Fri Jan 06 20:59:54.578 2017] [ 0.230590] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[Fri Jan 06 20:59:54.579 2017] [ 0.230926] NET: Registered protocol family 2
[Fri Jan 06 20:59:54.617 2017] [ 0.231109] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[Fri Jan 06 20:59:54.620 2017] [ 0.231506] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[Fri Jan 06 20:59:54.622 2017] [ 0.233093] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[Fri Jan 06 20:59:54.624 2017] [ 0.233581] TCP: Hash tables configured (established 131072 bind 65536)
[Fri Jan 06 20:59:54.626 2017] [ 0.233581] TCP reno registered
[Fri Jan 06 20:59:54.627 2017] [ 0.233581] UDP hash table entries: 512 (order: 1, 8192 bytes)
[Fri Jan 06 20:59:54.628 2017] [ 0.233612] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[Fri Jan 06 20:59:54.662 2017] [ 0.233764] NET: Registered protocol family 1
[Fri Jan 06 20:59:54.663 2017] [ 0.234008] RPC: Registered named UNIX socket transport module.
[Fri Jan 06 20:59:54.665 2017] [ 0.234039] RPC: Registered udp transport module.
[Fri Jan 06 20:59:54.666 2017] [ 0.234039] RPC: Registered tcp transport module.
[Fri Jan 06 20:59:54.668 2017] [ 0.234039] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Fri Jan 06 20:59:54.669 2017] [ 0.234222] NetWinder Floating Point Emulator V0.97 (double precision)
[Fri Jan 06 20:59:54.671 2017] [ 0.234405] omap-gpmc omap-gpmc: GPMC revision 6.0
[Fri Jan 06 20:59:54.672 2017] [ 0.234436] Registering NAND on CS0
[Fri Jan 06 20:59:54.673 2017] [ 0.334838] ashmem: initialized
[Fri Jan 06 20:59:54.673 2017] [ 0.335052] VFS: Disk quotas dquot_6.5.2
[Fri Jan 06 20:59:54.710 2017] [ 0.335083] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[Fri Jan 06 20:59:54.711 2017] [ 0.335754] JFFS2 version 2.2. (NAND) ⓒ 2001-2006 Red Hat, Inc.
[Fri Jan 06 20:59:54.713 2017] [ 0.335937] fuse init (API version 7.17)
[Fri Jan 06 20:59:54.714 2017] [ 0.336395] msgmni has been set to 1486
[Fri Jan 06 20:59:54.715 2017] [ 0.337158] io scheduler noop registered
[Fri Jan 06 20:59:54.716 2017] [ 0.337158] io scheduler deadline registered
[Fri Jan 06 20:59:54.717 2017] [ 0.337219] io scheduler cfq registered (default)
[Fri Jan 06 20:59:54.718 2017] [ 0.338623] da8xx_lcdc da8xx_lcdc.0: GLCD: Found INNO_EJ050NA_5INCH panel
[Fri Jan 06 20:59:54.719 2017] [ 0.352172] Console: switching to colour frame buffer device 100x60
[Fri Jan 06 20:59:54.725 2017] [ 0.360229] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[Fri Jan 06 20:59:54.727 2017] [ 0.931396] console [ttyO0] enabled
[Fri Jan 06 20:59:54.731 2017] [ 0.935577] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[Fri Jan 06 20:59:54.739 2017] [ 0.943389] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[Fri Jan 06 20:59:54.747 2017] [ 0.951171] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[Fri Jan 06 20:59:54.755 2017] [ 0.958923] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[Fri Jan 06 20:59:54.763 2017] [ 0.966674] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[Fri Jan 06 20:59:54.768 2017] [ 0.974700] [drm] Initialized drm 1.1.0 20060810
[Fri Jan 06 20:59:54.779 2017] [ 0.987365] brd: module loaded
[Fri Jan 06 20:59:54.786 2017] [ 0.994964] loop: module loaded
[Fri Jan 06 20:59:54.800 2017] [ 0.998626] i2c-core: driver [tsl2550] using legacy suspend method
[Fri Jan 06 20:59:54.801 2017] [ 1.005096] i2c-core: driver [tsl2550] using legacy resume method
[Fri Jan 06 20:59:54.804 2017] [ 1.011749] (hci_tty): inside hci_tty_init
[Fri Jan 06 20:59:54.809 2017] [ 1.016357] (hci_tty): allocated 249, 0
[Fri Jan 06 20:59:54.818 2017] [ 1.022460] mtdoops: mtd device (mtddev=name/number) must be supplied
[Fri Jan 06 20:59:54.822 2017] [ 1.029693] omap2-nand driver initializing
[Fri Jan 06 20:59:54.826 2017] [ 1.034271] ONFI flash detected
[Fri Jan 06 20:59:54.838 2017] [ 1.037689] ONFI param page 0 valid
[Fri Jan 06 20:59:54.840 2017] [ 1.041351] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[Fri Jan 06 20:59:54.849 2017] [ 1.049926] Creating 8 MTD partitions on "omap2-nand.0":
[Fri Jan 06 20:59:54.851 2017] [ 1.055511] 0x000000000000-0x000000020000 : "SPL"
[Fri Jan 06 20:59:54.856 2017] [ 1.061737] 0x000000020000-0x000000040000 : "SPL.backup1"
[Fri Jan 06 20:59:54.863 2017] [ 1.068511] 0x000000040000-0x000000060000 : "SPL.backup2"
[Fri Jan 06 20:59:54.870 2017] [ 1.075347] 0x000000060000-0x000000080000 : "SPL.backup3"
[Fri Jan 06 20:59:54.875 2017] [ 1.082183] 0x000000080000-0x000000260000 : "U-Boot"
[Fri Jan 06 20:59:54.883 2017] [ 1.089294] 0x000000260000-0x000000280000 : "U-Boot Env"
[Fri Jan 06 20:59:54.890 2017] [ 1.096069] 0x000000280000-0x000000780000 : "Kernel"
[Fri Jan 06 20:59:54.899 2017] [ 1.104461] 0x000000780000-0x000010000000 : "File System"
[Fri Jan 06 20:59:55.013 2017] [ 1.214630] CAN device driver interface
[Fri Jan 06 20:59:55.014 2017] [ 1.218688] CAN bus driver for Bosch D_CAN controller 1.0
[Fri Jan 06 20:59:55.070 2017] [ 1.268615] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[Fri Jan 06 20:59:55.073 2017] [ 1.275085] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[Fri Jan 06 20:59:55.082 2017] [ 1.282226] davinci_mdio.0: probed
[Fri Jan 06 20:59:55.083 2017] [ 1.285766] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[Fri Jan 06 20:59:55.087 2017] [ 1.293304] PPP generic driver version 2.4.2
[Fri Jan 06 20:59:55.112 2017] [ 1.298126] PPP BSD Compression module registered
[Fri Jan 06 20:59:55.114 2017] [ 1.303070] PPP Deflate Compression module registered
[Fri Jan 06 20:59:55.115 2017] [ 1.308380] RTL871X: module init start
[Fri Jan 06 20:59:55.117 2017] [ 1.312286] RTL871X: rtl8188eu v4.3.0.9_15178.20150907
[Fri Jan 06 20:59:55.118 2017] [ 1.317657] RTL871X: build time: Oct 27 2016 20:41:38
[Fri Jan 06 20:59:55.121 2017] [ 1.323150] usbcore: registered new interface driver rtl8188eu
[Fri Jan 06 20:59:55.123 2017] [ 1.329284] RTL871X: module init ret=0
[Fri Jan 06 20:59:55.135 2017] [ 1.333343] usbcore: registered new interface driver zd1201
[Fri Jan 06 20:59:55.137 2017] [ 1.339172] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[Fri Jan 06 20:59:55.163 2017] [ 1.346527] usbcore: registered new interface driver rtl8150
[Fri Jan 06 20:59:55.165 2017] [ 1.352569] usbcore: registered new interface driver cdc_ether
[Fri Jan 06 20:59:55.167 2017] [ 1.358795] usbcore: registered new interface driver cdc_eem
[Fri Jan 06 20:59:55.168 2017] [ 1.364807] usbcore: registered new interface driver dm9601
[Fri Jan 06 20:59:55.170 2017] [ 1.370697] cdc_ncm: 04-Aug-2011
[Fri Jan 06 20:59:55.173 2017] [ 1.374206] usbcore: registered new interface driver cdc_ncm
[Fri Jan 06 20:59:55.188 2017] [ 1.380279] usbcore: registered new interface driver cdc_acm
[Fri Jan 06 20:59:55.190 2017] [ 1.386169] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[Fri Jan 06 20:59:55.193 2017] [ 1.394561] Initializing USB Mass Storage driver...
[Fri Jan 06 20:59:55.199 2017] [ 1.399810] usbcore: registered new interface driver usb-storage
[Fri Jan 06 20:59:55.201 2017] [ 1.406066] USB Mass Storage support registered.
[Fri Jan 06 20:59:55.206 2017] [ 1.411193] usbcore: registered new interface driver usbserial
[Fri Jan 06 20:59:55.210 2017] [ 1.417388] USB Serial support registered for generic
[Fri Jan 06 20:59:55.223 2017] [ 1.422821] usbcore: registered new interface driver usbserial_generic
[Fri Jan 06 20:59:55.226 2017] [ 1.429656] usbserial: USB Serial Driver core
[Fri Jan 06 20:59:55.230 2017] [ 1.434326] USB Serial support registered for GSM modem (1-port)
[Fri Jan 06 20:59:55.241 2017] [ 1.440734] usbcore: registered new interface driver option
[Fri Jan 06 20:59:55.243 2017] [ 1.446563] option: v0.7.2:USB Driver for GSM modems
[Fri Jan 06 20:59:55.247 2017] [ 1.452545] mousedev: PS/2 mouse device common for all mice
[Fri Jan 06 20:59:55.257 2017] [ 1.459197] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[Fri Jan 06 20:59:55.263 2017] [ 1.468139] rtc-pcf8563 1-0051: chip found, driver version 0.4.3
[Fri Jan 06 20:59:55.269 2017] [ 1.474670] rtc-pcf8563 1-0051: pcf8563_get_datetime: read error
[Fri Jan 06 20:59:55.286 2017] [ 1.481536] using rtc device, rtc-pcf8563, for alarms
[Fri Jan 06 20:59:55.287 2017] [ 1.486694] rtc-pcf8563 1-0051: rtc core: registered rtc-pcf8563 as rtc0
[Fri Jan 06 20:59:55.289 2017] [ 1.494049] i2c /dev entries driver
[Fri Jan 06 20:59:55.292 2017] [ 1.498260] Linux video capture interface: v2.00
[Fri Jan 06 20:59:55.302 2017] [ 1.503753] usbcore: registered new interface driver uvcvideo
[Fri Jan 06 20:59:55.304 2017] [ 1.509796] USB Video Class driver (1.1.1)
[Fri Jan 06 20:59:56.443 2017] [ 2.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 20:59:57.443 2017] [ 3.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 20:59:58.442 2017] [ 4.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 20:59:59.447 2017] [ 5.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 21:00:00.443 2017] [ 6.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 21:00:01.442 2017] [ 7.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 21:00:02.443 2017] [ 8.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 21:00:03.443 2017] [ 9.648681] omap_i2c omap_i2c.2: controller timed out
[Fri Jan 06 21:00:03.450 2017] [ 9.654937] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[Fri Jan 06 21:00:03.455 2017] [ 9.661529] device-mapper: uevent: version 1.0.3
[Fri Jan 06 21:00:03.465 2017] [ 9.666717] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[Fri Jan 06 21:00:03.473 2017] [ 9.675628] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[Fri Jan 06 21:00:03.478 2017] [ 9.684295] cpuidle: using governor ladder
[Fri Jan 06 21:00:03.482 2017] [ 9.688995] cpuidle: using governor menu
[Fri Jan 06 21:00:03.494 2017] [ 9.693328] sdhci: Secure Digital Host Controller Interface driver
[Fri Jan 06 21:00:03.495 2017] [ 9.699798] sdhci: Copyright(c) Pierre Ossman
[Fri Jan 06 21:00:03.507 2017] [ 9.708007] usbcore: registered new interface driver usbhid
[Fri Jan 06 21:00:03.508 2017] [ 9.713867] usbhid: USB HID core driver
[Fri Jan 06 21:00:03.512 2017] [ 9.718414] logger: created 256K log 'log_main'
[Fri Jan 06 21:00:03.518 2017] [ 9.723632] logger: created 256K log 'log_events'
[Fri Jan 06 21:00:03.523 2017] [ 9.728820] logger: created 256K log 'log_radio'
[Fri Jan 06 21:00:03.527 2017] [ 9.733856] logger: created 256K log 'log_system'
[Fri Jan 06 21:00:03.533 2017] [ 9.739654] tiadc tiadc: attached adc driver
[Fri Jan 06 21:00:03.543 2017] [ 9.747833] usbcore: registered new interface driver snd-usb-audio
[Fri Jan 06 21:00:03.562 2017] [ 9.756164] ALSA device list:
[Fri Jan 06 21:00:03.563 2017] [ 9.759307] No soundcards found.
[Fri Jan 06 21:00:03.564 2017] [ 9.762878] oprofile: hardware counters not available
[Fri Jan 06 21:00:03.565 2017] [ 9.768157] oprofile: using timer interrupt.
[Fri Jan 06 21:00:03.576 2017] [ 9.772705] TCP cubic registered
[Fri Jan 06 21:00:03.577 2017] [ 9.776062] NET: Registered protocol family 17
[Fri Jan 06 21:00:03.578 2017] [ 9.780761] can: controller area network core (rev 20090105 abi 8)
[Fri Jan 06 21:00:03.603 2017] [ 9.787353] NET: Registered protocol family 29
[Fri Jan 06 21:00:03.604 2017] [ 9.792022] can: raw protocol (rev 20090105)
[Fri Jan 06 21:00:03.605 2017] [ 9.796478] can: broadcast manager protocol (rev 20090105 t)
[Fri Jan 06 21:00:03.606 2017] [ 9.802429] lib80211: common routines for IEEE802.11 drivers
[Fri Jan 06 21:00:03.608 2017] [ 9.808380] Registering the dns_resolver key type
[Fri Jan 06 21:00:03.620 2017] [ 9.813385] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[Fri Jan 06 21:00:03.622 2017] [ 9.821411] ThumbEE CPU extension supported.
[Fri Jan 06 21:00:03.623 2017] [ 9.825927] mux: Failed to setup hwmod io irq -22
[Fri Jan 06 21:00:03.625 2017] [ 9.831420] Power Management for AM33XX family
[Fri Jan 06 21:00:03.632 2017] [ 9.836242] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[Fri Jan 06 21:00:03.636 2017] [ 9.842956] Copied the M3 firmware to UMEM
[Fri Jan 06 21:00:03.641 2017] [ 9.847290] Cortex M3 Firmware Version = 0x181
[Fri Jan 06 21:00:03.649 2017] [ 9.854766] clock: disabling unused clocks to save power
[Fri Jan 06 21:00:03.657 2017] [ 9.863525] Detected MACID=4:a3:16:d8:1b:9b
[Fri Jan 06 21:00:03.663 2017] [ 9.868835] cpsw: Detected MACID = 04:a3:16:d8:1b:9d
[Fri Jan 06 21:00:03.671 2017] [ 9.875213] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[Fri Jan 06 21:00:03.687 2017] [ 9.884002] rtc-pcf8563 1-0051: pcf8563_get_datetime: read error
[Fri Jan 06 21:00:03.688 2017] [ 9.890319] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
[Fri Jan 06 21:00:03.692 2017] [ 9.897949] Waiting for root device /dev/mmcblk0p2...
[Fri Jan 06 21:00:03.727 2017] [ 9.929351] mmc0: host does not support reading read-only switch. assuming write-enable.
[Fri Jan 06 21:00:03.734 2017] [ 9.939758] mmc0: new high speed SDHC card at address 0007
[Fri Jan 06 21:00:03.740 2017] [ 9.946044] mmcblk0: mmc0:0007 SS08G 7.21 GiB
[Fri Jan 06 21:00:03.744 2017] [ 9.952301] mmcblk0: p1 p2
[Fri Jan 06 21:00:03.817 2017] [ 10.013458] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[Fri Jan 06 21:00:03.819 2017] [ 10.020599] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[Fri Jan 06 21:00:03.831 2017] [ 10.031463] kjournald starting. Commit interval 5 seconds
[Fri Jan 06 21:00:03.833 2017] [ 10.037231] EXT3-fs (mmcblk0p2): recovery complete
[Fri Jan 06 21:00:03.876 2017] [ 10.072875] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[Fri Jan 06 21:00:03.878 2017] [ 10.080139] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[Fri Jan 06 21:00:03.882 2017] [ 10.090789] devtmpfs: mounted
[Fri Jan 06 21:00:03.887 2017] [ 10.094207] Freeing init memory: 324K
[Fri Jan 06 21:00:04.038 2017] [ 10.243316] EXT3-fs (mmcblk0p2): using internal journal
[Fri Jan 06 21:00:04.149 2017] Starting logging: OK
[Fri Jan 06 21:00:04.200 2017] Populating /dev using udev: [ 10.484558] udevd[751]: starting version 182
[Fri Jan 06 21:00:04.375 2017] done
[Fri Jan 06 21:00:04.404 2017] Initializing random number generator... done.
[Fri Jan 06 21:00:04.709 2017] Starting system message bus: done
[Fri Jan 06 21:00:04.865 2017] Starting network...
[Fri Jan 06 21:00:05.003 2017] Starting connman ... done.
[Fri Jan 06 21:00:05.024 2017] Starting sshd: OK
[Fri Jan 06 21:00:05.308 2017] thttpdStarting input-event-daemon: done
------STOP-----
