DM6446 USB HOST
hi:
      I'm programing on dm6446, this support 4 usb devices, some problem
happied, help.
kernel is : 2.6.10, (and this problem on git kernel-2.6.32 also)
hard desigined:
        CPU connect usbHUB, this HUB connected 4 usb device, (4 HUAWEI EM660)
something happy:
          1. i'm runing 3 device OK only, random. but only 3 device
          2. using the forth device trying, but no response.
  • Danny,
    Pl. enable interrupt endpoint scheduing in the usb menuconfig on 2.6.10 kernel.  It should address your issue.
    regards
    swami
  • swami,  thanks
    this CONFIG_MUSB_SCHEDULE_INTR_EP=y been enabled already.
    if not this, support 1 device only.
    Other :
          drivers/usb/musb/plat_uds.c                        FUNC: mode_4_cfg
          on linux/driver/usb/musb/musb_host.c      FUNC: musb_find_ep(...),
           DM6446  support 4 CPPI channel : 0 1 2 3
    forth channel for resv_rx/tx end, only [ 0 1 2 ] support for different usb device.
    debug this info: when forth device opend, one CPPI channel been repeated, if it's rx_endpoint no data, driver didn't schedule the cppi endpoint to next for receive data.
  • Danny,
    Can you post the output of "lsusb -v" command when you have all the devices connected.  Pl. also evaluate the latest kernel snapshot (July snapshot) of DaVinci kernel from the Arago.  I believe it is on 2.6.34.
    regards
    swami
  • swami
    lsusb -v :
    Bus 001 Device 006: ID 19d2:fffe
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            0 (Defined at Interface level)
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x19d2
      idProduct          0xfffe
      bcdDevice            0.00
      iManufacturer           1 ZTE, Incorporated
      iProduct                2 ZTE CDMA Tech
      iSerial                 0
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength          108
        bNumInterfaces          4
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xa0
          Remote Wakeup
        MaxPower              500mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           3
          bInterfaceClass       255 Vendor Specific Class
          bInterfaceSubClass    255 Vendor Specific Subclass
          bInterfaceProtocol    255 Vendor Specific Protocol
          iInterface              4 Data Interface
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0010  bytes 16 once
            bInterval             128
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  bytes 64 once
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x02  EP 2 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x84  EP 4 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x04  EP 4 OUT
            bmAttributes            2
              Transfer Type            Bulk
             Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x87  EP 7 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x07  EP 7 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x88  EP 8 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x08  EP 8 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    Bus 001 Device 005: ID 19d2:fffe
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x19d2
      idProduct          0xfffe
      bcdDevice            0.00
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength          108
        bNumInterfaces          4
        iConfiguration          0
        bmAttributes         0xa0
          Remote Wakeup
        MaxPower              500mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           3
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             128
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    Bus 001 Device 004: ID 19d2:fffe
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x19d2
      idProduct          0xfffe
      bcdDevice            0.00
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength          108
        bNumInterfaces          4
        iConfiguration          0
        bmAttributes         0xa0
          Remote Wakeup
        MaxPower              500mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           3
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             128
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    Bus 001 Device 003: ID 12d1:1001
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x12d1
      idProduct          0x1001
      bcdDevice            0.00
      iManufacturer           1 HUAÿWEI TECHNOLOGIES
      iProduct                2 HUAWEI Mobile
      iSerial                 4 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
        bLength                 9
        bDescriptorType         2
        wTotalLength           85
        bNumInterfaces          3
        iConfiguration          0
        bmAttributes         0xa0
          Remote Wakeup
        MaxPower              500mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           3
          iInterface              3 Data Interface
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             128
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x86  EP 6 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x06  EP 6 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0 Unused
      bDeviceProtocol         1 Single TT
      bMaxPacketSize0        64
      idVendor           0x05e3 Genesys Logic, Inc.
      idProduct          0x0608
      bcdDevice           77.60
      iManufacturer           0
      iProduct                1 USB2.0 Hub
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         9 Hub
          bInterfaceSubClass      0 Unused
          bInterfaceProtocol      0
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0001  bytes 1 once
            bInterval              12
    Bus 001 Device 001: ID 04d6:0000 Mentor Graphics
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      idVendor           0x04d6 Mentor Graphics
      idProduct          0x0000
      bcdDevice            0.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    pls check it
    regards
    danny
  • Danny,
    You cannot support more than 3 of the mentioned devices.  If you have a high speed version of the devices then you could support more of such devices but since the current device apears to support only full speed operation we cannot support more than 3 such devices on DM6446 platform.
    regards
    swami
  • Hi swami and danny,
     And I met the problem similiar with that,
    My kernel is MVL4.0 Linux 2.6.10,
    my dvsdk is 1.2.0,
    hard desigined:
            CPU connect one usbHUB, this HUB connected 2 usb devices, (2 HUAWEI EM660 also)
    the problem is :
              1. i'm runing 1 device OK only
              2. using 2devices trying, I can dial the two HUAWEI EM660, and I can see the ppp0 and ppp1 using ifconfig, but I can not ping.
    I know that we should patch the kernel, but my kernel is MVL4.0 which is not fit the patch.
    where can I get the kernel patched or the patches and the kernel unpatched?
    So pls help me, I'm in urgent !!!!!!!!!!!!!!!!!!!!!
  • HI,Dane
            no problem on two or three devices.
            you should select:
                      CONFIG_USB_MUSB_HDRC_HCD=y
  • Hi,danny,
    Thanks for your reply very much!!!
    I think you have patched the kernel, and you can see the select option, but there is no select option when I make menuconfig --> device driver --> usb support.
    I think my kernel is too old and there is some problem with my hardware.
    can you send email to me, my email address is benxuelan0402@126.com, I am so urgent about that.
  • Hi Swami,
    What are maximum number of high speed devices can be connected to DM365?
    DS
