I want to send camera related parameters using ethernet to tda2x board.
Are there any Vision SDK examples that show how to send any parameter to TDA2x board using NDK APIs or configuration.
Mayank
Mayank
Mayank,
The use-case Shiju mentioned (network_rx_tx) will let you take data through network for further processing.
If your aim is to use network only for getting initial parameters for camera you can reuse code from Nullsouce link (vision_sdk\src\links_common\nullSrc) which takes commands from PC tool (vision_sdk\tools\network_tools\network_tx) and then takes data. You can integrate this command server in your use case.
