Compiler: enabling cache on DSP
Hello evryone,
I am using TDA 3X version 2.11.
I want to access cache for most frequently Data.
How to enable cache on DSP.
Please guide me and provide the solution for same.
Poonam
  • Hi, Poonam,
    Experts have been notified and will reply here.
    Mariya
  • Hi Poonam,
    You can refer to the implementation of vision_sdk\src\main_app\tda3xx\cfg\DSP_common.cfg.
    The BIOS call of Cache_setSize will set the desired cache size for the L1P, L1D and L2 DSP cache.
    Additionally you would need to set the MAR registers to make a region cacheable. Both these configurations are in the above mentioned cfg file.
    Additionally from code at run time you can set the cache using Utils_dspCacheInit from file vision_sdk\src\utils_common\src\utils_cache_c66x.c
    Hope this helps.
    Piyali
