Other Parts Discussed in Thread: AM5718, DRA722, TLC59108, BEAGLEBOARD-X15
Tool/software: Linux
I am using AM5718 processor with ti-processor-sdk-linux-am57xx-evm-02.00.01.07. I am trying to boot the board from eMMC memory, for which I have partitioned the eMMC memory into two partitions. While booting from eMMC kernel crashes. I am sure it is because of file system related issue , I tried to change in the environment variables also but unable to resolve. Please tell how to solve this?
Kernel Log:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.13-g8dc6617 (medha@medha) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #9 SMP PREEMPT S7
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI AM571x IDK
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 16 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] DRA722 ES1.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @eee47000 s16128 r8192 d20736 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 210514
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID= rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 633872K/848896K available (6263K kernel code, 287K rwdata, 2156K rodata, 328K init, 254K bss, 18416K reserved, 196608K c)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0841074 (8421 kB)
[ 0.000000] .init : 0xc0842000 - 0xc0894000 ( 328 kB)
[ 0.000000] .data : 0xc0894000 - 0xc08dbc48 ( 288 kB)
[ 0.000000] .bss : 0xc08de000 - 0xc091d80c ( 255 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer1 at 32768 Hz
[ 0.000000] clocksource 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000396] Architected cp15 timer(s) running at 6.14MHz (virt).
[ 0.000396] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000431] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000441] Switching to timer-based delay loop, resolution 162ns
[ 0.000943] Console: colour dummy device 80x30
[ 0.000958] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000964] This ensures that you still see kernel messages. Please
[ 0.000969] update your kernel commandline.
[ 0.000981] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000992] pid_max: default: 32768 minimum: 301
[ 0.001077] Security Framework initialized
[ 0.001113] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001123] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001645] Initializing cgroup subsys blkio
[ 0.001659] Initializing cgroup subsys memory
[ 0.001684] Initializing cgroup subsys devices
[ 0.001696] Initializing cgroup subsys freezer
[ 0.001708] Initializing cgroup subsys perf_event
[ 0.001730] CPU: Testing write buffer coherency: ok
[ 0.001982] /cpus/cpu@0 missing clock-frequency property
[ 0.001995] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002027] Setting up static identity map for 0x80008380 - 0x800083d8
[ 0.040712] Brought up 1 CPUs
[ 0.040722] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.040729] CPU: All CPU(s) started in SVC mode.
[ 0.041078] devtmpfs: initialized
[ 0.064129] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.064921] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.077719] omap_hwmod: tptc0 using broken dt data from edma-controller
[ 0.078167] omap_hwmod: tptc1 using broken dt data from edma-controller
[ 0.151393] omap_hwmod: dcan2: _wait_target_disable failed
[ 0.245041] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.249170] pinctrl core: initialized pinctrl subsystem
[ 0.249972] NET: Registered protocol family 16
[ 0.250957] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.258940] OMAP GPIO hardware version 0.1
[ 0.265365] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.282944] No ATAGs?
[ 0.282968] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.282977] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.285387] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.285398] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.285958] OMAP DMA hardware revision 0.0
[ 0.327883] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.330558] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[ 0.334914] ------------[ cut here ]------------
[ 0.334936] WARNING: CPU: 0 PID: 1 at drivers/iommu/omap-iommu.c:1433 omap_iommu_add_device+0xd0/0x108()
[ 0.334943] Modules linked in:
[ 0.334957] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.13-g8dc6617 #9
[ 0.334964] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 0.334970] Backtrace:
[ 0.334991] [<c0013018>] (dump_backtrace) from [<c001323c>] (show_stack+0x18/0x1c)
[ 0.334998] r7:c03b8d5c r6:00000599 r5:c08b390c r4:00000000
[ 0.335024] [<c0013224>] (show_stack) from [<c061d0dc>] (dump_stack+0x9c/0xdc)
[ 0.335037] [<c061d040>] (dump_stack) from [<c0039748>] (warn_slowpath_common+0x88/0xb8)
[ 0.335042] r5:00000009 r4:00000000
[ 0.335059] [<c00396c0>] (warn_slowpath_common) from [<c003981c>] (warn_slowpath_null+0x24/0x2c)
[ 0.335064] r8:00000002 r7:ffffffea r6:eea15c80 r5:eea15c80 r4:00000000
[ 0.335090] [<c00397f8>] (warn_slowpath_null) from [<c03b8d5c>] (omap_iommu_add_device+0xd0/0x108)
[ 0.335103] [<c03b8c8c>] (omap_iommu_add_device) from [<c03b7360>] (add_iommu_group+0x34/0x54)
[ 0.335108] r9:c08425ec r8:c088ead0 r7:eea15b40 r6:c03b732c r5:c0668ee0 r4:ee9a2210
[ 0.335137] [<c03b732c>] (add_iommu_group) from [<c03ff090>] (bus_for_each_dev+0x70/0xa4)
[ 0.335142] r5:ee87fe94 r4:00000000
[ 0.335159] [<c03ff020>] (bus_for_each_dev) from [<c03b7a80>] (bus_set_iommu+0x84/0xc8)
[ 0.335165] r6:eea15b40 r5:00000000 r4:c08c1ab0
[ 0.335183] [<c03b79fc>] (bus_set_iommu) from [<c086ae9c>] (omap_iommu_init+0x78/0x98)
[ 0.335189] r6:c0899130 r5:c086ae24 r4:c0899130
[ 0.335206] [<c086ae24>] (omap_iommu_init) from [<c0009848>] (do_one_initcall+0x94/0x1e0)
[ 0.335218] [<c00097b4>] (do_one_initcall) from [<c0842f28>] (kernel_init_freeable+0x1d0/0x274)
[ 0.335224] r10:c088233c r9:c08425ec r8:c088ead0 r7:c08de000 r6:c08de000 r5:c088232c
[ 0.335244] r4:00000004
[ 0.335258] [<c0842d58>] (kernel_init_freeable) from [<c0619778>] (kernel_init+0x18/0xf0)
[ 0.335263] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0619760
[ 0.335283] r4:c08de000
[ 0.335296] [<c0619760>] (kernel_init) from [<c000faa8>] (ret_from_fork+0x14/0x2c)
[ 0.335301] r5:c0619760 r4:00000000
[ 0.335322] ---[ end trace e28f400cdfe8c690 ]---
[ 0.335808] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.335972] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.336122] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.336390] vgaarb: loaded
[ 0.336738] SCSI subsystem initialized
[ 0.337836] palmas 0-0058: Irq flag is 0x00000000
[ 1.351507] omap_i2c 48070000.i2c: timeout waiting for bus ready
[ 1.351521] palmas 0-0058: POLARITY_CTRL updat failed: -110
[ 1.351827] palmas: probe of 0-0058 failed with error -110
[ 1.351949] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.352113] media: Linux media interface: v0.10
[ 1.352167] Linux video capture interface: v2.00
[ 1.352208] pps_core: LinuxPPS API ver. 1 registered
[ 1.352215] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.352240] PTP clock support registered
[ 1.352846] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[ 1.353128] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[ 1.353409] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 1.353476] omap-mailbox: probe of 48842000.mailbox failed with error -22
[ 1.353697] Advanced Linux Sound Architecture Driver Initialized.
[ 1.354306] Switched to clocksource arch_sys_counter
[ 1.363856] NET: Registered protocol family 2
[ 1.364442] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.364506] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.364631] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.364682] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.364714] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.364905] NET: Registered protocol family 1
[ 1.365145] RPC: Registered named UNIX socket transport module.
[ 1.365154] RPC: Registered udp transport module.
[ 1.365161] RPC: Registered tcp transport module.
[ 1.365167] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.366098] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[ 1.366126] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 1.367991] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 1.368062] audit: initializing netlink subsys (disabled)
[ 1.368099] audit: type=2000 audit(1.350:1): initialized
[ 1.375198] VFS: Disk quotas dquot_6.6.0
[ 1.375352] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.377298] NFS: Registering the id_resolver key type
[ 1.377331] Key type id_resolver registered
[ 1.377338] Key type id_legacy registered
[ 1.377396] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 1.379740] NET: Registered protocol family 38
[ 1.379817] bounce: pool size: 64 pages
[ 1.379830] io scheduler noop registered
[ 1.379843] io scheduler deadline registered
[ 1.379881] io scheduler cfq registered (default)
[ 1.383333] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[ 1.383450] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 1.416545] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.416558] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.416568] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.416579] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.416698] pci 0000:00:00.0: IOMMU is currently not supported for PCI
[ 1.416968] PCI: bus0: Fast back to back transfers disabled
[ 1.417089] PCI: bus1: Fast back to back transfers enabled
[ 1.417182] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 1.417196] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 1.417208] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.418908] omapdss_dss 58000000.dss: master bind failed: -517
[ 1.420767] tlc59108 0-0040: failed to find video source
[ 1.423248] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.426196] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
[ 2.578047] console [ttyS0] enabled
[ 2.582191] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 300, base_baud = 3000000) is a 8250
[ 2.592037] [drm] Initialized drm 1.1.0 20060810
[ 2.604953] brd: module loaded
[ 2.612028] loop: module loaded
[ 2.616104] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.674324] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 2.680449] davinci_mdio 48485000.mdio: detected phy mask fffffdff
[ 2.688963] libphy: 48485000.mdio: probed
[ 2.692995] davinci_mdio 48485000.mdio: phy[9]: device 48485000.mdio:09, driver unknown
[ 2.701667] cpsw 48484000.ethernet: Detected MACID = 74:da:ea:0c:dc:a2
[ 2.708993] cpsw 48484000.ethernet: cpsw: Detected MACID = 74:da:ea:0c:dc:a3
[ 2.717330] mousedev: PS/2 mouse device common for all mice
[ 2.722980] i2c /dev entries driver
[ 2.728498] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 2.733359] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 2.739887] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 2.746305] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 2.752686] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 2.759083] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 2.765477] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 2.804962] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.812404] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.820833] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[ 2.827540] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[ 2.864578] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.870958] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 2.880616] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 2.886964] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 2.893848] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 2.904009] oprofile: using timer interrupt.
[ 2.910641] Initializing XFRM netlink socket
[ 2.915035] NET: Registered protocol family 17
[ 2.919525] NET: Registered protocol family 15
[ 2.924063] Key type dns_resolver registered
[ 2.928569] omap_voltage_late_init: Voltage driver support not added
[ 2.935284] Power Management for TI OMAP4+ devices.
[ 2.940429] ThumbEE CPU extension supported.
[ 2.944803] Registering SWP/SWPB emulation handler
[ 2.951146] dmm 4e000000.dmm: workaround for errata i878 in use
[ 2.958662] dmm 4e000000.dmm: initialized all PAT entries
[ 2.964115] mmc1: MAN_BKOPS_EN bit is not set
[ 2.969293] omapdss_dss 58000000.dss: master bind failed: -517
[ 2.975243] mmc1: new MMC card at address 0001
[ 2.980037] mmcblk0: mmc1:0001 MMC04G 3.60 GiB
[ 2.984884] tlc59108 0-0040: failed to find video source
[ 2.990549] hctosys: unable to open rtc device (rtc0)
[ 2.995767] mmcblk0boot0: mmc1:0001 MMC04G partition 1 16.0 MiB
[ 3.013375] vdd_3v3: disabling
[ 3.016540] mmcblk0boot1: mmc1:0001 MMC04G partition 2 16.0 MiB
[ 3.023190] ALSA device list:
[ 3.026271] mmcblk0: p1 p2
[ 3.029382] No soundcards found.
[ 3.034450] omapdss_dss 58000000.dss: master bind failed: -517
[ 3.040595] tlc59108 0-0040: failed to find video source
[ 3.046139] VFS: PARTUUID= is invalid.
[ 3.046139] Expected PARTUUID=<valid-uuid-id>[/PARTNROFF=%d]
[ 3.055742] Disabling rootwait; root= is invalid.
[ 3.060624] VFS: Cannot open root device "PARTUUID=" or unknown-block(0,0): error -6
[ 3.068478] Please append a correct "root=" boot option; here are the available partitions:
[ 3.076913] 0100 8096 ram0 (driver?)
[ 3.081561] 0101 8096 ram1 (driver?)
[ 3.086249] 0102 8096 ram2 (driver?)
[ 3.090897] 0103 8096 ram3 (driver?)
[ 3.095579] 0104 8096 ram4 (driver?)
[ 3.100227] 0105 8096 ram5 (driver?)
[ 3.104887] 0106 8096 ram6 (driver?)
[ 3.109534] 0107 8096 ram7 (driver?)
[ 3.114181] 0108 8096 ram8 (driver?)
[ 3.118841] 0109 8096 ram9 (driver?)
[ 3.123487] 010a 8096 ram10 (driver?)
[ 3.128234] 010b 8096 ram11 (driver?)
[ 3.132967] 010c 8096 ram12 (driver?)
[ 3.137714] 010d 8096 ram13 (driver?)
[ 3.142448] 010e 8096 ram14 (driver?)
[ 3.147230] 010f 8096 ram15 (driver?)
[ 3.151965] b300 3776512 mmcblk0 driver: mmcblk
[ 3.157326] b301 71680 mmcblk0p1 b670dcf6-01
[ 3.162670] b302 3687424 mmcblk0p2 b670dcf6-02
[ 3.168029] b310 16384 mmcblk0boot1 (driver?)
[ 3.173373] b308 16384 mmcblk0boot0 (driver?)
[ 3.178731] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 3.187036] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Environment variables are:
EXPORT table = bff9fce4, htab.size = 521, htab.filled = 61, size = 0
arch=arm
args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
baudrate=115200
board=BeagleBoard-X15
board-name=am57xx-evm
board_name=BeagleBoard-X15
bootargs=console=ttyO0,115200n8 elevator=noop root=/dev/mmcblk0p2 rw rootwait
bootcmd=if test ${dofastboot} -eq 1; then echo Boot fastboot requested, resetting dofastboot ...;setenv dofastboot 0; saveenv;echo Booting into;
bootdelay=1
bootdir=/boot
bootenv=uEnv.txt
bootfile=zImage
bootm_size=0x10000000
bootpart=0:2
bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
cpu=armv7
dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os1
dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os-args.raw raw 0x80 0x801
dfu_alt_info_ram=kernel ram 0x80200000 0x4000000;fdt ram 0x80f80000 0x80000;ramdisk ram 0x81000000 0x4000000
dfu_bufsiz=0x10000
dofastboot=0
eth1addr=74:da:ea:0c:dc:a3
ethact=cpsw
ethaddr=74:da:ea:0c:dc:a2
fdt_addr_r=0x88000000
fdtaddr=0x88000000
fdtfile=am57xx-beagle-x15.dtb
filesize=17783
findfdt=if test $board_name = omap5_uevm; then setenv fdtfile omap5-uevm.dtb; fi; if test $board_name = dra7xx; then setenv fdtfile dra7-evm.dt
finduuid=part uuid mmc 0:2 uuid
importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
kernel_addr_r=0x82000000
loadaddr=0x82000000
loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}
loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr
loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};
loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
mmcargs=part uuid mmc 0:2 uuid
mmcboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${bo;
mmcdev=0
mmcrootfstype=ext4 rootwait
netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
netboot=echo Booting from network ...; setenv autoload no; dhcp; run netloadimage; run netloadfdt; run netargs; bootz ${loadaddr} - ${fdtaddr}
netloadfdt=tftp ${fdtaddr} ${fdtfile}
netloadimage=tftp ${loadaddr} ${bootfile}
nfsopts=nolock
partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}
ramdisk_addr_r=0x88080000
rdaddr=0x88080000
rootpath=/export/rootfs
scsidevs=0
soc=omap5
static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
stderr=serial
stdin=serial
stdout=serial
usbtty=cdc_acm
vendor=ti
ver=U-Boot 2015.07-00080-g4523775-dirty (Jan 31 2017 - 18:16:54 +0530)
vram=16M
Environment size: 3731/65532 bytes
Ganesh
