CCS: Exception call stack <symbol is not available>
I'm trying to determine the cause of an exception. I have a breakpoint set in my handler exception hook, which receives the Hwi_ExcContext pointer. Unfortunately, when I read the Hwi module, the Exception call stack shows the very unhelpful message of "<symbol is not available>"
What is the solution here? I do not have a stack overflow.
The issue I'm having is exactly the same as found here: e2e.ti.com/.../2094531
Sadly, the linked thread's solution is not helpful. It simply points to a wiki which describes how to use outdated software.
  • Hi Matthew,
    I see that you have posted in the TI-RTOS forum. Did you create a new thread there as Todd requested? The folks in that forum can help you best.
    ki
  • I created the new thread here, in the CCS forum, as this is an issue I'm having with CCS. Is this the incorrect forum? Can you please just help me answer the question?
  • CCS is the debugger being used but the issue appears to be specific to TI-RTOS. There is a dedicated forum for TI-RTOS. I see that you had replied to an existing thread there. I will move this thread to that forum.
    ki
  • Matthew,
    Debugging exceptions is a challenge on a good day. But the Hwi exception dump is your best tool in these situations. As detailed in the FAQ below, your first step is to take the PC, SP, and LR register values from the dump and put them into their respective registers in the CCS Register View. Hopefully, this will recreate a useful call stack.
    Exception Dump Decoding Using the CCS Register View
    If this does not yield a useful call stack, then your next step is to rebuild the TI-RTOS kernel with debug profile. Look in your program cfg file and change the BIOS library type to debug.
    var BIOS = xdc.useModule('ti.sysbios.BIOS');
    BIOS.libType = BIOS.LibType_Debug;
    What device are you using?
    What software release are you using?
    ~Ramsey
