Linux/AM5728: GP EVM audio input
Part Number: AM5728
Other Parts Discussed in Thread: BEAGLEBOARD-X15, TLV320AIC3104
Tool/software: Linux
Hi :
 I'm trying to use command arecord to record audio on AM572x GP EVM , but failed.
Same as the following links:
http://e2e.ti.com/support/arm/sitara_arm/f/791/p/515977/1879359
Whether the problem has been resolved?
  • The software team have been notified. They will respond here.
    Have you enabled the mic prior to running the arecord command? You should execute something like the bellow commands:
    amixer sset 'Right PGA Mixer Mic3L' on
    amixer sset 'Right PGA Mixer Mic3R' on
    amixer sset 'Left PGA Mixer Mic3L' on
    amixer sset 'Left PGA Mixer Mic3R' on
    Yordan
  • I've tried this method.The results are as follows:
    root@am57xx-evm:~# amixer sset 'Left PGA Mixer Mic3L' on
    amixer: Unable to find simple control 'Left PGA Mixer Mic3L',0
    The device tree configuration as follows:
    sound0: sound@0 {
    compatible = "simple-audio-card";
    simple-audio-card,name = "BeagleBoard-X15";
    simple-audio-card,widgets =
    "Line", "Line Out",
    "Line", "Line In";
    simple-audio-card,routing =
    "Line Out", "LLOUT",
    "Line Out", "RLOUT",
    "MIC2L", "Line In",
    "MIC2R", "Line In";
    /delete-property/The defination of DAI link
    simple-audio-card,format = "dsp_b";
    simple-audio-card,bitclock-master = <&sound0_master>;
    simple-audio-card,frame-master = <&sound0_master>;
    simple-audio-card,bitclock-inversion;
    simple-audio-card,cpu {
    sound-dai = <&mcasp3>;
    sound0_master: simple-audio-card,codec {
    sound-dai = <&tlv320aic3104>;
    clocks = <&clkout2_clk>;
    So I tried as  as follows:
    root@am57xx-evm:~# amixer sset 'Left PGA Mixer Mic2R' on
    Simple mixer control 'Left PGA Mixer Mic2R',0
    Capabilities: pswitch pswitch-joined
    Playback channels: Mono
    Mono: Playback [on]\
    But the recording is still failing
  • So I tried as as follows:
    amixer sset 'Right PGA Mixer Mic2L' on
    amixer sset 'Right PGA Mixer Mic2R' on
    amixer sset 'Left PGA Mixer Mic2L' on
    Does your aplay -l or cat /proc/asound detect your sound card? If yes, then I think this is an alsa configuration issue..
    Try turning off line in & turning on the MIC, something like:
    processors.wiki.ti.com/.../DRA7xx_GLSDK_Software_Developers_Guide
    Yordan
  • root@am57xx-evm:~# aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: BeagleBoardX15 [BeagleBoard-X15], device 0: davinci-mcasp.0-tlv320aic3x-hifi tlv320aic3x-hifi-0 []
    Subdevices: 1/1
    Subdevice #0: subdevice #0
    card 1: H58040000encode [HDMI 58040000.encoder], device 0: HDMI 58040000.encoder snd-soc-dummy-dai-0 []
    Subdevices: 1/1
    I have tried many times as the link. All the results failed
    I am facing the same issue. Please help.
    Prav
