Other Parts Discussed in Thread: CCSTUDIO
My customer wants to use MT29F4G08ABAEAWP from Micron, but failed to boot from it. This nand is ONFI compliant. From DM814x TRM, it says that for NAND boot, the rom code will send ONFI Read ID first to check if it an ONFI nand, if it is, it will use the ONFI info. If the ONFI Read ID command fails, it will check if the nand is in the support nand list or not.
Would you pls help to double confirm the flow, that is, the rom will check ONFI info first? MT29F4G08ABAEAWP's id is in the support nand list, but the page size is not match. I am suspecting this cause the problem. But as our rom will check ONFI info first as TRM mentioned, I can't find out why the boot failed.
Do you have any other suggestion on this boot fail issue? Any comment is welcome!
