Other Parts Discussed in Thread: CC1310
Tool/software: TI-RTOS
CC1310 driver library documentation says we can use the function called void SysCtrlStandby() to put CC1310 to low power mode. But there is no function like this. I am using tirtos_cc13xx_cc26xx_2_21_00_06.
Here is sys_ctrl.h file for tirtos_cc13xx_cc26xx_2_21_00_06
* Filename: sys_ctrl.h
* Revised: 2016-07-07 19:12:02 +0200 (Thu, 07 Jul 2016)
* Revision: 46848
* Description: Defines and prototypes for the System Controller.
* Copyright (c) 2015 - 2016, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1) Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2) Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3) Neither the name of the ORGANIZATION nor the names of its contributors may
* be used to endorse or promote products derived from this software without
* specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
//! \addtogroup system_control_group
//! \addtogroup sysctrl_api
#ifndef __SYSCTRL_H__
#define __SYSCTRL_H__
// If building with a C++ compiler, make all of the definitions in this header
// have a C binding.
#ifdef __cplusplus
extern "C"
#endif
#include <stdbool.h>
#include <stdint.h>
#include <inc/hw_types.h>
#include <inc/hw_memmap.h>
#include <inc/hw_ints.h>
#include <inc/hw_sysctl.h>
#include <inc/hw_prcm.h>
#include <inc/hw_nvic.h>
#include <inc/hw_aon_wuc.h>
#include <inc/hw_aux_wuc.h>
#include <inc/hw_aon_ioc.h>
#include <inc/hw_ddi_0_osc.h>
#include <inc/hw_rfc_pwr.h>
#include <inc/hw_adi_3_refsys.h>
#include <inc/hw_aon_sysctl.h>
#include <inc/hw_aon_rtc.h>
#include <inc/hw_fcfg1.h>
#include <driverlib/interrupt.h>
#include <driverlib/debug.h>
#include <driverlib/pwr_ctrl.h>
#include <driverlib/osc.h>
#include <driverlib/prcm.h>
#include <driverlib/aux_wuc.h>
#include <driverlib/aon_wuc.h>
#include <driverlib/adi.h>
#include <driverlib/ddi.h>
#include <driverlib/cpu.h>
#include <driverlib/vims.h>
// Support for DriverLib in ROM:
// This section renames all functions that are not "static inline", so that
// calling these functions will default to implementation in flash. At the end
// of this file a second renaming will change the defaults to implementation in
// ROM for available functions.
// To force use of the implementation in flash, e.g. for debugging:
// - Globally: Define DRIVERLIB_NOROM at project level
// - Per function: Use prefix "NOROM_" when calling the function
#if !defined(DOXYGEN)
#define SysCtrlPowerEverything NOROM_SysCtrlPowerEverything
#define SysCtrlSetRechargeBeforePowerDown NOROM_SysCtrlSetRechargeBeforePowerDown
#define SysCtrlAdjustRechargeAfterPowerDown NOROM_SysCtrlAdjustRechargeAfterPowerDown
#define SysCtrl_DCDC_VoltageConditionalControl NOROM_SysCtrl_DCDC_VoltageConditionalControl
#define SysCtrlResetSourceGet NOROM_SysCtrlResetSourceGet
#endif
// Defines for the settings of the main XOSC
#define SYSCTRL_SYSBUS_ON 0x00000001
#define SYSCTRL_SYSBUS_OFF 0x00000000
// Defines for the different power modes of the System CPU
#define CPU_RUN 0x00000000
#define CPU_SLEEP 0x00000001
#define CPU_DEEP_SLEEP 0x00000002
// Defines for SysCtrlSetRechargeBeforePowerDown
#define XOSC_IN_HIGH_POWER_MODE 0 // When xosc_hf is in HIGH_POWER_XOSC
#define XOSC_IN_LOW_POWER_MODE 1 // When xosc_hf is in LOW_POWER_XOSC
// API Functions and prototypes
//! \brief Power up everything.
//! \note The sequencing in this function is not necessarily how you would
//! want to sequence active mode in a real application. There might be
//! application specific prerequisites or hardware restrictions you would want
//! to consider which deviate from this specific implementation.
//! \note This function might be deprecated in future releases
//! \return None
extern void SysCtrlPowerEverything(void);
//! \brief Get the CPU core clock frequency.
//! Use this function to get the current clock frequency for the CPU.
//! The CPU can run from 48 MHz and down to 750kHz. The frequency is defined
//! by the combined division factor of the SYSBUS and the CPU clock divider.
//! \return Returns the current CPU core clock frequency.
__STATIC_INLINE uint32_t
SysCtrlClockGet( void )
// Return fixed clock speed
return( GET_MCU_CLOCK );
//! \brief Sync all accesses to the AON register interface.
//! When this function returns, all writes to the AON register interface are
//! guaranteed to have propagated to hardware. The function will return
//! immediately if no AON writes are pending; otherwise, it will wait for the next
//! AON clock before returning.
//! \return None
//! \sa \ref SysCtrlAonUpdate()
__STATIC_INLINE void
SysCtrlAonSync(void)
// Sync the AON interface
HWREG(AON_RTC_BASE + AON_RTC_O_SYNC);
//! \brief Update all interfaces to AON.
//! When this function returns, at least 1 clock cycle has progressed on the
//! AON domain, so that any outstanding updates to and from the AON interface
//! is guaranteed to be in sync.
//! \note This function should primarily be used after wakeup from sleep modes,
//! as it will guarantee that all shadow registers on the AON interface are updated
//! before reading any AON registers from the MCU domain. If a write has been
//! done to the AON interface it is sufficient to call the \ref SysCtrlAonSync().
//! \return None
//! \sa \ref SysCtrlAonSync()
SysCtrlAonUpdate(void)
// Force a clock cycle on the AON interface to guarantee all registers are
// in sync.
HWREG(AON_RTC_BASE + AON_RTC_O_SYNC) = 1;
//! \brief Set Recharge values before entering Power Down.
//! This function shall be called just before entering Power Down.
//! It calculates an optimal and safe recharge setting of the adaptive recharge
//! controller. The results of previous setting are also taken into account.
//! \note In order to make sure that the register writes are completed, \ref SysCtrlAonSync()
//! must be called before entering standby/power down. This is not done internally
//! in this function due to two reasons:
//! - 1) There might be other register writes that must be synchronized as well.
//! - 2) It is possible to save some time by doing other things before calling
//! \ref SysCtrlAonSync() since this call will not return before there are no
//! outstanding write requests between MCU and AON.
//! \param xoscPowerMode (typically running in XOSC_IN_HIGH_POWER_MODE all the time).
//! - \ref XOSC_IN_HIGH_POWER_MODE : When xosc_hf is in HIGH_POWER_XOSC.
//! - \ref XOSC_IN_LOW_POWER_MODE : When xosc_hf is in LOW_POWER_XOSC.
//! \return None
extern void SysCtrlSetRechargeBeforePowerDown( uint32_t xoscPowerMode );
//! \brief Adjust Recharge calculations to be used next.
//! This function shall be called just after returning from Power Down.
//! Reads the results from the adaptive recharge controller and current chip
//! temperature. This is used as additional information when calculating
//! optimal recharge controller settings next time (When
//! \ref SysCtrlSetRechargeBeforePowerDown() is called next time).
//! \note
//! Special care must be taken to make sure that the AON registers read are
//! updated after the wakeup. Writing to an AON register and then calling
//! \ref SysCtrlAonSync() will handle this.
//! \return None
extern void SysCtrlAdjustRechargeAfterPowerDown( void );
//! \brief Turns DCDC on or off depending of what is considered to be optimal usage.
//! This function controls the DCDC only if both the following CCFG settings are \c true:
//! - DCDC is configured to be used.
//! - Alternative DCDC settings are defined and enabled.
//! The DCDC is configured in accordance to the CCFG settings when turned on.
//! This function should be called periodically.
//! \return None
extern void SysCtrl_DCDC_VoltageConditionalControl( void );
// \name Return values from calling SysCtrlResetSourceGet()
#define RSTSRC_PWR_ON (( AON_SYSCTL_RESETCTL_RESET_SRC_PWR_ON ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_PIN_RESET (( AON_SYSCTL_RESETCTL_RESET_SRC_PIN_RESET ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_VDDS_LOSS (( AON_SYSCTL_RESETCTL_RESET_SRC_VDDS_LOSS ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_VDD_LOSS (( AON_SYSCTL_RESETCTL_RESET_SRC_VDD_LOSS ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_VDDR_LOSS (( AON_SYSCTL_RESETCTL_RESET_SRC_VDDR_LOSS ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_CLK_LOSS (( AON_SYSCTL_RESETCTL_RESET_SRC_CLK_LOSS ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_SYSRESET (( AON_SYSCTL_RESETCTL_RESET_SRC_SYSRESET ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_WARMRESET (( AON_SYSCTL_RESETCTL_RESET_SRC_WARMRESET ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S ))
#define RSTSRC_WAKEUP_FROM_SHUTDOWN ((( AON_SYSCTL_RESETCTL_RESET_SRC_M ) >> ( AON_SYSCTL_RESETCTL_RESET_SRC_S )) + 1 )
//! \brief Returns last reset source (including "wakeup from shutdown").
//! \return Returns one of the RSTSRC_ defines.
extern uint32_t SysCtrlResetSourceGet( void );
//! \brief Perform a full system reset.
//! \return The chip will reset and hence never return from this call.
SysCtrlSystemReset( void )
// Disable CPU interrupts
CPUcpsid();
// Write reset register
HWREGBITW( AON_SYSCTL_BASE + AON_SYSCTL_O_RESETCTL, AON_SYSCTL_RESETCTL_SYSRESET_BITN ) = 1;
// Finally, wait until the above write propagates
while ( 1 ) {
// Do nothing, just wait for the reset (and never return from here)
//! \brief Enables reset if OSC clock loss event is asserted.
//! Clock loss circuit in analog domain must be enabled as well in order to
//! actually enable for a clock loss reset to occur
//! \ref OSCClockLossEventEnable().
//! \note This function shall typically not be called because the clock loss
//! reset functionality is controlled by the boot code (a factory configuration
//! defines whether it is set or not).
//! \return None
//! \sa \ref SysCtrlClockLossResetDisable(), \ref OSCClockLossEventEnable()
SysCtrlClockLossResetEnable(void)
// Set clock loss enable bit in AON_SYSCTRL using bit banding
HWREGBITW(AON_SYSCTL_BASE + AON_SYSCTL_O_RESETCTL, AON_SYSCTL_RESETCTL_CLK_LOSS_EN_BITN) = 1;
//! \brief Disables reset due to OSC clock loss event.
//! \return None
//! \sa \ref SysCtrlClockLossResetEnable()
SysCtrlClockLossResetDisable(void)
// Clear clock loss enable bit in AON_SYSCTRL using bit banding
HWREGBITW(AON_SYSCTL_BASE + AON_SYSCTL_O_RESETCTL, AON_SYSCTL_RESETCTL_CLK_LOSS_EN_BITN) = 0;
// Redirect to implementation in ROM when available.
#if !defined(DRIVERLIB_NOROM) && !defined(DOXYGEN)
#include <driverlib/rom.h>
#ifdef ROM_SysCtrlPowerEverything
#undef SysCtrlPowerEverything
#define SysCtrlPowerEverything ROM_SysCtrlPowerEverything
#endif
#ifdef ROM_SysCtrlSetRechargeBeforePowerDown
#undef SysCtrlSetRechargeBeforePowerDown
#define SysCtrlSetRechargeBeforePowerDown ROM_SysCtrlSetRechargeBeforePowerDown
#endif
#ifdef ROM_SysCtrlAdjustRechargeAfterPowerDown
#undef SysCtrlAdjustRechargeAfterPowerDown
#define SysCtrlAdjustRechargeAfterPowerDown ROM_SysCtrlAdjustRechargeAfterPowerDown
#endif
#ifdef ROM_SysCtrl_DCDC_VoltageConditionalControl
#undef SysCtrl_DCDC_VoltageConditionalControl
#define SysCtrl_DCDC_VoltageConditionalControl ROM_SysCtrl_DCDC_VoltageConditionalControl
#endif
#ifdef ROM_SysCtrlResetSourceGet
#undef SysCtrlResetSourceGet
#define SysCtrlResetSourceGet ROM_SysCtrlResetSourceGet
#endif
#endif
// Mark the end of the C bindings section for C++ compilers.
#ifdef __cplusplus
#endif
#endif // __SYSCTRL_H__
//! Close the Doxygen group.
Can anyone help me how to put cc1310 standby mode using new TI-RTOS. Thank you.
