DM6467 VPIF : Max input size
Other Parts Discussed in Thread: TMS320DM6467
I have reviewed TMS320DM6467 for 5M pixel image processing.
The functional features of the VPIF are:
           - ITU-BT.656 format is supported.
           - ITU-BT.1120(1125/60/2:1, 1250/50/2:1, and 1080-30p) and SMPTE 296 formats are supported.
           - Raw data capturing function(receiver only; 8/10/12-bit format) is supported.
             Maximum screen size with valid pixel is 2048(H) X 1536(V) in frame format.
The following functions are not supported
           - ITU-BT601 format
           - Serparted synchronization format (which needs vertical and horizontal synchronization signal and field ID
            signal in independenced to pixel data) is not supported (except in case of raw data capturing mode).
1.At VSYNC HSYNC embedded synchronization interface, is Maximum pixel clock speed of VPIF 150Mhz?(DM6467-1G)
  At VSYNC HSYNC embedded synchronization interface, is Maxnmum image size of VPIF 8K X 4K pixel ?(DM6467-1G)
2.At VSYNC HSYNC seperated synchronization interface, Maximum pixel clock speed of VPIF 150Mhz?(DM6467-1G)
  At VSYNC HSYNC seperated synchronization interface, Maxnmum image size of VPIF 8K X 4K pixel ?(DM6467-1G)
3.What is the specific meaning of RAW Data?
4.At Raw Data Cature mode, Can’t VPIF support seperated synchronization interface(YCbCr 4:2:2)?
  • First, let me point out the major differences between these two modes.
    BT.656 (for NTSC/PAL) and BT.1120 (for 720p/1080i) are video industry standards for passing embedded syncs in the data bus along with video data; therefore, separate pins for the sync signals are not applicable.
    In RAW data capture mode, DM6467 basically captures whatever data (pixel format can be RGB, YCbCr, or anything else) is in the data bus into DDR2.  Since it is not a BT.xxx standard, it will need separate sync pins to tell it where a video line (hsync) begins and where a new video frame (vsync) begins.  However, please note that in this mode you are limited to 12-bit data bus; therefore if you need to send 16-bit YCbCr 422 pixels, but you can do 8-bit or 10-bit YCbCr 422 pixels (such is the case in BT.656 mode).
    In both you maximum pixel clock is 150MHz, and your max resolution is 2048x1536.  Although, BT.xxx standards have a required pixel clock and hence max of 150 MHz only serves to ensure BT.xxx requirement is lower than this maximum.
  • Thank you.
    1.In Raw data capture mode, Is it impossible that DM6467 captures YCbCr 4:2:2 format(2,592H x 1,944V resolution ) to DDR2?
    2. In embedded syncs mode , I Know that VPIF input 8K(H) X 4K(V) rosolution YCbCr Data.   Isn't It?
  • Ok, after digging a little further, it appears that for RAW mode we only validated the silicon for 2048x1536, therefore, even though it is possible to program 8k x 4k in the corresponding registers, this has not been tested and we cannot support it.  It may work, but at this point spec is violated and we cannot recommend nor support this approach.
  • Has anyone tried an image above 2048x1536?
