Part Number: AM5728
Tool/software: Linux
I've plugged my SSD to the am5728 EVM, and there is no any block devices after Linux booting. I've checked inserted modules and found, that sata_ti.ko module absent and there is no any parameter in menuconfig for it.
How can I fix this problem?
I'm attaching my dmesg and lsmod logs.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.32-gadde2ca9f8 (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Wed Dec 14 19:14:12 EST 2016
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI AM572x EVM Rev A3
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[ 0.000000] On node 0 totalpages: 474368
[ 0.000000] free_area_init_node: node 0, pgdat c098b800, node_mem_map eeda2000
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 147456 pages, LIFO batch:31
[ 0.000000] HighMem zone: 326912 pages, LIFO batch:31
[ 0.000000] DRA752 ES2.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @eed2f000 s14848 r8192 d22016 u45056
[ 0.000000] pcpu-alloc: s14848 r8192 d22016 u45056 alloc=11*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 472640
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=00000000-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1680564K/1897472K available (6579K kernel code, 360K rwdata, 2476K rodata, 332K init, 289K bss, 28492K reserved, 188416K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc08e0044 (9057 kB)
.init : 0xc08e1000 - 0xc0934000 ( 332 kB)
.data : 0xc0934000 - 0xc098e2f0 ( 361 kB)
.bss : 0xc0990000 - 0xc09d86c0 ( 290 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000015] Switching to timer-based delay loop, resolution 162ns
[ 0.000330] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000338] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000764] Console: colour dummy device 80x30
[ 0.000780] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000787] This ensures that you still see kernel messages. Please
[ 0.000792] update your kernel commandline.
[ 0.000805] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000818] pid_max: default: 32768 minimum: 301
[ 0.000910] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000919] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001453] Initializing cgroup subsys io
[ 0.001469] Initializing cgroup subsys memory
[ 0.001491] Initializing cgroup subsys devices
[ 0.001503] Initializing cgroup subsys freezer
[ 0.001514] Initializing cgroup subsys perf_event
[ 0.001525] Initializing cgroup subsys pids
[ 0.001550] CPU: Testing write buffer coherency: ok
[ 0.001746] /cpus/cpu@0 missing clock-frequency property
[ 0.001762] /cpus/cpu@1 missing clock-frequency property
[ 0.001773] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001811] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.080061] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080120] Brought up 2 CPUs
[ 0.080133] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080140] CPU: All CPU(s) started in HYP mode.
[ 0.080146] CPU: Virtualization extensions available.
[ 0.080519] devtmpfs: initialized
[ 0.108551] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.109486] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.310473] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.314390] pinctrl core: initialized pinctrl subsystem
[ 0.315221] NET: Registered protocol family 16
[ 0.316130] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.340273] cpuidle: using governor ladder
[ 0.370294] cpuidle: using governor menu
[ 0.378367] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.378904] OMAP GPIO hardware version 0.1
[ 0.379572] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.380503] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.381366] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.382213] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[ 0.383069] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[ 0.383916] gpiochip_add: registered GPIOs 192 to 223 on device: gpio
[ 0.384765] gpiochip_add: registered GPIOs 224 to 255 on device: gpio
[ 0.385381] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.411095] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.411106] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.411568] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.411577] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.412149] OMAP DMA hardware revision 0.0
[ 0.451402] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452553] edma 43300000.edma: memcpy is disabled
[ 0.457333] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.457737] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vdd_3v3[0]'
[ 0.457954] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-aic_dvdd[0]'
[ 0.458185] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
[ 0.458458] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0)
[ 0.461489] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.461670] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.461826] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.461979] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.462248] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.462450] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.465442] palmas 0-0058: Irq flag is 0x00000008
[ 0.482096] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.563632] gpiochip_find_base: found new base at 504
[ 0.563729] gpiochip_add: registered GPIOs 504 to 511 on device: 48070000.i2c:tps659038@58:tps659038_gpio
[ 0.564145] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.564642] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.565198] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.565410] media: Linux media interface: v0.10
[ 0.565464] Linux video capture interface: v2.00
[ 0.565510] pps_core: LinuxPPS API ver. 1 registered
[ 0.565517] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.565546] PTP clock support registered
[ 0.565596] EDAC MC: Ver: 3.0.0
[ 0.566335] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[ 0.566623] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[ 0.566910] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.567197] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.567542] Advanced Linux Sound Architecture Driver Initialized.
[ 0.568361] clocksource: Switched to clocksource arch_sys_counter
[ 0.579346] NET: Registered protocol family 2
[ 0.579834] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.579898] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.580023] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.580075] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.580106] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.580315] NET: Registered protocol family 1
[ 0.580556] RPC: Registered named UNIX socket transport module.
[ 0.580565] RPC: Registered udp transport module.
[ 0.580572] RPC: Registered tcp transport module.
[ 0.580578] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.580592] PCI: CLS 0 bytes, default 64
[ 0.581569] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.583985] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.591540] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.592185] NFS: Registering the id_resolver key type
[ 0.592209] Key type id_resolver registered
[ 0.592217] Key type id_legacy registered
[ 0.592276] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.594213] bounce: pool size: 64 pages
[ 0.594368] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.594384] io scheduler noop registered
[ 0.594398] io scheduler deadline registered
[ 0.594433] io scheduler cfq registered (default)
[ 0.599461] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.603038] dra7-pcie 51000000.pcie_rc: GPIO lookup for consumer (null)
[ 0.603050] dra7-pcie 51000000.pcie_rc: using device tree for GPIO lookup
[ 0.603081] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ocp/axi@0/pcie_rc@51000000[0]' - status (0)
[ 0.603199] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.603210] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.603243] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.603263] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.634004] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.634168] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.634181] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.634192] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.634202] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.634235] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[ 0.634279] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 0.634300] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 0.634366] pci 0000:00:00.0: supports D1
[ 0.634375] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.634596] PCI: bus0: Fast back to back transfers disabled
[ 0.634712] PCI: bus1: Fast back to back transfers enabled
[ 0.634794] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.634809] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.634821] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.635042] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.635055] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 0.635169] aer 0000:00:00.0:pcie02: service driver aer loaded
[ 0.636300] pwm-backlight backlight: GPIO lookup for consumer enable
[ 0.636310] pwm-backlight backlight: using device tree for GPIO lookup
[ 0.636320] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[ 0.636329] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[ 0.636337] pwm-backlight backlight: using lookup tables for GPIO lookup
[ 0.636346] pwm-backlight backlight: lookup for GPIO enable failed
[ 0.636377] backlight supply power not found, using dummy regulator
[ 0.695870] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.699302] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
[ 1.660182] console [ttyS2] enabled
[ 1.664520] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 302, base_baud = 3000000) is a 8250
[ 1.674612] [drm] Initialized drm 1.1.0 20060810
[ 1.681300] OMAP DSS rev 6.1
[ 1.685063] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.693540] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 1.702512] tpd12s015 encoder: GPIO lookup for consumer (null)
[ 1.702523] tpd12s015 encoder: using device tree for GPIO lookup
[ 1.702553] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[0]' - status (0)
[ 1.702569] tpd12s015 encoder: GPIO lookup for consumer (null)
[ 1.702577] tpd12s015 encoder: using device tree for GPIO lookup
[ 1.702614] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[1]' - status (0)
[ 1.702627] tpd12s015 encoder: GPIO lookup for consumer (null)
[ 1.702635] tpd12s015 encoder: using device tree for GPIO lookup
[ 1.702683] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[2]' - status (0)
[ 1.703367] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/connector[0]'
[ 1.703656] panel-dpi display: GPIO lookup for consumer enable
[ 1.703665] panel-dpi display: using device tree for GPIO lookup
[ 1.703693] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/display[0]' - status (0)
[ 1.709749] loop: module loaded
[ 1.715801] libphy: Fixed MDIO Bus: probed
[ 1.768397] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 1.774522] davinci_mdio 48485000.mdio: detected phy mask fffffff9
[ 1.785069] libphy: 48485000.mdio: probed
[ 1.789142] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 1.798879] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[ 1.809264] cpsw 48484000.ethernet: Detected MACID = 5c:f8:21:0e:96:3a
[ 1.815911] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 1.822904] cpsw 48484000.ethernet: cpsw: Detected MACID = 5c:f8:21:0e:96:3b
[ 1.831442] mousedev: PS/2 mouse device common for all mice
[ 1.837494] i2c /dev entries driver
[ 1.842601] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_fan[0]' - status (0)
[ 1.843842] gpio-fan gpio_fan: GPIO fan initialized
[ 1.849773] tmp102 0-0048: initialized
[ 1.856520] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer cd
[ 1.856531] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[ 1.856560] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@4809c000[0]' - status (0)
[ 1.856596] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 1.861281] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer wp
[ 1.861291] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[ 1.861300] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]'
[ 1.861310] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]'
[ 1.861318] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[ 1.861326] omap_hsmmc 4809c000.mmc: lookup for GPIO wp failed
[ 1.861654] vdd_3v3: supplied by regen1
[ 1.908598] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer cd
[ 1.908609] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[ 1.908619] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480b4000[0]'
[ 1.908628] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480b4000[0]'
[ 1.908636] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[ 1.908644] omap_hsmmc 480b4000.mmc: lookup for GPIO cd failed
[ 1.908654] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer wp
[ 1.908661] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[ 1.908670] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480b4000[0]'
[ 1.908678] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480b4000[0]'
[ 1.908685] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[ 1.908693] omap_hsmmc 480b4000.mmc: lookup for GPIO wp failed
[ 1.908861] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 1.915243] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 1.978648] omap_hsmmc 480ad000.mmc: GPIO lookup for consumer cd
[ 1.978658] omap_hsmmc 480ad000.mmc: using device tree for GPIO lookup
[ 1.978668] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480ad000[0]'
[ 1.978677] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480ad000[0]'
[ 1.978685] omap_hsmmc 480ad000.mmc: using lookup tables for GPIO lookup
[ 1.978693] omap_hsmmc 480ad000.mmc: lookup for GPIO cd failed
[ 1.978702] omap_hsmmc 480ad000.mmc: GPIO lookup for consumer wp
[ 1.978709] omap_hsmmc 480ad000.mmc: using device tree for GPIO lookup
[ 1.978719] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480ad000[0]'
[ 1.978726] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480ad000[0]'
[ 1.978734] omap_hsmmc 480ad000.mmc: using lookup tables for GPIO lookup
[ 1.978741] omap_hsmmc 480ad000.mmc: lookup for GPIO wp failed
[ 2.018847] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@0[0]' - status (0)
[ 2.018980] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@1[0]' - status (0)
[ 2.019095] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@2[0]' - status (0)
[ 2.019218] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@3[0]' - status (0)
[ 2.019716] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.030890] NET: Registered protocol family 10
[ 2.046205] sit: IPv6 over IPv4 tunneling driver
[ 2.051513] NET: Registered protocol family 17
[ 2.056191] Key type dns_resolver registered
[ 2.060624] omap_voltage_late_init: Voltage driver support not added
[ 2.067505] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.073730] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.080434] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.086643] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.094798] Power Management for TI OMAP4+ devices.
[ 2.099915] Registering SWP/SWPB emulation handler
[ 2.106764] dmm 4e000000.dmm: initialized all PAT entries
[ 2.131644] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.138286] [drm] No driver support for vblank timestamp query.
[ 2.152991] mmc1: MAN_BKOPS_EN bit is not set
[ 2.166443] mmc1: new DDR MMC card at address 0001
[ 2.171590] mmcblk0: mmc1:0001 S10004 3.56 GiB
[ 2.176268] mmcblk0boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[ 2.182400] mmcblk0boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[ 2.189003] mmcblk0: p1 p2
[ 2.412834] [drm] Enabling DMM ywrap scrolling
[ 2.451537] Console: switching to colour frame buffer device 100x30
[ 2.460490] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 2.488906] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.505533] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER1[0]' - status (0)
[ 2.505565] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER2[0]' - status (0)
[ 2.505592] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER3[0]' - status (0)
[ 2.505618] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER4[0]' - status (0)
[ 2.505644] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER5[0]' - status (0)
[ 2.506287] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 2.513278] hctosys: unable to open rtc device (rtc0)
[ 2.528816] aic_dvdd_fixed: disabling
[ 2.532523] vmmcwl_fixed: disabling
[ 2.536219] ldousb: disabling
[ 2.539680] ALSA device list:
[ 2.542680] No soundcards found.
[ 2.569029] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[ 2.580228] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 2.587784] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.597301] devtmpfs: mounted
[ 2.600488] Freeing unused kernel memory: 332K (c08e1000 - c0934000)
[ 2.606885] This architecture does not have kernel memory protection.
[ 2.731979] systemd[1]: System time before build time, advancing clock.
[ 2.756974] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 2.768598] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 2.780482] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.798943] systemd[1]: Detected architecture arm.
[ 2.818970] systemd[1]: Set hostname to <am57xx-evm>.
[ 2.880473] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[ 2.887296] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[ 2.889996] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[ 2.893740] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[ 2.920672] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
[ 2.959813] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.969310] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.979156] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 3.219084] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 3.226871] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 3.234620] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 3.241893] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 3.249340] systemd[1]: sysinit.target: Found dependency on avahi-daemon.socket/start
[ 3.257205] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 3.264653] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 3.274134] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ 3.302120] systemd[1]: Created slice User and Session Slice.
[ 3.328665] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.348793] systemd[1]: Listening on Network Service Netlink Socket.
[ 3.368588] systemd[1]: Listening on Syslog Socket.
[ 3.388683] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.418636] systemd[1]: Listening on Journal Socket.
[ 3.438648] systemd[1]: Listening on udev Control Socket.
[ 3.459109] systemd[1]: Created slice System Slice.
[ 3.508728] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.540712] systemd[1]: Starting Setup Virtual Console...
[ 3.570717] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.589500] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.608674] systemd[1]: Reached target Slices.
[ 3.678760] systemd[1]: Starting Load Kernel Modules...
[ 3.691615] CMEMK module: reference Linux version 4.4.32
[ 3.697579] allocated heap buffer 0x40500000 of size 0x100000
[ 3.703496] cmemk initialized
[ 3.703717] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.717661] cryptodev: driver 1.8 loaded.
[ 3.741089] systemd[1]: Mounting Temporary Directory...
[ 3.768723] systemd[1]: Listening on udev Kernel Socket.
[ 3.788577] systemd[1]: Reached target Remote File Systems.
[ 3.809261] systemd[1]: Created slice system-getty.slice.
[ 3.868742] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.885487] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.898805] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.929241] systemd[1]: Reached target Paths.
[ 3.978609] systemd[1]: Mounting Debug File System...
[ 4.013874] systemd[1]: Starting Journal Service...
[ 4.038724] systemd[1]: Reached target Swap.
[ 4.151734] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.178657] systemd[1]: Mounted Debug File System.
[ 4.198590] systemd[1]: Mounted Temporary Directory.
[ 4.218766] systemd[1]: Started Journal Service.
[ 4.849323] systemd-journald[146]: Received request to flush runtime journal from PID 1
[ 5.158076] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[ 5.207263] remoteproc0: 58820000.ipu is available
[ 5.233397] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 5.274694] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.302327] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 5.326036] remoteproc1: 55020000.ipu is available
[ 5.344628] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 5.372808] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.405678] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 5.420279] remoteproc2: 40800000.dsp is available
[ 5.425205] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 5.440017] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.462387] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 5.470549] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp/i2c@48070000/tlv320aic3104@18[0]'
[ 5.470688] aic_dvdd_fixed: supplied by vdd_3v3
[ 5.476021] rtc-ds1307 2-006f: read: 93 56 12 2d 16 03 17
[ 5.476033] rtc-ds1307 2-006f: read secs=13, mins=56, hours=12, mday=16, mon=2, year=117, wday=4
[ 5.476443] rtc-ds1307 2-006f: read: 93 56 12 2d 16 03 17
[ 5.476457] rtc-ds1307 2-006f: read secs=13, mins=56, hours=12, mday=16, mon=2, year=117, wday=4
[ 5.476900] rtc-ds1307 2-006f: mcp794xx_read_alarm, sec=0 min=0 hour=0 wday=0 mday=1 mon=0 enabled=0 polarity=0 irq=0 match=0
[ 5.477217] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[ 5.477224] rtc-ds1307 2-006f: read: 93 56 12 2d 16 03 17
[ 5.477230] rtc-ds1307 2-006f: read secs=13, mins=56, hours=12, mday=16, mon=2, year=117, wday=4
[ 5.477236] rtc rtc0: alarm rollover: year
[ 5.484823] rtc-ds1307 2-006f: read: 93 56 12 2d 16 03 17
[ 5.484835] rtc-ds1307 2-006f: read secs=13, mins=56, hours=12, mday=16, mon=2, year=117, wday=4
[ 5.485011] rtc rtc0: mcp7941x: dev (254:0)
[ 5.485026] rtc-ds1307 2-006f: rtc core: registered mcp7941x as rtc0
[ 5.501620] rtc-ds1307 2-006f: got IRQ 472
[ 5.501641] rtc-ds1307 2-006f: 64 bytes nvram
[ 5.506242] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 5.518478] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 5.532304] remoteproc0: registered virtio0 (type 7)
[ 5.538805] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 5.546500] rtc rtc1: 48070000.i2c:tps659: dev (254:1)
[ 5.546511] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
[ 5.556991] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 5.584153] remoteproc3: 41000000.dsp is available
[ 5.594008] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 5.604822] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.634113] pixcir_ts 4-005c: GPIO lookup for consumer attb
[ 5.634125] pixcir_ts 4-005c: using device tree for GPIO lookup
[ 5.634134] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 5.634158] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[ 5.634173] pixcir_ts 4-005c: GPIO lookup for consumer reset
[ 5.634181] pixcir_ts 4-005c: using device tree for GPIO lookup
[ 5.634194] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 5.634214] of_get_named_gpiod_flags: parsed 'reset-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[ 5.636254] remoteproc1: registered virtio1 (type 7)
[ 5.656170] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id
[ 5.656186] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[ 5.656196] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 5.656205] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 5.656212] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup tables for GPIO lookup
[ 5.656221] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: lookup for GPIO id failed
[ 5.656229] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus
[ 5.656240] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[ 5.656250] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 5.656280] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0)
[ 5.756523] rtc rtc2: 48838000.rtc: dev (254:2)
[ 5.756536] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
[ 5.809883] input: pixcir_tangoc as /devices/platform/44000000.ocp/4807c000.i2c/i2c-4/4-005c/input/input1
[ 5.851912] mt9t11x 4-003c: input-clock-freq: 32000000
[ 5.860239] mt9t11x 4-003c: pixel-clock-freq: 96000000
[ 5.894295] mt9t11x 4-003c: GPIO lookup for consumer reset
[ 5.894307] mt9t11x 4-003c: using device tree for GPIO lookup
[ 5.894378] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 5.894393] mt9t11x 4-003c: GPIO lookup for consumer powerdown
[ 5.894399] mt9t11x 4-003c: using device tree for GPIO lookup
[ 5.894418] of_get_named_gpiod_flags: parsed 'powerdown-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 5.896021] mt9t11x 4-003c: GPIO lookup for consumer oscen
[ 5.896031] mt9t11x 4-003c: using device tree for GPIO lookup
[ 5.896072] of_get_named_gpiod_flags: parsed 'oscen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 5.896083] mt9t11x 4-003c: GPIO lookup for consumer bufen
[ 5.896089] mt9t11x 4-003c: using device tree for GPIO lookup
[ 5.896106] of_get_named_gpiod_flags: parsed 'bufen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 5.896117] mt9t11x 4-003c: GPIO lookup for consumer camen
[ 5.896127] mt9t11x 4-003c: using device tree for GPIO lookup
[ 5.896148] of_get_named_gpiod_flags: parsed 'camen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 5.919163] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 5.922391] mt9t11x 4-003c: mt9t111 chip ID 2680
[ 5.923826] mt9t11x 4-003c: mt9t11x sensor driver registered !!
[ 6.028570] vpe 489d0000.vpe: Device registered as /dev/video0
[ 6.039075] vip 48990000.vip: loading firmware vpdma-1b8.bin
[ 6.058665] vip 48990000.vip: VPDMA firmware loaded
[ 6.096566] vip2-s0: Port A: Using subdev mt9t11x for capture
[ 6.097739] SCSI subsystem initialized
[ 6.107399] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 6.127236] vip2-s0: device registered as video1
[ 6.140962] libata version 3.00 loaded.
[ 6.143230] ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
[ 6.169206] irq: no irq domain found for /ocp/pruss@4b200000/intc@4b220000 !
[ 6.198339] irq: no irq domain found for /ocp/pruss@4b200000/intc@4b220000 !
[ 6.210709] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 6.233386] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 6.260002] rtc-ds1307 2-006f: write secs=23, mins=42, hours=12, mday=16, mon=2, year=117, wday=4
[ 6.260014] rtc-ds1307 2-006f: write: a3 42 12 0d 16 03 17
[ 6.263974] rtc-ds1307 2-006f: read: a3 42 12 2d 16 03 17
[ 6.263987] rtc-ds1307 2-006f: read secs=23, mins=42, hours=12, mday=16, mon=2, year=117, wday=4
[ 6.457204] remoteproc2: registered virtio2 (type 7)
[ 6.516778] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 6.527886] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 6.548542] ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
[ 6.558168] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound@0[0]'
[ 6.558177] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound@0[0]'
[ 6.559154] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 6.579151] irq: no irq domain found for /ocp/pruss@4b280000/intc@4b2a0000 !
[ 6.600494] irq: no irq domain found for /ocp/pruss@4b280000/intc@4b2a0000 !
[ 6.613795] remoteproc3: registered virtio3 (type 7)
[ 6.628002] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 6.689872] remoteproc4: 4b234000.pru0 is available
[ 6.694893] remoteproc4: Note: remoteproc is still under development and considered experimental.
[ 6.694897] remoteproc4: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.728151] remoteproc4: registered virtio4 (type 7)
[ 6.733377] pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss@4b200000/pru0@4b234000 probed successfully
[ 6.747131] remoteproc5: 4b238000.pru1 is available
[ 6.755452] remoteproc5: Note: remoteproc is still under development and considered experimental.
[ 6.767519] remoteproc5: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.785445] remoteproc5: registered virtio5 (type 7)
[ 6.792184] pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss@4b200000/pru1@4b238000 probed successfully
[ 6.822452] remoteproc6: 4b2b4000.pru0 is available
[ 6.873298] remoteproc6: Note: remoteproc is still under development and considered experimental.
[ 6.902736] remoteproc6: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.925159] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.959500] remoteproc6: registered virtio6 (type 7)
[ 6.966377] pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss@4b280000/pru0@4b2b4000 probed successfully
[ 6.981395] remoteproc7: 4b2b8000.pru1 is available
[ 6.986400] remoteproc7: Note: remoteproc is still under development and considered experimental.
[ 6.996612] remoteproc7: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 7.012760] remoteproc7: registered virtio7 (type 7)
[ 7.026456] pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss@4b280000/pru1@4b2b8000 probed successfully
[ 7.168295] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 7.175884] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 7.185354] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 7.198136] scsi host0: ahci
[ 7.201607] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 348
[ 7.266754] NET: Registered protocol family 15
[ 7.336955] net eth1: initializing cpsw version 1.15 (0)
[ 7.361213] net eth0: initialized cpsw ale version 1.4
[ 7.367039] net eth0: ALE Table size 1024
[ 7.426557] Bluetooth: Core ver 2.21
[ 7.436355] Initializing XFRM netlink socket
[ 7.443943] NET: Registered protocol family 31
[ 7.478206] net eth1: phy found : id is : 0x221622
[ 7.487411] Bluetooth: HCI device and connection manager initialized
[ 7.505220] Bluetooth: HCI socket layer initialized
[ 7.522389] remoteproc0: powering up 58820000.ipu
[ 7.558426] ata1: SATA link down (SStatus 0 SControl 300)
[ 7.563171] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4890352
[ 7.563293] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 7.564110] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.565912] Bluetooth: L2CAP socket layer initialized
[ 7.565943] Bluetooth: SCO socket layer initialized
[ 7.595306] net eth0: initializing cpsw version 1.15 (0)
[ 7.605873] remoteproc0: remote processor 58820000.ipu is now up
[ 7.711032] random: nonblocking pool is initialized
[ 7.733236] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 7.734897] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 7.735039] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 7.735553] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 7.735660] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 7.799305] remoteproc1: powering up 55020000.ipu
[ 7.803998] net eth0: phy found : id is : 0x221622
[ 7.828888] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.830018] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743072
[ 7.830100] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 8.008257] remoteproc1: remote processor 55020000.ipu is now up
[ 8.034326] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 8.037396] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 8.038291] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[ 8.100825] remoteproc2: powering up 40800000.dsp
[ 8.198598] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 21998880
[ 8.228238] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 8.234131] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 8.240058] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 8.322264] remoteproc2: remote processor 40800000.dsp is now up
[ 8.349706] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 8.349794] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 8.400723] remoteproc3: powering up 41000000.dsp
[ 8.488162] usbcore: registered new interface driver usbfs
[ 8.505724] usbcore: registered new interface driver hub
[ 8.530930] usbcore: registered new device driver usb
[ 8.551466] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 21998880
[ 8.569090] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 8.583159] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 8.589052] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 8.594994] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 8.603746] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 8.613600] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[ 8.629466] xhci-hcd xhci-hcd.1.auto: irq 475, io mem 0x48890000
[ 8.646624] hub 1-0:1.0: USB hub found
[ 8.657994] hub 1-0:1.0: 1 port detected
[ 8.672065] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 8.681608] remoteproc3: remote processor 41000000.dsp is now up
[ 8.692705] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 8.711389] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.720819] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 8.720897] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[ 8.750207] remoteproc4: powering up 4b234000.pru0
[ 8.755434] hub 2-0:1.0: USB hub found
[ 8.761717] hub 2-0:1.0: 1 port detected
[ 8.766953] remoteproc4: Booting fw image am57xx-pru1_0-fw, size 75804
[ 8.791141] ti-pruss 4b200000.pruss: configured system_events = 0x0000000000030000 intr_channels = 0x00000005 host_intr = 0x00000005
[ 8.873636] remoteproc4: remote processor 4b234000.pru0 is now up
[ 8.899199] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 8.899226] virtio_rpmsg_bus virtio4: creating channel rpmsg-pru addr 0x1e
[ 8.943114] remoteproc5: powering up 4b238000.pru1
[ 8.960618] remoteproc5: Booting fw image am57xx-pru1_1-fw, size 75804
[ 8.984290] ti-pruss 4b200000.pruss: configured system_events = 0x00000000000c0000 intr_channels = 0x0000000a host_intr = 0x0000000a
[ 8.996340] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 9.033316] remoteproc5: remote processor 4b238000.pru1 is now up
[ 9.045290] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 9.045315] virtio_rpmsg_bus virtio5: creating channel rpmsg-pru addr 0x1f
[ 9.061279] remoteproc6: powering up 4b2b4000.pru0
[ 9.075534] remoteproc6: Booting fw image am57xx-pru2_0-fw, size 75804
[ 9.093394] ti-pruss 4b280000.pruss: configured system_events = 0x0000000000030000 intr_channels = 0x00000005 host_intr = 0x00000005
[ 9.108645] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 9.128183] remoteproc6: remote processor 4b2b4000.pru0 is now up
[ 9.149163] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 9.149191] virtio_rpmsg_bus virtio6: creating channel rpmsg-pru addr 0x20
[ 9.161895] hub 2-1:1.0: USB hub found
[ 9.165748] remoteproc7: powering up 4b2b8000.pru1
[ 9.170695] hub 2-1:1.0: 4 ports detected
[ 9.187940] remoteproc7: Booting fw image am57xx-pru2_1-fw, size 75804
[ 9.194980] hub 1-1:1.0: USB hub found
[ 9.199299] hub 1-1:1.0: 4 ports detected
[ 9.204260] ti-pruss 4b280000.pruss: configured system_events = 0x00000000000c0000 intr_channels = 0x0000000a host_intr = 0x0000000a
[ 9.258897] remoteproc7: remote processor 4b2b8000.pru1 is now up
[ 9.272676] virtio_rpmsg_bus virtio7: rpmsg host is online
[ 9.272708] virtio_rpmsg_bus virtio7: creating channel rpmsg-pru addr 0x21
[ 9.355878] NET: Registered protocol family 41
[ 9.361113] rpmsg_rpc rpmsg3: probing service rpc_example_2 with src 1024 dst 101
[ 9.370885] rpmsg_pru rpmsg8: new rpmsg_pru device: /dev/rpmsg_pru30
[ 9.384757] rpmsg_pru rpmsg9: new rpmsg_pru device: /dev/rpmsg_pru31
[ 9.394080] rpmsg_rpc rpmsg4: probing service dce-callback with src 1024 dst 101
[ 9.394587] rpmsg_rpc rpmsg3: published functions = 8
[ 9.418677] rpmsg_pru rpmsg10: new rpmsg_pru device: /dev/rpmsg_pru32
[ 9.433861] rpmsg_pru rpmsg11: new rpmsg_pru device: /dev/rpmsg_pru33
[ 9.442101] rpmsg_rpc rpmsg5: probing service rpmsg-dce with src 1025 dst 102
[ 9.442459] rpmsg_rpc rpmsg4: published functions = 4
[ 9.472586] rpmsg_rpc rpmsg5: published functions = 9
[ 9.498877] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[ 9.612409] usb 1-1.1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 9.718400] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[ 9.785488] input: USB Optical Mouse as /devices/platform/44000000.ocp/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:0461:4D17.0001/input/input2
[ 9.838508] usb 1-1.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 9.858857] hid-generic 0003:0461:4D17.0001: input: USB HID v1.11 Mouse [USB Optical Mouse] on usb-xhci-hcd.1.auto-1.1/input0
[ 9.876237] usb 1-1.3: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 9.898742] usbcore: registered new interface driver usbhid
[ 9.910349] usbhid: USB HID core driver
[ 9.935076] input: Logitech USB Keyboard as /devices/platform/44000000.ocp/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input3
[ 10.079198] hid-generic 0003:046D:C31C.0002: input: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.1.auto-1.3/input0
[ 10.106044] input: Logitech USB Keyboard as /devices/platform/44000000.ocp/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input4
[ 10.159898] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ 10.178781] hid-generic 0003:046D:C31C.0003: input: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.1.auto-1.3/input1
[ 11.827071] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 11.848432] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.045773] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
[ 19.059866] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
[ 19.073020] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 19.086004] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 25.768393] rtc-ds1307 2-006f: write secs=34, mins=56, hours=12, mday=16, mon=2, year=117, wday=4
[ 25.768408] rtc-ds1307 2-006f: write: b4 56 12 0d 16 03 17
[ 25.768997] rtc-ds1307 2-006f: read: b4 56 12 2d 16 03 17
[ 25.769011] rtc-ds1307 2-006f: read secs=34, mins=56, hours=12, mday=16, mon=2, year=117, wday=4
[ 686.779755] rtc-ds1307 2-006f: write secs=35, mins=7, hours=13, mday=16, mon=2, year=117, wday=4
[ 686.779771] rtc-ds1307 2-006f: write: b5 07 13 0d 16 03 17
[ 686.780349] rtc-ds1307 2-006f: read: b5 07 13 2d 16 03 17
[ 686.780363] rtc-ds1307 2-006f: read secs=35, mins=7, hours=13, mday=16, mon=2, year=117, wday=4
[ 1347.787174] rtc-ds1307 2-006f: write secs=36, mins=18, hours=13, mday=16, mon=2, year=117, wday=4
[ 1347.787189] rtc-ds1307 2-006f: write: b6 18 13 0d 16 03 17
[ 1347.787767] rtc-ds1307 2-006f: read: b6 18 13 2d 16 03 17
[ 1347.787781] rtc-ds1307 2-006f: read secs=36, mins=18, hours=13, mday=16, mon=2, year=117, wday=4
[ 2010.794541] rtc-ds1307 2-006f: write secs=39, mins=29, hours=13, mday=16, mon=2, year=117, wday=4
[ 2010.794557] rtc-ds1307 2-006f: write: b9 29 13 0d 16 03 17
[ 2010.795143] rtc-ds1307 2-006f: read: b9 29 13 2d 16 03 17
[ 2010.795157] rtc-ds1307 2-006f: read secs=39, mins=29, hours=13, mday=16, mon=2, year=117, wday=4
Module Size Used by bc_example 7186 0 usbhid 19865 0 rpmsg_pru 4962 0 rpmsg_rpc 19668 0 rpmsg_proto 7597 0 xhci_plat_hcd 5247 0 xhci_hcd 109138 1 xhci_plat_hcd usbcore 194665 3 xhci_plat_hcd,usbhid,xhci_hcd cbc 2324 0 drbg 13425 1 dwc3 64055 0 udc_core 12063 1 dwc3 virtio_rpmsg_bus 13080 3 rpmsg_pru,rpmsg_rpc,rpmsg_proto xfrm_user 23228 2 bluetooth 325678 2 xfrm4_tunnel 2040 0 ipcomp 2473 0 xfrm_ipcomp 4695 1 ipcomp esp4 6465 0 ah4 5665 0 af_key 27563 0 xfrm_algo 6970 5 ah4,esp4,af_key,xfrm_user,xfrm_ipcomp sha512_generic 9903 0 sha512_arm 12079 0 sha256_generic 9503 1 hmac 2735 1 md5 1897 0 sha1_generic 2621 0 sha1_arm_neon 6261 0 sha1_arm 3862 1 sha1_arm_neon pru_rproc 11732 4 pruss_intc 7227 5 pru_rproc snd_soc_simple_card 7760 0 ecb 1909 0 ahci_platform 3218 0 omap_sham 21089 0 libahci_platform 8821 1 ahci_platform snd_soc_omap_hdmi_audio 4737 0 libahci 27891 2 libahci_platform,ahci_platform pvrsrvkm 412436 5 bc_example omap_aes_driver 19230 0 pruss 11186 1 pru_rproc libata 196388 3 libahci,libahci_platform,ahci_platform omap_wdt 4570 0 scsi_mod 129717 1 libata ti_vip 35302 0 ti_vpe 19292 0 ti_sc 24714 2 ti_vip,ti_vpe ti_csc 2313 2 ti_vip,ti_vpe ti_vpdma 15166 2 ti_vip,ti_vpe dwc3_omap 5054 0 rtc_omap 8272 0 mt9t11x 14769 1 extcon_palmas 6261 0 extcon 13943 3 dwc3,extcon_palmas,dwc3_omap pixcir_i2c_ts 6570 0 rtc_palmas 5187 0 snd_soc_tlv320aic3x 48260 1 omap_rng 4835 0 rtc_ds1307 11278 0 rng_core 8011 1 omap_rng omap_des 11446 0 debugss_kmodule 6848 0 omap_remoteproc 12389 4 remoteproc 27121 5 omap_remoteproc,pruss,pru_rproc,rpmsg_rpc,rpmsg_proto virtio 7580 2 remoteproc,virtio_rpmsg_bus virtio_ring 12291 2 remoteproc,virtio_rpmsg_bus sch_fq_codel 8251 3 uio_module_drv 7353 0 uio 9329 1 uio_module_drv gdbserverproxy 4671 0 cryptodev 37405 2 cmemk 31462 0
