Linux/J6EVM5777: USB1 interface usage on PSDKLA 3.0x
Part Number: J6EVM5777
Tool/software: Linux
Hi all,
I'm testing USB1 interface on J6 EVM, and below are my step and result .
First, switch CPU board SW1 DIP switch. Change DIP-2 to make ID pin to ground.
When using glsdk7.02.00.02, I can use USB1 as a USB Hub.
There are usb3 and usb4 in the boot logs.
[ 7.264450] hub 3-0:1.0: USB hub found
[ 7.268257] hub 3-0:1.0: 1 port detected
[ 7.320878] hub 4-0:1.0: USB hub found
[ 7.324659] hub 4-0:1.0: 1 port detected
Below is my logs and results.
glsdk7403_log.txt
But when I use SDK 3.0, including PSDKLA 3.00, 3.01, 3.02
I only get the following logs... I can't see usb3 and usb4. Is there anything need to modify ??
[ 11.141885] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 11.147983] rpmsg_rpc rpmsg5: published functions = 9
[ 11.153852] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 11.177584] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 11.201735] xhci-hcd xhci-hcd.2.auto: irq 511, io mem 0x488d0000
[ 11.210156] hub 1-0:1.0: USB hub found
[ 11.222239] hub 1-0:1.0: 1 port detected
[ 11.235261] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 11.240781] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 11.252709] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 11.262713] hub 2-0:1.0: USB hub found
[ 11.262739] hub 2-0:1.0: 1 port detected
Thanks in advance.
AC
  • Hi AC,
    Do you mean by usb3/usb4 the usb controllers (PHY-less) in the J6 SoC?
    I'm testing J6 EVM USB1 (USB3.0 port). I think it connect to USB3PHY. Am I right?
  • Sorry, please disregard my question. You did mean ports on the hub, not in the J6 device...
  • Hi AC,
    I have forwarded your question to USB expert.
    Yordan
  • AC,
    I can not find these messages in the glsdk7403_log.txt.
    For using USB1 (SuperSpeed USB3.0) as a hub (host mode) in PSDKLA 3.x, refer to the below pointers:
    http://processors.wiki.ti.com/index.php/Linux_Core_DWC3_User's_Guide
    Pavel
  • Pavel,
    Sorry.. attached wrong file.
    Here are the whole boot log.
    U-Boot SPL 2014.07 (Sep 04 2015 - 00:02:44)
    DRA752-GP ES1.0
    DRA752-GP ES1.0
    spl_mmc_load_image
    reading u-boot.img
    reading u-boot.img
    U-Boot 2014.07 (Sep 04 2015 - 00:02:44)
    CPU  : DRA752-GP ES1.0
    Board: DRA7xx
    I2C:   ready
    DRAM:  1.5 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Using default environment
    serial# not set, setting...
    SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    SCSI:  Net:   <ethaddr> not set. Validating first E-fuse MAC
    cpsw
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    reading uEnv.txt
    221 bytes read in 3 ms (71.3 KiB/s)
    Loaded environment from uEnv.txt
    Importing environment from mmc0 ...
    4936560 bytes read in 325 ms (14.5 MiB/s)
    99286 bytes read in 40 ms (2.4 MiB/s)
    Booting from mmc0 ...
    Kernel image @ 0x82000000 [ 0x000000 - 0x4b5370 ]
       Loading Device Tree to 8ffe4000, end 8ffff3d5 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 3.14.49 (tiiappadmin@swubn01) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 SMP PREEMPT Thu Sep 3 23:52:20 IST 2015
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c7387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine model: TI DRA742
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
    [    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
    [    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
    [    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
    [    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: CMA: reserved 64 MiB at ab800000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] DRA752 ES1.0
    [    0.000000] PERCPU: Embedded 8 pages/cpu @eab45000 s8640 r8192 d15936 u32768
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 389904
    [    0.000000] Kernel command line: console=ttyO0,115200n8 elevator=noop root=PARTUUID=6cf46e44-02 rw rootwait earlyprintk fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=64M rootfstype=ext4 snd.slots_reserved=1,1
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 1312372K/1565696K available (6511K kernel code, 411K rwdata, 2504K rodata, 312K init, 268K bss, 253324K reserved, 791552K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc08d60c4   (9017 kB)
    [    0.000000]       .init : 0xc08d7000 - 0xc09251c0   ( 313 kB)
    [    0.000000]       .data : 0xc0926000 - 0xc098cf20   ( 412 kB)
    [    0.000000]        .bss : 0xc098cf2c - 0xc09cff7c   ( 269 kB)
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] OMAP clockevent source: timer1 at 32786 Hz
    [    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65536000000000ns
    [    0.000000] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000427] Architected cp15 timer(s) running at 6.14MHz (virt).
    [    0.000432] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 2794592043008ns
    [    0.000440] Switching to timer-based delay loop
    [    0.001073] Console: colour dummy device 80x30
    [    0.001090] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [    0.001097] This ensures that you still see kernel messages. Please
    [    0.001103] update your kernel commandline.
    [    0.001119] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [    0.001132] pid_max: default: 32768 minimum: 301
    [    0.001240] Security Framework initialized
    [    0.001291] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001301] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.024854] CPU: Testing write buffer coherency: ok
    [    0.025094] /cpus/cpu@0 missing clock-frequency property
    [    0.025130] /cpus/cpu@1 missing clock-frequency property
    [    0.025142] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.025159] Setting up static identity map for 0x806616c0 - 0x80661718
    [    0.080833] CPU1: Booted secondary processor
    [    0.080863] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.080949] Brought up 2 CPUs
    [    0.080965] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [    0.080972] CPU: All CPU(s) started in SVC mode.
    [    0.081380] devtmpfs: initialized
    [    0.082129] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.083782] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.096688] omap_hwmod: tptc0 using broken dt data from edma-controller
    [    0.097176] omap_hwmod: tptc1 using broken dt data from edma-controller
    [    0.279285] pinctrl core: initialized pinctrl subsystem
    [    0.280011] regulator-dummy: no parameters
    [    0.284336] NET: Registered protocol family 16
    [    0.285430] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.287421] cpuidle: using governor ladder
    [    0.287431] cpuidle: using governor menu
    [    0.333929] syscon 4a002000.tisysconcore: regmap [mem 0x4a002000-0x4a0026cf] registered
    [    0.334241] syscon 4a002e00.tisyscon: regmap [mem 0x4a002e00-0x4a002e7b] registered
    [    0.336922] OMAP GPIO hardware version 0.1
    [    0.343201] irq: no irq domain found for /ocp/pinmux@4a003400 !
    [    0.349279] platform 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    0.349562] platform 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    0.349839] platform 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    0.366821] platform 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [    0.372888] No ATAGs?
    [    0.372913] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.372922] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.375902] OMAP DMA hardware revision 0.0
    [    0.402350] bio: create slab <bio-0> at 0
    [    0.417760] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
    [    0.423660] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
    [    0.424359] platform fixedregulator-sd: Driver reg-fixed-voltage requests probe deferral
    [    0.424618] evm_3v3_sw: 3300 mV
    [    0.424666] reg-fixed-voltage fixedregulator-evm_3v3_sw: Failed to find supply vin
    [    0.424848] reg-fixed-voltage fixedregulator-evm_3v3_sw: Failed to register regulator: -517
    [    0.424867] platform fixedregulator-evm_3v3_sw: Driver reg-fixed-voltage requests probe deferral
    [    0.425119] aic_dvdd: 1800 mV
    [    0.425173] reg-fixed-voltage fixedregulator-aic_dvdd: Failed to find supply vin
    [    0.425345] reg-fixed-voltage fixedregulator-aic_dvdd: Failed to register regulator: -517
    [    0.425364] platform fixedregulator-aic_dvdd: Driver reg-fixed-voltage requests probe deferral
    [    0.425657] vmmcwl_fixed: 1800 mV
    [    0.426020] vtt_fixed: 1350 mV
    [    0.426069] reg-fixed-voltage fixedregulator-vtt: Failed to find supply vin
    [    0.426285] reg-fixed-voltage fixedregulator-vtt: Failed to register regulator: -517
    [    0.426304] platform fixedregulator-vtt: Driver reg-fixed-voltage requests probe deferral
    [    0.430049] vgaarb: loaded
    [    0.430491] i2c-core: driver [palmas] using legacy suspend method
    [    0.430500] i2c-core: driver [palmas] using legacy resume method
    [    0.433102] SCSI subsystem initialized
    [    0.434316] usbcore: registered new interface driver usbfs
    [    0.434476] usbcore: registered new interface driver hub
    [    0.434649] usbcore: registered new device driver usb
    [    0.436926] palmas 0-0058: IRQ missing: skipping irq request
    [    0.437274] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
    [    0.437420] prom_parse: Bad cell count for /ocp/i2c@48070000/tps659038@58
    [    0.439517] smps123: 850 <--> 1250 mV at 1060 mV
    [    0.441175] smps45: 850 <--> 1150 mV at 1060 mV
    [    0.442816] smps6: 850 <--> 1250 mV at 1250 mV
    [    0.444285] smps7: 850 <--> 1060 mV at 1030 mV
    [    0.445915] smps8: 850 <--> 1250 mV at 1060 mV
    [    0.447377] smps9: 1800 mV
    [    0.451915] ldo1: 1800 <--> 3300 mV at 3000 mV
    [    0.461092] ldo2: 3300 mV
    [    0.471218] ldo3: 1800 mV
    [    0.472078] LDO4: at 1800 mV
    [    0.472671] LDO5: no parameters
    [    0.473245] LDO6: no parameters
    [    0.473831] LDO7: no parameters
    [    0.474410] LDO8: no parameters
    [    0.481116] ldo9: 1050 mV
    [    0.491140] ldoln: 1800 mV
    [    0.501206] ldousb: 3300 mV
    [    0.501907] REGEN1: no parameters
    [    0.502434] regen2: no parameters
    [    0.503014] sysen1: no parameters
    [    0.503583] sysen2: no parameters
    [    0.504531] pcf857x 0-0020: probed
    [    0.505420] pcf857x 0-0021: probed
    [    0.506547] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.507637] pcf857x 1-0026: probed
    [    0.509372] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.509791] omap_i2c 48060000.i2c: bus 2 rev0.12 at 3400 kHz
    [    0.510878] pcf857x 3-0021: probed
    [    0.510901] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.511230] media: Linux media interface: v0.10
    [    0.511370] Linux video capture interface: v2.00
    [    0.511582] pps_core: LinuxPPS API ver. 1 registered
    [    0.511591] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.511698] PTP clock support registered
    [    0.513092] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.513532] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.514667] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.514775] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.514886] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.514995] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.515186] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.515291] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.516048] Advanced Linux Sound Architecture Driver Initialized.
    [    0.517394] Switched to clocksource arch_sys_counter
    [    0.535104] NET: Registered protocol family 2
    [    0.535788] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.535859] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.535992] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.536036] TCP: reno registered
    [    0.536048] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.536080] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.536270] NET: Registered protocol family 1
    [    0.536537] RPC: Registered named UNIX socket transport module.
    [    0.536546] RPC: Registered udp transport module.
    [    0.536553] RPC: Registered tcp transport module.
    [    0.536561] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.537732] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
    [    0.540656] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.639021] bounce pool size: 64 pages
    [    0.639280] VFS: Disk quotas dquot_6.5.2
    [    0.639385] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.640003] NFS: Registering the id_resolver key type
    [    0.640050] Key type id_resolver registered
    [    0.640058] Key type id_legacy registered
    [    0.640088] jffs2: version 2.2. (NAND) (SUMMARY)  c 2001-2006 Red Hat, Inc.
    [    0.640269] msgmni has been set to 1465
    [    0.644288] alg: No test for stdrng (krng)
    [    0.644477] NET: Registered protocol family 38
    [    0.644506] io scheduler noop registered (default)
    [    0.644515] io scheduler deadline registered
    [    0.644549] io scheduler cfq registered
    [    0.650620] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
    [    0.687593] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [    0.687607] pci_bus 0000:00: root bus resource [io  0x1000-0x10000]
    [    0.687618] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    0.687629] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
    [    0.688128] PCI: bus0: Fast back to back transfers disabled
    [    0.688355] PCI: bus1: Fast back to back transfers enabled
    [    0.688472] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    0.688487] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    0.688500] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.688521] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.690603] OMAP DSS rev 6.1
    [    0.707596] tlc59108 0-0040: Successfully initialized tlc59108
    [    0.708858] platform encoder@1: Driver dra7evm-tpd12s015 requests probe deferral
    [    0.709545] connector-hdmi connector@1: failed to find video source
    [    0.709562] platform connector@1: Driver connector-hdmi requests probe deferral
    [    0.710483] pbias_mmc_omap5: 1800 <--> 3000 mV at 3000 mV
    [    0.711269] abb_mpu: 1100 <--> 1210 mV
    [    0.711623] abb_ivahd: 1060 <--> 1250 mV
    [    0.711960] abb_dspeve: 1060 <--> 1250 mV
    [    0.712316] abb_gpu: 1060 <--> 1280 mV
    [    0.713465] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.717834] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
    [    1.886732] console [ttyS0] enabled
    [    1.891003] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250
    [    1.900769] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.911425] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    1.918403] [drm] Initialized drm 1.1.0 20060810
    [    1.933311] brd: module loaded
    [    1.941681] loop: module loaded
    [    1.945091] (stk) :sysfs entries created
    [    1.949077] (stk) : debugfs entries created
    [    1.953349] (hci_tty): inside hci_tty_init
    [    1.957999] (hci_tty): allocated 249, 0
    [    1.964158] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [    1.970925] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    1.979506] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [    1.990009] scsi0 : ahci_platform
    [    1.993803] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 338
    [    2.003103] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    2.015643] usbcore: registered new interface driver asix
    [    2.021236] usbcore: registered new interface driver ax88179_178a
    [    2.027505] usbcore: registered new interface driver cdc_ether
    [    2.033516] usbcore: registered new interface driver smsc95xx
    [    2.039433] usbcore: registered new interface driver net1080
    [    2.045244] usbcore: registered new interface driver cdc_subset
    [    2.051443] usbcore: registered new interface driver zaurus
    [    2.057201] usbcore: registered new interface driver cdc_ncm
    [    2.063315] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.069886] ehci-pci: EHCI PCI platform driver
    [    2.074492] ehci-omap: OMAP-EHCI Host Controller driver
    [    2.080206] usbcore: registered new interface driver cdc_wdm
    [    2.086045] usbcore: registered new interface driver usb-storage
    [    2.093179] mousedev: PS/2 mouse device common for all mice
    [    2.100331] input: LDC 3001 TouchScreen Controller as /devices/44000000.ocp/48070000.i2c/i2c-0/0-0018/input/input0
    [    2.112392] i2c-core: driver [rtc-ds1307] using legacy suspend method
    [    2.118877] i2c-core: driver [rtc-ds1307] using legacy resume method
    [    2.125903] omap_rtc 48838000.rtcss: rtc core: registered 48838000.rtcss as rtc0
    [    2.134240] i2c /dev entries driver
    [    2.140438] tvp5158 1-0058: Camera sensor driver registered
    [    2.146493] ov1063x 1-0037: Failed writing register 0x0103!
    [    2.152139] ov1063x: probe of 1-0037 failed with error -121
    [    2.158678] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    2.164830] vip 48970000.vip: No explicit pinctrl resources data.
    [    2.171898] vip 48970000.vip: loading firmware vpdma-1b8.bin
    [    2.177878] vpe 489d0000.vpe: Device registered as /dev/video0
    [    2.184153] DRA7xx Radio probe done
    [    2.188105] Driver for 1-wire Dallas network protocol.
    [    2.194342] coproc iva_coproc: probe
    [    2.197959] vip 48970000.vip: VPDMA firmware loaded
    [    2.202951] vip1-s0: Using subdev tvp5158 1-0058 for capture
    [    2.208749] Adding alias for supply vdd,iva_coproc -> vdd,4a0025cc.voltdm
    [    2.215567] Adding alias for supply vbb,iva_coproc -> vbb,4a0025cc.voltdm
    [    2.222678] vip1-s0: vip Device registered as /dev/video1
    [    2.228426] vip1-s0: vip Device registered as /dev/video2
    [    2.234419] vip1-s0: vip Device registered as /dev/video3
    [    2.240218] coproc iva_coproc: coproc_probe result=0
    [    2.245239] coproc dsp_coproc: probe
    [    2.248959] vip1-s0: vip Device registered as /dev/video4
    [    2.254391] vip1-s1: Port A enabled but no endpoints found
    [    2.259801] Adding alias for supply vdd,dsp_coproc -> vdd,4a0025e0.voltdm
    [    2.266799] Adding alias for supply vbb,dsp_coproc -> vbb,4a0025e0.voltdm
    [    2.273646] vip1-s0: Port B enabled but no endpoints found
    [    2.278994] vip1-s1: Port B enabled but no endpoints found[    2.285533] coproc dsp_coproc: coproc_probe result=0
    [    2.291282] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
    [    2.298728] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
    [    2.306156] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
    [    2.313612] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
    [    2.321053] ti-soc-thermal 4a0021e0.bandgap: Non-trimmed BGAP, Temp not accurate
    [    2.331834] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    2.340769] omap_hsmmc 4809c000.mmc: unable to get vmmc regulator -517
    [    2.347427] ata1: SATA link down (SStatus 0 SControl 300)
    [    2.352915] platform 4809c000.mmc: Driver omap_hsmmc requests probe deferral
    [    2.360431] omap_hsmmc 480b4000.mmc: unable to get vmmc regulator -517
    [    2.367051] platform 480b4000.mmc: Driver omap_hsmmc requests probe deferral
    [    2.374279] omap_hsmmc 480d1000.mmc: no pinctrl state for default mode
    [    2.499181] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.507600] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    2.528383] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    2.534672] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    2.540996] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
    [    2.548647] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    2.556731] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    2.569731] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    2.597169] usbcore: registered new interface driver usbhid
    [    2.602813] usbhid: USB HID core driver
    [    2.607814]  remoteproc0: 58820000.ipu is available
    [    2.612715]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    2.621748]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    2.632283]  remoteproc0: Direct firmware load failed with error -2
    [    2.638726]  remoteproc1: 55020000.ipu is available
    [    2.643624]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    2.652658]  remoteproc0: Falling back to user helper
    [    2.657887]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    2.668492]  remoteproc1: Direct firmware load failed with error -2
    [    2.674787]  remoteproc1: Falling back to user helper
    [    2.679976]  remoteproc2: 40800000.dsp is available
    [    2.684874]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    2.694027]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    2.704624]  remoteproc2: Direct firmware load failed with error -2
    [    2.711194]  remoteproc3: 41000000.dsp is available
    [    2.716092]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    2.725116]  remoteproc2: Falling back to user helper
    [    2.727432]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    2.727542]  remoteproc3: Direct firmware load failed with error -2
    [    2.727545]  remoteproc3: Falling back to user helper
    [    2.756800] tlv320aic3x-codec 0-0019: Failed to get supply 'IOVDD': -517
    [    2.763555] tlv320aic3x-codec 0-0019: Failed to request supplies: -517
    [    2.770223] i2c 0-0019: Driver tlv320aic3x-codec requests probe deferral
    [    2.777138] tlv320aic3x-codec 1-0018: Failed to get supply 'IOVDD': -517
    [    2.783895] tlv320aic3x-codec 1-0018: Failed to request supplies: -517
    [    2.790557] i2c 1-0018: Driver tlv320aic3x-codec requests probe deferral
    [    2.797484] tlv320aic3x-codec 1-0019: Failed to get supply 'IOVDD': -517
    [    2.804215] tlv320aic3x-codec 1-0019: Failed to request supplies: -517
    [    2.810877] i2c 1-0019: Driver tlv320aic3x-codec requests probe deferral
    [    2.817789] tlv320aic3x-codec 1-001a: Failed to get supply 'IOVDD': -517
    [    2.824519] tlv320aic3x-codec 1-001a: Failed to request supplies: -517
    [    2.831195] i2c 1-001a: Driver tlv320aic3x-codec requests probe deferral
    [    2.838390] platform bt_sco_card: Driver asoc-simple-card requests probe deferral
    [    2.846629] asoc-simple-card asoc-simple-card.0:  hdmi-hifi <-> 58040000.encoder mapping ok
    [    2.856564] davinci-mcasp 48464000.mcasp: DAI is shared
    [    2.862433] davinci-mcasp 48468000.mcasp: numevt will be ignored due to errata i868
    [    2.871252] davinci-mcasp 48474000.mcasp: DAI is shared
    [    2.876734] davinci-mcasp 48474000.mcasp: numevt will be ignored due to errata i868
    [    2.884890] davinci-mcasp 48478000.mcasp: numevt will be ignored due to errata i868
    [    2.893044] davinci-mcasp 4847c000.mcasp: numevt will be ignored due to errata i868
    [    2.901435] davinci_evm primary_sound: ASoC: CODEC (null) not registered
    [    2.908210] davinci_evm primary_sound: snd_soc_register_card failed (-517)
    [    2.915124] platform primary_sound: Driver davinci_evm requests probe deferral
    [    2.922877] dra7xx-jamr3-snd jamr3_sound: ASoC: CODEC (null) not registered
    [    2.929909] dra7xx-jamr3-snd jamr3_sound: failed to register sound card -517
    [    2.936998] platform jamr3_sound: Driver dra7xx-jamr3-snd requests probe deferral
    [    2.945422] oprofile: using timer interrupt.
    [    2.949789] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
    [    2.956365] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    2.961796] TCP: cubic registered
    [    2.965125] Initializing XFRM netlink socket
    [    2.969438] NET: Registered protocol family 17
    [    2.973917] NET: Registered protocol family 15
    [    2.978462] Bridge firewalling registered
    [    2.982493] can: controller area network core (rev 20120528 abi 9)
    [    2.988775] NET: Registered protocol family 29
    [    2.993239] can: raw protocol (rev 20120528)
    [    2.997577] 8021q: 802.1Q VLAN Support v1.8
    [    3.001831] Key type dns_resolver registered
    [    3.006120] NET: Registered protocol family 41
    [    3.011250] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
    [    3.017595] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
    [    3.025429] Power Management for TI OMAP4+ devices.
    [    3.030514] ThumbEE CPU extension supported.
    [    3.034807] Registering SWP/SWPB emulation handler
    [    3.041231] vmmcwl_fixed: disabling
    [    3.044732] regulator-dummy: disabling
    [    3.048749] dmm 4e000000.dmm: workaround for errata i878 in use
    [    3.056405] dmm 4e000000.dmm: initialized all PAT entries
    [    3.062188] platform omapdrm.0: Driver omapdrm requests probe deferral
    [    3.070096] evm_3v3_sd: 3300 mV
    [    3.073582] evm_3v3_sw: 3300 mV
    [    3.076844] evm_3v3_sw: supplied by sysen1
    [    3.081404] aic_dvdd: 1800 mV
    [    3.084498] aic_dvdd: supplied by evm_3v3_sw
    [    3.089090] vtt_fixed: 1350 mV
    [    3.092268] vtt_fixed: supplied by sysen2
    [    3.179382] asoc-simple-card bt_sco_card:  bt-sco-pcm <-> 48478000.mcasp mapping ok
    [    3.189587] davinci_evm primary_sound:  tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
    [    3.205400] dra7xx-jamr3-snd jamr3_sound:  multicodec <-> 48474000.mcasp mapping ok
    [    3.229593] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.236234] [drm] No driver support for vblank timestamp query.
    [    3.256073] [drm] Enabling DMM ywrap scrolling
    [    3.298202] mmc1: host does not support reading read-only switch. assuming write-enable.
    [    3.302550] mmc1: new high speed SD card at address e624
    [    3.302885] mmcblk0: mmc1:e624 SU02G 1.84 GiB
    [    3.309720]  mmcblk0: p1 p2
    [    3.332425] Console: switching to colour frame buffer device 160x50
    [    3.364533] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    3.370489] omapdrm omapdrm.0: registered panic notifier
    [    3.375840] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [    3.375842] mmc2: BKOPS_EN bit is not set
    [    3.388315] mmc2: new high speed DDR MMC card at address 0001
    [    3.394410] mmcblk1: mmc2:0001 MMC04G 3.52 GiB
    [    3.399097] mmcblk1boot0: mmc2:0001 MMC04G partition 1 16.0 MiB
    [    3.405150] mmcblk1boot1: mmc2:0001 MMC04G partition 2 16.0 MiB
    [    3.412911]  mmcblk1: p1 p2
    [    3.417061]  mmcblk1boot1: unknown partition table
    [    3.422894]  mmcblk1boot0: unknown partition table
    [    3.427722] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    3.433839] davinci_mdio 48485000.mdio: detected phy mask fffffff3
    [    3.444133] libphy: 48485000.mdio: probed
    [    3.448247] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
    [    3.456306] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
    [    3.465296] cpsw 48484000.ethernet: Detected MACID = c4:ed:ba:bf:f8:16
    [    3.472995] cpsw 48484000.ethernet: cpsw: Detected MACID = c4:ed:ba:bf:f8:17
    [    3.481372] omap_rtc 48838000.rtcss: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    3.502990] ALSA device list:
    [    3.505975]   #0: DRA7xx-EVM
    [    3.508912]   #1: HDMI 58040000.encoder
    [    3.512764]   #2: DRA7xx-WiLink
    [    3.515917]   #3: DRA7xx-JAMR3
    [    3.553254] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.561437] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    3.569378] devtmpfs: mounted
    [    3.572553] Freeing unused kernel memory: 312K (c08d7000 - c0925000)
    INIT: version 2.88 booting
    Starting udev
    [    4.140728] udevd[1253]: starting version 182
    [    4.395840] Bluetooth: Core ver 2.18
    [    4.445783] NET: Registered protocol family 31
    [    4.497595] Bluetooth: HCI device and connection manager initialized
    [    4.577463] Bluetooth: HCI socket layer initialized
    [    4.622857] Bluetooth: L2CAP socket layer initialized
    [    4.647572] Bluetooth: SCO socket layer initialized
    [    4.747485] (stc):  chnl_id list empty :4
    [    4.751430] (stk) : st_kim_start(stk) :ldisc_install = 1
    [    5.005880]  remoteproc3: failed to load dra7-dsp2-fw.xe66
    [    5.042237] CAN device driver interface
    [    5.062111] tvp5158 1-0058: Currently only D1 resolution is supported
    [    5.083240]  remoteproc2: powering up 40800000.dsp
    [    5.085207] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=353)
    [    5.106989]  remoteproc0: failed to load dra7-ipu1-fw.xem4
    [    5.120563] tvp5158 1-0058: Currently only D1 resolution is supported
    [    5.172292]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 929770
    [    5.190964] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [    5.196853] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    5.202778] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    5.207515] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
    [    5.207575] 10 ofpart partitions found on MTD device spi32766.0
    [    5.207578] Creating 10 MTD partitions on "spi32766.0":
    [    5.207582] 0x000000000000-0x000000010000 : "QSPI.SPL"
    [    5.208328] 0x000000010000-0x000000020000 : "QSPI.SPL.backup1"
    [    5.209000] 0x000000020000-0x000000030000 : "QSPI.SPL.backup2"
    [    5.209667] 0x000000030000-0x000000040000 : "QSPI.SPL.backup3"
    [    5.210324] 0x000000040000-0x000000140000 : "QSPI.u-boot"
    [    5.210982] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
    [    5.211693] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
    [    5.212321] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
    [    5.212967] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
    [    5.213854] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
    [    5.231285] random: nonblocking pool is initialized
    udevd[1555]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[1556]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    5.386088]  remoteproc2: remote processor 40800000.dsp is now up
    [    5.393528] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.399850]  remoteproc2: registered virtio0 (type 7)
    [    5.400615] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x36
    [    5.400777] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x37
    [    5.400883] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
    [    5.400997] rpmsg_rpc rpmsg2: probing service rpmsg-dce-dsp with src 1024 dst 59
    [    5.401454] rpmsg_rpc rpmsg2: published functions = 8
    [    5.440811]  remoteproc1: powering up 55020000.ipu
    [    5.445623]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3484972
    [    5.454002] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    udevd[1558]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[1568]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    5.543068]  remoteproc1: remote processor 55020000.ipu is now up
    [    5.561141] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.566862]  remoteproc1: registered virtio1 (type 7)
    [    5.569978] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
    [    5.570121] rpmsg_rpc rpmsg3: probing service rpmsg-dce with src 1024 dst 59
    [    5.571526] rpmsg_rpc rpmsg3: published functions = 8
    [    5.857398] (stk) :ldisc installation timeout
    [    5.861598] (stk) :ldisc_install = 0[    6.375689] dwc3 48890000.usb: otg: primary host xhci-hcd.0.auto registered
    [    6.383202] dwc3 48890000.usb: otg: shared host xhci-hcd.0.auto registered
    [    6.390152] dwc3 48890000.usb: otg: can't start till gadget registers
    [    6.396687] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    6.408989] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    6.417609] xhci-hcd xhci-hcd.1.auto: irq 439, io mem 0x488d0000
    [    6.424643] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    6.431670] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    6.439925] usb usb1: Product: xHCI Host Controller
    [    6.444971] usb usb1: Manufacturer: Linux 3.14.49 xhci-hcd
    [    6.450997] usb usb1: SerialNumber: xhci-hcd.1.auto
    [    6.456355] hub 1-0:1.0: USB hub found
    [    6.460575] hub 1-0:1.0: 1 port detected
    [    6.466935] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    6.472698] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    6.481203] using random self ethernet address
    [    6.485667] using random host ethernet address
    [    6.490192] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    6.497008] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    6.504682] usb0: HOST MAC 16:44:21:05:08:ac
    [    6.505953] usb usb2: Product: xHCI Host Controller
    [    6.505957] usb usb2: Manufacturer: Linux 3.14.49 xhci-hcd
    [    6.505961] usb usb2: SerialNumber: xhci-hcd.1.auto
    [    6.524349] usb0: MAC 6e:60:2b:75:d0:b6
    [    6.524823] hub 2-0:1.0: USB hub found
    [    6.524848] hub 2-0:1.0: 1 port detected
    [    6.537477] g_ncm gadget: NCM Gadget
    [    6.546568] g_ncm gadget: g_ncm ready
    [    6.552754] dwc3 48890000.usb: otg: gadget gadget registered
    [    6.558486] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    6.564787] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
    [    6.573012] xhci-hcd xhci-hcd.0.auto: irq 438, io mem 0x48890000
    [    6.579173] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    [    6.585989] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    6.593249] usb usb3: Product: xHCI Host Controller
    [    6.598165] usb usb3: Manufacturer: Linux 3.14.49 xhci-hcd
    [    6.603671] usb usb3: SerialNumber: xhci-hcd.0.auto
    [    6.608963] hub 3-0:1.0: USB hub found
    [    6.612747] hub 3-0:1.0: 1 port detected
    [    6.616911] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    6.624889] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
    [    6.632727] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
    [    6.639555] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    6.646805] usb usb4: Product: xHCI Host Controller
    [    6.651709] usb usb4: Manufacturer: Linux 3.14.49 xhci-hcd
    [    6.657214] usb usb4: SerialNumber: xhci-hcd.0.auto
    [    6.662522] hub 4-0:1.0: USB hub found
    [    6.666304] hub 4-0:1.0: 1 port detected
    [    6.857411] (stk) : timed out waiting for ldisc to be un-installed
    [    6.970457] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
    [    7.970311] (stk) :ldisc_install = 0[    8.015754] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
    bootlogd.
    ALSA: Restoring mixer settings...
    No state is present for card DRA7xxEVM
    Found hardware: "DRA7xx-EVM" "" "" "" ""
    Hardware is initialized using a generic method
    No state is present for card H58040000encode
    Found hardware: "HDMI_58040000_e" "" "" "" ""
    No state is present for card DRA7xxWiLink
    Found hardware: "DRA7xx-WiLink" "" "" "" ""
    INIT: Entering runlevel: 5
    Configuring network interfaces... [    8.570971] net eth0: initializing cpsw version 1.15 (0)
    [    8.661081] net eth0: phy found : id is : 0x20005c7a
    [    8.671835] 8021q: adding VLAN 0 to HW filter on device eth0
    udhcpc (v1.22.1) started
    Sending discover...
    [    8.967418] (stk) : timed out waiting for ldisc to be un-installed
    [    9.080462] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
    [   10.080313] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
    [   11.189147] (stk) :ldisc_install = 1Sending discover...
    [   12.190308] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
    [   13.299144] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
    [   14.300300] (stk) :ldisc_install = 0Sending discover...
    [   15.409136] (stk) :ldisc_install = 1[   16.071677] omap_hwmod: mmu_ipu2: _wait_target_disable failed
    [   16.407412] (stk) :ldisc installation timeout
    [   16.411612] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
    [   17.414141] Bluetooth: st_register failed -22
    No lease, forking to background
    done.
    Starting system message bus: dbus.
    UIM SYSFS Node Found at /sys/./devices/kim/install
    Starting uim-sysfs daemon.
    uim:@ main
    uim:install = /sys/./devices/kim/install
    uim:dev_name = /sys/./devices/kim/dev_name
    uim:baud_rate = /sys/./devices/kim/baud_rate
    uim:flow_cntrl = /sys/./devices/kim/flow_cntrl
    uim:begin polling...
    Starting telnet daemon.
    Starting tiipclad daemon
    GateMP support enabled on host
    Opened log file: lad.txt
    numProcessors = 5 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_dra7xx
    Starting rpcbind daemon...rpcbind: cannot create socket for udp6
    rpcbind: cannot create socket for tcp6
    done.
    creating NFS state directory: done
    starting statd: done
    NFS daemon support not enabled in kernel
    Starting syslogd/klogd: done
    Starting thttpd.
    Enabling thermal zones...
    Stopping Bootlog daemon: bootlogd.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dra7xx-evm /dev/ttyO0
    Arago 2013.10 dra7xx-evm /dev/ttyO0
    dra7xx-evm login:
    and USB1 test logs.
    When connect to PC:
    [  107.982944] g_ncm gadget: high-speed config #1: CDC Ethernet (NCM)
    When connect to a ID-pin ground cable:
    [    7.071070] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    7.077901] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.085157] usb usb1: Product: xHCI Host Controller
    [    7.090076] usb usb1: Manufacturer: Linux 3.14.49 xhci-hcd
    [    7.095709] usb usb1: SerialNumber: xhci-hcd.1.auto
    [    7.101099] hub 1-0:1.0: USB hub found
    [    7.104888] hub 1-0:1.0: 1 port detected
    [    7.109836] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.115483] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    7.123325] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    7.130156] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.137440] usb usb2: Product: xHCI Host Controller
    [    7.142465] usb usb2: Manufacturer: Linux 3.14.49 xhci-hcd
    [    7.148028] usb usb2: SerialNumber: xhci-hcd.1.auto
    [    7.153397] hub 2-0:1.0: USB hub found
    [    7.157190] hub 2-0:1.0: 1 port detected
    [    7.181917] using random self ethernet address
    [    7.186384] using random host ethernet address
    [    7.192219] usb0: HOST MAC 86:ed:52:6c:77:d5
    [    7.196548] usb0: MAC 32:e8:3e:9b:31:0a
    [    7.200451] g_ncm gadget: NCM Gadget
    [    7.204037] g_ncm gadget: g_ncm ready
    [    7.207729] dwc3 48890000.usb: otg: gadget gadget registered
    [    7.213436] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.219460] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
    [    7.228078] xhci-hcd xhci-hcd.0.auto: irq 438, io mem 0x48890000
    [    7.234230] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    [    7.241059] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.248427] usb usb3: Product: xHCI Host Controller
    [    7.253323] usb usb3: Manufacturer: Linux 3.14.49 xhci-hcd
    [    7.258868] usb usb3: SerialNumber: xhci-hcd.0.auto
    [    7.274253] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.282406] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
    [    7.290737] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
    [    7.297576] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.304827] usb usb4: Product: xHCI Host Controller
    [    7.309800] usb usb4: Manufacturer: Linux 3.14.49 xhci-hcd
    [    7.315306] usb usb4: SerialNumber: xhci-hcd.0.auto
    Connect a USB mass storage stick to this Hub
    [  415.216520] usb 3-1: new high-speed USB device number 2 using xhci-hcd
    [  415.367062] usb 3-1: New USB device found, idVendor=0951, idProduct=1613
    [  415.373799] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [  415.381113] usb 3-1: Product: DT 101 II
    [  415.385578] usb 3-1: Manufacturer: Kingston
    [  415.389912] usb 3-1: SerialNumber: 5B8514000036
    [  415.395248] usb-storage 3-1:1.0: USB Mass Storage device detected
    [  415.401811] scsi1 : usb-storage 3-1:1.0
    [  416.397741] scsi 1:0:0:0: Direct-Access     Kingston DT 101 II        PMAP PQ: 0 ANSI: 0 CCS
    [  416.414255] sd 1:0:0:0: Attached scsi generic sg0 type 0
    [  417.843793] sd 1:0:0:0: [sda] 7821312 512-byte logical blocks: (4.00 GB/3.72 GiB)
    [  417.851653] sd 1:0:0:0: [sda] Write Protect is off
    [  417.856704] sd 1:0:0:0: [sda] No Caching mode page found
    [  417.862041] sd 1:0:0:0: [sda] Assuming drive cache: write through
    [  417.870392] sd 1:0:0:0: [sda] No Caching mode page found
    [  417.875730] sd 1:0:0:0: [sda] Assuming drive cache: write through
    [  417.882411]  sda: sda1
    [  417.885994] sd 1:0:0:0: [sda] No Caching mode page found
    [  417.891498] sd 1:0:0:0: [sda] Assuming drive cache: write through
    [  417.897718] sd 1:0:0:0: [sda] Attached SCSI removable disk
    Connect a USB mouse to this Hub
    [ 1426.326505] usb 3-1: new low-speed USB device number 3 using xhci-hcd
    [ 1426.470531] usb 3-1: New USB device found, idVendor=04f3, idProduct=0210
    [ 1426.477371] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
    [ 1426.484540] usb 3-1: Product: PS/2+USB Mouse
    [ 1426.489631] usb 3-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
    [ 1426.506104] input: PS/2+USB Mouse as /devices/44000000.ocp/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.0.auto/usb3/3-1/3-1:1.0/0003:04F3:0210.0001/input/input1
    [ 1426.520966] hid-generic 0003:04F3:0210.0001: input: USB HID v1.11 Mouse [PS/2+USB Mouse] on usb-xhci-hcd.0.auto-1/input0
    And all test are using SDK prebuilt image.
    AC
  • AC,
    So in GLSDK7.02 USB hub is working fine, while in PSDKLA 3.2 it is not working?
    Pavel
  • AC,
    Do you check the wiki pages I have sent? Do you follow these?
    USB HUB is stated as supported feature in the PSDKLA 3.2 data sheet wiki page.
    Pavel
