Part Number: AM4378
Other Parts Discussed in Thread: AM4376
We have AM4378 Evaluation module. Trying to build SDK by referring processors.wiki.ti.com/.../Processor_SDK_Building_The_SDK and followed steps under "Build Steps" section. The build was failed while compiling "qtwebengine". Following is the log snippet. Complete log attached.
| File "/media/disk2/AM4376/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtwebengine/5.6.2+gitAUTOINC+ec84507898_4d61c01b71-r0.arago0.tisdk0/git/src/3rdparty/chromium/build/compiler_version.py", line 127, in DoMain
| raise Exception("Failed to extract compiler version for args: %s" % args)
| Exception: Failed to extract compiler version for args: ['target', 'assembler']
| Project ERROR: -- running gyp_qtwebengine failed --
| Makefile.gyp_run:209: recipe for target 'Makefile.gyp_run' failed
| make[3]: *** [Makefile.gyp_run] Error 3
| make[3]: Leaving directory '/media/disk2/AM4376/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtwebengine/5.6.2+gitAUTOINC+ec84507898_4d61c01b71-r0.arago0.tisdk0/git/src/core'
| Makefile:116: recipe for target 'sub-gyp_run-pro-make_first' failed
| make[2]: *** [sub-gyp_run-pro-make_first] Error 2
| make[2]: Leaving directory '/media/disk2/AM4376/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtwebengine/5.6.2+gitAUTOINC+ec84507898_4d61c01b71-r0.arago0.tisdk0/git/src/core'
| Makefile:49: recipe for target 'sub-core-make_first' failed
| make[1]: *** [sub-core-make_first] Error 2
| make[1]: Leaving directory '/media/disk2/AM4376/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtwebengine/5.6.2+gitAUTOINC+ec84507898_4d61c01b71-r0.arago0.tisdk0/git/src'
| Makefile:44: recipe for target 'sub-src-make_first' failed
| make: *** [sub-src-make_first] Error 2
| ERROR: oe_runmake failed
Can you help on fixing build issue "qtwebengine".
