Part Number: AM5728
I was writing a driver for PMIC chip to control TF slot voltage up and down. Registers reading/writing were OK. So I want to measure if the voltage was changed. I used a multimeter to measure some resistors near the TF slot. After a while, I found the the shell hanged. Then I rebooted the board and found u-boot can not show from the serial port. I thought I may shorten the circuit or it may be damaged by static charge.
The power button can't work anymore. Is there a way can save it?
Thanks you,
