Error when rebuilding the DVSDK for EVM6446
Hello, I am following the GSG (SPRUE66F) chapter 4"software setup" for my EVM6446 board.
When I am rebuilding the DVSDK Software (with "make" in in /home/user/dvsdk_2_00_00_22/), I get the following two errors:
======== Building linux/image_decode_io_dm6446 ========
configuring image_decode_io_dm6446.x470MV from package/cfg/image_decode_io_dm6446_x470MV.cfg ...
      Failed to create engine "decode" since "ti.sdo.servers.jpegdec_unitserver_evmdm6446" could not be found in the XDC_PATH, continuing build..
======== Building linux/image_encode_io_dm6446 ========
configuring image_encode_io_dm6446.x470MV from package/cfg/image_encode_io_dm6446_x470MV.cfg ...
      Failed to create engine "encode" since "ti.sdo.servers.jpegenc_unitserver_evmdm6446" could not be found in the XDC_PATH, continuing build..
How I could get rid of these error ? Are these errors relevant ?
Thanks and best regards, Sara
Configuring application using linux/image_decode_io_dm6446.cfg
making package.mak (because of package.bld) ...
generating interfaces for package image_decode_io_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    will link with ti.sdo.dmai:lib/dmai_linux_dm6446.a470MV
    will link with ti.sdo.ce.image1:lib/release/imgdec1.av5T;lib/release/imgenc1.av5T
    will link with ti.sdo.ce.image:lib/release/image.av5T
    will link with ti.sdo.ce.video2:lib/release/viddec2.av5T
    will link with ti.sdo.ce.video1:lib/release/viddec1.av5T;lib/release/videnc1.av5T
    will link with ti.sdo.ce.video:lib/release/video.av5T
    will link with ti.sdo.ce.audio1:lib/release/auddec1.av5T;lib/release/audenc1.av5T
    will link with ti.sdo.ce.audio:lib/release/audio.av5T
    will link with ti.sdo.ce.speech1:lib/release/sphdec1.av5T;lib/release/sphenc1.av5T
    will link with ti.sdo.ce.speech:lib/release/speech.av5T
    will link with ti.sdo.ce:lib/release/ce.av5T
    will link with ti.sdo.ce.alg:lib/release/Algorithm_noOS.av5T;lib/release/alg.av5T
    will link with ti.sdo.ce.ipc.linux:lib/release/ipc_linux.av5T
    will link with ti.sdo.ce.osal.linux:lib/release/osal_linux_470.av5T
    will link with ti.sdo.fc.acpy3:lib/release/acpy3.a470MV
    will link with ti.sdo.fc.memutils:lib/release/memutils.a470MV
    will link with ti.sdo.linuxutils.cmem:lib/cmem.a470MV
    will link with ti.sdo.fc.dman3:lib/release/dman3Cfg.a470MV
    will link with ti.sdo.ce.node:lib/release/node.av5T
    will link with ti.sdo.ce.utils.xdm:lib/release/XdmUtils.av5T
    will link with ti.sdo.utils.trace:lib/release/gt.a470MV
cl470MV package/cfg/image_decode_io_dm6446_x470MV.c ...
Compiling appMain.dm6446.o470MV from appMain.c..
Compiling linux/main.dm6446.o470MV from linux/main.c..
Linking linux/image_decode_io_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/image_decode_io_dm6446_config/linker.cmd /home/user/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
make[3]: Leaving directory `/home/user/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_decode_io'
Configuring application using linux/image_encode_io_dm6446.cfg
generating interfaces for package image_encode_io_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
cl470MV package/cfg/image_encode_io_dm6446_x470MV.c ...
Linking linux/image_encode_io_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/image_encode_io_dm6446_config/linker.cmd /home/user/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
make[3]: Leaving directory `/home/user/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_encode_io'
  • It seems like it is having trouble finding the DSP codec servers.  Have you installed the DM6446 CODECS For 2_00_00_22 file available at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/S1SDKLNX/DVSDK_2_00/index_FDS.html ?
  • Hello
    I am using DM6441 MV4.0.1 kernel 2.6.10.xx.
    I run my application base video with COMS sensor, but I got DSP/CPU Freeze while this message is came:
     Warning: kfree_skb on hard IRQ c01ef20c
    Can you know what is meaning? And what need to solve it?
  • Eran,
    So what sensor are you running it with and how did you get support for these sensor under the kernel... to my knowledge there is only support for a couple of sensors in our DVSDK 1.20 (DM6441 MV4.0.1 kernel 2.6.10.xx) and these require custom hardware not available externally; for this reason Leopard Images has built a series of sensor daughter cards that are widely available to our customers along with software to support these daughter cards.
  • Juan
    I"m use exactly the Leopard LI-5M01 card for develop on DVEVM ( MT9P031 Micron sensor) but now I working with our board design with the same sensor.
    But how this error are associate with the sensor.
    My kernel out this error message moment before she die.
    Do you have idea way?
  • I am not familiar with the sensor software from Leopard Imaging; the support for this software/hardware solution is thru them and I believe they even offer engineering services if you need to get this working on your custome board.
    I am not too familiar with the error above but it seems to indicate you should not be calling the version of this function from the IRQ handler.  I believe there is an irq safe version of the call.  Unfortunately, this is Linux programing that is out of my expertise and hence beyond the scope of what I can help you with.
  • Hi Jaun,
     I am facing exactly the same problem as  Sara Grassi  is facing.
    I have installed the dm6446_codecs_setuplinux_2_00_00_22 which is downloaded from the link which you mentioned. http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/dvsdk/DVSDK_2_00/latest/index_FDS.html
    Please help me out.
    Thanks.
  • Attaching the log for make
    make clean
    make -C /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module clean
    make[1]: Entering directory `/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module'
    rm -rf *.o *mod* *.ko .cmem* .tmp*
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module'
    make -C /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/interface clean
    make[1]: Entering directory `/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/interface'
    rm -rf release debug *~
    rm -f ../../lib/cmemd.a470MV ../../lib/cmemd.a470uC ../../lib/cmem.a470MV ../../lib/cmem.a470uC
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/interface'
    make -C /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06 clean
    make[1]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06'
    make -C /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai clean
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai'
    Removing generated files..
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai'
    make -C /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps clean
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_decode1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_decode1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_decode_io'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_decode_io'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_decode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_decode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_encode1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_encode1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_encode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/audio_encode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_decode_io'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_decode_io'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_decode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_decode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_encode_io'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_encode_io'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_encode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/image_encode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_decode1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_decode1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_decode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_decode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_encode1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_encode1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_encode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/speech_encode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_decode_io'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_decode_io'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_decode_io2'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_decode_io2'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_display'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_display'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_encode_io'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_encode_io'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_encode_io1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_encode_io1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_encode_io_multich1'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_encode_io_multich1'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_blend'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_blend'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_convert'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_convert'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_copy'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_copy'
    make[3]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_resize'
    make[3]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/video_loopback_resize'
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps'
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06'
    make -C /home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446 clean
    make[1]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446'
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/decode'
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/decode'
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/encode'
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/encode'
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/encodedecode'
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/encodedecode'
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/interface'
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/interface'
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446'
    make -C examples/dm6446 clean
    make[1]: Entering directory `/home/aditya/dvsdk_2_00_00_22/examples/dm6446'
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/examples/dm6446'
    make -C /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08 clean
    make[1]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08'
    DVTB : Cleaning sub-directory "packages/ti/sdo/dvtb/dm355"...
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm355'
    rm -rf linux/dvtbApisDispatcher.rel.o linux/dvtbAppInit.rel.o linux/dvtbDVREnc.rel.o linux/dvtbDVREncDec.rel.o linux/dvtbDVRUC0.rel.o linux/dvtbFuncDispatcher.rel.o linux/dvtbImgCapture1.rel.o linux/dvtbImgDec1.rel.o linux/dvtbImgDisplay1.rel.o linux/dvtbImgEnc1.rel.o linux/dvtbIPNCUC0.rel.o linux/dvtbIPNCUC1.rel.o linux/dvtbIPNCUC2.rel.o linux/dvtbJPEGCapture1.rel.o linux/dvtbJPEGDec1.rel.o linux/dvtbJPEGDisplay1.rel.o linux/dvtbJPEGEnc1.rel.o linux/dvtbMPEG4SPCapture1.rel.o linux/dvtbMPEG4SPDec2.rel.o linux/dvtbMPEG4SPEnc1.rel.o linux/dvtbMPEG4SPPlay2.rel.o linux/dvtbParam.rel.o linux/dvtbSphCapture1.rel.o linux/dvtbSphCapture.rel.o linux/dvtbSphDec1.rel.o linux/dvtbSphDec.rel.o linux/dvtbSphEnc1.rel.o linux/dvtbSphEnc.rel.o linux/dvtbSphPlay1.rel.o linux/dvtbSphPlay.rel.o linux/dvtbVidCapture1.rel.o linux/dvtbVidDec2.rel.o linux/dvtbVidEnc1.rel.o linux/dvtbVidPlay2.rel.o ../core/linux/dvtbDispatcher.rel.o ../core/linux/dvtbEngine.rel.o ../core/linux/dvtbGetParam.rel.o ../core/linux/dvtbMain.rel.o ../core/linux/dvtbMemory.rel.o ../core/linux/dvtbSetParam.rel.o ../core/linux/dvtbThread.rel.o ../core/linux/dvtbVersion.rel.o ../pal/linux/v4l2/dvtbV4L2VPBE.rel.o ../pal/linux/v4l2/dvtbV4L2VPFE.rel.o ../pal/linux/alsa/dvtbALSAAudio.rel.o
    rm -rf ./bin/dvtb-r.a
    rm -rf linux/dvtbApisDispatcher.dbg.o linux/dvtbAppInit.dbg.o linux/dvtbDVREnc.dbg.o linux/dvtbDVREncDec.dbg.o linux/dvtbDVRUC0.dbg.o linux/dvtbFuncDispatcher.dbg.o linux/dvtbImgCapture1.dbg.o linux/dvtbImgDec1.dbg.o linux/dvtbImgDisplay1.dbg.o linux/dvtbImgEnc1.dbg.o linux/dvtbIPNCUC0.dbg.o linux/dvtbIPNCUC1.dbg.o linux/dvtbIPNCUC2.dbg.o linux/dvtbJPEGCapture1.dbg.o linux/dvtbJPEGDec1.dbg.o linux/dvtbJPEGDisplay1.dbg.o linux/dvtbJPEGEnc1.dbg.o linux/dvtbMPEG4SPCapture1.dbg.o linux/dvtbMPEG4SPDec2.dbg.o linux/dvtbMPEG4SPEnc1.dbg.o linux/dvtbMPEG4SPPlay2.dbg.o linux/dvtbParam.dbg.o linux/dvtbSphCapture1.dbg.o linux/dvtbSphCapture.dbg.o linux/dvtbSphDec1.dbg.o linux/dvtbSphDec.dbg.o linux/dvtbSphEnc1.dbg.o linux/dvtbSphEnc.dbg.o linux/dvtbSphPlay1.dbg.o linux/dvtbSphPlay.dbg.o linux/dvtbVidCapture1.dbg.o linux/dvtbVidDec2.dbg.o linux/dvtbVidEnc1.dbg.o linux/dvtbVidPlay2.dbg.o ../core/linux/dvtbDispatcher.dbg.o ../core/linux/dvtbEngine.dbg.o ../core/linux/dvtbGetParam.dbg.o ../core/linux/dvtbMain.dbg.o ../core/linux/dvtbMemory.dbg.o ../core/linux/dvtbSetParam.dbg.o ../core/linux/dvtbThread.dbg.o ../core/linux/dvtbVersion.dbg.o ../pal/linux/v4l2/dvtbV4L2VPBE.dbg.o ../pal/linux/v4l2/dvtbV4L2VPFE.dbg.o ../pal/linux/alsa/dvtbALSAAudio.dbg.o
    rm -rf ./bin/dvtb-d.a
    rm -rf ./bin/dvtb-r
    rm -rf ./bin/dvtb-d
    rm -rf ./bin
    rm -rf dvtb_dm355
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm355'
    DVTB : Cleaning sub-directory "packages/ti/sdo/dvtb/dm6446"...
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446'
    rm -rf ./bin/dvtb-r
    rm -rf linux/dvtbAACHECapture1.rel.o linux/dvtbAACHEEnc1.rel.o linux/dvtbAACLCCapture1.rel.o linux/dvtbAACLCEnc1.rel.o linux/dvtbApisDispatcher.rel.o linux/dvtbAppInit.rel.o linux/dvtbAudCapture1.rel.o linux/dvtbAudCapture.rel.o linux/dvtbAudDec1.rel.o linux/dvtbAudDec.rel.o linux/dvtbAudEnc1.rel.o linux/dvtbAudEnc.rel.o linux/dvtbAudPlay1.rel.o linux/dvtbAudPlay.rel.o linux/dvtbFuncDispatcher.rel.o linux/dvtbImgCapture1.rel.o linux/dvtbImgCapture.rel.o linux/dvtbImgDec1.rel.o linux/dvtbImgDec.rel.o linux/dvtbImgDisplay1.rel.o linux/dvtbImgDisplay.rel.o linux/dvtbImgEnc1.rel.o linux/dvtbImgEnc.rel.o linux/dvtbMP3BaseDec1.rel.o linux/dvtbMP3BaseDec.rel.o linux/dvtbMP3BasePlay1.rel.o linux/dvtbMP3BasePlay.rel.o linux/dvtbParam.rel.o linux/dvtbSphCapture1.rel.o linux/dvtbSphCapture.rel.o linux/dvtbSphDec1.rel.o linux/dvtbSphDec.rel.o linux/dvtbSphEnc1.rel.o linux/dvtbSphEnc.rel.o linux/dvtbSphPlay1.rel.o linux/dvtbSphPlay.rel.o linux/dvtbVidCapture1.rel.o linux/dvtbVidCapture.rel.o linux/dvtbVidDec2.rel.o linux/dvtbVidDec.rel.o linux/dvtbVidEnc1.rel.o linux/dvtbVidEnc.rel.o linux/dvtbVidLoopback1.rel.o linux/dvtbVidPlay2.rel.o linux/dvtbVidPlay.rel.o ../core/linux/dvtbDispatcher.rel.o ../core/linux/dvtbEngine.rel.o ../core/linux/dvtbGetParam.rel.o ../core/linux/dvtbMain.rel.o ../core/linux/dvtbMemory.rel.o ../core/linux/dvtbSetParam.rel.o ../core/linux/dvtbThread.rel.o ../core/linux/dvtbVersion.rel.o ../pal/linux/v4l2/dvtbV4L2VPBE.rel.o ../pal/linux/v4l2/dvtbV4L2VPFE.rel.o ../pal/linux/alsa/dvtbALSAAudio.rel.o
    rm -rf ./bin/dvtb-d
    rm -rf linux/dvtbAACHECapture1.dbg.o linux/dvtbAACHEEnc1.dbg.o linux/dvtbAACLCCapture1.dbg.o linux/dvtbAACLCEnc1.dbg.o linux/dvtbApisDispatcher.dbg.o linux/dvtbAppInit.dbg.o linux/dvtbAudCapture1.dbg.o linux/dvtbAudCapture.dbg.o linux/dvtbAudDec1.dbg.o linux/dvtbAudDec.dbg.o linux/dvtbAudEnc1.dbg.o linux/dvtbAudEnc.dbg.o linux/dvtbAudPlay1.dbg.o linux/dvtbAudPlay.dbg.o linux/dvtbFuncDispatcher.dbg.o linux/dvtbImgCapture1.dbg.o linux/dvtbImgCapture.dbg.o linux/dvtbImgDec1.dbg.o linux/dvtbImgDec.dbg.o linux/dvtbImgDisplay1.dbg.o linux/dvtbImgDisplay.dbg.o linux/dvtbImgEnc1.dbg.o linux/dvtbImgEnc.dbg.o linux/dvtbMP3BaseDec1.dbg.o linux/dvtbMP3BaseDec.dbg.o linux/dvtbMP3BasePlay1.dbg.o linux/dvtbMP3BasePlay.dbg.o linux/dvtbParam.dbg.o linux/dvtbSphCapture1.dbg.o linux/dvtbSphCapture.dbg.o linux/dvtbSphDec1.dbg.o linux/dvtbSphDec.dbg.o linux/dvtbSphEnc1.dbg.o linux/dvtbSphEnc.dbg.o linux/dvtbSphPlay1.dbg.o linux/dvtbSphPlay.dbg.o linux/dvtbVidCapture1.dbg.o linux/dvtbVidCapture.dbg.o linux/dvtbVidDec2.dbg.o linux/dvtbVidDec.dbg.o linux/dvtbVidEnc1.dbg.o linux/dvtbVidEnc.dbg.o linux/dvtbVidLoopback1.dbg.o linux/dvtbVidPlay2.dbg.o linux/dvtbVidPlay.dbg.o ../core/linux/dvtbDispatcher.dbg.o ../core/linux/dvtbEngine.dbg.o ../core/linux/dvtbGetParam.dbg.o ../core/linux/dvtbMain.dbg.o ../core/linux/dvtbMemory.dbg.o ../core/linux/dvtbSetParam.dbg.o ../core/linux/dvtbThread.dbg.o ../core/linux/dvtbVersion.dbg.o ../pal/linux/v4l2/dvtbV4L2VPBE.dbg.o ../pal/linux/v4l2/dvtbV4L2VPFE.dbg.o ../pal/linux/alsa/dvtbALSAAudio.dbg.o
    rm -rf ./bin
    rm -rf dvtb_dm6446
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446'
    DVTB : Cleaning sub-directory "packages/ti/sdo/dvtb/dm6467"...
    make[2]: Entering directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6467'
    rm -rf linux/dvtbAACCapture.rel.o linux/dvtbAACEnc.rel.o linux/dvtbAACHECapture1.rel.o linux/dvtbAACHEEnc1.rel.o linux/dvtbApisDispatcher.rel.o linux/dvtbAppInit.rel.o linux/dvtbAudCapture1.rel.o linux/dvtbAudCapture.rel.o linux/dvtbAudDec1.rel.o linux/dvtbAudDec.rel.o linux/dvtbAudEnc1.rel.o linux/dvtbAudEnc.rel.o linux/dvtbAudPlay1.rel.o linux/dvtbAudPlay.rel.o linux/dvtbFuncDispatcher.rel.o linux/dvtbH264Capture1.rel.o linux/dvtbH264Enc1.rel.o linux/dvtbParam.rel.o linux/dvtbSphCapture1.rel.o linux/dvtbSphCapture.rel.o linux/dvtbSphDec1.rel.o linux/dvtbSphDec.rel.o linux/dvtbSphEnc1.rel.o linux/dvtbSphEnc.rel.o linux/dvtbSphPlay1.rel.o linux/dvtbSphPlay.rel.o linux/dvtbUtils.rel.o linux/dvtbVdce.rel.o linux/dvtbVidCapture1.rel.o linux/dvtbVidDec2.rel.o linux/dvtbVidEnc1.rel.o linux/dvtbVidLoopback1.rel.o linux/dvtbVidPlay2.rel.o ../core/linux/dvtbDispatcher.rel.o ../core/linux/dvtbEngine.rel.o ../core/linux/dvtbGetParam.rel.o ../core/linux/dvtbMain.rel.o ../core/linux/dvtbMemory.rel.o ../core/linux/dvtbSetParam.rel.o ../core/linux/dvtbThread.rel.o ../core/linux/dvtbVersion.rel.o ../pal/linux/v4l2/dvtbV4L2VPBE.rel.o ../pal/linux/v4l2/dvtbV4L2VPFE.rel.o ../pal/linux/alsa/dvtbALSAAudio.rel.o linux/dvtbAACCapture.dbg.o linux/dvtbAACEnc.dbg.o linux/dvtbAACHECapture1.dbg.o linux/dvtbAACHEEnc1.dbg.o linux/dvtbApisDispatcher.dbg.o linux/dvtbAppInit.dbg.o linux/dvtbAudCapture1.dbg.o linux/dvtbAudCapture.dbg.o linux/dvtbAudDec1.dbg.o linux/dvtbAudDec.dbg.o linux/dvtbAudEnc1.dbg.o linux/dvtbAudEnc.dbg.o linux/dvtbAudPlay1.dbg.o linux/dvtbAudPlay.dbg.o linux/dvtbFuncDispatcher.dbg.o linux/dvtbH264Capture1.dbg.o linux/dvtbH264Enc1.dbg.o linux/dvtbParam.dbg.o linux/dvtbSphCapture1.dbg.o linux/dvtbSphCapture.dbg.o linux/dvtbSphDec1.dbg.o linux/dvtbSphDec.dbg.o linux/dvtbSphEnc1.dbg.o linux/dvtbSphEnc.dbg.o linux/dvtbSphPlay1.dbg.o linux/dvtbSphPlay.dbg.o linux/dvtbUtils.dbg.o linux/dvtbVdce.dbg.o linux/dvtbVidCapture1.dbg.o linux/dvtbVidDec2.dbg.o linux/dvtbVidEnc1.dbg.o linux/dvtbVidLoopback1.dbg.o linux/dvtbVidPlay2.dbg.o ../core/linux/dvtbDispatcher.dbg.o ../core/linux/dvtbEngine.dbg.o ../core/linux/dvtbGetParam.dbg.o ../core/linux/dvtbMain.dbg.o ../core/linux/dvtbMemory.dbg.o ../core/linux/dvtbSetParam.dbg.o ../core/linux/dvtbThread.dbg.o ../core/linux/dvtbVersion.dbg.o ../pal/linux/v4l2/dvtbV4L2VPBE.dbg.o ../pal/linux/v4l2/dvtbV4L2VPFE.dbg.o ../pal/linux/alsa/dvtbALSAAudio.dbg.o
    rm -rf ./bin/dvtb-r
    rm -rf ./bin/dvtb-d
    rm -rf ./bin
    rm -rf dvtb_dm6467
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6467'
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08'
    [aditya@localhost dvsdk_2_00_00_22]$
    [aditya@localhost dvsdk_2_00_00_22]$ make
    Checking that components in Rules.make are found:
    Done checking! If no warning messages above, all components are found..
    make -C /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/interface ../../lib/cmem.a470MV
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I. -Wall  -c -O2 -o release/cmem.o470MV cmem.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-ar rc ../../lib/cmem.a470MV release/cmem.o470MV
    make -C /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500 M=`pwd` ARCH=arm CROSS_COMPILE=/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le- \
    EXTRA_CFLAGS="-DUSE_UDEV=1 -DMAX_POOLS=128" modules
    make[2]: Entering directory `/home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500'
      WARNING: Symbol version dump /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/Module.symvers
               is missing; modules will have no dependencies and modversions.
      CC [M]  /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.o
    /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c:61:2: warning: #warning *** not a warning *** Note: 2.6.26 > LINUX_VERSION_CODE >= 2.6.18
      Building modules, stage 2.
      MODPOST
      CC      /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.mod.o
      LD [M]  /home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.ko
    make[2]: Leaving directory `/home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500'
    cmemk.ko kernel module can be found under /home/aditya/dvsdk_2_00_00_22/kernel_binaries/dm6446
    make -C /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06 dm6446_al
    Compiling obj/Buffer.dm6446.o470MV from Buffer.c..
    Compiling obj/BufferGfx.dm6446.o470MV from BufferGfx.c..
    Compiling obj/BufTab.dm6446.o470MV from BufTab.c..
    Compiling obj/Ccv.dm6446.o470MV from Ccv.c..
    Compiling obj/ColorSpace.dm6446.o470MV from ColorSpace.c..
    Compiling obj/Framecopy.dm6446.o470MV from Framecopy.c..
    Compiling obj/Loader.dm6446.o470MV from Loader.c..
    Compiling obj/VideoStd.dm6446.o470MV from VideoStd.c..
    Compiling obj/ce/Adec1.dm6446.o470MV from ce/Adec1.c..
    Compiling obj/ce/Adec.dm6446.o470MV from ce/Adec.c..
    Compiling obj/ce/Aenc1.dm6446.o470MV from ce/Aenc1.c..
    Compiling obj/ce/Aenc.dm6446.o470MV from ce/Aenc.c..
    Compiling obj/ce/Idec1.dm6446.o470MV from ce/Idec1.c..
    Compiling obj/ce/Idec.dm6446.o470MV from ce/Idec.c..
    Compiling obj/ce/Ienc1.dm6446.o470MV from ce/Ienc1.c..
    Compiling obj/ce/Ienc.dm6446.o470MV from ce/Ienc.c..
    Compiling obj/ce/Sdec1.dm6446.o470MV from ce/Sdec1.c..
    Compiling obj/ce/Sdec.dm6446.o470MV from ce/Sdec.c..
    Compiling obj/ce/Senc1.dm6446.o470MV from ce/Senc1.c..
    Compiling obj/ce/Senc.dm6446.o470MV from ce/Senc.c..
    Compiling obj/ce/Vdec2.dm6446.o470MV from ce/Vdec2.c..
    Compiling obj/ce/Vdec.dm6446.o470MV from ce/Vdec.c..
    Compiling obj/ce/Venc1.dm6446.o470MV from ce/Venc1.c..
    Compiling obj/ce/Venc.dm6446.o470MV from ce/Venc.c..
    Compiling obj/linux/Capture.dm6446.o470MV from linux/Capture.c..
    Compiling obj/linux/Cpu.dm6446.o470MV from linux/Cpu.c..
    Compiling obj/linux/Display.dm6446.o470MV from linux/Display.c..
    Compiling obj/linux/Display_fbdev.dm6446.o470MV from linux/Display_fbdev.c..
    Compiling obj/linux/Display_v4l2.dm6446.o470MV from linux/Display_v4l2.c..
    Compiling obj/linux/Dmai.dm6446.o470MV from linux/Dmai.c..
    Compiling obj/linux/Fifo.dm6446.o470MV from linux/Fifo.c..
    Compiling obj/linux/Pause.dm6446.o470MV from linux/Pause.c..
    Compiling obj/linux/Rendezvous.dm6446.o470MV from linux/Rendezvous.c..
    Compiling obj/linux/Sound_alsa.dm6446.o470MV from linux/Sound_alsa.c..
    Compiling obj/linux/Sound.dm6446.o470MV from linux/Sound.c..
    Compiling obj/linux/Sound_oss.dm6446.o470MV from linux/Sound_oss.c..
    Compiling obj/linux/_SysFs.dm6446.o470MV from linux/_SysFs.c..
    Compiling obj/linux/Time.dm6446.o470MV from linux/Time.c..
    Compiling obj/linux/_VideoBuf.dm6446.o470MV from linux/_VideoBuf.c..
    Compiling obj/linux/dm6446/Blend.dm6446.o470MV from linux/dm6446/Blend.c..
    Compiling obj/linux/dm6446/Ccv_accel.dm6446.o470MV from linux/dm6446/Ccv_accel.c..
    Compiling obj/linux/dm6446/Framecopy_accel.dm6446.o470MV from linux/dm6446/Framecopy_accel.c..
    Compiling obj/linux/dm6446/Ir.dm6446.o470MV from linux/dm6446/Ir.c..
    Compiling obj/linux/dm6446/Resize.dm6446.o470MV from linux/dm6446/Resize.c..
    Compiling obj/linux/dm6446/Resize_precalc.dm6446.o470MV from linux/dm6446/Resize_precalc.c..
    Compiling obj/linux/dm6446/Smooth.dm6446.o470MV from linux/dm6446/Smooth.c..
    Archiving lib/dmai_linux_dm6446.a470MV from obj/Buffer.dm6446.o470MV obj/BufferGfx.dm6446.o470MV obj/BufTab.dm6446.o470MV obj/Ccv.dm6446.o470MV obj/ColorSpace.dm6446.o470MV obj/Framecopy.dm6446.o470MV obj/Loader.dm6446.o470MV obj/VideoStd.dm6446.o470MV obj/ce/Adec1.dm6446.o470MV obj/ce/Adec.dm6446.o470MV obj/ce/Aenc1.dm6446.o470MV obj/ce/Aenc.dm6446.o470MV obj/ce/Idec1.dm6446.o470MV obj/ce/Idec.dm6446.o470MV obj/ce/Ienc1.dm6446.o470MV obj/ce/Ienc.dm6446.o470MV obj/ce/Sdec1.dm6446.o470MV obj/ce/Sdec.dm6446.o470MV obj/ce/Senc1.dm6446.o470MV obj/ce/Senc.dm6446.o470MV obj/ce/Vdec2.dm6446.o470MV obj/ce/Vdec.dm6446.o470MV obj/ce/Venc1.dm6446.o470MV obj/ce/Venc.dm6446.o470MV obj/linux/Capture.dm6446.o470MV obj/linux/Cpu.dm6446.o470MV obj/linux/Display.dm6446.o470MV obj/linux/Display_fbdev.dm6446.o470MV obj/linux/Display_v4l2.dm6446.o470MV obj/linux/Dmai.dm6446.o470MV obj/linux/Fifo.dm6446.o470MV obj/linux/Pause.dm6446.o470MV obj/linux/Rendezvous.dm6446.o470MV obj/linux/Sound_alsa.dm6446.o470MV obj/linux/Sound.dm6446.o470MV obj/linux/Sound_oss.dm6446.o470MV obj/linux/_SysFs.dm6446.o470MV obj/linux/Time.dm6446.o470MV obj/linux/_VideoBuf.dm6446.o470MV obj/linux/dm6446/Blend.dm6446.o470MV obj/linux/dm6446/Ccv_accel.dm6446.o470MV obj/linux/dm6446/Framecopy_accel.dm6446.o470MV obj/linux/dm6446/Ir.dm6446.o470MV obj/linux/dm6446/Resize.dm6446.o470MV obj/linux/dm6446/Resize_precalc.dm6446.o470MV obj/linux/dm6446/Smooth.dm6446.o470MV..
    Building package interface for dmai..
    generating interfaces for package ti.sdo.dmai (because package/package.xdc.inc is older than package.xdc) ...
    all files complete.
    Executing make dm6446_al in subdirectory audio_decode1/...
    ======== Building linux/audio_decode1_dm6446 ========
    Configuring application using linux/audio_decode1_dm6446.cfg
    generating interfaces for package audio_decode1_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring audio_decode1_dm6446.x470MV from package/cfg/audio_decode1_dm6446_x470MV.cfg ...
    Info: Configuring engine named 'decode' from the info file for DSP server './decodeCombo.x64P',
              located in package 'ti.sdo.servers.decode':
          Target app will look for the DSP server image 'decodeCombo.x64P' in its current directory.
          Adding codec 'h264dec' (ti.sdo.codecs.h264dec.ce.H264DEC), scratch groupId=0
          Adding codec 'mpeg2dec' (ti.sdo.codecs.mpeg2dec.ce.MPEG2DEC), scratch groupId=0
          Adding codec 'mpeg4dec' (ti.sdo.codecs.mpeg4dec.ce.MPEG4DEC), scratch groupId=0
          Adding codec 'aachedec' (ti.sdo.codecs.aachedec.ce.AACHEDEC), scratch groupId=1
          Adding codec 'g711dec' (ti.sdo.codecs.g711dec.ce.G711DEC), scratch groupId=1
    Info: Reading DSP memory map from the info file for DSP server './decodeCombo.x64P',
    warning: ti.catalog.c470.TMS320CDM6446: "/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages/ti/catalog/c470/package.xs", line 29: ti.catalog.c470 : Module ti.catalog.c470.TMS320CDM6446 is used in this configuration. All modules from the package 'ti.catalog.c470' should be replaced with modules with the same name from the package 'ti.catalog.arm'
        will link with ti.sdo.ce.ipc.dsplink:lib/release/ipc_dsplink_6446.av5T
        will link with dsplink.gpp:export/BIN/Linux/DAVINCI/RELEASE/dsplink.lib
    cl470MV package/cfg/audio_decode1_dm6446_x470MV.c ...
    Linking linux/audio_decode1_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/audio_decode1_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory audio_decode_io/...
    make[3]: Nothing to be done for `dm6446_al'.
    Executing make dm6446_al in subdirectory audio_decode_io1/...
    ======== Building linux/audio_decode_io1_dm6446 ========
    Configuring application using linux/audio_decode_io1_dm6446.cfg
    generating interfaces for package audio_decode_io1_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring audio_decode_io1_dm6446.x470MV from package/cfg/audio_decode_io1_dm6446_x470MV.cfg ...
    cl470MV package/cfg/audio_decode_io1_dm6446_x470MV.c ...
    Linking linux/audio_decode_io1_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/audio_decode_io1_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory audio_encode1/...
    Executing make dm6446_al in subdirectory audio_encode_io1/...
    Executing make dm6446_al in subdirectory image_decode_io/...
    Linking linux/image_decode_io_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/image_decode_io_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory image_decode_io1/...
    Executing make dm6446_al in subdirectory image_encode_io/...
    Linking linux/image_encode_io_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/image_encode_io_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory image_encode_io1/...
    Executing make dm6446_al in subdirectory speech_decode1/...
    ======== Building linux/speech_decode1_dm6446 ========
    Configuring application using linux/speech_decode1_dm6446.cfg
    generating interfaces for package speech_decode1_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring speech_decode1_dm6446.x470MV from package/cfg/speech_decode1_dm6446_x470MV.cfg ...
    cl470MV package/cfg/speech_decode1_dm6446_x470MV.c ...
    Linking linux/speech_decode1_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/speech_decode1_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory speech_decode_io1/...
    ======== Building linux/speech_decode_io1_dm6446 ========
    Configuring application using linux/speech_decode_io1_dm6446.cfg
    generating interfaces for package speech_decode_io1_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring speech_decode_io1_dm6446.x470MV from package/cfg/speech_decode_io1_dm6446_x470MV.cfg ...
    cl470MV package/cfg/speech_decode_io1_dm6446_x470MV.c ...
    Linking linux/speech_decode_io1_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/speech_decode_io1_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory speech_encode1/...
    Executing make dm6446_al in subdirectory speech_encode_io1/...
    Executing make dm6446_al in subdirectory video_decode_io/...
    Executing make dm6446_al in subdirectory video_decode_io2/...
    ======== Building linux/video_decode_io2_dm6446 ========
    Configuring application using linux/video_decode_io2_dm6446.cfg
    generating interfaces for package video_decode_io2_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring video_decode_io2_dm6446.x470MV from package/cfg/video_decode_io2_dm6446_x470MV.cfg ...
    cl470MV package/cfg/video_decode_io2_dm6446_x470MV.c ...
    Linking linux/video_decode_io2_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/video_decode_io2_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory video_display/...
    ======== Building linux/video_display_dm6446 ========
    Configuring application using linux/video_display_dm6446.cfg
    generating interfaces for package video_display_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring video_display_dm6446.x470MV from package/cfg/video_display_dm6446_x470MV.cfg ...
    cl470MV package/cfg/video_display_dm6446_x470MV.c ...
    Linking linux/video_display_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/video_display_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory video_encode_io/...
    Executing make dm6446_al in subdirectory video_encode_io1/...
    ======== Building linux/video_encode_io1_dm6446 ========
    Configuring application using linux/video_encode_io1_dm6446.cfg
    generating interfaces for package video_encode_io1_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring video_encode_io1_dm6446.x470MV from package/cfg/video_encode_io1_dm6446_x470MV.cfg ...
    Info: Configuring engine named 'encode' from the info file for DSP server './encodeCombo.x64P',
              located in package 'ti.sdo.servers.encode':
          Target app will look for the DSP server image 'encodeCombo.x64P' in its current directory.
          Adding codec 'h264enc' (ti.sdo.codecs.h264enc.ce.H264ENC), scratch groupId=0
          Adding codec 'mpeg4enc' (ti.sdo.codecs.mpeg4enc.ce.MPEG4ENC), scratch groupId=0
          Adding codec 'g711enc' (ti.sdo.codecs.g711enc.ce.G711ENC), scratch groupId=1
    Info: Reading DSP memory map from the info file for DSP server './encodeCombo.x64P',
    cl470MV package/cfg/video_encode_io1_dm6446_x470MV.c ...
    Linking linux/video_encode_io1_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/video_encode_io1_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory video_encode_io_multich1/...
    Executing make dm6446_al in subdirectory video_loopback/...
    Executing make dm6446_al in subdirectory video_loopback_blend/...
    Executing make dm6446_al in subdirectory video_loopback_convert/...
    Executing make dm6446_al in subdirectory video_loopback_copy/...
    ======== Building linux/video_loopback_copy_dm6446 ========
    Configuring application using linux/video_loopback_copy_dm6446.cfg
    generating interfaces for package video_loopback_copy_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring video_loopback_copy_dm6446.x470MV from package/cfg/video_loopback_copy_dm6446_x470MV.cfg ...
    cl470MV package/cfg/video_loopback_copy_dm6446_x470MV.c ...
    Linking linux/video_loopback_copy_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/video_loopback_copy_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    Executing make dm6446_al in subdirectory video_loopback_resize/...
    ======== Building linux/video_loopback_resize_dm6446 ========
    Configuring application using linux/video_loopback_resize_dm6446.cfg
    generating interfaces for package video_loopback_resize_dm6446_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring video_loopback_resize_dm6446.x470MV from package/cfg/video_loopback_resize_dm6446_x470MV.cfg ...
    cl470MV package/cfg/video_loopback_resize_dm6446_x470MV.c ...
    Linking linux/video_loopback_resize_dm6446.x470MV from appMain.dm6446.o470MV linux/main.dm6446.o470MV linux/video_loopback_resize_dm6446_config/linker.cmd /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/lib/dmai_linux_dm6446.a470MV..
    DMAI applications can be found under /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/apps
    To install them to /home/aditya/workdir1/filesys/opt/dvsdk/ enter /home/aditya/dvsdk_2_00_00_22/dmai_1_20_00_06 and execute 'make install'
    Making all in subdirectory decode...
    ======== Building decode ========
    Configuring application using decode.cfg
    generating interfaces for package decode_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring decode.x470MV from package/cfg/decode_x470MV.cfg ...
        will link with ti.sdo.ce.utils.trace:lib/release/TraceUtil.av5T
        will link with ti.sdo.ce.bioslog:lib/release/bioslog.av5T
        will link with ti.sdo.simplewidget:lib/simplewidget_dm6446.a470MV
    cl470MV package/cfg/decode_x470MV.c ...
    Compiling audio.o from audio.c..
    Compiling codecs.o from codecs.c..
    Compiling display.o from display.c..
    Compiling loader.o from loader.c..
    Compiling main.o from main.c..
    Compiling speech.o from speech.c..
    Compiling video.o from video.c..
    Compiling ../ctrl.o from ../ctrl.c..
    Compiling ../uibuttons.o from ../uibuttons.c..
    Compiling ../ui.o from ../ui.c..
    Linking decode from audio.o codecs.o display.o loader.o main.o speech.o video.o ../ctrl.o ../uibuttons.o ../ui.o decode_config/linker.cmd..
    Making all in subdirectory encode...
    ======== Building encode ========
    Configuring application using encode.cfg
    generating interfaces for package encode_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring encode.x470MV from package/cfg/encode_x470MV.cfg ...
    cl470MV package/cfg/encode_x470MV.c ...
    Compiling capture.o from capture.c..
    Compiling writer.o from writer.c..
    Linking encode from capture.o codecs.o main.o speech.o video.o writer.o ../ctrl.o ../uibuttons.o ../ui.o encode_config/linker.cmd..
    Making all in subdirectory encodedecode...
    ======== Building encodedecode ========
    Configuring application using encodedecode.cfg
    generating interfaces for package encodedecode_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring encodedecode.x470MV from package/cfg/encodedecode_x470MV.cfg ...
    Info: Configuring engine named 'encodedecode' from the info file for DSP server './loopbackCombo.x64P',
              located in package 'ti.sdo.servers.loopback':
          Target app will look for the DSP server image 'loopbackCombo.x64P' in its current directory.
    Info: Reading DSP memory map from the info file for DSP server './loopbackCombo.x64P',
    cl470MV package/cfg/encodedecode_x470MV.c ...
    Linking encodedecode from capture.o codecs.o display.o main.o video.o ../ctrl.o ../uibuttons.o ../ui.o encodedecode_config/linker.cmd..
    Making all in subdirectory interface...
    ======== Building interface ========
    Configuring application using interface.cfg
    generating interfaces for package interface_config (because package/package.xdc.inc is older than package.xdc) ...
    configuring interface.x470MV from package/cfg/interface_x470MV.cfg ...
    cl470MV package/cfg/interface_x470MV.c ...
    Compiling dec.o from dec.c..
    Compiling enc.o from enc.c..
    Compiling encdec.o from encdec.c..
    Compiling menu.o from menu.c..
    Compiling start.o from start.c..
    Compiling tparty.o from tparty.c..
    Linking interface from dec.o enc.o encdec.o main.o menu.o start.o tparty.o ../uibuttons.o interface_config/linker.cmd..
    make[1]: Nothing to be done for `all'.
    make -C /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08 dm6446
    Building DVTB for dm6446...
    cd packages/ti/sdo/dvtb/dm6446  && make
    XDCPATH="/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages;/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages;/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages;/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages;/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages;/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages;/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages;" /home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/xs xdc.tools.configuro -c /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le -o dvtb_dm6446 -t gnu.targets.MVArm9 -p ti.platforms.evmDM6446 dvtb_dm6446.cfg
    generating interfaces for package dvtb_dm6446 (because package/package.xdc.inc is older than package.xdc) ...
    configuring dvtb_dm6446.x470MV from package/cfg/dvtb_dm6446_x470MV.cfg ...
    Info: Configuring engine named 'loopback' from the info file for DSP server './loopbackCombo.x64P',
    cl470MV package/cfg/dvtb_dm6446_x470MV.c ...
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAACHECapture1.rel.o linux/dvtbAACHECapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAACHEEnc1.rel.o linux/dvtbAACHEEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAACLCCapture1.rel.o linux/dvtbAACLCCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAACLCEnc1.rel.o linux/dvtbAACLCEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbApisDispatcher.rel.o linux/dvtbApisDispatcher.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAppInit.rel.o linux/dvtbAppInit.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudCapture1.rel.o linux/dvtbAudCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudCapture.rel.o linux/dvtbAudCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudDec1.rel.o linux/dvtbAudDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudDec.rel.o linux/dvtbAudDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudEnc1.rel.o linux/dvtbAudEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudEnc.rel.o linux/dvtbAudEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudPlay1.rel.o linux/dvtbAudPlay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbAudPlay.rel.o linux/dvtbAudPlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbFuncDispatcher.rel.o linux/dvtbFuncDispatcher.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgCapture1.rel.o linux/dvtbImgCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgCapture.rel.o linux/dvtbImgCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgDec1.rel.o linux/dvtbImgDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgDec.rel.o linux/dvtbImgDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgDisplay1.rel.o linux/dvtbImgDisplay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgDisplay.rel.o linux/dvtbImgDisplay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgEnc1.rel.o linux/dvtbImgEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbImgEnc.rel.o linux/dvtbImgEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbMP3BaseDec1.rel.o linux/dvtbMP3BaseDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbMP3BaseDec.rel.o linux/dvtbMP3BaseDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbMP3BasePlay1.rel.o linux/dvtbMP3BasePlay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbMP3BasePlay.rel.o linux/dvtbMP3BasePlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbParam.rel.o linux/dvtbParam.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphCapture1.rel.o linux/dvtbSphCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphCapture.rel.o linux/dvtbSphCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphDec1.rel.o linux/dvtbSphDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphDec.rel.o linux/dvtbSphDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphEnc1.rel.o linux/dvtbSphEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphEnc.rel.o linux/dvtbSphEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphPlay1.rel.o linux/dvtbSphPlay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbSphPlay.rel.o linux/dvtbSphPlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidCapture1.rel.o linux/dvtbVidCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidCapture.rel.o linux/dvtbVidCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidDec2.rel.o linux/dvtbVidDec2.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidDec.rel.o linux/dvtbVidDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidEnc1.rel.o linux/dvtbVidEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidEnc.rel.o linux/dvtbVidEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidLoopback1.rel.o linux/dvtbVidLoopback1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidPlay2.rel.o linux/dvtbVidPlay2.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o linux/dvtbVidPlay.rel.o linux/dvtbVidPlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbDispatcher.rel.o ../core/linux/dvtbDispatcher.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbEngine.rel.o ../core/linux/dvtbEngine.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbGetParam.rel.o ../core/linux/dvtbGetParam.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbMain.rel.o ../core/linux/dvtbMain.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbMemory.rel.o ../core/linux/dvtbMemory.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbSetParam.rel.o ../core/linux/dvtbSetParam.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbThread.rel.o ../core/linux/dvtbThread.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../core/linux/dvtbVersion.rel.o ../core/linux/dvtbVersion.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../pal/linux/v4l2/dvtbV4L2VPBE.rel.o ../pal/linux/v4l2/dvtbV4L2VPBE.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../pal/linux/v4l2/dvtbV4L2VPFE.rel.o ../pal/linux/v4l2/dvtbV4L2VPFE.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1   -o ../pal/linux/alsa/dvtbALSAAudio.rel.o ../pal/linux/alsa/dvtbALSAAudio.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-ar -r  ./bin/dvtb-r.a linux/dvtbAACHECapture1.rel.o linux/dvtbAACHEEnc1.rel.o linux/dvtbAACLCCapture1.rel.o linux/dvtbAACLCEnc1.rel.o linux/dvtbApisDispatcher.rel.o linux/dvtbAppInit.rel.o linux/dvtbAudCapture1.rel.o linux/dvtbAudCapture.rel.o linux/dvtbAudDec1.rel.o linux/dvtbAudDec.rel.o linux/dvtbAudEnc1.rel.o linux/dvtbAudEnc.rel.o linux/dvtbAudPlay1.rel.o linux/dvtbAudPlay.rel.o linux/dvtbFuncDispatcher.rel.o linux/dvtbImgCapture1.rel.o linux/dvtbImgCapture.rel.o linux/dvtbImgDec1.rel.o linux/dvtbImgDec.rel.o linux/dvtbImgDisplay1.rel.o linux/dvtbImgDisplay.rel.o linux/dvtbImgEnc1.rel.o linux/dvtbImgEnc.rel.o linux/dvtbMP3BaseDec1.rel.o linux/dvtbMP3BaseDec.rel.o linux/dvtbMP3BasePlay1.rel.o linux/dvtbMP3BasePlay.rel.o linux/dvtbParam.rel.o linux/dvtbSphCapture1.rel.o linux/dvtbSphCapture.rel.o linux/dvtbSphDec1.rel.o linux/dvtbSphDec.rel.o linux/dvtbSphEnc1.rel.o linux/dvtbSphEnc.rel.o linux/dvtbSphPlay1.rel.o linux/dvtbSphPlay.rel.o linux/dvtbVidCapture1.rel.o linux/dvtbVidCapture.rel.o linux/dvtbVidDec2.rel.o linux/dvtbVidDec.rel.o linux/dvtbVidEnc1.rel.o linux/dvtbVidEnc.rel.o linux/dvtbVidLoopback1.rel.o linux/dvtbVidPlay2.rel.o linux/dvtbVidPlay.rel.o ../core/linux/dvtbDispatcher.rel.o ../core/linux/dvtbEngine.rel.o ../core/linux/dvtbGetParam.rel.o ../core/linux/dvtbMain.rel.o ../core/linux/dvtbMemory.rel.o ../core/linux/dvtbSetParam.rel.o ../core/linux/dvtbThread.rel.o ../core/linux/dvtbVersion.rel.o ../pal/linux/v4l2/dvtbV4L2VPBE.rel.o ../pal/linux/v4l2/dvtbV4L2VPFE.rel.o ../pal/linux/alsa/dvtbALSAAudio.rel.o
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-ar: creating ./bin/dvtb-r.a
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -o bin/dvtb-r bin/dvtb-r.a dvtb_dm6446/linker.cmd -lfreetype -lpthread -lcurses ./linux/libs/libedit.a -lasound
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAACHECapture1.dbg.o linux/dvtbAACHECapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAACHEEnc1.dbg.o linux/dvtbAACHEEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAACLCCapture1.dbg.o linux/dvtbAACLCCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAACLCEnc1.dbg.o linux/dvtbAACLCEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbApisDispatcher.dbg.o linux/dvtbApisDispatcher.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAppInit.dbg.o linux/dvtbAppInit.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudCapture1.dbg.o linux/dvtbAudCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudCapture.dbg.o linux/dvtbAudCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudDec1.dbg.o linux/dvtbAudDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudDec.dbg.o linux/dvtbAudDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudEnc1.dbg.o linux/dvtbAudEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudEnc.dbg.o linux/dvtbAudEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudPlay1.dbg.o linux/dvtbAudPlay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbAudPlay.dbg.o linux/dvtbAudPlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbFuncDispatcher.dbg.o linux/dvtbFuncDispatcher.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgCapture1.dbg.o linux/dvtbImgCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgCapture.dbg.o linux/dvtbImgCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgDec1.dbg.o linux/dvtbImgDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgDec.dbg.o linux/dvtbImgDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgDisplay1.dbg.o linux/dvtbImgDisplay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgDisplay.dbg.o linux/dvtbImgDisplay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgEnc1.dbg.o linux/dvtbImgEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbImgEnc.dbg.o linux/dvtbImgEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbMP3BaseDec1.dbg.o linux/dvtbMP3BaseDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbMP3BaseDec.dbg.o linux/dvtbMP3BaseDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbMP3BasePlay1.dbg.o linux/dvtbMP3BasePlay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbMP3BasePlay.dbg.o linux/dvtbMP3BasePlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbParam.dbg.o linux/dvtbParam.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphCapture1.dbg.o linux/dvtbSphCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphCapture.dbg.o linux/dvtbSphCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphDec1.dbg.o linux/dvtbSphDec1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphDec.dbg.o linux/dvtbSphDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphEnc1.dbg.o linux/dvtbSphEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphEnc.dbg.o linux/dvtbSphEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphPlay1.dbg.o linux/dvtbSphPlay1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbSphPlay.dbg.o linux/dvtbSphPlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidCapture1.dbg.o linux/dvtbVidCapture1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidCapture.dbg.o linux/dvtbVidCapture.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidDec2.dbg.o linux/dvtbVidDec2.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidDec.dbg.o linux/dvtbVidDec.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidEnc1.dbg.o linux/dvtbVidEnc1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidEnc.dbg.o linux/dvtbVidEnc.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidLoopback1.dbg.o linux/dvtbVidLoopback1.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidPlay2.dbg.o linux/dvtbVidPlay2.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o linux/dvtbVidPlay.dbg.o linux/dvtbVidPlay.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbDispatcher.dbg.o ../core/linux/dvtbDispatcher.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbEngine.dbg.o ../core/linux/dvtbEngine.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbGetParam.dbg.o ../core/linux/dvtbGetParam.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbMain.dbg.o ../core/linux/dvtbMain.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbMemory.dbg.o ../core/linux/dvtbMemory.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbSetParam.dbg.o ../core/linux/dvtbSetParam.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbThread.dbg.o ../core/linux/dvtbThread.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../core/linux/dvtbVersion.dbg.o ../core/linux/dvtbVersion.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../pal/linux/v4l2/dvtbV4L2VPBE.dbg.o ../pal/linux/v4l2/dvtbV4L2VPBE.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../pal/linux/v4l2/dvtbV4L2VPFE.dbg.o ../pal/linux/v4l2/dvtbV4L2VPFE.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -I /home/aditya/workdir1/lsp/ti-davinci/linux-2.6.18_pro500/include -I /home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm -I ../../../../../packages/ti/sdo/dvtb/core/inc -I /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/linux -I ../../../../../packages/ti/sdo/dvtb/pal/linux/v4l2 -I ../../../../../packages/ti/sdo/dvtb/pal/linux/alsa -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -I"/home/aditya/dvsdk_2_00_00_22/framework_components_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/codec_engine_2_23_01/cetools/packages" -I"/home/aditya/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdais_6_23/packages" -I"/home/aditya/dvsdk_2_00_00_22/linuxutils_2_23_01/packages" -I"/home/aditya/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages" -I"/home/aditya/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages" -I"/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/.."  -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=MVArm9 -Dxdc_cfg__header__="/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/dvtb_dm6446/package/cfg/dvtb_dm6446_x470MV.h" -c -Wall -fno-strict-aliasing -g -I./libedit -DREADLINE=1  -g -D_DVEVM_ST_DEBUG_ -o ../pal/linux/alsa/dvtbALSAAudio.dbg.o ../pal/linux/alsa/dvtbALSAAudio.c
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-ar -r  ./bin/dvtb-d.a linux/dvtbAACHECapture1.dbg.o linux/dvtbAACHEEnc1.dbg.o linux/dvtbAACLCCapture1.dbg.o linux/dvtbAACLCEnc1.dbg.o linux/dvtbApisDispatcher.dbg.o linux/dvtbAppInit.dbg.o linux/dvtbAudCapture1.dbg.o linux/dvtbAudCapture.dbg.o linux/dvtbAudDec1.dbg.o linux/dvtbAudDec.dbg.o linux/dvtbAudEnc1.dbg.o linux/dvtbAudEnc.dbg.o linux/dvtbAudPlay1.dbg.o linux/dvtbAudPlay.dbg.o linux/dvtbFuncDispatcher.dbg.o linux/dvtbImgCapture1.dbg.o linux/dvtbImgCapture.dbg.o linux/dvtbImgDec1.dbg.o linux/dvtbImgDec.dbg.o linux/dvtbImgDisplay1.dbg.o linux/dvtbImgDisplay.dbg.o linux/dvtbImgEnc1.dbg.o linux/dvtbImgEnc.dbg.o linux/dvtbMP3BaseDec1.dbg.o linux/dvtbMP3BaseDec.dbg.o linux/dvtbMP3BasePlay1.dbg.o linux/dvtbMP3BasePlay.dbg.o linux/dvtbParam.dbg.o linux/dvtbSphCapture1.dbg.o linux/dvtbSphCapture.dbg.o linux/dvtbSphDec1.dbg.o linux/dvtbSphDec.dbg.o linux/dvtbSphEnc1.dbg.o linux/dvtbSphEnc.dbg.o linux/dvtbSphPlay1.dbg.o linux/dvtbSphPlay.dbg.o linux/dvtbVidCapture1.dbg.o linux/dvtbVidCapture.dbg.o linux/dvtbVidDec2.dbg.o linux/dvtbVidDec.dbg.o linux/dvtbVidEnc1.dbg.o linux/dvtbVidEnc.dbg.o linux/dvtbVidLoopback1.dbg.o linux/dvtbVidPlay2.dbg.o linux/dvtbVidPlay.dbg.o ../core/linux/dvtbDispatcher.dbg.o ../core/linux/dvtbEngine.dbg.o ../core/linux/dvtbGetParam.dbg.o ../core/linux/dvtbMain.dbg.o ../core/linux/dvtbMemory.dbg.o ../core/linux/dvtbSetParam.dbg.o ../core/linux/dvtbThread.dbg.o ../core/linux/dvtbVersion.dbg.o ../pal/linux/v4l2/dvtbV4L2VPBE.dbg.o ../pal/linux/v4l2/dvtbV4L2VPFE.dbg.o ../pal/linux/alsa/dvtbALSAAudio.dbg.o
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-ar: creating ./bin/dvtb-d.a
    /opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -o bin/dvtb-d bin/dvtb-d.a dvtb_dm6446/linker.cmd -lfreetype -lpthread -lcurses ./linux/libs/libedit.a -lasound
    make[2]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446'
    make[1]: Leaving directory `/home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08'
    dvtb can be found under /home/aditya/dvsdk_2_00_00_22/dvtb_4_00_08/packages/ti/sdo/dvtb/dm6446/bin
    [aditya@localhost dvsdk_2_00_00_22]$
  • Dear Aditya Barawkar,
    I have managed to solve the problem. I summarize below the steps to create the dmai application for image decode and image decode with jpeg. Mind that I am using the DM6446 target, have switched to Community Linux and have updated DVSDK components to most recent. However it should work also with your current configuration, but maybe you should adapt some of the paths and toolnames.
    1) Build the unit servers
    1.1 ) Download and install the jpeg encode and decode in the codecs directory
    cd ${HOME}/Downloads
    wget http://software-dl.ti.com/dsps/dsps_public_sw/codecs/C64XPlus_Video//C64XPlus_Video_latest/c64xplus_jpegdec_02_00_01_01_production.bin
    chmod +x c64xplus_jpegdec_02_00_01_01_production.bin
    ./c64xplus_jpegdec_02_00_01_01_production.bin # chose directory ${HOME}/Downloads for the installation
    rm ./c64xplus_jpegdec_02_00_01_01_production.bin
    tar xvf c64xplus_jpegdec_02_00_01_01_production.tar
    mv ./c64xplus_jpegdec_02_00_01_01_production/packages/ti/sdo/codecs/jpegdec ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/codecs
    rm -R c64xplus_jpegdec_02_00_01_01_production
    ./uninstall
    wget http://software-dl.ti.com/dsps/dsps_public_sw/codecs/C64XPlus_Video//C64XPlus_Video_latest/c64xplus_jpegenc_02_00_01_00_production.bin
    chmod +x c64xplus_jpegenc_02_00_01_00_production.bin
    ./c64xplus_jpegenc_02_00_01_00_production.bin # # chose directory ${HOME}/Downloads for the installation
    rm ./c64xplus_jpegenc_02_00_01_00_production.bin
    tar xvf c64xplus_jpegenc_02_00_01_00_production.tar
    mv ./c64xplus_jpegenc_02_00_01_00_production/packages/ti/sdo/codecs/jpegenc ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/codecs
    rm -R c64xplus_jpegenc_02_00_01_00_production
    ./uninstall
    # Verify that you have now the directories jpegenc and jpegdec in ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/codecs
    ls ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/codecs
    # you should see : aachedec  g711enc  h264enc  jpegenc   mpeg4dec g711dec   h264dec  jpegdec  mpeg2dec  mpeg4enc
    1.2) Build the codecs
    cd ${HOME}
    cd dvsdk_2_00_00_22/
    make codecs_clean
    make codecs
    # verify that the subdirectory "package" was created in both the "jpegdec" and the "jpegenc" directory.
    1.3) Create the unit servers
    cd ${HOME}
    cd dvsdk_2_00_00_22/ceutils_1_07/
    make genserver # ignore any warnings and fill in the following information in the dialog box:
        packageName: ti.sdo.codecs.jpegdec
        module : JPEGDEC
        platform : ti.platforms.evmDM6446
        serverName : ti.sdo.servers.jpegdec_unitserver_evmdm6446
        outputRepository : ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/
    # Unit Server creation successful...
    # Files output to ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/servers/jpegdec_unitserver_evmdm6446
    make genserver # ignore any warnings and fill in the following information in the dialog boxfs
        packageName: ti.sdo.codecs.jpegenc
        module : JPEGENC
        serverName : ti.sdo.servers.jpegenc_unitserver_evmdm6446
    # Files output to ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/servers/jpegenc_unitserver_evmdm6446
    1.4) Configure the unit servers
    - Edit jpegenc_unitserver_evmdm6446/codec.cfg to assign code & data section placements:
            JPEGENC.alg.codeSection = "DDR2";
            JPEGENC.alg.udataSection = "DDR2";
            JPEGENC.alg.dataSection = "DDR2";
    - Edit jpegdec_unitserver_evmdm6446/codec.cfg to assign code & data section placements:
            JPEGDEC.alg.codeSection = "DDR2";
            JPEGDEC.alg.udataSection = "DDR2";
            JPEGDEC.alg.dataSection = "DDR2";
    1.5) Build the servers
    cd ${HOME}
    make codecs_clean
    make codecs
    - verify that the unit servers were created in:
    ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/servers/jpegdec_unitserver_evmdm6446/jpegdec_unitserver_evmdm6446.x64P
    ${HOME}/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/servers/jpegenc_unitserver_evmdm6446/jpegenc_unitserver_evmdm6446.x64P
    2) Correct the dmai configuration
    2.1) Remove the config files image_decode_io_dm6446.cfg and image_encode_io_dm6446.cfg (the downloaded jpeg codecs are XDM1 and not XDM):
    rm ${HOME}/dvsdk_2_00_00_22/dmai/packages/ti/sdo/dmai/apps/image_encode_io/linux/image_encode_io_dm6446.cfg
    rm ${HOME}/dvsdk_2_00_00_22/dmai/packages/ti/sdo/dmai/apps/image_decode_io/linux/image_decode_io_dm6446.cfg
    2.2) Add config files for image_encode_io1 and image_decode_io1
    2.2.1) In ${HOME}/dvsdk_2_00_00_22/dmai/packages/ti/sdo/dmai/apps/image_decode_io1/linux add the file "image_decode_io1_dm6446.cfg" containing:
    utils.importFile("../../app_common.cfg");
    var Engine = xdc.useModule('ti.sdo.ce.Engine');
    var demoEngine = Engine.createFromServer(
        "decode",
        "./jpegdec_unitserver_evmdm6446.x64P",
        "ti.sdo.servers.jpegdec_unitserver_evmdm6446"
    2.2.2) In ${HOME}/dvsdk_2_00_00_22/dmai/packages/ti/sdo/dmai/apps/image_encode_io1/linux add the file image_encode_io1_dm6446.cfg containing:
        "encode",
        "./jpegenc_unitserver_evmdm6446.x64P",
        "ti.sdo.servers.jpegenc_unitserver_evmdm6446"
    3) build the dmai applications
    cd ${HOME}
    cd dvsdk_2_00_00_22
    make dmai_clean
    make dmai
    # Verify that the dmai applications are ins
    ${HOME}/dvsdk_2_00_00_22/dmai/packages/ti/sdo/dmai/apps/image_encode_io1/linux/image_encode_io1_dm6446.x470MV
    ${HOME}/dvsdk_2_00_00_22/dmai/packages/ti/sdo/dmai/apps/image_decode_io1/linux/image_decode_io1_dm6446.x470MV
