RTOS: C6657 GPIO interrupt in tirtos
Other Parts Discussed in Thread: SYSBIOS, TMS320C6657
Tool/software: TI-RTOS
  I have developed a big test application for a custom board. In this environment we will use
an not defined GPIO (0-15) as interrupt external source. In this moment I use evaluation board and
I have developed a TI RTOS task with a little switch placed on test_PH1 connector (GPIO15).
When the ISR works all the other part of system is blocked on Task_sleep function (but I suppose
that all the TI RTOS  is on the blocked status). I have used the following TI RTSC  libraries:
EDMA3 2.12.2
IPC 3.44.0.00
NDK 2.25.0..9
SYSBIOS 6.46.1.38
PDK 2.0.4
XCDTools 3.32.0.06
CCS TI v8.1.0 (CCS 6.1.3.00034)
The ISR code follows:
******************************** C file:************************
#include <ti/csl/src/intc/csl_intcAux.h>
#include <ti/csl/csl_chip.h>
#include <ti/csl/csl_chipAux.h>
#include <ti/csl/src/intc/csl_intc.h>
#include <ti/csl/csl_gpio.h>
#include <ti/csl/csl_gpioAux.h>
//#define IRQ_SIMUL
typedef struct event2gpio_s
   uint32_t gpio;
   uint32_t eventID;
} event2gpio_t;
volatile int a = 0;
CSL_GpioHandle              hGpio = NULL;
const event2gpio_t myGpio2Event[] =
  {  0, CSL_GEM_PCIEXPRESS_MSI_INTN_PLUS_2 }, // DO NOT USE
  {  1, CSL_GEM_PCIEXPRESS_MSI_INTN_PLUS_6 }, // DO NOT USE
  {  2, CSL_GEM_GPINT2  },
  {  3, CSL_GEM_GPINT3  },
  {  4, CSL_GEM_GPINT4  },
  {  5, CSL_GEM_GPINT5  },
  {  6, CSL_GEM_GPINT6  },
  {  7, CSL_GEM_GPINT7  },
  {  8, CSL_GEM_GPINT8  },
  {  9, CSL_GEM_GPINT9  },
  { 10, CSL_GEM_GPINT10 },
  { 11, CSL_GEM_GPINT11 },
  { 12, CSL_GEM_GPINT12 },
  { 13, CSL_GEM_GPINT13 },
  { 14, CSL_GEM_GPINT14 },
  { 15, CSL_GEM_GPINT15 }
static void GPIO02InterruptHandler(void *arg)
   /* Clear the event ID. */
   CSL_intcEventClear((CSL_IntcEventId)arg);
   a++;
CSL_IntcContext             intcContext;
CSL_IntcEventHandlerRecord  EventHandler[30];
CSL_IntcObj                 intcObj;
CSL_IntcHandle              hTest;
CSL_IntcGlobalEnableState   state;
CSL_IntcEventHandlerRecord  EventRecord;
CSL_IntcParam               vectId;
//  GPIO irq design base:  e2e.ti.com/.../374048
**                      Global Function                                       **
Void mainFPGA(UArg arg0, UArg arg1)
   int                         bankNum = 0;
#ifdef IRQ_SIMUL
   int                         cnt = 1000;
   int                         pinNum = FPGA_GPIOIRQ;
#else
   int                         pinNum = 15;
#endif
   int                         aLocal = 0;
   DBG_PRINTF("Start %s taskname \"%s\"",
              __func__, FPGATASKNAME/*Task_Handle_name(Task_self())*/);
   a = 0;
   bankNum = 0; // Trigger pinNum in Core0
   if (pinNum > SIZEOF(myGpio2Event))
      DBG_PRINTF("Error: pinNum=%d is too big", pinNum);
      return;
   else if (pinNum < 2)
      DBG_PRINTF("Error: pinNum=%d is too little", pinNum);
      return;
    *************** INTC Configuration *************
   // INTC module initialization
   intcContext.eventhandlerRecord = EventHandler;
   intcContext.numEvtEntries      = 10;
   if (CSL_intcInit(&intcContext) != CSL_SOK)
      DBG_PRINTF("Error: GEM-INTC initialization failed");
      return;
   // Enable NMIs
   if (CSL_intcGlobalNmiEnable() != CSL_SOK)
      DBG_PRINTF("Error: GEM-INTC global NMI enable failed");
      return;
   /* Enable global interrupts */
   if (CSL_intcGlobalEnable(&state) != CSL_SOK)
      DBG_PRINTF("Error: GEM-INTC global enable failed");
      return;
   vectId = CSL_INTC_VECTID_4;
   hTest = CSL_intcOpen(&intcObj, myGpio2Event[pinNum].eventID, &vectId , NULL);
   if (hTest == NULL)
      DBG_PRINTF("Error: GEM-INTC Open failed");
      return;
   DBG_PRINTF("Debug: GEM-INTC INT%d EventID%d", hTest->vectId, hTest->eventId);
   /* Register an call-back handler which is invoked when the event occurs. */
   EventRecord.handler = &GPIO02InterruptHandler;
   EventRecord.arg     = hTest;
   if (CSL_intcPlugEventHandler(hTest, &EventRecord) != CSL_SOK)
      DBG_PRINTF("Error: GEM-INTC Plug event handler failed");
      return;
   /* Enabling the events. */
   if (CSL_intcHwControl(hTest, CSL_INTC_CMD_EVTENABLE, NULL) != CSL_SOK)
      DBG_PRINTF("Error: GEM-INTC CSL_INTC_CMD_EVTENABLE command failed");
      return;
   DBG_PRINTF("Debug: GEM-INTC Configuration Completed");
   // Open the CSL GPIO Module 0
   hGpio = CSL_GPIO_open(0);
#ifdef IRQ_SIMUL
   // Set GPIO pin number pinNum as an output pin
   CSL_GPIO_setPinDirOutput(hGpio, pinNum);
#endif
#ifdef RISING
#ifdef IRQ_SIMUL
   CSL_GPIO_clearOutputData(hGpio, pinNum);   //FPGA_GPIOIRQ=0
#endif
   // Set interrupt detection on GPIO pin pinNum to rising edge
   CSL_GPIO_setRisingEdgeDetect(hGpio, pinNum);
#else
#ifdef IRQ_SIMUL
   CSL_GPIO_setOutputData(hGpio, pinNum);     //FPGA_GPIOIRQ=1
#endif
   CSL_GPIO_setFallingEdgeDetect(hGpio, pinNum);
#endif
   // Set GPIO pin number pinNum as an input pin
   CSL_GPIO_setPinDirInput(hGpio, pinNum); //set FPGA_GPIOIRQ to be input
   // Enable GPIO per bank interrupt for bank zero
   CSL_GPIO_bankInterruptEnable(hGpio, bankNum);
   DBG_PRINTF("Debug: GEM-INTC IRQ waiting");
   do
#ifdef IRQ_SIMUL
      Clock0ISR(/*(UArg) */FPGATASKNAME);
      if ((cnt--) == 0)
         cnt = 100;
#ifdef RISING
         // Toggle FPGA_GPIOIRQ pin to trigger GPIO interrupt
#else
#endif
      else
     //    Task_sleep(10);// if uncomment this line also this task remain in blocked status
#else
#endif
      if (a != aLocal) // Wait for entering into ISR
#ifdef IRQ_SIMUL
#ifdef RISING
#else
#endif
#endif
         DBG_PRINTF("GPIO interrupt occurs a = %d", a);
         aLocal = a;
   } while (global_var->exit_flag == FALSE);
   CSL_intcClose(&intcObj);
   DBG_PRINTF("Exit %s", __func__);
   Task_exit();
   return;
******************************** CFG file:************************
var Memory              = xdc.useModule('xdc.runtime.Memory');
var BIOS                = xdc.useModule('ti.sysbios.BIOS');
var Task                = xdc.useModule('ti.sysbios.knl.Task');
var ti_ndk_config_Emac  = xdc.useModule('ti.ndk.config.Emac');
var Icmp                = xdc.useModule('ti.ndk.config.Icmp');
var Swi                 = xdc.useModule('ti.sysbios.knl.Swi');
var Timer                 = xdc.useModule('ti.sysbios.hal.Timer');
var SwTimerPrms           = new Timer.Params();
SwTimerPrms.startMode     = Timer.StartMode_AUTO;
SwTimerPrms.period        = 100000;        // 100,000 uSecs = 100ms
SwTimerPrms.instance.name = "SWTimer";
var SwTimer               = Timer.create(null, '&swthTimerHandler', SwTimerPrms);
Task.common$.namedInstance     = true;
var Clock        = xdc.useModule('ti.sysbios.knl.Clock');
Clock.tickPeriod = 750;
var Sem          = xdc.useModule('ti.sysbios.knl.Semaphore');
var Diags           = xdc.useModule('xdc.runtime.Diags');
var devType         = "c6657";
var Csl = xdc.loadPackage('ti.csl');
Csl.Settings.deviceType      = devType;
Csl.Settings.useCSLIntcLib   = true;
/* Load the OSAL package */
var osType          = "tirtos"
var Osal            = xdc.useModule('ti.osal.Settings');
Osal.osType         = osType;
Osal.socType        = devType;
var Qmss               = xdc.loadPackage('ti.drv.qmss');
var Emac               = xdc.loadPackage('ti.drv.emac');
Emac.Settings.socType  = devType;
var Nimu               = xdc.loadPackage('ti.transport.ndk.nimu');
Nimu.Settings.socType  = devType;
var LoggerBuf       = xdc.useModule('xdc.runtime.LoggerBuf');
var Exc             = xdc.useModule('ti.sysbios.family.c64p.Exception');
Exc.common$.logger  = LoggerBuf.create();
Exc.enablePrint     = true;
var Global    = xdc.useModule('ti.ndk.config.Global');
Global.enableCodeGeneration = false;
var Cache       =   xdc.useModule('ti.sysbios.family.c66.Cache');
var Startup       = xdc.useModule('xdc.runtime.Startup');
var System        = xdc.useModule('xdc.runtime.System');
var Settings      = xdc.useModule('ti.sysbios.posix.Settings');
Settings.supportsMutexPriority = true;
var HeapMem               = xdc.useModule('ti.sysbios.heaps.HeapMem');
var heapMemParams         = new HeapMem.Params();
heapMemParams.size        = 0x3D000;
heapMemParams.sectionName = "systemHeap";
Program.global.heap0      = HeapMem.create(heapMemParams);
Memory.defaultHeapInstance     = Program.global.heap0;
Program.sectMap["sharedL2"]    = "MSMCSRAM";
Program.sectMap["systemHeap"]  = "MSMCSRAM";
Program.sectMap[".sysmem"]     = "MSMCSRAM";
Program.sectMap[".args"]       = "MSMCSRAM";
Program.sectMap[".cio"]        = "MSMCSRAM";
Program.sectMap[".rodata"]     = "MSMCSRAM";
Program.sectMap[".neardata"]   = "MSMCSRAM";
Program.sectMap[".cppi"]       = "MSMCSRAM";
Program.sectMap[".init_array"] = "MSMCSRAM";
Program.sectMap[".qmss"]       = "MSMCSRAM";
Program.sectMap[".cinit"]      = "MSMCSRAM";
Program.sectMap[".bss"]        = "MSMCSRAM";
Program.sectMap[".const"]      = "MSMCSRAM";
Program.sectMap[".text"]       = "MSMCSRAM";
Program.sectMap[".code"]       = "MSMCSRAM";
Program.sectMap[".switch"]     = "MSMCSRAM";
Program.sectMap[".data"]       = "MSMCSRAM";
Program.sectMap[".vecs"]       = "MSMCSRAM";
Program.sectMap["emacComm"]    = "L2SRAM";
Program.sectMap[".far:taskStackSection"] = "L2SRAM";
Program.sectMap[".stack"]      =  "L2SRAM";
Program.sectMap["platform_lib"]         = "L2SRAM";
Program.sectMap[".fardata:benchmarking"] = "DDR3";
Program.sectMap[".dstBufSec"] = "L2SRAM";
Program.sectMap[".testData"] = "L2SRAM";
Program.sectMap[".srioSharedMem"] = "MSMCSRAM";
SysStd              = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
Startup.lastFxns.$add('&EVM_init');
BIOS.taskEnabled         =   true;
var drv      = xdc.loadPackage ("ti.sdo.edma3.drv");
var rm       = xdc.loadPackage ("ti.sdo.edma3.rm");
var Event    = xdc.useModule('ti.sysbios.knl.Event');
var Idle     = xdc.useModule('ti.sysbios.knl.Idle');
var CpIntc   = xdc.useModule('ti.sysbios.family.c66.tci66xx.CpIntc');
var ECM      = xdc.useModule ("ti.sysbios.family.c64p.EventCombiner");
var HWI      = xdc.useModule('ti.sysbios.family.c64p.Hwi');
var halCache = xdc.useModule('ti.sysbios.hal.Cache');
ECM.eventGroupHwiNum[0] = 7;
ECM.eventGroupHwiNum[1] = 8;
var Utils = xdc.loadPackage('ti.utils.profiling');
var Pcie    = xdc.loadPackage('ti.drv.pcie');
Pcie.Settings.enableProfiling = true;
BIOS.smpEnabled = true;
Clock.timerId = -1;
Clock.swiPriority = 15;
Global.IPv6 = false;
environment['xdc.cfg.check.fatal'] = 'false';
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var Log     = xdc.useModule('xdc.runtime.Log');
var Cppi = xdc.loadPackage('ti.drv.cppi');
var Ipc          = xdc.useModule('ti.sdo.ipc.Ipc');
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.translate = false;
var memmap = Program.cpu.memoryMap;
Program.sectMap[".my_sect_iram"]   = "L2SRAM";
Program.sectMap[".my_sect_ddr"]    = "L2SRAM";
/*  ======== gpio_test.cfg ========/
Task.deleteTerminatedTasks = false;
BIOS.swiEnabled = true;
Program.sectMap[".csl_vect"] = "L2SRAM";
var core                        =   xdc.useModule('ti.sysbios.hal.Core');
var Board = xdc.loadPackage('ti.board');
Board.Settings.boardName = "evmC6657";
var Gpio = xdc.loadPackage('ti.drv.gpio');
Gpio.Settings.socType = devType;
var Uart = xdc.useModule('ti.drv.uart.Settings');
Uart.socType = devType;
Task.checkStackFlag             = false;
************ Console:*******************
DigitalProc TestBench SW Ver 0.0.1 Build 46 CPU Freq 1000 MHz DSP's core 1 of 2
DSP hw rev. 0 DSP name "TMS320C6657" Board Name "TMDXEVM6657L"
MAC0: 00:18:30:0A:22:88
00:00:00 00:00:07 PciExMain.c@2223:    Start PciExMain taskname "PciExTask"
00:00:00 00:00:00 PciExMain.c@2258:    Version #: 0x02020007; string PCIE LLD Revision: 02.02.00.07:Dec 13 2016:16:29:29
00:00:00 00:00:00 FPGAInterrupt.c@209:    Start mainFPGA taskname "FpgaTask"
00:00:00 00:00:00 FPGAInterrupt.c@280:    Debug: GEM-INTC INT4 EventID89
00:00:00 00:00:00 FPGAInterrupt.c@300:    Debug: GEM-INTC Configuration Completed
00:00:00 00:00:00 FPGAInterrupt.c@327:    Debug: GEM-INTC IRQ waiting
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 3
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 5
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 6
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 12
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 14
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 18
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 21
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 22
00:00:00 00:00:00 FPGAInterrupt.c@370:    GPIO interrupt occurs a = 23
I suppose that the HWI CSL_INTC_VECTID_4 is already used in TI RTOS as timer schedule
(or some other using), when I use this vectID the RTOS remains blocked .
If I can't use this vectID which other one I can use?
Where is my mistake ? or I have missed something?
Best Regards
Dario
  • I have configured this task at priority 7 and stack size 0x1000.
    This morning I have tried to configure a HWI interrupt in cfg file using CSL_INTC_VECTID_4
    as vectID and the configuro has failed (obviously I think this vectID is reserved in ti-RTOS).
    Dario
  • I've moved this to the device forum.
    Todd
    RTOS team have been notified. Feedback will be posted here.
    Yordan
       today I have resolved the question.
    ************* C code *****************
    /* CSL RL includes */
    /* XDCtools Header files */
    #include <xdc/cfg/global.h>
    /* BIOS Header files */
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Task.h>
    /* TI-RTOS Header files */
    #include <ti/drv/gpio/GPIO.h>
    #include <ti/drv/gpio/soc/GPIO_soc.h>
    #include <ti/board/board.h>
    //#define IRQ_SIMUL
    volatile int a = 0;
    static Void GPIO02InterruptHandler(UArg arg)
       Hwi_Params *hwiParams = (Hwi_Params *)arg;
       CSL_intcEventClear((CSL_IntcEventId)(hwiParams->arg));
       a++;
    int gpioISRConfig(int pinNum)
       int                        bankNum = 0, ret = 0;
    #ifdef IRQ_SIMUL
       int                        cnt = 1000;
    #endif
       GPIO_v0_HwAttrs            gpio_cfg;
       uint32_t                   eventId;
       Hwi_Params                 hwiParams;
       Hwi_Handle                 myHwi;
       Error_Block                eb;
       uint32_t                   numPins, numPorts;
       a = 0;
       GPIO_socGetNumPinsPorts(&numPins, &numPorts);
       if (pinNum > numPins)
          return -11;
          return -12;
       if (GPIO_socGetInitCfg(0/*GPIO_LED0_PORT_NUM*/, &gpio_cfg) == -1)
          DBG_PRINTF("Error: GEM-INTC get gpio cfg failed");
          return -13;
       eventId = gpio_cfg.intCfg[pinNum].eventId;
       // initialize error block and hwiParams to default values
       Error_init(&eb);
       Hwi_Params_init(&hwiParams);
       hwiParams.arg        = (UArg)(&hwiParams);
       hwiParams.enableInt  = TRUE;
       hwiParams.eventId    = eventId; // 89;
    // hwiParams.priority   = ???
    // hwiParams.maskSetting = Hwi_MaskingOption_SELF;
       myHwi = Hwi_create(5, GPIO02InterruptHandler, &hwiParams, &eb);
       if (myHwi == NULL)
          DBG_PRINTF("Error: Hwi create failed");
          return -15;
    #ifdef IRQ_SIMUL
    #endif
    #ifdef RISING
    #ifdef IRQ_SIMUL
    #endif
    #else
    #ifdef IRQ_SIMUL
    #endif
    #endif
       return ret;
       int    aLocal = 0;
    #ifdef IRQ_SIMUL
    #else
       int    pinNum = 15;
    #endif
       if (gpioISRConfig(pinNum) >= 0)
          do
    #ifdef IRQ_SIMUL
             if ((cnt--) == 0)
                cnt = 100;
    #ifdef RISING
    #else
    #endif
             else
            //    Task_sleep(10);
    #else
             Task_sleep(1000);
    #endif
    #ifdef IRQ_SIMUL
    #ifdef RISING
    #else
    #endif
    #endif
                aLocal = a;
       Task_exit();
       return;
    ****************** Cfg file ***************
    var Timer               = xdc.useModule('ti.sysbios.timers.timer64.Timer');
    var ti_sysbios_hal_Timer = xdc.useModule('ti.sysbios.hal.Timer');
    var DEV = xdc.useModule('ti.sysbios.io.DEV');
    Clock.timerId = -1;           // default
    var Defaults = xdc.useModule('xdc.runtime.Defaults');
    Exc.enablePrint     = true; /* prints exception details to the CCS console */
    Pcie.Settings.socType = devType;
    /////////////////////// GPIO IRQ ///////////////////////
    Task.deleteTerminatedTasks = true;
    var exception = xdc.useModule('ti.sysbios.family.c64p.Exception');
    exception.enablePrint = true;
    ////////////////////////// GPIO IRQ end //////////////////////////
    BIOS.libType = BIOS.LibType_NonInstrumented;
    BIOS.assertsEnabled = false;
    BIOS.logsEnabled = false;
    Clock.tickSource = Clock.TickSource_TIMER;
    ***************************Serial Console  ***********************************
    00:00:00 00:00:00 SrioMain.c@1241:    Start SrioTask taskname "SrioTask"
    00:00:00 00:00:00 SrioMain.c@1249:    Executing the SRIO Unit Tests on the DEVICE
    00:00:00 00:00:00 SrioMain.c@1261:    Debug(Core 0): System Initialization for CPPI & QMSS
    00:00:00 00:00:00 SrioMain.c@697:    Debug(Core 0): Queue Manager and CPPI are initialized.
    00:00:00 00:00:00 SrioMain.c@698:    Debug(Core 0): Host Region 0x866f80
    00:00:00 00:00:00 SrioMain.c@1289:    Debug(Core 0): SRIO Driver has been initialized
    00:00:00 00:00:00 QueueHandler.c@95:    0 messages are currently on the /SrioTask queue
    00:00:00 00:00:00 EthMain.c@281:    Start EthTask taskname "EthTask"
    Network Added: If-1: 192.168.0.8
    00:00:00 00:00:00 PlatformTest.c@1598:    Start PlatMsgCmd taskname "PlatTask"
    00:00:00 00:00:00 QueueHandler.c@95:    0 messages are currently on the /PlatTask queue
    00:00:00 00:00:00 CLI.c@1284:    Start ColiTask taskname "ColiTask"
    Write "quit" or "exit" for exit
    PROMPT:>
    Unknown command ("")
    To see the commands writes:"help"
    PROMPT:>
    00:00:00 00:00:00 CLI.c@1352:    Start CliRecTask taskname "ColiTask"
    00:00:00 00:00:00 QueueHandler.c@95:    0 messages are currently on the /ColiRecTask queue
    00:00:00 00:00:00 SwTimer.c@425:    Start SwTmrTask taskname "SwTmrTask"
    00:00:00 00:00:00 FPGAInterrupt.c@669:    Start mainFPGA taskname "FpgaTask"
    00:00:00 00:00:00 FPGAInterrupt.c@271:    Debug: GEM-INTC Configuration Completed
    00:00:00 00:00:00 FPGAInterrupt.c@298:    Debug: GEM-INTC IRQ waiting
    PROMPT:>
    00:00:03 00:00:03 FPGAInterrupt.c@710:    GPIO interrupt occurs a = 10
    00:00:04 00:00:01 FPGAInterrupt.c@710:    GPIO interrupt occurs a = 27
    PROMPT:>
    ************ Log  on PC *************
    64 bytes from 192.168.0.8: icmp_seq=13703 ttl=255 time=0.153 ms
    64 bytes from 192.168.0.8: icmp_seq=13704 ttl=255 time=0.153 ms
    64 bytes from 192.168.0.8: icmp_seq=13705 ttl=255 time=0.153 ms
    64 bytes from 192.168.0.8: icmp_seq=13706 ttl=255 time=0.144 ms
    64 bytes from 192.168.0.8: icmp_seq=13707 ttl=255 time=0.145 ms
    64 bytes from 192.168.0.8: icmp_seq=13708 ttl=255 time=0.153 ms
    64 bytes from 192.168.0.8: icmp_seq=13709 ttl=255 time=0.152 ms
    The solution is not use (anymore) the CSL_intcInit / CSL_intcGlobalNmiEnable /
    CSL_intcOpen / CSL_intcPlugEventHandler / CSL_intcHwControl functions (intc module)
    Dario
