NOR Flash wiring to DM6467
The EVM for the DM6467 uses NAND flash.  Can you provide guidance on connecting NOR flash to this device?  Is there an example somewhere that I could reference?
-mc
  • The asynchronous SRAM interface is the one to look at.  NOR flash will have the same interface.  The difference comes in programming the NOR flash you'll need to execute a special sequence of writes as defined in the NOR flash data sheet.
    If you want to see an example for a similar device you could look at the DM6446 schematics.
