Part Number: DRA752
Other Parts Discussed in Thread: PMP, DRA742, , TVP5158, OPA362, TFP410, TPD12S015, TLC59108
Tool/software: Linux
Hi all,
I use GLSDK 3.00.00.03, custom board. It cannot use modetest and frame buffer (/dev/fb0) does not generate, either.
I referenced "Processor SDK Linux Automotive Data Sheet - OMAPDRM/OMAPDSS (Display Subsystem Driver)"
CONFIG_DRM_OMAP, CONFIG_OMAP2_DSS_DPI, CONFIG_OMAP5_DSS_HDMI all [y]
Some config such as CONFIG_OMAP2_DSS_DRA7XX_DPI, CONFIG_OMAP5_DSS_HDMI_DDC, and CONFIG_PANEL_TFCS9700 I cannot find...
The following is my boot log and modetest error message...
Log
U-Boot SPL 2016.05 (Apr 07 2017 - 12:00:45)
DRA752-GP ES2.0
MMC Device 1 not found
*** Warning - No MMC card found, using default environment
Trying to boot from MMC1
reading u-boot.img
reading u-boot.img
U-Boot 2016.05 (Apr 07 2017 - 12:00:45 +0800)
CPU : DRA752-GP ES2.0
Board: DRA74x EVM REV <NULL>
I2C: ready
DRAM: 1.5 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Warning: fastboot.board_rev: unknown board revision
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: <ethaddr> not set. Validating first E-fuse MAC
Could not get PHY for cpsw: addr 2
cpsw
Hit any key to stop autoboot: 0
=> boot_sd
J6 ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
3742008 bytes read in 336 ms (10.6 MiB/s)
107570 bytes read in 30 ms (3.4 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x391938 ]
Loading Device Tree to 8ffe2000, end 8ffff431 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.14 (root@louis-VirtualBox) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #18 SMP PREEMPT Fri Apr 7 14:28:04 CST 2017
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA742
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000de400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000dfd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ef1ae000 s19008 r8192 d21952 u49152
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 389440
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=65525fa8-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1350512K/1564672K available (6671K kernel code, 364K rwdata, 2516K rodata, 352K init, 293K bss, 25744K reserved, 188416K cma-reserved, 757760K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0901084 (9189 kB)
[ 0.000000] .init : 0xc0902000 - 0xc095a000 ( 352 kB)
[ 0.000000] .data : 0xc095a000 - 0xc09b5150 ( 365 kB)
[ 0.000000] .bss : 0xc09b7000 - 0xc0a00618 ( 294 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer1 at 31475 Hz
[ 0.000000] Architected cp15 timer(s) running at 5.90MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
[ 0.000004] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
[ 0.000015] Switching to timer-based delay loop, resolution 169ns
[ 0.000357] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000366] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000819] Console: colour dummy device 80x30
[ 0.000835] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000841] This ensures that you still see kernel messages. Please
[ 0.000847] update your kernel commandline.
[ 0.000861] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
[ 0.000873] pid_max: default: 32768 minimum: 301
[ 0.000967] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000978] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001501] Initializing cgroup subsys io
[ 0.001518] Initializing cgroup subsys memory
[ 0.001541] Initializing cgroup subsys devices
[ 0.001553] Initializing cgroup subsys freezer
[ 0.001565] Initializing cgroup subsys perf_event
[ 0.001576] Initializing cgroup subsys pids
[ 0.001597] CPU: Testing write buffer coherency: ok
[ 0.001803] /cpus/cpu@0 missing clock-frequency property
[ 0.001818] /cpus/cpu@1 missing clock-frequency property
[ 0.001830] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001868] Setting up static identity map for 0x80008380 - 0x800083d8
[ 0.080049] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080112] Brought up 2 CPUs
[ 0.080126] SMP: Total of 2 processors activated (23.60 BogoMIPS).
[ 0.080132] CPU: All CPU(s) started in SVC mode.
[ 0.080512] devtmpfs: initialized
[ 0.106989] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.107925] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.302077] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.305789] pinctrl core: initialized pinctrl subsystem
[ 0.306645] NET: Registered protocol family 16
[ 0.307588] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.330212] cpuidle: using governor ladder
[ 0.360235] cpuidle: using governor menu
[ 0.368766] OMAP GPIO hardware version 0.1
[ 0.372742] GPIO line 161 (radio_rst) hogged as output/low
[ 0.400285] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.400296] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.400683] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.400693] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.401271] OMAP DMA hardware revision 0.0
[ 0.434500] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[ 0.435622] edma 43300000.edma: memcpy is disabled
[ 0.440409] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.444421] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.444591] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.444745] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.444905] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.445186] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.445364] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.447512] SCSI subsystem initialized
[ 0.447897] usbcore: registered new interface driver usbfs
[ 0.447954] usbcore: registered new interface driver hub
[ 0.448025] usbcore: registered new device driver usb
[ 0.449361] palmas 0-0058: IRQ missing: skipping irq request
[ 0.460678] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
[ 0.532385] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.550571] pcf857x: probe of 1-0026 failed with error -121
[ 0.550830] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.551198] omap_i2c 48060000.i2c: bus 2 rev0.12 at 1 kHz
[ 0.590556] pcf857x: probe of 3-0021 failed with error -121
[ 0.590594] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 1 kHz
[ 0.590953] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 1 kHz
[ 0.591145] media: Linux media interface: v0.10
[ 0.591195] Linux video capture interface: v2.00
[ 0.591239] pps_core: LinuxPPS API ver. 1 registered
[ 0.591246] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.591274] PTP clock support registered
[ 0.591303] EDAC MC: Ver: 3.0.0
[ 0.592061] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.592346] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.593434] clocksource: Switched to clocksource arch_sys_counter
[ 0.603989] NET: Registered protocol family 2
[ 0.604504] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.604577] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.604708] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.604757] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.604788] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.604977] NET: Registered protocol family 1
[ 0.605228] RPC: Registered named UNIX socket transport module.
[ 0.605237] RPC: Registered udp transport module.
[ 0.605244] RPC: Registered tcp transport module.
[ 0.605250] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.606217] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.608327] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.616152] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.616810] NFS: Registering the id_resolver key type
[ 0.616834] Key type id_resolver registered
[ 0.616842] Key type id_legacy registered
[ 0.616917] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.618888] bounce: pool size: 64 pages
[ 0.619044] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.619058] io scheduler noop registered
[ 0.619069] io scheduler deadline registered
[ 0.619099] io scheduler cfq registered (default)
[ 0.624169] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.627266] PCI host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.627279] No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
[ 0.627312] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.627332] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.631350] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 0.631363] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.631373] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.631383] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.631792] PCI: bus0: Fast back to back transfers disabled
[ 0.643517] PCI: bus1: Fast back to back transfers disabled
[ 0.643566] irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
[ 0.643610] irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
[ 0.643647] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.643661] pci 0000:00:00.0: BAR 8: assigned [mem 0x20200000-0x202fffff]
[ 0.643673] pci 0000:00:00.0: BAR 9: assigned [mem 0x20300000-0x203fffff pref]
[ 0.643684] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.643698] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.643712] pci 0000:01:00.0: BAR 6: assigned [mem 0x20300000-0x2033ffff pref]
[ 0.643723] pci 0000:01:00.0: BAR 0: assigned [mem 0x20200000-0x2021ffff]
[ 0.643743] pci 0000:01:00.0: BAR 1: assigned [mem 0x20220000-0x2022ffff]
[ 0.643764] pci 0000:01:00.0: BAR 3: assigned [mem 0x20230000-0x20233fff]
[ 0.643784] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 0.643806] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.643816] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 0.643827] pci 0000:00:00.0: bridge window [mem 0x20200000-0x202fffff]
[ 0.643838] pci 0000:00:00.0: bridge window [mem 0x20300000-0x203fffff pref]
[ 0.644063] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.644073] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.704511] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.708120] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 0.708997] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[ 0.709858] console [ttyS2] disabled
[ 0.709904] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[ 1.787248] console [ttyS2] enabled
[ 1.791639] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 304, base_baud = 3000000) is a 8250
[ 1.801357] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 305, base_baud = 3000000) is a 8250
[ 1.811041] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 306, base_baud = 3000000) is a 8250
[ 1.820725] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 307, base_baud = 3000000) is a 8250
[ 1.830809] [drm] Initialized drm 1.1.0 20060810
[ 1.837549] OMAP DSS rev 6.1
[ 1.841612] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.850170] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 1.859427] connector-hdmi connector@1: failed to find video source
[ 1.876536] brd: module loaded
[ 1.884782] loop: module loaded
[ 1.894371] libphy: Fixed MDIO Bus: probed
[ 1.943460] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 1.949585] davinci_mdio 48485000.mdio: detected phy mask 0
[ 2.053439] davinci_mdio 48485000.mdio: timed out waiting for user access
[ 2.153436] davinci_mdio 48485000.mdio: timed out waiting for idle
[ 2.159669] davinci_mdio: probe of 48485000.mdio failed with error -5
[ 2.166777] cpsw 48484000.ethernet: Detected MACID = a4:d5:78:9e:a0:9a
[ 2.174050] cpsw 48484000.ethernet: cpsw: Detected MACID = a4:d5:78:9e:a0:9b
[ 2.182368] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.188949] ehci-pci: EHCI PCI platform driver
[ 2.193485] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.199070] usbcore: registered new interface driver usbserial
[ 2.205278] mousedev: PS/2 mouse device common for all mice
[ 2.221474] i2c /dev entries driver
[ 2.225779] tvp5158 1-0058: Camera sensor driver registered
[ 2.232237] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 2.239337] vip 48990000.vip: loading firmware vpdma-1b8.bin
[ 2.253628] vpe 489d0000.vpe: Device registered as /dev/video0
[ 2.263458] vip 48990000.vip: VPDMA firmware loaded
[ 2.268473] vip2-s1: Port B: Using subdev tvp5158 1-0058 for capture
[ 2.275040] vip2-s1: device registered as video1
[ 2.283805] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[ 2.290055] evm_3v3_sw: supplied by sysen1
[ 2.333798] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
[ 2.374225] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.380442] usbcore: registered new interface driver usbhid
[ 2.386058] usbhid: USB HID core driver
[ 2.392901] omap_hwmod: atl: _wait_target_ready failed: -16
[ 2.398525] ------------[ cut here ]------------
[ 2.400000] hwspinlock_user gatemp: requested 10 hwspinlocks
[ 2.401690] NET: Registered protocol family 10
[ 2.412572] sit: IPv6 over IPv4 tunneling driver
[ 2.413146] NET: Registered protocol family 17
[ 2.413387] Key type dns_resolver registered
[ 2.413510] omap_voltage_late_init: Voltage driver support not added
[ 2.414044] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.414048] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.414096] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.414236] Power Management for TI OMAP4+ devices.
[ 2.414503] Registering SWP/SWPB emulation handler
[ 2.461597] WARNING: CPU: 0 PID: 6 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x23c/0x368()
[ 2.470944] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
[ 2.483079] Modules linked in:
[ 2.486155] CPU: 0 PID: 6 Comm: kworker/u4:0 Not tainted 4.4.14 #18
[ 2.492449] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 2.498570] Workqueue: kmmcd mmc_rescan
[ 2.502427] Backtrace:
[ 2.504901] [<c0012ba0>] (dump_backtrace) from [<c0012d3c>] (show_stack+0x18/0x1c)
[ 2.512503] r6:c0862a84 r5:00000000 r4:20000193 r3:eecac000
[ 2.518228] [<c0012d24>] (show_stack) from [<c02a5fac>] (dump_stack+0x88/0xa8)
[ 2.525485] [<c02a5f24>] (dump_stack) from [<c00345f0>] (warn_slowpath_common+0x7c/0xb8)
[ 2.533608] r5:00000093 r4:eecadb50
[ 2.537215] [<c0034574>] (warn_slowpath_common) from [<c00346d0>] (warn_slowpath_fmt+0x38/0x40)
[ 2.545948] r8:c06c552c r7:eedb1b90 r6:c0862974 r5:c08629e0 r4:80080003
[ 2.552723] [<c003469c>] (warn_slowpath_fmt) from [<c02d263c>] (l3_interrupt_handler+0x23c/0x368)
[ 2.561628] r3:eedb1a00 r2:c0862aa0
[ 2.565239] [<c02d2400>] (l3_interrupt_handler) from [<c007cc14>] (handle_irq_event_percpu+0x64/0x164)
[ 2.574581] r10:eedad840 r9:c09b440b r8:00000017 r7:00000000 r6:00000000 r5:eedad8a0
[ 2.582483] r4:eedb1f00
[ 2.585038] [<c007cbb0>] (handle_irq_event_percpu) from [<c007cd54>] (handle_irq_event+0x40/0x64)
[ 2.593945] r10:00000000 r9:eeca4000 r8:eec08000 r7:00000000 r6:c0961e44 r5:eedad8a0
[ 2.601847] r4:eedad840
[ 2.604401] [<c007cd14>] (handle_irq_event) from [<c007ffec>] (handle_fasteoi_irq+0xbc/0x194)
[ 2.612959] r6:c0961e44 r5:eedad8a0 r4:eedad840 r3:00000000
[ 2.618678] [<c007ff30>] (handle_fasteoi_irq) from [<c007c4a4>] (generic_handle_irq+0x20/0x30)
[ 2.627323] r7:00000000 r6:00000000 r5:c0956424 r4:00000017
[ 2.633042] [<c007c484>] (generic_handle_irq) from [<c007c5d0>] (__handle_domain_irq+0x5c/0xbc)
[ 2.641781] [<c007c574>] (__handle_domain_irq) from [<c000945c>] (gic_handle_irq+0x3c/0x7c)
[ 2.650164] r8:fa213000 r7:fa212000 r6:eecadcf8 r5:c095c8d8 r4:fa21200c r3:eecadcf8
[ 2.657986] [<c0009420>] (gic_handle_irq) from [<c0013800>] (__irq_svc+0x40/0x74)
[ 2.665500] Exception stack(0xeecadcf8 to 0xeecadd40)
[ 2.670571] dce0: 02b3d879 00000000
[ 2.678786] dd00: 65c22580 c0536ef4 c09ea4a0 0000170d 02b3c200 eecaddf8 c0706878 eeca4000
[ 2.687000] dd20: 00000000 eecadd54 eecadd58 eecadd48 c0016830 c0536f04 a0000113 ffffffff
[ 2.695211] r8:c0706878 r7:eecadd2c r6:ffffffff r5:a0000113 r4:c0536f04 r3:c0016830
[ 2.703034] [<c0536ef4>] (arch_counter_get_cntvct) from [<c0016830>] (arch_timer_read_counter_long+0x1c/0x20)
[ 2.712995] [<c0016814>] (arch_timer_read_counter_long) from [<c02a3e14>] (__timer_delay+0x50/0x64)
[ 2.722082] [<c02a3dc4>] (__timer_delay) from [<c02a3e50>] (__timer_const_udelay+0x28/0x2c)
[ 2.730465] r6:c0986e74 r5:eecf8400 r4:00000181 r3:000005c3
[ 2.736183] [<c02a3e28>] (__timer_const_udelay) from [<c051a398>] (__mmc_start_request+0x80/0xd8)
[ 2.745093] [<c051a318>] (__mmc_start_request) from [<c051a4e8>] (mmc_start_request+0xf8/0x120)
[ 2.753825] r7:eecade08 r6:eecaddf8 r5:eecf8400 r4:eecaddf8
[ 2.759542] [<c051a3f0>] (mmc_start_request) from [<c051a554>] (mmc_wait_for_req+0x44/0x15c)
[ 2.768012] r5:eecf8400 r4:eecade44
[ 2.771620] [<c051a510>] (mmc_wait_for_req) from [<c051a6e8>] (mmc_wait_for_cmd+0x7c/0x9c)
[ 2.779916] r8:c0706878 r7:00061a80 r6:00000000 r5:eecf8400 r4:eecade44 r3:00000000
[ 2.787739] [<c051a66c>] (mmc_wait_for_cmd) from [<c0525644>] (mmc_io_rw_direct_host+0xa4/0x114)
[ 2.796559] r6:00000001 r5:eecadea7 r4:eecf8400
[ 2.801224] [<c05255a0>] (mmc_io_rw_direct_host) from [<c0525b70>] (sdio_reset+0x34/0x6c)
[ 2.809432] r6:eecf8400 r5:c070686c r4:eecf8400
[ 2.814100] [<c0525b3c>] (sdio_reset) from [<c051ca6c>] (mmc_rescan+0x25c/0x2ec)
[ 2.821525] r4:eecf8658
[ 2.824081] [<c051c810>] (mmc_rescan) from [<c0048ac4>] (process_one_work+0x128/0x330)
[ 2.832029] r8:00000000 r7:eeeaf800 r6:eeca4000 r5:eecf8658 r4:eec5f000 r3:c051c810
[ 2.839848] [<c004899c>] (process_one_work) from [<c0048d3c>] (worker_thread+0x34/0x4b0)
[ 2.847970] r10:eeca4000 r9:eeca4000 r8:00000088 r7:eec5f018 r6:eec5f000 r5:00000001
[ 2.855869] r4:eeca4014
[ 2.858425] [<c0048d08>] (worker_thread) from [<c004e4a0>] (kthread+0xe0/0xfc)
[ 2.865675] r10:00000000 r9:00000000 r8:00000000 r7:c0048d08 r6:eec5f000 r5:00000000
[ 2.873577] r4:eec5e1c0
[ 2.876132] [<c004e3c0>] (kthread) from [<c000fd08>] (ret_from_fork+0x14/0x2c)
[ 2.883381] r7:00000000 r6:00000000 r5:c004e3c0 r4:eec5e1c0
[ 2.889095] ---[ end trace 029518b5a71f1fea ]---
[ 2.894279] dmm 4e000000.dmm: initialized all PAT entries
[ 2.910470] connector-hdmi connector@1: failed to find video source
[ 2.912074] [drivers/mmc/core/core.c, mmc_select_voltage, 1515], ocr: 1090486272
[ 2.912077] [drivers/mmc/core/core.c, mmc_select_voltage, 1528], ocr: 3145728
[ 2.912081] [drivers/mmc/core/core.c, mmc_select_voltage, 1543]
[ 2.912085] [drivers/mmc/core/sd.c, mmc_sd_init_card, 903]
[ 2.939038] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.939116] mmc0: new SDHC card at address 0001
[ 2.955869] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.962077] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.965710] mmcblk0: mmc0:0001 SD4GB 3.64 GiB
[ 2.972857] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.973817] mmcblk0: p1 p2
[ 2.982871] connector-hdmi connector@1: failed to find video source
[ 2.982902] hctosys: unable to open rtc device (rtc0)
[ 2.994869] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.999116] aic_dvdd: disabling
[ 3.004343] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.010631] ldousb: disabling
[ 3.010650] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 3.023063] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 195]
[ 3.029423] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 206]
[ 3.035890] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 232] err: 0
[ 3.042546] [drivers/mmc/core/core.c, mmc_select_voltage, 1515], ocr: 16744576
[ 3.049820] [drivers/mmc/core/core.c, mmc_select_voltage, 1528], ocr: 3145728
[ 3.057490] [drivers/mmc/core/core.c, mmc_select_voltage, 1543]
[ 3.067107] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 195]
[ 3.073776] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 223]
[ 3.093759] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 218]
[ 3.099710] [drivers/mmc/core/mmc_ops.c, mmc_send_op_cond, 232] err: 0
[ 3.119213] mmc1: MAN_BKOPS_EN bit is not set
[ 3.123610] [drivers/mmc/core/mmc_ops.c, __mmc_switch, 505]
[ 3.130387] [drivers/mmc/core/mmc_ops.c, __mmc_switch, 572]
[ 3.136013] [drivers/mmc/core/mmc_ops.c, __mmc_switch, 505]
[ 3.142251] [drivers/mmc/core/mmc_ops.c, __mmc_switch, 572]
[ 3.147884] [drivers/mmc/core/mmc_ops.c, __mmc_switch, 505]
[ 3.282927] EXT4-fs (mmcblk0p2): recovery complete
[ 3.290444] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.298619] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.307075] devtmpfs: mounted
[ 3.310270] Freeing unused kernel memory: 352K (c0902000 - c095a000)
[ 3.316672] This architecture does not have kernel memory protection.
INIT: version 2.88 booting[ 3.503129] [drivers/mmc/core/mmc_ops.c, __mmc_switch, 540]
[ 3.508777] [drivers/mmc/core/mmc.c, mmc_init_card, 1661]
[ 3.514791] [drivers/mmc/core/mmc.c, mmc_init_card, 1710]
[ 3.520284] [drivers/mmc/core/mmc.c, mmc_init_card, 1714]
[ 3.525891] [drivers/mmc/core/mmc.c, mmc_attach_mmc, 2101]
[ 3.531403] mmc1: error -110 whilst initialising MMC card
[ 3.544690] [drivers/mmc/core/core.c, mmc_select_voltage, 1515], ocr: 16744448
[ 3.551949] [drivers/mmc/core/core.c, mmc_select_voltage, 1528], ocr: 3145728
[ 3.559168] [drivers/mmc/core/core.c, mmc_select_voltage, 1543]
[ 3.565149] [drivers/mmc/core/sd.c, mmc_sd_init_card, 903]
[ 3.700539] mmc2: host does not support reading read-only switch, assuming write-enable
[ 3.708834] mmc2: new SDHC card at address 59b4
[ 3.723973] mmcblk1: mmc2:59b4 USDU1 3.70 GiB
[ 3.729914] mmcblk1: p1 p2
[ 3.733664] connector-hdmi connector@1: failed to find video source
[ 3.741027] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.747262] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.753826] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
Starting udev
[ 4.059662] udevd[109]: starting version 182
[ 4.491842] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[ 4.571765] remoteproc0: 58820000.ipu is available
[ 4.662451] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 4.753496] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 4.909555] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 4.909705] connector-hdmi connector@1: failed to find video source
[ 4.910214] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 4.910218] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 4.910273] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 4.957366] remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 5.018068] remoteproc0: failed to load dra7-ipu1-fw.xem4
[ 5.160595] CAN device driver interface
[ 5.260702] remoteproc1: 55020000.ipu is available
[ 5.273492] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 5.371797] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.391165] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 5.391358] connector-hdmi connector@1: failed to find video source
[ 5.391879] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5.391884] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5.391940] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 5.497998] remoteproc2: 40800000.dsp is available
[ 5.504046] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 5.516160] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.540120] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 5.548689] remoteproc3: 41000000.dsp is available
[ 5.550021] connector-hdmi connector@1: failed to find video source
[ 5.550544] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5.550548] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5.550604] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 5.581095] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 5.592610] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 5.605036] connector-hdmi connector@1: failed to find video source
[ 5.611593] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 5.620927] remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 5.621668] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5.621672] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5.621726] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 5.651682] remoteproc3: failed to load dra7-dsp2-fw.xe66
[ 5.658201] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[ 5.668400] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 5.681796] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 5.695166] connector-hdmi connector@1: failed to find video source
[ 5.702200] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 5.704153] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5.704157] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5.704214] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 5.729028] connector-hdmi connector@1: failed to find video source
[ 5.736216] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
[ 5.741801] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5.741805] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5.741859] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 5.766622] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 5.767587] connector-hdmi connector@1: failed to find video source
[ 5.768036] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 5.768040] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 5.768094] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
udevd[427]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
udevd[428]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
[ 6.133030] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 6.139237] connector-hdmi connector@1: failed to find video source
[ 6.139412] remoteproc2: registered virtio0 (type 7)
[ 6.151662] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 6.159101] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.159370] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 6.159397] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 6.159406] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 6.191127] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.197819] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.204854] connector-hdmi connector@1: failed to find video source
[ 6.207643] scsi host0: ahci
[ 6.207993] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 346
[ 6.208572] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 6.228506] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.234765] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.241024] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.247847] connector-hdmi connector@1: failed to find video source
[ 6.300678] remoteproc2: powering up 40800000.dsp
[ 6.306829] remoteproc1: powering up 55020000.ipu
[ 6.311648] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3484972
[ 6.321346] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 929770
[ 6.328323] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 6.340937] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 6.346833] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 6.352758] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 6.435565] remoteproc1: remote processor 55020000.ipu is now up
[ 6.442326] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 6.445470] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
[ 6.455472] remoteproc1: registered virtio1 (type 7)
[ 6.455956] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.455961] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.456016] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.456444] connector-hdmi connector@1: failed to find video source
[ 6.483680] remoteproc2: remote processor 40800000.dsp is now up
[ 6.494207] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.499763] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x36
[ 6.508889] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.517626] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x37
[ 6.523664] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.523752] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.524247] connector-hdmi connector@1: failed to find video source
[ 6.543526] ata1: SATA link down (SStatus 0 SControl 300)
[ 6.550066] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
[ 6.676948] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 6.682811] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 6.689139] e1000e 0000:01:00.0: enabling device (0140 -> 0142)
[ 6.695658] e1000e 0000:01:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 6.705621] e1000e 0000:01:00.0 0000:01:00.0 (uninitialized): Failed to initialize MSI-X interrupts. Falling back to MSI interrupts.
[ 6.737776] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.744374] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.750636] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.757788] connector-hdmi connector@1: failed to find video source
[ 6.771479] rpmsg_rpc rpmsg0: probing service rpmsg-dce with src 1024 dst 59
[ 6.783853] rpmsg_rpc rpmsg3: probing service rpmsg-dce-dsp with src 1024 dst 59
[ 6.784219] rpmsg_rpc rpmsg0: published functions = 8
[ 6.797175] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.803571] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.809823] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.816933] rpmsg_rpc rpmsg3: published functions = 8
[ 6.819430] connector-hdmi connector@1: failed to find video source
[ 6.819864] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.819868] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.819918] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 6.851748] e1000e 0000:01:00.0 eth2: registered PHC clock
[ 6.858389] e1000e 0000:01:00.0 eth2: (PCI Express:2.5GT/s:Width x1) 88:88:88:88:87:88
[ 6.868836] e1000e 0000:01:00.0 eth2: Intel(R) PRO/1000 Network Connection
[ 6.875911] e1000e 0000:01:00.0 eth2: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
[ 6.883176] connector-hdmi connector@1: failed to find video source
[ 6.892461] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.898778] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.911760] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
udevd[484]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
[ 6.977573] connector-hdmi connector@1: failed to find video source
[ 6.984743] dwc3 48910000.usb: failed to register ULPI interface
[ 6.985443] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 6.985447] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 6.985505] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.005864] connector-hdmi connector@1: failed to find video source
[ 7.006294] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.006298] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.006349] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.006500] pinctrl-single 4a003400.pinmux: pin 4a0037d0.0 already requested by 4806a000.serial; cannot claim for 4ae3c000.can
[ 7.006505] pinctrl-single 4a003400.pinmux: pin-244 (4ae3c000.can) status -22
[ 7.006513] pinctrl-single 4a003400.pinmux: could not request pin 244 (4a0037d0.0) from group dcan1_pins_sleep on device pinctrl-single
[ 7.006518] c_can_platform 4ae3c000.can: Error applying setting, reverse things back
[ 7.007290] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=356)
[ 7.010295] connector-hdmi connector@1: failed to find video source
[ 7.010718] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.010722] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.010771] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.027506] [drm] Initialized pvr 1.14.3699939 20110701 on minor 0
[ 7.028918] connector-hdmi connector@1: failed to find video source
[ 7.029378] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.029382] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.029434] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
udevd[500]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory[ 7.139773] dwc3: probe of 48910000.usb failed with error -110
[ 7.181634] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 7.187644] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 7.195826] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[ 7.204681] xhci-hcd xhci-hcd.1.auto: irq 467, io mem 0x48890000
[ 7.211468] hub 1-0:1.0: USB hub found
[ 7.215309] hub 1-0:1.0: 1 port detected
[ 7.219838] connector-hdmi connector@1: failed to find video source
[ 7.226372] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 7.231891] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 7.240050] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.246284] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.252534] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.259128] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 7.259379] connector-hdmi connector@1: failed to find video source
[ 7.274493] hub 2-0:1.0: USB hub found
[ 7.278292] hub 2-0:1.0: 1 port detected
[ 7.282681] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 7.282708] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.282712] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.282758] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.283120] connector-hdmi connector@1: failed to find video source
[ 7.313415] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[ 7.321399] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[ 7.330196] xhci-hcd xhci-hcd.2.auto: irq 468, io mem 0x488d0000
[ 7.337183] hub 3-0:1.0: USB hub found
[ 7.340979] hub 3-0:1.0: 1 port detected
[ 7.345262] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.345310] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 7.345326] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[ 7.345416] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 7.372912] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.373418] hub 4-0:1.0: USB hub found
[ 7.373479] hub 4-0:1.0: 1 port detected
[ 7.399810] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.408558] connector-hdmi connector@1: failed to find video source
[ 7.415454] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.421738] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.428277] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.453377] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
tSarting Bootlog daemon: oobtlogd.
[ 7.542522] random: dd urandom read with 53 bits of entropy available
LASA: Restoring mixer settings...
u/sr/sbin/alsactl: load_state:1729: No soundcards found...
hTu Sep 3 18:41:00 UTC 2015
et/c/rcS.d/S98_AB_auto_execution.sh: line 17: /proc/irq/301/smp_afinity: No such file or directory
/usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
/usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
INIT: Entering runlevel: 5
Configuring network interfaces... [ 9.546725] net eth0: initializing cpsw version 1.15 (0)
[ 9.552083] net eth0: initialized cpsw ale version 1.4
[ 9.560332] libphy: PHY 48485000.mdio:02 not found
[ 9.565172] net eth0: phy "48485000.mdio:02" not found on slave 0, err -19
[ 9.578724] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.22.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting system message bus: dbus.
UIM SYSFS Node Not Found
Starting telnet daemon.
Starting tiipclad daemon
GateMP support enabled on host
Opened log file: lad.txt
numProcessors = 5 id = 0 baseId = 0
Spawned daemon: /usr/bin/lad_dra7xx
Starting rpcbind daemon...done.
creating NFS state directory: done
starting statd: done
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
Starting thttpd.
Enabling thermal zones...
Stopping Bootlog daemon: bootlogd.
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# modetest
trying to load module i915...failed.
trying to load module radeon...failed.
trying to load module nouveau...failed.
trying to load module vmwgfx...failed.
trying to load module omapdrm...failed.
trying to load module exynos...failed.
failed to load any modules, aborting.
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# dmesg | grep omapdrm
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~# ls -la /dev/fb*
ls: /dev/fb*: No such file or directory
root@wnc-j6:~#
root@wnc-j6:~#
root@wnc-j6:~#
Could you give me some debug way? Thanks.
