MPEG4_Decoder-Intigration --- help full inforamation
Hi Guys ,
This my last post because i am move to other task.
It may help when you are going to intgrate your decoders into Davince board(DM6446)
Packages used:
bios_setuplinux_5_33_03.bin
dm6446_codecs_setuplinux_2_00_00_22.bin
dvsdk_setuplinux_2_00_00_22.bin
LPTB-02.03.00.02-beta.bin
mvl_5_0_0_demo_lsp_setuplinux_02_00_00_140.bin
mvl_5_0_0801921_demo_sys_setuplinux.bin
TI-C6x-CGT-v6.0.21.1.bin
xdctools_setuplinux_3_10_03.bin
Note: Reference is video copy example for both dsp server and codec  to build.
Step 1 Dsp Server Side:
#cd
/media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/servers
#mkdir  mpeg4
#vim makefile
Add your newly created directory into the make file.
all:
        #$(MAKE) -C video_copy $@
        #$(MAKE) -C all_codecs $@
        #$(MAKE) -C all_codecs_new_config $@
        #$(MAKE) -C audio1_ires $@
        #$(MAKE) -C server_api_example $@
        $(MAKE) -C Mpeg4_Lnt_decoder $@
        $(MAKE) -c mpeg4 $@
#cd mpeg4
Copy  makefile  file from video_copy/makefile to mpeg4/makefile
And change the name of video_copy to mpeg4.
Copy  package.xdc  file from  video_copy/ package.xdc   to mpeg4/ package.xdc
#mkdir evmDM6446
#cd evmDM6446
Copy link.cmd, main.c, makefile, video_copy.cfg, video_copy.tcf, package.xdc  form servers/video_copy/evmDM6446 / to servers/mpeg4/evmDM6446/
And make changes the video_copy to mpeg4 in all file and directory name also.
Step 2 Dsp codec Side:
#cd  /media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/codecs
#mkdir mpeg4
#vim makefile
Add your directory name into the make file.
#cd mpeg4
Copy all the file form dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/codecs/video_copy/
To dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/codecs/mpeg4/
Change the name of video_copy to mpeg4  file names and inside the file also.
Main file in this directory
 Makefile
MPEG4.xdc
MPEG4.xs
package.bld
package.xdc
package.xs
Ø  if you want rebuild the codec engine interface please write the make file within all inter-face  like node ,vdec,ved2 ….etc.
refer the make file form /media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node.
Ø  If you want debug the ARM-DSP side please follow these steps
Ø  home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace
Ø  const Attrs FULL_TRACING = {
        localTraceMask:    "*=01234567",
        localTraceFile:    "/tmp/cearmlog.txt",
        dsp0TraceMask:     "*=01234567,ti.bios=01324567",
        dsp0TraceFile:     "/tmp/cedsp0log.txt",
        dsp0BiosFile:      "/tmp/bioslog.dat",
        traceFileFlags:    "w",
        refreshPeriod:     100,
        cmdPipeFile:       "/tmp/cecmdpipe",
        cmdAliases: [ ],
Ø  Now go to /home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/apps/video_copy/dualcpu/evmDM6446
Ø  open ceapp.cfg
Ø  edit
Ø  TraceUtil.attrs = TraceUtil.SOCRATES_TRACING; this to
Ø  TraceUtil.attrs = TraceUtil.FULL_TRACING;
Ø  Rebuild your ARM application .
Ø  Run on the board
Ø  you will get the log message of DSP , ARM ,Bios in
Ø   tmp/cearmlog.txt
Ø  "/tmp/cedsp0log.txt
Ø  tmp/bioslog.dat
http://e2e.ti.com/forums/p/9907/38806.aspx#38806
Ø  for memory configuration edit the  all_evmDM6446.tci from
/media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/servers/all_codecs/ all_evmDM6446.tci
Step 3 ARM Side:
#cd /media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/apps
#mkdir mpeg4
#cd mpeg4
#mkdir dualcpu
#cd dualcpu
#cd dualcpu
Copy all the files and directories form
/media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/apps/video_copy/dualcpu
/media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/apps/mpeg4/dualcpu
#cd evmDM6446
#vim ceapp.cfg
Edit  this file like:
var myEngine = Engine.createFromServer(
    "mpeg4",        // Engine name (as referred to in the C app)
    "./mpeg4.x64P", // path to server exe, relative to its package dir
    "ti.sdo.ce.examples.servers.mpeg4.evmDM6446" // server package
And edit the necessary file form video_copy to mpeg4.
Step 4 : Integration mpeg4 codec into demo
Codec side:
Procedure to make our mpeg4 library integration into decodeCombo.x64P.
decodeCombo.x64P contains all the decode/encode library.
copy your mpeg4 codec directory form
/media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples/ti/sdo/ce/examples/codecs/ mpeg4
To
/media/hda2/home/mahesh/dvsdk_2_00_00_22/dm6446_dvsdk_combos_2_05/packages/ti/sdo/codecs/
#vim  makefile
Edit the
EXAMPLES_ROOTDIR := /media/hda2/home/mahesh/dvsdk_2_00_00_22/codec_engine_2_23_01/examples
#vim  package,xdc
Edit:
package ti.sdo.codecs.mpeg4 [1, 0, 0] {
    module MPEG4;
#gmake clean
#gmake
Now your mpeg4 codec library is part of  decodeCombo.x64P.
ARM side:
#cd  dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/
#make clean
#make dm6446_al
#cd /media/hda2/home/mahesh/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/decode
#vim Makefile
Edit:
XDC_PATH =
$(USER_XDC_PATH);../../packages;$(DMAI_INSTALL_DIR)/packages;$(CE_INSTALL_DIR)/packages;$(FC_INSTALL_DIR)/packages;$(LINK_INSTALL_DIR)/packages;$(XDAIS_INSTALL_DIR)/packages;$(CMEM_INSTALL_DIR)/packages;$(CODEC_INSTALL_DIR)/packagesi
I request you guys if you are  taking help from forum pls share your exp back to forum.
Thank you.
Mahesh V Kalmeshwar
