DM388: TimeOut occure in boot_proc. Program exit.
Part Number: DM388
Other Parts Discussed in Thread: TMDSCSK388
I am facing issue of Timeout occur in boot_proc. program exit for testing TMDSCSK388 camera starter kit.
My boot log is as below:
U-Boot SPL 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46 -0500)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2662320 bytes read in 305 ms (8.3 MiB/s)
reading dm38x-csk.dtb
58698 bytes read in 14 ms (4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.4.12-00004-g82adbbf-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2662256 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Kernel Image ... OK
Loading Device Tree to 844ee000, end 844ff549 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (g cc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine model: DM38X CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84 e00000 size = 1048576 Bytes
[ 0.000000] cma: Reserved 24 MiB at 0x82c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES1.0 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 r ootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highm em)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067efa4 (6620 kB)
[ 0.000000] .init : 0xc067f000 - 0xc06c4000 ( 276 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc0705308 ( 261 kB)
[ 0.000000] .bss : 0xc0705308 - 0xc0741718 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.000016] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 10737 4182375ns
[ 0.008264] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max _idle_ns: 95563022313 ns
[ 0.017840] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023133] Console: colour dummy device 80x30
[ 0.027834] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086909] pid_max: default: 32768 minimum: 301
[ 0.091858] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098770] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106814] Initializing cgroup subsys io
[ 0.111047] Initializing cgroup subsys memory
[ 0.115669] Initializing cgroup subsys devices
[ 0.120342] Initializing cgroup subsys freezer
[ 0.125022] Initializing cgroup subsys pids
[ 0.129434] CPU: Testing write buffer coherency: ok
[ 0.134889] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142703] devtmpfs: initialized
[ 0.168784] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217153] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.229282] pinctrl core: initialized pinctrl subsystem
[ 0.236077] NET: Registered protocol family 16
[ 0.242317] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255264] OMAP GPIO hardware version 0.1
[ 0.267843] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4l s@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301536] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309798] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@ 48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323403] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@ 48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337074] media: Linux media interface: v0.10
[ 0.341889] Linux video capture interface: v2.00
[ 0.346798] pps_core: LinuxPPS API ver. 1 registered
[ 0.351992] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.361521] PTP clock support registered
[ 0.365663] EDAC MC: Ver: 3.0.0
[ 0.369716] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377120] clocksource: Switched to clocksource timer1
[ 0.394569] NET: Registered protocol family 2
[ 0.399939] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407253] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413892] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420611] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426715] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433436] NET: Registered protocol family 1
[ 0.438392] RPC: Registered named UNIX socket transport module.
[ 0.444575] RPC: Registered udp transport module.
[ 0.449532] RPC: Registered tcp transport module.
[ 0.454459] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462508] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469620] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486587] NFS: Registering the id_resolver key type
[ 0.491981] Key type id_resolver registered
[ 0.496374] Key type id_legacy registered
[ 0.502267] io scheduler noop registered
[ 0.506406] io scheduler deadline registered
[ 0.511152] io scheduler cfq registered (default)
[ 0.517473] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598636] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609647] console [ttyS0] disabled
[ 0.613462] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 30 00000) is a 8250
[ 0.622418] console [ttyS0] enabled
[ 0.629610] bootconsole [earlycon0] disabled
[ 0.639414] Reference Linux version 4.4.12
[ 0.643710] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script /TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/ cmem/src/module/cmemk.c
[ 0.662253] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668154] cmemk initialized
[ 0.678523] loop: module loaded
[ 0.747178] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753314] libphy: 4a100800.mdio: probed
[ 0.758229] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, dri ver TI DP83867
[ 0.767220] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c1:2c
[ 0.777320] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807394] mousedev: PS/2 mouse device common for all mice
[ 0.813635] rtc rtc0: invalid alarm value: 2090-11-1 0:0:60
[ 0.819566] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.826996] i2c /dev entries driver
[ 0.831504] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.838629] sdhci: Secure Digital Host Controller Interface driver
[ 0.844838] sdhci: Copyright(c) Pierre Ossman
[ 0.972619] omap_hsmmc 48060000.mmc: card claims to support voltages below de fined range
[ 0.991753] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.998001] mmc0: new high speed SDIO card at address 0001
[ 1.007384] Synopsys Designware Multimedia Card Interface Driver
[ 1.013879] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.020858] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.027016] notify_init : notify drivercreated for remote proc id 1 at phys ical Address 0xbfd00000
[ 1.038782] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registere d
[ 1.046058] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.053535] NET: Registered protocol family 10
[ 1.060403] sit: IPv6 over IPv4 tunneling driver
[ 1.065881] NET: Registered protocol family 17
[ 1.070552] Key type dns_resolver registered
[ 1.075088] omap_voltage_late_init: Could not get sys clk.
[ 1.080994] Power Management for TI81XX.
[ 1.090196] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.095381] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.103257] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.109690] nand: Micron MT29F2G16ABAEAWP
[ 1.113723] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB siz e: 64
[ 1.121359] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.126774] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.132828] Creating 8 MTD partitions on "8000000.nand":
[ 1.138186] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.147969] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.156187] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.163296] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.172389] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.182175] mmc1: host does not support reading read-only switch, assuming wr ite-enable
[ 1.197197] mmc1: new high speed SDHC card at address 0007
[ 1.217309] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.223271] mmcblk0: p1 p2
[ 1.272492] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.279858] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.290689] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.353751] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as r tc1
[ 1.361458] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.368956] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.375758] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.382830] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.392252] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:0 0 UTC (946684800)
[ 1.414089] wlan-en-regulator: disabling
[ 1.418452] ALSA device list:
[ 1.421439] #0: TI81XX-CSK
[ 1.426398] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 sub system
[ 11.885705] EXT4-fs (mmcblk0p2): recovery complete
[ 11.899141] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 11.907353] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 11.922489] devtmpfs: mounted
[ 11.926071] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 11.932486] This architecture does not have kernel memory protection.
[ 12.175013] systemd[1]: System time before build time, advancing clock.
[ 12.197028] random: systemd urandom read with 31 bits of entropy available
[ 12.217694] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SEL INUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL - XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 12.236455] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[ 12.259184] systemd[1]: Set hostname to <ti81xx>.
[ 12.545043] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-useca se.service is marked executable. Please remove executable permission bits. Proce eding anyway.
[ 12.693752] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 12.735945] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 12.757417] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 12.777549] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 12.801283] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 12.817450] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 12.838589] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 12.857615] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 12.877639] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 12.897727] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 12.927615] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 12.961480] systemd[1]: Mounting /media/ram...
[ 13.004183] systemd[1]: Starting Journal Service...
[ 13.051074] systemd[1]: Mounting /var/volatile...
[ 13.101509] systemd[1]: Starting udev Kernel Device Manager...
[ 13.163038] systemd[1]: Starting udev Coldplug all Devices...
[ 13.233572] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.312940] systemd[1]: Mounting Temporary Directory...
[ 13.357728] systemd[1]: Reached target Timers.
[ OK ] Reached target Timers.
[ 13.387786] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 13.418816] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 13.438026] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 13.467796] systemd[1]: Started Dispatch Password Requests to Console Directo ry Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 13.497437] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 13.521338] systemd[1]: Starting Synchronize System and HW clocks...
[ 13.574865] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 13.607576] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 13.627550] systemd[1]: Mounted /var/volatile.
[ OK ] Mounted /var/volatile.
[ 13.647503] systemd[1]: Mounted /media/ram.
[ OK ] Mounted /media/ram.
[ 13.668061] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started IPNC RDK use case service.
[ OK ] Reached target Local File Systems.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started System Logging Service.
[ 14.768418] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback V olume'
[ 14.787383] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values= 2,min=0,max=127,step=0
[ 14.788832] autorun-usecase.sh[113]: : values=115,115
[ 14.796452] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mut e=0
[ OK ] Started Kernel Logging Service.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started D-Bus System Message Bus.
[ 14.928537] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture V olume'
[ 14.952520] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values= 2,min=0,max=119,step=0
[ 14.982644] autorun-usecase.sh[113]: : values=72,72
[ 15.003675] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute= 0
[ 15.040143] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mix er Mic2R Switch'
[ 15.062502] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values= 1
[ 15.091994] autorun-usecase.sh[113]: : values=on
[ OK ] Started Getty on tty1.
[ 15.132607] ubi0: attaching mtd6
[ OK ] Reached target Login Prompts.
Starting uim-sysfs.service...
[ 15.122270] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixe r Mic2L Switch'
[ 15.192048] ubi0: scanning is finished
[ 15.191952] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values= 1
Starting Network Service...
[ 15.212687] autorun-usecase.sh[113]: : values=on
[ 15.271906] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 15.277948] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 15.284857] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 15.291614] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.298623] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 15.304570] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 12 8
[ 15.311842] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequ ence number: 2367567630
[ 15.321031] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved f or bad PEB handling: 40
[ 15.336312] ubi0: background thread "ubi_bgt0d" started, PID 147
[ 15.350156] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
[ 15.499351] net eth0: initializing cpsw version 1.10 (0)
[ 15.504712] net eth0: initialized cpsw ale version 1.3
[ 15.513203] net eth0: phy found : id is : 0x2000a231
[ 15.518270] libphy: PHY not found
[ 15.521693] net eth0: phy "" not found on slave 1, err -19
[ OK ] Started Network Service.
[ 15.601948] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (121[ 15.632124] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
89696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 16.237207] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 152
[ 16.296671] UBIFS (ubi0:0): recovery needed
[ 16.543457] UBIFS (ubi0:0): recovery completed
[ 16.548095] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubif s_volume"
[ 16.556054] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O u nit sizes: 2048 bytes/2048 bytes
[ 16.566050] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 16.576201] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 16.582692] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID CCD16 CCE-643B-4FE0-8D48-DEAEE5B4A223, small LPT model
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ 17.371219] ubi1: attaching mtd7
[ 17.641253] ubi1: scanning is finished
[ 17.671372] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 17.677759] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 17.684668] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 17.691428] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 17.698447] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 17.704481] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 12 8
[ 17.711756] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequ ence number: 455573015
[ 17.720858] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 17.737275] ubi1: background thread "ubi_bgt1d" started, PID 163
[ 17.810795] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (421 56032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ OK ] Started uim-sysfs.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Reached target Multi-User System.
[ 18.407223] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 183
[ 18.437336] UBIFS (ubi1:0): recovery needed
[ 18.473391] UBIFS (ubi1:0): recovery completed
[ 18.478028] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubif s_volume"
[ 18.485986] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O u nit sizes: 2048 bytes/2048 bytes
[ 18.495986] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journ al size 1777664 bytes (1 MiB, 14 LEBs)
[ 18.506487] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 18.513164] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 9B011 D6F-144D-4DAC-8697-9B0E6BA1215C, small LPT model
[ 19.083730] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 19.528096] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Ful l - flow control rx/tx
[ 19.542288] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.888823] cfg80211: World regulatory domain updated:
[ 19.894060] cfg80211: DFS Master region: unset
[ 19.898490] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai n, max_eirp), (dfs_cac_time)
[ 19.908303] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 m Bm), (N/A)
[ 19.916346] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 m Bm), (N/A)
[ 19.924404] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 m Bm), (N/A)
[ 19.932465] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AU TO), (N/A, 2000 mBm), (N/A)
[ 19.942009] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AU TO), (N/A, 2000 mBm), (0 s)
[ 19.951653] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 19.959829] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 m Bm), (N/A)
[ 19.967892] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 20.658520] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connecti vity/wl1271-nvs.bin failed with error -2
[ 21.067858] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 21.096699] wlcore: loaded
[ 21.697440] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 21.820353] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 21.826729] random: nonblocking pool is initialized
[ 21.843601] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 25.962710] autorun-usecase.sh[113]: SSID: Inacces
[ 25.964505] autorun-usecase.sh[113]: SSID: BetterNetwork
[ 25.965918] autorun-usecase.sh[113]: SSID: Tejovat_Eprize
[ 26.360314] <1>SysLink version : 2.21.02.10
[ 26.360314] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 26.370972] <1>Trace enabled
[ 26.373866] <1>Trace SetFailureReason enabled
[ 26.456963] autorun-usecase.sh[113]: /dev/mem opened.
[ 26.458721] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 26.465616] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 26.469834] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 26.475790] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 26.487634] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 26.491230] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 26.495365] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.497165] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.498618] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 26.500084] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 27.430575] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (233) - No such process
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 27.548949] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 28.577263] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 28.579002] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 28.581618] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 28.590159] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 28.592084] autorun-usecase.sh[113]: logical sector size is 512,
[ 28.593636] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 28.595123] autorun-usecase.sh[113]: drive number 0x80;
[ 28.598333] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 28.601595] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 28.605222] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 28.607989] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 28.611098] autorun-usecase.sh[113]: Volume ID is 9c065bb3, no volume label.
[ 28.852792] Mass Storage Function, version: 2009/09/11
[ 28.858053] LUN: removable file: (no medium)
[ 28.862632] LUN: removable file: /dev/sbulla
[ 28.866927] Number of LUNs=1
[ 28.901709] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 28.908766] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 28.915858] g_mass_storage gadget: g_mass_storage ready
[ 28.972162] autorun-usecase.sh[113]: Creat queue id:0
[ 28.976137] autorun-usecase.sh[113]: queue id:0
[ 28.977885] autorun-usecase.sh[113]: Creat queue id:32769
[ 28.984738] autorun-usecase.sh[113]: queue id:32769
[ 28.990283] autorun-usecase.sh[113]: Creat queue id:65538
[ 28.994752] autorun-usecase.sh[113]: queue id:65538
[ 29.001451] autorun-usecase.sh[113]: Creat queue id:98307
[ 29.010163] autorun-usecase.sh[113]: queue id:98307
[ 29.015642] autorun-usecase.sh[113]: queue id:32769
[host] Attached to slave procId 1.13]:
[host] Attached to slave procId 0.13]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.sh[113]:
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.sh[113]:
[host] After Ipc_startcallback status [0x00000000]
[ 31.431434] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.433184] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.437411] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.446595] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 31.539801] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.541646] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.543044] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.544326] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 31.558831] autorun-usecase.sh[113]: queue id:65538
[ 31.560764] autorun-usecase.sh[113]: Creat queue id:131076
[ 31.562373] autorun-usecase.sh[113]: queue id:131076
[ 31.563902] autorun-usecase.sh[113]: CPU is TI812x
[ 31.565402] autorun-usecase.sh[113]: vsenable : 0
[ 32.664715] autorun-usecase.sh[113]: Creat queue id:163845
[ 32.666543] autorun-usecase.sh[113]: queue id:163845
[ 32.667982] autorun-usecase.sh[113]: queue id:65538
[ 32.736771] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.738576] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.739977] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.787542] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.790822] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.793594] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.854391] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.856190] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.857569] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.858917] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 32.860758] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 32.862433] autorun-usecase.sh[113]: [m3video]
[ 32.863937] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 32.865571] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 32.867024] autorun-usecase.sh[113]: [m3video]
[ 32.868504] autorun-usecase.sh[113]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 32.869954] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 32.871461] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 32.873130] autorun-usecase.sh[113]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 32.874890] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 32.876378] autorun-usecase.sh[113]: [m3vpss ]
[ 32.877872] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 32.879448] autorun-usecase.sh[113]: [m3vpss ]
[ 32.880956] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 32.882426] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 32.883891] autorun-usecase.sh[113]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 32.885558] autorun-usecase.sh[113]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 32.887007] autorun-usecase.sh[113]: [m3video] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 32.888443] autorun-usecase.sh[113]: [m3video] 119: SYSTEM: Attaching to [VPSS-M3] ...
[ 32.889951] autorun-usecase.sh[113]: [m3vpss ] 133: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 32.891473] autorun-usecase.sh[113]: [m3vpss ] 134: SYSTEM: Attaching to [VIDEO-M3] ...
[ 32.892925] autorun-usecase.sh[113]: [m3video] 168: SYSTEM: Attaching to [VPSS-M3] ...
[ 32.894374] autorun-usecase.sh[113]: [m3video] 184: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 32.896005] autorun-usecase.sh[113]: [m3vpss ] 184: SYSTEM: Attaching to [VIDEO-M3] ...
[ 32.897443] autorun-usecase.sh[113]: [m3video] 184: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 32.898866] autorun-usecase.sh[113]: [m3vpss ] 184: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 32.900367] autorun-usecase.sh[113]: [m3vpss ] 184: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 32.901897] autorun-usecase.sh[113]: [m3vpss ] 185: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 32.903330] autorun-usecase.sh[113]: [m3vpss ] 185: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 32.904748] autorun-usecase.sh[113]: [m3vpss ] 187: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 32.906321] autorun-usecase.sh[113]: [m3vpss ] 187: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 32.907782] autorun-usecase.sh[113]: [m3vpss ] 188: SYSTEM: IPC init DONE !!!
[ 32.909218] autorun-usecase.sh[113]: [m3vpss ] 198: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 32.910796] autorun-usecase.sh[113]: [m3vpss ] 199: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 32.912406] autorun-usecase.sh[113]: [m3vpss ] 201: SYSTEM : System Common Init Done !!!
[ 32.913915] autorun-usecase.sh[113]: [m3video] 285: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 32.915511] autorun-usecase.sh[113]: [m3video] 285: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 32.917003] autorun-usecase.sh[113]: [m3video] 286: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 32.918512] autorun-usecase.sh[113]: [m3video] 288: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 32.919969] autorun-usecase.sh[113]: [m3video] 288: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 32.921500] autorun-usecase.sh[113]: [m3video] 288: SYSTEM: IPC init DONE !!!
[ 32.923022] autorun-usecase.sh[113]: [m3video] 299: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 32.924574] autorun-usecase.sh[113]: [m3video] 299: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 32.926181] autorun-usecase.sh[113]: [m3video] 301: SYSTEM : System Common Init Done !!!
[ 32.927650] autorun-usecase.sh[113]: [m3video] 1601: SYSTEM : System Video Init in progress !!!
[ 32.929167] autorun-usecase.sh[113]: [m3vpss ] 1601: SYSTEM : System VPSS Init in progress !!!
[ 32.930706] autorun-usecase.sh[113]: [m3video] 1602: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 32.932185] autorun-usecase.sh[113]: [m3video] 1602: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 33.265582] autorun-usecase.sh[113]: [m3video] 1602: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 33.267113] autorun-usecase.sh[113]: [m3video] 1604: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 33.268831] autorun-usecase.sh[113]: [m3video] 1605: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 33.270406] autorun-usecase.sh[113]: [m3video] 1605: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 33.271928] autorun-usecase.sh[113]: [m3video] 1615: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 33.273390] autorun-usecase.sh[113]: [m3video] 1615: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 33.274829] autorun-usecase.sh[113]: [m3video] 1615: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 33.276318] autorun-usecase.sh[113]: [m3video] 1618: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 33.277755] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 33.279301] autorun-usecase.sh[113]: [m3video] 1618: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 33.280875] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 33.282350] autorun-usecase.sh[113]: [m3video] 1618: SYSTEM: ListElem Shared Addr = 0xbe9a4800
[ 33.283834] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 33.285286] autorun-usecase.sh[113]: [m3video] 1620: HDVICP: Doing PRCM for IVAHD[0] ...
[ 33.286763] autorun-usecase.sh[113]: [m3vpss ] 1620: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 33.288463] autorun-usecase.sh[113]: [m3video] 1621: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 34.289383] autorun-usecase.sh[113]: [m3vpss ] 162ApproDrvInit: 7
[ 34.291356] autorun-usecase.sh[113]: queue id:163845
[ 36.964022] autorun-usecase.sh[113]: queue id:0
[ 38.392878] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.394674] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.398690] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 38.402101] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 38.422203] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.423959] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.425339] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 38.431199] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 38.458341] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 38.529329] DMA: Module install successful, device major num = 244
[ 38.535669] DRV: Module install successful
[ 38.539837] DRV: Module built on Feb 13 2017 19:26:20
[ 38.604701]
[ 38.604701] soc_is_dm38x
[ 38.674549] HDMI W1 rev 4.0
[ 38.677442] HDMI CEC Spec version 1.2
[ 39.057163] I2C No Ack
[ 39.059674] HDMI failed to read E-EDID
[ 39.075092] autorun-usecase.sh[113]: ApproDrvInit: 3
[ 39.085787] autorun-usecase.sh[113]: queue id:163845
[host]546128] autorun-usecase.sh[113]:
[host] ORG 0x46c00524: 0case.sh[113]:
[host] NEW 0x46c00524: 2case.sh[113]:
[host]551775] autorun-usecase.sh[113]:
[host] Application Start Completed13]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 12: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 39.663363] autorun-usecase.sh[113]: [ 39.696116] DMA: ChannelID allocated:4
[host] 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[host] 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[host] 12: SYSTEM: CPU [HOST] syslink proc I[ 39.723590] DMA: ChannelID allocated:5
D is [2] !!!
[host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 16: SYSTEM: IPC init DONE !!!:
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 18: SYSTEM: ListElem Shared Addr = 0xb55d8580
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 20: SYSTEM: ListElem Shared Addr = 0xb55f2200
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 24: SYSTEM: ListElem Shared Addr = 0xb560be80
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 25: SYSTEM: ListElem Shared Addr = 0xb562b880
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0xb564b280
[host] 28: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa7381000,size = 65011712
[ 39.758658] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[ 39.761212] autorun-usecase.sh[113]: queue id:0
[ 39.762880] autorun-usecase.sh[113]: queue id:32769
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6f14000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]803392] autorun-usecase.sh[113]:
[ 39.805574] autorun-usecase.sh[113]: ********** SMART ANALYTICS USECASE ********
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 157: MCFW : CPU Revision [ES1.0] !!!
[host] 157: MCFW : Detected [UNKNOWN] Board !!!
[host] 157: MCFW : Base Board Revision [REV A] !!!
[ 39.834844] autorun-usecase.sh[113]: 0: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 39.836785] autorun-usecase.sh[113]: [m3video] 1621: SYSTEM : Initializing Links !!!
[ 39.838489] autorun-usecase.sh[113]: [m3vpss ] 1620: SYSTEM: ListElem Shared Addr = 0xbe9be480
[ 39.840234] autorun-usecase.sh[113]: [m3vpss ] 1623: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 39.841911] autorun-usecase.sh[113]: [m3video] 1622: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 39.843586] autorun-usecase.sh[113]: [m3vpss ] 1624: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 39.845249] autorun-usecase.sh[113]: [m3vpss ] 1624: SYSTEM: ListElem Shared Addr = 0xbe9c1980
[ 39.846912] autorun-usecase.sh[113]: [m3video] 1622: SYSTEM : FREE SPACE : SR0 Heap = 15985792 B (15 MB)
[ 39.848801] autorun-usecase.sh[113]: [m3video] 1622: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 39.850523] autorun-usecase.sh[113]: [m3video] 1623: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 39.852199] autorun-usecase.sh[113]: [m3vpss ] 1637: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 39.853899] autorun-usecase.sh[113]: [m3vpss ] 1638: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 39.855555] autorun-usecase.sh[113]: [m3video] 1623: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 39.857224] autorun-usecase.sh[113]: [m3vpss ] 1638: SYSTEM: ListElem Shared Addr = 0xbe9c4e80
[ 39.858875] autorun-usecase.sh[113]: [m3video] 1624: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 39.860563] autorun-usecase.sh[113]: [m3vpss ] 1641: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 40.195330] autorun-usecase.sh[113]: [m3vpss ] 1641: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 40.197001] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 40.198792] autorun-usecase.sh[113]: [m3vpss ] 1642: SYSTEM: ListElem Shared Addr = 0xbe9e4880
[ 40.200587] autorun-usecase.sh[113]: [m3vpss ] 1644: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 40.202254] autorun-usecase.sh[113]: [m3vpss ] 1645: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 40.203939] autorun-usecase.sh[113]: [m3vpss ] 1645: SYSTEM: ListElem Shared Addr = 0xbea04280
[ 40.205590] autorun-usecase.sh[113]: [m3vpss ] 1651: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[ 40.207247] autorun-usecase.sh[113]: [m3vpss ] 1651: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 40.208934] autorun-usecase.sh[113]: [m3vpss ] 1652: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 40.210684] autorun-usecase.sh[113]: [m3vpss ] 1654: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 40.212376] autorun-usecase.sh[113]: [m3vpss ] 1655: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 40.213009] autorun-usecase.sh[113]: [m3vpss ] 1655: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 40.213698] autorun-usecase.sh[113]: [m3vpss ] 1657: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 40.214299] autorun-usecase.sh[113]: [m3vpss ] 1657: SYSTEM : FVID2 Init in progress !!!
[ 40.214792] autorun-usecase.sh[113]: [m3video] 1684: SYSTEM : Initializing Links ... DONE !!!
[ 40.215319] autorun-usecase.sh[113]: [m3video] 1684: SYSTEM : System Video Init Done !!!
[ 40.215773] autorun-usecase.sh[113]: [m3vpss ] 1727: SYSTEM : FVID2 Init in progress DONE !!!
[ 40.216326] autorun-usecase.sh[113]: [m3vpss ] 1727: SYSTEM : Device Init in progress !!!
[ 40.216778] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 40.217271] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 40.217765] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 40.218264] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 40.218722] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 40.219177] autorun-usecase.sh[113]: [m3vpss ] 1921: SYSTEM : Device Init in progress DONE !!!
[ 40.219693] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 40.220202] autorun-usecase.sh[113]: [m3vpss ] 7030: SYSTEM : System VPSS Init Done !!!
[ 40.220739] autorun-usecase.sh[113]: [m3vpss ] 7031: UTILS: DMA: HWI Create for INT62 !!!
[ 40.[ 40.479465] DMA: ChannelID allocated:6
221201] autorun-usecase.sh[113]: [m3vpss ] 7031: SYSTEM : Ini[ 40.488827] DMA: ChannelID allocated:7
tializing Links !!!
[ 40.221739] autorun-usecase.sh[113]: [m3vpss ] 7031: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 40.222202] autorun-usecase.sh[113]: [m3vpss ] 7031: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 40.222693] autorun-usecase.sh[113]: [m3vpss ] 7032: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 40.223158] autorun-usecase.sh[113]: [m3vpss ] 7032: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.223607] autorun-usecase.sh[113]: [m3vpss ] 7032: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.224125] autorun-usecase.sh[113]: [m3vpss ] 7163: SYSTEM : Initializing Links ... DONE !!!
[ 40.224577] autorun-usecase.sh[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 40.225199] autorun-usecase.sh[113]: [m3vpss ] VPS_[ 40.574117] DMA: ChannelID allocated:12
DCTRL_INST_0
[ 40.225707] autorun-usecase.sh[113]: [m3vpss ][ 40.580419] DMA: ChannelID allocated:13
IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 40.226[ 40.589792] DMA: ChannelID allocated:14
277] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 40.226750] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 40.227286] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 40.227746] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 40.582920] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
[ 40.583519] autorun-usecase.sh[113]: [m3vpss ] 8510: CAMERA: Create in progress !!!
[ 40.584257] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 40.584788] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 40.585265] autorun-usecase.sh[113]: [m3vpss ] 8510: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 40.588254] autorun-usecase.sh[113]: [m3vpss ] 8511: CAMERA: VIP 0: VID DEC 268436737 (0x10):
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1241: IPC_BITS_IN : Create in progress !!!
[host] 1241: IPC_BITS_IN : ListMPOpen start !!!
[host] 1241: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1241: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1241: IPC_BITS_IN : ListMPOpen done !!!
[host] 1242: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1243: IPC_BITS_IN : Create Done !!!
[ 40.945285] autorun-usecase.sh[113]: 0002:20202020:20202020, AUD_STATUS 538976288
[ 40.946047] autorun-usecase.sh[113]: [m3vpss ] Iss_captCreate:1661
[ 40.946630] autorun-usecase.sh[113]: [m3vpss ] 8724: CAMERA: Create Done !!!
[ 40.947122] autorun-usecase.sh[113]: [m3vpss ] 8814: CAMERA: Detect video in progress !!!
[ 40.947589] autorun-usecase.sh[113]: [m3vpss ] 8814: CAMERA: Detect video Done !!!
[ 40.948113] autorun-usecase.sh[113]: [m3vpss ] 8887: DUP : Create Done !!!
[ 40.948563] autorun-usecase.sh[113]: [m3vpss ] 8887: IPC_OUT_M3 : Create in progress !!!
[ 40.949074] autorun-usecase.sh[113]: [m3vpss ] 8888: IPC_OUT_M3 : Create Done !!!
[ 40.949522] autorun-usecase.sh[113]: [m3video] 8889: IPC_IN_M3 : Create in progress !!!
[ 40.950039] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 40.950503] autorun-usecase.sh[113]: [m3video] 8889: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 40.950953] autorun-usecase.sh[113]: [m3video] 8890: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 40.951458] autorun-usecase.sh[113]: [m3video] 8893: IPC_IN_M3 : Create Done !!!
[ 40.951903] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
[ 40.952436] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
[ 40.952882] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
[ 40.953365] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
[ 40.953979] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 40.954513] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
[ 40.954971] autorun-usecase.sh[113]: [m3vpss ] 9076: IPC_IN_M3 : Create in progress !!!
[ 40.955532] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
[ 40.955990] autorun-usecase.sh[113]: [m3vpss ] 9076: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 40.956446] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
[ 40.956959] autorun-usecase.sh[113]: [m3vpss ] 9077: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 40.957404] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
[ 40.957923] autorun-usecase.sh[113]: [m3vpss ] 9077: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 40.958375] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 40.958859] autorun-usecase.sh[113]: [m3vpss ] 9080: IPC_IN_M3 : Create Done !!!
[ 40.959308] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 40.959741] autorun-usecase.sh[113]: [m3vpss ] 9080: NSF: Create in progress !!!
[ 40.960286] autorun-usecase.sh[113]: [m3video] 9074: IPC_OUT_M3 : Create in progress !!!
[ 40.960742] autorun-usecase.sh[113]: [m3video] 9075: IPC_OUT_M3 : Create Done !!!
[ 40.961250] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 40.961862] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 40.962392] autorun-usecase.sh[113]: [m3vpss ] 9205: NSF: Create Done !!!
[ 40.962856] autorun-usecase.sh[113]: [m3vpss ] 9206: Mux : Creating... !!!
[ 40.963369] autorun-usecase.sh[113]: [m3vpss ] 9207: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 40.963835] autorun-usecase.sh[113]: [m3vpss ] 9208: Mux : Create Done !!!
[ 40.964279] autorun-usecase.sh[113]: [m3vpss ] 9214: DUP : Create Done !!!
[ 40.964786] autorun-usecase.sh[113]: [m3vpss ] 9221: DUP : Create Done !!!
[ 40.965303] autorun-usecase.sh[113]: [m3vpss ] 9222: Mux : Creating... !!!
[ 40.965905] autorun-usecase.sh[113]: [m3vpss ] 9224: Mux : Create Done !!!
[ 40.966381] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 40.966913] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 40.967367] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 40.967852] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 40.968297] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 40.968737] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 41.299577] autorun-usecase.sh[113]: [m3vpss ] 9233: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 41.300252] autorun-usecase.sh[113]: [m3vpss ] 9238: SWOSD : Create Done !!!
[ 41.300741] autorun-usecase.sh[113]: [m3vpss ] 9311: DUP : Create Done !!!
[ 41.301205] autorun-usecase.sh[113]: [m3vpss ] 9311: SCLR: Create in progress !!!
[ 41.301661] autorun-usecase.sh[113]: [m3vpss ] 9317: SCLR : Loading Up-scaling Co-effs ...
[ 41.302163] autorun-usecase.sh[113]: [m3vpss ] 9317: SCLR : Co-effs Loading ... DONE !!!
[ 41.302617] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 41.303068] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 41.303514] autorun-usecase.sh[113]: [m3vpss ] 9317: SCLR: Create Done !!!
[ 41.303961] autorun-usecase.sh[113]: [m3vpss ] 9324: DUP : Create Done !!!
[ 41.304439] autorun-usecase.sh[113]: [m3vpss ] 9262: VA : Create Done !!!
[ 41.304889] autorun-usecase.sh[113]: [m3vpss ] 9280: FD : Alg Create Done !!!
[ 41.305339] autorun-usecase.sh[113]: [m3vpss ] 9280: FD : Create Done !!!
[ 41.305784] autorun-usecase.sh[113]: [m3video] 9356: IPC_IN_M3 : Create in progress !!!
[ 41.306226] autorun-usecase.sh[113]: [m3vpss ] 9288: VA : ALG Init Done !!!
[ 41.306672] autorun-usecase.sh[113]: [m3video] 9357: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 41.307986] autorun-usecase.sh[113]: [m3vpss ] 9354: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR : failed !!!
[ 41.308674] autorun-usecase.sh[113]: [m3video] 9357: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 41.309368] autorun-usecase.sh[113]: [m3vpss ] 9354: IPC_OUT_M3 : Create in progress !!!
[ 41.310058] autorun-usecase.sh[113]: [m3video] 9360: IPC_IN_M3 : Create Done !!!
[ 41.310653] autorun-usecase.sh[113]: [m3vpss ] 9356: IPC_OUT_M3 : Create Done !!!
[ 41.311271] autorun-usecase.sh[113]: [m3video] 9360: ENCODE: Create in progress ... !!!
[ 41.311845] autorun-usecase.sh[113]: [m3video] 9486: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 41.312461] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 41.313025] autorun-usecase.sh[113]: [m3video] 9568: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 41.313633] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 41.314225] autorun-usecase.sh[113]: [m3video] 9651: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[ 41.314875] autorun-usecase.sh[113]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 41.315678] autorun-usecase.sh[113]: [m3video] 9652: ENCODE: All CH Create ... DONE !!!
[ 41.316465] autorun-usecase.sh[113]: [m3video] ENCLINK:HEAPID:0 USED:28144
[ 41.317226] autorun-usecase.sh[113]: [m3video] 9655queue id:0
_____ _____ _ _
|___| |___|
Arago Project http://arago-project.org DM388_CSK ttyS0
Arago 2016.05 DM388_CSK ttyS0
DM388_CSK login:
_____ _____ _ _
|___| |___|
DM388_CSK login:
_____ _____ _ _
|___| |___|
DM388_CSK login:
_____ _____ _ _
|___| |___|
DM388_CSK login:
_____ _____ _ _
|___| |___|
DM388_CSK login: [ 56.967142] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 56.967887] autorun-usecase.sh[113]: Program exit.
[ 60.984379] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 60.986969] autorun-usecase.sh[113]: Program exit.
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
cpsw
reading uImage
2662320 bytes read in 306 ms (8.3 MiB/s)
Starting kernel ...
[ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000015] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
[ 0.008262] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017839] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023135] Console: colour dummy device 80x30
[ 0.027837] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086908] pid_max: default: 32768 minimum: 301
[ 0.091856] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098768] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106810] Initializing cgroup subsys io
[ 0.111041] Initializing cgroup subsys memory
[ 0.115663] Initializing cgroup subsys devices
[ 0.120337] Initializing cgroup subsys freezer
[ 0.125017] Initializing cgroup subsys pids
[ 0.129430] CPU: Testing write buffer coherency: ok
[ 0.134885] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142693] devtmpfs: initialized
[ 0.168772] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217115] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229253] pinctrl core: initialized pinctrl subsystem
[ 0.236043] NET: Registered protocol family 16
[ 0.242284] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255244] OMAP GPIO hardware version 0.1
[ 0.267826] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.309798] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323407] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337079] media: Linux media interface: v0.10
[ 0.341892] Linux video capture interface: v2.00
[ 0.346802] pps_core: LinuxPPS API ver. 1 registered
[ 0.351996] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361526] PTP clock support registered
[ 0.365668] EDAC MC: Ver: 3.0.0
[ 0.369721] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377123] clocksource: Switched to clocksource timer1
[ 0.394536] NET: Registered protocol family 2
[ 0.399904] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407217] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413856] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420576] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426679] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433398] NET: Registered protocol family 1
[ 0.438348] RPC: Registered named UNIX socket transport module.
[ 0.444531] RPC: Registered udp transport module.
[ 0.449489] RPC: Registered tcp transport module.
[ 0.454416] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462462] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469567] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486557] NFS: Registering the id_resolver key type
[ 0.491953] Key type id_resolver registered
[ 0.496345] Key type id_legacy registered
[ 0.502234] io scheduler noop registered
[ 0.506373] io scheduler deadline registered
[ 0.511125] io scheduler cfq registered (default)
[ 0.517443] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598585] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609592] console [ttyS0] disabled
[ 0.613409] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622367] console [ttyS0] enabled
[ 0.629558] bootconsole [earlycon0] disabled
[ 0.639357] Reference Linux version 4.4.12
[ 0.643654] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662201] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668100] cmemk initialized
[ 0.678487] loop: module loaded
[ 0.747183] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753320] libphy: 4a100800.mdio: probed
[ 0.758227] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.777307] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807369] mousedev: PS/2 mouse device common for all mice
[ 0.813881] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.821361] i2c /dev entries driver
[ 0.825846] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.832976] sdhci: Secure Digital Host Controller Interface driver
[ 0.839208] sdhci: Copyright(c) Pierre Ossman
[ 0.962634] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.981652] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.988015] mmc0: new high speed SDIO card at address 0001
[ 0.997390] Synopsys Designware Multimedia Card Interface Driver
[ 1.003886] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.010873] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.017030] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.028778] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.036053] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.043522] NET: Registered protocol family 10
[ 1.050396] sit: IPv6 over IPv4 tunneling driver
[ 1.055880] NET: Registered protocol family 17
[ 1.060532] Key type dns_resolver registered
[ 1.065064] omap_voltage_late_init: Could not get sys clk.
[ 1.070975] Power Management for TI81XX.
[ 1.080210] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.085396] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.093240] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.099680] nand: Micron MT29F2G16ABAEAWP
[ 1.103713] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.111350] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.116764] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.122818] Creating 8 MTD partitions on "8000000.nand":
[ 1.128179] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.137940] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.146119] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.153233] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.162323] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.172110] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.187205] mmc1: new high speed SDHC card at address 0007
[ 1.207174] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.213139] mmcblk0: p1 p2
[ 1.262449] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.269833] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.280663] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.343723] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.351433] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.358924] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.365725] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.372801] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.382219] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.404039] wlan-en-regulator: disabling
[ 1.408399] ALSA device list:
[ 1.411387] #0: TI81XX-CSK
[ 1.416356] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 14.562684] EXT4-fs (mmcblk0p2): recovery complete
[ 14.576026] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 14.584240] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 14.599354] devtmpfs: mounted
[ 14.602938] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 14.609350] This architecture does not have kernel memory protection.
[ 14.849862] systemd[1]: System time before build time, advancing clock.
[ 14.871909] random: systemd urandom read with 33 bits of entropy available
[ 14.892519] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 14.911332] systemd[1]: Detected architecture arm.
[ 14.939147] systemd[1]: Set hostname to <ti81xx>.
[ 15.217031] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 15.364048] systemd[1]: Reached target Timers.
[ 15.387686] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 15.421219] systemd[1]: Created slice System Slice.
[ 15.438650] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 15.457669] systemd[1]: Listening on Journal Socket (/dev/log).
[ 15.477690] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 15.525759] systemd[1]: Reached target Slices.
[ 15.547608] systemd[1]: Listening on Syslog Socket.
[ 15.567564] systemd[1]: Listening on udev Kernel Socket.
[ 15.587637] systemd[1]: Listening on udev Control Socket.
[ 15.607667] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 15.637396] systemd[1]: Reached target Paths.
[ 15.657383] systemd[1]: Reached target Swap.
[ 15.678662] systemd[1]: Created slice system-getty.slice.
[ 15.697415] systemd[1]: Reached target Remote File Systems.
[ 15.717901] systemd[1]: Listening on Network Service Netlink Socket.
[ 15.747667] systemd[1]: Listening on Journal Socket.
[ 15.771308] systemd[1]: Starting Journal Service...
[ 15.815858] systemd[1]: Mounting POSIX Message Queue File System...
[ 15.866782] systemd[1]: Starting udev Kernel Device Manager...
[ 15.931256] systemd[1]: Mounting /var/volatile...
[ 15.986258] systemd[1]: Starting udev Coldplug all Devices...
[ 16.051335] systemd[1]: Starting Synchronize System and HW clocks...
[ 16.162543] systemd[1]: Mounting /media/ram...
[ 16.203012] systemd[1]: Mounting Temporary Directory...
[ 16.294594] systemd[1]: Mounted POSIX Message Queue File System.
[ 16.317618] systemd[1]: Mounted Temporary Directory.
[ 16.337533] systemd[1]: Mounted /var/volatile.
[ 16.357515] systemd[1]: Mounted /media/ram.
[ 16.378054] systemd[1]: Started Journal Service.
[ 17.445854] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 17.492050] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 17.532658] autorun-usecase.sh[113]: : values=115,115
[ 17.556912] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 17.570401] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 17.597514] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 17.599157] autorun-usecase.sh[113]: : values=72,72
[ 17.625158] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 17.666511] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 17.692582] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 17.722447] autorun-usecase.sh[113]: : values=on
[ 17.763613] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 17.791959] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 17.812132] autorun-usecase.sh[113]: : values=on
[ 17.841048] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
[ 17.961027] ubi0: attaching mtd6
[ 18.169494] net eth0: initializing cpsw version 1.10 (0)
[ 18.174856] net eth0: initialized cpsw ale version 1.3
[ 18.183403] net eth0: phy found : id is : 0x2000a231
[ 18.188464] libphy: PHY not found
[ 18.191888] net eth0: phy "" not found on slave 1, err -19
[ 18.201166] ubi0: scanning is finished
[ 18.247362] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 18.253334] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 18.260288] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 18.267021] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 18.274032] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 18.279995] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 18.287265] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2367567630
[ 18.296439] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 18.310562] ubi0: background thread "ubi_bgt0d" started, PID 146
[ 18.378165] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.530091] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 19.137335] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
[ 19.214274] UBIFS (ubi0:0): recovery needed
[ 19.450944] UBIFS (ubi0:0): recovery completed
[ 19.455528] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 19.463555] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 19.473538] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 19.483686] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 19.490179] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID CCD16CCE-643B-4FE0-8D48-DEAEE5B4A223, small LPT model
[ 20.321491] ubi1: attaching mtd7
[ 20.596821] ubi1: scanning is finished
[ 20.622950] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 20.629334] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 20.636243] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 20.643006] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 20.650016] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 20.656050] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 20.663322] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 455573015
[ 20.672425] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 20.685923] ubi1: background thread "ubi_bgt1d" started, PID 168
[ 20.775882] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 21.337260] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 181
[ 21.356782] UBIFS (ubi1:0): recovery needed
[ 21.376605] UBIFS (ubi1:0): recovery completed
[ 21.381247] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 21.389237] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 21.399219] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 21.409719] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 21.416372] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 9B011D6F-144D-4DAC-8697-9B0E6BA1215C, small LPT model
[ 21.932090] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
|___| |___|
ti81xx login: [ 22.178143] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.202450] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.031952] cfg80211: World regulatory domain updated:
[ 23.037213] cfg80211: DFS Master region: unset
[ 23.041592] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 23.051422] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.059479] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.067537] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.075582] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 23.085131] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 23.094674] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 23.102822] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.110890] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 23.548505] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 23.957859] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 23.986672] wlcore: loaded
[ 24.607035] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 24.717716] random: nonblocking pool is initialized
[ 24.725432] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 24.743657] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 28.978187] autorun-usecase.sh[113]: SSID: Tejovat_Eprize
[ 28.979989] autorun-usecase.sh[113]: SSID: Inacces
[ 28.983617] autorun-usecase.sh[113]: SSID: WTI
[ 29.374093] <1>SysLink version : 2.21.02.10
[ 29.374093] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 29.384919] <1>Trace enabled
[ 29.387864] <1>Trace SetFailureReason enabled
[ 29.491632] autorun-usecase.sh[113]: /dev/mem opened.
[ 29.493372] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 29.494761] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 29.496068] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 29.497383] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 29.498647] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 29.499897] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 29.512021] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 29.515916] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 29.517608] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 29.519027] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 30.455039] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (225) - No such process
[ 30.562083] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 31.589216] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 31.591387] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 31.593596] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 31.598321] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 31.605797] autorun-usecase.sh[113]: logical sector size is 512,
[ 31.608425] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 31.612719] autorun-usecase.sh[113]: drive number 0x80;
[ 31.615291] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 31.618180] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 31.624814] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 31.626553] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 31.636896] autorun-usecase.sh[113]: Volume ID is 9c0b806a, no volume label.
[ 31.866666] Mass Storage Function, version: 2009/09/11
[ 31.871929] LUN: removable file: (no medium)
[ 31.911944] LUN: removable file: /dev/sbulla
[ 31.916259] Number of LUNs=1
[ 31.937264] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 31.944307] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 31.951422] g_mass_storage gadget: g_mass_storage ready
[ 31.994549] autorun-usecase.sh[113]: Creat queue id:0
[ 31.996620] autorun-usecase.sh[113]: queue id:0
[ 31.999988] autorun-usecase.sh[113]: Creat queue id:32769
[ 32.010653] autorun-usecase.sh[113]: queue id:32769
[ 32.015865] autorun-usecase.sh[113]: Creat queue id:65538
[ 32.017764] autorun-usecase.sh[113]: queue id:65538
[ 32.021616] autorun-usecase.sh[113]: Creat queue id:98307
[ 32.030251] autorun-usecase.sh[113]: queue id:98307
[ 32.035498] autorun-usecase.sh[113]: queue id:32769
[ 33.163323] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.165113] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.166493] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.167780] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 33.261274] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.263522] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.270868] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.283419] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 33.290136] autorun-usecase.sh[113]: queue id:65538
[ 33.292019] autorun-usecase.sh[113]: Creat queue id:131076
[ 33.293752] autorun-usecase.sh[113]: queue id:131076
[ 33.302737] autorun-usecase.sh[113]: CPU is TI812x
[ 33.312925] autorun-usecase.sh[113]: vsenable : 0
[ 33.417980] autorun-usecase.sh[113]: Creat queue id:163845
[ 33.419805] autorun-usecase.sh[113]: queue id:163845
[ 33.435383] autorun-usecase.sh[113]: queue id:65538
[ 33.516045] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.517849] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.523205] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.598648] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.601912] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.611290] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.615151] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.617724] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.619460] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.621181] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 33.623187] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 33.624739] autorun-usecase.sh[113]: [m3video]
[ 33.626617] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 33.628301] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 33.629828] autorun-usecase.sh[113]: [m3video]
[ 33.631723] autorun-usecase.sh[113]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 33.633330] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 33.634981] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 33.636589] autorun-usecase.sh[113]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 33.638113] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 33.639574] autorun-usecase.sh[113]: [m3vpss ]
[ 33.641100] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 33.643025] autorun-usecase.sh[113]: [m3vpss ]
[ 33.644518] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 33.646335] autorun-usecase.sh[113]: [m3vpss ] 68: SYSTEM: IPC init in progress !!!
[ 33.647826] autorun-usecase.sh[113]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 33.649896] autorun-usecase.sh[113]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 33.651581] autorun-usecase.sh[113]: [m3video] 119: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 33.653200] autorun-usecase.sh[113]: [m3vpss ] 127: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 33.654794] autorun-usecase.sh[113]: [m3video] 119: SYSTEM: Attaching to [VPSS-M3] ...
[ 33.656250] autorun-usecase.sh[113]: [m3vpss ] 127: SYSTEM: Attaching to [VIDEO-M3] ...
[ 33.657704] autorun-usecase.sh[113]: [m3video] 168: SYSTEM: Attaching to [VPSS-M3] ...
[ 33.659125] autorun-usecase.sh[113]: [m3video] 177: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 33.660717] autorun-usecase.sh[113]: [m3vpss ] 177: SYSTEM: Attaching to [VIDEO-M3] ...
[ 33.662176] autorun-usecase.sh[113]: [m3video] 178: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.663944] autorun-usecase.sh[113]: [m3vpss ] 177: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 33.665935] autorun-usecase.sh[113]: [m3vpss ] 178: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.667563] autorun-usecase.sh[113]: [m3vpss ] 178: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 33.669336] autorun-usecase.sh[113]: [m3vpss ] 178: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 33.670926] autorun-usecase.sh[113]: [m3vpss ] 180: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 33.672922] autorun-usecase.sh[113]: [m3vpss ] 180: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 33.674418] autorun-usecase.sh[113]: [m3vpss ] 181: SYSTEM: IPC init DONE !!!
[ 33.685411] autorun-usecase.sh[113]: [m3vpss ] 192: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 33.693147] autorun-usecase.sh[113]: [m3vpss ] 192: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 33.695226] autorun-usecase.sh[113]: [m3vpss ] 194: SYSTEM : System Common Init Done !!!
[ 33.696882] autorun-usecase.sh[113]: [m3video] 278: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.698391] autorun-usecase.sh[113]: [m3video] 279: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 33.701426] autorun-usecase.sh[113]: [m3video] 279: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 33.708492] autorun-usecase.sh[113]: [m3video] 281: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 33.710461] autorun-usecase.sh[113]: [m3video] 281: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 33.712076] autorun-usecase.sh[113]: [m3video] 281: SYSTEM: IPC init DONE !!!
[ 33.713691] autorun-usecase.sh[113]: [m3video] 292: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 33.715230] autorun-usecase.sh[113]: [m3video] 292: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 33.716768] autorun-usecase.sh[113]: [m3video] 294: SYSTEM : System Common Init Done !!!
[ 33.718227] autorun-usecase.sh[113]: [m3vpss ] 594: SYSTEM : System VPSS Init in progress !!!
[ 33.719832] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 33.721409] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 33.722920] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 33.724567] autorun-usecase.sh[113]: [m3vpss ] 613: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 33.726054] autorun-usecase.sh[113]: [m3vpss ] 613: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 34.058637] autorun-usecase.sh[113]: [m3vpss ] 613: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 34.060438] autorun-usecase.sh[113]: [m3vpss ] 616: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 34.062108] autorun-usecase.sh[113]: [m3vpss ] 616: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 34.063651] autorun-usecase.sh[113]: [m3vpss ] 616: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 34.065118] autorun-usecase.sh[113]: [m3vpss ] 629: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 34.066620] autorun-usecase.sh[113]: [m3vpss ] 630: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 34.068119] autorun-usecase.sh[113]: [m3vpss ] 630: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 34.069574] autorun-usecase.sh[113]: [m3vpss ] 633: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 34.071136] autorun-usecase.sh[113]: [m3vpss ] 633: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 34.072670] autorun-usecase.sh[113]: [m3vpss ] 633: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 34.074155] autorun-usecase.sh[113]: [m3vpss ] 636: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 34.075604] autorun-usecase.sh[113]: [m3vpss ] 636: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 34.077102] autorun-usecase.sh[113]: [m3vpss ] 636: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 35.110172] autorun-usecase.sh[113]: [m3vpss ] 643: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in regionApproDrvInit: 7
[ 35.114708] autorun-usecase.sh[113]: queue id:163845
[ 39.119756] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.121635] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 39.123082] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.129207] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 39.148793] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.150944] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 39.155128] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.158355] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 39.186583] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 39.255047] DMA: Module install successful, device major num = 244
[ 39.261435] DRV: Module install successful
[ 39.265565] DRV: Module built on Feb 13 2017 19:26:20
[ 39.328710]
[ 39.328710] soc_is_dm38x
[ 39.398576] HDMI W1 rev 4.0
[ 39.401430] HDMI CEC Spec version 1.2
[ 39.777138] I2C No Ack
[ 39.779640] HDMI failed to read E-EDID
[ 39.992766] autorun-usecase.sh[113]: queue id:0
[host]277944] autorun-usecase.sh[113]:
[host]286318] autorun-usecase.sh[113]:
[host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 40.401919] autorun-usecase.sh[113]: [ 40.433579] DMA: ChannelID allocated:4
[host] 12: SYSTEM: C[ 40.450650] DMA: ChannelID allocated:5
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 13: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 15: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 15: SYSTEM: IPC init DONE !!!:
[host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 17: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 17: SYSTEM: ListElem Shared Addr = 0xb55d1580
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 19: SYSTEM: ListElem Shared Addr = 0xb55eb200
[host] 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 22: SYSTEM: ListElem Shared Addr = 0xb5604e80
[host] 24: SYSTEM: ListElem Shared Addr = 0xb5624880
[host] 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0xb5644280
[host] 27: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa737a000,size = 65011712
[ 40.480298] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[host] Vsys_allocBuf - addr = 0xb6f0d000,size = 33603
[host]525075] autorun-usecase.sh[113]:
[ 40.527092] autorun-usecase.sh[113]: ********** SMART ANALYTICS USECASE ********
[host] 140: MCFW : CPU Revision [ES1.0] !!!
[host] 140: MCFW : Detected [UNKNOWN] Board !!!
[host] 140: MCFW : Base Board Revision [REV A] !!!
[ 40.560936] autorun-usecase.sh[113]: 0 ...
[ 40.562740] autorun-usecase.sh[113]: [m3vpss ] 643: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 40.564501] autorun-usecase.sh[113]: [m3vpss ] 643: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 40.566153] autorun-usecase.sh[113]: [m3vpss ] 646: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 40.567847] autorun-usecase.sh[113]: [m3vpss ] 646: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 40.569461] autorun-usecase.sh[113]: [m3vpss ] 646: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 40.571251] autorun-usecase.sh[113]: [m3vpss ] 648: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 40.572883] autorun-usecase.sh[113]: [m3vpss ] 649: SYSTEM : FVID2 Init in progress !!!
[ 40.574815] autorun-usecase.sh[113]: [m3video] 694: SYSTEM : System Video Init in progress !!!
[ 40.576564] autorun-usecase.sh[113]: [m3video] 695: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 40.578215] autorun-usecase.sh[113]: [m3video] 695: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 40.579941] autorun-usecase.sh[113]: [m3video] 695: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 40.581723] autorun-usecase.sh[113]: [m3video] 698: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 40.583397] autorun-usecase.sh[113]: [m3video] 698: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 40.585043] autorun-usecase.sh[113]: [m3video] 698: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 40.586718] autorun-usecase.sh[113]: [m3video] 708: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 40.588301] autorun-usecase.sh[113]: [m3video] 708: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 40.921699] autorun-usecase.sh[113]: [m3video] 709: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 40.923343] autorun-usecase.sh[113]: [m3video] 711: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 40.925124] autorun-usecase.sh[113]: [m3video] 711: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 40.926860] autorun-usecase.sh[113]: [m3video] 712: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 40.928500] autorun-usecase.sh[113]: [m3video] 714: HDVICP: Doing PRCM for IVAHD[0] ...
[ 40.930207] autorun-usecase.sh[113]: [m3vpss ] 720: SYSTEM : FVID2 Init in progress DONE !!!
[ 40.931879] autorun-usecase.sh[113]: [m3video] 714: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 40.933540] autorun-usecase.sh[113]: [m3vpss ] 720: SYSTEM : Device Init in progress !!!
[ 40.935214] autorun-usecase.sh[113]: [m3video] 715: SYSTEM : Initializing Links !!!
[ 40.936903] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 40.938550] autorun-usecase.sh[113]: [m3video] 715: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 40.940254] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 40.941883] autorun-usecase.sh[113]: [m3video] 715: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 40.943587] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 40.945257] autorun-usecase.sh[113]: [m3video] 716: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 40.946048] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 40.946601] autorun-usecase.sh[113]: [m3video] 716: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.947174] autorun-usecase.sh[113]: [m3video] 716: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 40.947653] autorun-usecase.sh[113]: [m3video] 717: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.948238] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 40.948701] autorun-usecase.sh[113]: [m3video] 776: SYSTEM : Initializing Links ... DONE !!!
[ 40.949238] autorun-usecase.sh[113]: [m3video] 776: SYSTEM : System Video Init Done !!!
[ 40.949706] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 40.950279] autorun-usecase.sh[113]: [m3vpss ] 914: SYSTEM : Device Init in progress DONE !!!
[ 40.950763] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 40.951294] autorun-usecase.sh[113]: [m3vpss ] 6023: SYSTEM : System VPSS Init Done !!!
[ 40.951765] autorun-usecase[ 41.201082] DMA: ChannelID allocated:6
.sh[113]: [m3vpss ] 6024: UTILS: DMA: HWI Create for INT62 !!![ 41.209580] DMA: ChannelID allocated:7
[ 40.952265] autorun-usecase.sh[113]: [m3vpss ] 6024: SYSTEM : Initializing Links !!!
[ 40.952734] autorun-usecase.sh[113]: [m3vpss ] 6024: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 40.953193] autorun-usecase.sh[113]: [m3vpss ] 6024: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 40.953746] autorun-usecase.sh[113]: [m3vpss ] 6025: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 40.954291] autorun-usecase.sh[113]: [m3vpss ] 6025: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.954828] autorun-usecase.sh[113]: [m3vpss ] 6025: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.955291] autorun-usecase.sh[113]: [m3vpss ] 6156: SYSTEM : Initializing Links ... DONE !!!
[ 40.955819] autorun-usecase.sh[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VP[ 41.294866] DMA: ChannelID allocated:12
S_DC_VENC_HDCOMP
[ 40.956284] autorun-usecase.sh[113]: [m3vp[ 41.300994] DMA: ChannelID allocated:13
ss ] VPS_DCTRL_INST_0
[ 40.956789] autorun-usecase.sh[113]: [ 41.310737] DMA: ChannelID allocated:14
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 40.957248] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 40.957744] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 40.958210] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 40.958669] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.308955] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
[ 41.309554] autorun-usecase.sh[113]: [m3vpss ] 7500: CAMERA: Create in progress !!!
[ 41.310169] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 41.310688] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 41.311173] autorun-usecase.sh[113]: [m3vpss ] 7500: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 41.313941] autorun-usecase.sh[113]: [m3vpss ] 7501: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 41.315052] autorun-usecase.sh[113]: [m3vp
[host] 1223: IPC_BITS_IN : Create in progress !!!
[host] 1223: IPC_BITS_IN : ListMPOpen start !!!
[host] 1223: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1224: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1224: IPC_BITS_IN : ListMPOpen done !!!
[host] 1225: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1225: IPC_BITS_IN : Create Done !!!
[ 41.666162] autorun-usecase.sh[113]: ss ] Iss_captCreate:1661
[ 41.666810] autorun-usecase.sh[113]: [m3vpss ] 7714: CAMERA: Create Done !!!
[ 41.667401] autorun-usecase.sh[113]: [m3vpss ] 7804: CAMERA: Detect video in progress !!!
[ 41.667891] autorun-usecase.sh[113]: [m3vpss ] 7804: CAMERA: Detect video Done !!!
[ 41.668418] autorun-usecase.sh[113]: [m3video] 7879: IPC_IN_M3 : Create in progress !!!
[ 41.668894] autorun-usecase.sh[113]: [m3vpss ] 7877: DUP : Create Done !!!
[ 41.669358] autorun-usecase.sh[113]: [m3video] 7879: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 41.669887] autorun-usecase.sh[113]: [m3vpss ] 7877: IPC_OUT_M3 : Create in progress !!!
[ 41.670400] autorun-usecase.sh[113]: [m3video] 7880: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 41.670934] autorun-usecase.sh[113]: [m3vpss ] 7879: IPC_OUT_M3 : Create Done !!!
[ 41.671394] autorun-usecase.sh[113]: [m3video] 7883: IPC_IN_M3 : Create Done !!!
[ 41.671925] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 41.672382] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
[ 41.672874] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
[ 41.673336] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
[ 41.673952] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
[ 41.674469] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 41.674959] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
[ 41.675488] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
[ 41.676011] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
[ 41.676540] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
[ 41.676999] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 41.677545] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 41.678002] autorun-usecase.sh[113]: [m3video] 8064: IPC_OUT_M3 : Create in progress !!!
[ 41.678510] autorun-usecase.sh[113]: [m3video] 8065: IPC_OUT_M3 : Create Done !!!
[ 41.678972] autorun-usecase.sh[113]: [m3vpss ] 8066: IPC_IN_M3 : Create in progress !!!
[ 41.679466] autorun-usecase.sh[113]: [m3vpss ] 8066: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 41.679929] autorun-usecase.sh[113]: [m3vpss ] 8067: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 41.680448] autorun-usecase.sh[113]: [m3vpss ] 8067: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 41.680976] autorun-usecase.sh[113]: [m3vpss ] 8070: IPC_IN_M3 : Create Done !!!
[ 41.681433] autorun-usecase.sh[113]: [m3vpss ] 8070: NSF: Create in progress !!!
[ 41.682067] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 41.682576] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 41.683156] autorun-usecase.sh[113]: [m3vpss ] 8195: NSF: Create Done !!!
[ 41.683626] autorun-usecase.sh[113]: [m3vpss ] 8196: Mux : Creating... !!!
[ 41.684154] autorun-usecase.sh[113]: [m3vpss ] 8197: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 41.684620] autorun-usecase.sh[113]: [m3vpss ] 8198: Mux : Create Done !!!
[ 41.685125] autorun-usecase.sh[113]: [m3vpss ] 8204: DUP : Create Done !!!
[ 41.685582] autorun-usecase.sh[113]: [m3vpss ] 8211: DUP : Create Done !!!
[ 41.686161] autorun-usecase.sh[113]: [m3vpss ] 8212: Mux : Creating... !!!
[ 41.686633] autorun-usecase.sh[113]: [m3vpss ] 8214: Mux : Create Done !!!
[ 41.687202] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 41.687695] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 41.688162] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 41.688715] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 41.689176] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 41.689693] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 41.690351] autorun-usecase.sh[113]: [m3vpss ] 8223: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 41.690936] autorun-usecase.sh[113]: [m3vpss ] 8227: SWOSD : Create Done !!!
[ 42.024576] autorun-usecase.sh[113]: [m3vpss ] 8300: DUP : Create Done !!!
[ 42.025047] autorun-usecase.sh[113]: [m3vpss ] 8301: SCLR: Create in progress !!!
[ 42.025414] autorun-usecase.sh[113]: [m3vpss ] 8306: SCLR : Loading Up-scaling Co-effs ...
[ 42.025758] autorun-usecase.sh[113]: [m3vpss ] 8306: SCLR : Co-effs Loading ... DONE !!!
[ 42.026091] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 42.026415] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 42.026737] autorun-usecase.sh[113]: [m3vpss ] 8306: SCLR: Create Done !!!
[ 42.027058] autorun-usecase.sh[113]: [m3vpss ] 8313: DUP : Create Done !!!
[ 42.027378] autorun-usecase.sh[113]: [m3vpss ] 8251: VA : Create Done !!!
[ 42.028583] autorun-usecase.sh[113]: [m3vpss ] 8269: FD : Alg Create Done !!!
[ 42.029214] autorun-usecase.sh[113]: [m3vpss ] 8269: FD : Create Done !!!
[ 42.029760] autorun-usecase.sh[113]: [m3video] 8345: IPC_IN_M3 : Create in progress !!!
[ 42.030998] autorun-usecase.sh[113]: [m3vpss ] 8277: VA : ALG Init Done !!!
[ 42.031687] autorun-usecase.sh[113]: [m3video] 8345: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 42.032220] autorun-usecase.sh[113]: [m3vpss ] 8343: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR : failed !!!
[ 42.033474] autorun-usecase.sh[113]: [m3video] 8346: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 42.034608] autorun-usecase.sh[113]: [m3vpss ] 8343: IPC_OUT_M3 : Create in progress !!!
[ 42.035236] autorun-usecase.sh[113]: [m3video] 8349: IPC_IN_M3 : Create Done !!!
[ 42.035899] autorun-usecase.sh[113]: [m3vpss ] 8345: IPC_OUT_M3 : Create Done !!!
[ 42.036489] autorun-usecase.sh[113]: [m3video] 8349: ENCODE: Create in progress ... !!!
[ 42.036979] autorun-usecase.sh[113]: [m3video] 8475: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 42.037513] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 42.038919] autorun-usecase.sh[113]: [m3video] 8556: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 42.039582] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 42.040170] autorun-usecase.sh[113]: [m3video] 8640: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[ 42.040760] autorun-usecase.sh[113]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 42.041258] autorun-usecase.sh[113]: [m3video] 8641: ENCODE: All CH Create ... DONE !!!
[ 42.041721] autorun-usecase.sh[113]: [m3video] ENCLINK:HEAPID:0 USED:28144
[ 42.042333] autorun-usecase.sh[113]: [m3video] 8644: ENCODE: Create ... DONE !!!
[ 42.102852] autorun-usecase.sh[113]: [m3video] 8608: VSTApproDrvInit: 3
[ 42.114668] autorun-usecase.sh[113]: queue id:163845
[ 42.124966] autorun-usecase.sh[113]: queue id:0
[ 42.126067] autorun-usecase.sh[113]: queue id:32769
[ 44.013266] autorun-usecase.sh[113]: queue id:0
[ 59.995780] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 59.996580] autorun-usecase.sh[113]: Program exit.
[ 64.015385] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 64.016100] autorun-usecase.sh[113]: Program exit.
U-Boot SPL 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46 -0500)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2662320 bytes read in 305 ms (8.3 MiB/s)
reading dm38x-csk.dtb
58698 bytes read in 14 ms (4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.4.12-00004-g82adbbf-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2662256 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Kernel Image ... OK
Loading Device Tree to 844ee000, end 844ff549 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine model: DM38X CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: Reserved 24 MiB at 0x82c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES1.0 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067efa4 (6620 kB)
[ 0.000000] .init : 0xc067f000 - 0xc06c4000 ( 276 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc0705308 ( 261 kB)
[ 0.000000] .bss : 0xc0705308 - 0xc0741718 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.008263] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.086911] pid_max: default: 32768 minimum: 301
[ 0.091860] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098773] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106817] Initializing cgroup subsys io
[ 0.111049] Initializing cgroup subsys memory
[ 0.115671] Initializing cgroup subsys devices
[ 0.120345] Initializing cgroup subsys freezer
[ 0.125025] Initializing cgroup subsys pids
[ 0.129439] CPU: Testing write buffer coherency: ok
[ 0.134895] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142708] devtmpfs: initialized
[ 0.168774] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217131] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229274] pinctrl core: initialized pinctrl subsystem
[ 0.236061] NET: Registered protocol family 16
[ 0.242305] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255266] OMAP GPIO hardware version 0.1
[ 0.267844] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301554] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309822] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323426] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337095] media: Linux media interface: v0.10
[ 0.341911] Linux video capture interface: v2.00
[ 0.346823] pps_core: LinuxPPS API ver. 1 registered
[ 0.352018] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361546] PTP clock support registered
[ 0.365687] EDAC MC: Ver: 3.0.0
[ 0.369738] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377137] clocksource: Switched to clocksource timer1
[ 0.394570] NET: Registered protocol family 2
[ 0.399936] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407249] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413887] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420609] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426712] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433432] NET: Registered protocol family 1
[ 0.438386] RPC: Registered named UNIX socket transport module.
[ 0.444569] RPC: Registered udp transport module.
[ 0.449528] RPC: Registered tcp transport module.
[ 0.454454] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462501] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469600] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486574] NFS: Registering the id_resolver key type
[ 0.491974] Key type id_resolver registered
[ 0.496367] Key type id_legacy registered
[ 0.502272] io scheduler noop registered
[ 0.506409] io scheduler deadline registered
[ 0.511162] io scheduler cfq registered (default)
[ 0.517483] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598632] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609639] console [ttyS0] disabled
[ 0.613452] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622409] console [ttyS0] enabled
[ 0.629602] bootconsole [earlycon0] disabled
[ 0.639397] Reference Linux version 4.4.12
[ 0.643693] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662238] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668141] cmemk initialized
[ 0.678518] loop: module loaded
[ 0.747195] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753333] libphy: 4a100800.mdio: probed
[ 0.758232] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767223] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c1:2c
[ 0.777324] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807397] mousedev: PS/2 mouse device common for all mice
[ 0.813905] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.821383] i2c /dev entries driver
[ 0.825864] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.832994] sdhci: Secure Digital Host Controller Interface driver
[ 0.839229] sdhci: Copyright(c) Pierre Ossman
[ 0.988011] mmc0: new high speed SDIO card at address 0001
[ 0.997401] Synopsys Designware Multimedia Card Interface Driver
[ 1.003897] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.010882] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.017038] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.028797] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.036074] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.043540] NET: Registered protocol family 10
[ 1.050409] sit: IPv6 over IPv4 tunneling driver
[ 1.055886] NET: Registered protocol family 17
[ 1.060544] Key type dns_resolver registered
[ 1.065079] omap_voltage_late_init: Could not get sys clk.
[ 1.070989] Power Management for TI81XX.
[ 1.080235] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.085419] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.093264] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.099697] nand: Micron MT29F2G16ABAEAWP
[ 1.103730] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.111366] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.116780] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.122835] Creating 8 MTD partitions on "8000000.nand":
[ 1.128194] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.137946] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.146132] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.153242] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.162339] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.172124] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.187216] mmc1: new high speed SDHC card at address 0007
[ 1.207189] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.213164] mmcblk0: p1 p2
[ 1.262438] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.269810] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.280640] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.343725] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.351436] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.358919] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.365704] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.372770] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.382185] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.404007] wlan-en-regulator: disabling
[ 1.408364] ALSA device list:
[ 1.411352] #0: TI81XX-CSK
[ 1.416297] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 11.847260] EXT4-fs (mmcblk0p2): recovery complete
[ 11.860522] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 11.868735] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 11.883851] devtmpfs: mounted
[ 11.887463] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 11.893845] This architecture does not have kernel memory protection.
[ 12.134840] systemd[1]: System time before build time, advancing clock.
[ 12.156906] random: systemd urandom read with 32 bits of entropy available
[ 12.177442] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 12.196192] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[ 12.219143] systemd[1]: Set hostname to <ti81xx>.
[ 12.509467] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 12.657836] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 12.687464] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 12.707401] systemd[1]: Reached target Timers.
[ OK ] Reached target Timers.
[ 12.745884] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 12.771344] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 12.788688] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 12.808585] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 12.827743] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 12.857718] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 12.891467] systemd[1]: Mounting /media/ram...
[ 12.921551] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.991643] systemd[1]: Mounting /var/volatile...
[ 13.022821] systemd[1]: Mounting Temporary Directory...
[ 13.056079] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 13.077826] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 13.101362] systemd[1]: Starting udev Kernel Device Manager...
[ 13.127669] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 13.152277] systemd[1]: Starting udev Coldplug all Devices...
[ 13.204649] systemd[1]: Starting Synchronize System and HW clocks...
[ 13.244721] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 13.287563] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 13.310565] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 13.341776] systemd[1]: Starting Journal Service...
[ 13.387546] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 13.418027] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 13.476130] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 13.497714] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 13.517628] systemd[1]: Mounted /var/volatile.
[ OK ] Mounted /var/volatile.
[ 13.537547] systemd[1]: Mounted /media/ram.
[ OK ] Mounted /media/ram.
[ 13.558405] systemd[1]: Started udev Kernel Device Manager.
[ OK ] Started udev Kernel Device Manager.
[ 13.578160] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started IPNC RDK use case service.
[ OK ] Reached target Local File Systems.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started D-Bus System Message Bus.
[ 14.649453] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 14.692041] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 14.711855] autorun-usecase.sh[113]: : values=115,115
[ 14.733914] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 14.762031] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 14.781807] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 14.814227] autorun-usecase.sh[113]: : values=72,72
[ 14.831825] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 14.851811] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ 14.871802] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
Starting uim-sysfs.service...
[ OK ] Started Kernel Logging Service.
[ 14.911809] autorun-usecase.sh[113]: : values=on
[ 14.943353] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 14.971820] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 14.998234] ubi0: attaching mtd6
[ 14.991789] autorun-usecase.sh[113]: : values=on
[ OK ] Started System Logging Service.
[ 15.014470] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
Starting Network Service...
[ 15.224888] ubi0: scanning is finished
[ 15.295058] net eth0: initializing cpsw version 1.10 (0)
[ 15.300496] net eth0: initialized cpsw ale version 1.3
[ 15.308980] net eth0: phy found : id is : 0x2000a231
[ 15.314021] libphy: PHY not found
[ 15.317471] net eth0: phy "" not found on slave 1, err -19
[ 15.337275] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 15.343245] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 15.350188] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 15.356922] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.363931] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 15.369909] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 15.377185] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2367567630
[ 15.386360] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 15.396075] ubi0: background thread "ubi_bgt0d" started, PID 146
[ OK ] Started Network Service.
[ 15.490298] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.609882] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 16.257696] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
[ 16.344628] UBIFS (ubi0:0): recovery needed
[ 16.583451] UBIFS (ubi0:0): recovery completed
[ 16.588086] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 16.596045] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 16.606043] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 16.616193] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 16.622684] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID CCD16CCE-643B-4FE0-8D48-DEAEE5B4A223, small LPT model
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ 17.431103] ubi1: attaching mtd7
[ OK ] Started uim-sysfs.service.
[ 17.694815] ubi1: scanning is finished
[ 17.729463] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 17.735786] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 17.742767] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 17.749520] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 17.756513] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 17.762567] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 17.769839] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 455573015
[ 17.778942] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 17.790685] ubi1: background thread "ubi_bgt1d" started, PID 164
Starting telnetd.service...
[ OK ] Started telnetd.service.
[ 17.879723] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Reached target Multi-User System.
[ 18.437242] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 182
[ 18.460577] UBIFS (ubi1:0): recovery needed
[ 18.480301] UBIFS (ubi1:0): recovery completed
[ 18.484873] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 18.492892] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 18.502874] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 18.513374] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 18.520042] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 9B011D6F-144D-4DAC-8697-9B0E6BA1215C, small LPT model
[ 19.033675] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 19.308341] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 19.333677] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.853263] cfg80211: World regulatory domain updated:
[ 19.858547] cfg80211: DFS Master region: unset
[ 19.862928] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 19.872758] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.880819] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.888877] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.896922] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 19.906465] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 19.916006] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 19.924257] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.932327] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 20.628595] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 21.027882] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 21.056659] wlcore: loaded
[ 21.666052] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 21.769470] random: nonblocking pool is initialized
[ 21.780089] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 21.796493] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 25.939983] autorun-usecase.sh[113]: SSID: Tejovat_Eprize
[ 25.941846] autorun-usecase.sh[113]: SSID: Inacces
[ 25.943276] autorun-usecase.sh[113]: SSID: WTI
[ 25.944600] autorun-usecase.sh[113]: SSID: nirmal
[ 26.336083] <1>SysLink version : 2.21.02.10
[ 26.336083] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 26.346748] <1>Trace enabled
[ 26.349676] <1>Trace SetFailureReason enabled
[ 26.419034] autorun-usecase.sh[113]: /dev/mem opened.
[ 26.421166] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 26.428231] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 26.433990] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 26.440286] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 26.448433] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 26.455133] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 26.468889] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.477672] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.479371] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 26.481045] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 27.400469] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (229) - No such process
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 27.498020] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 28.530129] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 28.532207] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 28.534444] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 28.541382] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 28.543249] autorun-usecase.sh[113]: logical sector size is 512,
[ 28.544765] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 28.549670] autorun-usecase.sh[113]: drive number 0x80;
[ 28.554873] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 28.556827] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 28.559023] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 28.562002] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 28.568511] autorun-usecase.sh[113]: Volume ID is 9c0640c4, no volume label.
[ 28.806782] Mass Storage Function, version: 2009/09/11
[ 28.812061] LUN: removable file: (no medium)
[ 28.816714] LUN: removable file: /dev/sbulla
[ 28.821061] Number of LUNs=1
[ 28.855868] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 28.862927] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 28.870041] g_mass_storage gadget: g_mass_storage ready
[ 28.928023] autorun-usecase.sh[113]: Creat queue id:0
[ 28.929753] autorun-usecase.sh[113]: queue id:0
[ 28.931725] autorun-usecase.sh[113]: Creat queue id:32769
[ 28.938269] autorun-usecase.sh[113]: queue id:32769
[ 28.944895] autorun-usecase.sh[113]: Creat queue id:65538
[ 28.947802] autorun-usecase.sh[113]: queue id:65538
[ 28.960174] autorun-usecase.sh[113]: Creat queue id:98307
[ 28.962116] autorun-usecase.sh[113]: queue id:98307
[ 28.963697] autorun-usecase.sh[113]: queue id:32769
[host] Attached to slave procId 1.13]:
[host] Attached to slave procId 0.13]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.sh[113]:
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.sh[113]:
[host] After Ipc_startcallback status [0x00000000]
[ 30.026582] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.028610] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.030248] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.031802] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 31.477468] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.479306] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.489843] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.493055] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 31.495322] autorun-usecase.sh[113]: queue id:65538
[ 31.496963] autorun-usecase.sh[113]: Creat queue id:131076
[ 31.498881] autorun-usecase.sh[113]: queue id:131076
[ 31.500506] autorun-usecase.sh[113]: CPU is TI812x
[ 31.502073] autorun-usecase.sh[113]: vsenable : 0
[ 31.687329] autorun-usecase.sh[113]: Creat queue id:163845
[ 31.690967] autorun-usecase.sh[113]: queue id:163845
[ 31.700219] autorun-usecase.sh[113]: queue id:65538
[ 31.759183] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.761764] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.770529] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.849375] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.851267] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.852663] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.878488] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.880518] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.886005] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.888303] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.898706] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.926898] autorun-usecase.sh[113]: [m3video]
[ 31.930349] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 31.933261] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.935020] autorun-usecase.sh[113]: [m3video]
[ 31.936591] autorun-usecase.sh[113]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 31.938112] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 31.939751] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 31.941288] autorun-usecase.sh[113]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 31.942722] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 31.944215] autorun-usecase.sh[113]: [m3vpss ]
[ 31.945639] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.947043] autorun-usecase.sh[113]: [m3vpss ]
[ 31.948476] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 31.950231] autorun-usecase.sh[113]: [m3vpss ] 68: SYSTEM: IPC init in progress !!!
[ 31.951676] autorun-usecase.sh[113]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 31.953089] autorun-usecase.sh[113]: [m3video] 90: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.954544] autorun-usecase.sh[113]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 31.955936] autorun-usecase.sh[113]: [m3video] 90: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.957343] autorun-usecase.sh[113]: [m3vpss ] 119: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.958737] autorun-usecase.sh[113]: [m3vpss ] 119: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.960371] autorun-usecase.sh[113]: [m3video] 140: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.962100] autorun-usecase.sh[113]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.963532] autorun-usecase.sh[113]: [m3video] 169: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 31.964925] autorun-usecase.sh[113]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 31.966379] autorun-usecase.sh[113]: [m3video] 170: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.967780] autorun-usecase.sh[113]: [m3vpss ] 170: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.969198] autorun-usecase.sh[113]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 31.970882] autorun-usecase.sh[113]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 31.972327] autorun-usecase.sh[113]: [m3vpss ] 172: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.973732] autorun-usecase.sh[113]: [m3vpss ] 172: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 31.975116] autorun-usecase.sh[113]: [m3vpss ] 173: SYSTEM: IPC init DONE !!!
[ 31.976547] autorun-usecase.sh[113]: [m3vpss ] 184: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.978014] autorun-usecase.sh[113]: [m3vpss ] 184: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.979536] autorun-usecase.sh[113]: [m3vpss ] 186: SYSTEM : System Common Init Done !!!
[ 31.981225] autorun-usecase.sh[113]: [m3video] 270: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.982766] autorun-usecase.sh[113]: [m3video] 271: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 31.984197] autorun-usecase.sh[113]: [m3video] 271: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 31.985597] autorun-usecase.sh[113]: [m3video] 273: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.987005] autorun-usecase.sh[113]: [m3video] 273: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 31.988448] autorun-usecase.sh[113]: [m3video] 273: SYSTEM: IPC init DONE !!!
[ 31.989907] autorun-usecase.sh[113]: [m3video] 284: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.991536] autorun-usecase.sh[113]: [m3video] 284: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.992980] autorun-usecase.sh[113]: [m3video] 286: SYSTEM : System Common Init Done !!!
[ 31.994439] autorun-usecase.sh[113]: [m3vpss ] 1986: SYSTEM : System VPSS Init in progress !!!
[ 31.995874] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 31.997271] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 31.998679] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 32.000186] autorun-usecase.sh[113]: [m3vpss ] 2005: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 32.001744] autorun-usecase.sh[113]: [m3vpss ] 2005: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 32.003304] autorun-usecase.sh[113]: [m3vpss ] 2005: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 32.004754] autorun-usecase.sh[113]: [m3vpss ] 2008: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 32.006198] autorun-usecase.sh[113]: [m3vpss ] 2008: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 32.341614] autorun-usecase.sh[113]: [m3vpss ] 2008: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 32.343300] autorun-usecase.sh[113]: [m3vpss ] 2021: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 32.344814] autorun-usecase.sh[113]: [m3vpss ] 2022: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 32.346315] autorun-usecase.sh[113]: [m3vpss ] 2022: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 32.347757] autorun-usecase.sh[113]: [m3vpss ] 2025: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 32.349163] autorun-usecase.sh[113]: [m3vpss ] 2025: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 32.350663] autorun-usecase.sh[113]: [m3vpss ] 2025: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 32.352190] autorun-usecase.sh[113]: [m3vpss ] 2028: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 32.353743] autorun-usecase.sh[113]: [m3vpss ] 2028: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 32.355169] autorun-usecase.sh[113]: [m3vpss ] 2029: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 32.356841] autorun-usecase.sh[113]: [m3vpss ] 2035: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUApproDrvInit: 7
[ 32.358371] autorun-usecase.sh[113]: queue id:163845
[ 36.961796] autorun-usecase.sh[113]: queue id:0
[ 37.387191] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 37.391176] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 37.392980] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 37.396410] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 37.416100] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 37.417858] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 37.422141] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 37.425541] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 37.451543] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 37.522751] DMA: Module install successful, device major num = 244
[ 37.529141] DRV: Module install successful
[ 37.533258] DRV: Module built on Feb 13 2017 19:26:20
[ 37.595599]
[ 37.595599] soc_is_dm38x
[ 37.664666] HDMI W1 rev 4.0
[ 37.667562] HDMI CEC Spec version 1.2
[ 38.047152] I2C No Ack
[ 38.049654] HDMI failed to read E-EDID
[host]534049] autorun-usecase.sh[113]:
[host] ORG 0x46c00524: 0case.sh[113]:
[host] NEW 0x46c00524: 2case.sh[113]:
[host]541371] autorun-usecase.sh[113]:
[host] Application Start Completed13]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[ 38.657021] autorun-usecase.sh[113]: [ 38.687539] DMA: ChannelID allocated:4
[host] 13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[host] 13: SYSTEM: C[ 38.706148] DMA: ChannelID allocated:5
PU [VPSS-M3] syslink proc ID is [1] !!!
[host] 13: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 18: SYSTEM: ListElem Shared Addr = 0xb55fb580
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 19: SYSTEM: ListElem Shared Addr = 0xb5615200
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 22: SYSTEM: ListElem Shared Addr = 0xb562ee80
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 24: SYSTEM: ListElem Shared Addr = 0xb564e880
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0xb566e280
[host] 29: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa73a4000,size = 65011712
[ 38.733912] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6f37000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]777633] autorun-usecase.sh[113]:
[ 38.780093] autorun-usecase.sh[113]: ********** SMART ANALYTICS USECASE ********
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 139: MCFW : CPU Revision [ES1.0] !!!
[host] 139: MCFW : Detected [UNKNOWN] Board !!!
[host] 139: MCFW : Base Board Revision [REV A] !!!
[ 38.800430] autorun-usecase.sh[113]: T_29] in region 0 ...
[ 38.802202] autorun-usecase.sh[113]: [m3vpss ] 2035: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 38.803895] autorun-usecase.sh[113]: [m3vpss ] 2035: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 38.805768] autorun-usecase.sh[113]: [m3vpss ] 2038: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 38.807482] autorun-usecase.sh[113]: [m3vpss ] 2038: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 38.809171] autorun-usecase.sh[113]: [m3vpss ] 2039: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 38.810980] autorun-usecase.sh[113]: [m3vpss ] 2040: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 38.812697] autorun-usecase.sh[113]: [m3vpss ] 2041: SYSTEM : FVID2 Init in progress !!!
[ 38.814322] autorun-usecase.sh[113]: [m3video] 2086: SYSTEM : System Video Init in progress !!!
[ 38.815971] autorun-usecase.sh[113]: [m3video] 2087: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 38.817610] autorun-usecase.sh[113]: [m3video] 2087: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 38.819251] autorun-usecase.sh[113]: [m3video] 2087: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 38.820970] autorun-usecase.sh[113]: [m3video] 2090: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 38.822641] autorun-usecase.sh[113]: [m3video] 2090: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 38.824284] autorun-usecase.sh[113]: [m3video] 2090: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 39.159589] autorun-usecase.sh[113]: [m3video] 2100: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 39.161477] autorun-usecase.sh[113]: [m3video] 2100: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 39.163242] autorun-usecase.sh[113]: [m3video] 2101: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 39.164941] autorun-usecase.sh[113]: [m3video] 2103: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 39.166604] autorun-usecase.sh[113]: [m3vpss ] 2112: SYSTEM : FVID2 Init in progress DONE !!!
[ 39.168204] autorun-usecase.sh[113]: [m3video] 2104: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 39.169872] autorun-usecase.sh[113]: [m3vpss ] 2112: SYSTEM : Device Init in progress !!!
[ 39.171930] autorun-usecase.sh[113]: [m3video] 2104: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 39.173620] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 39.175314] autorun-usecase.sh[113]: [m3video] 2106: HDVICP: Doing PRCM for IVAHD[0] ...
[ 39.176915] autorun-usecase.sh[113]: [m3video] 2106: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 39.178520] autorun-usecase.sh[113]: [m3video] 2107: SYSTEM : Initializing Links !!!
[ 39.180575] autorun-usecase.sh[113]: [m3video] 2107: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 39.182310] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 39.183992] autorun-usecase.sh[113]: [m3video] 2107: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 39.185666] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 39.186463] autorun-usecase.sh[113]: [m3video] 2108: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 39.187031] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 39.187575] autorun-usecase.sh[113]: [m3video] 2108: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 39.188048] autorun-usecase.sh[113]: [m3video] 2108: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 39.188505] autorun-usecase.sh[113]: [m3video] 2109: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 39.189020] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 39.189467] autorun-usecase.sh[113]: [m3video] 2168: SYSTEM : Initializing Links ... DONE !!!
[ 39.189986] autorun-usecase.sh[113]: [m3video] 2168: SYSTEM : System Video Init Done !!!
[ 39.190502] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 39.191014] autorun-usecase.sh[113]: [m3vpss ] 2306: SYSTEM : Device Init in progress DONE !!!
[ 39.191494] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 39.19198[ 39.454021] DMA: ChannelID allocated:6
2] autorun-usecase.sh[113]: [m3vpss ] 7415: SYSTEM : System V[ 39.458451] DMA: ChannelID allocated:7
PSS Init Done !!!
[ 39.192429] autorun-usecase.sh[113]: [m3vpss ] 7416: UTILS: DMA: HWI Create for INT62 !!!
[ 39.192869] autorun-usecase.sh[113]: [m3vpss ] 7416: SYSTEM : Initializing Links !!!
[ 39.193376] autorun-usecase.sh[113]: [m3vpss ] 7416: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 39.193894] autorun-usecase.sh[113]: [m3vpss ] 7416: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 39.194399] autorun-usecase.sh[113]: [m3vpss ] 7417: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 39.194851] autorun-usecase.sh[113]: [m3vpss ] 7417: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 39.195334] autorun-usecase.sh[113]: [m3vpss ] 7417: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 39.195784] autorun-usecase.sh[113]: [m3vpss ] 7548: SYSTEM : In[ 39.543787] DMA: ChannelID allocated:12
[ 39.196219] autorun-usecase.sh[ 39.549906] DMA: ChannelID allocated:13
[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOM[ 39.559378] DMA: ChannelID allocated:14
P
[ 39.196730] autorun-usecase.sh[113]: [m3vpss ] VPS_DCTRL_INST_0
[ 39.197204] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 39.197702] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 39.198142] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 39.552482] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 39.553075] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 39.553805] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
[ 39.554341] autorun-usecase.sh[113]: [m3vpss ] 8876: CAMERA: Create in progress !!!
[ 39.554987] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 39.555594] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 39.556085] autorun-usecase.sh[113]: [m3vpss ] 8876: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 39.559253] autorun-usecase.sh[113]: [m3vpss ] 8877: CAMERA: VIP 0: VID DEC 268436737 (0x10): 00ApproDrvInit: 3
[ 39.559806] autorun-usecase.sh[113]: queue id:163845
[ 39.560460] autorun-usecase.sh[113]: queue id:0
[ 39.560984] autorun-usecase.sh[113]: queue id:32769
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1218: IPC_BITS_IN : Create in progress !!!
[host] 1219: IPC_BITS_IN : ListMPOpen start !!!
[host] 1219: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1219: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1219: IPC_BITS_IN : ListMPOpen done !!!
[host] 1220: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1220: IPC_BITS_IN : Create Done !!!
[ 39.915048] autorun-usecase.sh[113]: 02:20202020:20202020, AUD_STATUS 538976288
[ 39.915636] autorun-usecase.sh[113]: [m3vpss ] Iss_captCreate:1661
[ 39.916228] autorun-usecase.sh[113]: [m3vpss ] 9090: CAMERA: Create Done !!!
[ 39.916706] autorun-usecase.sh[113]: [m3vpss ] 9180: CAMERA: Detect video in progress !!!
[ 39.917226] autorun-usecase.sh[113]: [m3vpss ] 9180: CAMERA: Detect video Done !!!
[ 39.917681] autorun-usecase.sh[113]: [m3video] 9256: IPC_IN_M3 : Create in progress !!!
[ 39.918169] autorun-usecase.sh[113]: [m3vpss ] 9253: DUP : Create Done !!!
[ 39.918611] autorun-usecase.sh[113]: [m3video] 9256: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 39.919050] autorun-usecase.sh[113]: [m3vpss ] 9254: IPC_OUT_M3 : Create in progress !!!
[ 39.919552] autorun-usecase.sh[113]: [m3video] 9256: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 39.919995] autorun-usecase.sh[113]: [m3vpss ] 9255: IPC_OUT_M3 : Create Done !!!
[ 39.920538] autorun-usecase.sh[113]: [m3video] 9259: IPC_IN_M3 : Create Done !!!
[ 39.920989] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 39.921430] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
[ 39.921952] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
[ 39.922392] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
[ 39.923007] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
[ 39.923504] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 39.924041] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
[ 39.924496] autorun-usecase.sh[113]: [m3vpss ] 9442: IPC_IN_M3 : Create in progress !!!
[ 39.925062] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
[ 39.925509] autorun-usecase.sh[113]: [m3vpss ] 9443: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 39.925997] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
[ 39.926445] autorun-usecase.sh[113]: [m3vpss ] 9443: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 39.926886] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
[ 39.927412] autorun-usecase.sh[113]: [m3vpss ] 9444: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 39.927856] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 39.928335] autorun-usecase.sh[113]: [m3vpss ] 9446: IPC_IN_M3 : Create Done !!!
[ 39.928776] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 39.929209] autorun-usecase.sh[113]: [m3vpss ] 9447: NSF: Create in progress !!!
[ 39.929711] autorun-usecase.sh[113]: [m3video] 9440: IPC_OUT_M3 : Create in progress !!!
[ 39.930183] autorun-usecase.sh[113]: [m3video] 9442: IPC_OUT_M3 : Create Done !!!
[ 39.930693] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 39.931302] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 39.931847] autorun-usecase.sh[113]: [m3vpss ] 9572: NSF: Create Done !!!
[ 39.932300] autorun-usecase.sh[113]: [m3vpss ] 9572: Mux : Creating... !!!
[ 39.932826] autorun-usecase.sh[113]: [m3vpss ] 9574: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 39.933278] autorun-usecase.sh[113]: [m3vpss ] 9574: Mux : Create Done !!!
[ 39.933718] autorun-usecase.sh[113]: [m3vpss ] 9581: DUP : Create Done !!!
[ 39.934223] autorun-usecase.sh[113]: [m3vpss ] 9588: DUP : Create Done !!!
[ 39.934663] autorun-usecase.sh[113]: [m3vpss ] 9588: Mux : Creating... !!!
[ 39.935308] autorun-usecase.sh[113]: [m3vpss ] 9590: Mux : Create Done !!!
[ 39.935786] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 39.936312] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 39.936768] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 39.937248] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 39.937689] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 39.938123] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 40.268746] autorun-usecase.sh[113]: [m3vpss ] 9600: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 40.269268] autorun-usecase.sh[113]: [m3vpss ] 9599: SWOSD : Create Done !!!
[ 40.269737] autorun-usecase.sh[113]: [m3vpss ] 9672: DUP : Create Done !!!
[ 40.270243] autorun-usecase.sh[113]: [m3vpss ] 9673: SCLR: Create in progress !!!
[ 40.270731] autorun-usecase.sh[113]: [m3vpss ] 9678: SCLR : Loading Up-scaling Co-effs ...
[ 40.271185] autorun-usecase.sh[113]: [m3vpss ] 9678: SCLR : Co-effs Loading ... DONE !!!
[ 40.271626] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 40.272133] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 40.272723] autorun-usecase.sh[113]: [m3vpss ] 9679: SCLR: Create Done !!!
[ 40.273317] autorun-usecase.sh[113]: [m3vpss ] 9685: DUP : Create Done !!!
[ 40.273822] autorun-usecase.sh[113]: [m3vpss ] 9624: VA : Create Done !!!
[ 40.274354] autorun-usecase.sh[113]: [m3vpss ] 9641: FD : Alg Create Done !!!
[ 40.274806] autorun-usecase.sh[113]: [m3vpss ] 9641: FD : Create Done !!!
[ 40.275298] autorun-usecase.sh[113]: [m3video] 9718: IPC_IN_M3 : Create in progress !!!
[ 40.275741] autorun-usecase.sh[113]: [m3vpss ] 9649: VA : ALG Init Done !!!
[ 40.276179] autorun-usecase.sh[113]: [m3video] 9718: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 40.276855] autorun-usecase.sh[113]: [m3vpss ] 9716: IPC_OUT_M3 : Create in progress !!!
[ 40.277394] autorun-usecase.sh[113]: [m3video] 9718: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 40.277865] autorun-usecase.sh[113]: [m3vpss ] 9717: IPC_OUT_M3 : Create Done !!!
[ 40.278315] autorun-usecase.sh[113]: [m3video] 9721: IPC_IN_M3 : Create Done !!!
[ 40.278827] autorun-usecase.sh[113]: [m3vpss ] 9717: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR : failed !!!
[ 40.279302] autorun-usecase.sh[113]: [m3video] 9722: ENCODE: Create in progress ... !!!
[ 40.279803] autorun-usecase.sh[113]: [m3video] 9848: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 40.280310] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 40.280821] autorun-usecase.sh[113]: [m3video] 9929: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 40.281270] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 40.281714] autorun-usecase.sh[113]: [m3video] 10013: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[ 40.282212] autorun-usecase.sh[113]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 40.282654] autorun-usecase.sh[113]: [m3video] 10014: ENCODE: All CH Create ... DONE !!!
[ 40.283242] autorun-usecase.sh[113]: [m3video] ENCLINK:HEAPID:0 USED:28144
[ 40.978143] autorun-usecase.sh[113]: [m3video] 1001queue id:0
[ 56.964868] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 56.965652] autorun-usecase.sh[113]: Program exit.
[ 60.980159] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 60.980870] autorun-usecase.sh[113]: Program exit.
Any help is appreciated.
  • Hi Santosh,
    Have you connected  Ethernet cable to CSK? Or have you followed instructions to enable WiFi? Please refer to this wiki page "Using DM8127/DM388 CSK as STA for streaming over Wi-Fi" section.
    Also, please can you run this command on CSK console when you observe timeout error ?
    • ifconfig
    • ps -aux | grep -rni system_server
  • Please close the thread if issue is resolved
  • Hello Ravikiran,
    Thank you for your reply and sorry for my late reply.
    We have connected Ethernet cable to the CSK and used the commands mentioned by you:
    1. ifconfig
    2. ps -aux | grep -rni system_server
    Please see the log below:
    reading u-boot.img
    reading u-boot.img
    I2C: ready
    DRAM: 1 GiB
    MMC: OMAP SD/MMC: 0
    cpsw
    Hit any key to stop autoboot: 1 0
    reading uImage
    2662320 bytes read in 306 ms (8.3 MiB/s)
    Starting kernel ...
    [ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
    [ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
    [ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highmem)
    [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [ 0.000016] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
    [ 0.008264] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
    [ 0.017840] OMAP clocksource: timer1 at 20000000 Hz
    [ 0.023136] Console: colour dummy device 80x30
    [ 0.027835] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
    [ 0.086909] pid_max: default: 32768 minimum: 301
    [ 0.091861] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.098774] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.106822] Initializing cgroup subsys io
    [ 0.111052] Initializing cgroup subsys memory
    [ 0.115675] Initializing cgroup subsys devices
    [ 0.120349] Initializing cgroup subsys freezer
    [ 0.125029] Initializing cgroup subsys pids
    [ 0.129443] CPU: Testing write buffer coherency: ok
    [ 0.134897] Setting up static identity map for 0x800082c0 - 0x80008318
    [ 0.142707] devtmpfs: initialized
    [ 0.168775] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [ 0.217109] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.229248] pinctrl core: initialized pinctrl subsystem
    [ 0.236041] NET: Registered protocol family 16
    [ 0.242281] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.255239] OMAP GPIO hardware version 0.1
    [ 0.267813] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
    [ 0.301506] edma 49000000.edma: TI EDMA DMA engine driver
    [ 0.309770] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
    [ 0.323374] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
    [ 0.337045] media: Linux media interface: v0.10
    [ 0.341858] Linux video capture interface: v2.00
    [ 0.346767] pps_core: LinuxPPS API ver. 1 registered
    [ 0.351961] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.361488] PTP clock support registered
    [ 0.365629] EDAC MC: Ver: 3.0.0
    [ 0.369682] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.377084] clocksource: Switched to clocksource timer1
    [ 0.394546] NET: Registered protocol family 2
    [ 0.399919] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.407234] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.413872] TCP: Hash tables configured (established 1024 bind 1024)
    [ 0.420590] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.426693] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.433417] NET: Registered protocol family 1
    [ 0.438369] RPC: Registered named UNIX socket transport module.
    [ 0.444552] RPC: Registered udp transport module.
    [ 0.449510] RPC: Registered tcp transport module.
    [ 0.454436] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.462491] omap-iommu 55082000.mmu: 55082000.mmu registered
    [ 0.469595] futex hash table entries: 256 (order: -1, 3072 bytes)
    [ 0.486583] NFS: Registering the id_resolver key type
    [ 0.491980] Key type id_resolver registered
    [ 0.496372] Key type id_legacy registered
    [ 0.502266] io scheduler noop registered
    [ 0.506404] io scheduler deadline registered
    [ 0.511159] io scheduler cfq registered (default)
    [ 0.517479] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
    [ 0.598574] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [ 0.609592] console [ttyS0] disabled
    [ 0.613407] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
    [ 0.622366] console [ttyS0] enabled
    [ 0.629559] bootconsole [earlycon0] disabled
    [ 0.639362] Reference Linux version 4.4.12
    [ 0.643659] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
    [ 0.662205] allocated heap buffer 0xc8000000 of size 0x4000000
    [ 0.668106] cmemk initialized
    [ 0.678458] loop: module loaded
    [ 0.747142] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
    [ 0.753279] libphy: 4a100800.mdio: probed
    [ 0.758179] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
    [ 0.767181] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c1:2c
    [ 0.777268] 47401300.usb-phy supply vcc not found, using dummy regulator
    [ 0.807337] mousedev: PS/2 mouse device common for all mice
    [ 0.813585] rtc rtc0: invalid alarm value: 2010-1-1 0:0:60
    [ 0.819424] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
    [ 0.826849] i2c /dev entries driver
    [ 0.831368] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
    [ 0.838492] sdhci: Secure Digital Host Controller Interface driver
    [ 0.844701] sdhci: Copyright(c) Pierre Ossman
    [ 0.972585] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
    [ 0.991722] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
    [ 0.997972] mmc0: new high speed SDIO card at address 0001
    [ 1.007347] Synopsys Designware Multimedia Card Interface Driver
    [ 1.013842] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 1.020823] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
    [ 1.026979] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
    [ 1.038740] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
    [ 1.046017] davinci_evm sound: snd_soc_register_card failed (-517)
    [ 1.053481] NET: Registered protocol family 10
    [ 1.060358] sit: IPv6 over IPv4 tunneling driver
    [ 1.065838] NET: Registered protocol family 17
    [ 1.070502] Key type dns_resolver registered
    [ 1.075037] omap_voltage_late_init: Could not get sys clk.
    [ 1.080947] Power Management for TI81XX.
    [ 1.090131] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [ 1.095316] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [ 1.102931] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
    [ 1.109421] nand: Micron MT29F2G16ABAEAWP
    [ 1.113455] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    [ 1.121092] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
    [ 1.126507] 8 ofpart partitions found on MTD device 8000000.nand
    [ 1.132563] Creating 8 MTD partitions on "8000000.nand":
    [ 1.137921] 0x000000000000-0x000000020000 : "NAND.SPL"
    [ 1.147700] 0x000000020000-0x000000420000 : "NAND.u-boot"
    [ 1.155920] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
    [ 1.163025] 0x000000440000-0x000000a40000 : "NAND.kernel"
    [ 1.172130] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
    [ 1.181913] mmc1: host does not support reading read-only switch, assuming write-enable
    [ 1.197162] mmc1: new high speed SDHC card at address 0007
    [ 1.217143] mmcblk0: mmc1:0007 SD16G 14.5 GiB
    [ 1.223108] mmcblk0: p1 p2
    [ 1.272201] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
    [ 1.279573] 0x00000ca80000-0x00000d680000 : "NAND.data"
    [ 1.290412] 0x00000d680000-0x000010000000 : "NAND.reserved"
    [ 1.353843] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
    [ 1.361543] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
    [ 1.369029] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
    [ 1.375834] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
    [ 1.382905] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
    [ 1.392320] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [ 1.414150] wlan-en-regulator: disabling
    [ 1.418505] ALSA device list:
    [ 1.421494] #0: TI81XX-CSK
    [ 1.426508] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
    [ 4.656598] EXT4-fs (mmcblk0p2): recovery complete
    [ 4.672093] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 4.680303] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [ 4.695873] devtmpfs: mounted
    [ 4.699490] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
    [ 4.705874] This architecture does not have kernel memory protection.
    [ 4.970629] systemd[1]: System time before build time, advancing clock.
    [ 4.998339] random: systemd urandom read with 21 bits of entropy available
    [ 5.018388] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [ 5.037190] systemd[1]: Detected architecture arm.
    [ 5.069201] systemd[1]: Set hostname to <ti81xx>.
    [ 5.359236] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [ 5.512055] systemd[1]: Listening on udev Control Socket.
    [ 5.537592] systemd[1]: Listening on udev Kernel Socket.
    [ 5.557658] systemd[1]: Listening on Journal Socket.
    [ 5.577385] systemd[1]: Reached target Remote File Systems.
    [ 5.597527] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [ 5.627904] systemd[1]: Listening on Network Service Netlink Socket.
    [ 5.657370] systemd[1]: Reached target Swap.
    [ 5.677631] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 5.707346] systemd[1]: Reached target Timers.
    [ 5.727608] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ 5.757337] systemd[1]: Reached target Paths.
    [ 5.781309] systemd[1]: Created slice System Slice.
    [ 5.815821] systemd[1]: Mounting POSIX Message Queue File System...
    [ 5.860481] systemd[1]: Mounting /var/volatile...
    [ 5.897984] systemd[1]: Reached target Slices.
    [ 5.923929] systemd[1]: Mounting /media/ram...
    [ 5.949211] systemd[1]: Created slice system-getty.slice.
    [ 5.965133] systemd[1]: Starting udev Kernel Device Manager...
    [ 6.029690] systemd[1]: Mounting Temporary Directory...
    [ 6.058852] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ 6.098522] systemd[1]: Starting udev Coldplug all Devices...
    [ 6.131784] systemd[1]: Starting Synchronize System and HW clocks...
    [ 6.245561] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 6.267755] systemd[1]: Listening on Syslog Socket.
    [ 6.286523] systemd[1]: Starting Journal Service...
    [ 6.359109] systemd[1]: Mounted POSIX Message Queue File System.
    [ 6.397659] systemd[1]: Mounted Temporary Directory.
    [ 6.427637] systemd[1]: Mounted /var/volatile.
    [ 6.447572] systemd[1]: Mounted /media/ram.
    [ 6.468344] systemd[1]: Started udev Kernel Device Manager.
    [ 6.488097] systemd[1]: Started Journal Service.
    [ 7.597804] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
    [ 7.622032] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
    [ 7.652012] autorun-usecase.sh[113]: : values=115,115
    [ 7.672571] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
    [ 7.755583] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
    [ 7.792096] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
    [ 7.811996] autorun-usecase.sh[113]: : values=72,72
    [ 7.832687] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
    [ 7.878716] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
    [ 7.902170] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
    [ 7.922082] autorun-usecase.sh[113]: : values=on
    [ 7.956424] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
    [ 7.982617] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
    [ 8.000143] autorun-usecase.sh[113]: : values=on
    [ 8.041941] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
    [ 8.096675] ubi0: attaching mtd6
    [ 8.297479] net eth0: initializing cpsw version 1.10 (0)
    [ 8.302840] net eth0: initialized cpsw ale version 1.3
    [ 8.311353] net eth0: phy found : id is : 0x2000a231
    [ 8.316392] libphy: PHY not found
    [ 8.319844] net eth0: phy "" not found on slave 1, err -19
    [ 8.337559] ubi0: scanning is finished
    [ 8.378998] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
    [ 8.384970] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
    [ 8.391941] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
    [ 8.398699] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
    [ 8.405692] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
    [ 8.411655] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
    [ 8.418933] ubi0: max/mean erase counter: 33/17, WL threshold: 4096, image sequence number: 2367567630
    [ 8.428297] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
    [ 8.437965] ubi0: background thread "ubi_bgt0d" started, PID 146
    [ 8.505267] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 8.652439] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
    [ 9.287269] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
    [ 9.352067] UBIFS (ubi0:0): recovery needed
    [ 9.571901] UBIFS (ubi0:0): recovery completed
    [ 9.576482] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
    [ 9.584508] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
    [ 9.594491] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
    [ 9.604640] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
    [ 9.611131] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID CCD16CCE-643B-4FE0-8D48-DEAEE5B4A223, small LPT model
    [ 10.415849] ubi1: attaching mtd7
    [ 10.723446] ubi1: scanning is finished
    [ 10.744001] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
    [ 10.750395] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
    [ 10.757332] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
    [ 10.764064] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
    [ 10.771073] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
    [ 10.777120] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
    [ 10.784379] ubi1: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 455573015
    [ 10.793480] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
    [ 10.810973] ubi1: background thread "ubi_bgt1d" started, PID 168
    0tarting thermal-zone-init.service...
    d[ OK ] Started thermal-zone-init.service.
    [ 10.909924] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
    [ 11.467213] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 182
    [ 11.490331] UBIFS (ubi1:0): recovery needed
    [ 11.509994] UBIFS (ubi1:0): recovery completed
    [ 11.514568] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
    [ 11.522597] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
    [ 11.532582] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
    [ 11.543082] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
    [ 11.549748] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 9B011D6F-144D-4DAC-8697-9B0E6BA1215C, small LPT model
    [ 12.063672] autorun-usecase.sh[113]: wifi: in STA mode
    _____ _____ _ _
    |___| |___|
    ti81xx login: [ 18.814092] cfg80211: World regulatory domain updated:
    [ 18.819353] cfg80211: DFS Master region: unset
    [ 18.823733] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    [ 18.833561] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.841624] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.849680] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.857740] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
    [ 18.867284] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
    [ 18.876810] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
    [ 18.884954] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    [ 18.893026] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    [ 19.358381] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [ 19.757734] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [ 19.784867] wlcore: loaded
    [ 20.398908] wlcore: PHY firmware version: Rev 8.2.0.0.232
    [ 20.510263] wlcore: firmware booted (Rev 8.9.0.0.48)
    [ 20.520551] random: nonblocking pool is initialized
    [ 20.533962] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [ 26.037570] autorun-usecase.sh[113]: SSID: ORTLINGHAUS-Tikona
    [ 26.039404] autorun-usecase.sh[113]: SSID: NETGEAR83
    [ 26.042640] autorun-usecase.sh[113]: SSID: Inacces
    [ 26.046524] autorun-usecase.sh[113]: SSID: Tejovat_Eprize
    [ 26.048535] autorun-usecase.sh[113]: SSID: JioFi2_ED54B0
    [ 26.050295] autorun-usecase.sh[113]: SSID: NETGEAR83-5G
    [ 26.465321] <1>SysLink version : 2.21.02.10
    [ 26.465321] SysLink module created on Date:Feb 13 2017 Time:17:42:37
    [ 26.475992] <1>Trace enabled
    [ 26.478920] <1>Trace SetFailureReason enabled
    [ 26.577156] autorun-usecase.sh[113]: /dev/mem opened.
    [ 26.579198] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
    [ 26.581457] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
    [ 26.583184] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
    [ 26.587024] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
    [ 26.588785] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
    [ 26.590374] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
    [ 26.591801] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
    [ 26.593208] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
    [ 26.594830] autorun-usecase.sh[113]: DDR IOs RX is shutdown
    [ 26.596237] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
    [ 27.564611] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (228) - No such process
    [ 27.588736] autorun-usecase.sh[113]: [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
    [ 27.597022] autorun-usecase.sh[113]: [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
    [ 27.600212] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
    [ 27.605536] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
    [ 27.671126] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
    [ 28.698749] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
    [ 28.700541] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
    [ 28.701924] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
    [ 28.703182] autorun-usecase.sh[113]: hidden sectors 0x0000;
    [ 28.704418] autorun-usecase.sh[113]: logical sector size is 512,
    [ 28.715233] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
    [ 28.720405] autorun-usecase.sh[113]: drive number 0x80;
    [ 28.722439] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
    [ 28.724636] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
    [ 28.727528] autorun-usecase.sh[113]: There is 1 reserved sector.
    [ 28.729177] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
    [ 28.730940] autorun-usecase.sh[113]: Volume ID is 9c7b5535, no volume label.
    [ 28.980370] Mass Storage Function, version: 2009/09/11
    [ 28.985561] LUN: removable file: (no medium)
    [ 28.990276] LUN: removable file: /dev/sbulla
    [ 28.994573] Number of LUNs=1
    [ 29.028101] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
    [ 29.035150] g_mass_storage gadget: userspace failed to provide iSerialNumber
    [ 29.042275] g_mass_storage gadget: g_mass_storage ready
    [ 29.101259] autorun-usecase.sh[113]: Creat queue id:0
    [ 29.103426] autorun-usecase.sh[113]: queue id:0
    [ 29.106900] autorun-usecase.sh[113]: Creat queue id:32769
    [ 29.113816] autorun-usecase.sh[113]: queue id:32769
    [ 29.119115] autorun-usecase.sh[113]: Creat queue id:65538
    [ 29.121105] autorun-usecase.sh[113]: queue id:65538
    [ 29.130117] autorun-usecase.sh[113]: Creat queue id:98307
    [ 29.140135] autorun-usecase.sh[113]: queue id:98307
    [ 29.143729] autorun-usecase.sh[113]: queue id:32769
    [ 29.220905] autorun-usecase.sh[113]: [host] Attached to slave procId 1.
    [ 31.308062] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [ 31.316003] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ 32.740901] autorun-usecase.sh[113]: [host] Attached to slave procId 0.
    [ 32.744411] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
    [ 32.926547] autorun-usecase.sh[113]: [host] Started slave procId 1.
    [ 32.970325] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
    [ 33.008190] autorun-usecase.sh[113]: [host] Started slave procId 0.
    [ 33.009940] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
    [ 33.011935] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
    [ 33.095017] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
    [ 33.114821] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
    [ 33.179528] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 33.181391] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 33.182802] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 33.184119] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
    [ 33.279376] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 33.281274] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 33.282691] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 33.284031] autorun-usecase.sh[113]: [m3video] Received character 's'
    [ 33.309908] autorun-usecase.sh[113]: queue id:65538
    [ 33.311891] autorun-usecase.sh[113]: Creat queue id:131076
    [ 33.313499] autorun-usecase.sh[113]: queue id:131076
    [ 33.319211] autorun-usecase.sh[113]: CPU is TI812x
    [ 33.321254] autorun-usecase.sh[113]: vsenable : 0
    [ 33.479966] autorun-usecase.sh[113]: Creat queue id:163845
    [ 33.482583] autorun-usecase.sh[113]: queue id:163845
    [ 33.484223] autorun-usecase.sh[113]: queue id:65538
    [ 33.533721] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 33.535681] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 33.537110] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 33.577191] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 33.578988] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 33.584773] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 33.604867] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 33.606684] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 33.619432] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 33.622489] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
    [ 33.625268] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
    [ 33.627209] autorun-usecase.sh[113]: [m3video]
    [ 33.628876] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
    [ 33.630489] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
    [ 33.632124] autorun-usecase.sh[113]: [m3video]
    [ 33.633704] autorun-usecase.sh[113]: [m3video] 36: SYSTEM : System Common Init in progress !!!
    [ 33.635203] autorun-usecase.sh[113]: [m3video] 36: SYSTEM: IPC init in progress !!!
    [ 33.636960] autorun-usecase.sh[113]: [m3video] 36: SYSTEM: Attaching to [HOST] ...
    [ 33.638512] autorun-usecase.sh[113]: [m3video] 86: SYSTEM: Attaching to [HOST] ...
    [ 33.640055] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
    [ 33.641572] autorun-usecase.sh[113]: [m3vpss ]
    [ 33.643061] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
    [ 33.644564] autorun-usecase.sh[113]: [m3vpss ]
    [ 33.646085] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
    [ 33.647614] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
    [ 33.649092] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
    [ 33.651240] autorun-usecase.sh[113]: [m3video] 100: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    [ 33.652858] autorun-usecase.sh[113]: [m3video] 100: SYSTEM: Attaching to [VPSS-M3] ...
    [ 33.654418] autorun-usecase.sh[113]: [m3vpss ] 117: SYSTEM: Attaching to [HOST] ...
    [ 33.656054] autorun-usecase.sh[113]: [m3vpss ] 120: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    [ 33.657575] autorun-usecase.sh[113]: [m3vpss ] 120: SYSTEM: Attaching to [VIDEO-M3] ...
    [ 33.659052] autorun-usecase.sh[113]: [m3video] 150: SYSTEM: Attaching to [VPSS-M3] ...
    [ 33.660645] autorun-usecase.sh[113]: [m3video] 171: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
    [ 33.662190] autorun-usecase.sh[113]: [m3vpss ] 170: SYSTEM: Attaching to [VIDEO-M3] ...
    [ 33.663687] autorun-usecase.sh[113]: [m3video] 171: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
    [ 33.665175] autorun-usecase.sh[113]: [m3vpss ] 171: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
    [ 33.666920] autorun-usecase.sh[113]: [m3vpss ] 171: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
    [ 33.668460] autorun-usecase.sh[113]: [m3vpss ] 171: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
    [ 33.669964] autorun-usecase.sh[113]: [m3vpss ] 172: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
    [ 33.671581] autorun-usecase.sh[113]: [m3vpss ] 173: SYSTEM: Notify register to [HOST] line 0, event 12 ...
    [ 33.673100] autorun-usecase.sh[113]: [m3vpss ] 174: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
    [ 33.674609] autorun-usecase.sh[113]: [m3vpss ] 174: SYSTEM: IPC init DONE !!!
    [ 33.676198] autorun-usecase.sh[113]: [m3vpss ] 185: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
    [ 33.677749] autorun-usecase.sh[113]: [m3vpss ] 185: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
    [ 33.679337] autorun-usecase.sh[113]: [m3vpss ] 187: SYSTEM : System Common Init Done !!!
    [ 33.680950] autorun-usecase.sh[113]: [m3video] 271: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
    [ 33.682467] autorun-usecase.sh[113]: [m3video] 271: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
    [ 33.684030] autorun-usecase.sh[113]: [m3video] 272: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
    [ 33.685594] autorun-usecase.sh[113]: [m3video] 273: SYSTEM: Notify register to [HOST] line 0, event 12 ...
    [ 33.687227] autorun-usecase.sh[113]: [m3video] 274: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
    [ 33.688783] autorun-usecase.sh[113]: [m3video] 274: SYSTEM: IPC init DONE !!!
    [ 33.690544] autorun-usecase.sh[113]: [m3video] 285: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
    [ 33.692163] autorun-usecase.sh[113]: [m3video] 285: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
    [ 33.693683] autorun-usecase.sh[113]: [m3video] 287: SYSTEM : System Common Init Done !!!
    [ 33.695206] autorun-usecase.sh[113]: [m3video] 587: SYSTEM : System Video Init in progress !!!
    [ 33.696793] autorun-usecase.sh[113]: [m3vpss ] 587: SYSTEM : System VPSS Init in progress !!!
    [ 33.698303] autorun-usecase.sh[113]: [m3video] 587: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
    [ 33.699967] autorun-usecase.sh[113]: [m3video] 588: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
    [ 33.701580] autorun-usecase.sh[113]: [m3video] 588: SYSTEM: ListElem Shared Addr = 0xbe984180
    [ 33.703086] autorun-usecase.sh[113]: [m3video] 590: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
    [ 34.036860] autorun-usecase.sh[113]: [m3video] 591: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
    [ 34.038514] autorun-usecase.sh[113]: [m3video] 591: SYSTEM: ListElem Shared Addr = 0xbe987680
    [ 34.040245] autorun-usecase.sh[113]: [m3video] 601: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
    [ 34.041851] autorun-usecase.sh[113]: [m3video] 601: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
    [ 34.043376] autorun-usecase.sh[113]: [m3video] 601: SYSTEM: ListElem Shared Addr = 0xbe98ab80
    [ 34.044867] autorun-usecase.sh[113]: [m3video] 604: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
    [ 34.046426] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
    [ 34.047935] autorun-usecase.sh[113]: [m3video] 604: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
    [ 34.049503] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
    [ 34.051097] autorun-usecase.sh[113]: [m3video] 604: SYSTEM: ListElem Shared Addr = 0xbe9a4800
    [ 34.052648] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
    [ 34.054139] autorun-usecase.sh[113]: [m3video] 606: HDVICP: Doing PRCM for IVAHD[0] ...
    [ 34.055621] autorun-usecase.sh[113]: [m3vpss ] 606: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
    [ 34.057094] autorun-usecase.sh[113]: [m3video] 607: HDVICP: PRCM for IVAHD[0] ... DONE.
    [ 36.805501] autorun-usecase.sh[113]: [m3vpss ] 607: SYSTEM: CreatinApproDrvInit: 7
    [ 36.817763] autorun-usecase.sh[113]: queue id:163845
    [ 39.140736] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 39.142585] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 39.144011] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 39.145359] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
    [ 39.804739] autorun-usecase.sh[113]: queue id:0
    [ 39.820862] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
    [ 39.822679] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
    [ 39.827236] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    [ 39.830578] autorun-usecase.sh[113]: [m3video] Received character 't'
    [ 39.856809] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
    [ 39.924705] DMA: Module install successful, device major num = 244
    [ 39.931107] DRV: Module install successful
    [ 39.935244] DRV: Module built on Feb 13 2017 17:52:30
    [ 40.003867]
    [ 40.003867] soc_is_dm38x
    [ 40.077675] HDMI W1 rev 4.0
    [ 40.080527] HDMI CEC Spec version 1.2
    [ 40.425128] autorun-usecase.sh[113]: ApproDrvInit: 3
    [ 40.438453] autorun-usecase.sh[113]: queue id:163845
    [ 40.457181] I2C No Ack
    [ 40.463105] HDMI failed to read E-EDID
    [ 40.956008] autorun-usecase.sh[113]: [host]
    [ 40.958043] autorun-usecase.sh[113]: [host] ORG 0x46c00524: 0
    [ 40.959878] autorun-usecase.sh[113]: [host] NEW 0x46c00524: 2
    [ 40.961764] autorun-usecase.sh[113]: [host]
    [ 40.963499] autorun-usecase.sh[113]: [host] Application Start Completed
    [ 41.063299] autorun-usecase.sh[113]: [host] 0: SYSTEM: System Common Init in progress !!!
    [ 41.065531] autorun-usecase.sh[113]: [host] 0: SYSTEM: IPC init in progress !!!
    [ 41.068593] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
    [ 41.073671] autorun-usecase.sh[113]: [host] 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
    [ 41.079121] autorun-usecase.sh[113]: [host] 12: SYSTEM: C[ 41.116232] DMA: ChannelID allocated:4
    [ 41.090942] autorun-usecase.sh[113]: [host] 12: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
    [ 41.097307] autorun-usecase.sh[113]: [host] [ 41.136416] DMA: ChannelID allocated:5
    12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
    [ 41.108411] autorun-usecase.sh[113]: [host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
    [ 41.110470] autorun-usecase.sh[113]: [host] 13: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
    [ 41.112206] autorun-usecase.sh[113]: [host] 15: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
    [ 41.113926] autorun-usecase.sh[113]: [host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
    [ 41.115561] autorun-usecase.sh[113]: [host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
    [ 41.117220] autorun-usecase.sh[113]: [host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
    [ 41.128428] autorun-usecase.sh[113]: [host] 16: SYSTEM: IPC init DONE !!!
    [ 41.132775] autorun-usecase.sh[113]: [host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
    [ 41.134586] autorun-usecase.sh[113]: [host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
    [ 41.136307] autorun-usecase.sh[113]: [host] 18: SYSTEM: ListElem Shared Addr = 0xb55c2580
    [ 41.138364] autorun-usecase.sh[113]: [host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
    [ 41.145601] autorun-usecase.sh[113]: [host] 20: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
    [ 41.147690] autorun-usecase.sh[113]: [host] 20: SYSTEM: ListElem Shared Addr = 0xb55dc200
    [ 41.155960] autorun-usecase.sh[113]: [host] 30: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
    [ 41.166901] autorun-usecase.sh[113]: [host] 30: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
    [ 41.172725] autorun-usecase.sh[113]: [host] 30: SYSTEM: ListElem Shared Addr = 0xb55f5e80
    [ 41.175937] autorun-usecase.sh[113]: [host] 32: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
    [ 41.181006] autorun-usecase.sh[113]: [host] 32: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
    [ 41.182926] autorun-usecase.sh[113]: [host] 32: SYSTEM: ListElem Shared Addr = 0xb5615880
    [ 41.184747] autorun-usecase.sh[113]: [host] 34: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
    [ 41.186391] autorun-usecase.sh[113]: [host] 34: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
    [ 41.188041] autorun-usecase.sh[113]: [host] 35: SYSTEM: ListElem Shared Addr = 0xb5635280
    [ 41.189666] autorun-usecase.sh[113]: [host] 36: SYSTEM: System Common Init Done !!!
    [ 41.191595] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xa736b000,size = 65011712
    [ 41.193242] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
    [ 41.194929] autorun-usecase.sh[113]: [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
    [ 41.198232] autorun-usecase.sh[113]: [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
    [ 41.199925] autorun-usecase.sh[113]: [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
    [ 41.201662] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xb6efe000,size = 33603
    [ 41.203338] autorun-usecase.sh[113]: [host] DCC buffer allocated for size 33603
    [ 41.205061] autorun-usecase.sh[113]: [host] DCC Default File Intialization Done
    [ 41.206669] autorun-usecase.sh[113]: [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
    [ 41.208401] autorun-usecase.sh[113]: queue id:0
    [ 41.210098] autorun-usecase.sh[113]: queue id:32769
    [ 41.220443] autorun-usecase.sh[113]: [host]
    [ 41.222470] autorun-usecase.sh[113]: ********** SMART ANALYTICS USECASE ********
    [ 41.224412] autorun-usecase.sh[113]: [host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
    [ 41.226387] autorun-usecase.sh[113]: [host] 163: MCFW : CPU Revision [ES1.0] !!!
    [ 41.228121] autorun-usecase.sh[113]: [host] 163: MCFW : Detected [UNKNOWN] Board !!!
    [ 41.229909] autorun-usecase.sh[113]: [host] 163: MCFW : Base Board Revision [REV A] !!!
    [ 41.254658] autorun-usecase.sh[113]: g ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
    [ 41.256423] autorun-usecase.sh[113]: [m3video] 607: SYSTEM : Initializing Links !!!
    [ 41.258174] autorun-usecase.sh[113]: [m3vpss ] 607: SYSTEM: ListElem Shared Addr = 0xbe9be480
    [ 41.259816] autorun-usecase.sh[113]: [m3vpss ] 610: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
    [ 41.261581] autorun-usecase.sh[113]: [m3video] 608: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
    [ 41.263268] autorun-usecase.sh[113]: [m3vpss ] 610: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
    [ 41.265045] autorun-usecase.sh[113]: [m3vpss ] 611: SYSTEM: ListElem Shared Addr = 0xbe9c1980
    [ 41.266706] autorun-usecase.sh[113]: [m3video] 608: SYSTEM : FREE SPACE : SR0 Heap = 15985792 B (15 MB)
    [ 41.268403] autorun-usecase.sh[113]: [m3video] 608: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
    [ 41.270201] autorun-usecase.sh[113]: [m3vpss ] 624: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
    [ 41.271886] autorun-usecase.sh[113]: [m3video] 609: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
    [ 41.273582] autorun-usecase.sh[113]: [m3vpss ] 624: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
    [ 41.275310] autorun-usecase.sh[113]: [m3vpss ] 625: SYSTEM: ListElem Shared Addr = 0xbe9c4e80
    [ 41.277133] autorun-usecase.sh[113]: [m3video] 609: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
    [ 41.278858] autorun-usecase.sh[113]: [m3vpss ] 627: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
    [ 41.280703] autorun-usecase.sh[113]: [m3video] 610: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
    [ 41.282384] autorun-usecase.sh[113]: [m3vpss ] 628: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
    [ 41.616661] autorun-usecase.sh[113]: [m3vpss ] 628: SYSTEM: ListElem Shared Addr = 0xbe9e4880
    [ 41.618509] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
    [ 41.620223] autorun-usecase.sh[113]: [m3vpss ] 631: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
    [ 41.621980] autorun-usecase.sh[113]: [m3vpss ] 631: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
    [ 41.623641] autorun-usecase.sh[113]: [m3vpss ] 631: SYSTEM: ListElem Shared Addr = 0xbea04280
    [ 41.625316] autorun-usecase.sh[113]: [m3vpss ] 637: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
    [ 41.627032] autorun-usecase.sh[113]: [m3vpss ] 638: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
    [ 41.628748] autorun-usecase.sh[113]: [m3vpss ] 638: SYSTEM: ListElem Shared Addr = 0xbea23c80
    [ 41.630416] autorun-usecase.sh[113]: [m3vpss ] 641: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
    [ 41.632121] autorun-usecase.sh[113]: [m3vpss ] 641: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
    [ 41.633747] autorun-usecase.sh[113]: [m3vpss ] 641: SYSTEM: ListElem Shared Addr = 0xbea3d900
    [ 41.635405] autorun-usecase.sh[113]: [m3vpss ] 643: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
    [ 41.637204] autorun-usecase.sh[113]: [m3vpss ] 644: SYSTEM : FVID2 Init in progress !!!
    [ 41.639015] autorun-usecase.sh[113]: [m3video] 670: SYSTEM : Initializing Links ... DONE !!!
    [ 41.640805] autorun-usecase.sh[113]: [m3video] 670: SYSTEM : System Video Init Done !!!
    [ 41.642476] autorun-usecase.sh[113]: [m3vpss ] 713: SYSTEM : FVID2 Init in progress DONE !!!
    [ 41.644369] autorun-usecase.sh[113]: [m3vpss ] 713: SYSTEM : Device Init in progress !!!
    [ 41.646088] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
    [ 41.647819] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
    [ 41.649486] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
    [ 41.651236] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
    [ 41.652872] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
    [ 41.654564] autorun-usecase.sh[113]: [m3vpss ] 907: SYSTEM : Device Init in progress DONE !!!
    [ 41.656227] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
    [ 41.657975] autorun-usecase.sh[113]: [m3vpss ] 6016: SYSTEM : System VPSS Init Done !!!
    [ 41.659595] autorun-usecase.sh[113]: [m3vpss ] 6016: UTILS: DMA: HWI Create for INT62[ 41.885290] DMA: ChannelID allocated:6
    [ 41.661363] autorun-usecase.sh[113]: [m3vpss ] 6017: [ 41.893364] DMA: ChannelID allocated:7
    [ 41.662997] autorun-usecase.sh[113]: [m3vpss ] 6017: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
    [ 41.664655] autorun-usecase.sh[113]: [m3vpss ] 6017: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
    [ 41.666295] autorun-usecase.sh[113]: [m3vpss ] 6018: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
    [ 41.667987] autorun-usecase.sh[113]: [m3vpss ] 6018: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
    [ 41.669606] autorun-usecase.sh[113]: [m3vpss ] 6018: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
    [ 41.671377] autorun-usecase.sh[113]: [m3vpss ] 6149: SYSTEM : Initializing Links ... DONE !!!
    [ 41.673263] autorun-usecase.sh[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
    [ 41.674927] autorun-usecase.sh[113]: [[ 41.977714] DMA: ChannelID allocated:12
    [ 41.676635] autorun-usecase.sh[113[ 41.984783] DMA: ChannelID allocated:13
    ]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO[ 41.994268] DMA: ChannelID allocated:14
    2
    [ 41.678273] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
    [ 41.679965] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
    [ 41.681665] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
    [ 41.683371] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
    [ 41.685004] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
    [ 41.686686] autorun-usecase.sh[113]: [m3vpss ] 8165: CAMERA: Create in progress !!!
    [ 41.688358] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
    [ 41.690064] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
    [ 41.691674] autorun-usecase.sh[113]: [m3vpss ] 8165: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
    [ 41.693509] autorun-usecase.sh[113]: [m3vpss ] 8166: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
    [ 42.052690] autorun-usecase.sh[113]: [m3vp
    [ 42.054582] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
    [ 42.056292] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
    [ 42.058035] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
    [ 42.059734] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
    [ 42.062418] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
    [ 42.292461] autorun-usecase.sh[113]: [host] IpcBitsInLink_tskMain:Entered
    [ 42.295087] autorun-usecase.sh[113]: [host] 1234: IPC_BITS_IN : Create in progress !!!
    [ 42.296889] autorun-usecase.sh[113]: [host] 1234: IPC_BITS_IN : ListMPOpen start !!!
    [ 42.298621] autorun-usecase.sh[113]: [host] 1234: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
    [ 42.300508] autorun-usecase.sh[113]: [host] 1235: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
    [ 42.302630] autorun-usecase.sh[113]: [host] 1235: IPC_BITS_IN : ListMPOpen done !!!
    [ 42.304359] autorun-usecase.sh[113]: [host] 1236: IPC_BITS_IN : System_linkGetInfo done !!!
    [ 42.306027] autorun-usecase.sh[113]: [host] 1236: IPC_BITS_IN : Create Done !!!
    [ 42.333835] autorun-usecase.sh[113]: queue id:0
    [ 42.350444] autorun-usecase.sh[113]: ss ] Iss_captCreate:1661
    [ 42.351283] autorun-usecase.sh[113]: [m3vpss ] 8375: CAMERA: Create Done !!!
    [ 42.351973] autorun-usecase.sh[113]: [m3vpss ] 8464: CAMERA: Detect video in progress !!!
    [ 42.352652] autorun-usecase.sh[113]: [m3vpss ] 8464: CAMERA: Detect video Done !!!
    [ 42.353242] autorun-usecase.sh[113]: [m3video] 8538: IPC_IN_M3 : Create in progress !!!
    [ 42.353896] autorun-usecase.sh[113]: [m3vpss ] 8536: DUP : Create Done !!!
    [ 42.354465] autorun-usecase.sh[113]: [m3video] 8539: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
    [ 42.355083] autorun-usecase.sh[113]: [m3vpss ] 8537: IPC_OUT_M3 : Create in progress !!!
    [ 42.355677] autorun-usecase.sh[113]: [m3video] 8539: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
    [ 42.356273] autorun-usecase.sh[113]: [m3vpss ] 8538: IPC_OUT_M3 : Create Done !!!
    [ 42.356883] autorun-usecase.sh[113]: [m3video] 8542: IPC_IN_M3 : Create Done !!!
    [ 42.357449] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
    [ 42.358244] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
    [ 42.358881] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
    [ 42.359523] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
    [ 42.360232] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
    [ 42.360818] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
    [ 42.361462] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
    [ 42.362057] autorun-usecase.sh[113]: [m3vpss ] 8722: IPC_IN_M3 : Create in progress !!!
    [ 42.362696] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
    [ 42.363258] autorun-usecase.sh[113]: [m3vpss ] 8722: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
    [ 42.363875] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
    [ 42.364467] autorun-usecase.sh[113]: [m3vpss ] 8722: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
    [ 42.365034] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
    [ 42.365704] autorun-usecase.sh[113]: [m3vpss ] 8723: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
    [ 42.366461] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
    [ 42.367135] autorun-usecase.sh[113]: [m3vpss ] 8725: IPC_IN_M3 : Create Done !!!
    [ 42.367781] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
    [ 42.368361] autorun-usecase.sh[113]: [m3vpss ] 8726: NSF: Create in progress !!!
    [ 42.368976] autorun-usecase.sh[113]: [m3video] 8720: IPC_OUT_M3 : Create in progress !!!
    [ 42.369568] autorun-usecase.sh[113]: [m3video] 8721: IPC_OUT_M3 : Create Done !!!
    [ 42.370239] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
    [ 42.370899] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
    [ 42.371600] autorun-usecase.sh[113]: [m3vpss ] 8849: NSF: Create Done !!!
    [ 42.372239] autorun-usecase.sh[113]: [m3vpss ] 8849: Mux : Creating... !!!
    [ 42.372815] autorun-usecase.sh[113]: [m3vpss ] 8851: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
    [ 42.373478] autorun-usecase.sh[113]: [m3vpss ] 8851: Mux : Create Done !!!
    [ 42.374201] autorun-usecase.sh[113]: [m3vpss ] 8858: DUP : Create Done !!!
    [ 42.374860] autorun-usecase.sh[113]: [m3vpss ] 8865: DUP : Create Done !!!
    [ 42.375476] autorun-usecase.sh[113]: [m3vpss ] 8865: Mux : Creating... !!!
    [ 42.376060] autorun-usecase.sh[113]: [m3vpss ] 8867: Mux : Create Done !!!
    [ 42.376756] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
    [ 42.377340] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
    [ 42.377975] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
    [ 42.378603] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
    [ 42.379242] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
    [ 42.379853] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
    [ 42.380513] autorun-usecase.sh[113]: [m3vpss ] 8877: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
    [ 42.381152] autorun-usecase.sh[113]: [m3vpss ] 8880: SWOSD : Create Done !!!
    [ 42.714530] autorun-usecase.sh[113]: [m3vpss ] 8952: DUP : Create Done !!!
    [ 42.715157] autorun-usecase.sh[113]: [m3vpss ] 8953: SCLR: Create in progress !!!
    [ 42.715738] autorun-usecase.sh[113]: [m3vpss ] 8958: SCLR : Loading Up-scaling Co-effs ...
    [ 42.716331] autorun-usecase.sh[113]: [m3vpss ] 8958: SCLR : Co-effs Loading ... DONE !!!
    [ 42.716900] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:0 USED:64
    [ 42.717508] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:1 USED:5952
    [ 42.718123] autorun-usecase.sh[113]: [m3vpss ] 8958: SCLR: Create Done !!!
    [ 42.718751] autorun-usecase.sh[113]: [m3vpss ] 8965: DUP : Create Done !!!
    [ 42.719480] autorun-usecase.sh[113]: [m3vpss ] 8904: VA : Create Done !!!
    [ 42.720207] autorun-usecase.sh[113]: [m3vpss ] 8922: FD : Alg Create Done !!!
    [ 42.720838] autorun-usecase.sh[113]: [m3vpss ] 8922: FD : Create Done !!!
    [ 42.721418] autorun-usecase.sh[113]: [m3vpss ] 8930: VA : ALG Init Done !!!
    [ 42.722031] autorun-usecase.sh[113]: [m3video] 8998: IPC_IN_M3 : Create in progress !!!
    [ 42.722594] autorun-usecase.sh[113]: [m3vpss ] 8996: IPC_OUT_M3 : Create in progress !!!
    [ 42.723289] autorun-usecase.sh[113]: [m3video] 8998: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
    [ 42.723856] autorun-usecase.sh[113]: [m3vpss ] 8997: IPC_OUT_M3 : Create Done !!!
    [ 42.724468] autorun-usecase.sh[113]: [m3video] 8999: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
    [ 42.725099] autorun-usecase.sh[113]: [m3vpss ] 8998: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR : failed !!!
    [ 42.725757] autorun-usecase.sh[113]: [m3video] 9001: IPC_IN_M3 : Create Done !!!
    [ 42.726397] autorun-usecase.sh[113]: [m3video] 9002: ENCODE: Create in progress ... !!!
    [ 42.726979] autorun-usecase.sh[113]: [m3video] 9128: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
    [ 42.727742] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
    [ 42.728356] autorun-usecase.sh[113]: [m3video] 9209: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
    [ 42.729049] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
    [ 42.729785] autorun-usecase.sh[113]: [m3video] 9293: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
    [ 42.730433] autorun-usecase.sh[113]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
    [ 42.731124] autorun-usecase.sh[113]: [m3video] 9294: ENCODE: All CH Create ... DONE !!!
    [ 42.731706] autorun-usecase.sh[113]: [m3video] ENCLINK:HEAPID:0 USED:28144
    [ 42.732505] autorun-usecase.sh[113]: [m3video] 9296: ENCODE: Create ... DONE !!!
    [ 59.807754] autorun-usecase.sh[113]: [m3video] 9263: VSTTimeOut occure in boot_proc.
    [ 59.808575] autorun-usecase.sh[113]: Program exit.
    [ 62.335557] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
    [ 62.336356] autorun-usecase.sh[113]: Program exit.
    _____ _____ _ _
    | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    | | _| .'| . | . | | __| _| . | | | -_| _| _|
    |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    |___| |___|
    Arago Project http://arago-project.org DM388_CSK ttyS0
    Arago 2016.05 DM388_CSK ttyS0
    DM388_CSK login: root
    root@DM388_CSK:~# ifconfig
    eth0 Link encap:Ethernet HWaddr 7C:66:9D:F8:C1:2C
    inet6 addr: fe80::7e66:9dff:fef8:c12c%132688/64 Scope:Link
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:0 (0.0 B) TX bytes:4945 (4.8 KiB)
    Interrupt:170
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1%132688/128 Scope:Host
    UP LOOPBACK RUNNING MTU:65536 Metric:1
    RX packets:6 errors:0 dropped:0 overruns:0 frame:0
    TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:609 (609.0 B) TX bytes:609 (609.0 B)
    wlan0 Link encap:Ethernet HWaddr 54:4A:16:13:11:7E
    UP BROADCAST MULTICAST MTU:1500 Metric:1
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    root@DM388_CSK:~# ps -aux | grep -rni system_server
    ps: invalid option -- 'a'
    BusyBox v1.24.1 (2016-12-02 14:05:48 IST) multi-call binary.
    Usage: ps
    root@DM388_CSK:~#
    Thanks!
  • Hi Santosh,
    I believe this post is duplicate of e2e.ti.com/.../2182417
    If so please close it.
  • Yes, You can close this thread.
    Santosh
    As you had replied that we can close this thread.
    So please verify answer and close this thread.
    Anuj
    Pathpartner Technology Pvt Ltd
  • You may not want to use MCTNF functionality.
    Please rebuild the package with below changes in Rules.make and let me know the status.
     Line 33 & 34:
    #IPNC_CONFIG := FULL_FEATURE
    IPNC_CONFIG := LOW_POWER
    Here disable  LOW_POWER and change mode to full feature.
    Line 68:
    DM388_MCTNF_ON := YES
    set this option to NO
    Then run make sysclean and sysall for clean build :)
  • Athor option:
    rm -rf /mnt/nand/sysenv.cfg file from board
