Part Number: MSP430FR4133
Tool/software: TI-RTOS
I'm using MSP430FR4133 evaluation board. I've created the project for MSP430 and when I try to create task using sysbios api Task_create() i'm facing the below error.
**** Build of configuration Debug for project MSP430_Test ****
"C:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 4 all -O
'Building file: ../syshlthmonitor.c'
'Invoking: MSP430 Compiler'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_17.3.0.STS/bin/cl430" -vmspx --use_hw_mpy=none --include_path="C:/ti/ccsv7/ccs_base/msp430/include" --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_17.3.0.STS/include" --include_path="C:/dev/Projects/Soliton/Code/Workspace/MSP430_Test" --include_path="C:/dev/Projects/Soliton/Code/Workspace/MSP430_Test/MWare" --include_path="C:/dev/Projects/Soliton/Code/Workspace/MSP430_Test/lwip/src/include" --include_path="C:/dev/Projects/Soliton/Code/Workspace/MSP430_Test/lwip/ports/C2000/include" --include_path="C:/dev/Projects/Soliton/Code/Workspace/MSP430_Test/lwip/src/include/ipv4" --include_path="C:/ti/xdctools_3_25_03_72/packages" --include_path="C:/ti/ccsv7/ccs_base" --include_path="C:/ti/bios_6_35_04_50/packages" --advice:power="all" --advice:hw_config="all" --define=__MSP430FR4133__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU40 --preproc_with_compile --preproc_dependency="syshlthmonitor.d" "../syshlthmonitor.c"
"C:/ti/xdctools_3_25_03_72/packages/xdc/std.h", line 155: warning #173-D: invalid type conversion
"C:/ti/xdctools_3_25_03_72/packages/xdc/std.h", line 156: warning #173-D: invalid type conversion
"C:/ti/xdctools_3_25_03_72/packages/xdc/std.h", line 160: warning #173-D: invalid type conversion
"C:/ti/xdctools_3_25_03_72/packages/xdc/std.h", line 161: warning #173-D: invalid type conversion
"../syshlthmonitor.c", line 128: remark #1546-D: (ULP 15.1) Detected consecutive bitfield assigns. Recommend using bit mask instead
"../syshlthmonitor.c", line 129: remark #1546-D: (ULP 15.1) Detected consecutive bitfield assigns. Recommend using bit mask instead
'Finished building: ../syshlthmonitor.c'
'Building target: MSP430_Test.out'
'Invoking: MSP430 Linker'
"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_17.3.0.STS/bin/cl430" -vmspx --use_hw_mpy=none --advice:power="all" --advice:hw_config="all" --define=__MSP430FR4133__ -g --printf_support=minimal --diag_warning=225 --diag_wrap=off --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU40 -z -m"MSP430_Test.map" --heap_size=160 --stack_size=160 --cinit_hold_wdt=on -i"C:/ti/ccsv7/ccs_base/msp430/include" -i"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_17.3.0.STS/lib" -i"C:/ti/ccsv7/tools/compiler/ti-cgt-msp430_17.3.0.STS/include" --reread_libs --diag_wrap=off --display_error_number --warn_sections --xml_link_info="MSP430_Test_linkInfo.xml" --use_hw_mpy=none --rom_model -o "MSP430_Test.out" "./main.obj" "./msp430fr413x_euscia0_uart_01.obj" "./msp430fr413x_euscia0_uart_03.obj" "./syshlthmonitor.obj" "./lwip/ports/C2000/netif/concertoif.obj" "./lwip/ports/C2000/perf.obj" "./lwip/ports/C2000/sys_arch.obj" "./lwip/src/api/api_lib.obj" "./lwip/src/api/api_msg.obj" "./lwip/src/api/err.obj" "./lwip/src/api/netbuf.obj" "./lwip/src/api/netdb.obj" "./lwip/src/api/netifapi.obj" "./lwip/src/api/tcpip.obj" "./lwip/src/core/def.obj" "./lwip/src/core/dns.obj" "./lwip/src/core/init.obj" "./lwip/src/core/mem.obj" "./lwip/src/core/memp.obj" "./lwip/src/core/netif.obj" "./lwip/src/core/pbuf.obj" "./lwip/src/core/raw.obj" "./lwip/src/core/stats.obj" "./lwip/src/core/sys.obj" "./lwip/src/core/tcp.obj" "./lwip/src/core/tcp_in.obj" "./lwip/src/core/tcp_out.obj" "./lwip/src/core/timers.obj" "./lwip/src/core/udp.obj" "./lwip/src/core/ipv4/autoip.obj" "./lwip/src/core/ipv4/icmp.obj" "./lwip/src/core/ipv4/igmp.obj" "./lwip/src/core/ipv4/inet.obj" "./lwip/src/core/ipv4/inet_chksum.obj" "./lwip/src/core/ipv4/ip.obj" "./lwip/src/core/ipv4/ip_addr.obj" "./lwip/src/core/ipv4/ip_frag.obj" "./lwip/src/netif/etharp.obj" "../lnk_msp430fr4133.cmd" -llibc.a
<Linking>
warning #10420-D: For FRAM devices, at start up, the GPIO power-on default high-impedance mode needs to be disabled to activate previously configured port settings. This can be done by clearing the LOCKLPM5 bit in PM5CTL0 register.
undefined first referenced
symbol in file
ti_sysbios_knl_Task_Object__create__S ./syshlthmonitor.obj
error #10234-D: unresolved symbols remain
remark #10371-D: (ULP 1.1) Detected no uses of low power mode state changing instructions
error #10010: errors encountered during linking; "MSP430_Test.out" not built
>> Compilation failure
makefile:190: recipe for target 'MSP430_Test.out' failed
gmake[1]: *** [MSP430_Test.out] Error 1
makefile:186: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
I've included the necessary header files ( #include <xdc/std.h> #include <ti/sysbios/knl/Task.h>). but still compilation is not successful.
So please help me to resolve this error.
Thanks in advance.
Mohanraj
